[GRASS-SVN] r34552 - grass-addons/vector/v.colors
svn_grass at osgeo.org
Thu Nov 27 16:22:48 EST 2008
Author: neteler
Date: 2008-11-27 16:22:48 -0500 (Thu, 27 Nov 2008)
New Revision: 34552
grass-addons/vector/v.colors/v.colors
fix fs for v.db.connect (white space in path); use g.message. please move to >=6.4
Modified: grass-addons/vector/v.colors/v.colors
--- grass-addons/vector/v.colors/v.colors 2008-11-27 21:14:54 UTC (rev 34551)
+++ grass-addons/vector/v.colors/v.colors 2008-11-27 21:22:48 UTC (rev 34552)
@@ -157,7 +157,7 @@
fi
done
if [ "$CTEST" -ne 1 ] ; then
- echo "ERROR: Pick one of color, rules, or raster options"
+ g.message -e "Pick one of color, rules, or raster options"
exit 1
fi
@@ -174,19 +174,19 @@
fi
done
if [ "$HAVE_COLR" -eq 0 ] ; then
- echo "ERROR: Invalid color rule <$GIS_OPT_COLOR>"
+ g.message -e "Invalid color rule <$GIS_OPT_COLOR>"
echo " Valid options are: $COLOR_OPTS"
exit 1
fi
elif [ -n "$GIS_OPT_RASTER" ] ; then
r.info -r "$GIS_OPT_RASTER" > /dev/null
if [ $? -ne 0 ] ; then
- echo "ERROR: Unable to open raster map <$GIS_OPT_RASTER>"
+ g.message -e "Unable to open raster map <$GIS_OPT_RASTER>"
exit 1
fi
elif [ -n "$GIS_OPT_RULES" ] ; then
if [ ! -r "$GIS_OPT_RULES" ] ; then
- echo "ERROR: Unable to read color rules file <$GIS_OPT_RULES>"
+ g.message -e "Unable to read color rules file <$GIS_OPT_RULES>"
exit 1
fi
fi
@@ -196,32 +196,32 @@
# check input data column
NCOLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_COLUMN$" | cut -f1 -d'|'`
if [ -z "$NCOLUMN_TYPE" ] ; then
- echo "ERROR: Column <$GIS_OPT_COLUMN> not found"
+ g.message -e "Column <$GIS_OPT_COLUMN> not found"
exit 1
elif [ "$NCOLUMN_TYPE" != "INTEGER" ] && [ "$NCOLUMN_TYPE" != "DOUBLE PRECISION" ] ; then
- echo "ERROR: Column <$GIS_OPT_COLUMN> is not numeric"
+ g.message -e "Column <$GIS_OPT_COLUMN> is not numeric"
exit 1
fi
#echo "column <$GIS_OPT_COLUMN> is type [$NCOLUMN_TYPE]"
# check if GRASSRGB column exists, make it if it doesn't
-TABLE=`v.db.connect -g map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | cut -f2 -d' '`
+TABLE=`v.db.connect -g map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" fs=";" | cut -f2 -d';'`
COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
if [ -z "$COLUMN_TYPE" ] ; then
# RGB Column not found, create it
echo "Creating column <$GIS_OPT_RGB_COLUMN> ..."
v.db.addcol map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" column="$GIS_OPT_RGB_COLUMN varchar(11)"
- echo "ERROR: Creating color column"
+ g.message -e "Creating color column"
exit 1
fi
elif [ "$COLUMN_TYPE" != "CHARACTER" -a "$COLUMN_TYPE" != "TEXT" ] ; then
- echo "ERROR: Column <$GIS_OPT_RGB_COLUMN> is not of compatible type (found $COLUMN_TYPE)"
+ g.message -e "Column <$GIS_OPT_RGB_COLUMN> is not of compatible type (found $COLUMN_TYPE)"
exit 1
else
NUM_CHARS=`db.describe -c "$TABLE" | grep -i " $GIS_OPT_RGB_COLUMN:" | cut -f4 -d':'`
if [ "$NUM_CHARS" -lt 11 ] ; then
- echo "ERROR: Color column <$GIS_OPT_RGB_COLUMN> is not wide enough (needs 11 characters)"
+ g.message -e "Color column <$GIS_OPT_RGB_COLUMN> is not wide enough (needs 11 characters)"
exit 1
fi
fi
@@ -239,7 +239,7 @@
fi
echo " min=[$MINVAL] max=[$MAXVAL]"
if [ -z "$MINVAL" ] || [ -z "$MAXVAL" ] ; then
- echo "ERROR: Scanning data range"
+ g.message -e "Scanning data range"
exit 1
fi
@@ -276,7 +276,7 @@
TMP="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "${TMP}" ] ; then
- echo "ERROR: Unable to create temporary file"
+ g.message -e "Unable to create temporary file"
cleanup
exit 1
fi
@@ -296,7 +296,7 @@
if [ ! -e "${TMP}_vcol.sql" ] ; then
- echo "ERROR: No values found in color range"
+ g.message -e "No values found in color range"
cleanup
exit 1
fi
@@ -307,7 +307,7 @@
#less "$TMP"
db.execute input="${TMP}_vcol.sql"
- echo "ERROR: Processing SQL transaction"
+ g.message -e "Processing SQL transaction"
cleanup
exit 1
fi
@@ -329,7 +329,7 @@
fi
cleanup
-exit
+exit 0
#v.db.dropcol map=vcol_test col=GRASSRGB
#d.vect -a vcol_test icon=basic/circle color=none size=8
