[GRASS-SVN] r34482 - in grass/trunk: include lib/gis
svn_grass at osgeo.org
Mon Nov 24 18:58:49 EST 2008
Author: glynn
Date: 2008-11-24 18:58:48 -0500 (Mon, 24 Nov 2008)
New Revision: 34482
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/env.c
grass/trunk/lib/gis/get_window.c
Add G_init_env()
Remove unnecessary return values
Miscellaneous clean-up
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2008-11-24 23:55:42 UTC (rev 34481)
+++ grass/trunk/include/gisdefs.h 2008-11-24 23:58:48 UTC (rev 34482)
@@ -427,6 +427,7 @@
int G_is_little_endian(void);
/* env.c */
+void G_init_env(void);
char *G_getenv(const char *);
char *G_getenv2(const char *, int);
char *G__getenv(const char *);
@@ -583,8 +584,8 @@
unsigned char *);
/* get_window.c */
-int G_get_window(struct Cell_head *);
-int G_get_default_window(struct Cell_head *);
+void G_get_window(struct Cell_head *);
+void G_get_default_window(struct Cell_head *);
char *G__get_window(struct Cell_head *, const char *, const char *,
const char *);
Modified: grass/trunk/lib/gis/env.c
--- grass/trunk/lib/gis/env.c 2008-11-24 23:55:42 UTC (rev 34481)
+++ grass/trunk/lib/gis/env.c 2008-11-24 23:58:48 UTC (rev 34482)
@@ -79,6 +79,12 @@
return (st->varmode);
+ read_env(G_VAR_GISRC);
+ read_env(G_VAR_MAPSET);
static int read_env(int loc)
char buf[200];
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c 2008-11-24 23:55:42 UTC (rev 34481)
+++ grass/trunk/lib/gis/get_window.c 2008-11-24 23:58:48 UTC (rev 34482)
@@ -25,7 +25,13 @@
#include <grass/gis.h>
#include <grass/glocale.h>
+static struct state {
+ int initialized;
+ struct Cell_head dbwindow;
+} state;
+static struct state *st = &state;
* \brief read the database region
@@ -44,59 +50,41 @@
* \return int
-int G_get_window(struct Cell_head *window)
+void G_get_window(struct Cell_head *window)
- static int first = 1;
- static struct Cell_head dbwindow;
- char *regvar;
+ const char *regvar, *err;
+ if (st->initialized) {
+ *window = st->dbwindow;
+ return;
/* Optionally read the region from environment variable */
regvar = getenv("GRASS_REGION");
if (regvar) {
- char **tokens, *delm = ";";
- char *err;
- tokens = G_tokenize(regvar, delm);
- err = G__read_Cell_head_array(tokens, window, 0);
+ char **tokens = G_tokenize(regvar, ";");
+ err = G__read_Cell_head_array(tokens, &st->dbwindow, 0);
G_free_tokens(tokens);
- if (err) {
- G_fatal_error(_("region for current mapset %s\nrun \"g.region\""),
- err);
- G_free(err);
- return 1;
- if (first) {
- char *wind, *err;
- wind = getenv("WIND_OVERRIDE");
+ else {
+ char *wind = getenv("WIND_OVERRIDE");
if (wind)
- err = G__get_window(&dbwindow, "windows", wind, G_mapset());
+ err = G__get_window(&st->dbwindow, "windows", wind, G_mapset());
else
- err = G__get_window(&dbwindow, "", "WIND", G_mapset());
- if (err) {
- err);
- G_free(err);
+ err = G__get_window(&st->dbwindow, "", "WIND", G_mapset());
- first = 0;
- G_copy(window, &dbwindow, sizeof(dbwindow));
+ if (err)
+ G_fatal_error(_("region for current mapset %s\nrun \"g.region\""), err);
+ st->initialized = 1;
if (!G__.window_set) {
G__.window_set = 1;
- G_copy(&G__.window, &dbwindow, sizeof(dbwindow));
+ G__.window = st->dbwindow;
- return 1;
@@ -112,37 +100,29 @@
* \return int
-int G_get_default_window(struct Cell_head *window)
+void G_get_default_window(struct Cell_head *window)
- char *err;
+ const char *err = G__get_window(window, "", "DEFAULT_WIND", "PERMANENT");
- if ((err = G__get_window(window, "", "DEFAULT_WIND", "PERMANENT"))) {
+ if (err)
G_fatal_error(_("default region %s"), err);
- G_free(err);
- return 1;
char *G__get_window(struct Cell_head *window,
const char *element, const char *name, const char *mapset)
- FILE *fd;
+ FILE *fp;
char *err;
- G_zero((char *)window, sizeof(struct Cell_head));
+ G_zero(window, sizeof(struct Cell_head));
/* Read from file */
- if (!(fd = G_fopen_old(element, name, mapset))) {
- char path[GPATH_MAX];
- G__file_name (path,element,name,mapset);
- fprintf (stderr, "G__get_window(%s)\n",path);
+ fp = G_fopen_old(element, name, mapset);
+ if (!fp)
return G_store(_("is not set"));
- err = G__read_Cell_head(fd, window, 0);
- fclose(fd);
+ err = G__read_Cell_head(fp, window, 0);
+ fclose(fp);
if (err) {
char msg[1024];
