[GRASS-SVN] r34564 - grass/trunk/vector/v.buffer2
svn_grass at osgeo.org
Thu Nov 27 17:59:17 EST 2008
Author: martinl
Date: 2008-11-27 17:59:17 -0500 (Thu, 27 Nov 2008)
New Revision: 34564
grass/trunk/vector/v.buffer2/main.c
v.buffer: message cosmetics
(merge from devbr6, r34563)
Modified: grass/trunk/vector/v.buffer2/main.c
--- grass/trunk/vector/v.buffer2/main.c 2008-11-27 22:55:46 UTC (rev 34563)
+++ grass/trunk/vector/v.buffer2/main.c 2008-11-27 22:59:17 UTC (rev 34564)
@@ -254,7 +254,7 @@
dalpha = 0;
unit_tolerance = tolerance * MIN(da, db);
- G_message(_("The tolerance in map units = %g"), unit_tolerance);
+ G_verbose_message(_("The tolerance in map units = %g"), unit_tolerance);
Vect_check_input_output_name(in_opt->answer, out_opt->answer,
@@ -338,7 +338,8 @@
if ((type & GV_POINTS) || (type & GV_LINES)) {
int ltype;
- G_message(_("Lines buffers..."));
+ if (nlines > 0)
+ G_message(_("Buffering lines..."));
for (line = 1; line <= nlines; line++) {
int cat;
@@ -404,7 +405,8 @@
if (type & GV_AREA) {
int centroid;
- G_message(_("Areas buffers..."));
+ if (nareas > 0)
+ G_message(_("Buffering areas..."));
for (area = 1; area <= nareas; area++) {
int cat;
@@ -464,7 +466,7 @@
/* Create areas */
/* Break lines */
- G_message(_("Building parts of topology..."));
+ G_verbose_message(_("Building parts of topology..."));
Vect_build_partial(&Out, GV_BUILD_BASE);
G_message(_("Snapping boundaries..."));
