[GRASS-SVN] r34596 - grass/branches/develbranch_6/lib/vector/Vlib
svn_grass at osgeo.org
Fri Nov 28 05:35:49 EST 2008
Author: marisn
Date: 2008-11-28 05:35:49 -0500 (Fri, 28 Nov 2008)
New Revision: 34596
grass/branches/develbranch_6/lib/vector/Vlib/map.c
Add documentation notice Vect_copy_tables about copying nonexisting tables
Modified: grass/branches/develbranch_6/lib/vector/Vlib/map.c
--- grass/branches/develbranch_6/lib/vector/Vlib/map.c 2008-11-28 10:23:42 UTC (rev 34595)
+++ grass/branches/develbranch_6/lib/vector/Vlib/map.c 2008-11-28 10:35:49 UTC (rev 34596)
@@ -554,6 +554,8 @@
\brief Copy tables linked to vector map.
All if field = 0, or table defined by given field if field > 0
+ Notice, that if input map has no tables defined, it will copy
+ nothing and return 0 (success).
\param[in] In input vector map
\param[out] Out output vector map
@@ -568,9 +570,10 @@
struct field_info *Fi, *Fin;
dbDriver *driver;
- G_debug(2, "Vect_copy_tables()");
+ n = Vect_get_num_dblinks(In);
- n = Vect_get_num_dblinks(In);
+ G_debug(2, "Vect_copy_tables(): copying %d tables",n);
type = GV_1TABLE;
if (n > 1)
type = GV_MTABLE;
