[GRASS-SVN] r34529 - grass/trunk/include
svn_grass at osgeo.org
Thu Nov 27 06:23:17 EST 2008
Author: marisn
Date: 2008-11-27 06:23:17 -0500 (Thu, 27 Nov 2008)
New Revision: 34529
grass/trunk/include/Vect.h
Adding skipped Vect_line_get_intersections declaration (merge from develbranch_6 r34499)
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h 2008-11-27 11:16:49 UTC (rev 34528)
+++ grass/trunk/include/Vect.h 2008-11-27 11:23:17 UTC (rev 34529)
@@ -25,8 +25,7 @@
int Vect_destroy_line_struct(struct line_pnts *);
int Vect_point_on_line(struct line_pnts *, double, double *, double *,
double *, double *, double *);
-int Vect_line_segment(struct line_pnts *, double, double,
- struct line_pnts *);
+int Vect_line_segment(struct line_pnts *, double, double, struct line_pnts *);
double Vect_line_length(struct line_pnts *);
double Vect_area_perimeter(struct line_pnts *);
double Vect_line_geodesic_length(struct line_pnts *);
@@ -71,8 +70,7 @@
struct dblinks *Vect_new_dblinks_struct(void);
void Vect_reset_dblinks(struct dblinks *);
int Vect_add_dblink(struct dblinks *, int, const char *,
- const char *, const char *, const char *,
- const char *);
+ const char *, const char *, const char *, const char *);
int Vect_check_dblink(struct dblinks *, int);
int Vect_map_add_dblink(struct Map_info *, int, const char *,
@@ -84,7 +82,7 @@
struct field_info *Vect_default_field_info(struct Map_info *, int,
const char *, int);
struct field_info *Vect_get_dblink(struct Map_info *, int);
-struct field_info *Vect_get_field(struct Map_info *, int );
+struct field_info *Vect_get_field(struct Map_info *, int);
void Vect_set_db_updated(struct Map_info *);
const char *Vect_get_column_names(struct Map_info *, int);
const char *Vect_get_column_types(struct Map_info *, int);
@@ -323,8 +321,7 @@
int, struct Map_info *);
int Vect_overlay_and(struct Map_info *, int, struct ilist *,
struct ilist *, struct Map_info *, int,
- struct ilist *, struct ilist *,
- struct Map_info *);
+ struct ilist *, struct ilist *, struct Map_info *);
/* Graph */
void Vect_graph_init(GRAPH *, int);
@@ -371,6 +368,8 @@
struct line_pnts ***, struct line_pnts ***, int *,
int *, int);
int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
+int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
+ struct line_pnts *, int);
char *Vect_subst_var(const char *str, struct Map_info *Map);
