[GRASS-SVN] r34525 - in grass/branches/develbranch_6/vector: .
v.buffer v.buffer2 v.parallel v.voronoi
svn_grass at osgeo.org
Wed Nov 26 16:55:54 EST 2008
Author: neteler
Date: 2008-11-26 16:55:54 -0500 (Wed, 26 Nov 2008)
New Revision: 34525
Added:
grass/branches/develbranch_6/vector/v.buffer/DEPRECATED
grass/branches/develbranch_6/vector/v.parallel/DEPRECATED
grass/branches/develbranch_6/vector/v.voronoi/delaunay_DEPRECATED
grass/branches/develbranch_6/vector/Makefile
grass/branches/develbranch_6/vector/v.buffer2/
grass/branches/develbranch_6/vector/v.voronoi/Makefile
activated v.buffer2, v.delaunay2, v.parallel2
Modified: grass/branches/develbranch_6/vector/Makefile
--- grass/branches/develbranch_6/vector/Makefile 2008-11-26 21:53:48 UTC (rev 34524)
+++ grass/branches/develbranch_6/vector/Makefile 2008-11-26 21:55:54 UTC (rev 34525)
@@ -2,7 +2,7 @@
MODULE_TOPDIR = ..
SUBDIRS = \
- v.buffer \
+ v.buffer2 \
v.build \
v.build.polylines \
v.category \
@@ -11,6 +11,7 @@
v.convert \
v.db.connect \
v.db.select \
+ v.delaunay2 \
v.distance \
v.drape \
v.edit \
@@ -45,7 +46,7 @@
v.out.svg \
v.out.vtk \
v.overlay \
- v.parallel \
+ v.parallel2 \
v.patch \
v.perturb \
v.split \
Added: grass/branches/develbranch_6/vector/v.buffer/DEPRECATED
--- grass/branches/develbranch_6/vector/v.buffer/DEPRECATED (rev 0)
+++ grass/branches/develbranch_6/vector/v.buffer/DEPRECATED 2008-11-26 21:55:54 UTC (rev 34525)
@@ -0,0 +1,2 @@
+no longer maintained.
+Continued in ../v.buffer2/
Property changes on: grass/branches/develbranch_6/vector/v.buffer2
___________________________________________________________________
+ *.tmp.html
*OBJ*
Added: grass/branches/develbranch_6/vector/v.parallel/DEPRECATED
--- grass/branches/develbranch_6/vector/v.parallel/DEPRECATED (rev 0)
+++ grass/branches/develbranch_6/vector/v.parallel/DEPRECATED 2008-11-26 21:55:54 UTC (rev 34525)
@@ -0,0 +1,2 @@
+Continued in ../v.parallel2/
Modified: grass/branches/develbranch_6/vector/v.voronoi/Makefile
--- grass/branches/develbranch_6/vector/v.voronoi/Makefile 2008-11-26 21:53:48 UTC (rev 34524)
+++ grass/branches/develbranch_6/vector/v.voronoi/Makefile 2008-11-26 21:55:54 UTC (rev 34525)
@@ -1,17 +1,17 @@
MODULE_TOPDIR = ../..
VORONOI = v.voronoi
-DELAUNAY = v.delaunay
+#DELAUNAY = v.delaunay
-PROGRAMS = $(VORONOI) $(DELAUNAY)
+PROGRAMS = $(VORONOI)
+# $(DELAUNAY)
SWEEP_OBJS = sw_edgelist.o sw_geometry.o sw_heap.o sw_main.o sw_memory.o sw_output.o \
sw_voronoi.o
VORONOI_OBJS = vo_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
-DELAUNAY_OBJS = dt_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
+#DELAUNAY_OBJS = dt_main.o vo_extend.o vo_write.o dt_write.o $(SWEEP_OBJS)
LIBES = $(VECTLIB) $(GISLIB)
@@ -23,14 +23,15 @@
VORONOI_ARCH_OBJS := $(foreach obj,$(VORONOI_OBJS),$(OBJDIR)/$(obj))
-DELAUNAY_ARCH_OBJS := $(foreach obj,$(DELAUNAY_OBJS),$(OBJDIR)/$(obj))
+#DELAUNAY_ARCH_OBJS := $(foreach obj,$(DELAUNAY_OBJS),$(OBJDIR)/$(obj))
-default: $(BIN)/$(DELAUNAY)$(EXE) $(BIN)/$(VORONOI)$(EXE)
+#default: $(BIN)/$(DELAUNAY)$(EXE) $(BIN)/$(VORONOI)$(EXE)
+default: $(BIN)/$(VORONOI)$(EXE)
$(MAKE) htmlmulti
$(BIN)/$(VORONOI)$(EXE): $(VORONOI_ARCH_OBJS)
$(CC) $(LDFLAGS) -o $@ $^ $(FMODE_OBJ) $(LIBES) $(MATHLIB) $(XDRLIB)
-$(BIN)/$(DELAUNAY)$(EXE):$(DELAUNAY_ARCH_OBJS)
- $(CC) $(LDFLAGS) -o $@ $^ $(FMODE_OBJ) $(LIBES) $(MATHLIB) $(XDRLIB)
+#$(BIN)/$(DELAUNAY)$(EXE):$(DELAUNAY_ARCH_OBJS)
+# $(CC) $(LDFLAGS) -o $@ $^ $(FMODE_OBJ) $(LIBES) $(MATHLIB) $(XDRLIB)
Added: grass/branches/develbranch_6/vector/v.voronoi/delaunay_DEPRECATED
--- grass/branches/develbranch_6/vector/v.voronoi/delaunay_DEPRECATED (rev 0)
+++ grass/branches/develbranch_6/vector/v.voronoi/delaunay_DEPRECATED 2008-11-26 21:55:54 UTC (rev 34525)
@@ -0,0 +1,2 @@
+Continued in ../v.delaunay2/
