[GRASS-SVN] r34586 - in grass/branches/develbranch_6/raster: r.watershed/ram r.watershed2/ram
Fri Nov 28 01:58:13 EST 2008
Author: hamish
Date: 2008-11-28 01:58:12 -0500 (Fri, 28 Nov 2008)
New Revision: 34586
   grass/branches/develbranch_6/raster/r.watershed/ram/Gwater.h
   grass/branches/develbranch_6/raster/r.watershed2/ram/Gwater.h
more precise constants; merge between r.watershed1,2
Modified: grass/branches/develbranch_6/raster/r.watershed/ram/Gwater.h
--- grass/branches/develbranch_6/raster/r.watershed/ram/Gwater.h	2008-11-28 06:33:29 UTC (rev 34585)
+++ grass/branches/develbranch_6/raster/r.watershed/ram/Gwater.h	2008-11-28 06:58:12 UTC (rev 34586)
@@ -21,8 +21,8 @@
 #define NOMASK			1
 #define MIN_SLOPE		.00001
 #define MIN_GRADIENT_DEGREES	1
-#define DEG_TO_RAD		.017453293	/* pi / 180 */
-#define METER_TO_FOOT		3.281
+#define DEG_TO_RAD		((2 * M_PI) / 360.)
+#define METER_TO_FOOT		(1 / 0.3048)
 #define MAX_BYTES		2000000
 #define PAGE_BLOCK		512
 #define RITE			1
Modified: grass/branches/develbranch_6/raster/r.watershed2/ram/Gwater.h
--- grass/branches/develbranch_6/raster/r.watershed2/ram/Gwater.h	2008-11-28 06:33:29 UTC (rev 34585)
+++ grass/branches/develbranch_6/raster/r.watershed2/ram/Gwater.h	2008-11-28 06:58:12 UTC (rev 34586)
@@ -3,9 +3,9 @@
 /* program to map out drainage basin structure  */
-/* this one uses the A * search algorithm   	*/
-/* written by Chuck Ehlschlaeger        	*/
-/* last modified 03/26/91           		*/
+/* this one uses the A * search algorithm       */
+/* written by Chuck Ehlschlaeger                */
+/* last modified 03/26/91                       */
 #include <math.h>
 #include <grass/gis.h>
 #include "ramseg.h"
@@ -21,8 +21,8 @@
 #define NOMASK			1
 #define RITE			1
@@ -33,10 +33,9 @@
 #define TST(a)		(fprintf (stderr, "%e\n", (double) (a)))
 #define POINT       struct points
-POINT
-    SHORT       r, c, downr, downc;
-    int		nxt;
+POINT {
+    SHORT r, c, downr, downc;
+    int nxt;
 #ifdef MAIN
@@ -53,76 +52,96 @@
 #define NEXTDCVAR
 #endif
-GLOBAL struct Cell_head		window;
+GLOBAL struct Cell_head window;
-GLOBAL int 		*heap_index, heap_size;
-GLOBAL int	first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
-GLOBAL SHORT    nrows, ncols;
-GLOBAL double   half_res, diag, max_length, dep_slope;
-GLOBAL int	bas_thres, tot_parts;
-GLOBAL FLAG     *worked, *in_list, *s_b, *swale;
-GLOBAL RAMSEG   dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
-GLOBAL RAMSEG	r_h_seg, dep_seg;
-GLOBAL RAMSEG   slp_seg, s_l_seg, s_g_seg, l_s_seg;
-GLOBAL POINT	*astar_pts;
-GLOBAL CELL     *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep;
-GLOBAL CELL	*ril_buf;
-GLOBAL int	ril_fd;
-GLOBAL double   *s_l, *s_g, *l_s;
-GLOBAL CELL	one, zero;
-GLOBAL double	ril_value, dzero;
-GLOBAL SHORT    sides;
-GLOBAL SHORT	drain[3][3]	DRAINVAR;
-GLOBAL SHORT	updrain[3][3]	UPDRAINVAR;
-GLOBAL SHORT	nextdr[8]	NEXTDRVAR;
-GLOBAL SHORT	nextdc[8]	NEXTDCVAR;
-GLOBAL char     ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX], *pit_mapset;
-GLOBAL char     run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
-GLOBAL char	ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX], *dep_mapset;
-GLOBAL char	*this_mapset;
-GLOBAL char     seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
-GLOBAL char     ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
-GLOBAL char     wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX], dis_name[GNAME_MAX];
-GLOBAL char     ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
-GLOBAL char     wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
-GLOBAL char     bas_flag, seg_flag, haf_flag, er_flag;
-GLOBAL char	st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
-GLOBAL FILE     *fp;
+GLOBAL int *heap_index, heap_size;
+GLOBAL int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
+GLOBAL SHORT nrows, ncols;
+GLOBAL double half_res, diag, max_length, dep_slope;
+GLOBAL int bas_thres, tot_parts;
+GLOBAL FLAG *worked, *in_list, *s_b, *swale;
+GLOBAL RAMSEG dis_seg, alt_seg, wat_seg, asp_seg, bas_seg, haf_seg;
+GLOBAL RAMSEG r_h_seg, dep_seg;
+GLOBAL RAMSEG slp_seg, s_l_seg, s_g_seg, l_s_seg;
+GLOBAL POINT *astar_pts;
+GLOBAL CELL *dis, *alt, *wat, *asp, *bas, *haf, *r_h, *dep;
+GLOBAL CELL *ril_buf;
+GLOBAL int ril_fd;
+GLOBAL double *s_l, *s_g, *l_s;
+GLOBAL CELL one, zero;
+GLOBAL double ril_value, dzero;
+GLOBAL SHORT sides;
+GLOBAL SHORT drain[3][3] DRAINVAR;
+GLOBAL SHORT updrain[3][3] UPDRAINVAR;
+GLOBAL SHORT nextdr[8] NEXTDRVAR;
+GLOBAL SHORT nextdc[8] NEXTDCVAR;
+GLOBAL char ele_name[GNAME_MAX], *ele_mapset, pit_name[GNAME_MAX],
+    *pit_mapset;
+GLOBAL char run_name[GNAME_MAX], *run_mapset, ob_name[GNAME_MAX], *ob_mapset;
+GLOBAL char ril_name[GNAME_MAX], *ril_mapset, dep_name[GNAME_MAX],
+    *dep_mapset;
+GLOBAL char *this_mapset;
+GLOBAL char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX],
+    thr_name[8];
+GLOBAL char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX],
+    sg_name[GNAME_MAX];
+GLOBAL char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX],
+    dis_name[GNAME_MAX];
+GLOBAL char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
+GLOBAL char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
+GLOBAL char bas_flag, seg_flag, haf_flag, er_flag;
+GLOBAL char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
+GLOBAL FILE *fp;
 /* close_maps.c */
 int close_maps(void);
 /* close_maps2.c */
 int close_array_seg(void);
 /* def_basin.c */
 CELL def_basin(int, int, CELL, double, CELL);
 /* do_astar.c */
 int do_astar(void);
 int add_pt(SHORT, SHORT, SHORT, SHORT, CELL, CELL);
 int drop_pt(void);
 double get_slope(SHORT, SHORT, SHORT, SHORT, CELL, CELL);
 int replace(SHORT, SHORT, SHORT, SHORT);
 /* do_cum.c */
 int do_cum(void);
 /* find_pour.c */
 int find_pourpts(void);
 /* haf_side.c */
 int haf_basin_side(SHORT, SHORT, SHORT);
 /* init_vars.c */
 int init_vars(int, char *[]);
 int do_legal(char *);
 char *do_exist(char *);
 /* no_stream.c */
 int no_stream(int, int, CELL, double, CELL);
 /* over_cells.c */
 int overland_cells(int, int, CELL, CELL, CELL *);
 /* ramseg.c */
 int size_array(int *, int, int);
 /* sg_factor.c */
 int sg_factor(void);
 int len_slp_equ(double, double, double, int, int);
 /* slope_len.c */
 int slope_length(SHORT, SHORT, SHORT, SHORT);
 /* split_str.c */
-CELL split_stream(int, int, int [], int [], int, CELL, double, CELL);
+CELL split_stream(int, int, int[], int[], int, CELL, double, CELL);
 /* usage.c */
 void usage(char *);
