[GRASS-SVN] r34489 - in grass/trunk: gui/wxpython/docs vector/v.digit
Tue Nov 25 23:45:34 EST 2008
Author: hamish
Date: 2008-11-25 23:45:34 -0500 (Tue, 25 Nov 2008)
New Revision: 34489
   grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
   grass/trunk/vector/v.digit/v.digit.html
recovery tip (merge from devbr6)
Modified: grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html
--- grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html	2008-11-26 04:43:20 UTC (rev 34488)
+++ grass/trunk/gui/wxpython/docs/wxGUI.Vector_Digitizing_Tool.html	2008-11-26 04:45:34 UTC (rev 34489)
@@ -48,6 +48,11 @@
 based on 'Settings->General->Snapping threshold' value. To
 disable snapping set the snapping threshold to '0'.
+<p>
+If the digitizer crashes for some reason you can repair the vector map
+which was left open with the <em>v.build</em> module.
 <h2>Digitizer toolbar</h2>
 <center>
Modified: grass/trunk/vector/v.digit/v.digit.html
--- grass/trunk/vector/v.digit/v.digit.html	2008-11-26 04:43:20 UTC (rev 34488)
+++ grass/trunk/vector/v.digit/v.digit.html	2008-11-26 04:45:34 UTC (rev 34489)
@@ -4,6 +4,7 @@
 user interface.  Attribute tables can be directly generated while
 digitizing (define in "Settings" first).
 <h2>NOTES</h2>
 The <b>bgcmd</b> option is intended to be used with display (d.*) commands.
@@ -20,6 +21,11 @@
 not <em><a href="g.copy.html">g.copy</a></em>) will writes only lines
 which are 'alive'.
+<p>
+If <em>v.digit</em> crashes for some reason you can repair the vector map
 <h2>EXAMPLES</h2>
 <h3>Start a monitor and display a raster to help setup and zoom to area of interest</h3>
