[GRASS-SVN] r34548 - in grass/trunk: display/d.vect
gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Nov 27 15:59:05 EST 2008
Author: martinl
Date: 2008-11-27 15:59:04 -0500 (Thu, 27 Nov 2008)
New Revision: 34548
grass/trunk/display/d.vect/main.c
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI: fix layer > 1
vdigit: fix category dialog (change category)
dbm: delete multiple records fixed
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2008-11-27 20:53:39 UTC (rev 34547)
+++ grass/trunk/display/d.vect/main.c 2008-11-27 20:59:04 UTC (rev 34548)
@@ -141,8 +141,9 @@
type_opt->guisection = _("Query");
field_opt = G_define_standard_option(G_OPT_V_FIELD);
- field_opt->description =
- _("Layer number. If -1, all layers are displayed.");
+ field_opt->label =
+ _("Layer number (if -1, all layers are displayed)");
+ field_opt->gisprompt = "old_layer,layer,layer_all";
field_opt->guisection = _("Query");
cat_opt = G_define_standard_option(G_OPT_V_CATS);
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-11-27 20:53:39 UTC (rev 34547)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-11-27 20:59:04 UTC (rev 34548)
@@ -1646,9 +1646,9 @@
os.environ.has_key('GRASS_DB_ENCODING'):
enc = os.environ['GRASS_DB_ENCODING']
if enc:
- sqlFile.file.write(sql.encode(enc))
+ sqlFile.file.write(sql.encode(enc) + ';')
else:
- sqlFile.file.write(sql)
+ sqlFile.file.write(sql + ';')
sqlFile.file.write(os.linesep)
sqlFile.file.flush()
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-11-27 20:53:39 UTC (rev 34547)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-11-27 20:59:04 UTC (rev 34548)
@@ -50,9 +50,8 @@
import string
import textwrap
import os
-from os import system
import time
-start = time.time()
+import copy
### i18N
import gettext
@@ -1317,7 +1316,7 @@
if p.get('gisprompt', False) == False:
continue
- prompt = p.get('prompt', '')
+ prompt = p.get('element', '')
if prompt == 'vector':
name = p.get('name', '')
@@ -1335,7 +1334,7 @@
pTable = p
if pMap:
- pMap['wxId-bind'] = pColumn
+ pMap['wxId-bind'] = copy.copy(pColumn)
if pLayer:
pMap['wxId-bind'].append(pLayer['wxId'])
@@ -1350,7 +1349,7 @@
if pTable and pColumn:
pTable['wxId-bind'] = pColumn
# determine panel size
@@ -1497,8 +1496,21 @@
def OnUpdateSelection(self, event):
"""Update list of available layers, tables, columns for
vector map layer"""
- id = event.GetId()
+ if not event:
+ id = None
+ for p in self.task.params:
+ if p.get('gisprompt', False) == False:
+ continue
+ if prompt == 'vector':
+ name = p.get('name', '')
+ if name in ('map', 'input'):
+ id = p['wxId']
+ if id is None:
+ return
+ else:
+ id = event.GetId()
p = self.task.get_param(id, element='wxId', raiseError=False)
if not p or \
not p.has_key('wxId-bind'):
@@ -1511,12 +1523,9 @@
pMap = self.task.get_param('map', raiseError=False)
if not pMap:
pMap = self.task.get_param('input', raiseError=False)
- if p == pMap:
- map = event.GetString()
- elif pMap:
- map = pMap.get('value', '')
+ map = pMap.get('value', '')
for uid in p['wxId-bind']:
win = self.FindWindowById(uid)
name = win.GetName()
@@ -1534,9 +1543,8 @@
win.InsertTables(driver, db)
elif name == 'ColumnSelect':
- pLayer = self.task.get_param('layer', element='prompt', raiseError=False)
- if pLayer and \
- pLayer.get('prompt', '') == 'layer':
+ pLayer = self.task.get_param('layer', element='element', raiseError=False)
+ if pLayer:
if pLayer.get('value', '') != '':
layer = int(pLayer.get('value', 1))
else:
@@ -1546,7 +1554,8 @@
win.InsertColumns(map, layer)
- event.Skip()
+ if event:
+ event.Skip()
def createCmd( self, ignoreErrors = False ):
@@ -1614,7 +1623,7 @@
self.mf.CentreOnScreen()
self.mf.Show(True)
self.SetTopWindow(self.mf)
- # print >> sys.stderr, time.time() - start
return True
class GUI:
@@ -1700,6 +1709,8 @@
# update only propwin reference
get_dcmd(dcmd=None, layer=layer, params=None,
propwin=self.mf)
+ self.mf.notebookpanel.OnUpdateSelection(None)
if show:
if self.parent:
@@ -1709,7 +1720,6 @@
else:
self.mf.OnApply(None)
return cmd
def GetCommandInputMapParamKey(self, cmd):
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-11-27 20:53:39 UTC (rev 34547)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-11-27 20:59:04 UTC (rev 34548)
@@ -1877,12 +1877,12 @@
else:
layerNew = layerOld
catNew = int(event.GetLabel())
try:
if layerNew not in self.cats[self.fid].keys():
- self.cats[layerNew] = []
- self.cats[layerNew].append(catNew)
- self.cats[layerOld].remove(catOld)
+ self.cats[self.fid][layerNew] = []
+ self.cats[self.fid][layerNew].append(catNew)
+ self.cats[self.fid][layerOld].remove(catOld)
except:
event.Veto()
self.list.SetStringItem(itemIndex, 0, str(layerNew))
