[GRASS-SVN] r34561 - grass/branches/develbranch_6/vector/v.buffer2
svn_grass at osgeo.org
Thu Nov 27 17:04:34 EST 2008
Author: martinl
Date: 2008-11-27 17:04:34 -0500 (Thu, 27 Nov 2008)
New Revision: 34561
grass/branches/develbranch_6/vector/v.buffer2/dgraph.c
grass/branches/develbranch_6/vector/v.buffer2/e_intersect.c
grass/branches/develbranch_6/vector/v.buffer2/main.c
grass/branches/develbranch_6/vector/v.buffer2/vlib_buffer.c
v.buffer2: grass_indent.sh
message standardization
Modified: grass/branches/develbranch_6/vector/v.buffer2/dgraph.c
--- grass/branches/develbranch_6/vector/v.buffer2/dgraph.c 2008-11-27 21:57:06 UTC (rev 34560)
+++ grass/branches/develbranch_6/vector/v.buffer2/dgraph.c 2008-11-27 22:04:34 UTC (rev 34561)
@@ -6,32 +6,36 @@
#define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
#ifndef MIN
- #define MIN(X,Y) ((X<Y)?X:Y)
+#define MIN(X,Y) ((X<Y)?X:Y)
#endif
#ifndef MAX
- #define MAX(X,Y) ((X>Y)?X:Y)
-#endif
+#define MAX(X,Y) ((X>Y)?X:Y)
+#endif
#define PI M_PI
-struct intersection_point {
+struct intersection_point
double x;
double y;
- int group; /* IPs with very similar dist will be in the same group */
+ int group; /* IPs with very similar dist will be in the same group */
-struct seg_intersection {
- int with; /* second segment */
- int ip; /* index of the IP */
- double dist; /* distance from first point of first segment to intersection point (IP) */
+struct seg_intersection
+ int with; /* second segment */
+ int ip; /* index of the IP */
+ double dist; /* distance from first point of first segment to intersection point (IP) */
-struct seg_intersection_list {
+struct seg_intersection_list
int count;
int allocated;
struct seg_intersection *a;
-struct seg_intersections {
+struct seg_intersections
int ipcount;
int ipallocated;
struct intersection_point *ip;
@@ -40,64 +44,76 @@
int group_count;
-struct seg_intersections* create_si_struct(int segments_count) {
+struct seg_intersections *create_si_struct(int segments_count)
struct seg_intersections *si;
int i;
si = G_malloc(sizeof(struct seg_intersections));
si->ipcount = 0;
si->ipallocated = segments_count + 16;
- si->ip = G_malloc((si->ipallocated)*sizeof(struct intersection_point));
+ si->ip = G_malloc((si->ipallocated) * sizeof(struct intersection_point));
si->ilcount = segments_count;
- si->il = G_malloc(segments_count*sizeof(struct seg_intersection_list));
+ si->il = G_malloc(segments_count * sizeof(struct seg_intersection_list));
for (i = 0; i < segments_count; i++) {
- si->il[i].count = 0;
- si->il[i].allocated = 0;
- si->il[i].a = NULL;
+ si->il[i].count = 0;
+ si->il[i].allocated = 0;
+ si->il[i].a = NULL;
return si;
-void destroy_si_struct(struct seg_intersections *si) {
+void destroy_si_struct(struct seg_intersections *si)
int i;
for (i = 0; i < si->ilcount; i++)
- G_free(si->il[i].a);
+ G_free(si->il[i].a);
G_free(si->il);
G_free(si->ip);
G_free(si);
return;
/* internal use */
-void add_ipoint1(struct seg_intersection_list *il, int with, double dist, int ip) {
+void add_ipoint1(struct seg_intersection_list *il, int with, double dist,
+ int ip)
struct seg_intersection *s;
if (il->count == il->allocated) {
- il->allocated += 4;
- il->a = G_realloc(il->a, (il->allocated)*sizeof(struct seg_intersection));
+ il->allocated += 4;
+ il->a =
+ G_realloc(il->a,
+ (il->allocated) * sizeof(struct seg_intersection));
s = &(il->a[il->count]);
s->with = with;
s->ip = ip;
s->dist = dist;
il->count++;
return;
/* adds intersection point to the structure */
-void add_ipoint(struct line_pnts *Points, int first_seg, int second_seg, double x, double y, struct seg_intersections *si) {
+void add_ipoint(struct line_pnts *Points, int first_seg, int second_seg,
+ double x, double y, struct seg_intersections *si)
struct intersection_point *t;
int ip;
G_debug(4, "add_ipoint()");
if (si->ipcount == si->ipallocated) {
- si->ipallocated += 16;
- si->ip = G_realloc(si->ip, (si->ipallocated)*sizeof(struct intersection_point));
+ si->ipallocated += 16;
+ si->ip =
+ G_realloc(si->ip,
+ (si->ipallocated) * sizeof(struct intersection_point));
ip = si->ipcount;
t = &(si->ip[ip]);
@@ -105,212 +121,246 @@
t->y = y;
t->group = -1;
si->ipcount++;
- add_ipoint1(&(si->il[first_seg]), second_seg, LENGTH((Points->x[first_seg] - x), (Points->y[first_seg] - y)), ip);
+ add_ipoint1(&(si->il[first_seg]), second_seg,
+ LENGTH((Points->x[first_seg] - x),
+ (Points->y[first_seg] - y)), ip);
if (second_seg >= 0)
- add_ipoint1(&(si->il[second_seg]), first_seg, LENGTH((Points->x[second_seg] - x), (Points->y[second_seg] - y)), ip);
+ add_ipoint1(&(si->il[second_seg]), first_seg,
+ LENGTH((Points->x[second_seg] - x),
+ (Points->y[second_seg] - y)), ip);
-void sort_intersection_list(struct seg_intersection_list *il) {
+void sort_intersection_list(struct seg_intersection_list *il)
int n, i, j, min;
struct seg_intersection t;
G_debug(4, "sort_intersection_list()");
n = il->count;
G_debug(4, " n=%d", n);
- for (i = 0; i < n-1; i++) {
- min = i;
- for (j = i+1; j < n; j++) {
- if (il->a[j].dist < il->a[min].dist) {
- min = j;
- if (min != i) {
- t = il->a[i];
- il->a[i] = il->a[min];
- il->a[min] = t;
+ for (i = 0; i < n - 1; i++) {
+ min = i;
+ for (j = i + 1; j < n; j++) {
+ if (il->a[j].dist < il->a[min].dist) {
+ min = j;
+ if (min != i) {
+ t = il->a[i];
+ il->a[i] = il->a[min];
+ il->a[min] = t;
return;
static int compare(const void *a, const void *b)
struct intersection_point *aa, *bb;
aa = *((struct intersection_point **)a);
bb = *((struct intersection_point **)b);
if (aa->x < bb->x)
- return -1;
+ return -1;
else if (aa->x > bb->x)
- return 1;
+ return 1;
else
- return (aa->y < bb->y)?-1:((aa->y > bb->y)?1:0);
+ return (aa->y < bb->y) ? -1 : ((aa->y > bb->y) ? 1 : 0);
/* O(Points->n_points) time */
-double get_epsilon(struct line_pnts *Points) {
+double get_epsilon(struct line_pnts *Points)
int i, np;
double min, t;
double *x, *y;
np = Points->n_points;
x = Points->x;
y = Points->y;
- min = MAX(fabs(x[1]-x[0]), fabs(y[1]-y[0]));
- for (i = 1; i <= np-2; i++) {
- t = MAX(fabs(x[i+1]-x[i]), fabs(y[i+1]-y[i]));
- if ((t > 0) && (t < min)) {
- min = t;
+ min = MAX(fabs(x[1] - x[0]), fabs(y[1] - y[0]));
+ for (i = 1; i <= np - 2; i++) {
+ t = MAX(fabs(x[i + 1] - x[i]), fabs(y[i + 1] - y[i]));
+ if ((t > 0) && (t < min)) {
+ min = t;
/* ??? is 0.001 ok ??? */
- return min*0.000001;
+ return min * 0.000001;
/* currently O(n*n); future implementation O(nlogn) */
-struct seg_intersections* find_all_intersections(struct line_pnts *Points) {
+struct seg_intersections *find_all_intersections(struct line_pnts *Points)
int i, j, np;
int group, t;
int looped;
double EPSILON = 0.00000001;
double *x, *y;
double x1, y1, x2, y2;
int res;
/*int res2
- double x1_, y1_, x2_, y2_, z1_, z2_;*/
+ double x1_, y1_, x2_, y2_, z1_, z2_; */
struct seg_intersection_list *il;
struct intersection_point **sorted;
G_debug(3, "find_all_intersections()");
x = Points->x;
y = Points->y;
- si = create_si_struct(np-1);
- looped = ((x[0] == x[np-1]) && (y[0] == y[np-1]));
+ si = create_si_struct(np - 1);
+ looped = ((x[0] == x[np - 1]) && (y[0] == y[np - 1]));
G_debug(3, " looped=%d", looped);
G_debug(3, " finding intersections...");
- for (i = 0; i < np-1; i++) {
- for (j = i+1; j < np-1; j++) {
- G_debug(4, " checking %d-%d %d-%d", i, i+1, j, j+1);
- /*res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);*/
- res = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
-/* res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
- if ((res != res2) || ((res != 0) && (x1!=x1_ || y1!=y1_)) ) {
- G_debug(0, "exact=%d orig=%d", res, res2);
- segment_intersection_2d_test(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
- G_debug(4, " intersection type = %d", res);
- if (res == 1) {
- add_ipoint(Points, i, j, x1, y1, si);
- } else if ((res >= 2) && (res <= 5)) {
- add_ipoint(Points, i, j, x2, y2, si);
+ for (i = 0; i < np - 1; i++) {
+ for (j = i + 1; j < np - 1; j++) {
+ G_debug(4, " checking %d-%d %d-%d", i, i + 1, j, j + 1);
+ /*res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2); */
+ res =
+ segment_intersection_2d(x[i], y[i], x[i + 1], y[i + 1], x[j],
+ y[j], x[j + 1], y[j + 1], &x1, &y1,
+ &x2, &y2);
+ /* res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
+ if ((res != res2) || ((res != 0) && (x1!=x1_ || y1!=y1_)) ) {
+ G_debug(0, "exact=%d orig=%d", res, res2);
+ segment_intersection_2d_test(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
+ G_debug(4, " intersection type = %d", res);
+ if (res == 1) {
+ add_ipoint(Points, i, j, x1, y1, si);
+ else if ((res >= 2) && (res <= 5)) {
+ add_ipoint(Points, i, j, x2, y2, si);
if (!looped) {
- /* these are not really intersection points */
- add_ipoint(Points, 0, -1, Points->x[0], Points->y[0], si);
- add_ipoint(Points, np-2, -1, Points->x[np-1], Points->y[np-1], si);
+ /* these are not really intersection points */
+ add_ipoint(Points, 0, -1, Points->x[0], Points->y[0], si);
+ add_ipoint(Points, np - 2, -1, Points->x[np - 1], Points->y[np - 1],
+ si);
G_debug(3, " finding intersections...done");
G_debug(3, " postprocessing...");
if (si->ipallocated > si->ipcount) {
- si->ipallocated = si->ipcount;
- si->ip = G_realloc(si->ip, (si->ipcount)*sizeof(struct intersection_point));
+ si->ipallocated = si->ipcount;
+ si->ip =
+ G_realloc(si->ip,
+ (si->ipcount) * sizeof(struct intersection_point));
for (i = 0; i < si->ilcount; i++) {
- il = &(si->il[i]);
- if (il->allocated > il->count) {
- il->allocated = il->count;
- il->a = G_realloc(il->a, (il->count)*sizeof(struct seg_intersection));
- if (il->count > 0) {
- sort_intersection_list(il);
- /* is it ok to use qsort here ? */
+ il = &(si->il[i]);
+ if (il->allocated > il->count) {
+ il->allocated = il->count;
+ il->a =
+ G_realloc(il->a,
+ (il->count) * sizeof(struct seg_intersection));
+ if (il->count > 0) {
+ sort_intersection_list(il);
+ /* is it ok to use qsort here ? */
/* si->ip will not be reallocated any more so we can use pointers */
- sorted = G_malloc((si->ipcount)*sizeof(struct intersection_point *));
+ sorted = G_malloc((si->ipcount) * sizeof(struct intersection_point *));
for (i = 0; i < si->ipcount; i++)
- sorted[i] = &(si->ip[i]);
+ sorted[i] = &(si->ip[i]);
qsort(sorted, si->ipcount, sizeof(struct intersection_point *), compare);
/* assign groups */
- group = 0; /* next available group number */
+ group = 0; /* next available group number */
for (i = 0; i < si->ipcount; i++) {
- t = group;
- for (j = i-1; j >= 0; j--) {
- if (!FEQUAL(sorted[j]->x, sorted[i]->x, EPSILON))
-/* if (!almost_equal(sorted[j]->x, sorted[i]->x, 16))*/
- break;
- if (FEQUAL(sorted[j]->y, sorted[i]->y, EPSILON)) {
-/* if (almost_equal(sorted[j]->y, sorted[i]->y, 16)) {*/
- t = sorted[j]->group;
- break;
- G_debug(4, " group=%d, ip=%d", t, (int)(sorted[i] - &(si->ip[0])));
- sorted[i]->group = t;
- if (t == group)
- group++;
+ t = group;
+ for (j = i - 1; j >= 0; j--) {
+ if (!FEQUAL(sorted[j]->x, sorted[i]->x, EPSILON))
+ /* if (!almost_equal(sorted[j]->x, sorted[i]->x, 16)) */
+ break;
+ if (FEQUAL(sorted[j]->y, sorted[i]->y, EPSILON)) {
+ /* if (almost_equal(sorted[j]->y, sorted[i]->y, 16)) { */
+ t = sorted[j]->group;
+ break;
+ G_debug(4, " group=%d, ip=%d", t,
+ (int)(sorted[i] - &(si->ip[0])));
+ sorted[i]->group = t;
+ if (t == group)
+ group++;
si->group_count = group;
G_debug(3, " postprocessing...done");
/* output contents of si */
- G_debug(4, "%d-%d :", i, i+1);
- for (j = 0; j < si->il[i].count; j++) {
- G_debug(4, " %d-%d, group=%d", si->il[i].a[j].with, si->il[i].a[j].with+1, si->ip[si->il[i].a[j].ip].group);
- G_debug(4, " dist=%.18f", si->il[i].a[j].dist);
- G_debug(4, " x=%.18f, y=%.18f", si->ip[si->il[i].a[j].ip].x, si->ip[si->il[i].a[j].ip].y);
+ G_debug(4, "%d-%d :", i, i + 1);
+ for (j = 0; j < si->il[i].count; j++) {
+ G_debug(4, " %d-%d, group=%d", si->il[i].a[j].with,
+ si->il[i].a[j].with + 1, si->ip[si->il[i].a[j].ip].group);
+ G_debug(4, " dist=%.18f", si->il[i].a[j].dist);
+ G_debug(4, " x=%.18f, y=%.18f",
+ si->ip[si->il[i].a[j].ip].x, si->ip[si->il[i].a[j].ip].y);
return si;
/* create's graph with n vertices and allocates memory for e edges */
/* trying to add more than e edges, produces fatal error */
-struct planar_graph* pg_create_struct(int n, int e) {
+struct planar_graph *pg_create_struct(int n, int e)
struct planar_graph *pg;
pg = G_malloc(sizeof(struct planar_graph));
pg->vcount = n;
- pg->v = G_malloc(n*sizeof(struct pg_vertex));
- memset(pg->v, 0, n*sizeof(struct pg_vertex));
+ pg->v = G_malloc(n * sizeof(struct pg_vertex));
+ memset(pg->v, 0, n * sizeof(struct pg_vertex));
pg->ecount = 0;
pg->eallocated = MAX(e, 0);
pg->e = NULL;
- pg->e = G_malloc(e*sizeof(struct pg_edge));
+ pg->e = G_malloc(e * sizeof(struct pg_edge));
return pg;
-void pg_destroy_struct(struct planar_graph *pg) {
+void pg_destroy_struct(struct planar_graph *pg)
int i;
for (i = 0; i < pg->vcount; i++) {
- G_free(pg->v[i].edges);
- G_free(pg->v[i].angles);
+ G_free(pg->v[i].edges);
+ G_free(pg->v[i].angles);
G_free(pg->v);
G_free(pg->e);
@@ -318,137 +368,154 @@
/* v1 and v2 must be valid */
-int pg_existsedge(struct planar_graph *pg, int v1, int v2) {
+int pg_existsedge(struct planar_graph *pg, int v1, int v2)
struct pg_vertex *v;
struct pg_edge *e;
int i, ecount;
if (pg->v[v1].ecount <= pg->v[v2].ecount)
- v = &(pg->v[v1]);
+ v = &(pg->v[v1]);
else
- v = &(pg->v[v2]);
+ v = &(pg->v[v2]);
ecount = v->ecount;
for (i = 0; i < ecount; i++) {
- e = v->edges[i];
- if (((e->v1 == v1) && (e->v2 == v2)) || ((e->v1 == v2) && (e->v2 == v1)))
- return 1;
+ e = v->edges[i];
+ if (((e->v1 == v1) && (e->v2 == v2)) ||
+ ((e->v1 == v2) && (e->v2 == v1)))
+ return 1;
return 0;
/* for internal use */
-void pg_addedge1(struct pg_vertex *v, struct pg_edge *e) {
+void pg_addedge1(struct pg_vertex *v, struct pg_edge *e)
if (v->ecount == v->eallocated) {
- v->eallocated += 4;
- v->edges = G_realloc(v->edges, (v->eallocated)*sizeof(struct pg_edge *));
+ v->eallocated += 4;
+ v->edges =
+ G_realloc(v->edges, (v->eallocated) * sizeof(struct pg_edge *));
v->edges[v->ecount] = e;
v->ecount++;
-void pg_addedge(struct planar_graph *pg, int v1, int v2) {
+void pg_addedge(struct planar_graph *pg, int v1, int v2)
struct pg_edge *e;
G_debug(4, "pg_addedge(), v1=%d, v2=%d", v1, v2);
- if ((v1 == v2) || (v1 < 0) || (v1 >= pg->vcount) || (v2 < 0) || (v2 >= pg->vcount)) {
- G_fatal_error(" pg_addedge(), v1 and/or v2 is invalid");
- return;
+ if ((v1 == v2) || (v1 < 0) || (v1 >= pg->vcount) || (v2 < 0) ||
+ (v2 >= pg->vcount)) {
+ G_fatal_error(" pg_addedge(), v1 and/or v2 is invalid");
+ return;
if (pg_existsedge(pg, v1, v2))
- return;
+ return;
if (pg->ecount == pg->eallocated) {
- G_fatal_error("Trying to add more edges to the planar_graph than the initial allocation size allows");
+ G_fatal_error
+ ("Trying to add more edges to the planar_graph than the initial allocation size allows");
e = &(pg->e[pg->ecount]);
e->v1 = v1;
e->v2 = v2;
- e->winding_left = 0; /* winding is undefined if the corresponding side is not visited */
+ e->winding_left = 0; /* winding is undefined if the corresponding side is not visited */
e->winding_right = 0;
e->visited_left = 0;
e->visited_right = 0;
pg->ecount++;
pg_addedge1(&(pg->v[v1]), e);
pg_addedge1(&(pg->v[v2]), e);
return;
-struct planar_graph* pg_create(struct line_pnts *Points) {
+struct planar_graph *pg_create(struct line_pnts *Points)
struct pg_vertex *vert;
struct pg_edge *edge;
int i, j, t, v;
G_debug(3, "pg_create()");
si = find_all_intersections(Points);
- pg = pg_create_struct(si->group_count, 2*(si->ipcount));
+ pg = pg_create_struct(si->group_count, 2 * (si->ipcount));
/* set vertices info */
- ip = &(si->ip[i]);
- t = ip->group;
- pg->v[t].x = ip->x;
- pg->v[t].y = ip->y;
+ ip = &(si->ip[i]);
+ t = ip->group;
+ pg->v[t].x = ip->x;
+ pg->v[t].y = ip->y;
/* add all edges */
- v = si->ip[si->il[i].a[0].ip].group;
- for (j = 1; j < si->il[i].count; j++) {
- t = si->ip[si->il[i].a[j].ip].group;
- if (t != v) {
- pg_addedge(pg, v, t); /* edge direction is v ---> t */
- v = t;
+ v = si->ip[si->il[i].a[0].ip].group;
+ for (j = 1; j < si->il[i].count; j++) {
+ t = si->ip[si->il[i].a[j].ip].group;
+ if (t != v) {
+ pg_addedge(pg, v, t); /* edge direction is v ---> t */
+ v = t;
/* precalculate angles with 0x */
- vert = &(pg->v[i]);
- vert->angles = G_malloc((vert->ecount)*sizeof(double));
- for (j = 0; j < vert->ecount; j++) {
- edge = vert->edges[j];
- t = (edge->v1 != i)?(edge->v1):(edge->v2);
- vert->angles[j] = atan2(pg->v[t].y - vert->y, pg->v[t].x - vert->x);
+ vert = &(pg->v[i]);
+ vert->angles = G_malloc((vert->ecount) * sizeof(double));
+ for (j = 0; j < vert->ecount; j++) {
+ edge = vert->edges[j];
+ t = (edge->v1 != i) ? (edge->v1) : (edge->v2);
+ vert->angles[j] =
+ atan2(pg->v[t].y - vert->y, pg->v[t].x - vert->x);
destroy_si_struct(si);
- I'm not sure if shrinking of the allocated memory always preserves it's physical place.
- That's why I don't want to do this:
- if (pg->ecount < pg->eallocated) {
- pg->eallocated = pg->ecount;
- pg->e = G_realloc(pg->e, (pg->ecount)*sizeof(struct pg_edge));
+ I'm not sure if shrinking of the allocated memory always preserves it's physical place.
+ That's why I don't want to do this:
+ if (pg->ecount < pg->eallocated) {
+ pg->eallocated = pg->ecount;
+ pg->e = G_realloc(pg->e, (pg->ecount)*sizeof(struct pg_edge));
/* very time consuming */
- for (i = 0; i < pg->vcount; i++) {
- if (pg->v[i].ecount < pg->v[i].eallocated) {
- pg->v[i].eallocated = pg->v[i].ecount;
- pg->v[i].edges = G_realloc(pg->v[i].edges, (pg->v[i].ecount)*sizeof(struct pg_edges));
+ for (i = 0; i < pg->vcount; i++) {
+ if (pg->v[i].ecount < pg->v[i].eallocated) {
+ pg->v[i].eallocated = pg->v[i].ecount;
+ pg->v[i].edges = G_realloc(pg->v[i].edges, (pg->v[i].ecount)*sizeof(struct pg_edges));
/* output pg */
- G_debug(4, " vertex %d (%g, %g)", i, pg->v[i].x, pg->v[i].y);
- for (j = 0; j < pg->v[i].ecount; j++) {
- G_debug(4, " edge %d-%d", pg->v[i].edges[j]->v1, pg->v[i].edges[j]->v2);
+ G_debug(4, " vertex %d (%g, %g)", i, pg->v[i].x, pg->v[i].y);
+ for (j = 0; j < pg->v[i].ecount; j++) {
+ G_debug(4, " edge %d-%d", pg->v[i].edges[j]->v1,
+ pg->v[i].edges[j]->v2);
return pg;
Modified: grass/branches/develbranch_6/vector/v.buffer2/e_intersect.c
--- grass/branches/develbranch_6/vector/v.buffer2/e_intersect.c 2008-11-27 21:57:06 UTC (rev 34560)
+++ grass/branches/develbranch_6/vector/v.buffer2/e_intersect.c 2008-11-27 22:04:34 UTC (rev 34561)
@@ -5,11 +5,11 @@
#define SWAP(a,b) {t = a; a = b; b = t;}
#ifndef MIN
#endif
#ifndef MAX
-#endif
+#endif
#define D (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2)
#define DA (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2)
#define DB (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1)
@@ -17,39 +17,44 @@
#ifdef ASDASDASFDSAFFDAS
mpf_t p11, p12, p21, p22, t1, t2;
mpf_t dd, dda, ddb, delta;
mpf_t rra, rrb;
int initialized = 0;
-void initialize_mpf_vars() {
+void initialize_mpf_vars()
mpf_set_default_prec(2048);
mpf_init(p11);
mpf_init(p12);
mpf_init(p21);
mpf_init(p22);
mpf_init(t1);
mpf_init(t2);
mpf_init(dd);
mpf_init(dda);
mpf_init(ddb);
mpf_init(delta);
mpf_init(rra);
mpf_init(rrb);
initialized = 1;
- Caclulates:
- |a11-b11 a12-b12|
- |a21-b21 a22-b22|
-void det22(mpf_t rop, double a11, double b11, double a12, double b12, double a21, double b21, double a22, double b22) {
+ Caclulates:
+ |a11-b11 a12-b12|
+ |a21-b21 a22-b22|
+void det22(mpf_t rop, double a11, double b11, double a12, double b12,
+ double a21, double b21, double a22, double b22)
mpf_set_d(t1, a11);
mpf_set_d(t2, b11);
mpf_sub(p11, t1, t2);
@@ -62,39 +67,49 @@
mpf_set_d(t1, a22);
mpf_set_d(t2, b22);
mpf_sub(p22, t1, t2);
mpf_mul(t1, p11, p22);
mpf_mul(t2, p12, p21);
mpf_sub(rop, t1, t2);
return;
-void swap(double *a, double *b) {
+void swap(double *a, double *b)
double t = *a;
*a = *b;
*b = t;
return;
/* multi-precision version */
-int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
- double *x1, double *y1, double *x2, double *y2)
+int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2,
+ double bx1, double by1, double bx2, double by2,
+ double *x1, double *y1, double *x2, double *y2)
double t;
double max_ax, min_ax, max_ay, min_ay;
double max_bx, min_bx, max_by, min_by;
int sgn_d, sgn_da, sgn_db;
int vertical;
int f11, f12, f21, f22;
mp_exp_t exp;
char *s;
if (!initialized)
- initialize_mpf_vars();
+ initialize_mpf_vars();
/* TODO: Works for points ? */
- G_debug(3, "segment_intersection_2d_e()");
+ G_debug(3, "segment_intersection_2d_e()");
G_debug(4, " ax1 = %.18f, ay1 = %.18f", ax1, ay1);
G_debug(4, " ax2 = %.18f, ay2 = %.18f", ax2, ay2);
G_debug(4, " bx1 = %.18f, by1 = %.18f", bx1, by1);
@@ -104,191 +119,213 @@
f12 = ((ax1 == bx2) && (ay1 == by2));
f21 = ((ax2 == bx1) && (ay2 == by1));
f22 = ((ax2 == bx2) && (ay2 == by2));
/* Check for identical segments */
if ((f11 && f22) || (f12 && f21)) {
- G_debug (3, " identical segments" );
- *x1 = ax1; *y1 = ay1;
- *x2 = ax2; *y2 = ay2;
- return 5;
+ G_debug(3, " identical segments");
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = ax2;
+ *y2 = ay2;
+ return 5;
/* Check for identical endpoints */
if (f11 || f12) {
- G_debug (3, " connected by endpoints" );
- return 1;
+ G_debug(3, " connected by endpoints");
+ *x1 = ax1;
+ *y1 = ay1;
+ return 1;
if (f21 || f22) {
- *x1 = ax2; *y1 = ay2;
- return 1;
+ *x1 = ax2;
+ *y1 = ay2;
+ return 1;
if ((MAX(ax1, ax2) < MIN(bx1, bx2)) || (MAX(bx1, bx2) < MIN(ax1, ax2))) {
- G_debug(3, " no intersection (disjoint bounding boxes)");
- return 0;
+ G_debug(3, " no intersection (disjoint bounding boxes)");
+ return 0;
if ((MAX(ay1, ay2) < MIN(by1, by2)) || (MAX(by1, by2) < MIN(ay1, ay2))) {
- return 0;
+ return 0;
- det22(dd, ax2, ax1, bx1, bx2, ay2, ay1, by1, by2);
+ det22(dd, ax2, ax1, bx1, bx2, ay2, ay1, by1, by2);
sgn_d = mpf_sgn(dd);
if (sgn_d != 0) {
- G_debug(3, " general position");
+ G_debug(3, " general position");
- det22(dda, bx1, ax1, bx1, bx2, by1, ay1, by1, by2);
- sgn_da = mpf_sgn(dda);
- /*mpf_div(rra, dda, dd);
- mpf_div(rrb, ddb, dd);
- s = mpf_get_str(NULL, &exp, 10, 40, rra);
- G_debug(4, " ra = %sE%d", (s[0]==0)?"0":s, exp);
- s = mpf_get_str(NULL, &exp, 10, 24, rrb);
- G_debug(4, " rb = %sE%d", (s[0]==0)?"0":s, exp);
- if (sgn_d > 0) {
- if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
- G_debug(3, " no intersection");
- return 0;
- det22(ddb, ax2, ax1, bx1, ax1, ay2, ay1, by1, ay1);
- sgn_db = mpf_sgn(ddb);
- if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
- return 0;
- else { /* if sgn_d < 0 */
- if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
- return 0;
- if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
- return 0;
+ det22(dda, bx1, ax1, bx1, bx2, by1, ay1, by1, by2);
+ sgn_da = mpf_sgn(dda);
- /*G_debug(3, " ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));*/
- /*G_debug(3, " sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));*/
- mpf_set_d(delta, ax2 - ax1);
- mpf_mul(t1, dda, delta);
- mpf_div(t2, t1, dd);
- *x1 = ax1 + mpf_get_d(t2);
- mpf_set_d(delta, ay2 - ay1);
- *y1 = ay1 + mpf_get_d(t2);
+ /*mpf_div(rra, dda, dd);
+ mpf_div(rrb, ddb, dd);
+ s = mpf_get_str(NULL, &exp, 10, 40, rra);
+ G_debug(4, " ra = %sE%d", (s[0]==0)?"0":s, exp);
+ s = mpf_get_str(NULL, &exp, 10, 24, rrb);
+ G_debug(4, " rb = %sE%d", (s[0]==0)?"0":s, exp);
- G_debug(3, " intersection %.16g, %.16g", *x1, *y1);
- return 1;
+ if (sgn_d > 0) {
+ if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
+ G_debug(3, " no intersection");
+ return 0;
+ det22(ddb, ax2, ax1, bx1, ax1, ay2, ay1, by1, ay1);
+ sgn_db = mpf_sgn(ddb);
+ if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
+ return 0;
+ else { /* if sgn_d < 0 */
+ if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
+ return 0;
+ if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
+ return 0;
+ /*G_debug(3, " ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd)); */
+ /*G_debug(3, " sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd)); */
+ mpf_set_d(delta, ax2 - ax1);
+ mpf_mul(t1, dda, delta);
+ mpf_div(t2, t1, dd);
+ *x1 = ax1 + mpf_get_d(t2);
+ mpf_set_d(delta, ay2 - ay1);
+ *y1 = ay1 + mpf_get_d(t2);
+ G_debug(3, " intersection %.16g, %.16g", *x1, *y1);
+ return 1;
/* segments are parallel or collinear */
if (sgn_da != 0) {
- /* segments are parallel */
- G_debug(3, " parallel segments");
- return 0;
+ /* segments are parallel */
+ G_debug(3, " parallel segments");
+ return 0;
/* segments are colinear. check for overlap */
/* swap endpoints if needed */
- /* if segments are vertical, we swap x-coords with y-coords */
+ /* if segments are vertical, we swap x-coords with y-coords */
vertical = 0;
if (ax1 > ax2) {
- SWAP(ax1, ax2);
- SWAP(ay1, ay2);
- } else if (ax1 == ax2) {
- vertical = 1;
- if (ay1 > ay2)
- SWAP(ay1, ay2);
- SWAP(ax1, ay1);
- SWAP(ax2, ay2);
+ SWAP(ax1, ax2);
+ SWAP(ay1, ay2);
+ else if (ax1 == ax2) {
+ vertical = 1;
+ if (ay1 > ay2)
+ SWAP(ay1, ay2);
+ SWAP(ax1, ay1);
+ SWAP(ax2, ay2);
if (bx1 > bx2) {
- SWAP(bx1, bx2);
- SWAP(by1, by2);
- } else if (bx1 == bx2) {
- if (by1 > by2)
- SWAP(by1, by2);
- SWAP(bx1, by1);
- SWAP(bx2, by2);
+ SWAP(bx1, bx2);
+ SWAP(by1, by2);
+ else if (bx1 == bx2) {
+ if (by1 > by2)
+ SWAP(by1, by2);
+ SWAP(bx1, by1);
+ SWAP(bx2, by2);
G_debug(3, " collinear segments");
if ((bx2 < ax1) || (bx1 > ax2)) {
- return 0;
+ return 0;
/* there is overlap or connected end points */
G_debug(3, " overlap");
/* a contains b */
if ((ax1 < bx1) && (ax2 > bx2)) {
- G_debug(3, " a contains b");
- if (!vertical) {
- *x1 = bx1; *y1 = by1;
- *x2 = bx2; *y2 = by2;
- else {
- *x1 = by1; *y1 = bx1;
- *x2 = by2; *y2 = bx2;
- return 3;
+ G_debug(3, " a contains b");
+ if (!vertical) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = bx2;
+ *y2 = by2;
+ else {
+ *x1 = by1;
+ *y1 = bx1;
+ *x2 = by2;
+ *y2 = bx2;
+ return 3;
/* b contains a */
if ((ax1 > bx1) && (ax2 < bx2)) {
- G_debug(3, " b contains a");
- if (!vertical) {
- else {
- return 4;
+ G_debug(3, " b contains a");
+ if (!vertical) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = bx2;
+ *y2 = by2;
+ else {
+ *x1 = by1;
+ *y1 = bx1;
+ *x2 = by2;
+ *y2 = bx2;
+ return 4;
/* general overlap, 2 intersection points */
G_debug(3, " partial overlap");
- if ((bx1 > ax1) && (bx1 < ax2)) { /* b1 is in a */
- if (!vertical) {
- else {
- *x2 = ay2; *y2 = ax2;
- return 2;
+ if ((bx1 > ax1) && (bx1 < ax2)) { /* b1 is in a */
+ if (!vertical) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = ax2;
+ *y2 = ay2;
+ else {
+ *x1 = by1;
+ *y1 = bx1;
+ *x2 = ay2;
+ *y2 = ax2;
+ return 2;
- if ((bx2 > ax1) && (bx2 < ax2)) { /* b2 is in a */
- if (!vertical) {
- *x1 = bx2; *y1 = by2;
- *x2 = ax1; *y2 = ay1;
- else {
- *x1 = by2; *y1 = bx2;
- *x2 = ay1; *y2 = ax1;
- return 2;
+ if ((bx2 > ax1) && (bx2 < ax2)) { /* b2 is in a */
+ if (!vertical) {
+ *x1 = bx2;
+ *y1 = by2;
+ *x2 = ax1;
+ *y2 = ay1;
+ else {
+ *x1 = by2;
+ *y1 = bx2;
+ *x2 = ay1;
+ *y2 = ax1;
+ return 2;
/* should not be reached */
G_warning(("segment_intersection_2d() ERROR (should not be reached)"));
@@ -305,248 +342,326 @@
/* OLD */
/* tollerance aware version */
/* TODO: fix all ==s left */
-int segment_intersection_2d_tol(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
- double *x1, double *y1, double *x2, double *y2, double tol)
+int segment_intersection_2d_tol(double ax1, double ay1, double ax2,
+ double ay2, double bx1, double by1,
+ double bx2, double by2, double *x1,
+ double *y1, double *x2, double *y2,
+ double tol)
double tola, tolb;
double d, d1, d2, ra, rb, t;
- int switched = 0;
+ int switched = 0;
- G_debug(4, "segment_intersection_2d()");
+ G_debug(4, "segment_intersection_2d()");
G_debug(4, " bx2 = %.18f, by2 = %.18f", bx2, by2);
/* Check identical lines */
- if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) && FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
- (FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) && FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
- G_debug (2, " -> identical segments" );
- return 5;
+ if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) &&
+ FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
+ (FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) &&
+ FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
+ G_debug(2, " -> identical segments");
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = ax2;
+ *y2 = ay2;
+ return 5;
/* 'Sort' lines by x1, x2, y1, y2 */
- if ( bx1 < ax1 )
- switched = 1;
- else if ( bx1 == ax1 ) {
- if ( bx2 < ax2 ) switched = 1;
- else if ( bx2 == ax2 ) {
- if ( by1 < ay1 ) switched = 1;
- else if ( by1 == ay1 ) {
- if ( by2 < ay2 ) switched = 1; /* by2 != ay2 (would be identical */
+ if (bx1 < ax1)
+ switched = 1;
+ else if (bx1 == ax1) {
+ if (bx2 < ax2)
+ switched = 1;
+ else if (bx2 == ax2) {
+ if (by1 < ay1)
+ switched = 1;
+ else if (by1 == ay1) {
+ if (by2 < ay2)
+ switched = 1; /* by2 != ay2 (would be identical */
if (switched) {
- t = ax1; ax1 = bx1; bx1 = t; t = ay1; ay1 = by1; by1 = t;
- t = ax2; ax2 = bx2; bx2 = t; t = ay2; ay2 = by2; by2 = t;
- d = (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2);
- d1 = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
- d2 = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
+ t = ax1;
+ ax1 = bx1;
+ bx1 = t;
+ t = ay1;
+ ay1 = by1;
+ by1 = t;
+ t = ax2;
+ ax2 = bx2;
+ bx2 = t;
+ t = ay2;
+ ay2 = by2;
+ by2 = t;
+ d = (ax2 - ax1) * (by1 - by2) - (ay2 - ay1) * (bx1 - bx2);
+ d1 = (bx1 - ax1) * (by1 - by2) - (by1 - ay1) * (bx1 - bx2);
+ d2 = (ax2 - ax1) * (by1 - ay1) - (ay2 - ay1) * (bx1 - ax1);
G_debug(2, " d = %.18g", d);
G_debug(2, " d1 = %.18g", d1);
G_debug(2, " d2 = %.18g", d2);
- tola = tol/MAX(fabs(ax2-ax1), fabs(ay2-ay1));
- tolb = tol/MAX(fabs(bx2-bx1), fabs(by2-by1));
+ tola = tol / MAX(fabs(ax2 - ax1), fabs(ay2 - ay1));
+ tolb = tol / MAX(fabs(bx2 - bx1), fabs(by2 - by1));
G_debug(2, " tol = %.18g", tol);
G_debug(2, " tola = %.18g", tola);
G_debug(2, " tolb = %.18g", tolb);
if (!FZERO(d, tol)) {
- ra = d1/d;
- rb = d2/d;
- G_debug(2, " not parallel/collinear: ra = %.18g", ra);
- G_debug(2, " rb = %.18g", rb);
- if ((ra <= -tola) || (ra >= 1+tola) || (rb <= -tolb) || (rb >= 1+tolb)) {
- G_debug(2, " no intersection");
- return 0;
- ra = MIN(MAX(ra, 0), 1);
- *x1 = ax1 + ra*(ax2 - ax1);
- *y1 = ay1 + ra*(ay2 - ay1);
- G_debug(2, " intersection %.18f, %.18f", *x1, *y1);
- return 1;
+ ra = d1 / d;
+ rb = d2 / d;
+ G_debug(2, " not parallel/collinear: ra = %.18g", ra);
+ G_debug(2, " rb = %.18g", rb);
+ if ((ra <= -tola) || (ra >= 1 + tola) || (rb <= -tolb) ||
+ (rb >= 1 + tolb)) {
+ G_debug(2, " no intersection");
+ return 0;
+ ra = MIN(MAX(ra, 0), 1);
+ *x1 = ax1 + ra * (ax2 - ax1);
+ *y1 = ay1 + ra * (ay2 - ay1);
+ G_debug(2, " intersection %.18f, %.18f", *x1, *y1);
+ return 1;
- G_debug (3, " -> parallel/collinear" );
- if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) { /* lines are parallel */
- G_debug (2, " -> parallel" );
- return 0;
+ G_debug(3, " -> parallel/collinear");
+ if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) { /* lines are parallel */
+ G_debug(2, " -> parallel");
+ return 0;
-/* aa = adx*adx + ady*ady;
- bb = bdx*bdx + bdy*bdy;
- t = (ax1-bx1)*bdx + (ay1-by1)*bdy;*/
+ /* aa = adx*adx + ady*ady;
+ bb = bdx*bdx + bdy*bdy;
+ t = (ax1-bx1)*bdx + (ay1-by1)*bdy; */
/* Collinear vertical */
/* original code assumed lines were not both vertical
- * so there is a special case if they are */
- if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) && FEQUAL(ax1, bx1, tol)) {
- G_debug(2, " -> collinear vertical");
- if (ay1 > ay2) { t=ay1; ay1=ay2; ay2=t; } /* to be sure that ay1 < ay2 */
- if (by1 > by2) { t=by1; by1=by2; by2=t; } /* to be sure that by1 < by2 */
- if (ay1 > by2 || ay2 < by1) {
- G_debug (2, " -> no intersection");
- return 0;
+ * so there is a special case if they are */
+ if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) &&
+ FEQUAL(ax1, bx1, tol)) {
+ G_debug(2, " -> collinear vertical");
+ if (ay1 > ay2) {
+ t = ay1;
+ ay1 = ay2;
+ ay2 = t;
+ } /* to be sure that ay1 < ay2 */
+ if (by1 > by2) {
+ t = by1;
+ by1 = by2;
+ by2 = t;
+ } /* to be sure that by1 < by2 */
+ if (ay1 > by2 || ay2 < by1) {
+ G_debug(2, " -> no intersection");
+ return 0;
- /* end points */
- if (FEQUAL(ay1, by2, tol)) {
- G_debug(2, " -> connected by end points");
- return 1; /* endpoints only */
- if (FEQUAL(ay2, by1, tol)) {
- G_debug (2, " -> connected by end points");
- /* general overlap */
- G_debug(3, " -> vertical overlap");
- /* a contains b */
- if (ay1 <= by1 && ay2 >= by2) {
- G_debug (2, " -> a contains b" );
- if (!switched)
- return 3;
- else
- return 4;
- /* b contains a */
- if ( ay1 >= by1 && ay2 <= by2 ) {
- G_debug (2, " -> b contains a" );
- if ( !switched )
- return 4;
- else
- return 3;
+ /* end points */
+ if (FEQUAL(ay1, by2, tol)) {
+ *x1 = ax1;
+ *y1 = ay1;
+ G_debug(2, " -> connected by end points");
+ return 1; /* endpoints only */
+ if (FEQUAL(ay2, by1, tol)) {
+ *x1 = ax2;
+ *y1 = ay2;
- /* general overlap, 2 intersection points */
- G_debug (2, " -> partial overlap" );
- if ( by1 > ay1 && by1 < ay2 ) { /* b1 in a */
- if ( !switched ) {
- } else {
- *x2 = bx1; *y2 = by1;
- return 2;
- if ( by2 > ay1 && by2 < ay2 ) { /* b2 in a */
- } else {
- return 2;
- /* should not be reached */
- G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
- G_warning("%.15g %.15g", ax1, ay1);
- G_warning("%.15g %.15g", ax2, ay2);
- G_warning("x");
- G_warning("%.15g %.15g", bx1, by1);
- G_warning("%.15g %.15g", bx2, by2);
- return 0;
+ /* general overlap */
+ G_debug(3, " -> vertical overlap");
+ /* a contains b */
+ if (ay1 <= by1 && ay2 >= by2) {
+ G_debug(2, " -> a contains b");
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = bx2;
+ *y2 = by2;
+ if (!switched)
+ return 3;
+ else
+ return 4;
+ /* b contains a */
+ if (ay1 >= by1 && ay2 <= by2) {
+ G_debug(2, " -> b contains a");
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = ax2;
+ *y2 = ay2;
+ if (!switched)
+ return 4;
+ else
+ return 3;
+ /* general overlap, 2 intersection points */
+ G_debug(2, " -> partial overlap");
+ if (by1 > ay1 && by1 < ay2) { /* b1 in a */
+ if (!switched) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = ax2;
+ *y2 = ay2;
+ else {
+ *x1 = ax2;
+ *y1 = ay2;
+ *x2 = bx1;
+ *y2 = by1;
+ return 2;
+ if (by2 > ay1 && by2 < ay2) { /* b2 in a */
+ if (!switched) {
+ *x1 = bx2;
+ *y1 = by2;
+ *x2 = ax1;
+ *y2 = ay1;
+ else {
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = bx2;
+ *y2 = by2;
+ return 2;
+ /* should not be reached */
+ G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
+ G_warning("%.15g %.15g", ax1, ay1);
+ G_warning("%.15g %.15g", ax2, ay2);
+ G_warning("x");
+ G_warning("%.15g %.15g", bx1, by1);
+ G_warning("%.15g %.15g", bx2, by2);
+ return 0;
- G_debug (2, " -> collinear non vertical" );
+ G_debug(2, " -> collinear non vertical");
/* Collinear non vertical */
- if ( ( bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2 ) ||
- ( bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2 ) ) {
- G_debug (2, " -> no intersection" );
+ if ((bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2) ||
+ (bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2)) {
return 0;
- G_debug (2, " -> overlap/connected end points" );
+ G_debug(2, " -> overlap/connected end points");
/* end points */
- if ( (ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2) ) {
- return 1;
+ if ((ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2)) {
+ *x1 = ax1;
+ *y1 = ay1;
+ return 1;
- if ( (ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2) ) {
+ if ((ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2)) {
+ *x1 = ax2;
+ *y1 = ay2;
return 1;
- if (ax1 > ax2) { t=ax1; ax1=ax2; ax2=t; t=ay1; ay1=ay2; ay2=t; } /* to be sure that ax1 < ax2 */
- if (bx1 > bx2) { t=bx1; bx1=bx2; bx2=t; t=by1; by1=by2; by2=t; } /* to be sure that bx1 < bx2 */
+ if (ax1 > ax2) {
+ t = ax1;
+ ax1 = ax2;
+ ax2 = t;
+ t = ay1;
+ ay1 = ay2;
+ ay2 = t;
+ } /* to be sure that ax1 < ax2 */
+ if (bx1 > bx2) {
+ t = bx1;
+ bx1 = bx2;
+ bx2 = t;
+ t = by1;
+ by1 = by2;
+ by2 = t;
+ } /* to be sure that bx1 < bx2 */
/* a contains b */
- if ( ax1 <= bx1 && ax2 >= bx2 ) {
- if ( !switched )
- return 3;
- else
- return 4;
+ if (ax1 <= bx1 && ax2 >= bx2) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = bx2;
+ *y2 = by2;
+ if (!switched)
+ return 3;
+ else
+ return 4;
/* b contains a */
- if ( ax1 >= bx1 && ax2 <= bx2 ) {
- if ( !switched )
- return 4;
- else
- return 3;
+ if (ax1 >= bx1 && ax2 <= bx2) {
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = ax2;
+ *y2 = ay2;
+ if (!switched)
+ return 4;
+ else
+ return 3;
/* general overlap, 2 intersection points (lines are not vertical) */
- if ( bx1 > ax1 && bx1 < ax2 ) { /* b1 is in a */
- } else {
+ if (bx1 > ax1 && bx1 < ax2) { /* b1 is in a */
+ if (!switched) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = ax2;
+ *y2 = ay2;
+ else {
+ *x1 = ax2;
+ *y1 = ay2;
+ *x2 = bx1;
+ *y2 = by1;
return 2;
- if ( bx2 > ax1 && bx2 < ax2 ) { /* b2 is in a */
- } else {
+ if (bx2 > ax1 && bx2 < ax2) { /* b2 is in a */
+ if (!switched) {
+ *x1 = bx2;
+ *y1 = by2;
+ *x2 = ax1;
+ *y2 = ay1;
+ else {
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = bx2;
+ *y2 = by2;
return 2;
G_warning(("segment_intersection_2d() ERROR (collinear non vertical segments)"));
@@ -559,17 +674,22 @@
return 0;
-int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2,
const int DLEVEL = 4;
double t;
int vertical;
double d, da, db;
- G_debug(DLEVEL, "segment_intersection_2d()");
+ G_debug(DLEVEL, "segment_intersection_2d()");
@@ -579,180 +699,202 @@
- G_debug(DLEVEL, " identical segments" );
- return 5;
+ G_debug(DLEVEL, " identical segments");
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = ax2;
+ *y2 = ay2;
+ return 5;
if (f11 || f12) {
- G_debug(DLEVEL, " connected by endpoints" );
- return 1;
+ G_debug(DLEVEL, " connected by endpoints");
+ *x1 = ax1;
+ *y1 = ay1;
+ return 1;
if (f21 || f22) {
- G_debug (DLEVEL, " connected by endpoints" );
- return 1;
+ *x1 = ax2;
+ *y1 = ay2;
+ return 1;
- G_debug(DLEVEL, " no intersection (disjoint bounding boxes)");
- return 0;
+ G_debug(DLEVEL, " no intersection (disjoint bounding boxes)");
+ return 0;
- return 0;
+ return 0;
- d = D;
+ d = D;
if (d != 0) {
- G_debug(DLEVEL, " general position");
+ G_debug(DLEVEL, " general position");
- da = DA;
- if (d > 0) {
- if ((da < 0) || (da > d)) {
- G_debug(DLEVEL, " no intersection");
- return 0;
- db = DB;
- if ((db < 0) || (db > d)) {
- return 0;
- else { /* if d < 0 */
- if ((da > 0) || (da < d)) {
- return 0;
- db = DB;
- if ((db > 0) || (db < d)) {
- return 0;
+ da = DA;
- /*G_debug(DLEVEL, " ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));*/
- /*G_debug(DLEVEL, " sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));*/
- *x1 = ax1 + (ax2 - ax1)*da/d;
- *y1 = ay1 + (ay2 - ay1)*da/d;
- G_debug(DLEVEL, " intersection %.16g, %.16g", *x1, *y1);
- return 1;
+ if (d > 0) {
+ if ((da < 0) || (da > d)) {
+ G_debug(DLEVEL, " no intersection");
+ return 0;
+ db = DB;
+ if ((db < 0) || (db > d)) {
+ return 0;
+ else { /* if d < 0 */
+ if ((da > 0) || (da < d)) {
+ return 0;
+ db = DB;
+ if ((db > 0) || (db < d)) {
+ return 0;
+ /*G_debug(DLEVEL, " ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd)); */
+ /*G_debug(DLEVEL, " sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd)); */
+ *x1 = ax1 + (ax2 - ax1) * da / d;
+ *y1 = ay1 + (ay2 - ay1) * da / d;
+ G_debug(DLEVEL, " intersection %.16g, %.16g", *x1, *y1);
+ return 1;
da = DA;
db = DB;
if ((da != 0) || (db != 0)) {
- G_debug(DLEVEL, " parallel segments");
- return 0;
+ G_debug(DLEVEL, " parallel segments");
+ return 0;
vertical = 0;
if (ax1 > ax2) {
- SWAP(ax1, ax2);
- SWAP(ay1, ay2);
- vertical = 1;
- if (ay1 > ay2)
- SWAP(ay1, ay2);
- SWAP(ax1, ay1);
- SWAP(ax2, ay2);
+ SWAP(ax1, ax2);
+ SWAP(ay1, ay2);
+ vertical = 1;
+ if (ay1 > ay2)
+ SWAP(ay1, ay2);
+ SWAP(ax1, ay1);
+ SWAP(ax2, ay2);
if (bx1 > bx2) {
- SWAP(bx1, bx2);
- SWAP(by1, by2);
- if (by1 > by2)
- SWAP(by1, by2);
- SWAP(bx1, by1);
- SWAP(bx2, by2);
+ SWAP(bx1, bx2);
+ SWAP(by1, by2);
+ if (by1 > by2)
+ SWAP(by1, by2);
+ SWAP(bx1, by1);
+ SWAP(bx2, by2);
G_debug(DLEVEL, " collinear segments");
- return 0;
+ return 0;
G_debug(DLEVEL, " overlap");
/* a contains b */
- G_debug(DLEVEL, " a contains b");
- if (!vertical) {
- else {
- return 3;
+ G_debug(DLEVEL, " a contains b");
+ if (!vertical) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = bx2;
+ *y2 = by2;
+ else {
+ *x1 = by1;
+ *y1 = bx1;
+ *x2 = by2;
+ *y2 = bx2;
+ return 3;
/* b contains a */
- G_debug(DLEVEL, " b contains a");
- if (!vertical) {
- else {
- return 4;
+ G_debug(DLEVEL, " b contains a");
+ if (!vertical) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = bx2;
+ *y2 = by2;
+ else {
+ *x1 = by1;
+ *y1 = bx1;
+ *x2 = by2;
+ *y2 = bx2;
+ return 4;
G_debug(DLEVEL, " partial overlap");
- if (!vertical) {
- else {
- return 2;
+ if (!vertical) {
+ *x1 = bx1;
+ *y1 = by1;
+ *x2 = ax2;
+ *y2 = ay2;
+ else {
+ *x1 = by1;
+ *y1 = bx1;
+ *x2 = ay2;
+ *y2 = ax2;
+ return 2;
- if (!vertical) {
- else {
- return 2;
+ if (!vertical) {
+ *x1 = bx2;
+ *y1 = by2;
+ *x2 = ax1;
+ *y2 = ay1;
+ else {
+ *x1 = by2;
+ *y1 = bx2;
+ *x2 = ay1;
+ *y2 = ax1;
+ return 2;
@@ -765,154 +907,171 @@
return 0;
-#define N 52 /* double's mantisa size in bits */
+#define N 52 /* double's mantisa size in bits */
/* a and b are different in at most <bits> significant digits */
-int almost_equal(double a, double b, int bits) {
+int almost_equal(double a, double b, int bits)
int ea, eb, e;
if (a == b)
- return 1;
+ return 1;
if (a == 0 || b == 0) {
- /* return (0 < -N+bits); */
- return (bits > N);
+ /* return (0 < -N+bits); */
+ return (bits > N);
frexp(a, &ea);
frexp(b, &eb);
if (ea != eb)
- return (bits > N + abs(ea-eb));
- frexp(a-b, &e);
- return (e < ea-N+bits);
+ return (bits > N + abs(ea - eb));
+ frexp(a - b, &e);
+ return (e < ea - N + bits);
#ifdef ASDASDFASFEAS
-int segment_intersection_2d_test(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2, double *x1, double *y1, double *x2, double *y2) {
+int segment_intersection_2d_test(double ax1, double ay1, double ax2,
+ double *y1, double *x2, double *y2)
double t;
int vertical;
mp_exp_t exp;
char *s;
double d, da, db, ra, rb;
if (!initialized)
- G_debug(0, "segment_intersection_2d_test()");
- G_debug(0, " ax1 = %.18e, ay1 = %.18e", ax1, ay1);
- G_debug(0, " ax2 = %.18e, ay2 = %.18e", ax2, ay2);
- G_debug(0, " bx1 = %.18e, by1 = %.18e", bx1, by1);
- G_debug(0, " bx2 = %.18e, by2 = %.18e", bx2, by2);
+ G_debug(3, "segment_intersection_2d_test()");
+ G_debug(3, " ax1 = %.18e, ay1 = %.18e", ax1, ay1);
+ G_debug(3, " ax2 = %.18e, ay2 = %.18e", ax2, ay2);
+ G_debug(3, " bx1 = %.18e, by1 = %.18e", bx1, by1);
+ G_debug(3, " bx2 = %.18e, by2 = %.18e", bx2, by2);
f11 = ((ax1 == bx1) && (ay1 == by1));
- G_debug (0, " identical segments" );
- return 5;
+ G_debug(4, " identical segments");
+ *x1 = ax1;
+ *y1 = ay1;
+ *x2 = ax2;
+ *y2 = ay2;
+ return 5;
if (f11 || f12) {
- G_debug (0, " connected by endpoints" );
- return 1;
+ G_debug(4, " connected by endpoints");
+ *x1 = ax1;
+ *y1 = ay1;
+ return 1;
if (f21 || f22) {
- return 1;
+ *x1 = ax2;
+ *y1 = ay2;
+ return 1;
- G_debug(0, " no intersection (disjoint bounding boxes)");
- return 0;
+ G_debug(4, " no intersection (disjoint bounding boxes)");
+ return 0;
- return 0;
+ return 0;
- da = (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2);
- db = (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1);
+ da = (bx1 - ax1) * (by1 - by2) - (by1 - ay1) * (bx1 - bx2);
+ db = (ax2 - ax1) * (by1 - ay1) - (ay2 - ay1) * (bx1 - ax1);
s = mpf_get_str(NULL, &exp, 10, 40, dd);
- G_debug(0, " dd = %sE%d", (s[0]==0)?"0":s, exp);
- G_debug(0, " d = %.18E", d);
+ G_debug(3, " dd = %sE%d", (s[0] == 0) ? "0" : s, exp);
+ G_debug(3, " d = %.18E", d);
if (sgn_d != 0) {
- G_debug(0, " general position");
- ra = da/d;
- rb = db/d;
- mpf_div(rra, dda, dd);
- G_debug(0, " rra = %sE%d", (s[0]==0)?"0":s, exp);
- G_debug(0, " ra = %.18E", ra);
- s = mpf_get_str(NULL, &exp, 10, 40, rrb);
- G_debug(0, " rrb = %sE%d", (s[0]==0)?"0":s, exp);
- G_debug(0, " rb = %.18E", rb);
- if (sgn_d > 0) {
- return 0;
- return 0;
- return 0;
- return 0;
+ ra = da / d;
+ rb = db / d;
+ mpf_div(rra, dda, dd);
+ G_debug(4, " rra = %sE%d", (s[0] == 0) ? "0" : s, exp);
+ G_debug(4, " ra = %.18E", ra);
+ s = mpf_get_str(NULL, &exp, 10, 40, rrb);
+ G_debug(4, " rrb = %sE%d", (s[0] == 0) ? "0" : s, exp);
+ G_debug(4, " rb = %.18E", rb);
- G_debug(0, " intersection at:");
- G_debug(0, " xx = %.18e", *x1);
- G_debug(0, " x = %.18e", ax1 + ra*(ax2-ax1));
- G_debug(0, " yy = %.18e", *y1);
- G_debug(0, " y = %.18e", ay1 + ra*(ay2-ay1));
- return 1;
+ if (sgn_d > 0) {
+ return 0;
+ return 0;
+ return 0;
+ return 0;
+ G_debug(2, " intersection at:");
+ G_debug(2, " xx = %.18e", *x1);
+ G_debug(2, " x = %.18e", ax1 + ra * (ax2 - ax1));
+ G_debug(2, " yy = %.18e", *y1);
+ G_debug(2, " y = %.18e", ay1 + ra * (ay2 - ay1));
+ return 1;
- G_debug(0, " parallel/collinear...");
+ G_debug(3, " parallel/collinear...");
return -1;
#endif
Modified: grass/branches/develbranch_6/vector/v.buffer2/main.c
--- grass/branches/develbranch_6/vector/v.buffer2/main.c 2008-11-27 21:57:06 UTC (rev 34560)
+++ grass/branches/develbranch_6/vector/v.buffer2/main.c 2008-11-27 22:04:34 UTC (rev 34561)
@@ -1,3 +1,4 @@
* MODULE: v.buffer
@@ -2,7 +3,8 @@
- * AUTHOR(S): Radim Blazek, Rosen Matev
+ * AUTHOR(S): Radim Blazek
+ * Upgraded by Rosen Matev (Google Summer of Code 2008)
* PURPOSE: Vector buffer
- * COPYRIGHT: (C) 2001 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2008 by the GRASS Development Team
@@ -24,96 +26,106 @@
#define PI M_PI
#ifndef MIN
#endif
#ifndef MAX
-#endif
+#endif
-void stop(struct Map_info *In, struct Map_info *Out) {
- Vect_close (In);
+void stop(struct Map_info *In, struct Map_info *Out)
+ Vect_close(In);
- G_message ( _("Rebuilding topology...") );
- Vect_build_partial ( Out, GV_BUILD_NONE);
- Vect_build (Out);
- Vect_close (Out);
+ Vect_build_partial(Out, GV_BUILD_NONE);
+ Vect_build(Out);
+ Vect_close(Out);
/* returns 1 if unit_tolerance is adjusted, 0 otherwise */
-int adjust_tolerance(double *tolerance) {
- double t = 0.999 * ( 1 - cos ( 2 * PI / 8 / 2 ) );
+int adjust_tolerance(double *tolerance)
+ double t = 0.999 * (1 - cos(2 * PI / 8 / 2));
G_debug(2, "Maximum tolerance = %f", t);
if (*tolerance > t) {
- *tolerance = t;
- return 1;
+ *tolerance = t;
+ return 1;
return 0;
-int db_CatValArray_get_value_di(dbCatValArray *cvarr, int cat, double *value) {
+int db_CatValArray_get_value_di(dbCatValArray * cvarr, int cat, double *value)
int t;
int ctype = cvarr->ctype;
int ret;
if (ctype == DB_C_TYPE_INT) {
- ret = db_CatValArray_get_value_int(cvarr, cat, &t);
- if (ret != DB_OK)
- return ret;
- *value = (double)t;
- return DB_OK;
+ ret = db_CatValArray_get_value_int(cvarr, cat, &t);
+ if (ret != DB_OK)
+ return ret;
+ *value = (double)t;
+ return DB_OK;
if (ctype == DB_C_TYPE_DOUBLE) {
- ret = db_CatValArray_get_value_double(cvarr, cat, value);
- return ret;
+ ret = db_CatValArray_get_value_double(cvarr, cat, value);
+ return ret;
return DB_FAILED;
-struct buf_contours {
+struct buf_contours
int inner_count;
struct line_pnts *oPoints;
struct line_pnts **iPoints;
-int point_in_buffer(struct buf_contours *arr_bc, int buffers_count, struct Map_info *Out, double x, double y) {
+int point_in_buffer(struct buf_contours *arr_bc, int buffers_count,
+ double x, double y)
int i, j, ret, flag;
for (i = 0; i < buffers_count; i++) {
- ret = Vect_point_in_poly(x, y, arr_bc[i].oPoints);
- if (ret == 0)
- continue;
- flag = 1;
- for (j = 0; j < arr_bc[i].inner_count; j++) {
- ret = Vect_point_in_poly(x, y, arr_bc[i].iPoints[j]);
- if (ret != 0) { /* inside inner contour */
- flag = 0;
- break;
- if (flag) {
- /* (x,y) is inside outer contour and outside inner contours of arr_bc[i] */
- return 1;
+ ret = Vect_point_in_poly(x, y, arr_bc[i].oPoints);
+ if (ret == 0)
+ continue;
+ flag = 1;
+ for (j = 0; j < arr_bc[i].inner_count; j++) {
+ ret = Vect_point_in_poly(x, y, arr_bc[i].iPoints[j]);
+ if (ret != 0) { /* inside inner contour */
+ flag = 0;
+ break;
+ if (flag) {
+ /* (x,y) is inside outer contour and outside inner contours of arr_bc[i] */
+ return 1;
return 0;
-int main (int argc, char *argv[])
+int main(int argc, char *argv[])
struct Map_info In, Out;
struct line_pnts *Points;
struct line_cats *Cats, *BCats;
char *mapset;
struct GModule *module;
- struct Option *in_opt, *out_opt, *type_opt, *dista_opt, *distb_opt, *angle_opt;
+ struct Option *in_opt, *out_opt, *type_opt, *dista_opt, *distb_opt,
+ *angle_opt;
struct Flag *straight_flag, *nocaps_flag;
struct Option *tol_opt, *bufcol_opt, *scale_opt, *field_opt;
double da, db, dalpha, tolerance, unit_tolerance;
int type;
int i, j, ret, nareas, area, nlines, line;
@@ -122,7 +134,7 @@
struct buf_contours *arr_bc;
int buffers_count;
- /* Attributes if sizecol is used */
+ /* Attributes if sizecol is used */
int nrec, ctype;
struct field_info *Fi;
dbDriver *Driver;
@@ -131,61 +143,66 @@
module = G_define_module();
- module->keywords = _("vector");
- module->description = _("Creates a buffer around features of given type (areas must contain centroid).");
+ module->keywords = _("vector, buffer");
+ module->description =
+ _("Creates a buffer around features of given type (areas must contain centroid).");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
- type_opt = G_define_standard_option(G_OPT_V_TYPE) ;
+ type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,area";
type_opt->answer = "point,line,area";
field_opt = G_define_standard_option(G_OPT_V_FIELD);
dista_opt = G_define_option();
dista_opt->key = "distance";
dista_opt->type = TYPE_DOUBLE;
dista_opt->required = NO;
- dista_opt->description = _("Buffer distance along major axis in map units");
+ dista_opt->description =
+ _("Buffer distance along major axis in map units");
distb_opt = G_define_option();
distb_opt->key = "minordistance";
distb_opt->type = TYPE_DOUBLE;
distb_opt->required = NO;
- distb_opt->description = _("Buffer distance along minor axis in map units");
- distb_opt->guisection = _("Advanced");
+ distb_opt->description =
+ _("Buffer distance along minor axis in map units");
+ distb_opt->guisection = _("Advanced");
angle_opt = G_define_option();
angle_opt->key = "angle";
- angle_opt->type = TYPE_DOUBLE;
+ angle_opt->type = TYPE_DOUBLE;
angle_opt->required = NO;
angle_opt->answer = "0";
angle_opt->description = _("Angle of major axis in degrees");
- angle_opt->guisection = _("Advanced");
+ angle_opt->guisection = _("Advanced");
bufcol_opt = G_define_option();
bufcol_opt->key = "bufcol";
bufcol_opt->type = TYPE_STRING;
bufcol_opt->required = NO;
- bufcol_opt->description = _("Attribute column to use for buffer distances");
- bufcol_opt->guisection = _("Advanced");
+ bufcol_opt->description =
+ _("Attribute column to use for buffer distances");
+ bufcol_opt->guisection = _("Advanced");
scale_opt = G_define_option();
scale_opt->key = "scale";
scale_opt->type = TYPE_DOUBLE;
scale_opt->required = NO;
scale_opt->answer = "1.0";
scale_opt->description = _("Scaling factor for attribute column values");
- scale_opt->guisection = _("Advanced");
+ scale_opt->guisection = _("Advanced");
tol_opt = G_define_option();
tol_opt->key = "tolerance";
tol_opt->type = TYPE_DOUBLE;
tol_opt->required = NO;
tol_opt->answer = "0.01";
- tol_opt->guisection = _("Advanced");
- tol_opt->description = _("Maximum distance between theoretical arc and polygon segments as multiple of buffer");
+ tol_opt->guisection = _("Advanced");
+ tol_opt->description =
+ _("Maximum distance between theoretical arc and polygon segments as multiple of buffer");
straight_flag = G_define_flag();
straight_flag->key = 's';
@@ -196,103 +213,115 @@
nocaps_flag->description = _("Don't make caps at the ends of polylines");
G_gisinit(argv[0]);
- if (G_parser (argc, argv))
- exit(EXIT_FAILURE);
- type = Vect_option_to_types ( type_opt );
- field = atoi( field_opt->answer );
- if ((dista_opt->answer && bufcol_opt->answer) || (!(dista_opt->answer || bufcol_opt->answer)))
- G_fatal_error("Select a buffer distance/minordistance/angle or column, but not both.");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ type = Vect_option_to_types(type_opt);
+ field = atoi(field_opt->answer);
+ if ((dista_opt->answer && bufcol_opt->answer) ||
+ (!(dista_opt->answer || bufcol_opt->answer)))
+ G_fatal_error(_("Select a buffer distance/minordistance/angle "
+ "or column, but not both."));
if (bufcol_opt->answer)
- G_warning(_("The bufcol option may contain bugs during the cleaning "
- "step. If you encounter problems, use the debug "
- "option or clean manually with v.clean tool=break; "
- "v.category step=0; v.extract -d type=area"));
+ G_warning(_("The bufcol option may contain bugs during the cleaning "
+ "step. If you encounter problems, use the debug "
+ "option or clean manually with v.clean tool=break; "
+ "v.category step=0; v.extract -d type=area"));
tolerance = atof(tol_opt->answer);
if (adjust_tolerance(&tolerance))
- G_warning(_("The tolerance was reset to %g."), tolerance);
- scale = atof( scale_opt->answer );
+ G_warning(_("The tolerance was reset to %g"), tolerance);
+ scale = atof(scale_opt->answer);
if (scale <= 0.0)
- G_fatal_error("Illegal scale value");
+ G_fatal_error("Illegal scale value");
if (dista_opt->answer) {
- da = atof(dista_opt->answer);
- if (distb_opt->answer)
- db = atof(distb_opt->answer);
- else
- db = da;
- if (angle_opt->answer)
- dalpha = atof(angle_opt->answer);
- else
- dalpha = 0;
- unit_tolerance = tolerance * MIN(da, db);
- G_message(_("The tolerance in map units = %g"), unit_tolerance);
+ da = atof(dista_opt->answer);
+ if (distb_opt->answer)
+ db = atof(distb_opt->answer);
+ else
+ db = da;
+ if (angle_opt->answer)
+ dalpha = atof(angle_opt->answer);
+ else
+ dalpha = 0;
+ unit_tolerance = tolerance * MIN(da, db);
+ G_message(_("The tolerance in map units = %g"), unit_tolerance);
- Vect_check_input_output_name(in_opt->answer, out_opt->answer, GV_FATAL_EXIT);
+ Vect_check_input_output_name(in_opt->answer, out_opt->answer,
+ GV_FATAL_EXIT);
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
BCats = Vect_new_cats_struct();
/* open input vector */
if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL)
- G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
+ G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
Vect_set_open_level(2);
if (1 > Vect_open_old(&In, in_opt->answer, mapset))
- G_fatal_error(_("Unable to open vector map <%s>"), in_opt->answer);
+ G_fatal_error(_("Unable to open vector map <%s>"), in_opt->answer);
if (0 > Vect_open_new(&Out, out_opt->answer, WITHOUT_Z)) {
- Vect_close(&In);
- G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
+ Vect_close(&In);
+ G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
/* check and load attribute column data */
if (bufcol_opt->answer) {
- db_CatValArray_init ( &cvarr );
- Fi = Vect_get_field(&In, field);
- if ( Fi == NULL )
- G_fatal_error(_("Unable to get layer info for vector map"));
- Driver = db_start_driver_open_database(Fi->driver, Fi->database);
- if (Driver == NULL)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
- /* Note do not check if the column exists in the table because it may be expression */
+ db_CatValArray_init(&cvarr);
- /* TODO: only select values we need instead of all in column */
- nrec = db_select_CatValArray(Driver, Fi->table, Fi->key, bufcol_opt->answer, NULL, &cvarr);
- if (nrec < 0)
- G_fatal_error(_("Unable to select data from table"));
- G_debug(2, "%d records selected from table", nrec);
+ Fi = Vect_get_field(&In, field);
+ if (Fi == NULL)
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ field);
- ctype = cvarr.ctype;
- if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
- G_fatal_error(_("Column type not supported"));
- db_close_database_shutdown_driver(Driver);
- /* Output cats/values list */
- for (i = 0; i < cvarr.n_values; i++) {
- if (ctype == DB_C_TYPE_INT) {
- G_debug(4, "cat = %d val = %d", cvarr.value[i].cat, cvarr.value[i].val.i);
- } else if (ctype == DB_C_TYPE_DOUBLE) {
- G_debug(4, "cat = %d val = %f", cvarr.value[i].cat, cvarr.value[i].val.d);
+ Driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (Driver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ /* Note do not check if the column exists in the table because it may be expression */
+ /* TODO: only select values we need instead of all in column */
+ nrec =
+ db_select_CatValArray(Driver, Fi->table, Fi->key,
+ bufcol_opt->answer, NULL, &cvarr);
+ if (nrec < 0)
+ G_fatal_error(_("Unable to select data from table <%s>"),
+ Fi->table);
+ G_debug(2, "%d records selected from table", nrec);
+ ctype = cvarr.ctype;
+ if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_("Column type not supported"));
+ db_close_database_shutdown_driver(Driver);
+ /* Output cats/values list */
+ for (i = 0; i < cvarr.n_values; i++) {
+ if (ctype == DB_C_TYPE_INT) {
+ G_debug(4, "cat = %d val = %d", cvarr.value[i].cat,
+ cvarr.value[i].val.i);
+ else if (ctype == DB_C_TYPE_DOUBLE) {
+ G_debug(4, "cat = %d val = %f", cvarr.value[i].cat,
+ cvarr.value[i].val.d);
Vect_copy_head_data(&In, &Out);
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
@@ -300,253 +329,274 @@
/* Create buffers' boundaries */
nlines = Vect_get_num_lines(&In);
- nareas = Vect_get_num_areas (&In);
+ nareas = Vect_get_num_areas(&In);
/* TODO: don't allocate so much space */
buffers_count = 0;
- arr_bc = G_malloc((nlines+nareas)*sizeof(struct buf_contours));
+ arr_bc = G_malloc((nlines + nareas) * sizeof(struct buf_contours));
/* Lines (and Points) */
if ((type & GV_POINTS) || (type & GV_LINES)) {
- int ltype;
- G_message(_("Lines buffers... "));
- for (line = 1; line <= nlines; line++) {
- int cat;
- G_debug(2, "line = %d", line);
- G_percent(line, nlines, 2);
+ int ltype;
- ltype = Vect_read_line(&In, Points, Cats, line);
- if (!(ltype & type))
- continue;
+ G_message(_("Lines buffers..."));
+ for (line = 1; line <= nlines; line++) {
+ int cat;
- if (!Vect_cat_get(Cats, field, &cat))
- continue;
+ G_debug(2, "line = %d", line);
+ G_percent(line, nlines, 2);
- if (bufcol_opt->answer) {
- ret = db_CatValArray_get_value_di(&cvarr, cat, &size_val);
- if (ret != DB_OK) {
- G_warning(_("No record for category %d in table <%s>"), cat, Fi->table);
- continue;
- if (size_val < 0.0) {
- G_warning(_("Attribute is of invalid size (%.3f) for category %d"), size_val, cat);
- continue;
- if (size_val == 0.0)
- continue;
- da = size_val * scale;
- db = da;
- dalpha = 0;
- G_debug(2, " dynamic buffer size = %.2f", da);
- G_debug(2, _("The tolerance in map units: %g"), unit_tolerance);
- if (ltype & GV_POINTS) {
- Vect_point_buffer2(Points->x[0], Points->y[0], da, db, dalpha, !(straight_flag->answer), unit_tolerance, &(arr_bc[buffers_count].oPoints));
- arr_bc[buffers_count].iPoints = NULL;
- arr_bc[buffers_count].inner_count = 0;
- buffers_count++;
- else {
- Vect_line_buffer2(Points, da, db, dalpha, !(straight_flag->answer), !(nocaps_flag->answer), unit_tolerance, &(arr_bc[buffers_count].oPoints), &(arr_bc[buffers_count].iPoints), &(arr_bc[buffers_count].inner_count));
- buffers_count++;
+ ltype = Vect_read_line(&In, Points, Cats, line);
+ if (!(ltype & type))
+ continue;
+ if (!Vect_cat_get(Cats, field, &cat))
+ continue;
+ if (bufcol_opt->answer) {
+ ret = db_CatValArray_get_value_di(&cvarr, cat, &size_val);
+ if (ret != DB_OK) {
+ G_warning(_("No record for category %d in table <%s>"),
+ cat, Fi->table);
+ continue;
+ if (size_val < 0.0) {
+ G_warning(_("Attribute is of invalid size (%.3f) for category %d"),
+ size_val, cat);
+ continue;
+ if (size_val == 0.0)
+ continue;
+ da = size_val * scale;
+ db = da;
+ dalpha = 0;
+ G_debug(2, " dynamic buffer size = %.2f", da);
+ G_debug(2, _("The tolerance in map units: %g"),
+ unit_tolerance);
+ if (ltype & GV_POINTS) {
+ Vect_point_buffer2(Points->x[0], Points->y[0], da, db, dalpha,
+ !(straight_flag->answer), unit_tolerance,
+ &(arr_bc[buffers_count].oPoints));
+ arr_bc[buffers_count].iPoints = NULL;
+ arr_bc[buffers_count].inner_count = 0;
+ buffers_count++;
+ else {
+ Vect_line_buffer2(Points, da, db, dalpha,
+ !(nocaps_flag->answer), unit_tolerance,
+ &(arr_bc[buffers_count].oPoints),
+ &(arr_bc[buffers_count].iPoints),
+ &(arr_bc[buffers_count].inner_count));
+ buffers_count++;
/* Areas */
if (type & GV_AREA) {
- int centroid;
- G_message ( _("Areas buffers... "));
- for (area = 1; area <= nareas; area++) {
- int cat;
- G_percent(area, nareas, 2);
- centroid = Vect_get_area_centroid(&In, area);
- if (centroid == 0)
- continue;
- Vect_read_line(&In, NULL, Cats, centroid);
- continue;
- continue;
- continue;
- continue;
- db = da;
- dalpha = 0;
- Vect_area_buffer2(&In, area, da, db, dalpha, !(straight_flag->answer), !(nocaps_flag->answer), unit_tolerance, &(arr_bc[buffers_count].oPoints), &(arr_bc[buffers_count].iPoints), &(arr_bc[buffers_count].inner_count));
- buffers_count++;
+ int centroid;
+ G_message(_("Areas buffers..."));
+ for (area = 1; area <= nareas; area++) {
+ int cat;
+ G_percent(area, nareas, 2);
+ centroid = Vect_get_area_centroid(&In, area);
+ if (centroid == 0)
+ continue;
+ Vect_read_line(&In, NULL, Cats, centroid);
+ continue;
+ cat, Fi->table);
+ continue;
+ size_val, cat);
+ continue;
+ continue;
+ db = da;
+ dalpha = 0;
+ unit_tolerance);
+ Vect_area_buffer2(&In, area, da, db, dalpha,
+ buffers_count++;
/* write all buffer contours */
- Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].oPoints, BCats);
- Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].iPoints[j], BCats);
+ Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].oPoints, BCats);
+ Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].iPoints[j], BCats);
/* Create areas */
/* Break lines */
- G_message (_("Building parts of topology...") );
+ G_message(_("Building parts of topology..."));
Vect_build_partial(&Out, GV_BUILD_BASE);
- G_message(_("Snapping boundaries...") );
- Vect_snap_lines ( &Out, GV_BOUNDARY, 1e-7, NULL);
+ G_message(_("Snapping boundaries..."));
+ Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
- G_message(_( "Breaking boundaries...") );
- Vect_break_lines ( &Out, GV_BOUNDARY, NULL );
+ G_message(_("Breaking boundaries..."));
+ Vect_break_lines(&Out, GV_BOUNDARY, NULL);
- G_message(_( "Removing duplicates...") );
- Vect_remove_duplicates ( &Out, GV_BOUNDARY, NULL );
+ G_message(_("Removing duplicates..."));
+ Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
/* Dangles and bridges don't seem to be necessary if snapping is small enough. */
- G_message ( "Removing dangles..." );
- Vect_remove_dangles ( &Out, GV_BOUNDARY, -1, NULL, stderr );
+ G_message ( "Removing dangles..." );
+ Vect_remove_dangles ( &Out, GV_BOUNDARY, -1, NULL, stderr );
- G_message ( "Removing bridges..." );
- Vect_remove_bridges ( &Out, NULL, stderr );
+ G_message ( "Removing bridges..." );
+ Vect_remove_bridges ( &Out, NULL, stderr );
- G_message(_( "Attaching islands..."));
+ G_message(_("Attaching islands..."));
Vect_build_partial(&Out, GV_BUILD_ATTACH_ISLES);
/* Calculate new centroids for all areas */
- nareas = Vect_get_num_areas ( &Out );
- Areas = (char *) G_calloc ( nareas+1, sizeof(char) );
+ nareas = Vect_get_num_areas(&Out);
+ Areas = (char *)G_calloc(nareas + 1, sizeof(char));
- double x, y;
- G_debug ( 3, "area = %d", area );
+ double x, y;
- if (!Vect_area_alive(&Out, area))
- continue;
- ret = Vect_get_point_in_area(&Out, area, &x, &y);
- if ( ret < 0 ) {
- G_warning (_("Cannot calculate area centroid"));
- continue;
- ret = point_in_buffer(arr_bc, buffers_count, &Out, x, y);
- if (ret) {
- G_debug (3, " -> in buffer");
- Areas[area] = 1;
+ G_debug(3, "area = %d", area);
+ if (!Vect_area_alive(&Out, area))
+ continue;
+ ret = Vect_get_point_in_area(&Out, area, &x, &y);
+ if (ret < 0) {
+ G_warning(_("Cannot calculate area centroid"));
+ continue;
+ ret = point_in_buffer(arr_bc, buffers_count, x, y);
+ if (ret) {
+ G_debug(3, " -> in buffer");
+ Areas[area] = 1;
/* Make a list of boundaries to be deleted (both sides inside) */
nlines = Vect_get_num_lines(&Out);
- G_debug ( 3, "nlines = %d", nlines );
- Lines = (char *) G_calloc ( nlines+1, sizeof(char) );
+ G_debug(3, "nlines = %d", nlines);
+ Lines = (char *)G_calloc(nlines + 1, sizeof(char));
- for ( line = 1; line <= nlines; line++ ) {
- int j, side[2], areas[2];
- G_debug ( 3, "line = %d", line );
- if ( !Vect_line_alive ( &Out, line ) )
- continue;
- Vect_get_line_areas ( &Out, line, &side[0], &side[1] );
- for ( j = 0; j < 2; j++ ) {
- if ( side[j] == 0 ) { /* area/isle not build */
- areas[j] = 0;
- } else if ( side[j] > 0 ) { /* area */
- areas[j] = side[j];
- } else { /* < 0 -> island */
- areas[j] = Vect_get_isle_area ( &Out, abs ( side[j] ) );
- G_debug ( 3, " areas = %d , %d -> Areas = %d, %d", areas[0], areas[1], Areas[areas[0]], Areas[areas[1]] );
- if ( Areas[areas[0]] && Areas[areas[1]] )
- Lines[line] = 1;
+ int j, side[2], areas[2];
+ G_debug(3, "line = %d", line);
+ if (!Vect_line_alive(&Out, line))
+ continue;
+ Vect_get_line_areas(&Out, line, &side[0], &side[1]);
+ for (j = 0; j < 2; j++) {
+ if (side[j] == 0) { /* area/isle not build */
+ areas[j] = 0;
+ else if (side[j] > 0) { /* area */
+ areas[j] = side[j];
+ else { /* < 0 -> island */
+ areas[j] = Vect_get_isle_area(&Out, abs(side[j]));
+ G_debug(3, " areas = %d , %d -> Areas = %d, %d", areas[0], areas[1],
+ Areas[areas[0]], Areas[areas[1]]);
+ if (Areas[areas[0]] && Areas[areas[1]])
+ Lines[line] = 1;
G_free(Areas);
/* Delete boundaries */
- if ( Lines[line] ) {
- G_debug ( 3, " delete line %d", line );
- Vect_delete_line ( &Out, line );
+ if (Lines[line]) {
+ G_debug(3, " delete line %d", line);
+ Vect_delete_line(&Out, line);
- G_free( Lines );
+ G_free(Lines);
/* Create new centroids */
- Vect_reset_cats ( Cats );
- Vect_cat_set (Cats, 1, 1 );
+ Vect_reset_cats(Cats);
+ Vect_cat_set(Cats, 1, 1);
- double x, y;
+ double x, y;
- continue;
- if ( ret < 0 ) {
- continue;
- if (ret) {
- Vect_reset_line(Points);
- Vect_append_point(Points, x, y, 0.);
- Vect_write_line(&Out, GV_CENTROID, Points, Cats);
+ continue;
+ if (ret < 0) {
+ continue;
+ if (ret) {
+ Vect_reset_line(Points);
+ Vect_append_point(Points, x, y, 0.);
+ Vect_write_line(&Out, GV_CENTROID, Points, Cats);
/* free arr_bc[] */
/* will only slow down the module
- for (i = 0; i < buffers_count; i++) {
- Vect_destroy_line_struct(arr_bc[i].oPoints);
- Vect_destroy_line_struct(arr_bc[i].iPoints[j]);
- G_free(arr_bc[i].iPoints);
- G_message(_("Attaching centroids...") );
- Vect_build_partial ( &Out, GV_BUILD_CENTROIDS);
- stop ( &In, &Out );
+ for (i = 0; i < buffers_count; i++) {
+ Vect_destroy_line_struct(arr_bc[i].oPoints);
+ Vect_destroy_line_struct(arr_bc[i].iPoints[j]);
+ G_free(arr_bc[i].iPoints);
+ G_message(_("Attaching centroids..."));
+ Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
+ stop(&In, &Out);
exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/vector/v.buffer2/vlib_buffer.c
--- grass/branches/develbranch_6/vector/v.buffer2/vlib_buffer.c 2008-11-27 21:57:06 UTC (rev 34560)
+++ grass/branches/develbranch_6/vector/v.buffer2/vlib_buffer.c 2008-11-27 22:04:34 UTC (rev 34561)
@@ -1,21 +1,23 @@
/* Functions: ...
-** Author: Radim Blazek, Rosen Matev; July 2008
+ ** Author: Radim Blazek, Rosen Matev; July 2008
#include <stdlib.h>
#include <grass/Vect.h>
#include <grass/gis.h>
+#include <grass/glocale.h>
#include "dgraph.h"
#define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
#ifndef MIN
- #define MIN(X,Y) ((X<Y)?X:Y)
+#define MIN(X,Y) ((X<Y)?X:Y)
#endif
#ifndef MAX
- #define MAX(X,Y) ((X>Y)?X:Y)
-#endif
+#define MAX(X,Y) ((X>Y)?X:Y)
+#endif
#define PI M_PI
#define RIGHT_SIDE 1
#define LEFT_SIDE -1
@@ -23,533 +25,602 @@
#define NON_LOOPED_LINE 0
/* norm_vector() calculates normalized vector form two points */
-static void norm_vector(double x1, double y1, double x2, double y2, double *x, double *y) {
+static void norm_vector(double x1, double y1, double x2, double y2, double *x,
+ double *y)
double dx, dy, l;
- dx = x2 - x1;
- dy = y2 - y1;
+ dx = x2 - x1;
+ dy = y2 - y1;
if ((dx == 0) && (dy == 0)) {
- /* assume that dx == dy == 0, which should give (NaN,NaN) */
- /* without this, very small dx or dy could result in Infinity */
- *x = 0;
- *y = 0;
- return;
+ /* assume that dx == dy == 0, which should give (NaN,NaN) */
+ /* without this, very small dx or dy could result in Infinity */
+ *x = 0;
+ *y = 0;
+ return;
l = LENGTH(dx, dy);
- *x = dx/l;
- *y = dy/l;
+ *x = dx / l;
+ *y = dy / l;
return;
-static void rotate_vector(double x, double y, double cosa, double sina, double *nx, double *ny) {
- *nx = x*cosa - y*sina;
- *ny = x*sina + y*cosa;
- return;
+static void rotate_vector(double x, double y, double cosa, double sina,
+ double *nx, double *ny)
+ *nx = x * cosa - y * sina;
+ *ny = x * sina + y * cosa;
+ return;
-* (x,y) shoud be normalized vector for common transforms; This func transforms (x,y) to a vector corresponding to da, db, dalpha params
-* dalpha is in radians
-static void elliptic_transform(double x, double y, double da, double db, double dalpha, double *nx, double *ny) {
+ * (x,y) shoud be normalized vector for common transforms; This func transforms (x,y) to a vector corresponding to da, db, dalpha params
+ * dalpha is in radians
+static void elliptic_transform(double x, double y, double da, double db,
+ double dalpha, double *nx, double *ny)
double cosa = cos(dalpha);
double sina = sin(dalpha);
-/* double cc = cosa*cosa;
- double ss = sina*sina;
- double t = (da-db)*sina*cosa;
- *nx = (da*cc + db*ss)*x + t*y;
- *ny = (da*ss + db*cc)*y + t*x;
- return;*/
+ /* double cc = cosa*cosa;
+ double ss = sina*sina;
+ double t = (da-db)*sina*cosa;
+ *nx = (da*cc + db*ss)*x + t*y;
+ *ny = (da*ss + db*cc)*y + t*x;
+ return; */
double va, vb;
- va = (x*cosa + y*sina)*da;
- vb = (x*(-sina) + y*cosa)*db;
- *nx = va*cosa + vb*(-sina);
- *ny = va*sina + vb*cosa;
- return;
+ va = (x * cosa + y * sina) * da;
+ vb = (x * (-sina) + y * cosa) * db;
+ *nx = va * cosa + vb * (-sina);
+ *ny = va * sina + vb * cosa;
+ return;
-* vect(x,y) must be normalized
-* gives the tangent point of the tangent to ellpise(da,db,dalpha) parallel to vect(x,y)
-* ellipse center is in (0,0)
-static void elliptic_tangent(double x, double y, double da, double db, double dalpha, double *px, double *py) {
+ * vect(x,y) must be normalized
+ * gives the tangent point of the tangent to ellpise(da,db,dalpha) parallel to vect(x,y)
+ * ellipse center is in (0,0)
+static void elliptic_tangent(double x, double y, double da, double db,
+ double dalpha, double *px, double *py)
double u, v, len;
/* rotate (x,y) -dalpha radians */
rotate_vector(x, y, cosa, -sina, &x, &y);
/*u = (x + da*y/db)/2;
- v = (y - db*x/da)/2;*/
- u = da*da*y;
- v = -db*db*x;
- len = da*db/sqrt(da*da*v*v + db*db*u*u);
+ v = (y - db*x/da)/2; */
+ u = da * da * y;
+ v = -db * db * x;
+ len = da * db / sqrt(da * da * v * v + db * db * u * u);
u *= len;
v *= len;
rotate_vector(u, v, cosa, sina, px, py);
- return;
+ return;
-* !!! This is not line in GRASS' sense. See http://en.wikipedia.org/wiki/Line_%28mathematics%29
-static void line_coefficients(double x1, double y1, double x2, double y2, double *a, double *b, double *c) {
+ * !!! This is not line in GRASS' sense. See http://en.wikipedia.org/wiki/Line_%28mathematics%29
+static void line_coefficients(double x1, double y1, double x2, double y2,
+ double *a, double *b, double *c)
*a = y2 - y1;
*b = x1 - x2;
- *c = x2*y1 - x1*y2;
+ *c = x2 * y1 - x1 * y2;
return;
-* Finds intersection of two straight lines. Returns 0 if the lines are parallel, 1 if they cross,
-* 2 if they are the same line.
-* !!!!!!!!!!!!!!!! FIX THIS TOLLERANCE CONSTANTS BAD (and UGLY) CODE !!!!!!!!!
-static int line_intersection(double a1, double b1, double c1, double a2, double b2, double c2, double *x, double *y) {
+ * Finds intersection of two straight lines. Returns 0 if the lines are parallel, 1 if they cross,
+ * 2 if they are the same line.
+ * !!!!!!!!!!!!!!!! FIX THIS TOLLERANCE CONSTANTS BAD (and UGLY) CODE !!!!!!!!!
+static int line_intersection(double a1, double b1, double c1, double a2,
+ double b2, double c2, double *x, double *y)
double d;
- if (fabs(a2*b1 - a1*b2) == 0) {
- if (fabs(a2*c1 - a1*c2) == 0)
- return 2;
- else
- return 0;
+ if (fabs(a2 * b1 - a1 * b2) == 0) {
+ if (fabs(a2 * c1 - a1 * c2) == 0)
+ return 2;
+ else
+ return 0;
else {
- d = a1*b2 - a2*b1;
- *x = (b1*c2 - b2*c1)/d;
- *y = (c1*a2 - c2*a1)/d;
- return 1;
+ d = a1 * b2 - a2 * b1;
+ *x = (b1 * c2 - b2 * c1) / d;
+ *y = (c1 * a2 - c2 * a1) / d;
+ return 1;
-static double angular_tolerance(double tol, double da, double db) {
+static double angular_tolerance(double tol, double da, double db)
double a = MAX(da, db);
if (tol > a)
- tol = a;
- return 2*acos(1-tol/a);
+ tol = a;
+ return 2 * acos(1 - tol / a);
-* This function generates parallel line (with loops, but not like the old ones).
-* It is not to be used directly for creating buffers.
-* + added elliptical buffers/par.lines support
-* dalpha - direction of elliptical buffer major axis in degrees
-* da - distance along major axis
-* db: distance along minor (perp.) axis
-* side: side >= 0 - right side, side < 0 - left side
-* when (da == db) we have plain distances (old case)
-* round - 1 for round corners, 0 for sharp corners. (tol is used only if round == 1)
-void parallel_line(struct line_pnts *Points, double da, double db, double dalpha, int side, int round, int caps, int looped, double tol, struct line_pnts *nPoints)
+ * This function generates parallel line (with loops, but not like the old ones).
+ * It is not to be used directly for creating buffers.
+ * + added elliptical buffers/par.lines support
+ * dalpha - direction of elliptical buffer major axis in degrees
+ * da - distance along major axis
+ * db: distance along minor (perp.) axis
+ * side: side >= 0 - right side, side < 0 - left side
+ * when (da == db) we have plain distances (old case)
+ * round - 1 for round corners, 0 for sharp corners. (tol is used only if round == 1)
+void parallel_line(struct line_pnts *Points, double da, double db,
+ double dalpha, int side, int round, int caps, int looped,
+ double tol, struct line_pnts *nPoints)
int i, j, res, np;
double *x, *y;
double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
double vx1, vy1, wx1, wy1;
double a0, b0, c0, a1, b1, c1;
double phi1, phi2, delta_phi;
double nsegments, angular_tol, angular_step;
int inner_corner, turns360;
G_debug(3, "parallel_line()");
if (looped && 0) {
- /* start point != end point */
- return;
+ /* start point != end point */
+ return;
Vect_reset_line(nPoints);
if (looped) {
- Vect_append_point(Points, Points->x[1], Points->y[1], Points->z[1]);
+ Vect_append_point(Points, Points->x[1], Points->y[1], Points->z[1]);
np = Points->n_points;
x = Points->x;
y = Points->y;
if ((np == 0) || (np == 1))
- return;
+ return;
if ((da == 0) || (db == 0)) {
- Vect_copy_xyz_to_pnts(nPoints, x, y, NULL, np);
- return;
+ Vect_copy_xyz_to_pnts(nPoints, x, y, NULL, np);
+ return;
- side = (side >= 0)?(1):(-1); /* normalize variable */
- dalpha *= PI/180; /* convert dalpha from degrees to radians */
+ side = (side >= 0) ? (1) : (-1); /* normalize variable */
+ dalpha *= PI / 180; /* convert dalpha from degrees to radians */
angular_tol = angular_tolerance(tol, da, db);
- for (i = 0; i < np-1; i++)
- /* save the old values */
- a0 = a1;
- b0 = b1;
- c0 = c1;
- wx = vx;
- wy = vy;
- norm_vector(x[i], y[i], x[i+1], y[i+1], &tx, &ty);
- if ((tx == 0) && (ty == 0))
- continue;
- elliptic_tangent(side*tx, side*ty, da, db, dalpha, &vx, &vy);
- nx = x[i] + vx;
- ny = y[i] + vy;
- mx = x[i+1] + vx;
- my = y[i+1] + vy;
- line_coefficients(nx, ny, mx, my, &a1, &b1, &c1);
+ for (i = 0; i < np - 1; i++) {
+ /* save the old values */
+ a0 = a1;
+ b0 = b1;
+ c0 = c1;
+ wx = vx;
+ wy = vy;
- if (i == 0) {
- if (!looped)
- Vect_append_point(nPoints, nx, ny, 0);
- continue;
- delta_phi = atan2(ty, tx) - atan2(y[i]-y[i-1], x[i]-x[i-1]);
- if (delta_phi > PI)
- delta_phi -= 2*PI;
- else if (delta_phi <= -PI)
- delta_phi += 2*PI;
- /* now delta_phi is in [-pi;pi] */
- turns360 = (fabs(fabs(delta_phi) - PI) < 1e-15);
- inner_corner = (side*delta_phi <= 0) && (!turns360);
- if ((turns360) && (!(caps && round))) {
- if (caps) {
- norm_vector(0, 0, vx, vy, &tx, &ty);
- elliptic_tangent(side*tx, side*ty, da, db, dalpha, &tx, &ty);
- else {
- tx = 0;
- ty = 0;
- Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
- Vect_append_point(nPoints, nx + tx, ny + ty, 0); /* nx == x[i] + vx, ny == y[i] + vy */
- else if ((!round) || inner_corner) {
- res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
-/* if (res == 0) {
- G_debug(4, "a0=%.18f, b0=%.18f, c0=%.18f, a1=%.18f, b1=%.18f, c1=%.18f", a0, b0, c0, a1, b1, c1);
- G_fatal_error("Two consequtive line segments are parallel, but not on one straight line! This should never happen.");
- return;
- if (res == 1) {
- if (!round)
- Vect_append_point(nPoints, rx, ry, 0);
- else {
-/* d = dig_distance2_point_to_line(rx, ry, 0, x[i-1], y[i-1], 0, x[i], y[i], 0,
- 0, NULL, NULL, NULL, NULL, NULL);
- if (*/
- else {
- /* we should draw elliptical arc for outside corner */
- /* inverse transforms */
- elliptic_transform(wx, wy, 1/da, 1/db, dalpha, &wx1, &wy1);
- elliptic_transform(vx, vy, 1/da, 1/db, dalpha, &vx1, &vy1);
- phi1 = atan2(wy1, wx1);
- phi2 = atan2(vy1, vx1);
- delta_phi = side*(phi2 - phi1);
- /* make delta_phi in [0, 2pi] */
- if (delta_phi < 0)
- nsegments = (int)(delta_phi/angular_tol) + 1;
- angular_step = side*(delta_phi/nsegments);
- for (j = 0; j <= nsegments; j++) {
- elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx, &ty);
- Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
- phi1 += angular_step;
- if ((!looped) && (i == np-2)) {
- Vect_append_point(nPoints, mx, my, 0);
+ norm_vector(x[i], y[i], x[i + 1], y[i + 1], &tx, &ty);
+ if ((tx == 0) && (ty == 0))
+ continue;
+ elliptic_tangent(side * tx, side * ty, da, db, dalpha, &vx, &vy);
+ nx = x[i] + vx;
+ ny = y[i] + vy;
+ mx = x[i + 1] + vx;
+ my = y[i + 1] + vy;
+ line_coefficients(nx, ny, mx, my, &a1, &b1, &c1);
+ if (i == 0) {
+ if (!looped)
+ Vect_append_point(nPoints, nx, ny, 0);
+ continue;
+ delta_phi = atan2(ty, tx) - atan2(y[i] - y[i - 1], x[i] - x[i - 1]);
+ if (delta_phi > PI)
+ delta_phi -= 2 * PI;
+ else if (delta_phi <= -PI)
+ delta_phi += 2 * PI;
+ /* now delta_phi is in [-pi;pi] */
+ turns360 = (fabs(fabs(delta_phi) - PI) < 1e-15);
+ inner_corner = (side * delta_phi <= 0) && (!turns360);
+ if ((turns360) && (!(caps && round))) {
+ if (caps) {
+ norm_vector(0, 0, vx, vy, &tx, &ty);
+ elliptic_tangent(side * tx, side * ty, da, db, dalpha, &tx,
+ &ty);
+ else {
+ tx = 0;
+ ty = 0;
+ Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
+ Vect_append_point(nPoints, nx + tx, ny + ty, 0); /* nx == x[i] + vx, ny == y[i] + vy */
+ else if ((!round) || inner_corner) {
+ res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
+ /* if (res == 0) {
+ G_debug(4, "a0=%.18f, b0=%.18f, c0=%.18f, a1=%.18f, b1=%.18f, c1=%.18f", a0, b0, c0, a1, b1, c1);
+ G_fatal_error("Two consequtive line segments are parallel, but not on one straight line! This should never happen.");
+ return;
+ if (res == 1) {
+ if (!round)
+ Vect_append_point(nPoints, rx, ry, 0);
+ else {
+ /* d = dig_distance2_point_to_line(rx, ry, 0, x[i-1], y[i-1], 0, x[i], y[i], 0,
+ 0, NULL, NULL, NULL, NULL, NULL);
+ if ( */
+ else {
+ /* we should draw elliptical arc for outside corner */
+ /* inverse transforms */
+ elliptic_transform(wx, wy, 1 / da, 1 / db, dalpha, &wx1, &wy1);
+ elliptic_transform(vx, vy, 1 / da, 1 / db, dalpha, &vx1, &vy1);
+ phi1 = atan2(wy1, wx1);
+ phi2 = atan2(vy1, vx1);
+ delta_phi = side * (phi2 - phi1);
+ /* make delta_phi in [0, 2pi] */
+ if (delta_phi < 0)
+ nsegments = (int)(delta_phi / angular_tol) + 1;
+ angular_step = side * (delta_phi / nsegments);
+ for (j = 0; j <= nsegments; j++) {
+ elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx,
+ &ty);
+ Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
+ phi1 += angular_step;
+ if ((!looped) && (i == np - 2)) {
+ Vect_append_point(nPoints, mx, my, 0);
if (looped) {
- Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0], nPoints->z[0]);
+ Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0],
+ nPoints->z[0]);
- Vect_line_prune ( nPoints );
+ Vect_line_prune(nPoints);
if (looped) {
- Vect_line_delete_point(Points, Points->n_points-1);
+ Vect_line_delete_point(Points, Points->n_points - 1);
/* input line must be looped */
-void convolution_line(struct line_pnts *Points, double da, double db, double dalpha, int side, int round, int caps, double tol, struct line_pnts *nPoints)
+void convolution_line(struct line_pnts *Points, double da, double db,
int i, j, res, np;
double *x, *y;
double angle0, angle1;
G_debug(3, "convolution_line() side = %d", side);
x = Points->x;
y = Points->y;
- return;
- if ((x[0] != x[np-1]) || (y[0] != y[np-1])) {
- G_fatal_error("line is not looped");
- return;
+ return;
+ if ((x[0] != x[np - 1]) || (y[0] != y[np - 1])) {
+ G_fatal_error(_("Line is not looped"));
+ return;
- return;
+ return;
- i = np-2;
+ i = np - 2;
angle1 = atan2(ty, tx);
nx = x[i] + vx;
ny = y[i] + vy;
- mx = x[i+1] + vx;
- my = y[i+1] + vy;
if (!round)
- for (i = 0; i <= np-2; i++)
- G_debug(4, "point %d, segment %d-%d", i, i, i+1);
- if (!round) {
- a0 = a1;
- b0 = b1;
- c0 = c1;
- wx = vx;
- wy = vy;
- angle0 = angle1;
- continue;
- angle1 = atan2(ty, tx);
- nx = x[i] + vx;
- ny = y[i] + vy;
- mx = x[i+1] + vx;
- my = y[i+1] + vy;
- if (!round)
- delta_phi = angle1 - angle0;
+ for (i = 0; i <= np - 2; i++) {
+ G_debug(4, "point %d, segment %d-%d", i, i, i + 1);
+ if (!round) {
+ a0 = a1;
+ b0 = b1;
+ c0 = c1;
+ wx = vx;
+ wy = vy;
+ angle0 = angle1;
- /* if <line turns 360> and (<caps> and <not round>) */
- if (turns360 && caps && (!round)) {
- G_debug(4, " append point (c) x=%.16f y=%.16f", x[i] + wx + tx, y[i] + wy + ty);
- G_debug(4, " append point (c) x=%.16f y=%.16f", nx + tx, ny + ty);
- if ((!turns360) && (!round) && (!inner_corner)) {
- if (res == 1) {
- G_debug(4, " append point (o) x=%.16f y=%.16f", rx, ry);
- else if (res == 2) {
- /* no need to append point in this case */
- else
- G_fatal_error("unexpected result of line_intersection() res = %d", res);
- if (round && (!inner_corner) && (!turns360 || caps)) {
- for (j = 1; j <= nsegments-1; j++) {
- G_debug(4, " append point (r) x=%.16f y=%.16f", x[i] + tx, y[i] + ty);
- G_debug(4, " append point (s) x=%.16f y=%.16f", nx, ny);
- G_debug(4, " append point (s) x=%.16f y=%.16f", mx, my);
+ continue;
+ angle1 = atan2(ty, tx);
+ nx = x[i] + vx;
+ ny = y[i] + vy;
+ if (!round)
+ delta_phi = angle1 - angle0;
+ /* if <line turns 360> and (<caps> and <not round>) */
+ if (turns360 && caps && (!round)) {
+ elliptic_tangent(side * tx, side * ty, da, db, dalpha, &tx, &ty);
+ G_debug(4, " append point (c) x=%.16f y=%.16f", x[i] + wx + tx,
+ y[i] + wy + ty);
+ G_debug(4, " append point (c) x=%.16f y=%.16f", nx + tx, ny + ty);
+ if ((!turns360) && (!round) && (!inner_corner)) {
+ if (res == 1) {
+ G_debug(4, " append point (o) x=%.16f y=%.16f", rx, ry);
+ else if (res == 2) {
+ /* no need to append point in this case */
+ else
+ G_fatal_error
+ ("unexpected result of line_intersection() res = %d",
+ res);
+ if (round && (!inner_corner) && (!turns360 || caps)) {
+ for (j = 1; j <= nsegments - 1; j++) {
+ &ty);
+ G_debug(4, " append point (r) x=%.16f y=%.16f", x[i] + tx,
+ y[i] + ty);
+ G_debug(4, " append point (s) x=%.16f y=%.16f", nx, ny);
+ G_debug(4, " append point (s) x=%.16f y=%.16f", mx, my);
/* close the output line */
-/* Vect_line_prune ( nPoints ); */
+ /* Vect_line_prune ( nPoints ); */
-* side: side >= 0 - extracts contour on right side of edge, side < 0 - extracts contour on left side of edge
-* if the extracted contour is the outer contour, it is returned in ccw order
-* else if it is inner contour, it is returned in cw order
-static void extract_contour(struct planar_graph *pg, struct pg_edge *first, int side, int winding, int stop_at_line_end, struct line_pnts *nPoints) {
+ * side: side >= 0 - extracts contour on right side of edge, side < 0 - extracts contour on left side of edge
+ * if the extracted contour is the outer contour, it is returned in ccw order
+ * else if it is inner contour, it is returned in cw order
+static void extract_contour(struct planar_graph *pg, struct pg_edge *first,
+ int side, int winding, int stop_at_line_end,
+ struct line_pnts *nPoints)
int j;
- int v; /* current vertex number */
+ int v; /* current vertex number */
int v0;
- int eside; /* side of the current edge */
- double eangle; /* current edge angle with Ox (according to the current direction) */
- struct pg_vertex *vert; /* current vertex */
- struct pg_vertex *vert0; /* last vertex */
- struct pg_edge *edge; /* current edge; must be edge of vert */
-/* int cs;*/ /* on which side are we turning along the contour */
+ int eside; /* side of the current edge */
+ double eangle; /* current edge angle with Ox (according to the current direction) */
+ struct pg_vertex *vert; /* current vertex */
+ struct pg_vertex *vert0; /* last vertex */
+ struct pg_edge *edge; /* current edge; must be edge of vert */
+ /* int cs; *//* on which side are we turning along the contour */
/* we will always turn right and dont need that one */
double opt_angle, tangle;
int opt_j, opt_side, opt_flag;
- G_debug(3, "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d", first->v1, first->v2, side, stop_at_line_end);
+ G_debug(3,
+ "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d",
+ first->v1, first->v2, side, stop_at_line_end);
edge = first;
if (side >= 0) {
- eside = 1;
- v0 = edge->v1;
- v = edge->v2;
+ eside = 1;
+ v0 = edge->v1;
+ v = edge->v2;
else {
- eside = -1;
- v0 = edge->v2;
- v = edge->v1;
+ eside = -1;
+ v0 = edge->v2;
+ v = edge->v1;
- vert0 = &(pg->v[v0]);
+ vert0 = &(pg->v[v0]);
vert = &(pg->v[v]);
eangle = atan2(vert->y - vert0->y, vert->x - vert0->x);
while (1) {
- Vect_append_point(nPoints, vert0->x, vert0->y, 0);
- G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0, v, eside, edge->v1, edge->v2);
- G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
- /* mark current edge as visited on the appropriate side */
- if (eside == 1) {
- edge->visited_right = 1;
- edge->winding_right = winding;
- else {
- edge->visited_left = 1;
- edge->winding_left = winding;
- opt_flag = 1;
- for (j = 0; j < vert->ecount; j++) {
- /* exclude current edge */
- if (vert->edges[j] != edge) {
- tangle = vert->angles[j] - eangle;
- if (tangle < -PI)
- tangle += 2*PI;
- else if (tangle > PI)
- tangle -= 2*PI;
- /* now tangle is in (-PI, PI) */
- if (opt_flag || (tangle < opt_angle)) {
- opt_j = j;
- opt_side = (vert->edges[j]->v1 == v)?(1):(-1);
- opt_angle = tangle;
- opt_flag = 0;
-// G_debug(4, "ec: opt: side=%d opt_flag=%d opt_angle=%.18f opt_j=%d opt_step=%d", side, opt_flag, opt_angle, opt_j, opt_step);
- /* if line end is reached (no other edges at curr vertex) */
- if (opt_flag) {
- if (stop_at_line_end) {
- G_debug(3, " end has been reached, will stop here");
- break;
- else {
- opt_j = 0; /* the only edge of vert is vert->edges[0] */
- opt_side = -eside; /* go to the other side of the current edge */
- G_debug(3, " end has been reached, turning around");
- /* break condition */
- if ((vert->edges[opt_j] == first) && (opt_side == side))
- break;
- if (opt_side == 1) {
- if (vert->edges[opt_j]->visited_right) {
- G_warning("next edge was visited but it is not the first one !!! breaking loop");
- G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v, (edge->v1 == v)?(edge->v2):(edge->v1), opt_side, vert->edges[opt_j]->v1, vert->edges[opt_j]->v2);
- break;
- else {
- if (vert->edges[opt_j]->visited_left) {
- break;
- edge = vert->edges[opt_j];
- eside = opt_side;
- v0 = v;
- v = (edge->v1 == v)?(edge->v2):(edge->v1);
- vert0 = vert;
- vert = &(pg->v[v]);
- eangle = vert0->angles[opt_j];
+ Vect_append_point(nPoints, vert0->x, vert0->y, 0);
+ G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0,
+ v, eside, edge->v1, edge->v2);
+ G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
+ /* mark current edge as visited on the appropriate side */
+ if (eside == 1) {
+ edge->visited_right = 1;
+ edge->winding_right = winding;
+ else {
+ edge->visited_left = 1;
+ edge->winding_left = winding;
+ opt_flag = 1;
+ for (j = 0; j < vert->ecount; j++) {
+ /* exclude current edge */
+ if (vert->edges[j] != edge) {
+ tangle = vert->angles[j] - eangle;
+ if (tangle < -PI)
+ tangle += 2 * PI;
+ else if (tangle > PI)
+ tangle -= 2 * PI;
+ /* now tangle is in (-PI, PI) */
+ if (opt_flag || (tangle < opt_angle)) {
+ opt_j = j;
+ opt_side = (vert->edges[j]->v1 == v) ? (1) : (-1);
+ opt_angle = tangle;
+ opt_flag = 0;
+ // G_debug(4, "ec: opt: side=%d opt_flag=%d opt_angle=%.18f opt_j=%d opt_step=%d", side, opt_flag, opt_angle, opt_j, opt_step);
+ /* if line end is reached (no other edges at curr vertex) */
+ if (opt_flag) {
+ if (stop_at_line_end) {
+ G_debug(3, " end has been reached, will stop here");
+ break;
+ else {
+ opt_j = 0; /* the only edge of vert is vert->edges[0] */
+ opt_side = -eside; /* go to the other side of the current edge */
+ G_debug(3, " end has been reached, turning around");
+ /* break condition */
+ if ((vert->edges[opt_j] == first) && (opt_side == side))
+ break;
+ if (opt_side == 1) {
+ if (vert->edges[opt_j]->visited_right) {
+ G_warning(_("Next edge was visited but it is not the first one !!! breaking loop"));
+ G_debug(4,
+ "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d",
+ v, (edge->v1 == v) ? (edge->v2) : (edge->v1),
+ opt_side, vert->edges[opt_j]->v1,
+ vert->edges[opt_j]->v2);
+ break;
+ else {
+ if (vert->edges[opt_j]->visited_left) {
+ G_debug(4,
+ break;
+ edge = vert->edges[opt_j];
+ eside = opt_side;
+ v0 = v;
+ v = (edge->v1 == v) ? (edge->v2) : (edge->v1);
+ vert0 = vert;
+ vert = &(pg->v[v]);
+ eangle = vert0->angles[opt_j];
Vect_append_point(nPoints, vert->x, vert->y, 0);
G_debug(4, "ec: append point x=%.18f y=%.18f", vert->x, vert->y);
@@ -558,455 +629,540 @@
-* This function extracts the outer contour of a (self crossing) line.
-* It can generate left/right contour if none of the line ends are in a loop.
-* If one or both of them is in a loop, then there's only one contour
-* side: side > 0 - right contour, side < 0 - left contour, side = 0 - outer contour
-* if side != 0 and there's only one contour, the function returns it
-* TODO: Implement side != 0 feature;
-void extract_outer_contour(struct planar_graph *pg, int side, struct line_pnts *nPoints) {
+ * This function extracts the outer contour of a (self crossing) line.
+ * It can generate left/right contour if none of the line ends are in a loop.
+ * If one or both of them is in a loop, then there's only one contour
+ * side: side > 0 - right contour, side < 0 - left contour, side = 0 - outer contour
+ * if side != 0 and there's only one contour, the function returns it
+ * TODO: Implement side != 0 feature;
+void extract_outer_contour(struct planar_graph *pg, int side,
int i;
int flag;
int v;
double min_x, min_angle;
G_debug(3, "extract_outer_contour()");
if (side != 0) {
- G_fatal_error(" side != 0 feature not implemented");
- return;
+ G_fatal_error(_("side != 0 feature not implemented"));
+ return;
/* find a line segment which is on the outer contour */
flag = 1;
for (i = 0; i < pg->vcount; i++) {
- if (flag || (pg->v[i].x < min_x)) {
- v = i;
- min_x = pg->v[i].x;
- flag = 0;
+ if (flag || (pg->v[i].x < min_x)) {
+ v = i;
+ min_x = pg->v[i].x;
+ flag = 0;
vert = &(pg->v[v]);
flag = 1;
for (i = 0; i < vert->ecount; i++) {
- if (flag || (vert->angles[i] < min_angle)) {
- edge = vert->edges[i];
- min_angle = vert->angles[i];
- flag = 0;
+ if (flag || (vert->angles[i] < min_angle)) {
+ edge = vert->edges[i];
+ min_angle = vert->angles[i];
+ flag = 0;
/* the winding on the outer contour is 0 */
- extract_contour(pg, edge, (edge->v1 == v)?RIGHT_SIDE:LEFT_SIDE, 0, 0, nPoints);
+ extract_contour(pg, edge, (edge->v1 == v) ? RIGHT_SIDE : LEFT_SIDE, 0, 0,
+ nPoints);
return;
-* Extracts contours which are not visited.
-* IMPORTANT: the outer contour must be visited (you should call extract_outer_contour() to do that),
-* so that extract_inner_contour() doesn't return it
-* returns: 0 when there are no more inner contours; otherwise, 1
-int extract_inner_contour(struct planar_graph *pg, int *winding, struct line_pnts *nPoints) {
+ * Extracts contours which are not visited.
+ * IMPORTANT: the outer contour must be visited (you should call extract_outer_contour() to do that),
+ * so that extract_inner_contour() doesn't return it
+ * returns: 0 when there are no more inner contours; otherwise, 1
+int extract_inner_contour(struct planar_graph *pg, int *winding,
int i, w;
G_debug(3, "extract_inner_contour()");
for (i = 0; i < pg->ecount; i++) {
- edge = &(pg->e[i]);
- if (edge->visited_left) {
- if (!(pg->e[i].visited_right)) {
- w = edge->winding_left - 1;
- extract_contour(pg, &(pg->e[i]), RIGHT_SIDE, w, 0, nPoints);
- *winding = w;
- return 1;
- else {
- if (pg->e[i].visited_right) {
- w = edge->winding_right + 1;
- extract_contour(pg, &(pg->e[i]), LEFT_SIDE, w, 0, nPoints);
- *winding = w;
- return 1;
+ edge = &(pg->e[i]);
+ if (edge->visited_left) {
+ if (!(pg->e[i].visited_right)) {
+ w = edge->winding_left - 1;
+ extract_contour(pg, &(pg->e[i]), RIGHT_SIDE, w, 0, nPoints);
+ *winding = w;
+ return 1;
+ else {
+ if (pg->e[i].visited_right) {
+ w = edge->winding_right + 1;
+ extract_contour(pg, &(pg->e[i]), LEFT_SIDE, w, 0, nPoints);
+ *winding = w;
+ return 1;
return 0;
/* point_in_buf - test if point px,py is in d buffer of Points
-** dalpha is in degrees
-** returns: 1 in buffer
-** 0 not in buffer
-int point_in_buf(struct line_pnts *Points, double px, double py, double da, double db, double dalpha) {
+ ** dalpha is in degrees
+ ** returns: 1 in buffer
+ ** 0 not in buffer
+int point_in_buf(struct line_pnts *Points, double px, double py, double da,
+ double db, double dalpha)
int i, np;
double cx, cy;
double delta, delta_k, k;
double vx, vy, wx, wy, mx, my, nx, ny;
double len, tx, ty, d, da2;
G_debug(3, "point_in_buf()");
- da2 = da*da;
- for (i = 0; i < np-1; i++) {
- vx = Points->x[i];
- vy = Points->y[i];
- wx = Points->x[i+1];
- wy = Points->y[i+1];
- if (da != db) {
- mx = wx - vx;
- my = wy - vy;
- len = LENGTH(mx, my);
- elliptic_tangent(mx/len, my/len, da, db, dalpha, &cx, &cy);
- delta = mx*cy - my*cx;
- delta_k = (px-vx)*cy - (py-vy)*cx;
- k = delta_k/delta;
-/* G_debug(4, "k = %g, k1 = %g", k, (mx * (px - vx) + my * (py - vy)) / (mx * mx + my * my)); */
- if (k <= 0) {
- nx = vx;
- ny = vy;
- else if (k >= 1) {
- nx = wx;
- ny = wy;
- else {
- nx = vx + k*mx;
- ny = vy + k*my;
- /* inverse transform */
- elliptic_transform(px - nx, py - ny, 1/da, 1/db, dalpha, &tx, &ty);
- d = dig_distance2_point_to_line(nx + tx, ny + ty, 0, vx, vy, 0, wx, wy, 0,
+ da2 = da * da;
+ vx = Points->x[i];
+ vy = Points->y[i];
+ wx = Points->x[i + 1];
+ wy = Points->y[i + 1];
-/* G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny)));*/
- if (d <= 1) {
- //G_debug(1, "d=%g", d);
- return 1;
- else {
- d = dig_distance2_point_to_line(px, py, 0, vx, vy, 0, wx, wy, 0,
-/* G_debug(4, "sqrt(d) = %g", sqrt(d));*/
- if (d <= da2) {
- return 1;
+ if (da != db) {
+ mx = wx - vx;
+ my = wy - vy;
+ len = LENGTH(mx, my);
+ elliptic_tangent(mx / len, my / len, da, db, dalpha, &cx, &cy);
+ delta = mx * cy - my * cx;
+ delta_k = (px - vx) * cy - (py - vy) * cx;
+ k = delta_k / delta;
+ /* G_debug(4, "k = %g, k1 = %g", k, (mx * (px - vx) + my * (py - vy)) / (mx * mx + my * my)); */
+ if (k <= 0) {
+ nx = vx;
+ ny = vy;
+ else if (k >= 1) {
+ nx = wx;
+ ny = wy;
+ else {
+ nx = vx + k * mx;
+ ny = vy + k * my;
+ /* inverse transform */
+ elliptic_transform(px - nx, py - ny, 1 / da, 1 / db, dalpha, &tx,
+ &ty);
+ d = dig_distance2_point_to_line(nx + tx, ny + ty, 0, vx, vy, 0,
+ wx, wy, 0, 0, NULL, NULL, NULL,
+ NULL, NULL);
+ /* G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny))); */
+ if (d <= 1) {
+ //G_debug(1, "d=%g", d);
+ return 1;
+ else {
+ d = dig_distance2_point_to_line(px, py, 0, vx, vy, 0, wx, wy, 0,
+ /* G_debug(4, "sqrt(d) = %g", sqrt(d)); */
+ if (d <= da2) {
+ return 1;
return 0;
/* returns 0 for ccw, non-zero for cw
-int get_polygon_orientation(const double *x, const double *y, int n) {
- double x1,y1,x2,y2;
+int get_polygon_orientation(const double *x, const double *y, int n)
+ double x1, y1, x2, y2;
double area;
- x2 = x[n-1];
- y2 = y[n-1];
+ x2 = x[n - 1];
+ y2 = y[n - 1];
area = 0;
- while (--n >= 0)
- x1 = x2;
- y1 = y2;
+ while (--n >= 0) {
+ x1 = x2;
+ y1 = y2;
- x2 = *x++;
- y2 = *y++;
+ x2 = *x++;
+ y2 = *y++;
- area += (y2+y1)*(x2-x1);
+ area += (y2 + y1) * (x2 - x1);
return (area > 0);
/* internal */
-void add_line_to_array(struct line_pnts *Points, struct line_pnts ***arrPoints, int *count, int *allocated, int more) {
+void add_line_to_array(struct line_pnts *Points,
+ struct line_pnts ***arrPoints, int *count,
+ int *allocated, int more)
if (*allocated == *count) {
- *allocated += more;
- *arrPoints = G_realloc(*arrPoints, (*allocated)*sizeof(struct line_pnts *));
+ *allocated += more;
+ *arrPoints =
+ G_realloc(*arrPoints, (*allocated) * sizeof(struct line_pnts *));
(*arrPoints)[*count] = Points;
(*count)++;
return;
-void destroy_lines_array(struct line_pnts **arr, int count) {
+void destroy_lines_array(struct line_pnts **arr, int count)
int i;
for (i = 0; i < count; i++)
- Vect_destroy_line_struct(arr[i]);
+ Vect_destroy_line_struct(arr[i]);
G_free(arr);
/* area_outer and area_isles[i] must be closed non self-intersecting lines
side: 0 - auto, 1 - right, -1 left
-void buffer_lines(struct line_pnts *area_outer, struct line_pnts **area_isles, int isles_count, int side, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+void buffer_lines(struct line_pnts *area_outer, struct line_pnts **area_isles,
+ int isles_count, int side, double da, double db,
+ double dalpha, int round, int caps, double tol,
+ struct line_pnts **oPoints, struct line_pnts ***iPoints,
+ int *inner_count)
struct planar_graph *pg2;
struct line_pnts *sPoints, *cPoints;
struct line_pnts **arrPoints;
int i, count = 0;
int res, winding;
int auto_side;
int more = 8;
int allocated = 0;
double px, py;
G_debug(3, "buffer_lines()");
auto_side = (side == 0);
/* initializations */
sPoints = Vect_new_line_struct();
cPoints = Vect_new_line_struct();
arrPoints = NULL;
/* outer contour */
G_debug(3, " processing outer contour");
*oPoints = Vect_new_line_struct();
if (auto_side)
- side = get_polygon_orientation(area_outer->x, area_outer->y, area_outer->n_points-1)?LEFT_SIDE:RIGHT_SIDE;
- convolution_line(area_outer, da, db, dalpha, side, round, caps, tol, sPoints);
+ side =
+ get_polygon_orientation(area_outer->x, area_outer->y,
+ area_outer->n_points -
+ 1) ? LEFT_SIDE : RIGHT_SIDE;
+ convolution_line(area_outer, da, db, dalpha, side, round, caps, tol,
+ sPoints);
pg2 = pg_create(sPoints);
extract_outer_contour(pg2, 0, *oPoints);
res = extract_inner_contour(pg2, &winding, cPoints);
while (res != 0) {
- if (winding == 0) {
- if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
- if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
- G_fatal_error("Vect_get_point_in_poly() failed.");
- if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
- add_line_to_array(cPoints, &arrPoints, &count, &allocated, more);
- cPoints = Vect_new_line_struct();
- res = extract_inner_contour(pg2, &winding, cPoints);
+ if (winding == 0) {
+ if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
+ if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
+ G_fatal_error(_("Vect_get_point_in_poly() failed"));
+ if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
+ add_line_to_array(cPoints, &arrPoints, &count, &allocated,
+ more);
+ cPoints = Vect_new_line_struct();
+ res = extract_inner_contour(pg2, &winding, cPoints);
pg_destroy_struct(pg2);
/* inner contours */
G_debug(3, " processing inner contours");
for (i = 0; i < isles_count; i++) {
- if (auto_side)
- side = get_polygon_orientation(area_isles[i]->x, area_isles[i]->y, area_isles[i]->n_points-1)?RIGHT_SIDE:LEFT_SIDE;
- convolution_line(area_isles[i], da, db, dalpha, side, round, caps, tol, sPoints);
- pg2 = pg_create(sPoints);
- extract_outer_contour(pg2, 0, cPoints);
- while (res != 0) {
- if (winding == -1) {
- /* we need to check if the area is in the buffer.
- I've simplfied convolution_line(), so that it runs faster,
- however that leads to ocasional problems */
- if (Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_isles[i])) {
- if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
- pg_destroy_struct(pg2);
+ if (auto_side)
+ side =
+ get_polygon_orientation(area_isles[i]->x, area_isles[i]->y,
+ area_isles[i]->n_points -
+ 1) ? RIGHT_SIDE : LEFT_SIDE;
+ convolution_line(area_isles[i], da, db, dalpha, side, round, caps,
+ tol, sPoints);
+ pg2 = pg_create(sPoints);
+ extract_outer_contour(pg2, 0, cPoints);
+ while (res != 0) {
+ if (winding == -1) {
+ /* we need to check if the area is in the buffer.
+ I've simplfied convolution_line(), so that it runs faster,
+ however that leads to ocasional problems */
+ if (Vect_point_in_poly
+ (cPoints->x[0], cPoints->y[0], area_isles[i])) {
+ if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
+ &allocated, more);
+ pg_destroy_struct(pg2);
- arrPoints = G_realloc(arrPoints, count*sizeof(struct line_pnts *));
+ arrPoints = G_realloc(arrPoints, count * sizeof(struct line_pnts *));
*inner_count = count;
*iPoints = arrPoints;
Vect_destroy_line_struct(sPoints);
Vect_destroy_line_struct(cPoints);
G_debug(3, "buffer_lines() ... done");
return;
- \fn void Vect_line_buffer(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
- \brief Creates buffer around the line Points.
- \param InPoints input line
- \param da distance along major axis
- \param da distance along minor axis
- \param dalpha angle between 0x and major axis
- \param round make corners round
- \param caps add caps at line ends
- \param tol maximum distance between theoretical arc and output segments
- \param oPoints output polygon outer border (ccw order)
- \param inner_count number of holes
- \param iPoints array of output polygon's holes (cw order)
-void Vect_line_buffer2(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+ \fn void Vect_line_buffer(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+ \brief Creates buffer around the line Points.
+ \param InPoints input line
+ \param da distance along major axis
+ \param da distance along minor axis
+ \param dalpha angle between 0x and major axis
+ \param round make corners round
+ \param caps add caps at line ends
+ \param tol maximum distance between theoretical arc and output segments
+ \param oPoints output polygon outer border (ccw order)
+ \param inner_count number of holes
+ \param iPoints array of output polygon's holes (cw order)
+void Vect_line_buffer2(struct line_pnts *Points, double da, double db,
+ struct line_pnts ***iPoints, int *inner_count)
struct planar_graph *pg;
struct line_pnts *tPoints, *outer;
struct line_pnts **isles;
int isles_count = 0;
int res, winding;
int more = 8;
int isles_allocated = 0;
G_debug(2, "Vect_line_buffer()");
tPoints = Vect_new_line_struct();
isles = NULL;
pg = pg_create(Points);
/* outer contour */
outer = Vect_new_line_struct();
extract_outer_contour(pg, 0, outer);
res = extract_inner_contour(pg, &winding, tPoints);
while (res != 0) {
- add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated, more);
- tPoints = Vect_new_line_struct();
- res = extract_inner_contour(pg, &winding, tPoints);
+ add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated,
+ more);
+ tPoints = Vect_new_line_struct();
+ res = extract_inner_contour(pg, &winding, tPoints);
- buffer_lines(outer, isles, isles_count, RIGHT_SIDE, da, db, dalpha, round, caps, tol, oPoints, iPoints, inner_count);
+ buffer_lines(outer, isles, isles_count, RIGHT_SIDE, da, db, dalpha, round,
+ caps, tol, oPoints, iPoints, inner_count);
Vect_destroy_line_struct(tPoints);
Vect_destroy_line_struct(outer);
destroy_lines_array(isles, isles_count);
pg_destroy_struct(pg);
return;
-void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
+void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db,
int i, isle;
int more = 8;
G_debug(2, "Vect_area_buffer()");
isles_count = Vect_get_area_num_isles(Map, area);
isles_allocated = isles_count;
- isles = G_malloc(isles_allocated*sizeof(struct line_pnts *));
+ isles = G_malloc(isles_allocated * sizeof(struct line_pnts *));
/* outer contour */
Vect_get_area_points(Map, area, outer);
Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
- isle = Vect_get_area_isle(Map, area, i);
- Vect_get_isle_points(Map, isle, tPoints);
- /* Check if the isle is big enough */
- if (Vect_line_length(tPoints) < 2*PI*max)
- continue;
- Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0], tPoints->z[0]);
+ isle = Vect_get_area_isle(Map, area, i);
+ Vect_get_isle_points(Map, isle, tPoints);
+ /* Check if the isle is big enough */
+ if (Vect_line_length(tPoints) < 2*PI*max)
+ continue;
+ Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0],
+ tPoints->z[0]);
+ more);
- buffer_lines(outer, isles, isles_count, 0, da, db, dalpha, round, caps, tol, oPoints, iPoints, inner_count);
+ buffer_lines(outer, isles, isles_count, 0, da, db, dalpha, round, caps,
+ tol, oPoints, iPoints, inner_count);
return;
- \fn void Vect_point_buffer(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints) {
- \brief Creates buffer around the point (px,py).
- \param px input point x-coordinate
- \param py input point y-coordinate
- \param nPoints output polygon outer border (ccw order)
-void Vect_point_buffer2(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints) {
+ \fn void Vect_point_buffer(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints) {
+ \brief Creates buffer around the point (px,py).
+ \param px input point x-coordinate
+ \param py input point y-coordinate
+ \param nPoints output polygon outer border (ccw order)
+void Vect_point_buffer2(double px, double py, double da, double db,
+ double dalpha, int round, double tol,
+ struct line_pnts **oPoints)
double tx, ty;
double angular_tol, angular_step, phi1;
int j, nsegments;
G_debug(2, "Vect_point_buffer()");
if (round || (!round)) {
- angular_tol = angular_tolerance(tol, da, db);
- nsegments = (int)(2*PI/angular_tol) + 1;
- angular_step = 2*PI/nsegments;
- phi1 = 0;
- for (j = 0; j < nsegments; j++) {
- Vect_append_point(*oPoints, px + tx, py + ty, 0);
+ angular_tol = angular_tolerance(tol, da, db);
+ nsegments = (int)(2 * PI / angular_tol) + 1;
+ angular_step = 2 * PI / nsegments;
+ phi1 = 0;
+ for (j = 0; j < nsegments; j++) {
+ &ty);
+ Vect_append_point(*oPoints, px + tx, py + ty, 0);
else {
- Vect_append_point(*oPoints, (*oPoints)->x[0], (*oPoints)->y[0], (*oPoints)->z[0]);
+ Vect_append_point(*oPoints, (*oPoints)->x[0], (*oPoints)->y[0],
+ (*oPoints)->z[0]);
return;
- \fn void Vect_line_parallel2 ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
- struct line_pnts *OutPoints )
- \brief Create parrallel line
- \param distance
- \param tolerance maximum distance between theoretical arc and polygon segments
- \param rm_end remove end points falling into distance
- \param OutPoints output line
-void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db, double dalpha, int side, int round, double tol, struct line_pnts *OutPoints )
+ \fn void Vect_line_parallel2 ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
+ struct line_pnts *OutPoints )
+ \brief Create parrallel line
+ \param distance
+ \param tolerance maximum distance between theoretical arc and polygon segments
+ \param rm_end remove end points falling into distance
+ \param OutPoints output line
+void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db,
+ double dalpha, int side, int round, double tol,
+ struct line_pnts *OutPoints)
- G_debug(2, "Vect_line_parallel(): npoints = %d, da = %f, db = %f, dalpha = %f, side = %d, round_corners = %d, tol = %f",
- InPoints->n_points, da, db, dalpha, side, round, tol);
+ G_debug(2, "Vect_line_parallel(): npoints = %d, da = %f, "
+ "db = %f, dalpha = %f, side = %d, round_corners = %d, tol = %f",
+ InPoints->n_points, da, db, dalpha, side, round, tol);
- parallel_line(InPoints, da, db, dalpha, side, round, 1, NON_LOOPED_LINE, tol, OutPoints);
-/* if (!loops)
- clean_parallel(OutPoints, InPoints, distance, rm_end);
+ parallel_line(InPoints, da, db, dalpha, side, round, 1, NON_LOOPED_LINE,
+ tol, OutPoints);
+ /* if (!loops)
+ clean_parallel(OutPoints, InPoints, distance, rm_end);
return;
