[GRASS-SVN] r34493 - grass/branches/develbranch_6/scripts/v.in.wfs
svn_grass at osgeo.org
Wed Nov 26 03:17:35 EST 2008
Author: neteler
Date: 2008-11-26 03:17:34 -0500 (Wed, 26 Nov 2008)
New Revision: 34493
grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs
fix broken xerces-c test; use curl instead of lynx; fix cleanup; add cmd history
Modified: grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs
--- grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs 2008-11-26 06:57:07 UTC (rev 34492)
+++ grass/branches/develbranch_6/scripts/v.in.wfs/v.in.wfs 2008-11-26 08:17:34 UTC (rev 34493)
@@ -6,7 +6,7 @@
# AUTHOR(S): Markus Neteler. neteler itc it
# Hamish Bowman (fixes)
# PURPOSE: WFS support
-# COPYRIGHT: (C) 2006, 2007 Markus Neteler and GRASS Development Team
+# COPYRIGHT: (C) 2006-2008 Markus Neteler and GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -37,20 +37,27 @@
exit 1
fi
+# save command line
if [ "$1" != "@ARGS_PARSED@" ] ; then
+ CMDLINE="`basename $0`"
+ for arg in "$@" ; do
+ CMDLINE="$CMDLINE \"$arg\""
+ done
+ export CMDLINE
exec g.parser "$0" "$@"
fi
# xerces support compiled in?
OGRINFO=`which ogrinfo`
-if [ -z "`ldd $OGRINFO | grep xerces`" ] ; then
- g.message -e "OGR needs to be compiled with xerces-c support"
- exit 1
-fi
+#TODO: this is Linux only, needs a fix:
+#if [ -z "`ldd $OGRINFO | grep xerces`" ] ; then
+# g.message -e "OGR needs to be compiled with xerces-c support"
+# exit 1
+#fi
-#### check if we have lynx
-if [ ! -x "`which lynx`" ] ; then
- g.message -e "'lynx' is required, please install first"
+#### check if we have curl
+if [ ! -x "`which curl`" ] ; then
+ g.message -e "'curl' is required, please install first"
exit 1
fi
@@ -64,10 +71,19 @@
WFS_URL="$GIS_OPT_WFS"
g.message "Retrieving data ..."
-lynx -source "$WFS_URL" > "$TMP.xml"
+curl "$WFS_URL" > "$TMP.xml"
v.in.ogr dsn="$TMP.xml" out=$OUT -o
-#rm -f "$TMP.xml"
+if [ $? -ne 0 ] ; then
+ g.message -e "WFS-XML file not readable. Check if xerces-c support is compiled into GDAL/OGR library."
+ rm -f "$TMP.xml" "$TMP" "$TMP.gfs"
+ exit 1
+fi
+rm -f "$TMP.xml" "$TMP" "$TMP.gfs"
+v.support $OUT cmdhist="${CMDLINE}"
g.message "Vector points map <$OUT> imported from WFS."
exit 0
