[GRASS-SVN] r34523 - in grass/trunk/vector: . v.buffer v.parallel
v.voronoi
svn_grass at osgeo.org
Wed Nov 26 16:52:43 EST 2008
Author: neteler
Date: 2008-11-26 16:52:43 -0500 (Wed, 26 Nov 2008)
New Revision: 34523
Added:
grass/trunk/vector/v.buffer/DEPRECATED
grass/trunk/vector/v.parallel/DEPRECATED
grass/trunk/vector/v.voronoi/delaunay_DEPRECATED
grass/trunk/vector/Makefile
grass/trunk/vector/v.voronoi/Makefile
activated v.buffer2, v.delaunay2, v.parallel2
Modified: grass/trunk/vector/Makefile
--- grass/trunk/vector/Makefile 2008-11-26 21:43:14 UTC (rev 34522)
+++ grass/trunk/vector/Makefile 2008-11-26 21:52:43 UTC (rev 34523)
@@ -4,7 +4,7 @@
PGM = vectorintro
SUBDIRS = \
- v.buffer \
+ v.buffer2 \
v.build \
v.build.polylines \
v.category \
@@ -13,6 +13,7 @@
v.convert \
v.db.connect \
v.db.select \
+ v.delaunay2 \
v.distance \
v.drape \
v.edit \
@@ -47,7 +48,7 @@
v.out.svg \
v.out.vtk \
v.overlay \
- v.parallel \
+ v.parallel2 \
v.patch \
v.perturb \
v.split \
Added: grass/trunk/vector/v.buffer/DEPRECATED
--- grass/trunk/vector/v.buffer/DEPRECATED (rev 0)
+++ grass/trunk/vector/v.buffer/DEPRECATED 2008-11-26 21:52:43 UTC (rev 34523)
@@ -0,0 +1,2 @@
+no longer maintained.
+Continued in ../v.buffer2/
Added: grass/trunk/vector/v.parallel/DEPRECATED
--- grass/trunk/vector/v.parallel/DEPRECATED (rev 0)
+++ grass/trunk/vector/v.parallel/DEPRECATED 2008-11-26 21:52:43 UTC (rev 34523)
@@ -0,0 +1,2 @@
+Continued in ../v.parallel2/
Modified: grass/trunk/vector/v.voronoi/Makefile
--- grass/trunk/vector/v.voronoi/Makefile 2008-11-26 21:43:14 UTC (rev 34522)
+++ grass/trunk/vector/v.voronoi/Makefile 2008-11-26 21:52:43 UTC (rev 34523)
@@ -2,16 +2,17 @@
MODULE_TOPDIR = ../..
VORONOI = v.voronoi
-DELAUNAY = v.delaunay
+# DELAUNAY = v.delaunay
-PROGRAMS = $(VORONOI) $(DELAUNAY)
+PROGRAMS = $(VORONOI)
+# $(DELAUNAY)
SWEEP_OBJS = sw_edgelist.o sw_geometry.o sw_heap.o sw_main.o sw_memory.o sw_output.o \
sw_voronoi.o
v_voronoi_OBJS = vo_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
-v_delaunay_OBJS = dt_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
+# v_delaunay_OBJS = dt_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
LIBES = $(VECTLIB) $(GISLIB)
DEPENDENCIES= $(VECTDEP) $(GISDEP)
Added: grass/trunk/vector/v.voronoi/delaunay_DEPRECATED
--- grass/trunk/vector/v.voronoi/delaunay_DEPRECATED (rev 0)
+++ grass/trunk/vector/v.voronoi/delaunay_DEPRECATED 2008-11-26 21:52:43 UTC (rev 34523)
@@ -0,0 +1,2 @@
+Continued in ../v.delaunay2/
