[GRASS-SVN] r34582 - in grass/branches/develbranch_6/raster: .
r.watershed/front r.watershed2/front
svn_grass at osgeo.org
Fri Nov 28 01:26:53 EST 2008
Author: hamish
Date: 2008-11-28 01:26:53 -0500 (Fri, 28 Nov 2008)
New Revision: 34582
grass/branches/develbranch_6/raster/Makefile
grass/branches/develbranch_6/raster/r.watershed/front/main.c
grass/branches/develbranch_6/raster/r.watershed2/front/main.c
reactivate r.watershed, being merge of v2 into v1.
minimize diff between r.watershed and r.watershed2 (front dir)
rename flag variabes to something meaningful
Modified: grass/branches/develbranch_6/raster/Makefile
--- grass/branches/develbranch_6/raster/Makefile 2008-11-28 00:51:24 UTC (rev 34581)
+++ grass/branches/develbranch_6/raster/Makefile 2008-11-28 06:26:53 UTC (rev 34582)
@@ -107,7 +107,7 @@
r.volume \
r.walk \
r.water.outlet \
- r.watershed2 \
+ r.watershed \
r.what \
r.what.color \
simwe \
Modified: grass/branches/develbranch_6/raster/r.watershed/front/main.c
--- grass/branches/develbranch_6/raster/r.watershed/front/main.c 2008-11-28 00:51:24 UTC (rev 34581)
+++ grass/branches/develbranch_6/raster/r.watershed/front/main.c 2008-11-28 06:26:53 UTC (rev 34582)
@@ -39,8 +39,8 @@
struct Option *opt13;
struct Option *opt14;
struct Option *opt15;
- struct Flag *flag1;
- struct Flag *flag2;
+ struct Flag *flag_flow;
+ struct Flag *flag_seg;
struct GModule *module;
G_gisinit(argv[0]);
@@ -176,19 +176,20 @@
opt15->gisprompt = "new,cell,raster";
opt15->guisection = _("Output_options");
- flag1 = G_define_flag();
- flag1->key = 'm';
- flag1->description =
+ flag_flow = G_define_flag();
+ flag_flow->key = '4';
+ flag_flow->description =
+ _("Allow only horizontal and vertical flow of water");
+ flag_seg = G_define_flag();
+ flag_seg->key = 'm';
+ flag_seg->description =
_("Enable disk swap memory option: Operation is slow");
- flag2 = G_define_flag();
- flag2->key = '4';
- flag2->description =
- _("Allow only horizontal and vertical flow of water");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* Check option combinations */
/* Check for some output map */
@@ -225,12 +226,12 @@
/* Build command line */
sprintf(command, "%s/etc/", G_gisbase());
- if (flag1->answer)
+ if (flag_seg->answer)
strcat(command, "r.watershed.seg");
else
strcat(command, "r.watershed.ram");
- if (flag2->answer)
+ if (flag_flow->answer)
strcat(command, " -4");
if (opt1->answer) {
@@ -334,7 +335,7 @@
strcat(command, "\"");
- G_debug(1, "Mode: %s", flag1->answer ? "Segmented" : "All in RAM");
+ G_debug(1, "Mode: %s", flag_seg->answer ? "Segmented" : "All in RAM");
G_debug(1, "Running: %s", command);
ret = system(command);
@@ -344,32 +345,32 @@
if (opt8->answer)
write_hist(opt8->answer,
"Watershed accumulation: overland flow that traverses each cell",
- opt1->answer, flag1->answer);
+ opt1->answer, flag_seg->answer);
if (opt9->answer)
write_hist(opt9->answer,
"Watershed drainage direction (divided by 45deg)",
if (opt10->answer)
write_hist(opt10->answer,
- "Watershed basins", opt1->answer, flag1->answer);
+ "Watershed basins", opt1->answer, flag_seg->answer);
if (opt11->answer)
write_hist(opt11->answer,
- "Watershed stream segments", opt1->answer, flag1->answer);
+ "Watershed stream segments", opt1->answer, flag_seg->answer);
if (opt12->answer)
write_hist(opt12->answer,
- "Watershed half-basins", opt1->answer, flag1->answer);
+ "Watershed half-basins", opt1->answer, flag_seg->answer);
if (opt13->answer)
write_hist(opt13->answer,
"Watershed visualization map (filtered accumulation map)",
if (opt14->answer)
write_hist(opt14->answer,
"Watershed slope length and steepness (LS) factor",
if (opt15->answer)
write_hist(opt15->answer,
"Watershed slope steepness (S) factor",
exit(ret);
Modified: grass/branches/develbranch_6/raster/r.watershed2/front/main.c
--- grass/branches/develbranch_6/raster/r.watershed2/front/main.c 2008-11-28 00:51:24 UTC (rev 34581)
+++ grass/branches/develbranch_6/raster/r.watershed2/front/main.c 2008-11-28 06:26:53 UTC (rev 34582)
@@ -40,8 +40,8 @@
struct Option *opt16;
G_gisinit(argv[0]);
@@ -73,7 +73,7 @@
opt3->guisection = _("Input_options");
opt4 = G_define_option();
- opt4->key = "disturbed_land";
+ opt4->key = "disturbed.land";
opt4->description =
_("Input map or value: percent of disturbed land, for USLE");
opt4->required = NO;
@@ -100,7 +100,7 @@
opt6->guisection = _("Input_options");
opt7 = G_define_option();
- opt7->key = "max_slope_length";
+ opt7->key = "max.slope.length";
opt7->description =
_("Input value: maximum length of surface flow, for USLE");
opt7->required = NO;
@@ -143,7 +143,7 @@
opt11->guisection = _("Output_options");
opt12 = G_define_option();
- opt12->key = "half_basin";
+ opt12->key = "half.basin";
opt12->description =
_("Output map: each half-basin is given a unique value");
opt12->required = NO;
@@ -161,7 +161,7 @@
opt13->guisection = _("Output_options");
opt14 = G_define_option();
- opt14->key = "length_slope";
+ opt14->key = "length.slope";
opt14->description =
_("Output map: slope length and steepness (LS) factor for USLE");
opt14->required = NO;
@@ -170,34 +170,34 @@
opt14->guisection = _("Output_options");
opt15 = G_define_option();
- opt15->key = "slope_steepness";
+ opt15->key = "slope.steepness";
opt15->description = _("Output map: slope steepness (S) factor for USLE");
opt15->required = NO;
opt15->type = TYPE_STRING;
- opt16 = G_define_option() ;
- opt16->key = "memory";
- opt16->type = TYPE_INTEGER;
- opt16->required = NO;
- opt16->answer = "300"; /* 300MB default value */
- opt16->description = _("Maximum memory to be used with -m flag (in MB)");
+ opt16 = G_define_option() ;
+ opt16->key = "memory";
+ opt16->type = TYPE_INTEGER;
+ opt16->required = NO;
+ opt16->answer = "300"; /* 300MB default value, please keep in sync with r.terraflow */
+ opt16->description = _("Maximum memory to be used with -m flag (in MB)");
- flag1->key = '4';
- flag2->key = 'm';
exit(EXIT_FAILURE);
@@ -234,12 +234,12 @@
strcat(command, "r.watershed2.seg");
else
strcat(command, "r.watershed2.ram");
if (opt1->answer) {
@@ -343,14 +343,14 @@
- if (flag2->answer && opt16->answer) {
+ if (flag_seg->answer && opt16->answer) {
strcat(command, " mb=");
strcat(command, opt16->answer);
@@ -360,32 +360,32 @@
if (opt8->answer)
if (opt9->answer)
if (opt10->answer)
if (opt11->answer)
if (opt12->answer)
if (opt13->answer)
if (opt14->answer)
if (opt15->answer)
exit(ret);
