[GRASS-SVN] r34540 - grass/branches/develbranch_6/scripts/db.in.ogr
svn_grass at osgeo.org
Thu Nov 27 12:11:52 EST 2008
Author: neteler
Date: 2008-11-27 12:11:52 -0500 (Thu, 27 Nov 2008)
New Revision: 34540
grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr
bugfix for key parameter which never worked so far
Modified: grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr
--- grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr 2008-11-27 16:39:38 UTC (rev 34539)
+++ grass/branches/develbranch_6/scripts/db.in.ogr/db.in.ogr 2008-11-27 17:11:52 UTC (rev 34540)
@@ -5,7 +5,7 @@
# MODULE: db.in.ogr
# AUTHOR(S): Markus Neteler
# PURPOSE: imports attribute tables in various formats
-# COPYRIGHT: (C) 2007 by Markus Neteler and the GRASS Development Team
+# COPYRIGHT: (C) 2007, 2008 by Markus Neteler and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -100,7 +100,7 @@
fi
else
# user gave --o
- echo "DROP TABLE ${GIS_OPT_OUTPUT}" | db.execute
+ db.droptable -f --q ${GIS_OPT_OUTPUT} >/dev/null 2>/dev/null
fi
# treat DB as real vector map...
@@ -109,9 +109,10 @@
fi
# check ERRORs and cat and cat_ issues (maybe problem with translated messages)
-WARNING="`v.in.ogr --q dsn=\"$GIS_OPT_DSN\" $LAYER out=$GIS_OPT_OUTPUT -o 2>&1 | grep 'ERROR\|cat' | grep -v 'truncated'`"
-#if [ $? -ne 0 ] ; then
+# we import faking a map which generates only the attribute table:
+WARNING="`v.in.ogr --q dsn=\"$GIS_OPT_DSN\" $LAYER out=$GIS_OPT_OUTPUT -o --o 2>&1 | grep -i 'ERROR\|cat' | grep -v 'truncated'`"
if [ ! -z "$WARNING" ] ; then
+ echo "$WARNING"
if [ ! -z "$GIS_OPT_DB_TABLE" ] ; then
g.message -e "Input DSN <$INPUT> not found or not readable"
else
@@ -120,9 +121,10 @@
exit 1
fi
-# rename ID col if requested from cat to new name
+# rename "key" col if requested from "cat" (generated by v.in.ogr) to new name:
if [ ! -z ${GIS_OPT_KEY} ] ; then
- v.db.renamecol --q $GIS_OPT_OUTPUT layer=1 column=cat,${GIS_OPT_KEY} 2> /dev/null > /dev/null
+ echo "ALTER TABLE $GIS_OPT_OUTPUT ADD COLUMN $GIS_OPT_KEY integer" | db.execute
+ echo "UPDATE $GIS_OPT_OUTPUT SET $GIS_OPT_KEY=cat" | db.execute
fi
# ... and immediately drop the empty geometry
@@ -143,5 +145,5 @@
RECORDS=`db.describe -c $GIS_OPT_OUTPUT | grep '^nrows' | sed 's+ ++g' | cut -d':' -f2`
g.message "Imported table <$GIS_OPT_OUTPUT> with $RECORDS rows"
exit 0
