[GRASS-SVN] r34512 - grass/trunk/vector/v.buffer2
svn_grass at osgeo.org
Wed Nov 26 16:24:25 EST 2008
Author: neteler
Date: 2008-11-26 16:24:25 -0500 (Wed, 26 Nov 2008)
New Revision: 34512
Added:
grass/trunk/vector/v.buffer2/v.buffer2.html
Removed:
grass/trunk/vector/v.buffer2/description.html
renamed
Deleted: grass/trunk/vector/v.buffer2/description.html
--- grass/trunk/vector/v.buffer2/description.html 2008-11-26 21:23:44 UTC (rev 34511)
+++ grass/trunk/vector/v.buffer2/description.html 2008-11-26 21:24:25 UTC (rev 34512)
@@ -1,58 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.buffer</em> creates a buffer around features of given <b>type</b>, which
-have a category in the given <b>layer</b>. The <b>tolerance</b> controls
-the number of vector segments being generated (the smaller the value, the more
-vector segments are generated).
-<h2>NOTES</h2>
-<!-- TRUE?? -->
-Attributes are not transferred due to potential buffer overlap, which
-cannot be resolved automatically.
-<h2>EXAMPLES</h2>
-<h3>Buffer around input lines</h3>
-<div class="code"><pre>
-v.buffer input=map output=buffer type=line buffer=100
-</pre></div>
-<h3>Circles around input points</h3>
-v.buffer input=pointsmap output=circles type=point buffer=1000
-</pre></div>
-<h3>Non-overlapping circles around input points with attribute transfer</h3>
-v.buffer input=archsites output=circles type=point buffer=200
-# change original points to centroids:
-v.type in=archsites out=archcentroids type=point,centroid
-# patch circles and centroids:
-v.patch in=archcentroids,circles out=circles_db
-# attach attributes, either use
-# db.copy ...
-# or link to the original table:
-v.db.connect map=circles_db table=archsites field=1 key=cat driver=dbf \
-database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a HREF="r.buffer.html">r.buffer</a>,
-<a HREF="v.extract.html">v.extract</a>,
-<a HREF="v.type.html">v.type</a>,
-<a HREF="v.patch.html">v.patch</a>,
-<a HREF="v.db.connect.html">v.db.connect</a>
-</em>
-<h2>AUTHORS</h2>
-Radim Blazek<br>
-Rewritten by Rosen Matev (with support through the Google Summer of Code program 2008)
-<p>
-<i>Last changed: $Date: 2008-03-16 16:29:33 +0100 (Sun, 16 Mar 2008) $</i>
Copied: grass/trunk/vector/v.buffer2/v.buffer2.html (from rev 34510, grass/trunk/vector/v.buffer2/description.html)
--- grass/trunk/vector/v.buffer2/v.buffer2.html (rev 0)
+++ grass/trunk/vector/v.buffer2/v.buffer2.html 2008-11-26 21:24:25 UTC (rev 34512)
@@ -0,0 +1,58 @@
+<h2>DESCRIPTION</h2>
+<em>v.buffer</em> creates a buffer around features of given <b>type</b>, which
+have a category in the given <b>layer</b>. The <b>tolerance</b> controls
+the number of vector segments being generated (the smaller the value, the more
+vector segments are generated).
+<h2>NOTES</h2>
+<!-- TRUE?? -->
+Attributes are not transferred due to potential buffer overlap, which
+cannot be resolved automatically.
+<h2>EXAMPLES</h2>
+<h3>Buffer around input lines</h3>
+<div class="code"><pre>
+v.buffer input=map output=buffer type=line buffer=100
+</pre></div>
+<h3>Circles around input points</h3>
+v.buffer input=pointsmap output=circles type=point buffer=1000
+</pre></div>
+<h3>Non-overlapping circles around input points with attribute transfer</h3>
+v.buffer input=archsites output=circles type=point buffer=200
+# change original points to centroids:
+v.type in=archsites out=archcentroids type=point,centroid
+# patch circles and centroids:
+v.patch in=archcentroids,circles out=circles_db
+# attach attributes, either use
+# db.copy ...
+# or link to the original table:
+v.db.connect map=circles_db table=archsites field=1 key=cat driver=dbf \
+database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a HREF="r.buffer.html">r.buffer</a>,
+<a HREF="v.extract.html">v.extract</a>,
+<a HREF="v.type.html">v.type</a>,
+<a HREF="v.patch.html">v.patch</a>,
+<a HREF="v.db.connect.html">v.db.connect</a>
+</em>
+<h2>AUTHORS</h2>
+Radim Blazek<br>
+Rewritten by Rosen Matev (with support through the Google Summer of Code program 2008)
+<p>
+<i>Last changed: $Date: 2008-03-16 16:29:33 +0100 (Sun, 16 Mar 2008) $</i>
