[GRASS-SVN] r34497 - grass/trunk/vector/v.to.db
svn_grass at osgeo.org
Wed Nov 26 05:28:41 EST 2008
Author: neteler
Date: 2008-11-26 05:28:41 -0500 (Wed, 26 Nov 2008)
New Revision: 34497
grass/trunk/vector/v.to.db/query.c
grass/trunk/vector/v.to.db/update.c
debug fixes
Modified: grass/trunk/vector/v.to.db/query.c
--- grass/trunk/vector/v.to.db/query.c 2008-11-26 09:31:44 UTC (rev 34496)
+++ grass/trunk/vector/v.to.db/query.c 2008-11-26 10:28:41 UTC (rev 34497)
@@ -81,8 +81,6 @@
if ((Fi = Vect_get_field(Map, options.qfield)) == NULL)
G_fatal_error(_("Database connection not defined for layer %d. Use v.db.connect first."),
options.qfield);
- G_debug(3, "Reading from map <%s>, query layer %d: updating table <%s>, column <%s>",
- options.name, options.qfield, Fi->table, Fi->key);
/* Open driver */
driver = db_start_driver_open_database(Fi->driver, Fi->database);
Modified: grass/trunk/vector/v.to.db/update.c
--- grass/trunk/vector/v.to.db/update.c 2008-11-26 09:31:44 UTC (rev 34496)
+++ grass/trunk/vector/v.to.db/update.c 2008-11-26 10:28:41 UTC (rev 34497)
@@ -30,8 +30,8 @@
if ((Fi = Vect_get_field(Map, options.field)) == NULL)
options.field);
+ G_debug(3, "Reading from map <%s>, query layer %d (table <%s>): updating table <%s>, column <%s>",
+ options.name, options.qfield, qFi->table, Fi->table, Fi->key);
/* Open driver */
@@ -44,6 +44,7 @@
/* select existing categories to array (array is sorted) */
vstat.select = db_select_int(driver, qFi->table, Fi->key, NULL, &catexst);
+ G_debug(3, "Existing categories: %d", vstat.select);
/* create beginning of stmt */
switch (options.option) {
@@ -69,8 +70,6 @@
break;
- G_debug(3, "Existing categories: %d", vstat.rcat);
/* update */
G_message(_("Updating database..."));
for (i = 0; i < vstat.rcat; i++) {
