[GRASS-SVN] r34504 - grass/trunk/db/base
svn_grass at osgeo.org
Wed Nov 26 14:30:47 EST 2008
Author: neteler
Date: 2008-11-26 14:30:47 -0500 (Wed, 26 Nov 2008)
New Revision: 34504
grass/trunk/db/base/db.execute.html
table join example added
Modified: grass/trunk/db/base/db.execute.html
--- grass/trunk/db/base/db.execute.html 2008-11-26 17:04:40 UTC (rev 34503)
+++ grass/trunk/db/base/db.execute.html 2008-11-26 19:30:47 UTC (rev 34504)
@@ -92,6 +92,12 @@
cat file.sql | db.execute
</pre></div>
+<P>
+<em>Join table 'myroads' into table 'extratab' based on common 'cat' column values (not supported by DBF driver):<br>
+<div class="code"><pre>
+echo "UPDATE extratab SET names=(SELECT label FROM myroads WHERE extratab.cat=myroads.cat);" | db.execute
+</pre></div>
<h2>SEE ALSO</h2>
<em><a HREF="db.columns.html">db.columns</a>,
<a HREF="db.describe.html">db.describe</a>,
