[GRASS-SVN] r34484 - in grass/trunk: include lib/g3d lib/gis
lib/ogsf raster/r.contour raster/r.flow
svn_grass at osgeo.org
Tue Nov 25 01:26:50 EST 2008
Author: glynn
Date: 2008-11-25 01:26:49 -0500 (Tue, 25 Nov 2008)
New Revision: 34484
grass/trunk/include/gisdefs.h
grass/trunk/lib/g3d/g3dcolor.c
grass/trunk/lib/g3d/g3drange.c
grass/trunk/lib/gis/area_ellipse.c
grass/trunk/lib/gis/area_poly1.c
grass/trunk/lib/gis/area_sphere.c
grass/trunk/lib/gis/ascii_chk.c
grass/trunk/lib/gis/auto_mask.c
grass/trunk/lib/gis/bres_line.c
grass/trunk/lib/gis/cats.c
grass/trunk/lib/gis/cell_stats.c
grass/trunk/lib/gis/clear_scrn.c
grass/trunk/lib/gis/color_compat.c
grass/trunk/lib/gis/color_free.c
grass/trunk/lib/gis/color_get.c
grass/trunk/lib/gis/color_hist.c
grass/trunk/lib/gis/color_init.c
grass/trunk/lib/gis/color_invrt.c
grass/trunk/lib/gis/color_look.c
grass/trunk/lib/gis/color_org.c
grass/trunk/lib/gis/color_rand.c
grass/trunk/lib/gis/color_range.c
grass/trunk/lib/gis/color_read.c
grass/trunk/lib/gis/color_rule.c
grass/trunk/lib/gis/color_rules.c
grass/trunk/lib/gis/color_set.c
grass/trunk/lib/gis/color_shift.c
grass/trunk/lib/gis/color_write.c
grass/trunk/lib/gis/color_xform.c
grass/trunk/lib/gis/commas.c
grass/trunk/lib/gis/copy.c
grass/trunk/lib/gis/done_msg.c
grass/trunk/lib/gis/error.c
grass/trunk/lib/gis/fpreclass.c
grass/trunk/lib/gis/geodesic.c
grass/trunk/lib/gis/geodist.c
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/gis/histo_eq.c
grass/trunk/lib/gis/histogram.c
grass/trunk/lib/gis/history.c
grass/trunk/lib/gis/key_value1.c
grass/trunk/lib/gis/line_dist.c
grass/trunk/lib/gis/list.c
grass/trunk/lib/gis/ll_format.c
grass/trunk/lib/gis/ls.c
grass/trunk/lib/gis/null_val.c
grass/trunk/lib/gis/parser.c
grass/trunk/lib/gis/percent.c
grass/trunk/lib/gis/plot.c
grass/trunk/lib/gis/pole_in_poly.c
grass/trunk/lib/gis/put_row.c
grass/trunk/lib/gis/quant.c
grass/trunk/lib/gis/range.c
grass/trunk/lib/gis/raster.c
grass/trunk/lib/gis/reclass.c
grass/trunk/lib/gis/rhumbline.c
grass/trunk/lib/gis/short_way.c
grass/trunk/lib/gis/strings.c
grass/trunk/lib/gis/tempfile.c
grass/trunk/lib/gis/timestamp.c
grass/trunk/lib/gis/token.c
grass/trunk/lib/gis/trim_dec.c
grass/trunk/lib/gis/view.c
grass/trunk/lib/gis/wind_2_box.c
grass/trunk/lib/gis/wind_format.c
grass/trunk/lib/gis/window_map.c
grass/trunk/lib/gis/wr_cellhd.c
grass/trunk/lib/gis/writ_zeros.c
grass/trunk/lib/gis/zero.c
grass/trunk/lib/gis/zero_cell.c
grass/trunk/lib/ogsf/Gvl3.c
grass/trunk/raster/r.contour/main.c
grass/trunk/raster/r.flow/mem.h
Remove unnecessary return values
Miscellaneous clean-up
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/include/gisdefs.h 2008-11-25 06:26:49 UTC (rev 34484)
@@ -79,24 +79,24 @@
double G_area_of_polygon(const double *, const double *, int);
/* area_ellipse.c */
-int G_begin_zone_area_on_ellipsoid(double, double, double);
+void G_begin_zone_area_on_ellipsoid(double, double, double);
double G_darea0_on_ellipsoid(double);
double G_area_for_zone_on_ellipsoid(double, double);
/* area_poly1.c */
-int G_begin_ellipsoid_polygon_area(double, double);
+void G_begin_ellipsoid_polygon_area(double, double);
double G_ellipsoid_polygon_area(const double *, const double *, int);
/* area_poly2.c */
double G_planimetric_polygon_area(const double *, const double *, int);
/* area_sphere.c */
-int G_begin_zone_area_on_sphere(double, double);
+void G_begin_zone_area_on_sphere(double, double);
double G_darea0_on_sphere(double);
double G_area_for_zone_on_sphere(double, double);
/* ascii_chk.c */
-int G_ascii_check(char *);
+void G_ascii_check(char *);
/* asprintf.c */
@@ -114,14 +114,14 @@
/* auto_mask.c */
int G__check_for_auto_masking(void);
-int G_suppress_masking(void);
-int G_unsuppress_masking(void);
+void G_suppress_masking(void);
+void G_unsuppress_masking(void);
/* basename.c */
char *G_basename(char *, const char *);
/* bres_line.c */
-int G_bresenham_line(int, int, int, int, int (*)(int, int));
+void G_bresenham_line(int, int, int, int, int (*)(int, int));
/* cats.c */
int G_read_cats(const char *, const char *, struct Categories *);
@@ -135,12 +135,12 @@
char *G_get_f_raster_cat(FCELL *, struct Categories *);
char *G_get_d_raster_cat(DCELL *, struct Categories *);
char *G_get_raster_cat(void *, struct Categories *, RASTER_MAP_TYPE);
-int G_unmark_raster_cats(struct Categories *);
-int G_mark_c_raster_cats(const CELL *, int, struct Categories *);
-int G_mark_f_raster_cats(const FCELL *, int, struct Categories *);
-int G_mark_d_raster_cats(const DCELL *, int, struct Categories *);
+void G_unmark_raster_cats(struct Categories *);
+void G_mark_c_raster_cats(const CELL *, int, struct Categories *);
+void G_mark_f_raster_cats(const FCELL *, int, struct Categories *);
+void G_mark_d_raster_cats(const DCELL *, int, struct Categories *);
int G_mark_raster_cats(const void *, int, struct Categories *, RASTER_MAP_TYPE);
-int G_rewind_raster_cats(struct Categories *);
+void G_rewind_raster_cats(struct Categories *);
char *G_get_next_marked_d_raster_cat(struct Categories *, DCELL *, DCELL *,
long *);
char *G_get_next_marked_c_raster_cat(struct Categories *, CELL *, CELL *,
@@ -164,28 +164,28 @@
char *G_get_ith_c_raster_cat(const struct Categories *, int, void *, void *);
char *G_get_ith_raster_cat(const struct Categories *, int, void *, void *,
RASTER_MAP_TYPE);
-int G_init_cats(CELL, const char *, struct Categories *);
-int G_init_raster_cats(const char *, struct Categories *);
-int G_set_cats_title(const char *, struct Categories *);
-int G_set_raster_cats_title(const char *, struct Categories *);
-int G_set_cats_fmt(const char *, double, double, double, double,
+void G_init_cats(CELL, const char *, struct Categories *);
+void G_init_raster_cats(const char *, struct Categories *);
+void G_set_cats_title(const char *, struct Categories *);
+void G_set_raster_cats_title(const char *, struct Categories *);
+void G_set_cats_fmt(const char *, double, double, double, double,
-int G_set_raster_cats_fmt(const char *, double, double, double, double,
- struct Categories *);
-int G_free_cats(struct Categories *);
-int G_free_raster_cats(struct Categories *);
-int G_copy_raster_cats(struct Categories *, const struct Categories *);
+void G_set_raster_cats_fmt(const char *, double, double, double, double,
+ struct Categories *);
+void G_free_cats(struct Categories *);
+void G_free_raster_cats(struct Categories *);
+void G_copy_raster_cats(struct Categories *, const struct Categories *);
int G_number_of_raster_cats(struct Categories *);
int G_sort_cats(struct Categories *);
/* cell_stats.c */
-int G_init_cell_stats(struct Cell_stats *);
+void G_init_cell_stats(struct Cell_stats *);
int G_update_cell_stats(const CELL *, int, struct Cell_stats *);
int G_find_cell_stat(CELL, long *, const struct Cell_stats *);
int G_rewind_cell_stats(struct Cell_stats *);
int G_next_cell_stat(CELL *, long *, struct Cell_stats *);
-int G_get_stats_for_null_value(long *, const struct Cell_stats *);
-int G_free_cell_stats(struct Cell_stats *);
+void G_get_stats_for_null_value(long *, const struct Cell_stats *);
+void G_free_cell_stats(struct Cell_stats *);
/* cell_title.c */
char *G_get_cell_title(const char *, const char *);
@@ -194,11 +194,8 @@
int G_cell_stats_histo_eq(struct Cell_stats *, CELL, CELL, CELL, CELL, int,
void (*)(CELL, CELL, CELL));
-/* chop.c */
-char *G_chop(char *);
/* clear_scrn.c */
-int G_clear_screen(void);
+void G_clear_screen(void);
/* clicker.c */
void G_clicker(void);
@@ -208,33 +205,33 @@
int G_unopen_cell(int);
/* color_compat.c */
-int G_make_ryg_colors(struct Colors *, CELL, CELL);
-int G_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_aspect_colors(struct Colors *, CELL, CELL);
-int G_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_byr_colors(struct Colors *, CELL, CELL);
-int G_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_bgyr_colors(struct Colors *, CELL, CELL);
-int G_make_bgyr_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_byg_colors(struct Colors *, CELL, CELL);
-int G_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_grey_scale_colors(struct Colors *, CELL, CELL);
-int G_make_grey_scale_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_gyr_colors(struct Colors *, CELL, CELL);
-int G_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_rainbow_colors(struct Colors *, CELL, CELL);
-int G_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_ramp_colors(struct Colors *, CELL, CELL);
-int G_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
-int G_make_wave_colors(struct Colors *, CELL, CELL);
-int G_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_ryg_colors(struct Colors *, CELL, CELL);
+void G_make_ryg_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_aspect_colors(struct Colors *, CELL, CELL);
+void G_make_aspect_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_byr_colors(struct Colors *, CELL, CELL);
+void G_make_byr_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_bgyr_colors(struct Colors *, CELL, CELL);
+void G_make_bgyr_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_byg_colors(struct Colors *, CELL, CELL);
+void G_make_byg_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_grey_scale_colors(struct Colors *, CELL, CELL);
+void G_make_grey_scale_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_gyr_colors(struct Colors *, CELL, CELL);
+void G_make_gyr_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_rainbow_colors(struct Colors *, CELL, CELL);
+void G_make_rainbow_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_ramp_colors(struct Colors *, CELL, CELL);
+void G_make_ramp_fp_colors(struct Colors *, DCELL, DCELL);
+void G_make_wave_colors(struct Colors *, CELL, CELL);
+void G_make_wave_fp_colors(struct Colors *, DCELL, DCELL);
/* color_free.c */
-int G_free_colors(struct Colors *);
-int G__color_free_rules(struct _Color_Info_ *);
-int G__color_free_lookup(struct _Color_Info_ *);
-int G__color_free_fp_lookup(struct _Color_Info_ *);
-int G__color_reset(struct Colors *);
+void G_free_colors(struct Colors *);
+void G__color_free_rules(struct _Color_Info_ *);
+void G__color_free_lookup(struct _Color_Info_ *);
+void G__color_free_fp_lookup(struct _Color_Info_ *);
+void G__color_reset(struct Colors *);
/* color_get.c */
int G_get_color(CELL, int *, int *, int *, struct Colors *);
@@ -243,74 +240,78 @@
int G_get_c_raster_color(const CELL *, int *, int *, int *, struct Colors *);
int G_get_f_raster_color(const FCELL *, int *, int *, int *, struct Colors *);
int G_get_d_raster_color(const DCELL *, int *, int *, int *, struct Colors *);
-int G_get_null_value_color(int *, int *, int *, const struct Colors *);
-int G_get_default_color(int *, int *, int *, const struct Colors *);
+void G_get_null_value_color(int *, int *, int *, const struct Colors *);
+void G_get_default_color(int *, int *, int *, const struct Colors *);
/* color_hist.c */
-int G_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
-int G_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int,
- int);
+void G_make_histogram_eq_colors(struct Colors *, struct Cell_stats *);
+void G_make_histogram_log_colors(struct Colors *, struct Cell_stats *, int, int);
/* color_init.c */
-int G_init_colors(struct Colors *);
+void G_init_colors(struct Colors *);
/* color_insrt.c */
int G__insert_color_into_lookup(CELL, int, int, int, struct _Color_Info_ *);
/* color_invrt.c */
-int G_invert_colors(struct Colors *);
+void G_invert_colors(struct Colors *);
/* color_look.c */
-int G_lookup_colors(const CELL *, unsigned char *, unsigned char *,
- unsigned char *, unsigned char *, int, struct Colors *);
-int G_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
+void G_lookup_colors(const CELL *, unsigned char *, unsigned char *,
+ unsigned char *, unsigned char *, int, struct Colors *);
+void G_lookup_c_raster_colors(const CELL *, unsigned char *, unsigned char *,
+ struct Colors *);
+void G_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
+ struct Colors *, RASTER_MAP_TYPE);
+void G_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
struct Colors *);
-int G_lookup_raster_colors(const void *, unsigned char *, unsigned char *,
- struct Colors *, RASTER_MAP_TYPE);
-int G_lookup_f_raster_colors(const FCELL *, unsigned char *, unsigned char *,
+void G_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
struct Colors *);
-int G_lookup_d_raster_colors(const DCELL *, unsigned char *, unsigned char *,
- struct Colors *);
-int G__lookup_colors(const void *, unsigned char *, unsigned char *,
- unsigned char *, unsigned char *, int, struct Colors *,
- int, int, RASTER_MAP_TYPE);
-int G__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
- unsigned char *, const struct _Color_Rule_ *);
+void G__lookup_colors(const void *, unsigned char *, unsigned char *,
+ unsigned char *, unsigned char *, int, struct Colors *,
+ int, int, RASTER_MAP_TYPE);
+void G__interpolate_color_rule(DCELL, unsigned char *, unsigned char *,
+ unsigned char *, const struct _Color_Rule_ *);
/* color_org.c */
-int G__organize_colors(struct Colors *);
+void G__organize_colors(struct Colors *);
/* color_rand.c */
-int G_make_random_colors(struct Colors *, CELL, CELL);
+void G_make_random_colors(struct Colors *, CELL, CELL);
/* color_range.c */
-int G_set_color_range(CELL, CELL, struct Colors *);
-int G_set_d_color_range(DCELL, DCELL, struct Colors *);
-int G_get_color_range(CELL *, CELL *, const struct Colors *);
-int G_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
+void G_set_color_range(CELL, CELL, struct Colors *);
+void G_set_d_color_range(DCELL, DCELL, struct Colors *);
+void G_get_color_range(CELL *, CELL *, const struct Colors *);
+void G_get_d_color_range(DCELL *, DCELL *, const struct Colors *);
/* color_read.c */
int G_read_colors(const char *, const char *, struct Colors *);
-int G_mark_colors_as_fp(struct Colors *);
+void G_mark_colors_as_fp(struct Colors *);
/* color_remove.c */
int G_remove_colors(const char *, const char *);
/* color_rule.c */
-int G_add_d_raster_color_rule(const DCELL *, int, int, int, const DCELL *,
- int, int, int, struct Colors *);
-int G_add_f_raster_color_rule(const FCELL *, int, int, int, const FCELL *,
-int G_add_c_raster_color_rule(const CELL *, int, int, int, const CELL *, int,
- int, int, struct Colors *);
-int G_add_raster_color_rule(const void *, int, int, int, const void *, int,
- int, int, struct Colors *, RASTER_MAP_TYPE);
-int G_add_color_rule(const CELL, int, int, int, const CELL, int, int, int,
- struct Colors *);
+void G_add_d_raster_color_rule(const DCELL *, int, int, int,
+ const DCELL *, int, int, int,
+ struct Colors *);
+void G_add_f_raster_color_rule(const FCELL *, int, int, int,
+ const FCELL *, int, int, int,
+ struct Colors *);
+void G_add_c_raster_color_rule(const CELL *, int, int, int,
+ const CELL *, int, int, int,
+ struct Colors *);
+void G_add_raster_color_rule(const void *, int, int, int,
+ const void *, int, int, int,
+void G_add_color_rule(const CELL, int, int, int,
+ const CELL, int, int, int,
+ struct Colors *);
int G_add_modular_d_raster_color_rule(const DCELL *, int, int, int,
struct Colors *);
@@ -320,10 +321,11 @@
int G_add_modular_c_raster_color_rule(const CELL *, int, int, int,
struct Colors *);
-int G_add_modular_raster_color_rule(const void *, int, int, int, const void *,
- int, int, int, struct Colors *,
- RASTER_MAP_TYPE);
-int G_add_modular_color_rule(CELL, int, int, int, CELL, int, int, int,
+int G_add_modular_raster_color_rule(const void *, int, int, int,
+int G_add_modular_color_rule(CELL, int, int, int,
+ CELL, int, int, int,
struct Colors *);
/* color_rule_get.c */
@@ -344,44 +346,46 @@
int G_read_color_rules(struct Colors *, DCELL, DCELL, read_rule_fn *, void *);
int G_load_colors(struct Colors *, const char *, CELL, CELL);
int G_load_fp_colors(struct Colors *, const char *, DCELL, DCELL);
-int G_make_colors(struct Colors *, const char *, CELL, CELL);
-int G_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
+void G_make_colors(struct Colors *, const char *, CELL, CELL);
+void G_make_fp_colors(struct Colors *, const char *, DCELL, DCELL);
/* color_set.c */
-int G_set_color(CELL, int, int, int, struct Colors *);
-int G_set_d_color(DCELL, int, int, int, struct Colors *);
-int G_set_null_value_color(int, int, int, struct Colors *);
-int G_set_default_color(int, int, int, struct Colors *);
+void G_set_color(CELL, int, int, int, struct Colors *);
+void G_set_d_color(DCELL, int, int, int, struct Colors *);
+void G_set_null_value_color(int, int, int, struct Colors *);
+void G_set_default_color(int, int, int, struct Colors *);
/* color_shift.c */
-int G_shift_colors(int, struct Colors *);
-int G_shift_d_colors(DCELL, struct Colors *);
+void G_shift_colors(int, struct Colors *);
+void G_shift_d_colors(DCELL, struct Colors *);
/* color_str.c */
int G_str_to_color(const char *, int *, int *, int *);
/* color_write.c */
int G_write_colors(const char *, const char *, struct Colors *);
-int G__write_colors(FILE *, struct Colors *);
+void G__write_colors(FILE *, struct Colors *);
/* color_xform.c */
-int G_histogram_eq_colors(struct Colors *, struct Colors *,
- struct Cell_stats *);
+void G_histogram_eq_colors(struct Colors *, struct Colors *,
+ struct Cell_stats *);
void G_histogram_eq_colors_fp(struct Colors *,
struct Colors *, struct FP_stats *);
-int G_log_colors(struct Colors *, struct Colors *, int);
-int G_abs_log_colors(struct Colors *, struct Colors *, int);
+void G_log_colors(struct Colors *, struct Colors *, int);
+void G_abs_log_colors(struct Colors *, struct Colors *, int);
/* commas.c */
int G_insert_commas(char *);
-int G_remove_commas(char *);
+void G_remove_commas(char *);
/* copy.c */
-int G_copy(void *, const void *, int);
+void G_copy(void *, const void *, int);
+/* copy_dir.c */
+int G_recursive_copy(const char *, const char *);
/* copy_file.c */
int G_copy_file(const char *, const char *);
-int G_recursive_copy(const char *, const char *);
/* dalloc.c */
double *G_alloc_vector(size_t);
@@ -418,7 +422,7 @@
double, double);
/* done_msg.c */
-int G_done_msg(const char *, ...) __attribute__ ((format(printf, 1, 2)));
+void G_done_msg(const char *, ...) __attribute__ ((format(printf, 1, 2)));
/* eigen_tools.c */
int G_tqli(double[], double[], int, double **);
@@ -454,13 +458,13 @@
void G_important_message(const char *, ...)
-int G_fatal_error(const char *, ...) __attribute__ ((format(printf, 1, 2)))
+void G_fatal_error(const char *, ...) __attribute__ ((format(printf, 1, 2)))
__attribute__ ((noreturn));
-int G_warning(const char *, ...) __attribute__ ((format(printf, 1, 2)));
+void G_warning(const char *, ...) __attribute__ ((format(printf, 1, 2)));
int G_suppress_warnings(int);
int G_sleep_on_error(int);
-int G_set_error_routine(int (*)(const char *, int));
-int G_unset_error_routine(void);
+void G_set_error_routine(int (*)(const char *, int));
+void G_unset_error_routine(void);
void G_init_logging(void);
/* file_name.c */
@@ -501,7 +505,7 @@
/* fpreclass.c */
void G_fpreclass_clear(struct FPReclass *);
void G_fpreclass_reset(struct FPReclass *);
-int G_fpreclass_init(struct FPReclass *);
+void G_fpreclass_init(struct FPReclass *);
void G_fpreclass_set_domain(struct FPReclass *, DCELL, DCELL);
void G_fpreclass_set_range(struct FPReclass *, DCELL, DCELL);
int G_fpreclass_get_limits(const struct FPReclass *, DCELL *, DCELL *,
@@ -546,9 +550,9 @@
double G_geodesic_lat_from_lon(double);
/* geodist.c */
-int G_begin_geodesic_distance(double, double);
-int G_set_geodesic_distance_lat1(double);
-int G_set_geodesic_distance_lat2(double);
+void G_begin_geodesic_distance(double, double);
+void G_set_geodesic_distance_lat1(double);
+void G_set_geodesic_distance_lat2(double);
double G_geodesic_distance_lon_to_lon(double, double);
double G_geodesic_distance(double, double, double, double);
@@ -602,36 +606,36 @@
char *G_gisdbase(void);
/* gisinit.c */
-int G__gisinit(const char *, const char *);
-int G__no_gisinit(const char *);
-int G__check_gisinit(void);
+void G__gisinit(const char *, const char *);
+void G__no_gisinit(const char *);
+void G__check_gisinit(void);
/* histo_eq.c */
-int G_histogram_eq(const struct Histogram *, unsigned char **, CELL *,
- CELL *);
+void G_histogram_eq(const struct Histogram *, unsigned char **,
+ CELL *, CELL *);
/* histogram.c */
-int G_init_histogram(struct Histogram *);
+void G_init_histogram(struct Histogram *);
int G_read_histogram(const char *, const char *, struct Histogram *);
int G_write_histogram(const char *, const struct Histogram *);
int G_write_histogram_cs(const char *, struct Cell_stats *);
-int G_make_histogram_cs(struct Cell_stats *, struct Histogram *);
+void G_make_histogram_cs(struct Cell_stats *, struct Histogram *);
int G_get_histogram_num(const struct Histogram *);
CELL G_get_histogram_cat(int, const struct Histogram *);
long G_get_histogram_count(int, const struct Histogram *);
-int G_free_histogram(struct Histogram *);
+void G_free_histogram(struct Histogram *);
int G_sort_histogram(struct Histogram *);
int G_sort_histogram_by_count(struct Histogram *);
-int G_remove_histogram(const char *);
+void G_remove_histogram(const char *);
int G_add_histogram(CELL, long, struct Histogram *);
int G_set_histogram(CELL, long, struct Histogram *);
-int G_extend_histogram(CELL, long, struct Histogram *);
-int G_zero_histogram(struct Histogram *);
+void G_extend_histogram(CELL, long, struct Histogram *);
+void G_zero_histogram(struct Histogram *);
/* history.c */
int G_read_history(const char *, const char *, struct History *);
int G_write_history(const char *, struct History *);
-int G_short_history(const char *, const char *, struct History *);
+void G_short_history(const char *, const char *, struct History *);
int G_command_history(struct History *);
/* home.c */
@@ -671,7 +675,7 @@
struct Key_Value *G_create_key_value(void);
int G_set_key_value(const char *, const char *, struct Key_Value *);
char *G_find_key_value(const char *, const struct Key_Value *);
-int G_free_key_value(struct Key_Value *);
+void G_free_key_value(struct Key_Value *);
/* key_value2.c */
int G_fwrite_key_value(FILE *, const struct Key_Value *);
@@ -690,25 +694,25 @@
int G_check_input_output_name(const char *, const char *, int);
/* line_dist.c */
-int G_set_distance_to_line_tolerance(double);
+void G_set_distance_to_line_tolerance(double);
double G_distance2_point_to_line(double, double, double, double, double,
double);
/* list.c */
-int G_list_element(const char *, const char *, const char *,
- int (*)(const char *, const char *, const char *));
+void G_list_element(const char *, const char *, const char *,
+ int (*)(const char *, const char *, const char *));
char **G_list(int, const char *, const char *, const char *);
void G_free_list(char **);
/* ll_format.c */
-int G_lat_format(double, char *);
+void G_lat_format(double, char *);
char *G_lat_format_string(void);
-int G_lon_format(double, char *);
+void G_lon_format(double, char *);
char *G_lon_format_string(void);
-int G_llres_format(double, char *);
+void G_llres_format(double, char *);
char *G_llres_format_string(void);
-int G_lat_parts(double, int *, int *, double *, char *);
-int G_lon_parts(double, int *, int *, double *, char *);
+void G_lat_parts(double, int *, int *, double *, char *);
+void G_lon_parts(double, int *, int *, double *, char *);
/* ll_scan.c */
int G_lat_scan(const char *, double *);
@@ -803,14 +807,14 @@
int G_is_c_null_value(const CELL *);
int G_is_f_null_value(const FCELL *);
int G_is_d_null_value(const DCELL *);
-int G_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
-int G_insert_c_null_values(CELL *, char *, int);
-int G_insert_f_null_values(FCELL *, char *, int);
-int G_insert_d_null_values(DCELL *, char *, int);
+void G_insert_null_values(void *, char *, int, RASTER_MAP_TYPE);
+void G_insert_c_null_values(CELL *, char *, int);
+void G_insert_f_null_values(FCELL *, char *, int);
+void G_insert_d_null_values(DCELL *, char *, int);
int G__check_null_bit(const unsigned char *, int, int);
-int G__convert_01_flags(const char *, unsigned char *, int);
-int G__convert_flags_01(char *, const unsigned char *, int);
-int G__init_null_bits(unsigned char *, int);
+void G__convert_01_flags(const char *, unsigned char *, int);
+void G__convert_flags_01(char *, const unsigned char *, int);
+void G__init_null_bits(unsigned char *, int);
/* open.c */
int G_open_new(const char *, const char *);
@@ -862,7 +866,7 @@
struct Option *G_define_option(void);
struct Option *G_define_standard_option(int);
int G_parser(int, char **);
-int G_usage(void);
+void G_usage(void);
char *G_recreate_command(void);
/* paths.c */
@@ -880,17 +884,17 @@
void G_percent_reset(void);
/* plot.c */
-int G_setup_plot(double, double, double, double, int (*)(int, int),
- int (*)(int, int));
-int G_setup_fill(int);
-int G_plot_where_xy(double, double, int *, int *);
-int G_plot_where_en(int, int, double *, double *);
-int G_plot_point(double, double);
-int G_plot_line(double, double, double, double);
-int G_plot_line2(double, double, double, double);
+void G_setup_plot(double, double, double, double, int (*)(int, int),
+ int (*)(int, int));
+void G_setup_fill(int);
+void G_plot_where_xy(double, double, int *, int *);
+void G_plot_where_en(int, int, double *, double *);
+void G_plot_point(double, double);
+void G_plot_line(double, double, double, double);
+void G_plot_line2(double, double, double, double);
int G_plot_polygon(const double *, const double *, int);
int G_plot_area(double *const *, double *const *, int *, int);
-int G_plot_fx(double (*)(double), double, double);
+void G_plot_fx(double (*)(double), double, double);
/* pole_in_poly.c */
int G_pole_in_polygon(const double *, const double *, int);
@@ -945,11 +949,11 @@
void G_quant_clear(struct Quant *);
void G_quant_free(struct Quant *);
int G__quant_organize_fp_lookup(struct Quant *);
-int G_quant_init(struct Quant *);
+void G_quant_init(struct Quant *);
int G_quant_is_truncate(const struct Quant *);
int G_quant_is_round(const struct Quant *);
-int G_quant_truncate(struct Quant *);
-int G_quant_round(struct Quant *);
+void G_quant_truncate(struct Quant *);
+void G_quant_round(struct Quant *);
int G_quant_get_limits(const struct Quant *, DCELL *, DCELL *, CELL *,
CELL *);
int G_quant_nof_rules(const struct Quant *);
@@ -986,30 +990,30 @@
double G_radius_of_conformal_tangent_sphere(double, double, double);
/* range.c */
-int G__remove_fp_range(const char *);
-int G_construct_default_range(struct Range *);
+void G__remove_fp_range(const char *);
+void G_construct_default_range(struct Range *);
int G_read_fp_range(const char *, const char *, struct FPRange *);
int G_read_range(const char *, const char *, struct Range *);
int G_write_range(const char *, const struct Range *);
int G_write_fp_range(const char *, const struct FPRange *);
-int G_update_range(CELL, struct Range *);
-int G_update_fp_range(DCELL, struct FPRange *);
-int G_row_update_range(const CELL *, int, struct Range *);
-int G__row_update_range(const CELL *, int, struct Range *, int);
-int G_row_update_fp_range(const void *, int, struct FPRange *,
+void G_update_range(CELL, struct Range *);
+void G_update_fp_range(DCELL, struct FPRange *);
+void G_row_update_range(const CELL *, int, struct Range *);
+void G__row_update_range(const CELL *, int, struct Range *, int);
+void G_row_update_fp_range(const void *, int, struct FPRange *,
RASTER_MAP_TYPE);
-int G_init_range(struct Range *);
-int G_get_range_min_max(const struct Range *, CELL *, CELL *);
-int G_init_fp_range(struct FPRange *);
-int G_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
+void G_init_range(struct Range *);
+void G_get_range_min_max(const struct Range *, CELL *, CELL *);
+void G_init_fp_range(struct FPRange *);
+void G_get_fp_range_min_max(const struct FPRange *, DCELL *, DCELL *);
/* raster.c */
void *G_incr_void_ptr(const void *, const size_t);
int G_raster_cmp(const void *, const void *, RASTER_MAP_TYPE);
-int G_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
-int G_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
-int G_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
-int G_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
+void G_raster_cpy(void *, const void *, int, RASTER_MAP_TYPE);
+void G_set_raster_value_c(void *, CELL, RASTER_MAP_TYPE);
+void G_set_raster_value_f(void *, FCELL, RASTER_MAP_TYPE);
+void G_set_raster_value_d(void *, DCELL, RASTER_MAP_TYPE);
CELL G_get_raster_value_c(const void *, RASTER_MAP_TYPE);
FCELL G_get_raster_value_f(const void *, RASTER_MAP_TYPE);
DCELL G_get_raster_value_d(const void *, RASTER_MAP_TYPE);
@@ -1031,7 +1035,7 @@
int G_is_reclass(const char *, const char *, char *, char *);
int G_is_reclassed_to(const char *, const char *, int *, char ***);
int G_get_reclass(const char *, const char *, struct Reclass *);
-int G_free_reclass(struct Reclass *);
+void G_free_reclass(struct Reclass *);
int G_put_reclass(const char *, const struct Reclass *);
/* remove.c */
@@ -1066,7 +1070,7 @@
int G_set_window(struct Cell_head *);
/* short_way.c */
-int G_shortest_way(double *, double *);
+void G_shortest_way(double *, double *);
/* sleep.c */
void G_sleep(unsigned int);
@@ -1080,7 +1084,7 @@
char *G_store(const char *);
char *G_strchg(char *, char, char);
char *G_str_replace(char *, const char *, const char *);
-int G_strip(char *);
+void G_strip(char *);
void G_str_to_upper(char *);
void G_str_to_lower(char *);
@@ -1098,7 +1102,7 @@
/* tempfile.c */
char *G_tempfile(void);
char *G__tempfile(int);
-int G__temp_element(char *);
+void G__temp_element(char *);
/* timestamp.c */
void G_init_timestamp(struct TimeStamp *);
@@ -1107,7 +1111,7 @@
const DateTime *);
int G__read_timestamp(FILE *, struct TimeStamp *);
int G__write_timestamp(FILE *, const struct TimeStamp *);
-int G_get_timestamps(const struct TimeStamp *, DateTime *, DateTime *, int *);
+void G_get_timestamps(const struct TimeStamp *, DateTime *, DateTime *, int *);
int G_read_raster_timestamp(const char *, const char *, struct TimeStamp *);
int G_read_vector_timestamp(const char *, const char *, struct TimeStamp *);
int G_write_raster_timestamp(const char *, const struct TimeStamp *);
@@ -1123,11 +1127,14 @@
/* token.c */
char **G_tokenize(const char *, const char *);
int G_number_of_tokens(char **);
-int G_free_tokens(char **);
+void G_free_tokens(char **);
/* trim_dec.c */
-int G_trim_decimal(char *);
+void G_trim_decimal(char *);
+/* user_config.c */
+char *G_rc_path(const char *, const char *);
/* verbose.c */
int G_verbose(void);
int G_verbose_min(void);
@@ -1136,7 +1143,7 @@
int G_set_verbose(int);
/* view.c */
-int G_3dview_warning(int);
+void G_3dview_warning(int);
int G_get_3dview_defaults(struct G_3dview *, struct Cell_head *);
int G_put_3dview(const char *, const char *, const struct G_3dview *,
const struct Cell_head *);
@@ -1146,13 +1153,13 @@
char *G_whoami(void);
/* wind_2_box.c */
-int G_adjust_window_to_box(const struct Cell_head *, struct Cell_head *, int,
- int);
+void G_adjust_window_to_box(const struct Cell_head *, struct Cell_head *, int,
+ int);
/* wind_format.c */
-int G_format_northing(double, char *, int);
-int G_format_easting(double, char *, int);
-int G_format_resolution(double, char *, int);
+void G_format_northing(double, char *, int);
+void G_format_easting(double, char *, int);
+void G_format_resolution(double, char *, int);
/* wind_in.c */
int G_point_in_region(double, double);
@@ -1176,7 +1183,7 @@
int G_scan_resolution(const char *, double *, int);
/* window_map.c */
-int G__create_window_mapping(int);
+void G__create_window_mapping(int);
double G_northing_to_row(double, const struct Cell_head *);
double G_adjust_east_longitude(double, double);
double G_adjust_easting(double, const struct Cell_head *);
@@ -1185,22 +1192,22 @@
double G_col_to_easting(double, const struct Cell_head *);
int G_window_rows(void);
int G_window_cols(void);
-int G__init_window(void);
+void G__init_window(void);
int G_row_repeat_nomask(int, int);
/* wr_cellhd.c */
-int G__write_Cell_head(FILE *, const struct Cell_head *, int);
-int G__write_Cell_head3(FILE *, const struct Cell_head *, int);
+void G__write_Cell_head(FILE *, const struct Cell_head *, int);
+void G__write_Cell_head3(FILE *, const struct Cell_head *, int);
/* writ_zeros.c */
-int G_write_zeros(int, size_t);
+void G_write_zeros(int, size_t);
/* zero.c */
-int G_zero(void *, int);
+void G_zero(void *, int);
/* zero_cell.c */
-int G_zero_cell_buf(CELL *);
-int G_zero_raster_buf(void *, RASTER_MAP_TYPE);
+void G_zero_cell_buf(CELL *);
+void G_zero_raster_buf(void *, RASTER_MAP_TYPE);
/* zone.c */
int G_zone(void);
Modified: grass/trunk/lib/g3d/g3dcolor.c
--- grass/trunk/lib/g3d/g3dcolor.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/g3d/g3dcolor.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -326,7 +326,6 @@
/* adapted from G_write_colors */
FILE *fd;
- int stat;
if (strcmp(mapset, G_mapset()) != 0) {
G_warning(_("mapset <%s> is not the current mapset"), mapset);
@@ -337,10 +336,10 @@
if (!fd)
return -1;
- stat = G__write_colors(fd, colors);
+ G__write_colors(fd, colors);
fclose(fd);
- return stat;
+ return 1;
Modified: grass/trunk/lib/g3d/g3drange.c
--- grass/trunk/lib/g3d/g3drange.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/g3d/g3drange.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -214,5 +214,6 @@
int G3d_range_init(G3D_Map * map)
- return G_init_fp_range(&(map->range));
+ G_init_fp_range(&(map->range));
+ return 0;
Modified: grass/trunk/lib/gis/area_ellipse.c
--- grass/trunk/lib/gis/area_ellipse.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/area_ellipse.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -46,15 +46,13 @@
* \param[in] a semi-major axis
* \param[in] e2 ellipsoid eccentricity
* \param[in] s scale factor
- * \return always returns 0
+ * \return
-int G_begin_zone_area_on_ellipsoid(double a, double e2, double s)
+void G_begin_zone_area_on_ellipsoid(double a, double e2, double s)
st->E = sqrt(e2);
st->M = s * a * a * M_PI * (1 - e2) / st->E;
- return 0;
Modified: grass/trunk/lib/gis/area_poly1.c
--- grass/trunk/lib/gis/area_poly1.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/area_poly1.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -61,10 +61,10 @@
+ * \return
-int G_begin_ellipsoid_polygon_area(double a, double e2)
+void G_begin_ellipsoid_polygon_area(double a, double e2)
double e4, e6;
@@ -86,8 +86,6 @@
st->E = 4 * M_PI * st->Qp * st->AE;
if (st->E < 0.0)
st->E = -st->E;
- return 0;
Modified: grass/trunk/lib/gis/area_sphere.c
--- grass/trunk/lib/gis/area_sphere.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/area_sphere.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -39,12 +39,12 @@
* \param[in] r radius of sphere
- * \return int
+ * \return
-int G_begin_zone_area_on_sphere(double r, double s)
+void G_begin_zone_area_on_sphere(double r, double s)
- return (st->M = s * 2.0 * r * r * M_PI);
+ st->M = s * 2.0 * r * r * M_PI;
Modified: grass/trunk/lib/gis/ascii_chk.c
--- grass/trunk/lib/gis/ascii_chk.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/ascii_chk.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -28,10 +28,10 @@
* tabs, which are turned into spaces.
* \param[in,out] string buffer to have non-ascii characters removed
+ * \return
-int G_ascii_check(char *string)
+void G_ascii_check(char *string)
char *ptr1, *ptr2;
@@ -46,6 +46,4 @@
ptr1++;
*ptr2 = 0;
- return 0;
Modified: grass/trunk/lib/gis/auto_mask.c
--- grass/trunk/lib/gis/auto_mask.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/auto_mask.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -76,10 +76,10 @@
* \brief Suppresses masking.
+ * \return
if (G__.auto_mask > 0) {
G_close_cell(G__.mask_fd);
@@ -87,23 +87,19 @@
G__.mask_fd = -1;
G__.auto_mask = -2;
- return 0;
* \brief Unsuppresses masking.
+ * \return
if (G__.auto_mask < -1) {
G__.mask_fd = -1;
G__check_for_auto_masking();
- return 0;
Modified: grass/trunk/lib/gis/bres_line.c
--- grass/trunk/lib/gis/bres_line.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/bres_line.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -32,10 +32,10 @@
* \param[in] x1
* \param[in] y1
* \param[in] point pointer to point plotting function
+ * \return
-int G_bresenham_line(int x0, int y0, int x1, int y1, int (*point) (int, int))
+void G_bresenham_line(int x0, int y0, int x1, int y1, int (*point) (int, int))
int dx, dy;
int xinc, yinc;
@@ -90,6 +90,4 @@
point(x1, y1);
- return 0;
Modified: grass/trunk/lib/gis/cats.c
--- grass/trunk/lib/gis/cats.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/cats.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -325,7 +325,7 @@
#include <grass/gis.h>
#include <grass/glocale.h>
-static int get_cond(char **, char *, DCELL);
+static void get_cond(char **, char *, DCELL);
static int get_fmt(char **, char *, int *);
static int cmp(const void *, const void *);
@@ -725,16 +725,15 @@
* used and which weren't.
* \param pcats
- * \return int
+ * \return
-int G_unmark_raster_cats(struct Categories *pcats)
+void G_unmark_raster_cats(struct Categories *pcats)
{ /* structure to hold category info */
int i;
for (i = 0; i < pcats->ncats; i++)
pcats->marks[i] = 0;
- return 0;
@@ -749,14 +748,13 @@
* \param rast_row
* \param ncols
* \param pcats
- * \return int
+ * \return
-int G_mark_c_raster_cats(const CELL * rast_row, /* raster row to update stats */
- int ncols, struct Categories *pcats)
+void G_mark_c_raster_cats(const CELL * rast_row, /* raster row to update stats */
+ int ncols, struct Categories *pcats)
G_mark_raster_cats(rast_row, ncols, pcats, CELL_TYPE);
- return 0;
@@ -771,14 +769,13 @@
* \param rast_row
* \param ncols
* \param pcats
- * \return int
+ * \return
-int G_mark_f_raster_cats(const FCELL * rast_row, /* raster row to update stats */
+void G_mark_f_raster_cats(const FCELL * rast_row, /* raster row to update stats */
G_mark_raster_cats(rast_row, ncols, pcats, FCELL_TYPE);
- return 0;
@@ -793,14 +790,13 @@
* \param rast_row
* \param ncols
* \param pcats
- * \return int
+ * \return
-int G_mark_d_raster_cats(const DCELL * rast_row, /* raster row to update stats */
+void G_mark_d_raster_cats(const DCELL * rast_row, /* raster row to update stats */
G_mark_raster_cats(rast_row, ncols, pcats, DCELL_TYPE);
- return 0;
@@ -848,13 +844,12 @@
* cat label.
* \param pcats
- * \return int
+ * \return
-int G_rewind_raster_cats(struct Categories *pcats)
+void G_rewind_raster_cats(struct Categories *pcats)
pcats->last_marked_rule = -1;
- return 0;
char *G_get_next_marked_d_raster_cat(struct Categories *pcats, /* structure to hold category info */
@@ -955,7 +950,7 @@
return 1;
-static int get_cond(char **f, char *value, DCELL val)
+static void get_cond(char **f, char *value, DCELL val)
char *ff;
@@ -981,8 +976,6 @@
*value = 0;
*f = ff;
- return 0;
@@ -1406,14 +1399,12 @@
* \param n
* \param title
* \param cats
- * \return int
-int G_init_cats(CELL num, const char *title, struct Categories *pcats)
+void G_init_cats(CELL num, const char *title, struct Categories *pcats)
G_init_raster_cats(title, pcats);
pcats->num = num;
- return 0;
@@ -1426,10 +1417,10 @@
* \param title
* \param pcats
- * \return int
+ * \return
-int G_init_raster_cats(const char *title, struct Categories *pcats)
+void G_init_raster_cats(const char *title, struct Categories *pcats)
G_set_raster_cats_title(title, pcats);
pcats->labels = NULL;
@@ -1443,7 +1434,6 @@
pcats->a2 = 0.0;
G_quant_init(&pcats->q);
- return 0;
@@ -1455,13 +1445,12 @@
* \param title
* \param cats
- * \return int
+ * \return
-int G_set_cats_title(const char *title, struct Categories *pcats)
+void G_set_cats_title(const char *title, struct Categories *pcats)
- return 0;
@@ -1472,24 +1461,22 @@
* \param title
* \param pcats
- * \return int
+ * \return
-int G_set_raster_cats_title(const char *title, struct Categories *pcats)
+void G_set_raster_cats_title(const char *title, struct Categories *pcats)
if (title == NULL)
title = "";
pcats->title = G_store(title);
G_newlines_to_spaces(pcats->title);
G_strip(pcats->title);
- return 0;
-int G_set_cats_fmt(const char *fmt, double m1, double a1, double m2,
- double a2, struct Categories *pcats)
+void G_set_cats_fmt(const char *fmt, double m1, double a1, double m2,
+ double a2, struct Categories *pcats)
G_set_raster_cats_fmt(fmt, m1, a1, m2, a2, pcats);
- return 0;
@@ -1504,10 +1491,9 @@
* \param m2
* \param a2
* \param pcats
- * \return int
-int G_set_raster_cats_fmt(const char *fmt, double m1, double a1, double m2,
+void G_set_raster_cats_fmt(const char *fmt, double m1, double a1, double m2,
pcats->m1 = m1;
@@ -1518,7 +1504,6 @@
pcats->fmt = G_store(fmt);
G_newlines_to_spaces(pcats->fmt);
G_strip(pcats->fmt);
- return 0;
@@ -1529,13 +1514,12 @@
* and<i>G_set_cat.</i>
* \param cats
- * \return int
+ * \return
-int G_free_cats(struct Categories *pcats)
+void G_free_cats(struct Categories *pcats)
G_free_raster_cats(pcats);
- return 0;
@@ -1545,10 +1529,10 @@
* Same as existing G_free_cats()
* \param pcats
- * \return int
+ * \return
-int G_free_raster_cats(struct Categories *pcats)
+void G_free_raster_cats(struct Categories *pcats)
int i;
@@ -1571,7 +1555,6 @@
G_quant_free(&pcats->q);
pcats->ncats = 0;
pcats->nalloc = 0;
- return 0;
@@ -1586,12 +1569,11 @@
* \param pcats_to
* \param pcats_from
- * \return int
+ * \return
-int
-G_copy_raster_cats(struct Categories *pcats_to,
- const struct Categories *pcats_from)
+void G_copy_raster_cats(struct Categories *pcats_to,
+ const struct Categories *pcats_from)
int i;
char *descr;
@@ -1602,7 +1584,6 @@
descr = G_get_ith_d_raster_cat(pcats_from, i, &d1, &d2);
G_set_d_raster_cat(&d1, &d2, descr, pcats_to);
- return 0;
int G_number_of_raster_cats(struct Categories *pcats)
Modified: grass/trunk/lib/gis/cell_stats.c
--- grass/trunk/lib/gis/cell_stats.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/cell_stats.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -9,7 +9,7 @@
#define NODE struct Cell_stats_node
static int next_node(struct Cell_stats *);
-static int init_node(NODE *, int, int);
+static void init_node(NODE *, int, int);
@@ -28,17 +28,15 @@
* Set the count for NULL-values to zero.
- * \return int
+ * \return
-int G_init_cell_stats(struct Cell_stats *s)
+void G_init_cell_stats(struct Cell_stats *s)
s->N = 0;
s->tlen = INCR;
s->node = (NODE *) G_malloc(s->tlen * sizeof(NODE));
s->null_data_count = 0;
- return 1;
@@ -161,7 +159,7 @@
return 0;
-static int init_node(NODE * node, int idx, int offset)
+static void init_node(NODE * node, int idx, int offset)
long *count;
int i;
@@ -172,8 +170,6 @@
node->idx = idx;
node->count[offset] = 1;
node->left = 0;
- return 0;
@@ -390,13 +386,12 @@
* \param count
* \param s
- * \return int
+ * \return
-int G_get_stats_for_null_value(long *count, const struct Cell_stats *s)
+void G_get_stats_for_null_value(long *count, const struct Cell_stats *s)
*count = s->null_data_count;
- return 1;
@@ -407,16 +402,14 @@
* called any time after calling<i>G_init_cell_stats.</i>
* \param s
- * \return int
+ * \return
-int G_free_cell_stats(struct Cell_stats *s)
+void G_free_cell_stats(struct Cell_stats *s)
int i;
for (i = 1; i <= s->N; i++)
G_free(s->node[i].count);
G_free(s->node);
- return 0;
Modified: grass/trunk/lib/gis/clear_scrn.c
--- grass/trunk/lib/gis/clear_scrn.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/clear_scrn.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -9,13 +9,11 @@
#include <stdlib.h>
#ifdef __MINGW32__
system("cls");
#else
system("clear");
#endif
- return 0;
Modified: grass/trunk/lib/gis/color_compat.c
--- grass/trunk/lib/gis/color_compat.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_compat.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -32,28 +32,28 @@
* \param colors
* \param min
* \param max
- * \return int
+ * \return
-int G_make_wave_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_wave_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "wave", min, max);
+ G_make_colors(colors, "wave", min, max);
-int G_make_wave_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_wave_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "wave", min, max);
+ G_make_fp_colors(colors, "wave", min, max);
-int G_make_ryg_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_ryg_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "ryg", min, max);
+ G_make_colors(colors, "ryg", min, max);
-int G_make_ryg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_ryg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "ryg", min, max);
+ G_make_fp_colors(colors, "ryg", min, max);
@@ -66,17 +66,17 @@
* \param colors
* \param min
* \param max
- * \return int
+ * \return
-int G_make_ramp_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_ramp_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "ramp", min, max);
+ G_make_colors(colors, "ramp", min, max);
-int G_make_ramp_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_ramp_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "ramp", min, max);
+ G_make_fp_colors(colors, "ramp", min, max);
@@ -91,28 +91,28 @@
* \param colors
* \param min
* \param max
- * \return int
+ * \return
-int G_make_rainbow_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_rainbow_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "rainbow", min, max);
+ G_make_colors(colors, "rainbow", min, max);
-int G_make_rainbow_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_rainbow_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "rainbow", min, max);
+ G_make_fp_colors(colors, "rainbow", min, max);
-int G_make_gyr_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_gyr_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "gyr", min, max);
+ G_make_colors(colors, "gyr", min, max);
-int G_make_gyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_gyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "gyr", min, max);
+ G_make_fp_colors(colors, "gyr", min, max);
@@ -124,47 +124,47 @@
* \param colors
* \param min
* \param max
- * \return int
+ * \return
-int G_make_grey_scale_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_grey_scale_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "grey", min, max);
+ G_make_colors(colors, "grey", min, max);
-int G_make_grey_scale_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_grey_scale_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "grey", min, max);
+ G_make_fp_colors(colors, "grey", min, max);
-int G_make_byr_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_byr_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "byr", min, max);
+ G_make_colors(colors, "byr", min, max);
-int G_make_byr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_byr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "byr", min, max);
+ G_make_fp_colors(colors, "byr", min, max);
-int G_make_bgyr_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_bgyr_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "bgyr", min, max);
+ G_make_colors(colors, "bgyr", min, max);
-int G_make_bgyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_bgyr_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "bgyr", min, max);
+ G_make_fp_colors(colors, "bgyr", min, max);
-int G_make_byg_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_byg_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "byg", min, max);
+ G_make_colors(colors, "byg", min, max);
-int G_make_byg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_byg_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "byg", min, max);
+ G_make_fp_colors(colors, "byg", min, max);
@@ -175,15 +175,15 @@
* \param colors
* \param min
* \param max
- * \return int
+ * \return
-int G_make_aspect_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_aspect_colors(struct Colors *colors, CELL min, CELL max)
- return G_make_colors(colors, "aspect", min, max);
+ G_make_colors(colors, "aspect", min, max);
-int G_make_aspect_fp_colors(struct Colors *colors, DCELL min, DCELL max)
+void G_make_aspect_fp_colors(struct Colors *colors, DCELL min, DCELL max)
- return G_make_fp_colors(colors, "aspect", min, max);
+ G_make_fp_colors(colors, "aspect", min, max);
Modified: grass/trunk/lib/gis/color_free.c
--- grass/trunk/lib/gis/color_free.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_free.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -11,15 +11,13 @@
* well as after <i>G_init_colors.</i>
* \param colors
- * \return int
+ * \return
-int G_free_colors(struct Colors *colors)
+void G_free_colors(struct Colors *colors)
G__color_reset(colors);
G_init_colors(colors);
- return 0;
@@ -27,7 +25,7 @@
* library
-int G__color_free_rules(struct _Color_Info_ *cp)
+void G__color_free_rules(struct _Color_Info_ *cp)
struct _Color_Rule_ *rule, *next;
@@ -36,11 +34,9 @@
G_free(rule);
cp->rules = NULL;
- return 0;
-int G__color_free_lookup(struct _Color_Info_ *cp)
+void G__color_free_lookup(struct _Color_Info_ *cp)
if (cp->lookup.active) {
G_free(cp->lookup.red);
@@ -49,11 +45,9 @@
G_free(cp->lookup.set);
cp->lookup.active = 0;
- return 0;
-int G__color_free_fp_lookup(struct _Color_Info_ *cp)
+void G__color_free_fp_lookup(struct _Color_Info_ *cp)
if (cp->fp_lookup.active) {
G_free(cp->fp_lookup.vals);
@@ -61,11 +55,9 @@
cp->fp_lookup.active = 0;
cp->fp_lookup.nalloc = 0;
- return 0;
-int G__color_reset(struct Colors *colors)
+void G__color_reset(struct Colors *colors)
G__color_free_lookup(&colors->fixed);
G__color_free_lookup(&colors->modular);
@@ -73,6 +65,4 @@
G__color_free_rules(&colors->modular);
colors->version = 0;
/* this routine should NOT init the colors */
- return 0;
Modified: grass/trunk/lib/gis/color_get.c
--- grass/trunk/lib/gis/color_get.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_get.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -153,10 +153,10 @@
* \param[out] grn green value
* \param[out] blu blue value
* \param[in] colors Colors struct
+ * \return
-int G_get_null_value_color(int *red, int *grn, int *blu,
+void G_get_null_value_color(int *red, int *grn, int *blu,
const struct Colors *colors)
if (colors->null_set) {
@@ -171,8 +171,6 @@
else
*red = *blu = *grn = 255; /* white */
- return 0;
@@ -186,11 +184,11 @@
+ * \return
-int G_get_default_color(int *red, int *grn, int *blu,
- const struct Colors *colors)
+void G_get_default_color(int *red, int *grn, int *blu,
+ const struct Colors *colors)
if (colors->undef_set) {
*red = (int)colors->undef_red;
@@ -199,6 +197,4 @@
else
- return 0;
Modified: grass/trunk/lib/gis/color_hist.c
--- grass/trunk/lib/gis/color_hist.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_hist.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -36,11 +36,11 @@
* \param colors
* \param s
- * \return int
+ * \return
-int G_make_histogram_eq_colors(struct Colors *colors,
- struct Cell_stats *statf)
+void G_make_histogram_eq_colors(struct Colors *colors,
+ struct Cell_stats *statf)
long count, total;
CELL prev = 0, cat;
@@ -61,7 +61,7 @@
if (count > 0)
total += count;
if (total <= 0)
- return 0;
+ return;
span = total / 256.0;
first = 1;
@@ -94,13 +94,10 @@
G_add_color_rule(prev, grey, grey, grey, cat, grey, grey, grey,
colors);
- return 0;
-int G_make_histogram_log_colors(struct Colors *colors,
- struct Cell_stats *statf, int min, int max)
+void G_make_histogram_log_colors(struct Colors *colors,
+ struct Cell_stats *statf, int min, int max)
long count, total;
double lmin, lmax;
@@ -121,7 +118,7 @@
if (count > 0)
total += count;
if (total <= 0)
- return 0;
+ return;
first = 1;
grey = 0;
@@ -157,6 +154,4 @@
colors);
- return 0;
Modified: grass/trunk/lib/gis/color_init.c
--- grass/trunk/lib/gis/color_init.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_init.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -17,10 +17,10 @@
* to <i>G_add_color_rule</i> and<i>G_set_color.</i>
* \param colors
- * \return int
+ * \return
-int G_init_colors(struct Colors *colors)
+void G_init_colors(struct Colors *colors)
colors->null_set = 0;
@@ -45,6 +45,4 @@
colors->modular.fp_lookup.active = 0;
colors->modular.fp_lookup.nalloc = 0;
colors->organizing = 0;
- return 0;
Modified: grass/trunk/lib/gis/color_invrt.c
--- grass/trunk/lib/gis/color_invrt.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_invrt.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -1,8 +1,6 @@
-int G_invert_colors(struct Colors *colors)
+void G_invert_colors(struct Colors *colors)
colors->invert = !colors->invert;
- return 0;
Modified: grass/trunk/lib/gis/color_look.c
--- grass/trunk/lib/gis/color_look.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_look.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -32,17 +32,15 @@
* Modified to return a color for NULL-values.
- * \return int
+ * \return
-int G_lookup_colors(const CELL * cell,
- unsigned char *red, unsigned char *grn,
- unsigned char *blu, unsigned char *set, int n,
- struct Colors *colors)
+void G_lookup_colors(const CELL * cell,
+ unsigned char *red, unsigned char *grn,
+ unsigned char *blu, unsigned char *set, int n,
+ struct Colors *colors)
G_lookup_c_raster_colors(cell, red, grn, blu, set, n, colors);
- return 0;
/* I don't think it should exist, because it requires openning
@@ -70,13 +68,13 @@
* \param set
* \param n
* \param colors
- * \return int
+ * \return
-int G_lookup_c_raster_colors(const CELL * cell,
+void G_lookup_c_raster_colors(const CELL * cell,
G__organize_colors(colors); /* make sure the lookup tables are in place */
@@ -89,8 +87,6 @@
/* now lookup unset colors using the modular rules */
G__lookup_colors((void *)cell, red, grn, blu, set, n, colors, 1, 0,
CELL_TYPE);
- return 0;
@@ -112,13 +108,13 @@
* \param n
* \param colors
* \param cell_type
- * \return int
+ * \return
-int G_lookup_raster_colors(const void *raster,
- struct Colors *colors, RASTER_MAP_TYPE map_type)
+void G_lookup_raster_colors(const void *raster,
+ struct Colors *colors, RASTER_MAP_TYPE map_type)
/* in case of float color rules, fp_lookup table is created */
@@ -130,8 +126,6 @@
G__lookup_colors(raster, red, grn, blu, set, n, colors, 1, 0, map_type);
- return 0;
@@ -149,12 +143,12 @@
* \param set
* \param n
* \param colors
- * \return int
+ * \return
-int G_lookup_f_raster_colors(const FCELL * fcell, unsigned char *red,
- unsigned char *grn, unsigned char *blu,
- unsigned char *set, int n, struct Colors *colors)
+void G_lookup_f_raster_colors(const FCELL * fcell, unsigned char *red,
+ unsigned char *grn, unsigned char *blu,
+ unsigned char *set, int n, struct Colors *colors)
@@ -168,8 +162,6 @@
G__lookup_colors((void *)fcell, red, grn, blu, set, n, colors, 1, 0,
FCELL_TYPE);
- return 0;
@@ -187,12 +179,12 @@
* \param set
* \param n
* \param colors
- * \return int
+ * \return
-int G_lookup_d_raster_colors(const DCELL * dcell, unsigned char *red,
+void G_lookup_d_raster_colors(const DCELL * dcell, unsigned char *red,
@@ -206,8 +198,6 @@
G__lookup_colors((void *)dcell, red, grn, blu, set, n, colors, 1, 0,
DCELL_TYPE);
- return 0;
@@ -228,10 +218,10 @@
-int G__lookup_colors(const void *raster, unsigned char *red,
- unsigned char *set, int n, struct Colors *colors,
- int mod, int rules_only, RASTER_MAP_TYPE data_type)
+void G__lookup_colors(const void *raster, unsigned char *red,
+ unsigned char *set, int n, struct Colors *colors,
+ int mod, int rules_only, RASTER_MAP_TYPE data_type)
struct _Color_Info_ *cp;
struct _Color_Rule_ *rule;
@@ -439,13 +429,11 @@
fprintf (stderr, "rule found %d %.2lf %d %d %d\n\n", cat, val, *red, *grn, *blu);
- return 0;
-int G__interpolate_color_rule(DCELL val, unsigned char *red,
- const struct _Color_Rule_ *rule)
+void G__interpolate_color_rule(DCELL val, unsigned char *red,
+ const struct _Color_Rule_ *rule)
DCELL delta;
@@ -470,6 +458,4 @@
*grn = rule->low.grn;
*blu = rule->low.blu;
- return 0;
Modified: grass/trunk/lib/gis/color_org.c
--- grass/trunk/lib/gis/color_org.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_org.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -3,11 +3,11 @@
#define LOOKUP_COLORS 2048
-static int organize_lookup(struct Colors *, int);
+static void organize_lookup(struct Colors *, int);
static int organize_fp_lookup(struct Colors *, int);
static int double_comp(const void *, const void *);
-int G__organize_colors(struct Colors *colors)
+void G__organize_colors(struct Colors *colors)
/* don't do anything if called recursively */
if (!colors->organizing) {
@@ -21,8 +21,6 @@
- return 0;
static int organize_fp_lookup(struct Colors *colors, int mod)
@@ -93,7 +91,7 @@
return 0;
-static int organize_lookup(struct Colors *colors, int mod)
+static void organize_lookup(struct Colors *colors, int mod)
int i, n;
CELL x;
@@ -102,7 +100,7 @@
/* don't do anything if the color structure is float */
if (colors->is_float)
- return 0;
+ return;
if (mod)
cp = &colors->modular;
@@ -110,11 +108,11 @@
cp = &colors->fixed;
- return 0;
+ return;
n = (CELL) cp->max - (CELL) cp->min + 1;
if (n >= LOOKUP_COLORS || n <= 0)
- return 0;
+ return;
x = (CELL) cp->min;
for (i = 0; i < n; i++)
@@ -132,8 +130,6 @@
cp->lookup.set, n, colors, mod, 1, CELL_TYPE);
cp->lookup.active = 1;
- return 0;
static int double_comp(const void *xx, const void *yy)
Modified: grass/trunk/lib/gis/color_rand.c
--- grass/trunk/lib/gis/color_rand.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_rand.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -2,6 +2,7 @@
#include <stdio.h> /* For NULL */
#include <stdlib.h> /* For rand() and srand() */
+#include <grass/glocale.h>
#define MAX_COLORS 1024
#define DEVIATION 128
@@ -16,10 +17,10 @@
* \param colors
* \param min
* \param max
- * \return int
+ * \return
-int G_make_random_colors(struct Colors *colors, CELL min, CELL max)
+void G_make_random_colors(struct Colors *colors, CELL min, CELL max)
unsigned char red, grn, blu;
int count;
@@ -27,7 +28,8 @@
if (min > max)
- return -1;
+ G_fatal_error(_("G_make_random_colors: min (%d) > max (%d)"),
+ min, max);
srand(time(NULL));
@@ -42,6 +44,4 @@
G_add_modular_color_rule(n, red, grn, blu, n, red, grn, blu, colors);
G_set_color_range(min, max, colors);
- return 1;
Modified: grass/trunk/lib/gis/color_range.c
--- grass/trunk/lib/gis/color_range.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_range.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -1,7 +1,7 @@
#include <math.h>
-int G_set_color_range(CELL min, CELL max, struct Colors *colors)
+void G_set_color_range(CELL min, CELL max, struct Colors *colors)
if (min < max) {
colors->cmin = (DCELL) min;
@@ -11,11 +11,9 @@
colors->cmin = (DCELL) max;
colors->cmax = (DCELL) min;
- return 0;
-int G_set_d_color_range(DCELL min, DCELL max, struct Colors *colors)
+void G_set_d_color_range(DCELL min, DCELL max, struct Colors *colors)
if (min < max) {
colors->cmin = min;
@@ -25,8 +23,6 @@
colors->cmin = max;
colors->cmax = min;
- return 0;
/* returns min and max category in the range or huge numbers
@@ -41,7 +37,7 @@
* \return int
-int G_get_color_range(CELL * min, CELL * max, const struct Colors *colors)
+void G_get_color_range(CELL * min, CELL * max, const struct Colors *colors)
if (!colors->is_float) {
*min = (CELL) floor(colors->cmin);
@@ -51,15 +47,11 @@
*min = -255 * 255 * 255;
*max = 255 * 255 * 255;
- return 0;
/* returns min and max values in the range */
-int G_get_d_color_range(DCELL * min, DCELL * max, const struct Colors *colors)
+void G_get_d_color_range(DCELL * min, DCELL * max, const struct Colors *colors)
*min = colors->cmin;
*max = colors->cmax;
- return 0;
Modified: grass/trunk/lib/gis/color_read.c
--- grass/trunk/lib/gis/color_read.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_read.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -393,9 +393,7 @@
* \return int
-int G_mark_colors_as_fp(struct Colors *colors)
+void G_mark_colors_as_fp(struct Colors *colors)
colors->is_float = 1;
- return 0;
Modified: grass/trunk/lib/gis/color_rule.c
--- grass/trunk/lib/gis/color_rule.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_rule.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -18,10 +18,10 @@
#define LIMIT(x) if (x < 0) x = 0; else if (x > 255) x = 255;
-static int add_color_rule(const void *, int, int, int,
- const void *, int, int, int,
- struct _Color_Info_ *, int,
- DCELL *, DCELL *, RASTER_MAP_TYPE);
+static void add_color_rule(const void *, int, int, int,
+ struct _Color_Info_ *, int,
+ DCELL *, DCELL *, RASTER_MAP_TYPE);
@@ -34,17 +34,16 @@
* \param v2 cell value
* \param r2,g2,b2 color value
* \param[in,out] colors pointer to color table structure
- * \return 1
+ * \return
-int
-G_add_d_raster_color_rule(const DCELL * val1, int r1, int g1, int b1,
- const DCELL * val2, int r2, int g2, int b2,
+ const DCELL * val1, int r1, int g1, int b1,
+ const DCELL * val2, int r2, int g2, int b2,
add_color_rule(val1, r1, g1, b1, val2, r2, g2, b2, &colors->fixed,
colors->version, &colors->cmin, &colors->cmax, DCELL_TYPE);
- return 1;
@@ -58,17 +57,16 @@
- * \return 1
+ * \return
-int
-G_add_f_raster_color_rule(const FCELL * cat1, int r1, int g1, int b1,
- const FCELL * cat2, int r2, int g2, int b2,
+ const FCELL * cat1, int r1, int g1, int b1,
+ const FCELL * cat2, int r2, int g2, int b2,
add_color_rule(cat1, r1, g1, b1, cat2, r2, g2, b2, &colors->fixed,
colors->version, &colors->cmin, &colors->cmax, FCELL_TYPE);
- return 1;
@@ -82,17 +80,16 @@
- * \return 1
+ * \return
-int
-G_add_c_raster_color_rule(const CELL * cat1, int r1, int g1, int b1,
- const CELL * cat2, int r2, int g2, int b2,
+ const CELL * cat1, int r1, int g1, int b1,
+ const CELL * cat2, int r2, int g2, int b2,
colors->version, &colors->cmin, &colors->cmax, CELL_TYPE);
- return 1;
@@ -115,17 +112,16 @@
* \param data_type raster data type (CELL, FCELL, DCELL)
- * \return 1
+ * \return
-int
-G_add_raster_color_rule(const void *val1, int r1, int g1, int b1,
- const void *val2, int r2, int g2, int b2,
- struct Colors *colors, RASTER_MAP_TYPE data_type)
+ const void *val1, int r1, int g1, int b1,
+ const void *val2, int r2, int g2, int b2,
+ struct Colors *colors, RASTER_MAP_TYPE data_type)
colors->version, &colors->cmin, &colors->cmax, data_type);
- return 1;
@@ -158,17 +154,17 @@
* \param cat2 cell value
- * \return 1
+ * \return
-int
-G_add_color_rule(CELL cat1, int r1, int g1, int b1, CELL cat2, int r2, int g2,
- int b2, struct Colors *colors)
+ CELL cat1, int r1, int g1, int b1,
+ CELL cat2, int r2, int g2,
+ int b2, struct Colors *colors)
add_color_rule((void *)&cat1, r1, g1, b1, (void *)&cat2, r2, g2, b2,
&colors->fixed, colors->version, &colors->cmin,
- return 1;
@@ -183,10 +179,10 @@
* \return -1 on failure
* \return 1 on success
-int
-G_add_modular_d_raster_color_rule(const DCELL * val1, int r1, int g1, int b1,
+int G_add_modular_d_raster_color_rule(
DCELL min, max;
@@ -214,10 +210,10 @@
-int
-G_add_modular_f_raster_color_rule(const FCELL * val1, int r1, int g1, int b1,
- const FCELL * val2, int r2, int g2, int b2,
+int G_add_modular_f_raster_color_rule(
+ const FCELL * val1, int r1, int g1, int b1,
+ const FCELL * val2, int r2, int g2, int b2,
DCELL min, max;
@@ -245,10 +241,10 @@
-int
-G_add_modular_c_raster_color_rule(const CELL * val1, int r1, int g1, int b1,
- const CELL * val2, int r2, int g2, int b2,
+int G_add_modular_c_raster_color_rule(
+ const CELL * val1, int r1, int g1, int b1,
+ const CELL * val2, int r2, int g2, int b2,
return G_add_modular_color_rule(*val1, r1, g1, b1, *val2, r2, g2, b2,
colors);
@@ -270,11 +266,10 @@
-int
-G_add_modular_raster_color_rule(const void *val1, int r1, int g1, int b1,
- RASTER_MAP_TYPE data_type)
CELL min, max;
@@ -306,9 +301,10 @@
-int
-G_add_modular_color_rule(CELL cat1, int r1, int g1, int b1, CELL cat2, int r2,
- int g2, int b2, struct Colors *colors)
+ int b1, CELL cat2, int r2,
+ int g2, int b2, struct Colors *colors)
CELL min, max;
@@ -325,10 +321,10 @@
return 1;
-static int add_color_rule(const void *pt1, int r1, int g1, int b1,
- const void *pt2, int r2, int g2, int b2,
- struct _Color_Info_ *cp, int version, DCELL * cmin,
- DCELL * cmax, RASTER_MAP_TYPE data_type)
+static void add_color_rule(const void *pt1, int r1, int g1, int b1,
+ const void *pt2, int r2, int g2, int b2,
+ struct _Color_Info_ *cp, int version, DCELL * cmin,
+ DCELL * cmax, RASTER_MAP_TYPE data_type)
@@ -382,9 +378,9 @@
/* keep track of the overall min and max, excluding null */
if (G_is_d_null_value(&(rule->low.value)))
- return 0;
+ return;
if (G_is_d_null_value(&(rule->high.value)))
- return 0;
+ return;
min = rule->low.value;
max = rule->high.value;
if (min <= max) {
@@ -453,6 +449,4 @@
G__color_free_lookup(cp);
G__color_free_fp_lookup(cp);
- return 0;
Modified: grass/trunk/lib/gis/color_rules.c
--- grass/trunk/lib/gis/color_rules.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_rules.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -222,8 +222,7 @@
return 1;
-static int load_rules_file(struct Colors *colors, const char *path, DCELL min,
- DCELL max)
+static int load_rules_file(struct Colors *colors, const char *path, DCELL min, DCELL max)
FILE *fp;
int ret;
@@ -245,29 +244,27 @@
return load_rules_file(colors, path, (DCELL) min, (DCELL) max);
-int G_load_fp_colors(struct Colors *colors, const char *path, DCELL min,
- DCELL max)
+int G_load_fp_colors(struct Colors *colors, const char *path, DCELL min, DCELL max)
return load_rules_file(colors, path, min, max);
-static int load_rules_name(struct Colors *colors, const char *name, DCELL min,
- DCELL max)
+static void load_rules_name(struct Colors *colors, const char *name, DCELL min, DCELL max)
char path[GPATH_MAX];
sprintf(path, "%s/etc/colors/%s", G_gisbase(), name);
- return load_rules_file(colors, path, min, max);
+ if (!load_rules_file(colors, path, min, max))
+ G_fatal_error(_("Unable to load color rules <%s>"), name);
-int G_make_colors(struct Colors *colors, const char *name, CELL min, CELL max)
+void G_make_colors(struct Colors *colors, const char *name, CELL min, CELL max)
return load_rules_name(colors, name, (DCELL) min, (DCELL) max);
-int G_make_fp_colors(struct Colors *colors, const char *name, DCELL min,
- DCELL max)
+void G_make_fp_colors(struct Colors *colors, const char *name, DCELL min, DCELL max)
return load_rules_name(colors, name, min, max);
Modified: grass/trunk/lib/gis/color_set.c
--- grass/trunk/lib/gis/color_set.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_set.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -22,25 +22,23 @@
* \param green
* \param blue
* \param colors
- * \return int
+ * \return
-int G_set_color(CELL cat, int r, int g, int b, struct Colors *colors)
+void G_set_color(CELL cat, int r, int g, int b, struct Colors *colors)
- CELL tmp = cat;
- if (G_is_c_null_value(&tmp))
- return G_set_null_value_color(r, g, b, colors);
- return G_add_color_rule(cat, r, g, b, cat, r, g, b, colors);
+ if (G_is_c_null_value(&cat))
+ G_set_null_value_color(r, g, b, colors);
+ else
+ G_add_color_rule(cat, r, g, b, cat, r, g, b, colors);
-int G_set_d_color(DCELL val, int r, int g, int b, struct Colors *colors)
+void G_set_d_color(DCELL val, int r, int g, int b, struct Colors *colors)
- DCELL tmp = val;
- if (G_is_d_null_value(&tmp))
- return G_add_d_raster_color_rule(&val, r, g, b, &val, r, g, b, colors);
+ if (G_is_d_null_value(&val))
+ else
+ G_add_d_raster_color_rule(&val, r, g, b, &val, r, g, b, colors);
@@ -53,16 +51,15 @@
* \param g
* \param b
* \param colors
- * \return int
+ * \return
-int G_set_null_value_color(int red, int grn, int blu, struct Colors *colors)
+void G_set_null_value_color(int red, int grn, int blu, struct Colors *colors)
colors->null_red = red;
colors->null_grn = grn;
colors->null_blu = blu;
colors->null_set = 1;
- return 1;
@@ -76,14 +73,13 @@
* \param g
* \param b
* \param colors
- * \return int
+ * \return
-int G_set_default_color(int red, int grn, int blu, struct Colors *colors)
+void G_set_default_color(int red, int grn, int blu, struct Colors *colors)
colors->undef_red = red;
colors->undef_grn = grn;
colors->undef_blu = blu;
colors->undef_set = 1;
- return 1;
Modified: grass/trunk/lib/gis/color_shift.c
--- grass/trunk/lib/gis/color_shift.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_shift.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -1,14 +1,10 @@
-int G_shift_colors(int shift, struct Colors *colors)
+void G_shift_colors(int shift, struct Colors *colors)
colors->shift += (DCELL) shift;
- return 0;
-int G_shift_d_colors(DCELL shift, struct Colors *colors)
+void G_shift_d_colors(DCELL shift, struct Colors *colors)
colors->shift += shift;
- return 0;
Modified: grass/trunk/lib/gis/color_write.c
--- grass/trunk/lib/gis/color_write.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_write.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -24,12 +24,12 @@
#define THRESHOLD .0000000000000000000000000000005
/* .5 * 10 ^(-30) */
-static int write_new_colors(FILE *, struct Colors *);
-static int write_rules(FILE *, struct _Color_Rule_ *, DCELL, DCELL);
-static int write_old_colors(FILE *, struct Colors *);
-static int forced_write_old_colors(FILE *, struct Colors *);
-static int format_min(char *, double);
-static int format_max(char *, double);
+static void write_rules(FILE *, struct _Color_Rule_ *, DCELL, DCELL);
+static void write_new_colors(FILE *, struct Colors *);
+static void write_old_colors(FILE *, struct Colors *);
+static void forced_write_old_colors(FILE *, struct Colors *);
+static void format_min(char *, double);
+static void format_max(char *, double);
@@ -80,7 +80,6 @@
char element[512];
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
FILE *fd;
- int stat;
if (G__name_is_fully_qualified(name, xname, xmapset)) {
if (strcmp(xmapset, mapset) != 0)
@@ -100,22 +99,22 @@
if (!(fd = G_fopen_new(element, name)))
return -1;
fclose(fd);
- return stat;
+ return 1;
-int G__write_colors(FILE * fd, struct Colors *colors)
+void G__write_colors(FILE * fd, struct Colors *colors)
if (getenv("FORCE_GRASS3_COLORS"))
- return forced_write_old_colors(fd, colors);
+ forced_write_old_colors(fd, colors);
else if (colors->version < 0)
- return write_old_colors(fd, colors);
+ write_old_colors(fd, colors);
else
- return write_new_colors(fd, colors);
+ write_new_colors(fd, colors);
-static int write_new_colors(FILE * fd, struct Colors *colors)
+static void write_new_colors(FILE * fd, struct Colors *colors)
char str1[100], str2[100];
@@ -152,12 +151,10 @@
if (colors->fixed.rules)
write_rules(fd, colors->fixed.rules, colors->cmin, colors->cmax);
- return 1;
-static int write_rules(FILE * fd, struct _Color_Rule_ *crules, DCELL dmin, DCELL dmax /* overall min and max data values in color table */
+/* overall min and max data values in color table */
+static void write_rules(FILE * fd, struct _Color_Rule_ *crules, DCELL dmin, DCELL dmax)
char str[100];
@@ -193,11 +190,9 @@
fprintf(fd, "\n");
- return 0;
-static int write_old_colors(FILE * fd, struct Colors *colors)
+static void write_old_colors(FILE * fd, struct Colors *colors)
int i, n;
@@ -221,11 +216,9 @@
(int)colors->fixed.lookup.blu[i]);
fprintf(fd, "\n");
- return 1;
-static int forced_write_old_colors(FILE * fd, struct Colors *colors)
+static void forced_write_old_colors(FILE * fd, struct Colors *colors)
int red, grn, blu;
CELL cat;
@@ -241,11 +234,9 @@
fprintf(fd, " %d %d", grn, blu);
fprintf(fd, "\n");
- return 1;
-static int format_min(char *str, double dval)
+static void format_min(char *str, double dval)
double dtmp;
@@ -256,11 +247,9 @@
sprintf(str, "%.*f", PRECISION, dval - THRESHOLD);
/* because precision is probably higher than PRECISION */
- return 0;
-static int format_max(char *str, double dval)
+static void format_max(char *str, double dval)
double dtmp;
@@ -271,6 +260,4 @@
sprintf(str, "%.*f", PRECISION, dval + THRESHOLD);
- return 0;
Modified: grass/trunk/lib/gis/color_xform.c
--- grass/trunk/lib/gis/color_xform.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/color_xform.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -53,11 +53,11 @@
* \param dst
* \param src
* \param statf
- * \return int
+ * \return
-int G_histogram_eq_colors(struct Colors *dst,
- struct Colors *src, struct Cell_stats *statf)
+void G_histogram_eq_colors(struct Colors *dst,
+ struct Colors *src, struct Cell_stats *statf)
DCELL min, max;
int red, grn, blu;
@@ -83,7 +83,7 @@
total += count;
if (total <= 0)
- return 0;
+ return;
sum = 0;
prev = 0;
@@ -111,8 +111,6 @@
grn = grn2;
blu = blu2;
- return 0;
@@ -191,10 +189,10 @@
* \param dst
* \param src
* \param samples
- * \return int
+ * \return
-int G_log_colors(struct Colors *dst, struct Colors *src, int samples)
+void G_log_colors(struct Colors *dst, struct Colors *src, int samples)
DCELL min, max;
double lmin, lmax;
@@ -243,8 +241,6 @@
grn = grn2;
blu = blu2;
- return 0;
@@ -253,10 +249,10 @@
* \param dst
* \param src
* \param samples
- * \return int
+ * \return
-int G_abs_log_colors(struct Colors *dst, struct Colors *src, int samples)
+void G_abs_log_colors(struct Colors *dst, struct Colors *src, int samples)
DCELL min, max;
double lmin, lmax;
@@ -316,7 +312,5 @@
grn = grn2;
blu = blu2;
- return 0;
Modified: grass/trunk/lib/gis/commas.c
--- grass/trunk/lib/gis/commas.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/commas.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -82,10 +82,10 @@
* - 1234 stays 1234
* \param[in,out] buf string
+ * \return
-int G_remove_commas(char *buf)
+void G_remove_commas(char *buf)
char *b;
@@ -94,6 +94,4 @@
*buf++ = *b;
*buf = 0;
- return 0;
Modified: grass/trunk/lib/gis/copy.c
--- grass/trunk/lib/gis/copy.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/copy.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -25,10 +25,9 @@
* \param[in] b source (from)
* \param[in] n number of bytes to copy
+ * \return
-int G_copy(void *a, const void *b, int n)
+void G_copy(void *a, const void *b, int n)
memcpy(a, b, n);
- return 0;
Modified: grass/trunk/lib/gis/done_msg.c
--- grass/trunk/lib/gis/done_msg.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/done_msg.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -23,10 +23,10 @@
* \brief Print a final message.
* \param[in] msg string. Cannot be NULL.
+ * \return
-int G_done_msg(const char *msg, ...)
+void G_done_msg(const char *msg, ...)
char buffer[2000];
va_list ap;
@@ -36,6 +36,4 @@
va_end(ap);
G_message(_("%s complete. %s"), G_program_name(), buffer);
- return 0;
Modified: grass/trunk/lib/gis/error.c
--- grass/trunk/lib/gis/error.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/error.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -54,19 +54,18 @@
static int print_word(FILE *, char **, int *, const int);
static void print_sentence(FILE *, const int, const char *);
-static int print_error(const char *, const int);
+static void print_error(const char *, const int);
static int mail_msg(const char *, int);
static int write_error(const char *, int, time_t, const char *);
-static int log_error(const char *, int);
+static void log_error(const char *, int);
-static int vfprint_error(int type, const char *template, va_list ap)
+static void vfprint_error(int type, const char *template, va_list ap)
char buffer[2000]; /* G_asprintf does not work */
vsprintf(buffer, template, ap);
- return print_error(buffer, type);
+ print_error(buffer, type);
@@ -85,8 +84,6 @@
vfprint_error(MSG, msg, ap);
va_end(ap);
- return;
@@ -106,8 +103,6 @@
va_end(ap);
- return;
@@ -130,8 +125,6 @@
va_end(ap);
- return;
@@ -152,7 +145,7 @@
* \return Terminates with an exit status of EXIT_FAILURE if no external
* routine is specified by G_set_error_routine()
-int G_fatal_error(const char *msg, ...)
+void G_fatal_error(const char *msg, ...)
va_list ap;
@@ -173,20 +166,18 @@
* \param msg string (cannot be NULL)
- * \return 0
+ * \return
-int G_warning(const char *msg, ...)
+void G_warning(const char *msg, ...)
va_list ap;
if (no_warn)
- return 0;
+ return;
va_start(ap, msg);
vfprint_error(WARN, msg, ap);
va_end(ap);
- return 0;
@@ -228,12 +219,11 @@
* \param error_routine routine will be called like this: error_routine(msg,
* fatal)
- * \return 0
+ * \return
-int G_set_error_routine(int (*error_routine) (const char *, int))
+void G_set_error_routine(int (*error_routine) (const char *, int))
ext_error = error_routine; /* Roger Bivand 17 June 2000 */
- return 0;
@@ -244,15 +234,13 @@
* \return 0
ext_error = 0; /* Roger Bivand 17 June 2000 */
- return 0;
/* Print info to stderr and optionally to log file and optionally send mail */
-static int print_error(const char *msg, const int type)
+static void print_error(const char *msg, const int type)
int fatal, format;
@@ -297,11 +285,9 @@
print_sentence(stderr, type, msg);
- return 0;
-static int log_error(const char *msg, int fatal)
+static void log_error(const char *msg, int fatal)
char cwd[GPATH_MAX];
time_t clock;
@@ -316,8 +302,6 @@
/* write the error log file */
if ((gisbase = G_gisbase()))
write_error(msg, fatal, clock, cwd);
- return 0;
Modified: grass/trunk/lib/gis/fpreclass.c
--- grass/trunk/lib/gis/fpreclass.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/fpreclass.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -284,12 +284,10 @@
-int G_fpreclass_init(struct FPReclass *r)
+void G_fpreclass_init(struct FPReclass *r)
r->maxNofRules = 0;
G_fpreclass_reset(r);
- return 1;
@@ -312,9 +310,9 @@
-static void
-fpreclass_set_limits(struct FPReclass *r, DCELL dLow, DCELL dHigh, DCELL rLow,
- DCELL rHigh)
+static void fpreclass_set_limits(struct FPReclass *r,
+ DCELL dLow, DCELL dHigh,
+ DCELL rLow, DCELL rHigh)
r->dMin = dLow;
r->dMax = dHigh;
@@ -324,9 +322,9 @@
-static void
-fpreclass_update_limits(struct FPReclass *r, DCELL dLow, DCELL dHigh,
- DCELL rLow, DCELL rHigh)
+static void fpreclass_update_limits(struct FPReclass *r,
if (NO_EXPLICIT_RULE) {
fpreclass_set_limits(r, dLow, dHigh, rLow, rHigh);
@@ -341,9 +339,9 @@
-int
-G_fpreclass_get_limits(const struct FPReclass *r, DCELL * dMin, DCELL * dMax,
- DCELL * rMin, DCELL * rMax)
+int G_fpreclass_get_limits(const struct FPReclass *r,
+ DCELL * dMin, DCELL * dMax,
+ DCELL * rMin, DCELL * rMax)
if (NO_DEFAULT_RULE)
@@ -381,9 +379,9 @@
-void
-G_fpreclass_get_ith_rule(const struct FPReclass *r, int i, DCELL * dLow,
- DCELL * dHigh, DCELL * rLow, DCELL * rHigh)
+void G_fpreclass_get_ith_rule(const struct FPReclass *r, int i,
+ DCELL *dLow, DCELL *dHigh,
+ DCELL *rLow, DCELL *rHigh)
*dLow = r->table[i].dLow;
*dHigh = r->table[i].dHigh;
@@ -424,9 +422,8 @@
-int
-G_fpreclass_get_neg_infinite_rule(const struct FPReclass *r, DCELL * dLeft,
- DCELL * c)
+int G_fpreclass_get_neg_infinite_rule(const struct FPReclass *r,
+ DCELL *dLeft, DCELL *c)
if (r->infiniteLeftSet == 0)
return 0;
@@ -439,8 +436,7 @@
-void
-G_fpreclass_set_pos_infinite_rule(struct FPReclass *r, DCELL dRight, DCELL c)
+void G_fpreclass_set_pos_infinite_rule(struct FPReclass *r, DCELL dRight, DCELL c)
r->infiniteDRight = dRight;
r->infiniteRRight = c;
@@ -450,9 +446,8 @@
-int
-G_fpreclass_get_pos_infinite_rule(const struct FPReclass *r, DCELL * dRight,
- DCELL * c)
+int G_fpreclass_get_pos_infinite_rule(const struct FPReclass *r,
+ DCELL *dRight, DCELL *c)
if (r->infiniteRightSet == 0)
return 0;
@@ -465,9 +460,9 @@
-void
-G_fpreclass_add_rule(struct FPReclass *r, DCELL dLow, DCELL dHigh, DCELL rLow,
- DCELL rHigh)
+void G_fpreclass_add_rule(struct FPReclass *r,
int i;
struct FPReclass_table *p;
@@ -528,9 +523,10 @@
-static DCELL
-fpreclass_interpolate(DCELL dLow, DCELL dHigh, DCELL rLow, DCELL rHigh,
- DCELL dValue)
+static DCELL fpreclass_interpolate(
+ DCELL rLow, DCELL rHigh,
+ DCELL dValue)
if (rLow == rHigh)
return rLow;
@@ -542,8 +538,7 @@
-static DCELL
-fpreclass_get_default_cell_value(const struct FPReclass *r, DCELL cellVal)
+static DCELL fpreclass_get_default_cell_value(const struct FPReclass *r, DCELL cellVal)
DCELL tmp;
@@ -593,9 +588,8 @@
-void
-G_fpreclass_perform_di(const struct FPReclass *r, const DCELL * dcell,
- CELL * cell, int n)
+void G_fpreclass_perform_di(const struct FPReclass *r,
+ const DCELL *dcell, CELL *cell, int n)
int i;
@@ -608,9 +602,8 @@
-void
-G_fpreclass_perform_df(const struct FPReclass *r, const DCELL * dcell,
- FCELL * cell, int n)
+void G_fpreclass_perform_df(const struct FPReclass *r,
+ const DCELL *dcell, FCELL *cell, int n)
int i;
@@ -623,9 +616,8 @@
-void
-G_fpreclass_perform_dd(const struct FPReclass *r, const DCELL * dcell,
- DCELL * cell, int n)
+void G_fpreclass_perform_dd(const struct FPReclass *r,
+ const DCELL *dcell, DCELL *cell, int n)
int i;
@@ -638,9 +630,8 @@
-void
-G_fpreclass_perform_fi(const struct FPReclass *r, const FCELL * fcell,
+void G_fpreclass_perform_fi(const struct FPReclass *r,
+ const FCELL *fcell, CELL *cell, int n)
int i;
@@ -653,9 +644,8 @@
-void
-G_fpreclass_perform_ff(const struct FPReclass *r, const FCELL * fcell,
+void G_fpreclass_perform_ff(const struct FPReclass *r,
+ const FCELL *fcell, FCELL *cell, int n)
int i;
@@ -668,9 +658,8 @@
-void
-G_fpreclass_perform_fd(const struct FPReclass *r, const FCELL * fcell,
+void G_fpreclass_perform_fd(const struct FPReclass *r,
+ const FCELL *fcell, DCELL *cell, int n)
int i;
@@ -683,9 +672,8 @@
-void
-G_fpreclass_perform_ii(const struct FPReclass *r, const CELL * icell,
+void G_fpreclass_perform_ii(const struct FPReclass *r,
+ const CELL *icell, CELL *cell, int n)
int i;
@@ -698,9 +686,8 @@
-void
-G_fpreclass_perform_if(const struct FPReclass *r, const CELL * icell,
+void G_fpreclass_perform_if(const struct FPReclass *r,
+ const CELL *icell, FCELL *cell, int n)
int i;
@@ -713,9 +700,8 @@
-void
-G_fpreclass_perform_id(const struct FPReclass *r, const CELL * icell,
+void G_fpreclass_perform_id(const struct FPReclass *r,
+ const CELL *icell, DCELL *cell, int n)
int i;
Modified: grass/trunk/lib/gis/geodesic.c
--- grass/trunk/lib/gis/geodesic.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/geodesic.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -28,8 +28,8 @@
-static int adjust_lat(double *);
-static int adjust_lon(double *);
+static void adjust_lat(double *);
+static void adjust_lon(double *);
static struct state {
double A, B;
@@ -80,22 +80,18 @@
return Degrees(atan(st->A * sin(lon) - st->B * cos(lon)));
-static int adjust_lon(double *lon)
+static void adjust_lon(double *lon)
while (*lon > 180.0)
*lon -= 360.0;
while (*lon < -180.0)
*lon += 360.0;
- return 0;
-static int adjust_lat(double *lat)
+static void adjust_lat(double *lat)
if (*lat > 90.0)
*lat = 90.0;
if (*lat < -90.0)
*lat = -90.0;
- return 0;
Modified: grass/trunk/lib/gis/geodist.c
--- grass/trunk/lib/gis/geodist.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/geodist.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -49,17 +49,15 @@
* \param[in] a semi-major axis in meters
+ * \return
-int G_begin_geodesic_distance(double a, double e2)
+void G_begin_geodesic_distance(double a, double e2)
st->al = a;
st->boa = sqrt(1 - e2);
st->f = 1 - st->boa;
st->ff64 = st->f * st->f / 64;
- return 0;
@@ -72,14 +70,12 @@
* <b>Note:</b> Must be called first.
* \param[in] lat1 first latitude
+ * \return
-int G_set_geodesic_distance_lat1(double lat1)
+void G_set_geodesic_distance_lat1(double lat1)
st->t1r = atan(st->boa * tan(Radians(lat1)));
- return 0;
@@ -91,10 +87,10 @@
* <b>Note:</b> Must be called second.
* \param[in] lat2 second latitidue
+ * \return
-int G_set_geodesic_distance_lat2(double lat2)
+void G_set_geodesic_distance_lat2(double lat2)
double stm, ctm, sdtm, cdtm;
double tm, dtm;
@@ -117,8 +113,6 @@
st->t3 = sdtm * sdtm;
st->t4 = cdtm * cdtm - stm * stm;
- return 0;
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/gisinit.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -41,12 +41,12 @@
* \return exit() is called on error
-int G__gisinit(const char *version, const char *pgm)
+void G__gisinit(const char *version, const char *pgm)
char *mapset;
if (initialized)
- return 0;
+ return;
G_set_program_name(pgm);
@@ -67,8 +67,6 @@
gisinit();
- return 0;
@@ -77,34 +75,31 @@
* Initializes GIS engine, but does not check for a valid mapset.
- * \return always returns 0 on success
+ * \return
-int G__no_gisinit(const char *version)
+void G__no_gisinit(const char *version)
if (initialized)
- return 0;
+ return;
if (strcmp(version, GIS_H_VERSION) != 0)
G_fatal_error(_("Incompatible library version for module"));
gisinit();
- return 0;
* \brief Checks to see if GIS engine is initialized.
- * \return 1 on success
- * \return exit() is called on error
+ * \return
-int G__check_gisinit(void)
+void G__check_gisinit(void)
if (initialized)
- return 1;
+ return;
G_warning(_("System not initialized. Programmer forgot to call G_gisinit()."));
G_sleep(3);
exit(EXIT_FAILURE);
Modified: grass/trunk/lib/gis/histo_eq.c
--- grass/trunk/lib/gis/histo_eq.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/histo_eq.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -10,8 +10,9 @@
* inputs are histo, output is map,min,max
-int G_histogram_eq(const struct Histogram *histo,
- unsigned char **map, CELL * min, CELL * max)
+void G_histogram_eq(const struct Histogram *histo,
+ unsigned char **map, CELL *min, CELL *max)
int i;
int x;
@@ -30,7 +31,7 @@
*min = *max = G_get_histogram_cat(0, histo);
*map = xmap = (unsigned char *)G_malloc(1);
*xmap = 0;
- return 0;
+ return;
if ((*min = G_get_histogram_cat(first = 0, histo)) == 0)
*min = G_get_histogram_cat(++first, histo);
@@ -50,7 +51,7 @@
if (total <= 0) {
for (i = 0; i < len; i++)
xmap[i] = 0;
- return 0;
+ return;
span = total / 256;
@@ -73,6 +74,4 @@
while (prev++ <= cat)
*xmap++ = x;
- return 0;
Modified: grass/trunk/lib/gis/histogram.c
--- grass/trunk/lib/gis/histogram.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/histogram.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -16,15 +16,13 @@
* initializes the histogram structure for calls to G_set_histogram()
* and G_add_histogram()
* \param histogram
- * \return int
+ * \return
-int G_init_histogram(struct Histogram *histogram)
+void G_init_histogram(struct Histogram *histogram)
histogram->num = 0;
histogram->list = NULL;
- return 0;
@@ -158,9 +156,9 @@
* \param statf: cell statistics
* \param histogram: raster histogram
- * \return 0
+ * \return
-int G_make_histogram_cs(struct Cell_stats *statf, struct Histogram *histogram)
+void G_make_histogram_cs(struct Cell_stats *statf, struct Histogram *histogram)
CELL cat;
long count;
@@ -171,8 +169,6 @@
G_add_histogram(cat, count, histogram);
G_sort_histogram(histogram);
- return 0;
@@ -231,14 +227,12 @@
* \param histogram: struct for histogram
* \return
-int G_free_histogram(struct Histogram *histogram)
+void G_free_histogram(struct Histogram *histogram)
if (histogram->num > 0)
G_free(histogram->list);
histogram->num = 0;
- return 1;
@@ -365,14 +359,12 @@
* Removes the histogram information associated with map layer "name"
* \param name: name of map
- * \return 0
+ * \return
-int G_remove_histogram(const char *name)
+void G_remove_histogram(const char *name)
G_remove_misc("cell_misc", "histogram", name);
- return 0;
@@ -436,16 +428,14 @@
* \return
-int G_extend_histogram(CELL cat, long count, struct Histogram *histogram)
+void G_extend_histogram(CELL cat, long count, struct Histogram *histogram)
histogram->num++;
histogram->list =
- (LIST *) G_realloc((char *)histogram->list,
+ (LIST *) G_realloc(histogram->list,
histogram->num * sizeof(LIST));
histogram->list[histogram->num - 1].cat = cat;
histogram->list[histogram->num - 1].count = count;
- return 0;
@@ -455,12 +445,10 @@
* \return
-int G_zero_histogram(struct Histogram *histogram)
+void G_zero_histogram(struct Histogram *histogram)
int i;
for (i = 0; i < histogram->num; i++)
histogram->list[i].count = 0;
- return 0;
Modified: grass/trunk/lib/gis/history.c
--- grass/trunk/lib/gis/history.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/history.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -196,10 +196,10 @@
* \param name
* \param type
* \param history
- * \return int
+ * \return
-int G_short_history(const char *name, const char *type, struct History *hist)
+void G_short_history(const char *name, const char *type, struct History *hist)
strncpy(hist->mapid, G_date(), RECORD_LEN);
strncpy(hist->title, name, RECORD_LEN);
@@ -211,8 +211,6 @@
strcpy(hist->datsrc_1, "");
strcpy(hist->datsrc_2, "");
hist->edlinecnt = 0;
- return 1;
Modified: grass/trunk/lib/gis/key_value1.c
--- grass/trunk/lib/gis/key_value1.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/key_value1.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -140,9 +140,9 @@
\param[in] kv Key_Value structure
- \return 0
+ \return
-int G_free_key_value(struct Key_Value *kv)
+void G_free_key_value(struct Key_Value *kv)
int n;
@@ -155,6 +155,4 @@
kv->nitems = 0; /* just for safe measure */
kv->nalloc = 0;
G_free(kv);
- return 0;
Modified: grass/trunk/lib/gis/line_dist.c
--- grass/trunk/lib/gis/line_dist.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/line_dist.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -5,13 +5,11 @@
#define TOLERANCE 1.0e-10
static double tolerance = TOLERANCE;
-int G_set_distance_to_line_tolerance(double t)
+void G_set_distance_to_line_tolerance(double t)
if (t <= 0.0)
t = TOLERANCE;
tolerance = t;
- return 0;
double G_distance2_point_to_line(double x, double y, /* point */
Modified: grass/trunk/lib/gis/list.c
--- grass/trunk/lib/gis/list.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/list.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -48,12 +48,12 @@
\param lister If given will call this routine to get a list
title. NULL if no titles desired.
- \return Number of elements
+ \return
-int G_list_element(const char *element,
- const char *desc,
- const char *mapset,
- int (*lister) (const char *, const char *, const char *))
+void G_list_element(const char *element,
+ const char *desc,
+ const char *mapset,
+ int (*lister) (const char *, const char *, const char *))
int n;
FILE *more;
@@ -123,8 +123,6 @@
#ifdef SIGPIPE
signal(SIGPIPE, sigpipe);
#endif
- return 0;
static void sigpipe_catch(int n)
Modified: grass/trunk/lib/gis/ll_format.c
--- grass/trunk/lib/gis/ll_format.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/ll_format.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -35,10 +35,10 @@
#include <string.h>
-static int format(char *, int, int, double, char);
-static int ll_parts(double, int *, int *, double *);
+static void format(char *, int, int, double, char);
+static void ll_parts(double, int *, int *, double *);
-int G_lat_format(double lat, char *buf)
+void G_lat_format(double lat, char *buf)
int d, m;
char h;
@@ -46,8 +46,6 @@
G_lat_parts(lat, &d, &m, &s, &h);
format(buf, d, m, s, h);
- return 0;
char *G_lat_format_string(void)
@@ -55,7 +53,7 @@
return "dd:mm:ss{N|S}";
-int G_lon_format(double lon, char *buf)
+void G_lon_format(double lon, char *buf)
int d, m;
char h;
@@ -63,15 +61,14 @@
G_lon_parts(lon, &d, &m, &s, &h);
- return 0;
char *G_lon_format_string(void)
return "ddd:mm:ss{E|W}";
-int G_llres_format(double res, char *buf)
+void G_llres_format(double res, char *buf)
int d, m;
char h;
@@ -80,16 +77,14 @@
G_lat_parts(res, &d, &m, &s, &h);
h = 0;
- return 0;
char *G_llres_format_string(void)
return "dd:mm:ss";
-static int format(char *buf, int d, int m, double s, char h)
+static void format(char *buf, int d, int m, double s, char h)
char temp[50];
double ss;
@@ -117,14 +112,12 @@
sprintf(buf, "%d%c", d, h);
else
sprintf(buf, "0");
- return 0;
-int G_lat_parts(double lat, /* lat in degrees to be split into parts */
- int *d, int *m, /* degrees, minutes */
- double *s, /* seconds */
- char *h /* hemisphere */
+void G_lat_parts(double lat, /* lat in degrees to be split into parts */
+ int *d, int *m, /* degrees, minutes */
+ double *s, /* seconds */
+ char *h /* hemisphere */
if (lat < 0) {
@@ -135,14 +128,12 @@
*h = 'N';
ll_parts(lat, d, m, s);
- return 0;
-int G_lon_parts(double lon, /* lon in degrees to be split into parts */
+void G_lon_parts(double lon, /* lon in degrees to be split into parts */
while (lon > 180.0)
@@ -158,14 +149,13 @@
*h = 'E';
ll_parts(lon, d, m, s);
- return 0;
-static int ll_parts(double ll, /* ll in degrees to be split into parts */
- double *s)
-{ /* seconds */
+static void ll_parts(double ll, /* ll in degrees to be split into parts */
+ double *s /* seconds */
if (ll == 0.0) {
*d = 0;
*m = 0;
@@ -180,6 +170,4 @@
if (*s < 0)
*s = 0;
- return 0;
Modified: grass/trunk/lib/gis/ls.c
--- grass/trunk/lib/gis/ls.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/ls.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -140,8 +140,6 @@
G_free(dir_listing[i]);
G_free(dir_listing);
- return;
@@ -218,6 +216,4 @@
- return;
Modified: grass/trunk/lib/gis/null_val.c
--- grass/trunk/lib/gis/null_val.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/null_val.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -24,7 +24,7 @@
-static int EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
+static void EmbedGivenNulls(void *, char *, RASTER_MAP_TYPE, int);
* int EmbedGivenNulls (void *cell, char *nulls, RASTER_MAP_TYPE map_type,
@@ -37,7 +37,7 @@
* ncols => ??
* RETURN VAL: ??
-static int EmbedGivenNulls(void *cell, char *nulls, RASTER_MAP_TYPE map_type,
+static void EmbedGivenNulls(void *cell, char *nulls, RASTER_MAP_TYPE map_type,
int ncols)
CELL *c;
@@ -69,8 +69,6 @@
- return 1;
/*========================== Library Functions =============================*/
@@ -96,8 +94,6 @@
G_set_null_value(rast, numVals, data_type);
- return;
@@ -127,8 +123,6 @@
default:
G_warning(_("G_set_null_value: wrong data type!"));
- return;
@@ -344,13 +338,13 @@
* \param flags
* \param count
* \param data_type
- * \return int
+ * \return
-int G_insert_null_values(void *rast, char *null_row, int ncols,
+void G_insert_null_values(void *rast, char *null_row, int ncols,
+ RASTER_MAP_TYPE data_type)
- return (EmbedGivenNulls(rast, null_row, data_type, ncols));
+ EmbedGivenNulls(rast, null_row, data_type, ncols);
@@ -373,12 +367,12 @@
* \param cell
* \param flags
* \param count
- * \return int
+ * \return
-int G_insert_c_null_values(CELL * cellVal, char *null_row, int ncols)
+void G_insert_c_null_values(CELL * cellVal, char *null_row, int ncols)
- return (EmbedGivenNulls((void *)cellVal, null_row, CELL_TYPE, ncols));
+ EmbedGivenNulls((void *)cellVal, null_row, CELL_TYPE, ncols);
@@ -401,12 +395,12 @@
* \param fcell
* \param flags
* \param count
- * \return int
+ * \return
-int G_insert_f_null_values(FCELL * fcellVal, char *null_row, int ncols)
+void G_insert_f_null_values(FCELL * fcellVal, char *null_row, int ncols)
- return (EmbedGivenNulls((void *)fcellVal, null_row, FCELL_TYPE, ncols));
+ EmbedGivenNulls((void *)fcellVal, null_row, FCELL_TYPE, ncols);
@@ -429,12 +423,12 @@
* \param dcell
* \param flags
* \param count
- * \return int
+ * \return
-int G_insert_d_null_values(DCELL * dcellVal, char *null_row, int ncols)
+void G_insert_d_null_values(DCELL * dcellVal, char *null_row, int ncols)
- return (EmbedGivenNulls((void *)dcellVal, null_row, DCELL_TYPE, ncols));
+ EmbedGivenNulls((void *)dcellVal, null_row, DCELL_TYPE, ncols);
@@ -531,7 +525,7 @@
* n => ??
* RETURN VAL: ??
-int G__convert_01_flags(const char *zero_ones, unsigned char *flags, int n)
+void G__convert_01_flags(const char *zero_ones, unsigned char *flags, int n)
unsigned char *v;
int count;
@@ -557,8 +551,6 @@
v++;
- return 0;
@@ -570,7 +562,7 @@
* n => ??
* RETURN VAL: ??
-int G__convert_flags_01(char *zero_ones, const unsigned char *flags, int n)
+void G__convert_flags_01(char *zero_ones, const unsigned char *flags, int n)
const unsigned char *v;
int count;
@@ -593,8 +585,6 @@
v++;
- return 0;
@@ -605,7 +595,7 @@
* cols => ??
* RETURN VAL: ??
-int G__init_null_bits(unsigned char *flags, int cols)
+void G__init_null_bits(unsigned char *flags, int cols)
unsigned char *v;
int size;
@@ -625,6 +615,4 @@
v++;
- return 0;
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/parser.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -123,7 +123,7 @@
static struct state *st = &state;
-static int show_options(int, const char *);
+static void show_options(int, const char *);
static int show(const char *, int);
static int set_flag(int);
static int contains(const char *, int);
@@ -135,10 +135,10 @@
static int check_double(const char *, const char **);
static int check_string(const char *, const char **, int *);
static int check_required(void);
-static int split_opts(void);
+static void split_opts(void);
static int check_multiple_opts(void);
static int check_overwrite(void);
-static int split_gisprompt(const char *, char *, char *, char *);
+static void split_gisprompt(const char *, char *, char *, char *);
static void G_gui(void);
static void G_tcltk(void);
@@ -1040,10 +1040,10 @@
* the standard usage message and print additional information about how
* the two options work together.
+ * \return
-int G_usage(void)
+void G_usage(void)
struct Option *opt;
struct Flag *flag;
@@ -1212,8 +1212,6 @@
opt = opt->next_opt;
- return 0;
@@ -2049,7 +2047,7 @@
-static int show_options(int maxlen, const char *str)
+static void show_options(int maxlen, const char *str)
char *buff = G_store(str);
char *p1, *p2;
@@ -2075,8 +2073,6 @@
fprintf(stderr, "%s\n", p1);
G_free(buff);
- return 0;
static int show(const char *item, int len)
@@ -2411,7 +2407,7 @@
return (err);
struct Option *opt;
char *ptr1;
@@ -2422,7 +2418,7 @@
if (!st->n_opts)
- return 0;
+ return;
opt = &st->first_option;
while (opt != NULL) {
@@ -2467,8 +2463,6 @@
- return 0;
@@ -2579,8 +2573,8 @@
return (error);
-static int split_gisprompt(const char *gisprompt, char *age, char *element,
- char *desc)
+static void split_gisprompt(const char *gisprompt, char *age, char *element,
+ char *desc)
const char *ptr1;
char *ptr2;
@@ -2605,8 +2599,6 @@
*ptr2 = *ptr1;
*ptr2 = '\0';
- return 0;
Modified: grass/trunk/lib/gis/percent.c
--- grass/trunk/lib/gis/percent.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/percent.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -68,8 +68,6 @@
st->prev = -1;
st->first = 1;
- return;
Modified: grass/trunk/lib/gis/plot.c
--- grass/trunk/lib/gis/plot.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/plot.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -17,16 +17,16 @@
#include <math.h>
#include <grass/gis.h>
-static int fastline(double, double, double, double);
-static int slowline(double, double, double, double);
-static int plot_line(double, double, double, double, int (*)());
+static void fastline(double, double, double, double);
+static void slowline(double, double, double, double);
+static void plot_line(double, double, double, double, void (*)());
static double nearest(double, double);
static int edge(double, double, double, double);
static int edge_point(double, int);
static int edge_order(const void *, const void *);
-static int row_solid_fill(int, double, double);
-static int row_dotted_fill(int, double, double);
+static void row_solid_fill(int, double, double);
+static void row_dotted_fill(int, double, double);
static int ifloor(double);
static int iceil(double);
@@ -47,7 +47,7 @@
int np;
int npalloc;
- int (*row_fill)(int, double, double);
+ void (*row_fill)(int, double, double);
int (*move)(int, int);
int (*cont)(int, int);
} state;
@@ -102,11 +102,11 @@
* to x,y. Cont(~) is responsible for clipping
* \param ~
- * \return int
+ * \return
-int G_setup_plot(double t, double b, double l, double r,
- int (*Move) (int, int), int (*Cont) (int, int))
+void G_setup_plot(double t, double b, double l, double r,
+ int (*Move) (int, int), int (*Cont) (int, int))
G_get_set_window(&st->window);
@@ -129,8 +129,6 @@
st->move = Move;
st->cont = Cont;
- return 0;
@@ -142,9 +140,9 @@
* row_solid_fill is used.
* \param int
- * \return int
+ * \return
-int G_setup_fill(int gap)
+void G_setup_fill(int gap)
if (gap > 0) {
st->row_fill = row_dotted_fill;
@@ -152,8 +150,6 @@
else
st->row_fill = row_solid_fill;
- return 0;
#define X(e) (st->left + st->xconv * ((e) - st->window.west))
@@ -173,15 +169,13 @@
* \param north
* \param x
* \param y
- * \return int
+ * \return
-int G_plot_where_xy(double east, double north, int *x, int *y)
+void G_plot_where_xy(double east, double north, int *x, int *y)
*x = ifloor(X(G_adjust_easting(east, &st->window)) + 0.5);
*y = ifloor(Y(north) + 0.5);
- return 0;
@@ -195,26 +189,22 @@
* \param y
* \param east
* \param north
- * \return int
+ * \return
-int G_plot_where_en(int x, int y, double *east, double *north)
+void G_plot_where_en(int x, int y, double *east, double *north)
*east = G_adjust_easting(EAST(x), &st->window);
*north = NORTH(y);
- return 0;
-int G_plot_point(double east, double north)
+void G_plot_point(double east, double north)
int x, y;
G_plot_where_xy(east, north, &x, &y);
st->move(x, y);
st->cont(x, y);
- return 0;
@@ -235,29 +225,27 @@
* \param north1
* \param east2
* \param north2
- * \return int
+ * \return
-int G_plot_line(double east1, double north1, double east2, double north2)
+void G_plot_line(double east1, double north1, double east2, double north2)
- return plot_line(east1, north1, east2, north2, fastline);
+ plot_line(east1, north1, east2, north2, fastline);
-int G_plot_line2(double east1, double north1, double east2, double north2)
+void G_plot_line2(double east1, double north1, double east2, double north2)
- return plot_line(east1, north1, east2, north2, slowline);
+ plot_line(east1, north1, east2, north2, slowline);
/* fastline converts double rows/cols to ints then plots
* this is ok for graphics, but not the best for vector to raster
-static int fastline(double x1, double y1, double x2, double y2)
+static void fastline(double x1, double y1, double x2, double y2)
st->move(ifloor(x1 + 0.5), ifloor(y1 + 0.5));
st->cont(ifloor(x2 + 0.5), ifloor(y2 + 0.5));
- return 0;
/* NOTE (shapiro):
@@ -266,7 +254,7 @@
* be adjusted for this: left=-0.5; right = window.cols-0.5;
-static int slowline(double x1, double y1, double x2, double y2)
+static void slowline(double x1, double y1, double x2, double y2)
double dx, dy;
double m, b;
@@ -320,12 +308,10 @@
- return 0;
-static int plot_line(double east1, double north1, double east2, double north2,
- int (*line) (double, double, double, double))
+static void plot_line(double east1, double north1, double east2, double north2,
+ void (*line)(double, double, double, double))
double x1, x2, y1, y2;
@@ -371,8 +357,6 @@
x2 = X(east2);
line(x1, y1, x2, y2);
- return 0;
@@ -750,7 +734,7 @@
return (0);
-static int row_solid_fill(int y, double x1, double x2)
+static void row_solid_fill(int y, double x1, double x2)
int i1, i2;
@@ -760,16 +744,14 @@
st->move(i1, y);
st->cont(i2, y);
- return 0;
-static int row_dotted_fill(int y, double x1, double x2)
+static void row_dotted_fill(int y, double x1, double x2)
int i1, i2, i;
if (y != iceil(y / st->dotted_fill_gap) * st->dotted_fill_gap)
- return 0;
+ return;
i1 = iceil(x1 / st->dotted_fill_gap) * st->dotted_fill_gap;
i2 = ifloor(x2);
@@ -779,8 +761,6 @@
st->cont(i, y);
- return 0;
static int ifloor(double x)
@@ -821,7 +801,7 @@
* \return int
-int G_plot_fx(double (*f) (double), double east1, double east2)
+void G_plot_fx(double (*f) (double), double east1, double east2)
double east, north, north1;
double incr;
@@ -848,7 +828,6 @@
east = east1;
- G_plot_line(east, north, east2, f(east2));
- return 0;
+ G_plot_line(east, north, east2, f(east2));
Modified: grass/trunk/lib/gis/pole_in_poly.c
--- grass/trunk/lib/gis/pole_in_poly.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/pole_in_poly.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -16,7 +16,7 @@
* no check is made by this routine for valid projection
-static int mystats(double, double, double, double, double *, double *);
+static void mystats(double, double, double, double, double *, double *);
@@ -63,8 +63,8 @@
return total_area >= 0.0 ? 1 : -1;
-static int mystats(double x0, double y0, double x1, double y1, double *len,
- double *area)
+static void mystats(double x0, double y0, double x1, double y1, double *len,
+ double *area)
if (x1 > x0)
while (x1 - x0 > 180)
@@ -79,6 +79,4 @@
*area = (x0 - x1) * (y0 + y1) / 2.0;
else
*area = (x1 - x0) * (y1 + y0) / 2.0;
- return 0;
Modified: grass/trunk/lib/gis/put_row.c
--- grass/trunk/lib/gis/put_row.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/put_row.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -189,8 +189,6 @@
G_warning(_("map [%s] - unable to write row %d"), fcb->name, row);
fcb->io_error = 1;
- return;
Modified: grass/trunk/lib/gis/quant.c
--- grass/trunk/lib/gis/quant.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/quant.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -416,18 +416,16 @@
* Initializes the <em>q</em> struct.
* \param q
- * \return int
+ * \return
-int G_quant_init(struct Quant *quant)
+void G_quant_init(struct Quant *quant)
quant->fp_lookup.active = 0;
quant->maxNofRules = 0;
quant->truncate_only = 0;
quant->round_only = 0;
G_quant_clear(quant);
- return 1;
@@ -446,7 +444,6 @@
* \brief
@@ -454,10 +451,16 @@
* rules to perform simple truncation on floats.
* \param q
- * \return int
+ * \return
+void G_quant_truncate(struct Quant *quant)
+ quant->truncate_only = 1;
* \brief
@@ -465,21 +468,12 @@
* rules to perform simple rounding on floats.
* \param q
- * \return int
+ * \return
-int G_quant_truncate(struct Quant *quant)
+void G_quant_round(struct Quant *quant)
- quant->truncate_only = 1;
- return 1;
-int G_quant_round(struct Quant *quant)
quant->round_only = 1;
- return 1;
Modified: grass/trunk/lib/gis/range.c
--- grass/trunk/lib/gis/range.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/range.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -92,11 +92,9 @@
/* range functions for type "Range" */
-int G__remove_fp_range(const char *name)
+void G__remove_fp_range(const char *name)
G_remove_misc("cell_misc", "f_range", name);
- return 0;
@@ -106,15 +104,13 @@
* Sets the integer range <em>r</em> to [1,255]
* \param r
- * \return int
+ * \return
-int G_construct_default_range(struct Range *range)
+void G_construct_default_range(struct Range *range)
G_update_range(DEFAULT_CELL_MIN, range);
G_update_range(DEFAULT_CELL_MAX, range);
- return 0;
@@ -371,7 +367,7 @@
* created.
* \param r
- * \return int
+ * \return
int G_write_fp_range(const char *name, const struct FPRange *range)
@@ -425,44 +421,41 @@
* \param cat
* \param range
- * \return int
+ * \return
-int G_update_range(CELL cat, struct Range *range)
+void G_update_range(CELL cat, struct Range *range)
if (!G_is_c_null_value(&cat)) {
if (range->first_time) {
range->first_time = 0;
range->min = cat;
range->max = cat;
- return 0;
+ return;
if (cat < range->min)
range->min = cat;
if (cat > range->max)
range->max = cat;
- return 0;
-int G_update_fp_range(DCELL val, struct FPRange *range)
+void G_update_fp_range(DCELL val, struct FPRange *range)
if (!G_is_d_null_value(&val)) {
range->min = val;
range->max = val;
- return 0;
+ return;
if (val < range->min)
range->min = val;
if (val > range->max)
range->max = val;
- return 0;
@@ -478,20 +471,18 @@
* \param cell
* \param n
* \param range
- * \return int
+ * \return
-int G_row_update_range(const CELL * cell, int n, struct Range *range)
+void G_row_update_range(const CELL *cell, int n, struct Range *range)
G__row_update_range(cell, n, range, 0);
- return 0;
-int G__row_update_range(const CELL * cell, int n,
- struct Range *range, int ignore_zeros)
+void G__row_update_range(const CELL *cell, int n,
+ struct Range *range, int ignore_zeros)
CELL cat;
@@ -510,14 +501,12 @@
range->max = cat;
- return 0;
-int G_row_update_fp_range(const void *rast, int n,
- struct FPRange *range, RASTER_MAP_TYPE data_type)
+void G_row_update_fp_range(const void *rast, int n,
+ struct FPRange *range, RASTER_MAP_TYPE data_type)
DCELL val = 0L;
@@ -552,8 +541,6 @@
rast = G_incr_void_ptr(rast, G_raster_size(data_type));
- return 0;
@@ -568,16 +555,14 @@
* no min/max have been defined - probably a <tt>"first"</tt> boolean flag.
* \param range
- * \return int
+ * \return
-int G_init_range(struct Range *range)
+void G_init_range(struct Range *range)
G_set_c_null_value(&(range->min), 1);
G_set_c_null_value(&(range->max), 1);
range->first_time = 1;
- return 0;
@@ -596,11 +581,11 @@
* \param range
* \param min
* \param max
- * \return int
+ * \return
-int G_get_range_min_max(const struct Range *range, CELL * min, CELL * max)
+void G_get_range_min_max(const struct Range *range, CELL * min, CELL * max)
G_set_c_null_value(min, 1);
@@ -617,8 +602,6 @@
else
*max = range->max;
- return 0;
@@ -631,16 +614,14 @@
* <tt>"first"</tt> boolean flag.
* \param r
- * \return int
+ * \return
-int G_init_fp_range(struct FPRange *range)
+void G_init_fp_range(struct FPRange *range)
G_set_d_null_value(&(range->min), 1);
G_set_d_null_value(&(range->max), 1);
- return 0;
@@ -656,11 +637,11 @@
* \param r
* \param min
* \param max
- * \return int
+ * \return
-int G_get_fp_range_min_max(const struct FPRange *range,
- DCELL * min, DCELL * max)
+void G_get_fp_range_min_max(const struct FPRange *range,
+ DCELL *min, DCELL *max)
G_set_d_null_value(min, 1);
@@ -677,6 +658,4 @@
else
*max = range->max;
- return 0;
Modified: grass/trunk/lib/gis/raster.c
--- grass/trunk/lib/gis/raster.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/raster.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -99,13 +99,12 @@
* \param q
* \param n
* \param data_type
- * \return int
+ * \return
-int G_raster_cpy(void *v1, const void *v2, int n, RASTER_MAP_TYPE data_type)
+void G_raster_cpy(void *v1, const void *v2, int n, RASTER_MAP_TYPE data_type)
- G_copy((char *)v1, (char *)v2, n * G_raster_size(data_type));
- return 0;
+ G_copy(v1, v2, n * G_raster_size(data_type));
@@ -119,17 +118,17 @@
* \param p
* \param val
* \param data_type
- * \return int
+ * \return
-int G_set_raster_value_c(void *rast, CELL cval, RASTER_MAP_TYPE data_type)
+void G_set_raster_value_c(void *rast, CELL cval, RASTER_MAP_TYPE data_type)
CELL c;
c = cval;
if (G_is_c_null_value(&c)) {
G_set_null_value(rast, 1, data_type);
- return 0;
+ return;
switch (data_type) {
case CELL_TYPE:
@@ -142,8 +141,6 @@
*((DCELL *) rast) = (DCELL) cval;
break;
- return 0;
@@ -157,17 +154,17 @@
* \param p
* \param val
* \param data_type
- * \return int
+ * \return
-int G_set_raster_value_f(void *rast, FCELL fval, RASTER_MAP_TYPE data_type)
+void G_set_raster_value_f(void *rast, FCELL fval, RASTER_MAP_TYPE data_type)
FCELL f;
f = fval;
if (G_is_f_null_value(&f)) {
- return 0;
+ return;
case CELL_TYPE:
@@ -180,8 +177,6 @@
*((DCELL *) rast) = (DCELL) fval;
break;
- return 0;
@@ -195,17 +190,17 @@
* \param p
* \param val
* \param data_type
- * \return int
+ * \return
-int G_set_raster_value_d(void *rast, DCELL dval, RASTER_MAP_TYPE data_type)
+void G_set_raster_value_d(void *rast, DCELL dval, RASTER_MAP_TYPE data_type)
DCELL d;
d = dval;
if (G_is_d_null_value(&d)) {
- return -1;
+ return;
case CELL_TYPE:
@@ -218,8 +213,6 @@
*((DCELL *) rast) = dval;
break;
- return 0;
Modified: grass/trunk/lib/gis/reclass.c
--- grass/trunk/lib/gis/reclass.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/reclass.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -150,7 +150,7 @@
return stat;
-int G_free_reclass(struct Reclass *reclass)
+void G_free_reclass(struct Reclass *reclass)
switch (reclass->type) {
case RECLASS_TABLE:
@@ -167,8 +167,6 @@
default:
break;
- return 0;
static int reclass_type(FILE * fd, char **rname, char **rmapset)
Modified: grass/trunk/lib/gis/rhumbline.c
--- grass/trunk/lib/gis/rhumbline.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/rhumbline.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -32,10 +32,10 @@
#include "pi.h"
#if 0
#endif /* unused */
@@ -109,24 +109,20 @@
#if 0
*lon -= 360.0;
*lon += 360.0;
- return 0;
#endif /* unused */
if (*lat > 90.0)
*lat = 90.0;
if (*lat < -90.0)
*lat = -90.0;
- return 0;
Modified: grass/trunk/lib/gis/short_way.c
--- grass/trunk/lib/gis/short_way.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/short_way.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -27,10 +27,10 @@
* \param[in] east1 east (x) coordinate of first point
* \param[in] east2 east (x) coordinate of second point
+ * \return
-int G_shortest_way(double *east1, double *east2)
+void G_shortest_way(double *east1, double *east2)
if (G_projection() == PROJECTION_LL) {
if (*east1 > *east2)
@@ -40,6 +40,4 @@
while ((*east2 - *east1) > 180)
*east1 += 360;
- return 0;
Modified: grass/trunk/lib/gis/strings.c
--- grass/trunk/lib/gis/strings.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/strings.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -195,9 +195,9 @@
* \param[in,out] buf buffer to be worked on
- * \return 0
+ * \return
-int G_strip(char *buf)
+void G_strip(char *buf)
char *a, *b;
@@ -212,8 +212,6 @@
a++;
*a = 0;
- return 0;
Modified: grass/trunk/lib/gis/tempfile.c
--- grass/trunk/lib/gis/tempfile.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/tempfile.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -84,10 +84,10 @@
* \brief Populates <b>element</b> with a path string.
* \param[in,out] element
+ * \return
-int G__temp_element(char *element)
+void G__temp_element(char *element)
const char *machine;
@@ -98,6 +98,4 @@
strcat(element, machine);
G__make_mapset_element(element);
- return 0;
Modified: grass/trunk/lib/gis/timestamp.c
--- grass/trunk/lib/gis/timestamp.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/timestamp.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -247,10 +247,10 @@
* \param dt1 first DateTime struct to be filled
* \param dt2 second DateTime struct to be filled
* \param count return code
- * \return int always 0
+ * \return
-int G_get_timestamps(const struct TimeStamp *ts,
- DateTime * dt1, DateTime * dt2, int *count)
+void G_get_timestamps(const struct TimeStamp *ts,
+ DateTime * dt1, DateTime * dt2, int *count)
*count = 0;
if (ts->count > 0) {
@@ -261,8 +261,6 @@
datetime_copy(dt2, &ts->dt[1]);
*count = 2;
- return 0;
Modified: grass/trunk/lib/gis/token.c
--- grass/trunk/lib/gis/token.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/token.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -92,14 +92,12 @@
* tokens to release memory.
* \param[in,out] tokens
+ * \return
-int G_free_tokens(char **tokens)
+void G_free_tokens(char **tokens)
if (tokens[0] != NULL)
G_free(tokens[0]);
G_free(tokens);
- return (0);
Modified: grass/trunk/lib/gis/trim_dec.c
--- grass/trunk/lib/gis/trim_dec.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/trim_dec.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -23,23 +23,21 @@
* Example: 23.45000 would come back as 23.45
+ * \return
-int G_trim_decimal(char *buf)
+void G_trim_decimal(char *buf)
char *mark;
/* find the . */
while (*buf != '.')
if (*buf++ == 0)
- return 0;
+ return;
mark = buf;
while (*++buf)
if (*buf != '0')
mark = buf + 1;
*mark = 0;
- return 0;
Modified: grass/trunk/lib/gis/view.c
--- grass/trunk/lib/gis/view.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/view.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -42,14 +42,12 @@
* the window when the view was saved overlaps the current window.
* \param[in] b
+ * \return
-int G_3dview_warning(int b)
+void G_3dview_warning(int b)
Suppress_warn = b ? 0 : 1;
- return 0;
Modified: grass/trunk/lib/gis/wind_2_box.c
--- grass/trunk/lib/gis/wind_2_box.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/wind_2_box.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -27,11 +27,11 @@
* \param[in,out] dst destination window
* \param[in] rows number of rows in box
* \param[in] cols number of columns in box
+ * \return
-int G_adjust_window_to_box(const struct Cell_head *src,
- struct Cell_head *dst, int rows, int cols)
+void G_adjust_window_to_box(const struct Cell_head *src,
+ struct Cell_head *dst, int rows, int cols)
double ew, ns;
@@ -53,6 +53,4 @@
/* compute rows and cols */
dst->rows = (dst->north - dst->south) / dst->ns_res;
dst->cols = (dst->east - dst->west) / dst->ew_res;
- return 0;
Modified: grass/trunk/lib/gis/wind_format.c
--- grass/trunk/lib/gis/wind_format.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/wind_format.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -18,7 +18,7 @@
-static int format_double(double, char *);
+static void format_double(double, char *);
@@ -30,17 +30,15 @@
* \param[in] north northing
* \param[in,out] buf buffer to hold formatted string
* \param[in] projection
+ * \return
-int G_format_northing(double north, char *buf, int projection)
+void G_format_northing(double north, char *buf, int projection)
if (projection == PROJECTION_LL)
G_lat_format(north, buf);
else
format_double(north, buf);
- return 0;
@@ -53,17 +51,15 @@
* \param[in] east easting
+ * \return
-int G_format_easting(double east, char *buf, int projection)
+void G_format_easting(double east, char *buf, int projection)
G_lon_format(east, buf);
else
format_double(east, buf);
- return 0;
@@ -76,23 +72,19 @@
* \param[in] resolution
+ * \return
-int G_format_resolution(double res, char *buf, int projection)
+void G_format_resolution(double res, char *buf, int projection)
G_llres_format(res, buf);
else
format_double(res, buf);
- return 0;
-static int format_double(double value, char *buf)
+static void format_double(double value, char *buf)
sprintf(buf, "%.8f", value);
G_trim_decimal(buf);
- return 0;
Modified: grass/trunk/lib/gis/window_map.c
--- grass/trunk/lib/gis/window_map.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/window_map.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -30,10 +30,10 @@
* any way.
* \param[in] fd file descriptor
+ * \return
-int G__create_window_mapping(int fd)
+void G__create_window_mapping(int fd)
struct fileinfo *fcb = &G__.fileinfo[fd];
COLUMN_MAPPING *col;
@@ -45,7 +45,7 @@
G__init_window();
if (fcb->open_mode >= 0 && fcb->open_mode != OPEN_OLD) /* open for write? */
- return 0;
+ return;
if (fcb->open_mode == OPEN_OLD) /* already open ? */
G_free(fcb->col_map);
@@ -109,8 +109,6 @@
fcb->C2 =
(fcb->cellhd.north - G__.window.north +
G__.window.ns_res / 2.0) / fcb->cellhd.ns_res;
- return 0;
@@ -314,17 +312,15 @@
* \brief Initialize window.
+ * \return
-int G__init_window(void)
+void G__init_window(void)
if (!G__.window_set) {
G__.window_set = 1;
G_get_window(&G__.window);
- return 0;
Modified: grass/trunk/lib/gis/wr_cellhd.c
--- grass/trunk/lib/gis/wr_cellhd.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/wr_cellhd.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -24,11 +24,11 @@
* \param[in,out] fd header file
* \param[in] cellhd pointed to cell header structure
* \param[in] is_cellhd 1 cell header; 0 window
- * \return always returns 1
+ * \return
-int G__write_Cell_head(FILE * fd,
- const struct Cell_head *cellhd, int is_cellhd)
+void G__write_Cell_head(FILE * fd,
+ const struct Cell_head *cellhd, int is_cellhd)
char buf[1024];
int fmt;
@@ -63,8 +63,6 @@
fprintf(fd, "format: %d\n", cellhd->format);
fprintf(fd, "compressed: %d\n", cellhd->compressed);
- return 1;
@@ -74,11 +72,11 @@
* \param[in] cellhd pointer to cell header structure
+ * \return
-int G__write_Cell_head3(FILE * fd,
+void G__write_Cell_head3(FILE * fd,
char buf[1024];
int fmt;
@@ -102,6 +100,4 @@
G_format_resolution(cellhd->tb_res, buf, fmt);
fprintf(fd, "t-b resol: %s\n", buf);
- return 1;
Modified: grass/trunk/lib/gis/writ_zeros.c
--- grass/trunk/lib/gis/writ_zeros.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/writ_zeros.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -23,17 +23,17 @@
* \param[in] n number of bytes to write
+ * \return
-int G_write_zeros(int fd, size_t n)
+void G_write_zeros(int fd, size_t n)
char zeros[1024];
char *z;
int i;
if (n <= 0)
- return 0;
+ return;
/* There is a subtle gotcha to be avoided here.
@@ -61,6 +61,4 @@
write(fd, zeros, i);
n -= i;
- return 0;
Modified: grass/trunk/lib/gis/zero.c
--- grass/trunk/lib/gis/zero.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/zero.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -23,12 +23,10 @@
* \param[in] i number of bytes to be zeroed
+ * \return
-int G_zero(void *buf, int i)
+void G_zero(void *buf, int i)
memset(buf, 0, i);
- return 0;
Modified: grass/trunk/lib/gis/zero_cell.c
--- grass/trunk/lib/gis/zero_cell.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/gis/zero_cell.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -25,17 +25,15 @@
* using <i>G_allocate_cell_buf.</i>
* \param[in] buf
+ * \return
-int G_zero_cell_buf(CELL * buf)
+void G_zero_cell_buf(CELL * buf)
int i = G_window_cols();
while (i--)
*buf++ = 0;
- return 0;
@@ -48,10 +46,10 @@
* \param[in,out] rast
* \param[in] data_type RASTER_MAP_TYPE
+ * \return
-int G_zero_raster_buf(void *rast, RASTER_MAP_TYPE data_type)
+void G_zero_raster_buf(void *rast, RASTER_MAP_TYPE data_type)
int i;
unsigned char *ptr;
@@ -62,6 +60,4 @@
while (i--)
*ptr++ = 0;
- return 0;
Modified: grass/trunk/lib/ogsf/Gvl3.c
--- grass/trunk/lib/ogsf/Gvl3.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/lib/ogsf/Gvl3.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -63,8 +63,7 @@
int Gvl_unload_colors_data(void *color_data)
- if (!G_free_colors(color_data))
- return (-1);
+ G_free_colors(color_data);
G_free(color_data);
Modified: grass/trunk/raster/r.contour/main.c
--- grass/trunk/raster/r.contour/main.c 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/raster/r.contour/main.c 2008-11-25 06:26:49 UTC (rev 34484)
@@ -269,13 +269,13 @@
dstep = atof(step->answer);
/* fix if step < 1, Roger Bivand 1/2001: */
- dmax = (max->answer) ? atof(max->answer) : dstep == 0 ?
- G_fatal_error(_("This step value is not allowed.")) : zmax -
- fmod(zmax, dstep);
- dmin =
- (min->answer) ? atof(min->answer) : dstep ==
- 0 ? G_fatal_error(_("This step value is not allowed.")) :
- fmod(zmin, dstep) ? zmin - fmod(zmin, dstep) + dstep : zmin;
+ dmax = (max->answer) ? atof(max->answer) :
+ dstep == 0 ? (G_fatal_error(_("This step value is not allowed.")), 0) :
+ zmax - fmod(zmax, dstep);
+ dmin = (min->answer) ? atof(min->answer) :
+ fmod(zmin, dstep) ? zmin - fmod(zmin, dstep) + dstep :
+ zmin;
while (dmin < zmin) {
dmin += dstep;
Modified: grass/trunk/raster/r.flow/mem.h
--- grass/trunk/raster/r.flow/mem.h 2008-11-25 01:05:48 UTC (rev 34483)
+++ grass/trunk/raster/r.flow/mem.h 2008-11-25 06:26:49 UTC (rev 34484)
@@ -52,7 +52,7 @@
(segment_get(as.seg, &v, \
row + as.row_offset, col + as.col_offset) < 1 ? \
(sprintf(string,"r.flow: cannot read segment file for %s",as.name), \
- G_fatal_error(string)) : \
+ G_fatal_error(string), 0) : \
v) : \
(parm.mem ? \
aspect_fly(el.buf[row - 1] + col, \
@@ -64,7 +64,7 @@
(parm.seg ? \
(segment_get(l.seg, &v, row + l.row_offset, col + l.col_offset) < 1 ? \
(sprintf(string,"r.flow: cannot read segment file for %s",l.name),\
v) : \
l.buf[row][col])
@@ -73,6 +73,6 @@
(v = w, \
segment_put(l.seg, &v, row + l.row_offset, col + l.col_offset) < 1 ? \
(sprintf(string,"r.flow: cannot write segment file for %s",l.name), \
0) : \
(l.buf[row][col] = w))
