[GRASS-SVN] r34602 - in grass/trunk: include lib/vector/Vlib vector/v.buffer2 vector/v.parallel2
Fri Nov 28 17:12:43 EST 2008
Author: martinl
Date: 2008-11-28 17:12:43 -0500 (Fri, 28 Nov 2008)
New Revision: 34602
Added:
   grass/trunk/lib/vector/Vlib/buffer2.c
   grass/trunk/lib/vector/Vlib/dgraph.c
   grass/trunk/lib/vector/Vlib/dgraph.h
   grass/trunk/lib/vector/Vlib/e_intersect.c
   grass/trunk/lib/vector/Vlib/e_intersect.h
Removed:
   grass/trunk/vector/v.buffer2/dgraph.c
   grass/trunk/vector/v.buffer2/dgraph.h
   grass/trunk/vector/v.buffer2/e_intersect.c
   grass/trunk/vector/v.buffer2/e_intersect.h
   grass/trunk/vector/v.buffer2/vlib_buffer.c
   grass/trunk/vector/v.parallel2/dgraph.c
   grass/trunk/vector/v.parallel2/dgraph.h
   grass/trunk/vector/v.parallel2/e_intersect.c
   grass/trunk/vector/v.parallel2/e_intersect.h
   grass/trunk/vector/v.parallel2/vlib_buffer.c
   grass/trunk/include/Vect.h
   grass/trunk/lib/vector/Vlib/buffer.c
Vlib: Vect_line_buffe2(), Vect_area_buffer2(), Vect_point_buffer2() and
      Vect_line_parallel() moved from v.buffer2 and v.parallel2 to
      vector library (buffer2.c)
      (merge from devbr6, r34601)
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/include/Vect.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -35,8 +35,23 @@
 int Vect_line_box(struct line_pnts *, BOUND_BOX *);
 void Vect_line_parallel(struct line_pnts *, double, double, int,
 			struct line_pnts *);
+void Vect_line_parallel2(struct line_pnts *, double, double,
+			 double, int, int, double,
+			 struct line_pnts *);
 void Vect_line_buffer(struct line_pnts *, double, double, struct line_pnts *);
+void Vect_line_buffer2(struct line_pnts *, double, double,
+		       struct line_pnts **,
+		       struct line_pnts ***, int *);
+void Vect_area_buffer2(struct Map_info *, int, double, double,
+void Vect_point_buffer2(double, double, double, double,
+			double, int, double,
+			struct line_pnts **);
 /* Categories */
 struct line_cats *Vect_new_cats_struct(void);
 int Vect_cat_set(struct line_cats *, int, int);
Modified: grass/trunk/lib/vector/Vlib/buffer.c
--- grass/trunk/lib/vector/Vlib/buffer.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/lib/vector/Vlib/buffer.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,7 +1,7 @@
    \file buffer.c
-   \brief Vector library - nearest, adjust_line, parallel_line
+   \brief Vector library - nearest, adjust, parallel lines
    Higher level functions for reading/writing/manipulating vectors.
Copied: grass/trunk/lib/vector/Vlib/buffer2.c (from rev 34601, grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c)
--- grass/trunk/lib/vector/Vlib/buffer2.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/buffer2.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -0,0 +1,1203 @@
+   \file buffer2.c
+   Higher level functions for reading/writing/manipulating vectors.
+   (C) 2001-2008 by the GRASS Development Team
+   This program is free software under the
+   GNU General Public License (>=v2).
+   Read the file COPYING that comes with GRASS
+   for details.
+   \author Original author Radim Blazek (see buffer.c)
+   \author Rewritten by Rosen Matev (Google Summer of Code 2008)
+   \date 2008
+#include <stdlib.h>
+#include <grass/Vect.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "dgraph.h"
+#define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
+#ifndef MIN
+#define MIN(X,Y) ((X<Y)?X:Y)
+#endif
+#ifndef MAX
+#define MAX(X,Y) ((X>Y)?X:Y)
+#endif
+#define PI M_PI
+#define RIGHT_SIDE 1
+#define LEFT_SIDE -1
+#define LOOPED_LINE 1
+#define NON_LOOPED_LINE 0
+/* norm_vector() calculates normalized vector form two points */
+static void norm_vector(double x1, double y1, double x2, double y2, double *x,
+			double *y)
+    double dx, dy, l;
+    dx = x2 - x1;
+    dy = y2 - y1;
+    if ((dx == 0) && (dy == 0)) {
+	/* assume that dx == dy == 0, which should give (NaN,NaN) */
+	/* without this, very small dx or dy could result in Infinity */
+	*x = 0;
+	*y = 0;
+	return;
+    l = LENGTH(dx, dy);
+    *x = dx / l;
+    *y = dy / l;
+    return;
+static void rotate_vector(double x, double y, double cosa, double sina,
+			  double *nx, double *ny)
+    *nx = x * cosa - y * sina;
+    *ny = x * sina + y * cosa;
+    return;
+ * (x,y) shoud be normalized vector for common transforms; This func transforms (x,y) to a vector corresponding to da, db, dalpha params
+ * dalpha is in radians
+static void elliptic_transform(double x, double y, double da, double db,
+			       double dalpha, double *nx, double *ny)
+    double cosa = cos(dalpha);
+    double sina = sin(dalpha);
+    /*    double cc = cosa*cosa;
+       double ss = sina*sina;
+       double t = (da-db)*sina*cosa;
+       *nx = (da*cc + db*ss)*x + t*y;
+       *ny = (da*ss + db*cc)*y + t*x;
+       return; */
+    double va, vb;
+    va = (x * cosa + y * sina) * da;
+    vb = (x * (-sina) + y * cosa) * db;
+    *nx = va * cosa + vb * (-sina);
+    *ny = va * sina + vb * cosa;
+    return;
+ * vect(x,y) must be normalized
+ * gives the tangent point of the tangent to ellpise(da,db,dalpha) parallel to vect(x,y)
+ * ellipse center is in (0,0)
+static void elliptic_tangent(double x, double y, double da, double db,
+			     double dalpha, double *px, double *py)
+    double u, v, len;
+    /* rotate (x,y) -dalpha radians */
+    rotate_vector(x, y, cosa, -sina, &x, &y);
+    /*u = (x + da*y/db)/2;
+       v = (y - db*x/da)/2; */
+    u = da * da * y;
+    v = -db * db * x;
+    len = da * db / sqrt(da * da * v * v + db * db * u * u);
+    u *= len;
+    v *= len;
+    rotate_vector(u, v, cosa, sina, px, py);
+    return;
+ * !!! This is not line in GRASS' sense. See http://en.wikipedia.org/wiki/Line_%28mathematics%29
+static void line_coefficients(double x1, double y1, double x2, double y2,
+			      double *a, double *b, double *c)
+    *a = y2 - y1;
+    *b = x1 - x2;
+    *c = x2 * y1 - x1 * y2;
+    return;
+ * Finds intersection of two straight lines. Returns 0 if the lines are parallel, 1 if they cross,
+ * 2 if they are the same line.
+ * !!!!!!!!!!!!!!!! FIX THIS TOLLERANCE CONSTANTS BAD (and UGLY) CODE !!!!!!!!!
+static int line_intersection(double a1, double b1, double c1, double a2,
+			     double b2, double c2, double *x, double *y)
+    double d;
+    if (fabs(a2 * b1 - a1 * b2) == 0) {
+	if (fabs(a2 * c1 - a1 * c2) == 0)
+	    return 2;
+	else
+	    return 0;
+    else {
+	d = a1 * b2 - a2 * b1;
+	*x = (b1 * c2 - b2 * c1) / d;
+	*y = (c1 * a2 - c2 * a1) / d;
+	return 1;
+static double angular_tolerance(double tol, double da, double db)
+    double a = MAX(da, db);
+    if (tol > a)
+	tol = a;
+    return 2 * acos(1 - tol / a);
+ * This function generates parallel line (with loops, but not like the old ones).
+ * It is not to be used directly for creating buffers.
+ * + added elliptical buffers/par.lines support
+ * dalpha - direction of elliptical buffer major axis in degrees
+ * da - distance along major axis
+ * db: distance along minor (perp.) axis
+ * side: side >= 0 - right side, side < 0 - left side
+ * when (da == db) we have plain distances (old case)
+ * round - 1 for round corners, 0 for sharp corners. (tol is used only if round == 1)
+static void parallel_line(struct line_pnts *Points, double da, double db,
+			  double dalpha, int side, int round, int caps, int looped,
+			  double tol, struct line_pnts *nPoints)
+    int i, j, res, np;
+    double *x, *y;
+    double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
+    double vx1, vy1, wx1, wy1;
+    double a0, b0, c0, a1, b1, c1;
+    double phi1, phi2, delta_phi;
+    double nsegments, angular_tol, angular_step;
+    int inner_corner, turns360;
+    G_debug(3, "parallel_line()");
+    if (looped && 0) {
+	/* start point != end point */
+	return;
+    Vect_reset_line(nPoints);
+    if (looped) {
+	Vect_append_point(Points, Points->x[1], Points->y[1], Points->z[1]);
+    np = Points->n_points;
+    x = Points->x;
+    y = Points->y;
+    if ((np == 0) || (np == 1))
+	return;
+    if ((da == 0) || (db == 0)) {
+	Vect_copy_xyz_to_pnts(nPoints, x, y, NULL, np);
+	return;
+    side = (side >= 0) ? (1) : (-1);	/* normalize variable */
+    dalpha *= PI / 180;		/* convert dalpha from degrees to radians */
+    angular_tol = angular_tolerance(tol, da, db);
+    for (i = 0; i < np - 1; i++) {
+	/* save the old values */
+	a0 = a1;
+	b0 = b1;
+	c0 = c1;
+	wx = vx;
+	wy = vy;
+	norm_vector(x[i], y[i], x[i + 1], y[i + 1], &tx, &ty);
+	if ((tx == 0) && (ty == 0))
+	    continue;
+	elliptic_tangent(side * tx, side * ty, da, db, dalpha, &vx, &vy);
+	nx = x[i] + vx;
+	ny = y[i] + vy;
+	mx = x[i + 1] + vx;
+	my = y[i + 1] + vy;
+	line_coefficients(nx, ny, mx, my, &a1, &b1, &c1);
+	if (i == 0) {
+	    if (!looped)
+		Vect_append_point(nPoints, nx, ny, 0);
+	    continue;
+	delta_phi = atan2(ty, tx) - atan2(y[i] - y[i - 1], x[i] - x[i - 1]);
+	if (delta_phi > PI)
+	    delta_phi -= 2 * PI;
+	else if (delta_phi <= -PI)
+	    delta_phi += 2 * PI;
+	/* now delta_phi is in [-pi;pi] */
+	turns360 = (fabs(fabs(delta_phi) - PI) < 1e-15);
+	inner_corner = (side * delta_phi <= 0) && (!turns360);
+	if ((turns360) && (!(caps && round))) {
+	    if (caps) {
+		norm_vector(0, 0, vx, vy, &tx, &ty);
+		elliptic_tangent(side * tx, side * ty, da, db, dalpha, &tx,
+				 &ty);
+	    else {
+		tx = 0;
+		ty = 0;
+	    Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
+	    Vect_append_point(nPoints, nx + tx, ny + ty, 0);	/* nx == x[i] + vx, ny == y[i] + vy */
+	else if ((!round) || inner_corner) {
+	    res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
+	    /*                if (res == 0) {
+	       G_debug(4, "a0=%.18f, b0=%.18f, c0=%.18f, a1=%.18f, b1=%.18f, c1=%.18f", a0, b0, c0, a1, b1, c1);
+	       G_fatal_error("Two consequtive line segments are parallel, but not on one straight line! This should never happen.");
+	       return;
+	    if (res == 1) {
+		if (!round)
+		    Vect_append_point(nPoints, rx, ry, 0);
+		else {
+		    /*                    d = dig_distance2_point_to_line(rx, ry, 0, x[i-1], y[i-1], 0, x[i], y[i], 0,
+		       0, NULL, NULL, NULL, NULL, NULL);
+		       if ( */
+	else {
+	    /* we should draw elliptical arc for outside corner */
+	    /* inverse transforms */
+	    elliptic_transform(wx, wy, 1 / da, 1 / db, dalpha, &wx1, &wy1);
+	    elliptic_transform(vx, vy, 1 / da, 1 / db, dalpha, &vx1, &vy1);
+	    phi1 = atan2(wy1, wx1);
+	    phi2 = atan2(vy1, vx1);
+	    delta_phi = side * (phi2 - phi1);
+	    /* make delta_phi in [0, 2pi] */
+	    if (delta_phi < 0)
+	    nsegments = (int)(delta_phi / angular_tol) + 1;
+	    angular_step = side * (delta_phi / nsegments);
+	    for (j = 0; j <= nsegments; j++) {
+		elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx,
+				   &ty);
+		Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
+		phi1 += angular_step;
+	if ((!looped) && (i == np - 2)) {
+	    Vect_append_point(nPoints, mx, my, 0);
+    if (looped) {
+	Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0],
+			  nPoints->z[0]);
+    Vect_line_prune(nPoints);
+    if (looped) {
+	Vect_line_delete_point(Points, Points->n_points - 1);
+/* input line must be looped */
+static void convolution_line(struct line_pnts *Points, double da, double db,
+    double *x, *y;
+    double angle0, angle1;
+    G_debug(3, "convolution_line() side = %d", side);
+    x = Points->x;
+    y = Points->y;
+	return;
+    if ((x[0] != x[np - 1]) || (y[0] != y[np - 1])) {
+	G_fatal_error(_("Line is not looped"));
+	return;
+	return;
+    i = np - 2;
+    angle1 = atan2(ty, tx);
+    nx = x[i] + vx;
+    ny = y[i] + vy;
+    if (!round)
+    for (i = 0; i <= np - 2; i++) {
+	G_debug(4, "point %d, segment %d-%d", i, i, i + 1);
+	if (!round) {
+	    a0 = a1;
+	    b0 = b1;
+	    c0 = c1;
+	wx = vx;
+	wy = vy;
+	angle0 = angle1;
+	    continue;
+	nx = x[i] + vx;
+	ny = y[i] + vy;
+	if (!round)
+	delta_phi = angle1 - angle0;
+	/* if <line turns 360> and (<caps> and <not round>) */
+	if (turns360 && caps && (!round)) {
+	    elliptic_tangent(side * tx, side * ty, da, db, dalpha, &tx, &ty);
+	    G_debug(4, " append point (c) x=%.16f y=%.16f", x[i] + wx + tx,
+		    y[i] + wy + ty);
+	    G_debug(4, " append point (c) x=%.16f y=%.16f", nx + tx, ny + ty);
+	if ((!turns360) && (!round) && (!inner_corner)) {
+	    if (res == 1) {
+		G_debug(4, " append point (o) x=%.16f y=%.16f", rx, ry);
+	    else if (res == 2) {
+		/* no need to append point in this case */
+	    else
+		G_fatal_error
+		    ("unexpected result of line_intersection() res = %d",
+		     res);
+	if (round && (!inner_corner) && (!turns360 || caps)) {
+	    for (j = 1; j <= nsegments - 1; j++) {
+				   &ty);
+		G_debug(4, " append point (r) x=%.16f y=%.16f", x[i] + tx,
+			y[i] + ty);
+	G_debug(4, " append point (s) x=%.16f y=%.16f", nx, ny);
+	G_debug(4, " append point (s) x=%.16f y=%.16f", mx, my);
+    /* close the output line */
+    Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0], nPoints->z[0]);
+    /*    Vect_line_prune ( nPoints ); */
+ * side: side >= 0 - extracts contour on right side of edge, side < 0 - extracts contour on left side of edge
+ * if the extracted contour is the outer contour, it is returned in ccw order
+ * else if it is inner contour, it is returned in cw order
+static void extract_contour(struct planar_graph *pg, struct pg_edge *first,
+			    int side, int winding, int stop_at_line_end,
+			    struct line_pnts *nPoints)
+    int j;
+    int v;			/* current vertex number */
+    int v0;
+    int eside;			/* side of the current edge */
+    double eangle;		/* current edge angle with Ox (according to the current direction) */
+    struct pg_vertex *vert;	/* current vertex */
+    struct pg_vertex *vert0;	/* last vertex */
+    struct pg_edge *edge;	/* current edge; must be edge of vert */
+    /*    int cs; *//* on which side are we turning along the contour */
+    /* we will always turn right and dont need that one */
+    double opt_angle, tangle;
+    int opt_j, opt_side, opt_flag;
+    G_debug(3,
+	    "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d",
+	    first->v1, first->v2, side, stop_at_line_end);
+    edge = first;
+    if (side >= 0) {
+	eside = 1;
+	v0 = edge->v1;
+	v = edge->v2;
+    else {
+	eside = -1;
+	v0 = edge->v2;
+	v = edge->v1;
+    vert0 = &(pg->v[v0]);
+    vert = &(pg->v[v]);
+    eangle = atan2(vert->y - vert0->y, vert->x - vert0->x);
+    while (1) {
+	Vect_append_point(nPoints, vert0->x, vert0->y, 0);
+	G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0,
+		v, eside, edge->v1, edge->v2);
+	G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
+	/* mark current edge as visited on the appropriate side */
+	if (eside == 1) {
+	    edge->visited_right = 1;
+	    edge->winding_right = winding;
+	else {
+	    edge->visited_left = 1;
+	    edge->winding_left = winding;
+	opt_flag = 1;
+	for (j = 0; j < vert->ecount; j++) {
+	    /* exclude current edge */
+	    if (vert->edges[j] != edge) {
+		tangle = vert->angles[j] - eangle;
+		if (tangle < -PI)
+		    tangle += 2 * PI;
+		else if (tangle > PI)
+		    tangle -= 2 * PI;
+		/* now tangle is in (-PI, PI) */
+		if (opt_flag || (tangle < opt_angle)) {
+		    opt_j = j;
+		    opt_side = (vert->edges[j]->v1 == v) ? (1) : (-1);
+		    opt_angle = tangle;
+		    opt_flag = 0;
+	//        G_debug(4, "ec: opt: side=%d opt_flag=%d opt_angle=%.18f opt_j=%d opt_step=%d", side, opt_flag, opt_angle, opt_j, opt_step);
+	/* if line end is reached (no other edges at curr vertex) */
+	if (opt_flag) {
+	    if (stop_at_line_end) {
+		G_debug(3, "    end has been reached, will stop here");
+		break;
+	    else {
+		opt_j = 0;	/* the only edge of vert is vert->edges[0] */
+		opt_side = -eside;	/* go to the other side of the current edge */
+		G_debug(3, "    end has been reached, turning around");
+	/* break condition */
+	if ((vert->edges[opt_j] == first) && (opt_side == side))
+	    break;
+	if (opt_side == 1) {
+	    if (vert->edges[opt_j]->visited_right) {
+		G_warning(_("Next edge was visited but it is not the first one !!! breaking loop"));
+		G_debug(4,
+			"ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d",
+			v, (edge->v1 == v) ? (edge->v2) : (edge->v1),
+			opt_side, vert->edges[opt_j]->v1,
+			vert->edges[opt_j]->v2);
+		break;
+	else {
+	    if (vert->edges[opt_j]->visited_left) {
+		G_debug(4,
+		break;
+	edge = vert->edges[opt_j];
+	eside = opt_side;
+	v0 = v;
+	v = (edge->v1 == v) ? (edge->v2) : (edge->v1);
+	vert0 = vert;
+	eangle = vert0->angles[opt_j];
+    Vect_append_point(nPoints, vert->x, vert->y, 0);
+    G_debug(4, "ec: append point x=%.18f y=%.18f", vert->x, vert->y);
+    return;
+ * This function extracts the outer contour of a (self crossing) line.
+ * It can generate left/right contour if none of the line ends are in a loop.
+ * If one or both of them is in a loop, then there's only one contour
+ * side: side > 0 - right contour, side < 0 - left contour, side = 0 - outer contour
+ *       if side != 0 and there's only one contour, the function returns it
+ * TODO: Implement side != 0 feature;
+static void extract_outer_contour(struct planar_graph *pg, int side,
+    int i;
+    int flag;
+    int v;
+    double min_x, min_angle;
+    G_debug(3, "extract_outer_contour()");
+    if (side != 0) {
+	G_fatal_error(_("side != 0 feature not implemented"));
+	return;
+    /* find a line segment which is on the outer contour */
+    flag = 1;
+    for (i = 0; i < pg->vcount; i++) {
+	if (flag || (pg->v[i].x < min_x)) {
+	    v = i;
+	    min_x = pg->v[i].x;
+	    flag = 0;
+    flag = 1;
+    for (i = 0; i < vert->ecount; i++) {
+	if (flag || (vert->angles[i] < min_angle)) {
+	    edge = vert->edges[i];
+	    min_angle = vert->angles[i];
+	    flag = 0;
+    /* the winding on the outer contour is 0 */
+    extract_contour(pg, edge, (edge->v1 == v) ? RIGHT_SIDE : LEFT_SIDE, 0, 0,
+		    nPoints);
+    return;
+ * Extracts contours which are not visited.
+ * IMPORTANT: the outer contour must be visited (you should call extract_outer_contour() to do that),
+ *            so that extract_inner_contour() doesn't return it
+ * returns: 0 when there are no more inner contours; otherwise, 1
+static int extract_inner_contour(struct planar_graph *pg, int *winding,
+    int i, w;
+    G_debug(3, "extract_inner_contour()");
+    for (i = 0; i < pg->ecount; i++) {
+	edge = &(pg->e[i]);
+	if (edge->visited_left) {
+	    if (!(pg->e[i].visited_right)) {
+		w = edge->winding_left - 1;
+		extract_contour(pg, &(pg->e[i]), RIGHT_SIDE, w, 0, nPoints);
+		*winding = w;
+		return 1;
+	else {
+	    if (pg->e[i].visited_right) {
+		w = edge->winding_right + 1;
+		extract_contour(pg, &(pg->e[i]), LEFT_SIDE, w, 0, nPoints);
+		*winding = w;
+		return 1;
+    return 0;
+/* point_in_buf - test if point px,py is in d buffer of Points
+ ** dalpha is in degrees
+ ** returns:  1 in buffer
+ **           0 not in buffer
+static int point_in_buf(struct line_pnts *Points, double px, double py, double da,
+			double db, double dalpha)
+    int i, np;
+    double cx, cy;
+    double delta, delta_k, k;
+    double vx, vy, wx, wy, mx, my, nx, ny;
+    double len, tx, ty, d, da2;
+    G_debug(3, "point_in_buf()");
+    da2 = da * da;
+	vx = Points->x[i];
+	vy = Points->y[i];
+	wx = Points->x[i + 1];
+	wy = Points->y[i + 1];
+	if (da != db) {
+	    mx = wx - vx;
+	    my = wy - vy;
+	    len = LENGTH(mx, my);
+	    elliptic_tangent(mx / len, my / len, da, db, dalpha, &cx, &cy);
+	    delta = mx * cy - my * cx;
+	    delta_k = (px - vx) * cy - (py - vy) * cx;
+	    k = delta_k / delta;
+	    /*            G_debug(4, "k = %g, k1 = %g", k, (mx * (px - vx) + my * (py - vy)) / (mx * mx + my * my)); */
+	    if (k <= 0) {
+		nx = vx;
+		ny = vy;
+	    else if (k >= 1) {
+		nx = wx;
+		ny = wy;
+	    else {
+		nx = vx + k * mx;
+		ny = vy + k * my;
+	    /* inverse transform */
+	    elliptic_transform(px - nx, py - ny, 1 / da, 1 / db, dalpha, &tx,
+			       &ty);
+	    d = dig_distance2_point_to_line(nx + tx, ny + ty, 0, vx, vy, 0,
+					    wx, wy, 0, 0, NULL, NULL, NULL,
+					    NULL, NULL);
+	    /*            G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny))); */
+	    if (d <= 1) {
+		//G_debug(1, "d=%g", d);
+		return 1;
+	else {
+	    d = dig_distance2_point_to_line(px, py, 0, vx, vy, 0, wx, wy, 0,
+	    /*            G_debug(4, "sqrt(d)     = %g", sqrt(d)); */
+	    if (d <= da2) {
+		return 1;
+    return 0;
+/* returns 0 for ccw, non-zero for cw
+static int get_polygon_orientation(const double *x, const double *y, int n)
+    double x1, y1, x2, y2;
+    double area;
+    x2 = x[n - 1];
+    y2 = y[n - 1];
+    area = 0;
+    while (--n >= 0) {
+	x1 = x2;
+	y1 = y2;
+	x2 = *x++;
+	y2 = *y++;
+	area += (y2 + y1) * (x2 - x1);
+    return (area > 0);
+/* internal */
+static void add_line_to_array(struct line_pnts *Points,
+			      struct line_pnts ***arrPoints, int *count,
+			      int *allocated, int more)
+    if (*allocated == *count) {
+	*allocated += more;
+	*arrPoints =
+	    G_realloc(*arrPoints, (*allocated) * sizeof(struct line_pnts *));
+    (*arrPoints)[*count] = Points;
+    (*count)++;
+    return;
+static void destroy_lines_array(struct line_pnts **arr, int count)
+    int i;
+    for (i = 0; i < count; i++)
+	Vect_destroy_line_struct(arr[i]);
+    G_free(arr);
+/* area_outer and area_isles[i] must be closed non self-intersecting lines
+   side: 0 - auto, 1 - right, -1 left
+static void buffer_lines(struct line_pnts *area_outer, struct line_pnts **area_isles,
+			 int isles_count, int side, double da, double db,
+			 double dalpha, int round, int caps, double tol,
+			 struct line_pnts **oPoints, struct line_pnts ***iPoints,
+			 int *inner_count)
+    struct planar_graph *pg2;
+    struct line_pnts *sPoints, *cPoints;
+    struct line_pnts **arrPoints;
+    int i, count = 0;
+    int res, winding;
+    int auto_side;
+    int more = 8;
+    int allocated = 0;
+    double px, py;
+    G_debug(3, "buffer_lines()");
+    auto_side = (side == 0);
+    /* initializations */
+    sPoints = Vect_new_line_struct();
+    cPoints = Vect_new_line_struct();
+    arrPoints = NULL;
+    /* outer contour */
+    G_debug(3, "    processing outer contour");
+    *oPoints = Vect_new_line_struct();
+    if (auto_side)
+	side =
+	    get_polygon_orientation(area_outer->x, area_outer->y,
+				    area_outer->n_points -
+				    1) ? LEFT_SIDE : RIGHT_SIDE;
+    convolution_line(area_outer, da, db, dalpha, side, round, caps, tol,
+		     sPoints);
+    pg2 = pg_create(sPoints);
+    extract_outer_contour(pg2, 0, *oPoints);
+    res = extract_inner_contour(pg2, &winding, cPoints);
+    while (res != 0) {
+	if (winding == 0) {
+	    if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
+		if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
+		    G_fatal_error(_("Vect_get_point_in_poly() failed"));
+		if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
+		    add_line_to_array(cPoints, &arrPoints, &count, &allocated,
+				      more);
+    pg_destroy_struct(pg2);
+    /* inner contours */
+    G_debug(3, "    processing inner contours");
+    for (i = 0; i < isles_count; i++) {
+	if (auto_side)
+	    side =
+		get_polygon_orientation(area_isles[i]->x, area_isles[i]->y,
+					area_isles[i]->n_points -
+					1) ? RIGHT_SIDE : LEFT_SIDE;
+	convolution_line(area_isles[i], da, db, dalpha, side, round, caps,
+			 tol, sPoints);
+	extract_outer_contour(pg2, 0, cPoints);
+	    if (winding == -1) {
+		/* we need to check if the area is in the buffer.
+		   I've simplfied convolution_line(), so that it runs faster,
+		   however that leads to ocasional problems */
+		if (Vect_point_in_poly
+		    (cPoints->x[0], cPoints->y[0], area_isles[i])) {
+		    if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
+					  &allocated, more);
+    arrPoints = G_realloc(arrPoints, count * sizeof(struct line_pnts *));
+    *inner_count = count;
+    *iPoints = arrPoints;
+    Vect_destroy_line_struct(sPoints);
+    Vect_destroy_line_struct(cPoints);
+    G_debug(3, "buffer_lines() ... done");
+    return;
+   \brief Creates buffer around line.
+   See also Vect_line_buffer().
+   \param InPoints input line geometry
+   \param da distance along major axis
+   \param db distance along minor axis
+   \param dalpha angle between 0x and major axis
+   \param round make corners round
+   \param caps add caps at line ends
+   \param tol maximum distance between theoretical arc and output segments
+   \param[out] oPoints output polygon outer border (ccw order)
+   \param[out] inner_count number of holes
+   \param[out] iPoints array of output polygon's holes (cw order)
+void Vect_line_buffer2(struct line_pnts *Points, double da, double db,
+		       struct line_pnts ***iPoints, int *inner_count)
+    struct planar_graph *pg;
+    struct line_pnts *tPoints, *outer;
+    struct line_pnts **isles;
+    int isles_count = 0;
+    int res, winding;
+    int more = 8;
+    int isles_allocated = 0;
+    G_debug(2, "Vect_line_buffer()");
+    tPoints = Vect_new_line_struct();
+    isles = NULL;
+    pg = pg_create(Points);
+    outer = Vect_new_line_struct();
+    extract_outer_contour(pg, 0, outer);
+    res = extract_inner_contour(pg, &winding, tPoints);
+	add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated,
+			  more);
+    buffer_lines(outer, isles, isles_count, RIGHT_SIDE, da, db, dalpha, round,
+		 caps, tol, oPoints, iPoints, inner_count);
+    Vect_destroy_line_struct(tPoints);
+    Vect_destroy_line_struct(outer);
+    destroy_lines_array(isles, isles_count);
+    pg_destroy_struct(pg);
+    return;
+   \brief Creates buffer around area.
+   \param Map vector map
+   \param area area id
+void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db,
+    int i, isle;
+    int more = 8;
+    G_debug(2, "Vect_area_buffer()");
+    isles_count = Vect_get_area_num_isles(Map, area);
+    isles_allocated = isles_count;
+    isles = G_malloc(isles_allocated * sizeof(struct line_pnts *));
+    Vect_get_area_points(Map, area, outer);
+    Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
+	isle = Vect_get_area_isle(Map, area, i);
+	Vect_get_isle_points(Map, isle, tPoints);
+	/* Check if the isle is big enough */
+	   if (Vect_line_length(tPoints) < 2*PI*max)
+	   continue;
+	Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0],
+			  tPoints->z[0]);
+			  more);
+    buffer_lines(outer, isles, isles_count, 0, da, db, dalpha, round, caps,
+		 tol, oPoints, iPoints, inner_count);
+    return;
+   \brief Creates buffer around the point (px, py).
+   \param px input point x-coordinate
+   \param py input point y-coordinate
+   \param da distance along minor axis
+   \param[out] nPoints output polygon outer border (ccw order)
+void Vect_point_buffer2(double px, double py, double da, double db,
+			double dalpha, int round, double tol,
+			struct line_pnts **oPoints)
+    double tx, ty;
+    double angular_tol, angular_step, phi1;
+    int j, nsegments;
+    G_debug(2, "Vect_point_buffer()");
+    if (round || (!round)) {
+	nsegments = (int)(2 * PI / angular_tol) + 1;
+	angular_step = 2 * PI / nsegments;
+	phi1 = 0;
+	for (j = 0; j < nsegments; j++) {
+			       &ty);
+	    Vect_append_point(*oPoints, px + tx, py + ty, 0);
+    else {
+    Vect_append_point(*oPoints, (*oPoints)->x[0], (*oPoints)->y[0],
+		      (*oPoints)->z[0]);
+    return;
+   \brief Create parrallel line
+   See also Vect_line_parallel().
+   \param[out] OutPoints output line
+void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db,
+			 double dalpha, int side, int round, double tol,
+			 struct line_pnts *OutPoints)
+    G_debug(2, "Vect_line_parallel(): npoints = %d, da = %f, "
+	    "db = %f, dalpha = %f, side = %d, round_corners = %d, tol = %f",
+	    InPoints->n_points, da, db, dalpha, side, round, tol);
+    parallel_line(InPoints, da, db, dalpha, side, round, 1, NON_LOOPED_LINE,
+		  tol, OutPoints);
+    /*    if (!loops)
+       clean_parallel(OutPoints, InPoints, distance, rm_end);
+    return;
Copied: grass/trunk/lib/vector/Vlib/dgraph.c (from rev 34601, grass/branches/develbranch_6/lib/vector/Vlib/dgraph.c)
--- grass/trunk/lib/vector/Vlib/dgraph.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/dgraph.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -0,0 +1,521 @@
+#include "e_intersect.h"
+#ifndef MIN
+#endif
+#ifndef MAX
+#endif
+#define PI M_PI
+struct intersection_point
+    double x;
+    double y;
+    int group;			/* IPs with very similar dist will be in the same group */
+struct seg_intersection
+    int with;			/* second segment */
+    int ip;			/* index of the IP */
+    double dist;		/* distance from first point of first segment to intersection point (IP) */
+struct seg_intersection_list
+    int count;
+    int allocated;
+    struct seg_intersection *a;
+struct seg_intersections
+    int ipcount;
+    int ipallocated;
+    struct intersection_point *ip;
+    int ilcount;
+    struct seg_intersection_list *il;
+    int group_count;
+struct seg_intersections *create_si_struct(int segments_count)
+    struct seg_intersections *si;
+    int i;
+    si = G_malloc(sizeof(struct seg_intersections));
+    si->ipcount = 0;
+    si->ipallocated = segments_count + 16;
+    si->ip = G_malloc((si->ipallocated) * sizeof(struct intersection_point));
+    si->ilcount = segments_count;
+    si->il = G_malloc(segments_count * sizeof(struct seg_intersection_list));
+    for (i = 0; i < segments_count; i++) {
+	si->il[i].count = 0;
+	si->il[i].allocated = 0;
+	si->il[i].a = NULL;
+    return si;
+void destroy_si_struct(struct seg_intersections *si)
+    int i;
+    for (i = 0; i < si->ilcount; i++)
+	G_free(si->il[i].a);
+    G_free(si->il);
+    G_free(si->ip);
+    G_free(si);
+    return;
+/* internal use */
+void add_ipoint1(struct seg_intersection_list *il, int with, double dist,
+		 int ip)
+    struct seg_intersection *s;
+    if (il->count == il->allocated) {
+	il->allocated += 4;
+	il->a =
+	    G_realloc(il->a,
+		      (il->allocated) * sizeof(struct seg_intersection));
+    s = &(il->a[il->count]);
+    s->with = with;
+    s->ip = ip;
+    s->dist = dist;
+    il->count++;
+    return;
+/* adds intersection point to the structure */
+void add_ipoint(struct line_pnts *Points, int first_seg, int second_seg,
+		double x, double y, struct seg_intersections *si)
+    struct intersection_point *t;
+    int ip;
+    G_debug(4, "add_ipoint()");
+    if (si->ipcount == si->ipallocated) {
+	si->ipallocated += 16;
+	si->ip =
+	    G_realloc(si->ip,
+		      (si->ipallocated) * sizeof(struct intersection_point));
+    ip = si->ipcount;
+    t = &(si->ip[ip]);
+    t->x = x;
+    t->y = y;
+    t->group = -1;
+    si->ipcount++;
+    add_ipoint1(&(si->il[first_seg]), second_seg,
+		LENGTH((Points->x[first_seg] - x),
+		       (Points->y[first_seg] - y)), ip);
+    if (second_seg >= 0)
+	add_ipoint1(&(si->il[second_seg]), first_seg,
+		    LENGTH((Points->x[second_seg] - x),
+			   (Points->y[second_seg] - y)), ip);
+void sort_intersection_list(struct seg_intersection_list *il)
+    int n, i, j, min;
+    struct seg_intersection t;
+    G_debug(4, "sort_intersection_list()");
+    n = il->count;
+    G_debug(4, "    n=%d", n);
+    for (i = 0; i < n - 1; i++) {
+	min = i;
+	for (j = i + 1; j < n; j++) {
+	    if (il->a[j].dist < il->a[min].dist) {
+		min = j;
+	if (min != i) {
+	    t = il->a[i];
+	    il->a[i] = il->a[min];
+	    il->a[min] = t;
+    return;
+static int compare(const void *a, const void *b)
+    struct intersection_point *aa, *bb;
+    aa = *((struct intersection_point **)a);
+    bb = *((struct intersection_point **)b);
+    if (aa->x < bb->x)
+	return -1;
+    else if (aa->x > bb->x)
+	return 1;
+    else
+	return (aa->y < bb->y) ? -1 : ((aa->y > bb->y) ? 1 : 0);
+/* O(Points->n_points) time */
+double get_epsilon(struct line_pnts *Points)
+    int i, np;
+    double min, t;
+    double *x, *y;
+    x = Points->x;
+    y = Points->y;
+    min = MAX(fabs(x[1] - x[0]), fabs(y[1] - y[0]));
+    for (i = 1; i <= np - 2; i++) {
+	t = MAX(fabs(x[i + 1] - x[i]), fabs(y[i + 1] - y[i]));
+	if ((t > 0) && (t < min)) {
+	    min = t;
+    /* ??? is 0.001 ok ??? */
+    return min * 0.000001;
+/* currently O(n*n); future implementation O(nlogn) */
+struct seg_intersections *find_all_intersections(struct line_pnts *Points)
+    int i, j, np;
+    int group, t;
+    int looped;
+    double EPSILON = 0.00000001;
+    double *x, *y;
+    int res;
+    /*int res2
+       double x1_, y1_, x2_, y2_, z1_, z2_; */
+    struct intersection_point **sorted;
+    G_debug(3, "find_all_intersections()");
+    x = Points->x;
+    y = Points->y;
+    si = create_si_struct(np - 1);
+    looped = ((x[0] == x[np - 1]) && (y[0] == y[np - 1]));
+    G_debug(3, "    looped=%d", looped);
+    G_debug(3, "    finding intersections...");
+	for (j = i + 1; j < np - 1; j++) {
+	    G_debug(4, "        checking %d-%d %d-%d", i, i + 1, j, j + 1);
+	    /*res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2); */
+	    res =
+		segment_intersection_2d(x[i], y[i], x[i + 1], y[i + 1], x[j],
+					y[j], x[j + 1], y[j + 1], &x1, &y1,
+					&x2, &y2);
+	    /*            res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
+	       if ((res != res2) || ((res != 0) && (x1!=x1_ || y1!=y1_)) ) {
+	       G_debug(0, "exact=%d orig=%d", res, res2);
+	       segment_intersection_2d_test(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
+	    G_debug(4, "        intersection type = %d", res);
+	    if (res == 1) {
+		add_ipoint(Points, i, j, x1, y1, si);
+	    else if ((res >= 2) && (res <= 5)) {
+		add_ipoint(Points, i, j, x2, y2, si);
+    if (!looped) {
+	/* these are not really intersection points */
+	add_ipoint(Points, 0, -1, Points->x[0], Points->y[0], si);
+	add_ipoint(Points, np - 2, -1, Points->x[np - 1], Points->y[np - 1],
+		   si);
+    G_debug(3, "    finding intersections...done");
+    G_debug(3, "    postprocessing...");
+    if (si->ipallocated > si->ipcount) {
+	si->ipallocated = si->ipcount;
+	si->ip =
+	    G_realloc(si->ip,
+		      (si->ipcount) * sizeof(struct intersection_point));
+    for (i = 0; i < si->ilcount; i++) {
+	il = &(si->il[i]);
+	if (il->allocated > il->count) {
+	    il->allocated = il->count;
+	    il->a =
+		G_realloc(il->a,
+			  (il->count) * sizeof(struct seg_intersection));
+	if (il->count > 0) {
+	    sort_intersection_list(il);
+	    /* is it ok to use qsort here ? */
+    /* si->ip will not be reallocated any more so we can use pointers */
+    sorted = G_malloc((si->ipcount) * sizeof(struct intersection_point *));
+    for (i = 0; i < si->ipcount; i++)
+	sorted[i] = &(si->ip[i]);
+    qsort(sorted, si->ipcount, sizeof(struct intersection_point *), compare);
+    /* assign groups */
+    group = 0;			/* next available group number */
+    for (i = 0; i < si->ipcount; i++) {
+	t = group;
+	for (j = i - 1; j >= 0; j--) {
+	    if (!FEQUAL(sorted[j]->x, sorted[i]->x, EPSILON))
+		/*            if (!almost_equal(sorted[j]->x, sorted[i]->x, 16)) */
+		break;
+	    if (FEQUAL(sorted[j]->y, sorted[i]->y, EPSILON)) {
+		/*            if (almost_equal(sorted[j]->y, sorted[i]->y, 16)) { */
+		t = sorted[j]->group;
+		break;
+	G_debug(4, "        group=%d, ip=%d", t,
+		(int)(sorted[i] - &(si->ip[0])));
+	sorted[i]->group = t;
+	if (t == group)
+	    group++;
+    si->group_count = group;
+    G_debug(3, "    postprocessing...done");
+    /* output contents of si */
+	G_debug(4, "%d-%d :", i, i + 1);
+	for (j = 0; j < si->il[i].count; j++) {
+	    G_debug(4, "     %d-%d, group=%d", si->il[i].a[j].with,
+		    si->il[i].a[j].with + 1, si->ip[si->il[i].a[j].ip].group);
+	    G_debug(4, "            dist=%.18f", si->il[i].a[j].dist);
+	    G_debug(4, "            x=%.18f, y=%.18f",
+		    si->ip[si->il[i].a[j].ip].x, si->ip[si->il[i].a[j].ip].y);
+    return si;
+/* create's graph with n vertices and allocates memory for e edges */
+/* trying to add more than e edges, produces fatal error */
+struct planar_graph *pg_create_struct(int n, int e)
+    pg = G_malloc(sizeof(struct planar_graph));
+    pg->vcount = n;
+    pg->v = G_malloc(n * sizeof(struct pg_vertex));
+    memset(pg->v, 0, n * sizeof(struct pg_vertex));
+    pg->ecount = 0;
+    pg->eallocated = MAX(e, 0);
+    pg->e = NULL;
+    pg->e = G_malloc(e * sizeof(struct pg_edge));
+    return pg;
+void pg_destroy_struct(struct planar_graph *pg)
+    int i;
+	G_free(pg->v[i].edges);
+	G_free(pg->v[i].angles);
+    G_free(pg->v);
+    G_free(pg->e);
+    G_free(pg);
+/* v1 and v2 must be valid */
+int pg_existsedge(struct planar_graph *pg, int v1, int v2)
+    struct pg_vertex *v;
+    struct pg_edge *e;
+    int i, ecount;
+    if (pg->v[v1].ecount <= pg->v[v2].ecount)
+	v = &(pg->v[v1]);
+    else
+	v = &(pg->v[v2]);
+    ecount = v->ecount;
+    for (i = 0; i < ecount; i++) {
+	e = v->edges[i];
+	if (((e->v1 == v1) && (e->v2 == v2)) ||
+	    ((e->v1 == v2) && (e->v2 == v1)))
+	    return 1;
+    return 0;
+/* for internal use */
+void pg_addedge1(struct pg_vertex *v, struct pg_edge *e)
+    if (v->ecount == v->eallocated) {
+	v->eallocated += 4;
+	v->edges =
+	    G_realloc(v->edges, (v->eallocated) * sizeof(struct pg_edge *));
+    v->edges[v->ecount] = e;
+    v->ecount++;
+void pg_addedge(struct planar_graph *pg, int v1, int v2)
+    G_debug(4, "pg_addedge(), v1=%d, v2=%d", v1, v2);
+    if ((v1 == v2) || (v1 < 0) || (v1 >= pg->vcount) || (v2 < 0) ||
+	(v2 >= pg->vcount)) {
+	G_fatal_error("    pg_addedge(), v1 and/or v2 is invalid");
+	return;
+    if (pg_existsedge(pg, v1, v2))
+	return;
+    if (pg->ecount == pg->eallocated) {
+	G_fatal_error
+	    ("Trying to add more edges to the planar_graph than the initial allocation size allows");
+    e = &(pg->e[pg->ecount]);
+    e->v1 = v1;
+    e->v2 = v2;
+    e->winding_left = 0;	/* winding is undefined if the corresponding side is not visited */
+    e->winding_right = 0;
+    e->visited_left = 0;
+    e->visited_right = 0;
+    pg->ecount++;
+    pg_addedge1(&(pg->v[v1]), e);
+    pg_addedge1(&(pg->v[v2]), e);
+    return;
+struct planar_graph *pg_create(struct line_pnts *Points)
+    int i, j, t, v;
+    G_debug(3, "pg_create()");
+    si = find_all_intersections(Points);
+    pg = pg_create_struct(si->group_count, 2 * (si->ipcount));
+    /* set vertices info */
+	ip = &(si->ip[i]);
+	t = ip->group;
+	pg->v[t].x = ip->x;
+	pg->v[t].y = ip->y;
+    /* add all edges */
+	v = si->ip[si->il[i].a[0].ip].group;
+	for (j = 1; j < si->il[i].count; j++) {
+	    t = si->ip[si->il[i].a[j].ip].group;
+	    if (t != v) {
+		pg_addedge(pg, v, t);	/* edge direction is v ---> t */
+		v = t;
+    /* precalculate angles with 0x */
+	vert = &(pg->v[i]);
+	vert->angles = G_malloc((vert->ecount) * sizeof(double));
+	    edge = vert->edges[j];
+	    t = (edge->v1 != i) ? (edge->v1) : (edge->v2);
+	    vert->angles[j] =
+		atan2(pg->v[t].y - vert->y, pg->v[t].x - vert->x);
+    destroy_si_struct(si);
+       I'm not sure if shrinking of the allocated memory always preserves it's physical place.
+       That's why I don't want to do this:
+       if (pg->ecount < pg->eallocated) {
+       pg->eallocated = pg->ecount;
+       pg->e = G_realloc(pg->e, (pg->ecount)*sizeof(struct pg_edge));
+    /* very time consuming */
+       if (pg->v[i].ecount < pg->v[i].eallocated) {
+       pg->v[i].eallocated = pg->v[i].ecount;
+       pg->v[i].edges = G_realloc(pg->v[i].edges, (pg->v[i].ecount)*sizeof(struct pg_edges));
+    /* output pg */
+	G_debug(4, "    vertex %d (%g, %g)", i, pg->v[i].x, pg->v[i].y);
+	for (j = 0; j < pg->v[i].ecount; j++) {
+	    G_debug(4, "        edge %d-%d", pg->v[i].edges[j]->v1,
+		    pg->v[i].edges[j]->v2);
+    return pg;
Copied: grass/trunk/lib/vector/Vlib/dgraph.h (from rev 34601, grass/branches/develbranch_6/lib/vector/Vlib/dgraph.h)
--- grass/trunk/lib/vector/Vlib/dgraph.h	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/dgraph.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -0,0 +1,38 @@
+#ifndef GRASS_DGRAPH_H
+#define GRASS_DGRAPH_H
+/* pg comes from "planar graph" */
+/* every edge is directed. Nevertheless, we can visit it on both sides */
+struct pg_edge {
+    int v1; /* first vertex */
+    int v2; /* second vertex */
+    char visited_left;
+    char visited_right;
+    char winding_left; /* winding numbers */
+    char winding_right;
+struct pg_vertex {
+    double x; /* coordinates */
+    double y;
+    int ecount; /* number of neighbours */
+    int eallocated; /* size of the array bellow */
+    struct pg_edge **edges; /* array of pointers */
+    double *angles; /* precalculated angles with Ox */
+struct planar_graph {
+    int vcount; /* number of vertices */
+    int ecount;
+    int eallocated;
+struct planar_graph* pg_create_struct(int n, int e);
+void pg_destroy_struct(struct planar_graph *pg);
+int pg_existsedge(struct planar_graph *pg, int v1, int v2);
+void pg_addedge(struct planar_graph *pg, int v1, int v2);
+struct planar_graph* pg_create(struct line_pnts *Points);
+#endif
Copied: grass/trunk/lib/vector/Vlib/e_intersect.c (from rev 34601, grass/branches/develbranch_6/lib/vector/Vlib/e_intersect.c)
--- grass/trunk/lib/vector/Vlib/e_intersect.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/e_intersect.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -0,0 +1,1077 @@
+#include <math.h>
+#define SWAP(a,b) {t = a; a = b; b = t;}
+#ifndef MIN
+#endif
+#ifndef MAX
+#endif
+#define D (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2)
+#define DA (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2)
+#define DB (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1)
+#ifdef ASDASDASFDSAFFDAS
+mpf_t p11, p12, p21, p22, t1, t2;
+mpf_t dd, dda, ddb, delta;
+mpf_t rra, rrb;
+int initialized = 0;
+void initialize_mpf_vars()
+    mpf_set_default_prec(2048);
+    mpf_init(p11);
+    mpf_init(p12);
+    mpf_init(p21);
+    mpf_init(p22);
+    mpf_init(t1);
+    mpf_init(t2);
+    mpf_init(dd);
+    mpf_init(dda);
+    mpf_init(ddb);
+    mpf_init(delta);
+    mpf_init(rra);
+    mpf_init(rrb);
+    initialized = 1;
+   Caclulates:
+   |a11-b11  a12-b12|
+   |a21-b21  a22-b22|
+void det22(mpf_t rop, double a11, double b11, double a12, double b12,
+	   double a21, double b21, double a22, double b22)
+    mpf_set_d(t1, a11);
+    mpf_set_d(t2, b11);
+    mpf_sub(p11, t1, t2);
+    mpf_set_d(t1, a12);
+    mpf_set_d(t2, b12);
+    mpf_sub(p12, t1, t2);
+    mpf_set_d(t1, a21);
+    mpf_set_d(t2, b21);
+    mpf_sub(p21, t1, t2);
+    mpf_set_d(t1, a22);
+    mpf_set_d(t2, b22);
+    mpf_sub(p22, t1, t2);
+    mpf_mul(t1, p11, p22);
+    mpf_mul(t2, p12, p21);
+    mpf_sub(rop, t1, t2);
+    return;
+void swap(double *a, double *b)
+    double t = *a;
+    *a = *b;
+    *b = t;
+    return;
+/* multi-precision version */
+int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2,
+			      double bx1, double by1, double bx2, double by2,
+			      double *x1, double *y1, double *x2, double *y2)
+    double t;
+    double max_ax, min_ax, max_ay, min_ay;
+    double max_bx, min_bx, max_by, min_by;
+    int sgn_d, sgn_da, sgn_db;
+    int vertical;
+    int f11, f12, f21, f22;
+    mp_exp_t exp;
+    char *s;
+    if (!initialized)
+	initialize_mpf_vars();
+    /* TODO: Works for points ? */
+    G_debug(3, "segment_intersection_2d_e()");
+    G_debug(4, "    ax1  = %.18f, ay1  = %.18f", ax1, ay1);
+    G_debug(4, "    ax2  = %.18f, ay2  = %.18f", ax2, ay2);
+    G_debug(4, "    bx1  = %.18f, by1  = %.18f", bx1, by1);
+    G_debug(4, "    bx2  = %.18f, by2  = %.18f", bx2, by2);
+    f11 = ((ax1 == bx1) && (ay1 == by1));
+    f12 = ((ax1 == bx2) && (ay1 == by2));
+    f21 = ((ax2 == bx1) && (ay2 == by1));
+    f22 = ((ax2 == bx2) && (ay2 == by2));
+    /* Check for identical segments */
+    if ((f11 && f22) || (f12 && f21)) {
+	G_debug(3, "    identical segments");
+	*x1 = ax1;
+	*y1 = ay1;
+	*x2 = ax2;
+	*y2 = ay2;
+	return 5;
+    /* Check for identical endpoints */
+    if (f11 || f12) {
+	G_debug(3, "    connected by endpoints");
+	*x1 = ax1;
+	*y1 = ay1;
+	return 1;
+    if (f21 || f22) {
+	*x1 = ax2;
+	*y1 = ay2;
+	return 1;
+    if ((MAX(ax1, ax2) < MIN(bx1, bx2)) || (MAX(bx1, bx2) < MIN(ax1, ax2))) {
+	G_debug(3, "    no intersection (disjoint bounding boxes)");
+	return 0;
+    if ((MAX(ay1, ay2) < MIN(by1, by2)) || (MAX(by1, by2) < MIN(ay1, ay2))) {
+	return 0;
+    det22(dd, ax2, ax1, bx1, bx2, ay2, ay1, by1, by2);
+    sgn_d = mpf_sgn(dd);
+    if (sgn_d != 0) {
+	G_debug(3, "    general position");
+	det22(dda, bx1, ax1, bx1, bx2, by1, ay1, by1, by2);
+	sgn_da = mpf_sgn(dda);
+	/*mpf_div(rra, dda, dd);
+	   mpf_div(rrb, ddb, dd);
+	   s = mpf_get_str(NULL, &exp, 10, 40, rra);
+	   G_debug(4, "        ra = %sE%d", (s[0]==0)?"0":s, exp);
+	   s = mpf_get_str(NULL, &exp, 10, 24, rrb);
+	   G_debug(4, "        rb = %sE%d", (s[0]==0)?"0":s, exp);
+	if (sgn_d > 0) {
+	    if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
+		G_debug(3, "        no intersection");
+		return 0;
+	    det22(ddb, ax2, ax1, bx1, ax1, ay2, ay1, by1, ay1);
+	    sgn_db = mpf_sgn(ddb);
+	    if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
+		return 0;
+	else {			/* if sgn_d < 0 */
+	    if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
+		return 0;
+	    if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
+		return 0;
+	/*G_debug(3, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd)); */
+	/*G_debug(3, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd)); */
+	mpf_set_d(delta, ax2 - ax1);
+	mpf_mul(t1, dda, delta);
+	mpf_div(t2, t1, dd);
+	*x1 = ax1 + mpf_get_d(t2);
+	mpf_set_d(delta, ay2 - ay1);
+	*y1 = ay1 + mpf_get_d(t2);
+	G_debug(3, "        intersection %.16g, %.16g", *x1, *y1);
+	return 1;
+    /* segments are parallel or collinear */
+    if (sgn_da != 0) {
+	/* segments are parallel */
+	G_debug(3, "    parallel segments");
+	return 0;
+    /* segments are colinear. check for overlap */
+    /* swap endpoints if needed */
+    /* if segments are vertical, we swap x-coords with y-coords */
+    vertical = 0;
+    if (ax1 > ax2) {
+	SWAP(ax1, ax2);
+	SWAP(ay1, ay2);
+    else if (ax1 == ax2) {
+	vertical = 1;
+	if (ay1 > ay2)
+	    SWAP(ay1, ay2);
+	SWAP(ax1, ay1);
+	SWAP(ax2, ay2);
+    if (bx1 > bx2) {
+	SWAP(bx1, bx2);
+	SWAP(by1, by2);
+    else if (bx1 == bx2) {
+	if (by1 > by2)
+	    SWAP(by1, by2);
+	SWAP(bx1, by1);
+	SWAP(bx2, by2);
+    G_debug(3, "    collinear segments");
+    if ((bx2 < ax1) || (bx1 > ax2)) {
+	return 0;
+    /* there is overlap or connected end points */
+    G_debug(3, "        overlap");
+    /* a contains b */
+    if ((ax1 < bx1) && (ax2 > bx2)) {
+	G_debug(3, "            a contains b");
+	if (!vertical) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = bx2;
+	    *y2 = by2;
+	else {
+	    *x1 = by1;
+	    *y1 = bx1;
+	    *x2 = by2;
+	    *y2 = bx2;
+	return 3;
+    /* b contains a */
+    if ((ax1 > bx1) && (ax2 < bx2)) {
+	G_debug(3, "            b contains a");
+	if (!vertical) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = bx2;
+	    *y2 = by2;
+	else {
+	    *x1 = by1;
+	    *y1 = bx1;
+	    *x2 = by2;
+	    *y2 = bx2;
+	return 4;
+    /* general overlap, 2 intersection points */
+    G_debug(3, "        partial overlap");
+    if ((bx1 > ax1) && (bx1 < ax2)) {	/* b1 is in a */
+	if (!vertical) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = ax2;
+	    *y2 = ay2;
+	else {
+	    *x1 = by1;
+	    *y1 = bx1;
+	    *x2 = ay2;
+	    *y2 = ax2;
+	return 2;
+    if ((bx2 > ax1) && (bx2 < ax2)) {	/* b2 is in a */
+	if (!vertical) {
+	    *x1 = bx2;
+	    *y1 = by2;
+	    *x2 = ax1;
+	    *y2 = ay1;
+	else {
+	    *x1 = by2;
+	    *y1 = bx2;
+	    *x2 = ay1;
+	    *y2 = ax1;
+	return 2;
+    /* should not be reached */
+    G_warning(("segment_intersection_2d() ERROR (should not be reached)"));
+    G_warning("%.16g %.16g", ax1, ay1);
+    G_warning("%.16g %.16g", ax2, ay2);
+    G_warning("x");
+    G_warning("%.16g %.16g", bx1, by1);
+    G_warning("%.16g %.16g", bx2, by2);
+    return 0;
+#endif
+/* OLD */
+/* tollerance aware version */
+/* TODO: fix all ==s left */
+int segment_intersection_2d_tol(double ax1, double ay1, double ax2,
+				double ay2, double bx1, double by1,
+				double bx2, double by2, double *x1,
+				double *y1, double *x2, double *y2,
+				double tol)
+    double tola, tolb;
+    double d, d1, d2, ra, rb, t;
+    int switched = 0;
+    G_debug(4, "segment_intersection_2d()");
+    /* Check identical lines */
+    if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) &&
+	 FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
+	(FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) &&
+	 FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
+	G_debug(2, " -> identical segments");
+	*x1 = ax1;
+	*y1 = ay1;
+	*x2 = ax2;
+	*y2 = ay2;
+	return 5;
+    /*  'Sort' lines by x1, x2, y1, y2 */
+    if (bx1 < ax1)
+	switched = 1;
+    else if (bx1 == ax1) {
+	if (bx2 < ax2)
+	    switched = 1;
+	else if (bx2 == ax2) {
+	    if (by1 < ay1)
+		switched = 1;
+	    else if (by1 == ay1) {
+		if (by2 < ay2)
+		    switched = 1;	/* by2 != ay2 (would be identical */
+    if (switched) {
+	t = ax1;
+	ax1 = bx1;
+	bx1 = t;
+	t = ay1;
+	ay1 = by1;
+	by1 = t;
+	t = ax2;
+	ax2 = bx2;
+	bx2 = t;
+	t = ay2;
+	ay2 = by2;
+	by2 = t;
+    d = (ax2 - ax1) * (by1 - by2) - (ay2 - ay1) * (bx1 - bx2);
+    d1 = (bx1 - ax1) * (by1 - by2) - (by1 - ay1) * (bx1 - bx2);
+    d2 = (ax2 - ax1) * (by1 - ay1) - (ay2 - ay1) * (bx1 - ax1);
+    G_debug(2, "    d  = %.18g", d);
+    G_debug(2, "    d1 = %.18g", d1);
+    G_debug(2, "    d2 = %.18g", d2);
+    tola = tol / MAX(fabs(ax2 - ax1), fabs(ay2 - ay1));
+    tolb = tol / MAX(fabs(bx2 - bx1), fabs(by2 - by1));
+    G_debug(2, "    tol  = %.18g", tol);
+    G_debug(2, "    tola = %.18g", tola);
+    G_debug(2, "    tolb = %.18g", tolb);
+    if (!FZERO(d, tol)) {
+	ra = d1 / d;
+	rb = d2 / d;
+	G_debug(2, "    not parallel/collinear: ra = %.18g", ra);
+	G_debug(2, "                            rb = %.18g", rb);
+	if ((ra <= -tola) || (ra >= 1 + tola) || (rb <= -tolb) ||
+	    (rb >= 1 + tolb)) {
+	    G_debug(2, "        no intersection");
+	    return 0;
+	ra = MIN(MAX(ra, 0), 1);
+	*x1 = ax1 + ra * (ax2 - ax1);
+	*y1 = ay1 + ra * (ay2 - ay1);
+	G_debug(2, "        intersection %.18f, %.18f", *x1, *y1);
+	return 1;
+    G_debug(3, " -> parallel/collinear");
+    if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) {	/* lines are parallel */
+	G_debug(2, "  -> parallel");
+	return 0;
+    /*    aa = adx*adx + ady*ady;
+       bb = bdx*bdx + bdy*bdy;
+       t = (ax1-bx1)*bdx + (ay1-by1)*bdy; */
+    /* Collinear vertical */
+    /* original code assumed lines were not both vertical
+     *  so there is a special case if they are */
+    if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) &&
+	FEQUAL(ax1, bx1, tol)) {
+	G_debug(2, "  -> collinear vertical");
+	if (ay1 > ay2) {
+	    t = ay1;
+	    ay1 = ay2;
+	    ay2 = t;
+	}			/* to be sure that ay1 < ay2 */
+	if (by1 > by2) {
+	    t = by1;
+	    by1 = by2;
+	    by2 = t;
+	}			/* to be sure that by1 < by2 */
+	if (ay1 > by2 || ay2 < by1) {
+	    G_debug(2, "   -> no intersection");
+	    return 0;
+	/* end points */
+	if (FEQUAL(ay1, by2, tol)) {
+	    *x1 = ax1;
+	    *y1 = ay1;
+	    G_debug(2, "   -> connected by end points");
+	    return 1;		/* endpoints only */
+	if (FEQUAL(ay2, by1, tol)) {
+	    *x1 = ax2;
+	    *y1 = ay2;
+	/* general overlap */
+	G_debug(3, "   -> vertical overlap");
+	if (ay1 <= by1 && ay2 >= by2) {
+	    G_debug(2, "    -> a contains b");
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = bx2;
+	    *y2 = by2;
+	    if (!switched)
+		return 3;
+	    else
+		return 4;
+	if (ay1 >= by1 && ay2 <= by2) {
+	    G_debug(2, "    -> b contains a");
+	    *x1 = ax1;
+	    *y1 = ay1;
+	    *x2 = ax2;
+	    *y2 = ay2;
+	    if (!switched)
+		return 4;
+	    else
+		return 3;
+	G_debug(2, "    -> partial overlap");
+	if (by1 > ay1 && by1 < ay2) {	/* b1 in a */
+	    if (!switched) {
+		*x1 = bx1;
+		*y1 = by1;
+		*x2 = ax2;
+		*y2 = ay2;
+	    else {
+		*x1 = ax2;
+		*y1 = ay2;
+		*x2 = bx1;
+		*y2 = by1;
+	    return 2;
+	if (by2 > ay1 && by2 < ay2) {	/* b2 in a */
+	    if (!switched) {
+		*x1 = bx2;
+		*y1 = by2;
+		*x2 = ax1;
+		*y2 = ay1;
+	    else {
+		*x1 = ax1;
+		*y1 = ay1;
+		*x2 = bx2;
+		*y2 = by2;
+	    return 2;
+	G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
+	G_warning("%.15g %.15g", ax1, ay1);
+	G_warning("%.15g %.15g", ax2, ay2);
+	G_warning("x");
+	G_warning("%.15g %.15g", bx1, by1);
+	G_warning("%.15g %.15g", bx2, by2);
+	return 0;
+    G_debug(2, "   -> collinear non vertical");
+    /* Collinear non vertical */
+    if ((bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2) ||
+	(bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2)) {
+	return 0;
+    G_debug(2, "   -> overlap/connected end points");
+    /* end points */
+    if ((ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2)) {
+	*x1 = ax1;
+	*y1 = ay1;
+	return 1;
+    if ((ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2)) {
+	*x1 = ax2;
+	*y1 = ay2;
+	return 1;
+    if (ax1 > ax2) {
+	t = ax1;
+	ax1 = ax2;
+	ax2 = t;
+	t = ay1;
+	ay1 = ay2;
+	ay2 = t;
+    }				/* to be sure that ax1 < ax2 */
+    if (bx1 > bx2) {
+	t = bx1;
+	bx1 = bx2;
+	bx2 = t;
+	t = by1;
+	by1 = by2;
+	by2 = t;
+    }				/* to be sure that bx1 < bx2 */
+    if (ax1 <= bx1 && ax2 >= bx2) {
+	*x1 = bx1;
+	*y1 = by1;
+	*x2 = bx2;
+	*y2 = by2;
+	if (!switched)
+	    return 3;
+	else
+	    return 4;
+    if (ax1 >= bx1 && ax2 <= bx2) {
+	*x1 = ax1;
+	*y1 = ay1;
+	*x2 = ax2;
+	*y2 = ay2;
+	if (!switched)
+	    return 4;
+	else
+	    return 3;
+    /* general overlap, 2 intersection points (lines are not vertical) */
+    if (bx1 > ax1 && bx1 < ax2) {	/* b1 is in a */
+	if (!switched) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = ax2;
+	    *y2 = ay2;
+	else {
+	    *x1 = ax2;
+	    *y1 = ay2;
+	    *x2 = bx1;
+	    *y2 = by1;
+	return 2;
+    if (bx2 > ax1 && bx2 < ax2) {	/* b2 is in a */
+	if (!switched) {
+	    *x1 = bx2;
+	    *y1 = by2;
+	    *x2 = ax1;
+	    *y2 = ay1;
+	else {
+	    *x1 = ax1;
+	    *y1 = ay1;
+	    *x2 = bx2;
+	    *y2 = by2;
+	return 2;
+    G_warning(("segment_intersection_2d() ERROR (collinear non vertical segments)"));
+    G_warning("x");
+    return 0;
+int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2,
+    const int DLEVEL = 4;
+    double t;
+    int vertical;
+    double d, da, db;
+    G_debug(DLEVEL, "segment_intersection_2d()");
+	G_debug(DLEVEL, "    identical segments");
+	*x1 = ax1;
+	*y1 = ay1;
+	*x2 = ax2;
+	*y2 = ay2;
+	return 5;
+    if (f11 || f12) {
+	G_debug(DLEVEL, "    connected by endpoints");
+	*x1 = ax1;
+	*y1 = ay1;
+	return 1;
+    if (f21 || f22) {
+	*x1 = ax2;
+	*y1 = ay2;
+	return 1;
+	G_debug(DLEVEL, "    no intersection (disjoint bounding boxes)");
+	return 0;
+	return 0;
+    d = D;
+    if (d != 0) {
+	G_debug(DLEVEL, "    general position");
+	da = DA;
+	if (d > 0) {
+	    if ((da < 0) || (da > d)) {
+		G_debug(DLEVEL, "        no intersection");
+		return 0;
+	    db = DB;
+	    if ((db < 0) || (db > d)) {
+		return 0;
+	else {			/* if d < 0 */
+	    if ((da > 0) || (da < d)) {
+		return 0;
+	    db = DB;
+	    if ((db > 0) || (db < d)) {
+		return 0;
+	/*G_debug(DLEVEL, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd)); */
+	/*G_debug(DLEVEL, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd)); */
+	*x1 = ax1 + (ax2 - ax1) * da / d;
+	*y1 = ay1 + (ay2 - ay1) * da / d;
+	G_debug(DLEVEL, "        intersection %.16g, %.16g", *x1, *y1);
+	return 1;
+    da = DA;
+    db = DB;
+    if ((da != 0) || (db != 0)) {
+	G_debug(DLEVEL, "    parallel segments");
+	return 0;
+    vertical = 0;
+    if (ax1 > ax2) {
+	SWAP(ax1, ax2);
+	SWAP(ay1, ay2);
+	vertical = 1;
+	if (ay1 > ay2)
+	    SWAP(ay1, ay2);
+	SWAP(ax1, ay1);
+	SWAP(ax2, ay2);
+    if (bx1 > bx2) {
+	SWAP(bx1, bx2);
+	SWAP(by1, by2);
+	if (by1 > by2)
+	    SWAP(by1, by2);
+	SWAP(bx1, by1);
+	SWAP(bx2, by2);
+    G_debug(DLEVEL, "    collinear segments");
+	return 0;
+    G_debug(DLEVEL, "        overlap");
+	G_debug(DLEVEL, "            a contains b");
+	if (!vertical) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = bx2;
+	    *y2 = by2;
+	else {
+	    *x1 = by1;
+	    *y1 = bx1;
+	    *x2 = by2;
+	    *y2 = bx2;
+	return 3;
+	G_debug(DLEVEL, "            b contains a");
+	if (!vertical) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = bx2;
+	    *y2 = by2;
+	else {
+	    *x1 = by1;
+	    *y1 = bx1;
+	    *x2 = by2;
+	    *y2 = bx2;
+	return 4;
+    G_debug(DLEVEL, "        partial overlap");
+	if (!vertical) {
+	    *x1 = bx1;
+	    *y1 = by1;
+	    *x2 = ax2;
+	    *y2 = ay2;
+	else {
+	    *x1 = by1;
+	    *y1 = bx1;
+	    *x2 = ay2;
+	    *y2 = ax2;
+	return 2;
+	if (!vertical) {
+	    *x1 = bx2;
+	    *y1 = by2;
+	    *x2 = ax1;
+	    *y2 = ay1;
+	else {
+	    *x1 = by2;
+	    *y1 = bx2;
+	    *x2 = ay1;
+	    *y2 = ax1;
+	return 2;
+    G_warning("x");
+    return 0;
+#define N 52			/* double's mantisa size in bits */
+/* a and b are different in at most <bits> significant digits */
+int almost_equal(double a, double b, int bits)
+    int ea, eb, e;
+    if (a == b)
+	return 1;
+    if (a == 0 || b == 0) {
+	/* return (0 < -N+bits); */
+	return (bits > N);
+    frexp(a, &ea);
+    frexp(b, &eb);
+    if (ea != eb)
+	return (bits > N + abs(ea - eb));
+    frexp(a - b, &e);
+    return (e < ea - N + bits);
+#ifdef ASDASDFASFEAS
+int segment_intersection_2d_test(double ax1, double ay1, double ax2,
+				 double *y1, double *x2, double *y2)
+    double t;
+    int vertical;
+    mp_exp_t exp;
+    char *s;
+    double d, da, db, ra, rb;
+    if (!initialized)
+    G_debug(3, "segment_intersection_2d_test()");
+    G_debug(3, "    ax1  = %.18e, ay1  = %.18e", ax1, ay1);
+    G_debug(3, "    ax2  = %.18e, ay2  = %.18e", ax2, ay2);
+    G_debug(3, "    bx1  = %.18e, by1  = %.18e", bx1, by1);
+    G_debug(3, "    bx2  = %.18e, by2  = %.18e", bx2, by2);
+	G_debug(4, "    identical segments");
+	*x1 = ax1;
+	*y1 = ay1;
+	*x2 = ax2;
+	*y2 = ay2;
+	return 5;
+    if (f11 || f12) {
+	G_debug(4, "    connected by endpoints");
+	*x1 = ax1;
+	*y1 = ay1;
+	return 1;
+    if (f21 || f22) {
+	*x1 = ax2;
+	*y1 = ay2;
+	return 1;
+	G_debug(4, "    no intersection (disjoint bounding boxes)");
+	return 0;
+	return 0;
+    da = (bx1 - ax1) * (by1 - by2) - (by1 - ay1) * (bx1 - bx2);
+    db = (ax2 - ax1) * (by1 - ay1) - (ay2 - ay1) * (bx1 - ax1);
+    s = mpf_get_str(NULL, &exp, 10, 40, dd);
+    G_debug(3, "    dd = %sE%d", (s[0] == 0) ? "0" : s, exp);
+    G_debug(3, "    d = %.18E", d);
+    if (sgn_d != 0) {
+	ra = da / d;
+	rb = db / d;
+	mpf_div(rra, dda, dd);
+	G_debug(4, "        rra = %sE%d", (s[0] == 0) ? "0" : s, exp);
+	G_debug(4, "        ra = %.18E", ra);
+	s = mpf_get_str(NULL, &exp, 10, 40, rrb);
+	G_debug(4, "        rrb = %sE%d", (s[0] == 0) ? "0" : s, exp);
+	G_debug(4, "        rb = %.18E", rb);
+	if (sgn_d > 0) {
+		return 0;
+		return 0;
+		return 0;
+		return 0;
+	G_debug(2, "        intersection at:");
+	G_debug(2, "            xx = %.18e", *x1);
+	G_debug(2, "             x = %.18e", ax1 + ra * (ax2 - ax1));
+	G_debug(2, "            yy = %.18e", *y1);
+	G_debug(2, "             y = %.18e", ay1 + ra * (ay2 - ay1));
+	return 1;
+    G_debug(3, "    parallel/collinear...");
+    return -1;
+#endif
Copied: grass/trunk/lib/vector/Vlib/e_intersect.h (from rev 34601, grass/branches/develbranch_6/lib/vector/Vlib/e_intersect.h)
--- grass/trunk/lib/vector/Vlib/e_intersect.h	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/e_intersect.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -0,0 +1,21 @@
+#ifndef GRASS_E_INTERSECT_H
+#define GRASS_E_INTERSECT_H
+#define FZERO(X, TOL) (fabs(X)<TOL)
+#define FEQUAL(X, Y, TOL) (fabs(X-Y)<TOL)
+/*int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+    double *x1, double *y1, double *x2, double *y2);
+int segment_intersection_2d_test(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+    double *x1, double *y1, double *x2, double *y2);*/
+int segment_intersection_2d_tol(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+    double *x1, double *y1, double *x2, double *y2, double tol);
+int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
+int almost_equal(double a, double b, int bits);
+#endif
Deleted: grass/trunk/vector/v.buffer2/dgraph.c
--- grass/trunk/vector/v.buffer2/dgraph.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.buffer2/dgraph.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,521 +0,0 @@
-#include <stdlib.h>
-#include <grass/Vect.h>
-#include <grass/gis.h>
-#include "dgraph.h"
-#include "e_intersect.h"
-#define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
-#ifndef MIN
-#define MIN(X,Y) ((X<Y)?X:Y)
-#endif
-#ifndef MAX
-#define MAX(X,Y) ((X>Y)?X:Y)
-#endif
-#define PI M_PI
-struct intersection_point
-    double x;
-    double y;
-    int group;			/* IPs with very similar dist will be in the same group */
-struct seg_intersection
-    int with;			/* second segment */
-    int ip;			/* index of the IP */
-    double dist;		/* distance from first point of first segment to intersection point (IP) */
-struct seg_intersection_list
-    int count;
-    int allocated;
-    struct seg_intersection *a;
-struct seg_intersections
-    int ipcount;
-    int ipallocated;
-    struct intersection_point *ip;
-    int ilcount;
-    struct seg_intersection_list *il;
-    int group_count;
-struct seg_intersections *create_si_struct(int segments_count)
-    struct seg_intersections *si;
-    int i;
-    si = G_malloc(sizeof(struct seg_intersections));
-    si->ipcount = 0;
-    si->ipallocated = segments_count + 16;
-    si->ip = G_malloc((si->ipallocated) * sizeof(struct intersection_point));
-    si->ilcount = segments_count;
-    si->il = G_malloc(segments_count * sizeof(struct seg_intersection_list));
-    for (i = 0; i < segments_count; i++) {
-	si->il[i].count = 0;
-	si->il[i].allocated = 0;
-	si->il[i].a = NULL;
-    return si;
-void destroy_si_struct(struct seg_intersections *si)
-    int i;
-    for (i = 0; i < si->ilcount; i++)
-	G_free(si->il[i].a);
-    G_free(si->il);
-    G_free(si->ip);
-    G_free(si);
-    return;
-/* internal use */
-void add_ipoint1(struct seg_intersection_list *il, int with, double dist,
-		 int ip)
-    struct seg_intersection *s;
-    if (il->count == il->allocated) {
-	il->allocated += 4;
-	il->a =
-	    G_realloc(il->a,
-		      (il->allocated) * sizeof(struct seg_intersection));
-    s = &(il->a[il->count]);
-    s->with = with;
-    s->ip = ip;
-    s->dist = dist;
-    il->count++;
-    return;
-/* adds intersection point to the structure */
-void add_ipoint(struct line_pnts *Points, int first_seg, int second_seg,
-		double x, double y, struct seg_intersections *si)
-    struct intersection_point *t;
-    int ip;
-    G_debug(4, "add_ipoint()");
-    if (si->ipcount == si->ipallocated) {
-	si->ipallocated += 16;
-	si->ip =
-	    G_realloc(si->ip,
-		      (si->ipallocated) * sizeof(struct intersection_point));
-    ip = si->ipcount;
-    t = &(si->ip[ip]);
-    t->x = x;
-    t->y = y;
-    t->group = -1;
-    si->ipcount++;
-    add_ipoint1(&(si->il[first_seg]), second_seg,
-		LENGTH((Points->x[first_seg] - x),
-		       (Points->y[first_seg] - y)), ip);
-    if (second_seg >= 0)
-	add_ipoint1(&(si->il[second_seg]), first_seg,
-		    LENGTH((Points->x[second_seg] - x),
-			   (Points->y[second_seg] - y)), ip);
-void sort_intersection_list(struct seg_intersection_list *il)
-    int n, i, j, min;
-    struct seg_intersection t;
-    G_debug(4, "sort_intersection_list()");
-    n = il->count;
-    G_debug(4, "    n=%d", n);
-    for (i = 0; i < n - 1; i++) {
-	min = i;
-	for (j = i + 1; j < n; j++) {
-	    if (il->a[j].dist < il->a[min].dist) {
-		min = j;
-	if (min != i) {
-	    t = il->a[i];
-	    il->a[i] = il->a[min];
-	    il->a[min] = t;
-    return;
-static int compare(const void *a, const void *b)
-    struct intersection_point *aa, *bb;
-    aa = *((struct intersection_point **)a);
-    bb = *((struct intersection_point **)b);
-    if (aa->x < bb->x)
-	return -1;
-    else if (aa->x > bb->x)
-	return 1;
-    else
-	return (aa->y < bb->y) ? -1 : ((aa->y > bb->y) ? 1 : 0);
-/* O(Points->n_points) time */
-double get_epsilon(struct line_pnts *Points)
-    int i, np;
-    double min, t;
-    double *x, *y;
-    np = Points->n_points;
-    x = Points->x;
-    y = Points->y;
-    min = MAX(fabs(x[1] - x[0]), fabs(y[1] - y[0]));
-    for (i = 1; i <= np - 2; i++) {
-	t = MAX(fabs(x[i + 1] - x[i]), fabs(y[i + 1] - y[i]));
-	if ((t > 0) && (t < min)) {
-	    min = t;
-    /* ??? is 0.001 ok ??? */
-    return min * 0.000001;
-/* currently O(n*n); future implementation O(nlogn) */
-struct seg_intersections *find_all_intersections(struct line_pnts *Points)
-    int i, j, np;
-    int group, t;
-    int looped;
-    double EPSILON = 0.00000001;
-    double *x, *y;
-    double x1, y1, x2, y2;
-    int res;
-    /*int res2
-       double x1_, y1_, x2_, y2_, z1_, z2_; */
-    struct intersection_point **sorted;
-    G_debug(3, "find_all_intersections()");
-    x = Points->x;
-    y = Points->y;
-    si = create_si_struct(np - 1);
-    looped = ((x[0] == x[np - 1]) && (y[0] == y[np - 1]));
-    G_debug(3, "    looped=%d", looped);
-    G_debug(3, "    finding intersections...");
-    for (i = 0; i < np - 1; i++) {
-	for (j = i + 1; j < np - 1; j++) {
-	    G_debug(4, "        checking %d-%d %d-%d", i, i + 1, j, j + 1);
-	    /*res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2); */
-	    res =
-		segment_intersection_2d(x[i], y[i], x[i + 1], y[i + 1], x[j],
-					y[j], x[j + 1], y[j + 1], &x1, &y1,
-					&x2, &y2);
-	    /*            res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
-	       if ((res != res2) || ((res != 0) && (x1!=x1_ || y1!=y1_)) ) {
-	       G_debug(0, "exact=%d orig=%d", res, res2);
-	       segment_intersection_2d_test(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
-	    G_debug(4, "        intersection type = %d", res);
-	    if (res == 1) {
-		add_ipoint(Points, i, j, x1, y1, si);
-	    else if ((res >= 2) && (res <= 5)) {
-		add_ipoint(Points, i, j, x2, y2, si);
-    if (!looped) {
-	/* these are not really intersection points */
-	add_ipoint(Points, 0, -1, Points->x[0], Points->y[0], si);
-	add_ipoint(Points, np - 2, -1, Points->x[np - 1], Points->y[np - 1],
-		   si);
-    G_debug(3, "    finding intersections...done");
-    G_debug(3, "    postprocessing...");
-    if (si->ipallocated > si->ipcount) {
-	si->ipallocated = si->ipcount;
-	si->ip =
-	    G_realloc(si->ip,
-		      (si->ipcount) * sizeof(struct intersection_point));
-    for (i = 0; i < si->ilcount; i++) {
-	il = &(si->il[i]);
-	if (il->allocated > il->count) {
-	    il->allocated = il->count;
-	    il->a =
-		G_realloc(il->a,
-			  (il->count) * sizeof(struct seg_intersection));
-	if (il->count > 0) {
-	    sort_intersection_list(il);
-	    /* is it ok to use qsort here ? */
-    /* si->ip will not be reallocated any more so we can use pointers */
-    sorted = G_malloc((si->ipcount) * sizeof(struct intersection_point *));
-    for (i = 0; i < si->ipcount; i++)
-	sorted[i] = &(si->ip[i]);
-    qsort(sorted, si->ipcount, sizeof(struct intersection_point *), compare);
-    /* assign groups */
-    group = 0;			/* next available group number */
-    for (i = 0; i < si->ipcount; i++) {
-	t = group;
-	for (j = i - 1; j >= 0; j--) {
-	    if (!FEQUAL(sorted[j]->x, sorted[i]->x, EPSILON))
-		/*            if (!almost_equal(sorted[j]->x, sorted[i]->x, 16)) */
-		break;
-	    if (FEQUAL(sorted[j]->y, sorted[i]->y, EPSILON)) {
-		/*            if (almost_equal(sorted[j]->y, sorted[i]->y, 16)) { */
-		t = sorted[j]->group;
-		break;
-	G_debug(4, "        group=%d, ip=%d", t,
-		(int)(sorted[i] - &(si->ip[0])));
-	sorted[i]->group = t;
-	if (t == group)
-	    group++;
-    si->group_count = group;
-    G_debug(3, "    postprocessing...done");
-    /* output contents of si */
-	G_debug(4, "%d-%d :", i, i + 1);
-	for (j = 0; j < si->il[i].count; j++) {
-	    G_debug(4, "     %d-%d, group=%d", si->il[i].a[j].with,
-		    si->il[i].a[j].with + 1, si->ip[si->il[i].a[j].ip].group);
-	    G_debug(4, "            dist=%.18f", si->il[i].a[j].dist);
-	    G_debug(4, "            x=%.18f, y=%.18f",
-		    si->ip[si->il[i].a[j].ip].x, si->ip[si->il[i].a[j].ip].y);
-    return si;
-/* create's graph with n vertices and allocates memory for e edges */
-/* trying to add more than e edges, produces fatal error */
-struct planar_graph *pg_create_struct(int n, int e)
-    struct planar_graph *pg;
-    pg = G_malloc(sizeof(struct planar_graph));
-    pg->vcount = n;
-    pg->v = G_malloc(n * sizeof(struct pg_vertex));
-    memset(pg->v, 0, n * sizeof(struct pg_vertex));
-    pg->ecount = 0;
-    pg->eallocated = MAX(e, 0);
-    pg->e = NULL;
-    pg->e = G_malloc(e * sizeof(struct pg_edge));
-    return pg;
-void pg_destroy_struct(struct planar_graph *pg)
-    int i;
-    for (i = 0; i < pg->vcount; i++) {
-	G_free(pg->v[i].edges);
-	G_free(pg->v[i].angles);
-    G_free(pg->v);
-    G_free(pg->e);
-    G_free(pg);
-/* v1 and v2 must be valid */
-int pg_existsedge(struct planar_graph *pg, int v1, int v2)
-    struct pg_vertex *v;
-    struct pg_edge *e;
-    int i, ecount;
-    if (pg->v[v1].ecount <= pg->v[v2].ecount)
-	v = &(pg->v[v1]);
-    else
-	v = &(pg->v[v2]);
-    ecount = v->ecount;
-    for (i = 0; i < ecount; i++) {
-	e = v->edges[i];
-	if (((e->v1 == v1) && (e->v2 == v2)) ||
-	    ((e->v1 == v2) && (e->v2 == v1)))
-	    return 1;
-    return 0;
-/* for internal use */
-void pg_addedge1(struct pg_vertex *v, struct pg_edge *e)
-    if (v->ecount == v->eallocated) {
-	v->eallocated += 4;
-	v->edges =
-	    G_realloc(v->edges, (v->eallocated) * sizeof(struct pg_edge *));
-    v->edges[v->ecount] = e;
-    v->ecount++;
-void pg_addedge(struct planar_graph *pg, int v1, int v2)
-    G_debug(4, "pg_addedge(), v1=%d, v2=%d", v1, v2);
-    if ((v1 == v2) || (v1 < 0) || (v1 >= pg->vcount) || (v2 < 0) ||
-	(v2 >= pg->vcount)) {
-	G_fatal_error("    pg_addedge(), v1 and/or v2 is invalid");
-	return;
-    if (pg_existsedge(pg, v1, v2))
-	return;
-    if (pg->ecount == pg->eallocated) {
-	G_fatal_error
-	    ("Trying to add more edges to the planar_graph than the initial allocation size allows");
-    e = &(pg->e[pg->ecount]);
-    e->v1 = v1;
-    e->v2 = v2;
-    e->winding_left = 0;	/* winding is undefined if the corresponding side is not visited */
-    e->winding_right = 0;
-    e->visited_left = 0;
-    e->visited_right = 0;
-    pg->ecount++;
-    pg_addedge1(&(pg->v[v1]), e);
-    pg_addedge1(&(pg->v[v2]), e);
-    return;
-struct planar_graph *pg_create(struct line_pnts *Points)
-    struct pg_vertex *vert;
-    struct pg_edge *edge;
-    int i, j, t, v;
-    G_debug(3, "pg_create()");
-    si = find_all_intersections(Points);
-    pg = pg_create_struct(si->group_count, 2 * (si->ipcount));
-    /* set vertices info */
-	ip = &(si->ip[i]);
-	t = ip->group;
-	pg->v[t].x = ip->x;
-	pg->v[t].y = ip->y;
-    /* add all edges */
-	v = si->ip[si->il[i].a[0].ip].group;
-	for (j = 1; j < si->il[i].count; j++) {
-	    t = si->ip[si->il[i].a[j].ip].group;
-	    if (t != v) {
-		pg_addedge(pg, v, t);	/* edge direction is v ---> t */
-		v = t;
-    /* precalculate angles with 0x */
-	vert = &(pg->v[i]);
-	vert->angles = G_malloc((vert->ecount) * sizeof(double));
-	for (j = 0; j < vert->ecount; j++) {
-	    edge = vert->edges[j];
-	    t = (edge->v1 != i) ? (edge->v1) : (edge->v2);
-	    vert->angles[j] =
-		atan2(pg->v[t].y - vert->y, pg->v[t].x - vert->x);
-    destroy_si_struct(si);
-       I'm not sure if shrinking of the allocated memory always preserves it's physical place.
-       That's why I don't want to do this:
-       if (pg->ecount < pg->eallocated) {
-       pg->eallocated = pg->ecount;
-       pg->e = G_realloc(pg->e, (pg->ecount)*sizeof(struct pg_edge));
-    /* very time consuming */
-       if (pg->v[i].ecount < pg->v[i].eallocated) {
-       pg->v[i].eallocated = pg->v[i].ecount;
-       pg->v[i].edges = G_realloc(pg->v[i].edges, (pg->v[i].ecount)*sizeof(struct pg_edges));
-    /* output pg */
-	G_debug(4, "    vertex %d (%g, %g)", i, pg->v[i].x, pg->v[i].y);
-	for (j = 0; j < pg->v[i].ecount; j++) {
-	    G_debug(4, "        edge %d-%d", pg->v[i].edges[j]->v1,
-		    pg->v[i].edges[j]->v2);
-    return pg;
Deleted: grass/trunk/vector/v.buffer2/dgraph.h
--- grass/trunk/vector/v.buffer2/dgraph.h	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.buffer2/dgraph.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,38 +0,0 @@
-#ifndef DGRAPH_H
-#define DGRAPH_H
-/* pg comes from "planar graph" */
-/* every edge is directed. Nevertheless, we can visit it on both sides */
-struct pg_edge {
-    int v1; /* first vertex */
-    int v2; /* second vertex */
-    char visited_left;
-    char visited_right;
-    char winding_left; /* winding numbers */
-    char winding_right;
-struct pg_vertex {
-    double x; /* coordinates */
-    double y;
-    int ecount; /* number of neighbours */
-    int eallocated; /* size of the array bellow */
-    struct pg_edge **edges; /* array of pointers */
-    double *angles; /* precalculated angles with Ox */
-struct planar_graph {
-    int vcount; /* number of vertices */
-    int ecount;
-    int eallocated;
-struct planar_graph* pg_create_struct(int n, int e);
-void pg_destroy_struct(struct planar_graph *pg);
-int pg_existsedge(struct planar_graph *pg, int v1, int v2);
-void pg_addedge(struct planar_graph *pg, int v1, int v2);
-struct planar_graph* pg_create(struct line_pnts *Points);
-#endif
Deleted: grass/trunk/vector/v.buffer2/e_intersect.c
--- grass/trunk/vector/v.buffer2/e_intersect.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.buffer2/e_intersect.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,1077 +0,0 @@
-#include <math.h>
-#define SWAP(a,b) {t = a; a = b; b = t;}
-#ifndef MIN
-#endif
-#ifndef MAX
-#endif
-#define D (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2)
-#define DA (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2)
-#define DB (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1)
-#ifdef ASDASDASFDSAFFDAS
-mpf_t p11, p12, p21, p22, t1, t2;
-mpf_t dd, dda, ddb, delta;
-mpf_t rra, rrb;
-int initialized = 0;
-void initialize_mpf_vars()
-    mpf_set_default_prec(2048);
-    mpf_init(p11);
-    mpf_init(p12);
-    mpf_init(p21);
-    mpf_init(p22);
-    mpf_init(t1);
-    mpf_init(t2);
-    mpf_init(dd);
-    mpf_init(dda);
-    mpf_init(ddb);
-    mpf_init(delta);
-    mpf_init(rra);
-    mpf_init(rrb);
-    initialized = 1;
-   Caclulates:
-   |a11-b11  a12-b12|
-   |a21-b21  a22-b22|
-void det22(mpf_t rop, double a11, double b11, double a12, double b12,
-	   double a21, double b21, double a22, double b22)
-    mpf_set_d(t1, a11);
-    mpf_set_d(t2, b11);
-    mpf_sub(p11, t1, t2);
-    mpf_set_d(t1, a12);
-    mpf_set_d(t2, b12);
-    mpf_sub(p12, t1, t2);
-    mpf_set_d(t1, a21);
-    mpf_set_d(t2, b21);
-    mpf_sub(p21, t1, t2);
-    mpf_set_d(t1, a22);
-    mpf_set_d(t2, b22);
-    mpf_sub(p22, t1, t2);
-    mpf_mul(t1, p11, p22);
-    mpf_mul(t2, p12, p21);
-    mpf_sub(rop, t1, t2);
-    return;
-void swap(double *a, double *b)
-    double t = *a;
-    *a = *b;
-    *b = t;
-    return;
-/* multi-precision version */
-int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2,
-			      double bx1, double by1, double bx2, double by2,
-			      double *x1, double *y1, double *x2, double *y2)
-    double t;
-    double max_ax, min_ax, max_ay, min_ay;
-    double max_bx, min_bx, max_by, min_by;
-    int sgn_d, sgn_da, sgn_db;
-    int vertical;
-    int f11, f12, f21, f22;
-    mp_exp_t exp;
-    char *s;
-    if (!initialized)
-	initialize_mpf_vars();
-    /* TODO: Works for points ? */
-    G_debug(3, "segment_intersection_2d_e()");
-    G_debug(4, "    ax1  = %.18f, ay1  = %.18f", ax1, ay1);
-    G_debug(4, "    ax2  = %.18f, ay2  = %.18f", ax2, ay2);
-    G_debug(4, "    bx1  = %.18f, by1  = %.18f", bx1, by1);
-    G_debug(4, "    bx2  = %.18f, by2  = %.18f", bx2, by2);
-    f11 = ((ax1 == bx1) && (ay1 == by1));
-    f12 = ((ax1 == bx2) && (ay1 == by2));
-    f21 = ((ax2 == bx1) && (ay2 == by1));
-    f22 = ((ax2 == bx2) && (ay2 == by2));
-    /* Check for identical segments */
-    if ((f11 && f22) || (f12 && f21)) {
-	G_debug(3, "    identical segments");
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    /* Check for identical endpoints */
-    if (f11 || f12) {
-	G_debug(3, "    connected by endpoints");
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if (f21 || f22) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-    if ((MAX(ax1, ax2) < MIN(bx1, bx2)) || (MAX(bx1, bx2) < MIN(ax1, ax2))) {
-	G_debug(3, "    no intersection (disjoint bounding boxes)");
-	return 0;
-    if ((MAX(ay1, ay2) < MIN(by1, by2)) || (MAX(by1, by2) < MIN(ay1, ay2))) {
-	return 0;
-    det22(dd, ax2, ax1, bx1, bx2, ay2, ay1, by1, by2);
-    sgn_d = mpf_sgn(dd);
-    if (sgn_d != 0) {
-	G_debug(3, "    general position");
-	det22(dda, bx1, ax1, bx1, bx2, by1, ay1, by1, by2);
-	sgn_da = mpf_sgn(dda);
-	/*mpf_div(rra, dda, dd);
-	   mpf_div(rrb, ddb, dd);
-	   s = mpf_get_str(NULL, &exp, 10, 40, rra);
-	   G_debug(4, "        ra = %sE%d", (s[0]==0)?"0":s, exp);
-	   s = mpf_get_str(NULL, &exp, 10, 24, rrb);
-	   G_debug(4, "        rb = %sE%d", (s[0]==0)?"0":s, exp);
-	if (sgn_d > 0) {
-	    if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
-		G_debug(3, "        no intersection");
-		return 0;
-	    det22(ddb, ax2, ax1, bx1, ax1, ay2, ay1, by1, ay1);
-	    sgn_db = mpf_sgn(ddb);
-	    if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
-		return 0;
-	else {			/* if sgn_d < 0 */
-	    if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
-		return 0;
-	    if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
-		return 0;
-	/*G_debug(3, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd)); */
-	/*G_debug(3, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd)); */
-	mpf_set_d(delta, ax2 - ax1);
-	mpf_mul(t1, dda, delta);
-	mpf_div(t2, t1, dd);
-	*x1 = ax1 + mpf_get_d(t2);
-	mpf_set_d(delta, ay2 - ay1);
-	*y1 = ay1 + mpf_get_d(t2);
-	G_debug(3, "        intersection %.16g, %.16g", *x1, *y1);
-	return 1;
-    /* segments are parallel or collinear */
-    if (sgn_da != 0) {
-	/* segments are parallel */
-	G_debug(3, "    parallel segments");
-	return 0;
-    /* segments are colinear. check for overlap */
-    /* swap endpoints if needed */
-    /* if segments are vertical, we swap x-coords with y-coords */
-    vertical = 0;
-    if (ax1 > ax2) {
-	SWAP(ax1, ax2);
-	SWAP(ay1, ay2);
-    else if (ax1 == ax2) {
-	vertical = 1;
-	if (ay1 > ay2)
-	    SWAP(ay1, ay2);
-	SWAP(ax1, ay1);
-	SWAP(ax2, ay2);
-    if (bx1 > bx2) {
-	SWAP(bx1, bx2);
-	SWAP(by1, by2);
-    else if (bx1 == bx2) {
-	if (by1 > by2)
-	    SWAP(by1, by2);
-	SWAP(bx1, by1);
-	SWAP(bx2, by2);
-    G_debug(3, "    collinear segments");
-    if ((bx2 < ax1) || (bx1 > ax2)) {
-	return 0;
-    /* there is overlap or connected end points */
-    G_debug(3, "        overlap");
-    /* a contains b */
-    if ((ax1 < bx1) && (ax2 > bx2)) {
-	G_debug(3, "            a contains b");
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 3;
-    /* b contains a */
-    if ((ax1 > bx1) && (ax2 < bx2)) {
-	G_debug(3, "            b contains a");
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 4;
-    /* general overlap, 2 intersection points */
-    G_debug(3, "        partial overlap");
-    if ((bx1 > ax1) && (bx1 < ax2)) {	/* b1 is in a */
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = ay2;
-	    *y2 = ax2;
-	return 2;
-    if ((bx2 > ax1) && (bx2 < ax2)) {	/* b2 is in a */
-	if (!vertical) {
-	    *x1 = bx2;
-	    *y1 = by2;
-	    *x2 = ax1;
-	    *y2 = ay1;
-	else {
-	    *x1 = by2;
-	    *y1 = bx2;
-	    *x2 = ay1;
-	    *y2 = ax1;
-	return 2;
-    /* should not be reached */
-    G_warning(("segment_intersection_2d() ERROR (should not be reached)"));
-    G_warning("%.16g %.16g", ax1, ay1);
-    G_warning("%.16g %.16g", ax2, ay2);
-    G_warning("x");
-    G_warning("%.16g %.16g", bx1, by1);
-    G_warning("%.16g %.16g", bx2, by2);
-    return 0;
-#endif
-/* OLD */
-/* tollerance aware version */
-/* TODO: fix all ==s left */
-int segment_intersection_2d_tol(double ax1, double ay1, double ax2,
-				double ay2, double bx1, double by1,
-				double bx2, double by2, double *x1,
-				double *y1, double *x2, double *y2,
-				double tol)
-    double tola, tolb;
-    double d, d1, d2, ra, rb, t;
-    int switched = 0;
-    G_debug(4, "segment_intersection_2d()");
-    /* Check identical lines */
-    if ((FEQUAL(ax1, bx1, tol) && FEQUAL(ay1, by1, tol) &&
-	 FEQUAL(ax2, bx2, tol) && FEQUAL(ay2, by2, tol)) ||
-	(FEQUAL(ax1, bx2, tol) && FEQUAL(ay1, by2, tol) &&
-	 FEQUAL(ax2, bx1, tol) && FEQUAL(ay2, by1, tol))) {
-	G_debug(2, " -> identical segments");
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    /*  'Sort' lines by x1, x2, y1, y2 */
-    if (bx1 < ax1)
-	switched = 1;
-    else if (bx1 == ax1) {
-	if (bx2 < ax2)
-	    switched = 1;
-	else if (bx2 == ax2) {
-	    if (by1 < ay1)
-		switched = 1;
-	    else if (by1 == ay1) {
-		if (by2 < ay2)
-		    switched = 1;	/* by2 != ay2 (would be identical */
-    if (switched) {
-	t = ax1;
-	ax1 = bx1;
-	bx1 = t;
-	t = ay1;
-	ay1 = by1;
-	by1 = t;
-	t = ax2;
-	ax2 = bx2;
-	bx2 = t;
-	t = ay2;
-	ay2 = by2;
-	by2 = t;
-    d = (ax2 - ax1) * (by1 - by2) - (ay2 - ay1) * (bx1 - bx2);
-    d1 = (bx1 - ax1) * (by1 - by2) - (by1 - ay1) * (bx1 - bx2);
-    d2 = (ax2 - ax1) * (by1 - ay1) - (ay2 - ay1) * (bx1 - ax1);
-    G_debug(2, "    d  = %.18g", d);
-    G_debug(2, "    d1 = %.18g", d1);
-    G_debug(2, "    d2 = %.18g", d2);
-    tola = tol / MAX(fabs(ax2 - ax1), fabs(ay2 - ay1));
-    tolb = tol / MAX(fabs(bx2 - bx1), fabs(by2 - by1));
-    G_debug(2, "    tol  = %.18g", tol);
-    G_debug(2, "    tola = %.18g", tola);
-    G_debug(2, "    tolb = %.18g", tolb);
-    if (!FZERO(d, tol)) {
-	ra = d1 / d;
-	rb = d2 / d;
-	G_debug(2, "    not parallel/collinear: ra = %.18g", ra);
-	G_debug(2, "                            rb = %.18g", rb);
-	if ((ra <= -tola) || (ra >= 1 + tola) || (rb <= -tolb) ||
-	    (rb >= 1 + tolb)) {
-	    G_debug(2, "        no intersection");
-	    return 0;
-	ra = MIN(MAX(ra, 0), 1);
-	*x1 = ax1 + ra * (ax2 - ax1);
-	*y1 = ay1 + ra * (ay2 - ay1);
-	G_debug(2, "        intersection %.18f, %.18f", *x1, *y1);
-	return 1;
-    G_debug(3, " -> parallel/collinear");
-    if ((!FZERO(d1, tol)) || (!FZERO(d2, tol))) {	/* lines are parallel */
-	G_debug(2, "  -> parallel");
-	return 0;
-    /*    aa = adx*adx + ady*ady;
-       bb = bdx*bdx + bdy*bdy;
-       t = (ax1-bx1)*bdx + (ay1-by1)*bdy; */
-    /* Collinear vertical */
-    /* original code assumed lines were not both vertical
-     *  so there is a special case if they are */
-    if (FEQUAL(ax1, ax2, tol) && FEQUAL(bx1, bx2, tol) &&
-	FEQUAL(ax1, bx1, tol)) {
-	G_debug(2, "  -> collinear vertical");
-	if (ay1 > ay2) {
-	    t = ay1;
-	    ay1 = ay2;
-	    ay2 = t;
-	}			/* to be sure that ay1 < ay2 */
-	if (by1 > by2) {
-	    t = by1;
-	    by1 = by2;
-	    by2 = t;
-	}			/* to be sure that by1 < by2 */
-	if (ay1 > by2 || ay2 < by1) {
-	    G_debug(2, "   -> no intersection");
-	    return 0;
-	/* end points */
-	if (FEQUAL(ay1, by2, tol)) {
-	    *x1 = ax1;
-	    *y1 = ay1;
-	    G_debug(2, "   -> connected by end points");
-	    return 1;		/* endpoints only */
-	if (FEQUAL(ay2, by1, tol)) {
-	    *x1 = ax2;
-	    *y1 = ay2;
-	/* general overlap */
-	G_debug(3, "   -> vertical overlap");
-	if (ay1 <= by1 && ay2 >= by2) {
-	    G_debug(2, "    -> a contains b");
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	    if (!switched)
-		return 3;
-	    else
-		return 4;
-	if (ay1 >= by1 && ay2 <= by2) {
-	    G_debug(2, "    -> b contains a");
-	    *x1 = ax1;
-	    *y1 = ay1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	    if (!switched)
-		return 4;
-	    else
-		return 3;
-	G_debug(2, "    -> partial overlap");
-	if (by1 > ay1 && by1 < ay2) {	/* b1 in a */
-	    if (!switched) {
-		*x1 = bx1;
-		*y1 = by1;
-		*x2 = ax2;
-		*y2 = ay2;
-	    else {
-		*x1 = ax2;
-		*y1 = ay2;
-		*x2 = bx1;
-		*y2 = by1;
-	    return 2;
-	if (by2 > ay1 && by2 < ay2) {	/* b2 in a */
-	    if (!switched) {
-		*x1 = bx2;
-		*y1 = by2;
-		*x2 = ax1;
-		*y2 = ay1;
-	    else {
-		*x1 = ax1;
-		*y1 = ay1;
-		*x2 = bx2;
-		*y2 = by2;
-	    return 2;
-	G_warning(("Vect_segment_intersection() ERROR (collinear vertical segments)"));
-	G_warning("%.15g %.15g", ax1, ay1);
-	G_warning("%.15g %.15g", ax2, ay2);
-	G_warning("x");
-	G_warning("%.15g %.15g", bx1, by1);
-	G_warning("%.15g %.15g", bx2, by2);
-	return 0;
-    G_debug(2, "   -> collinear non vertical");
-    /* Collinear non vertical */
-    if ((bx1 > ax1 && bx2 > ax1 && bx1 > ax2 && bx2 > ax2) ||
-	(bx1 < ax1 && bx2 < ax1 && bx1 < ax2 && bx2 < ax2)) {
-	return 0;
-    G_debug(2, "   -> overlap/connected end points");
-    /* end points */
-    if ((ax1 == bx1 && ay1 == by1) || (ax1 == bx2 && ay1 == by2)) {
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if ((ax2 == bx1 && ay2 == by1) || (ax2 == bx2 && ay2 == by2)) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-    if (ax1 > ax2) {
-	t = ax1;
-	ax1 = ax2;
-	ax2 = t;
-	t = ay1;
-	ay1 = ay2;
-	ay2 = t;
-    }				/* to be sure that ax1 < ax2 */
-    if (bx1 > bx2) {
-	t = bx1;
-	bx1 = bx2;
-	bx2 = t;
-	t = by1;
-	by1 = by2;
-	by2 = t;
-    }				/* to be sure that bx1 < bx2 */
-    if (ax1 <= bx1 && ax2 >= bx2) {
-	*x1 = bx1;
-	*y1 = by1;
-	*x2 = bx2;
-	*y2 = by2;
-	if (!switched)
-	    return 3;
-	else
-	    return 4;
-    if (ax1 >= bx1 && ax2 <= bx2) {
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	if (!switched)
-	    return 4;
-	else
-	    return 3;
-    /* general overlap, 2 intersection points (lines are not vertical) */
-    if (bx1 > ax1 && bx1 < ax2) {	/* b1 is in a */
-	if (!switched) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	else {
-	    *x1 = ax2;
-	    *y1 = ay2;
-	    *x2 = bx1;
-	    *y2 = by1;
-	return 2;
-    if (bx2 > ax1 && bx2 < ax2) {	/* b2 is in a */
-	if (!switched) {
-	    *x1 = bx2;
-	    *y1 = by2;
-	    *x2 = ax1;
-	    *y2 = ay1;
-	else {
-	    *x1 = ax1;
-	    *y1 = ay1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	return 2;
-    G_warning(("segment_intersection_2d() ERROR (collinear non vertical segments)"));
-    G_warning("x");
-    return 0;
-int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2,
-    const int DLEVEL = 4;
-    double t;
-    int vertical;
-    double d, da, db;
-    G_debug(DLEVEL, "segment_intersection_2d()");
-	G_debug(DLEVEL, "    identical segments");
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    if (f11 || f12) {
-	G_debug(DLEVEL, "    connected by endpoints");
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if (f21 || f22) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-	G_debug(DLEVEL, "    no intersection (disjoint bounding boxes)");
-	return 0;
-	return 0;
-    d = D;
-    if (d != 0) {
-	G_debug(DLEVEL, "    general position");
-	da = DA;
-	if (d > 0) {
-	    if ((da < 0) || (da > d)) {
-		G_debug(DLEVEL, "        no intersection");
-		return 0;
-	    db = DB;
-	    if ((db < 0) || (db > d)) {
-		return 0;
-	else {			/* if d < 0 */
-	    if ((da > 0) || (da < d)) {
-		return 0;
-	    db = DB;
-	    if ((db > 0) || (db < d)) {
-		return 0;
-	/*G_debug(DLEVEL, "        ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd)); */
-	/*G_debug(DLEVEL, "        sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd)); */
-	*x1 = ax1 + (ax2 - ax1) * da / d;
-	*y1 = ay1 + (ay2 - ay1) * da / d;
-	G_debug(DLEVEL, "        intersection %.16g, %.16g", *x1, *y1);
-	return 1;
-    da = DA;
-    db = DB;
-    if ((da != 0) || (db != 0)) {
-	G_debug(DLEVEL, "    parallel segments");
-	return 0;
-    vertical = 0;
-    if (ax1 > ax2) {
-	SWAP(ax1, ax2);
-	SWAP(ay1, ay2);
-	vertical = 1;
-	if (ay1 > ay2)
-	    SWAP(ay1, ay2);
-	SWAP(ax1, ay1);
-	SWAP(ax2, ay2);
-    if (bx1 > bx2) {
-	SWAP(bx1, bx2);
-	SWAP(by1, by2);
-	if (by1 > by2)
-	    SWAP(by1, by2);
-	SWAP(bx1, by1);
-	SWAP(bx2, by2);
-    G_debug(DLEVEL, "    collinear segments");
-	return 0;
-    G_debug(DLEVEL, "        overlap");
-	G_debug(DLEVEL, "            a contains b");
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 3;
-	G_debug(DLEVEL, "            b contains a");
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 4;
-    G_debug(DLEVEL, "        partial overlap");
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = ay2;
-	    *y2 = ax2;
-	return 2;
-	if (!vertical) {
-	    *x1 = bx2;
-	    *y1 = by2;
-	    *x2 = ax1;
-	    *y2 = ay1;
-	else {
-	    *x1 = by2;
-	    *y1 = bx2;
-	    *x2 = ay1;
-	    *y2 = ax1;
-	return 2;
-    G_warning("x");
-    return 0;
-#define N 52			/* double's mantisa size in bits */
-/* a and b are different in at most <bits> significant digits */
-int almost_equal(double a, double b, int bits)
-    int ea, eb, e;
-    if (a == b)
-	return 1;
-    if (a == 0 || b == 0) {
-	/* return (0 < -N+bits); */
-	return (bits > N);
-    frexp(a, &ea);
-    frexp(b, &eb);
-    if (ea != eb)
-	return (bits > N + abs(ea - eb));
-    frexp(a - b, &e);
-    return (e < ea - N + bits);
-#ifdef ASDASDFASFEAS
-int segment_intersection_2d_test(double ax1, double ay1, double ax2,
-				 double *y1, double *x2, double *y2)
-    double t;
-    int vertical;
-    mp_exp_t exp;
-    char *s;
-    double d, da, db, ra, rb;
-    if (!initialized)
-    G_debug(3, "segment_intersection_2d_test()");
-    G_debug(3, "    ax1  = %.18e, ay1  = %.18e", ax1, ay1);
-    G_debug(3, "    ax2  = %.18e, ay2  = %.18e", ax2, ay2);
-    G_debug(3, "    bx1  = %.18e, by1  = %.18e", bx1, by1);
-    G_debug(3, "    bx2  = %.18e, by2  = %.18e", bx2, by2);
-	G_debug(4, "    identical segments");
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    if (f11 || f12) {
-	G_debug(4, "    connected by endpoints");
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if (f21 || f22) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-	G_debug(4, "    no intersection (disjoint bounding boxes)");
-	return 0;
-	return 0;
-    da = (bx1 - ax1) * (by1 - by2) - (by1 - ay1) * (bx1 - bx2);
-    db = (ax2 - ax1) * (by1 - ay1) - (ay2 - ay1) * (bx1 - ax1);
-    s = mpf_get_str(NULL, &exp, 10, 40, dd);
-    G_debug(3, "    dd = %sE%d", (s[0] == 0) ? "0" : s, exp);
-    G_debug(3, "    d = %.18E", d);
-    if (sgn_d != 0) {
-	ra = da / d;
-	rb = db / d;
-	mpf_div(rra, dda, dd);
-	G_debug(4, "        rra = %sE%d", (s[0] == 0) ? "0" : s, exp);
-	G_debug(4, "        ra = %.18E", ra);
-	s = mpf_get_str(NULL, &exp, 10, 40, rrb);
-	G_debug(4, "        rrb = %sE%d", (s[0] == 0) ? "0" : s, exp);
-	G_debug(4, "        rb = %.18E", rb);
-	if (sgn_d > 0) {
-		return 0;
-		return 0;
-		return 0;
-		return 0;
-	G_debug(2, "        intersection at:");
-	G_debug(2, "            xx = %.18e", *x1);
-	G_debug(2, "             x = %.18e", ax1 + ra * (ax2 - ax1));
-	G_debug(2, "            yy = %.18e", *y1);
-	G_debug(2, "             y = %.18e", ay1 + ra * (ay2 - ay1));
-	return 1;
-    G_debug(3, "    parallel/collinear...");
-    return -1;
-#endif
Deleted: grass/trunk/vector/v.buffer2/e_intersect.h
--- grass/trunk/vector/v.buffer2/e_intersect.h	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.buffer2/e_intersect.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,21 +0,0 @@
-#ifndef E_INTERSECT_H
-#define E_INTERSECT_H
-#define FZERO(X, TOL) (fabs(X)<TOL)
-#define FEQUAL(X, Y, TOL) (fabs(X-Y)<TOL)
-/*int segment_intersection_2d_e(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
-    double *x1, double *y1, double *x2, double *y2);
-int segment_intersection_2d_test(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
-    double *x1, double *y1, double *x2, double *y2);*/
-int segment_intersection_2d_tol(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
-    double *x1, double *y1, double *x2, double *y2, double tol);
-int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
-int almost_equal(double a, double b, int bits);
-#endif
Deleted: grass/trunk/vector/v.buffer2/vlib_buffer.c
--- grass/trunk/vector/v.buffer2/vlib_buffer.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.buffer2/vlib_buffer.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,1168 +0,0 @@
-/* Functions: ...
- ** Author: Radim Blazek, Rosen Matev; July 2008
-#include <grass/glocale.h>
-#ifndef MIN
-#endif
-#ifndef MAX
-#endif
-#define PI M_PI
-#define RIGHT_SIDE 1
-#define LEFT_SIDE -1
-#define LOOPED_LINE 1
-#define NON_LOOPED_LINE 0
-/* norm_vector() calculates normalized vector form two points */
-static void norm_vector(double x1, double y1, double x2, double y2, double *x,
-			double *y)
-    double dx, dy, l;
-    dx = x2 - x1;
-    dy = y2 - y1;
-    if ((dx == 0) && (dy == 0)) {
-	/* assume that dx == dy == 0, which should give (NaN,NaN) */
-	/* without this, very small dx or dy could result in Infinity */
-	*x = 0;
-	*y = 0;
-	return;
-    l = LENGTH(dx, dy);
-    *x = dx / l;
-    *y = dy / l;
-    return;
-static void rotate_vector(double x, double y, double cosa, double sina,
-			  double *nx, double *ny)
-    *nx = x * cosa - y * sina;
-    *ny = x * sina + y * cosa;
-    return;
- * (x,y) shoud be normalized vector for common transforms; This func transforms (x,y) to a vector corresponding to da, db, dalpha params
- * dalpha is in radians
-static void elliptic_transform(double x, double y, double da, double db,
-			       double dalpha, double *nx, double *ny)
-    double cosa = cos(dalpha);
-    double sina = sin(dalpha);
-    /*    double cc = cosa*cosa;
-       double ss = sina*sina;
-       double t = (da-db)*sina*cosa;
-       *nx = (da*cc + db*ss)*x + t*y;
-       *ny = (da*ss + db*cc)*y + t*x;
-       return; */
-    double va, vb;
-    va = (x * cosa + y * sina) * da;
-    vb = (x * (-sina) + y * cosa) * db;
-    *nx = va * cosa + vb * (-sina);
-    *ny = va * sina + vb * cosa;
-    return;
- * vect(x,y) must be normalized
- * gives the tangent point of the tangent to ellpise(da,db,dalpha) parallel to vect(x,y)
- * ellipse center is in (0,0)
-static void elliptic_tangent(double x, double y, double da, double db,
-			     double dalpha, double *px, double *py)
-    double u, v, len;
-    /* rotate (x,y) -dalpha radians */
-    rotate_vector(x, y, cosa, -sina, &x, &y);
-    /*u = (x + da*y/db)/2;
-       v = (y - db*x/da)/2; */
-    u = da * da * y;
-    v = -db * db * x;
-    len = da * db / sqrt(da * da * v * v + db * db * u * u);
-    u *= len;
-    v *= len;
-    rotate_vector(u, v, cosa, sina, px, py);
-    return;
- * !!! This is not line in GRASS' sense. See http://en.wikipedia.org/wiki/Line_%28mathematics%29
-static void line_coefficients(double x1, double y1, double x2, double y2,
-			      double *a, double *b, double *c)
-    *a = y2 - y1;
-    *b = x1 - x2;
-    *c = x2 * y1 - x1 * y2;
-    return;
- * Finds intersection of two straight lines. Returns 0 if the lines are parallel, 1 if they cross,
- * 2 if they are the same line.
- * !!!!!!!!!!!!!!!! FIX THIS TOLLERANCE CONSTANTS BAD (and UGLY) CODE !!!!!!!!!
-static int line_intersection(double a1, double b1, double c1, double a2,
-			     double b2, double c2, double *x, double *y)
-    double d;
-    if (fabs(a2 * b1 - a1 * b2) == 0) {
-	if (fabs(a2 * c1 - a1 * c2) == 0)
-	    return 2;
-	else
-	    return 0;
-    else {
-	d = a1 * b2 - a2 * b1;
-	*x = (b1 * c2 - b2 * c1) / d;
-	*y = (c1 * a2 - c2 * a1) / d;
-	return 1;
-static double angular_tolerance(double tol, double da, double db)
-    double a = MAX(da, db);
-    if (tol > a)
-	tol = a;
-    return 2 * acos(1 - tol / a);
- * This function generates parallel line (with loops, but not like the old ones).
- * It is not to be used directly for creating buffers.
- * + added elliptical buffers/par.lines support
- * dalpha - direction of elliptical buffer major axis in degrees
- * da - distance along major axis
- * db: distance along minor (perp.) axis
- * side: side >= 0 - right side, side < 0 - left side
- * when (da == db) we have plain distances (old case)
- * round - 1 for round corners, 0 for sharp corners. (tol is used only if round == 1)
-void parallel_line(struct line_pnts *Points, double da, double db,
-		   double dalpha, int side, int round, int caps, int looped,
-		   double tol, struct line_pnts *nPoints)
-    int i, j, res, np;
-    double *x, *y;
-    double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
-    double vx1, vy1, wx1, wy1;
-    double a0, b0, c0, a1, b1, c1;
-    double phi1, phi2, delta_phi;
-    double nsegments, angular_tol, angular_step;
-    int inner_corner, turns360;
-    G_debug(3, "parallel_line()");
-    if (looped && 0) {
-	/* start point != end point */
-	return;
-    Vect_reset_line(nPoints);
-    if (looped) {
-	Vect_append_point(Points, Points->x[1], Points->y[1], Points->z[1]);
-    x = Points->x;
-    y = Points->y;
-    if ((np == 0) || (np == 1))
-	return;
-    if ((da == 0) || (db == 0)) {
-	Vect_copy_xyz_to_pnts(nPoints, x, y, NULL, np);
-	return;
-    side = (side >= 0) ? (1) : (-1);	/* normalize variable */
-    dalpha *= PI / 180;		/* convert dalpha from degrees to radians */
-    angular_tol = angular_tolerance(tol, da, db);
-	/* save the old values */
-	a0 = a1;
-	b0 = b1;
-	c0 = c1;
-	wx = vx;
-	wy = vy;
-	norm_vector(x[i], y[i], x[i + 1], y[i + 1], &tx, &ty);
-	if ((tx == 0) && (ty == 0))
-	    continue;
-	elliptic_tangent(side * tx, side * ty, da, db, dalpha, &vx, &vy);
-	nx = x[i] + vx;
-	ny = y[i] + vy;
-	mx = x[i + 1] + vx;
-	my = y[i + 1] + vy;
-	line_coefficients(nx, ny, mx, my, &a1, &b1, &c1);
-	if (i == 0) {
-	    if (!looped)
-		Vect_append_point(nPoints, nx, ny, 0);
-	    continue;
-	delta_phi = atan2(ty, tx) - atan2(y[i] - y[i - 1], x[i] - x[i - 1]);
-	if (delta_phi > PI)
-	    delta_phi -= 2 * PI;
-	else if (delta_phi <= -PI)
-	    delta_phi += 2 * PI;
-	/* now delta_phi is in [-pi;pi] */
-	turns360 = (fabs(fabs(delta_phi) - PI) < 1e-15);
-	inner_corner = (side * delta_phi <= 0) && (!turns360);
-	if ((turns360) && (!(caps && round))) {
-	    if (caps) {
-		norm_vector(0, 0, vx, vy, &tx, &ty);
-		elliptic_tangent(side * tx, side * ty, da, db, dalpha, &tx,
-				 &ty);
-	    else {
-		tx = 0;
-		ty = 0;
-	    Vect_append_point(nPoints, x[i] + wx + tx, y[i] + wy + ty, 0);
-	    Vect_append_point(nPoints, nx + tx, ny + ty, 0);	/* nx == x[i] + vx, ny == y[i] + vy */
-	else if ((!round) || inner_corner) {
-	    res = line_intersection(a0, b0, c0, a1, b1, c1, &rx, &ry);
-	    /*                if (res == 0) {
-	       G_debug(4, "a0=%.18f, b0=%.18f, c0=%.18f, a1=%.18f, b1=%.18f, c1=%.18f", a0, b0, c0, a1, b1, c1);
-	       G_fatal_error("Two consequtive line segments are parallel, but not on one straight line! This should never happen.");
-	       return;
-	    if (res == 1) {
-		if (!round)
-		    Vect_append_point(nPoints, rx, ry, 0);
-		else {
-		    /*                    d = dig_distance2_point_to_line(rx, ry, 0, x[i-1], y[i-1], 0, x[i], y[i], 0,
-		       0, NULL, NULL, NULL, NULL, NULL);
-		       if ( */
-	else {
-	    /* we should draw elliptical arc for outside corner */
-	    /* inverse transforms */
-	    elliptic_transform(wx, wy, 1 / da, 1 / db, dalpha, &wx1, &wy1);
-	    elliptic_transform(vx, vy, 1 / da, 1 / db, dalpha, &vx1, &vy1);
-	    phi1 = atan2(wy1, wx1);
-	    phi2 = atan2(vy1, vx1);
-	    delta_phi = side * (phi2 - phi1);
-	    /* make delta_phi in [0, 2pi] */
-	    if (delta_phi < 0)
-	    nsegments = (int)(delta_phi / angular_tol) + 1;
-	    angular_step = side * (delta_phi / nsegments);
-	    for (j = 0; j <= nsegments; j++) {
-		elliptic_transform(cos(phi1), sin(phi1), da, db, dalpha, &tx,
-				   &ty);
-		Vect_append_point(nPoints, x[i] + tx, y[i] + ty, 0);
-		phi1 += angular_step;
-	if ((!looped) && (i == np - 2)) {
-	    Vect_append_point(nPoints, mx, my, 0);
-    if (looped) {
-	Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0],
-			  nPoints->z[0]);
-    Vect_line_prune(nPoints);
-    if (looped) {
-	Vect_line_delete_point(Points, Points->n_points - 1);
-/* input line must be looped */
-void convolution_line(struct line_pnts *Points, double da, double db,
-    double *x, *y;
-    double angle0, angle1;
-    G_debug(3, "convolution_line() side = %d", side);
-    x = Points->x;
-    y = Points->y;
-	return;
-    if ((x[0] != x[np - 1]) || (y[0] != y[np - 1])) {
-	G_fatal_error(_("Line is not looped"));
-	return;
-	return;
-    i = np - 2;
-    angle1 = atan2(ty, tx);
-    nx = x[i] + vx;
-    ny = y[i] + vy;
-    if (!round)
-    for (i = 0; i <= np - 2; i++) {
-	G_debug(4, "point %d, segment %d-%d", i, i, i + 1);
-	if (!round) {
-	    a0 = a1;
-	    b0 = b1;
-	    c0 = c1;
-	wx = vx;
-	wy = vy;
-	angle0 = angle1;
-	    continue;
-	nx = x[i] + vx;
-	ny = y[i] + vy;
-	if (!round)
-	delta_phi = angle1 - angle0;
-	/* if <line turns 360> and (<caps> and <not round>) */
-	if (turns360 && caps && (!round)) {
-	    elliptic_tangent(side * tx, side * ty, da, db, dalpha, &tx, &ty);
-	    G_debug(4, " append point (c) x=%.16f y=%.16f", x[i] + wx + tx,
-		    y[i] + wy + ty);
-	    G_debug(4, " append point (c) x=%.16f y=%.16f", nx + tx, ny + ty);
-	if ((!turns360) && (!round) && (!inner_corner)) {
-	    if (res == 1) {
-		G_debug(4, " append point (o) x=%.16f y=%.16f", rx, ry);
-	    else if (res == 2) {
-		/* no need to append point in this case */
-	    else
-		G_fatal_error
-		    ("unexpected result of line_intersection() res = %d",
-		     res);
-	if (round && (!inner_corner) && (!turns360 || caps)) {
-	    for (j = 1; j <= nsegments - 1; j++) {
-				   &ty);
-		G_debug(4, " append point (r) x=%.16f y=%.16f", x[i] + tx,
-			y[i] + ty);
-	G_debug(4, " append point (s) x=%.16f y=%.16f", nx, ny);
-	G_debug(4, " append point (s) x=%.16f y=%.16f", mx, my);
-    /* close the output line */
-    Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0], nPoints->z[0]);
-    /*    Vect_line_prune ( nPoints ); */
- * side: side >= 0 - extracts contour on right side of edge, side < 0 - extracts contour on left side of edge
- * if the extracted contour is the outer contour, it is returned in ccw order
- * else if it is inner contour, it is returned in cw order
-static void extract_contour(struct planar_graph *pg, struct pg_edge *first,
-			    int side, int winding, int stop_at_line_end,
-			    struct line_pnts *nPoints)
-    int j;
-    int v;			/* current vertex number */
-    int v0;
-    int eside;			/* side of the current edge */
-    double eangle;		/* current edge angle with Ox (according to the current direction) */
-    struct pg_vertex *vert;	/* current vertex */
-    struct pg_vertex *vert0;	/* last vertex */
-    struct pg_edge *edge;	/* current edge; must be edge of vert */
-    /*    int cs; *//* on which side are we turning along the contour */
-    /* we will always turn right and dont need that one */
-    double opt_angle, tangle;
-    int opt_j, opt_side, opt_flag;
-    G_debug(3,
-	    "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d",
-	    first->v1, first->v2, side, stop_at_line_end);
-    edge = first;
-    if (side >= 0) {
-	eside = 1;
-	v0 = edge->v1;
-	v = edge->v2;
-    else {
-	eside = -1;
-	v0 = edge->v2;
-	v = edge->v1;
-    vert0 = &(pg->v[v0]);
-    vert = &(pg->v[v]);
-    eangle = atan2(vert->y - vert0->y, vert->x - vert0->x);
-    while (1) {
-	Vect_append_point(nPoints, vert0->x, vert0->y, 0);
-	G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0,
-		v, eside, edge->v1, edge->v2);
-	G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
-	/* mark current edge as visited on the appropriate side */
-	if (eside == 1) {
-	    edge->visited_right = 1;
-	    edge->winding_right = winding;
-	else {
-	    edge->visited_left = 1;
-	    edge->winding_left = winding;
-	opt_flag = 1;
-	    /* exclude current edge */
-	    if (vert->edges[j] != edge) {
-		tangle = vert->angles[j] - eangle;
-		if (tangle < -PI)
-		    tangle += 2 * PI;
-		else if (tangle > PI)
-		    tangle -= 2 * PI;
-		/* now tangle is in (-PI, PI) */
-		if (opt_flag || (tangle < opt_angle)) {
-		    opt_j = j;
-		    opt_side = (vert->edges[j]->v1 == v) ? (1) : (-1);
-		    opt_angle = tangle;
-		    opt_flag = 0;
-	//        G_debug(4, "ec: opt: side=%d opt_flag=%d opt_angle=%.18f opt_j=%d opt_step=%d", side, opt_flag, opt_angle, opt_j, opt_step);
-	/* if line end is reached (no other edges at curr vertex) */
-	if (opt_flag) {
-	    if (stop_at_line_end) {
-		G_debug(3, "    end has been reached, will stop here");
-		break;
-	    else {
-		opt_j = 0;	/* the only edge of vert is vert->edges[0] */
-		opt_side = -eside;	/* go to the other side of the current edge */
-		G_debug(3, "    end has been reached, turning around");
-	/* break condition */
-	if ((vert->edges[opt_j] == first) && (opt_side == side))
-	    break;
-	if (opt_side == 1) {
-	    if (vert->edges[opt_j]->visited_right) {
-		G_warning(_("Next edge was visited but it is not the first one !!! breaking loop"));
-		G_debug(4,
-			"ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d",
-			v, (edge->v1 == v) ? (edge->v2) : (edge->v1),
-			opt_side, vert->edges[opt_j]->v1,
-			vert->edges[opt_j]->v2);
-		break;
-	else {
-	    if (vert->edges[opt_j]->visited_left) {
-		G_debug(4,
-		break;
-	edge = vert->edges[opt_j];
-	eside = opt_side;
-	v0 = v;
-	v = (edge->v1 == v) ? (edge->v2) : (edge->v1);
-	vert0 = vert;
-	eangle = vert0->angles[opt_j];
-    Vect_append_point(nPoints, vert->x, vert->y, 0);
-    G_debug(4, "ec: append point x=%.18f y=%.18f", vert->x, vert->y);
-    return;
- * This function extracts the outer contour of a (self crossing) line.
- * It can generate left/right contour if none of the line ends are in a loop.
- * If one or both of them is in a loop, then there's only one contour
- * side: side > 0 - right contour, side < 0 - left contour, side = 0 - outer contour
- *       if side != 0 and there's only one contour, the function returns it
- * TODO: Implement side != 0 feature;
-void extract_outer_contour(struct planar_graph *pg, int side,
-    int i;
-    int flag;
-    int v;
-    double min_x, min_angle;
-    G_debug(3, "extract_outer_contour()");
-    if (side != 0) {
-	G_fatal_error(_("side != 0 feature not implemented"));
-	return;
-    /* find a line segment which is on the outer contour */
-    flag = 1;
-	if (flag || (pg->v[i].x < min_x)) {
-	    v = i;
-	    min_x = pg->v[i].x;
-	    flag = 0;
-    flag = 1;
-    for (i = 0; i < vert->ecount; i++) {
-	if (flag || (vert->angles[i] < min_angle)) {
-	    edge = vert->edges[i];
-	    min_angle = vert->angles[i];
-	    flag = 0;
-    /* the winding on the outer contour is 0 */
-    extract_contour(pg, edge, (edge->v1 == v) ? RIGHT_SIDE : LEFT_SIDE, 0, 0,
-		    nPoints);
-    return;
- * Extracts contours which are not visited.
- * IMPORTANT: the outer contour must be visited (you should call extract_outer_contour() to do that),
- *            so that extract_inner_contour() doesn't return it
- * returns: 0 when there are no more inner contours; otherwise, 1
-int extract_inner_contour(struct planar_graph *pg, int *winding,
-    int i, w;
-    G_debug(3, "extract_inner_contour()");
-    for (i = 0; i < pg->ecount; i++) {
-	edge = &(pg->e[i]);
-	if (edge->visited_left) {
-	    if (!(pg->e[i].visited_right)) {
-		w = edge->winding_left - 1;
-		extract_contour(pg, &(pg->e[i]), RIGHT_SIDE, w, 0, nPoints);
-		*winding = w;
-		return 1;
-	else {
-	    if (pg->e[i].visited_right) {
-		w = edge->winding_right + 1;
-		extract_contour(pg, &(pg->e[i]), LEFT_SIDE, w, 0, nPoints);
-		*winding = w;
-		return 1;
-    return 0;
-/* point_in_buf - test if point px,py is in d buffer of Points
- ** dalpha is in degrees
- ** returns:  1 in buffer
- **           0 not in buffer
-int point_in_buf(struct line_pnts *Points, double px, double py, double da,
-		 double db, double dalpha)
-    int i, np;
-    double cx, cy;
-    double delta, delta_k, k;
-    double vx, vy, wx, wy, mx, my, nx, ny;
-    double len, tx, ty, d, da2;
-    G_debug(3, "point_in_buf()");
-    da2 = da * da;
-	vx = Points->x[i];
-	vy = Points->y[i];
-	wx = Points->x[i + 1];
-	wy = Points->y[i + 1];
-	if (da != db) {
-	    mx = wx - vx;
-	    my = wy - vy;
-	    len = LENGTH(mx, my);
-	    elliptic_tangent(mx / len, my / len, da, db, dalpha, &cx, &cy);
-	    delta = mx * cy - my * cx;
-	    delta_k = (px - vx) * cy - (py - vy) * cx;
-	    k = delta_k / delta;
-	    /*            G_debug(4, "k = %g, k1 = %g", k, (mx * (px - vx) + my * (py - vy)) / (mx * mx + my * my)); */
-	    if (k <= 0) {
-		nx = vx;
-		ny = vy;
-	    else if (k >= 1) {
-		nx = wx;
-		ny = wy;
-	    else {
-		nx = vx + k * mx;
-		ny = vy + k * my;
-	    /* inverse transform */
-	    elliptic_transform(px - nx, py - ny, 1 / da, 1 / db, dalpha, &tx,
-			       &ty);
-	    d = dig_distance2_point_to_line(nx + tx, ny + ty, 0, vx, vy, 0,
-					    wx, wy, 0, 0, NULL, NULL, NULL,
-					    NULL, NULL);
-	    /*            G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny))); */
-	    if (d <= 1) {
-		//G_debug(1, "d=%g", d);
-		return 1;
-	else {
-	    d = dig_distance2_point_to_line(px, py, 0, vx, vy, 0, wx, wy, 0,
-	    /*            G_debug(4, "sqrt(d)     = %g", sqrt(d)); */
-	    if (d <= da2) {
-		return 1;
-    return 0;
-/* returns 0 for ccw, non-zero for cw
-int get_polygon_orientation(const double *x, const double *y, int n)
-    double area;
-    x2 = x[n - 1];
-    y2 = y[n - 1];
-    area = 0;
-    while (--n >= 0) {
-	x1 = x2;
-	y1 = y2;
-	x2 = *x++;
-	y2 = *y++;
-	area += (y2 + y1) * (x2 - x1);
-    return (area > 0);
-/* internal */
-void add_line_to_array(struct line_pnts *Points,
-		       struct line_pnts ***arrPoints, int *count,
-		       int *allocated, int more)
-    if (*allocated == *count) {
-	*allocated += more;
-	*arrPoints =
-	    G_realloc(*arrPoints, (*allocated) * sizeof(struct line_pnts *));
-    (*arrPoints)[*count] = Points;
-    (*count)++;
-    return;
-void destroy_lines_array(struct line_pnts **arr, int count)
-    int i;
-    for (i = 0; i < count; i++)
-	Vect_destroy_line_struct(arr[i]);
-    G_free(arr);
-/* area_outer and area_isles[i] must be closed non self-intersecting lines
-   side: 0 - auto, 1 - right, -1 left
-void buffer_lines(struct line_pnts *area_outer, struct line_pnts **area_isles,
-		  int isles_count, int side, double da, double db,
-		  double dalpha, int round, int caps, double tol,
-		  struct line_pnts **oPoints, struct line_pnts ***iPoints,
-		  int *inner_count)
-    struct planar_graph *pg2;
-    struct line_pnts *sPoints, *cPoints;
-    struct line_pnts **arrPoints;
-    int i, count = 0;
-    int res, winding;
-    int auto_side;
-    int more = 8;
-    int allocated = 0;
-    double px, py;
-    G_debug(3, "buffer_lines()");
-    auto_side = (side == 0);
-    /* initializations */
-    sPoints = Vect_new_line_struct();
-    cPoints = Vect_new_line_struct();
-    arrPoints = NULL;
-    /* outer contour */
-    G_debug(3, "    processing outer contour");
-    *oPoints = Vect_new_line_struct();
-    if (auto_side)
-	side =
-	    get_polygon_orientation(area_outer->x, area_outer->y,
-				    area_outer->n_points -
-				    1) ? LEFT_SIDE : RIGHT_SIDE;
-    convolution_line(area_outer, da, db, dalpha, side, round, caps, tol,
-		     sPoints);
-    pg2 = pg_create(sPoints);
-    extract_outer_contour(pg2, 0, *oPoints);
-    res = extract_inner_contour(pg2, &winding, cPoints);
-    while (res != 0) {
-	if (winding == 0) {
-	    if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
-		if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
-		    G_fatal_error(_("Vect_get_point_in_poly() failed"));
-		if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
-		    add_line_to_array(cPoints, &arrPoints, &count, &allocated,
-				      more);
-    pg_destroy_struct(pg2);
-    /* inner contours */
-    G_debug(3, "    processing inner contours");
-    for (i = 0; i < isles_count; i++) {
-	if (auto_side)
-	    side =
-		get_polygon_orientation(area_isles[i]->x, area_isles[i]->y,
-					area_isles[i]->n_points -
-					1) ? RIGHT_SIDE : LEFT_SIDE;
-	convolution_line(area_isles[i], da, db, dalpha, side, round, caps,
-			 tol, sPoints);
-	extract_outer_contour(pg2, 0, cPoints);
-	    if (winding == -1) {
-		/* we need to check if the area is in the buffer.
-		   I've simplfied convolution_line(), so that it runs faster,
-		   however that leads to ocasional problems */
-		if (Vect_point_in_poly
-		    (cPoints->x[0], cPoints->y[0], area_isles[i])) {
-		    if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
-					  &allocated, more);
-    arrPoints = G_realloc(arrPoints, count * sizeof(struct line_pnts *));
-    *inner_count = count;
-    *iPoints = arrPoints;
-    Vect_destroy_line_struct(sPoints);
-    Vect_destroy_line_struct(cPoints);
-    G_debug(3, "buffer_lines() ... done");
-    return;
-   \fn void Vect_line_buffer(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count) {
-   \brief Creates buffer around the line Points.
-   \param InPoints input line
-   \param da distance along major axis
-   \param da distance along minor axis
-   \param dalpha angle between 0x and major axis
-   \param round make corners round
-   \param caps add caps at line ends
-   \param tol maximum distance between theoretical arc and output segments
-   \param oPoints output polygon outer border (ccw order)
-   \param inner_count number of holes
-   \param iPoints array of output polygon's holes (cw order)
-void Vect_line_buffer2(struct line_pnts *Points, double da, double db,
-		       struct line_pnts ***iPoints, int *inner_count)
-    struct line_pnts *tPoints, *outer;
-    struct line_pnts **isles;
-    int isles_count = 0;
-    int res, winding;
-    int more = 8;
-    int isles_allocated = 0;
-    G_debug(2, "Vect_line_buffer()");
-    tPoints = Vect_new_line_struct();
-    isles = NULL;
-    pg = pg_create(Points);
-    outer = Vect_new_line_struct();
-    extract_outer_contour(pg, 0, outer);
-    res = extract_inner_contour(pg, &winding, tPoints);
-	add_line_to_array(tPoints, &isles, &isles_count, &isles_allocated,
-			  more);
-    buffer_lines(outer, isles, isles_count, RIGHT_SIDE, da, db, dalpha, round,
-		 caps, tol, oPoints, iPoints, inner_count);
-    Vect_destroy_line_struct(tPoints);
-    Vect_destroy_line_struct(outer);
-    destroy_lines_array(isles, isles_count);
-    pg_destroy_struct(pg);
-    return;
-void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db,
-    int i, isle;
-    int more = 8;
-    G_debug(2, "Vect_area_buffer()");
-    isles_count = Vect_get_area_num_isles(Map, area);
-    isles_allocated = isles_count;
-    isles = G_malloc(isles_allocated * sizeof(struct line_pnts *));
-    Vect_get_area_points(Map, area, outer);
-    Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
-	isle = Vect_get_area_isle(Map, area, i);
-	Vect_get_isle_points(Map, isle, tPoints);
-	/* Check if the isle is big enough */
-	   if (Vect_line_length(tPoints) < 2*PI*max)
-	   continue;
-	Vect_append_point(tPoints, tPoints->x[0], tPoints->y[0],
-			  tPoints->z[0]);
-			  more);
-    buffer_lines(outer, isles, isles_count, 0, da, db, dalpha, round, caps,
-		 tol, oPoints, iPoints, inner_count);
-    return;
-   \fn void Vect_point_buffer(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints) {
-   \brief Creates buffer around the point (px,py).
-   \param px input point x-coordinate
-   \param py input point y-coordinate
-   \param nPoints output polygon outer border (ccw order)
-void Vect_point_buffer2(double px, double py, double da, double db,
-			double dalpha, int round, double tol,
-			struct line_pnts **oPoints)
-    double tx, ty;
-    double angular_tol, angular_step, phi1;
-    int j, nsegments;
-    G_debug(2, "Vect_point_buffer()");
-    if (round || (!round)) {
-	nsegments = (int)(2 * PI / angular_tol) + 1;
-	angular_step = 2 * PI / nsegments;
-	phi1 = 0;
-	for (j = 0; j < nsegments; j++) {
-			       &ty);
-	    Vect_append_point(*oPoints, px + tx, py + ty, 0);
-    else {
-    Vect_append_point(*oPoints, (*oPoints)->x[0], (*oPoints)->y[0],
-		      (*oPoints)->z[0]);
-    return;
-   \fn void Vect_line_parallel2 ( struct line_pnts *InPoints, double distance, double tolerance, int rm_end,
-   struct line_pnts *OutPoints )
-   \brief Create parrallel line
-   \param distance
-   \param tolerance maximum distance between theoretical arc and polygon segments
-   \param rm_end remove end points falling into distance
-   \param OutPoints output line
-void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db,
-			 double dalpha, int side, int round, double tol,
-			 struct line_pnts *OutPoints)
-    G_debug(2, "Vect_line_parallel(): npoints = %d, da = %f, "
-	    "db = %f, dalpha = %f, side = %d, round_corners = %d, tol = %f",
-	    InPoints->n_points, da, db, dalpha, side, round, tol);
-    parallel_line(InPoints, da, db, dalpha, side, round, 1, NON_LOOPED_LINE,
-		  tol, OutPoints);
-    /*    if (!loops)
-       clean_parallel(OutPoints, InPoints, distance, rm_end);
-    return;
Deleted: grass/trunk/vector/v.parallel2/dgraph.c
--- grass/trunk/vector/v.parallel2/dgraph.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.parallel2/dgraph.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,521 +0,0 @@
-#ifndef MIN
-#endif
-#ifndef MAX
-#endif
-#define PI M_PI
-    double x;
-    double y;
-    int count;
-    int allocated;
-    int ipcount;
-    int ipallocated;
-    int ilcount;
-    int group_count;
-    int i;
-    si->ipcount = 0;
-    return si;
-    int i;
-    G_free(si->il);
-    G_free(si->ip);
-    G_free(si);
-    return;
-/* internal use */
-		 int ip)
-	il->a =
-	    G_realloc(il->a,
-    s->with = with;
-    s->ip = ip;
-    s->dist = dist;
-    il->count++;
-    return;
-    int ip;
-	si->ip =
-	    G_realloc(si->ip,
-    ip = si->ipcount;
-    t->x = x;
-    t->y = y;
-    t->group = -1;
-    si->ipcount++;
-    int n, i, j, min;
-    n = il->count;
-	min = i;
-		min = j;
-	if (min != i) {
-	    t = il->a[i];
-	    il->a[min] = t;
-    return;
-	return -1;
-	return 1;
-    else
-    int i, np;
-    double min, t;
-    double *x, *y;
-    x = Points->x;
-    y = Points->y;
-	    min = t;
-    int i, j, np;
-    int group, t;
-    int looped;
-    double *x, *y;
-    int res;
-    /*int res2
-    x = Points->x;
-    y = Points->y;
-	    res =
-					&x2, &y2);
-	    if (res == 1) {
-    if (!looped) {
-		   si);
-	si->ip =
-	    G_realloc(si->ip,
-	    il->a =
-		G_realloc(il->a,
-	t = group;
-		break;
-		break;
-	if (t == group)
-	    group++;
-    return si;
-    pg->vcount = n;
-    pg->ecount = 0;
-    pg->e = NULL;
-    return pg;
-    int i;
-    G_free(pg->v);
-    G_free(pg->e);
-    G_free(pg);
-    int i, ecount;
-	v = &(pg->v[v1]);
-    else
-	v = &(pg->v[v2]);
-	e = v->edges[i];
-	    return 1;
-    return 0;
-	v->edges =
-    v->ecount++;
-	return;
-	return;
-	G_fatal_error
-    e->v1 = v1;
-    e->v2 = v2;
-    pg->ecount++;
-    return;
-    int i, j, t, v;
-	t = ip->group;
-	    if (t != v) {
-		v = t;
-	    vert->angles[j] =
-    /* output pg */
-    return pg;
Deleted: grass/trunk/vector/v.parallel2/dgraph.h
--- grass/trunk/vector/v.parallel2/dgraph.h	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.parallel2/dgraph.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,38 +0,0 @@
-#ifndef DGRAPH_H
-#define DGRAPH_H
-struct pg_edge {
-struct pg_vertex {
-    double y;
-    int ecount;
-    int eallocated;
-#endif
Deleted: grass/trunk/vector/v.parallel2/e_intersect.c
--- grass/trunk/vector/v.parallel2/e_intersect.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.parallel2/e_intersect.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,1077 +0,0 @@
-#include <math.h>
-#ifndef MIN
-#endif
-#ifndef MAX
-#endif
-mpf_t rra, rrb;
-    mpf_init(p11);
-    mpf_init(p12);
-    mpf_init(p21);
-    mpf_init(p22);
-    mpf_init(t1);
-    mpf_init(t2);
-    mpf_init(dd);
-    mpf_init(dda);
-    mpf_init(ddb);
-    mpf_init(delta);
-    mpf_init(rra);
-    mpf_init(rrb);
-    initialized = 1;
-   Caclulates:
-   |a11-b11  a12-b12|
-   |a21-b21  a22-b22|
-    return;
-    double t = *a;
-    *a = *b;
-    *b = t;
-    return;
-    double t;
-    int vertical;
-    mp_exp_t exp;
-    char *s;
-    if (!initialized)
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    if (f11 || f12) {
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if (f21 || f22) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-	return 0;
-	return 0;
-    if (sgn_d != 0) {
-	if (sgn_d > 0) {
-		return 0;
-		return 0;
-		return 0;
-		return 0;
-	return 1;
-	return 0;
-    vertical = 0;
-    if (ax1 > ax2) {
-	SWAP(ax1, ax2);
-	SWAP(ay1, ay2);
-	vertical = 1;
-	if (ay1 > ay2)
-	    SWAP(ay1, ay2);
-	SWAP(ax1, ay1);
-	SWAP(ax2, ay2);
-    if (bx1 > bx2) {
-	SWAP(bx1, bx2);
-	SWAP(by1, by2);
-	if (by1 > by2)
-	    SWAP(by1, by2);
-	SWAP(bx1, by1);
-	SWAP(bx2, by2);
-	return 0;
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 3;
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 4;
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = ay2;
-	    *y2 = ax2;
-	return 2;
-	if (!vertical) {
-	    *x1 = bx2;
-	    *y1 = by2;
-	    *x2 = ax1;
-	    *y2 = ay1;
-	else {
-	    *x1 = by2;
-	    *y1 = bx2;
-	    *x2 = ay1;
-	    *y2 = ax1;
-	return 2;
-    G_warning("x");
-    return 0;
-#endif
-/* OLD */
-				double tol)
-    int switched = 0;
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    if (bx1 < ax1)
-	switched = 1;
-	if (bx2 < ax2)
-	    switched = 1;
-	    if (by1 < ay1)
-		switched = 1;
-		if (by2 < ay2)
-    if (switched) {
-	t = ax1;
-	ax1 = bx1;
-	bx1 = t;
-	t = ay1;
-	ay1 = by1;
-	by1 = t;
-	t = ax2;
-	ax2 = bx2;
-	bx2 = t;
-	t = ay2;
-	ay2 = by2;
-	by2 = t;
-	ra = d1 / d;
-	rb = d2 / d;
-	    return 0;
-	return 1;
-	return 0;
-	if (ay1 > ay2) {
-	    t = ay1;
-	    ay1 = ay2;
-	    ay2 = t;
-	if (by1 > by2) {
-	    t = by1;
-	    by1 = by2;
-	    by2 = t;
-	    return 0;
-	/* end points */
-	    *x1 = ax1;
-	    *y1 = ay1;
-	    *x1 = ax2;
-	    *y1 = ay2;
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	    if (!switched)
-		return 3;
-	    else
-		return 4;
-	    *x1 = ax1;
-	    *y1 = ay1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	    if (!switched)
-		return 4;
-	    else
-		return 3;
-	    if (!switched) {
-		*x1 = bx1;
-		*y1 = by1;
-		*x2 = ax2;
-		*y2 = ay2;
-	    else {
-		*x1 = ax2;
-		*y1 = ay2;
-		*x2 = bx1;
-		*y2 = by1;
-	    return 2;
-	    if (!switched) {
-		*x1 = bx2;
-		*y1 = by2;
-		*x2 = ax1;
-		*y2 = ay1;
-	    else {
-		*x1 = ax1;
-		*y1 = ay1;
-		*x2 = bx2;
-		*y2 = by2;
-	    return 2;
-	G_warning("x");
-	return 0;
-	return 0;
-    /* end points */
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-    if (ax1 > ax2) {
-	t = ax1;
-	ax1 = ax2;
-	ax2 = t;
-	t = ay1;
-	ay1 = ay2;
-	ay2 = t;
-    if (bx1 > bx2) {
-	t = bx1;
-	bx1 = bx2;
-	bx2 = t;
-	t = by1;
-	by1 = by2;
-	by2 = t;
-	*x1 = bx1;
-	*y1 = by1;
-	*x2 = bx2;
-	*y2 = by2;
-	if (!switched)
-	    return 3;
-	else
-	    return 4;
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	if (!switched)
-	    return 4;
-	else
-	    return 3;
-	if (!switched) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	else {
-	    *x1 = ax2;
-	    *y1 = ay2;
-	    *x2 = bx1;
-	    *y2 = by1;
-	return 2;
-	if (!switched) {
-	    *x1 = bx2;
-	    *y1 = by2;
-	    *x2 = ax1;
-	    *y2 = ay1;
-	else {
-	    *x1 = ax1;
-	    *y1 = ay1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	return 2;
-    G_warning("x");
-    return 0;
-    double t;
-    int vertical;
-    double d, da, db;
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    if (f11 || f12) {
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if (f21 || f22) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-	return 0;
-	return 0;
-    d = D;
-    if (d != 0) {
-	da = DA;
-	if (d > 0) {
-		return 0;
-	    db = DB;
-		return 0;
-		return 0;
-	    db = DB;
-		return 0;
-	return 1;
-    da = DA;
-    db = DB;
-	return 0;
-    vertical = 0;
-    if (ax1 > ax2) {
-	SWAP(ax1, ax2);
-	SWAP(ay1, ay2);
-	vertical = 1;
-	if (ay1 > ay2)
-	    SWAP(ay1, ay2);
-	SWAP(ax1, ay1);
-	SWAP(ax2, ay2);
-    if (bx1 > bx2) {
-	SWAP(bx1, bx2);
-	SWAP(by1, by2);
-	if (by1 > by2)
-	    SWAP(by1, by2);
-	SWAP(bx1, by1);
-	SWAP(bx2, by2);
-	return 0;
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 3;
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = bx2;
-	    *y2 = by2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = by2;
-	    *y2 = bx2;
-	return 4;
-	if (!vertical) {
-	    *x1 = bx1;
-	    *y1 = by1;
-	    *x2 = ax2;
-	    *y2 = ay2;
-	else {
-	    *x1 = by1;
-	    *y1 = bx1;
-	    *x2 = ay2;
-	    *y2 = ax2;
-	return 2;
-	if (!vertical) {
-	    *x1 = bx2;
-	    *y1 = by2;
-	    *x2 = ax1;
-	    *y2 = ay1;
-	else {
-	    *x1 = by2;
-	    *y1 = bx2;
-	    *x2 = ay1;
-	    *y2 = ax1;
-	return 2;
-    G_warning("x");
-    return 0;
-    int ea, eb, e;
-    if (a == b)
-	return 1;
-    frexp(a, &ea);
-    frexp(b, &eb);
-    if (ea != eb)
-    frexp(a - b, &e);
-    double t;
-    int vertical;
-    mp_exp_t exp;
-    char *s;
-    if (!initialized)
-	*x1 = ax1;
-	*y1 = ay1;
-	*x2 = ax2;
-	*y2 = ay2;
-	return 5;
-    if (f11 || f12) {
-	*x1 = ax1;
-	*y1 = ay1;
-	return 1;
-    if (f21 || f22) {
-	*x1 = ax2;
-	*y1 = ay2;
-	return 1;
-	return 0;
-	return 0;
-    if (sgn_d != 0) {
-	ra = da / d;
-	rb = db / d;
-	G_debug(3, "        rra = %sE%d", (s[0] == 0) ? "0" : s, exp);
-	G_debug(3, "        ra = %.18E", ra);
-	G_debug(3, "        rrb = %sE%d", (s[0] == 0) ? "0" : s, exp);
-	G_debug(3, "        rb = %.18E", rb);
-	if (sgn_d > 0) {
-		return 0;
-		return 0;
-		return 0;
-		return 0;
-	G_debug(3, "        intersection at:");
-	G_debug(3, "            xx = %.18e", *x1);
-	G_debug(3, "             x = %.18e", ax1 + ra * (ax2 - ax1));
-	G_debug(3, "            yy = %.18e", *y1);
-	G_debug(3, "             y = %.18e", ay1 + ra * (ay2 - ay1));
-	return 1;
-    return -1;
-#endif
Deleted: grass/trunk/vector/v.parallel2/e_intersect.h
--- grass/trunk/vector/v.parallel2/e_intersect.h	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.parallel2/e_intersect.h	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,21 +0,0 @@
-#endif
Deleted: grass/trunk/vector/v.parallel2/vlib_buffer.c
--- grass/trunk/vector/v.parallel2/vlib_buffer.c	2008-11-28 22:09:53 UTC (rev 34601)
+++ grass/trunk/vector/v.parallel2/vlib_buffer.c	2008-11-28 22:12:43 UTC (rev 34602)
@@ -1,1167 +0,0 @@
-/* Functions: ...
-#include <stdlib.h>
-#include <grass/Vect.h>
-#include <grass/gis.h>
-#include "dgraph.h"
-#define LENGTH(DX, DY) (sqrt((DX*DX)+(DY*DY)))
-#ifndef MIN
-#define MIN(X,Y) ((X<Y)?X:Y)
-#endif
-#ifndef MAX
-#define MAX(X,Y) ((X>Y)?X:Y)
-#endif
-#define PI M_PI
-			double *y)
-    double dx, dy, l;
-    dx = x2 - x1;
-    dy = y2 - y1;
-	*x = 0;
-	*y = 0;
-	return;
-    *x = dx / l;
-    *y = dy / l;
-    return;
-    return;
-       return; */
-    double va, vb;
-    return;
-    double u, v, len;
-    u = da * da * y;
-    v = -db * db * x;
-    u *= len;
-    v *= len;
-    return;
-    *a = y2 - y1;
-    *b = x1 - x2;
-    return;
-    double d;
-	    return 2;
-	else
-	    return 0;
-    else {
-	return 1;
-    if (tol > a)
-	tol = a;
-    double *x, *y;
-	return;
-    if (looped) {
-    x = Points->x;
-    y = Points->y;
-	return;
-	return;
-	a0 = a1;
-	b0 = b1;
-	c0 = c1;
-	wx = vx;
-	wy = vy;
-	    continue;
-	nx = x[i] + vx;
-	ny = y[i] + vy;
-	if (i == 0) {
-	    if (!looped)
-	    continue;
-	    if (caps) {
-				 &ty);
-	    else {
-		tx = 0;
-		ty = 0;
-	       return;
-	    if (res == 1) {
-		if (!round)
-		else {
-		       if ( */
-	else {
-				   &ty);
-    if (looped) {
-			  nPoints->z[0]);
-    if (looped) {
-    double *x, *y;
-    np = Points->n_points;
-    x = Points->x;
-    y = Points->y;
-	return;
-	return;
-	return;
-    i = np - 2;
-    nx = x[i] + vx;
-    ny = y[i] + vy;
-    if (!round)
-	if (!round) {
-	    a0 = a1;
-	    b0 = b1;
-	    c0 = c1;
-	wx = vx;
-	wy = vy;
-	angle0 = angle1;
-	    continue;
-	nx = x[i] + vx;
-	ny = y[i] + vy;
-	if (!round)
-		    y[i] + wy + ty);
-	    if (res == 1) {
-	    else
-		G_fatal_error(_("Unexpected result of line_intersection() res = %d"),
-			      res);
-				   &ty);
-			y[i] + ty);
-    int j;
-    int v0;
-    G_debug(3,
-    edge = first;
-    if (side >= 0) {
-	eside = 1;
-	v0 = edge->v1;
-	v = edge->v2;
-    else {
-	eside = -1;
-	v0 = edge->v2;
-	v = edge->v1;
-    while (1) {
-	if (eside == 1) {
-	else {
-	opt_flag = 1;
-		if (tangle < -PI)
-		    tangle += 2 * PI;
-		    tangle -= 2 * PI;
-		    opt_j = j;
-		    opt_flag = 0;
-	if (opt_flag) {
-		break;
-	    else {
-	    break;
-		G_debug(4,
-		break;
-	else {
-		G_debug(4,
-		break;
-	eside = opt_side;
-	v0 = v;
-	vert0 = vert;
-    return;
-    int i;
-    int flag;
-    int v;
-    if (side != 0) {
-	G_fatal_error("    side != 0 feature not implemented");
-	return;
-    flag = 1;
-	    v = i;
-	    flag = 0;
-    flag = 1;
-	    flag = 0;
-		    nPoints);
-    return;
-    int i, w;
-		*winding = w;
-		return 1;
-	else {
-		*winding = w;
-		return 1;
-    return 0;
-    int i, np;
-    double cx, cy;
-    da2 = da * da;
-    for (i = 0; i < np - 1; i++) {
-	if (da != db) {
-	    mx = wx - vx;
-	    my = wy - vy;
-	    if (k <= 0) {
-		nx = vx;
-		ny = vy;
-		nx = wx;
-		ny = wy;
-	    else {
-		nx = vx + k * mx;
-		ny = vy + k * my;
-			       &ty);
-					    NULL, NULL);
-	    if (d <= 1) {
-		return 1;
-	else {
-	    if (d <= da2) {
-		return 1;
-    return 0;
-    double x1, y1, x2, y2;
-    double area;
-    x2 = x[n - 1];
-    y2 = y[n - 1];
-    area = 0;
-	x1 = x2;
-	y1 = y2;
-	x2 = *x++;
-	y2 = *y++;
-/* internal */
-	*arrPoints =
-    (*count)++;
-    return;
-    int i;
-    G_free(arr);
-		  int *inner_count)
-    int i, count = 0;
-    int res, winding;
-    int auto_side;
-    int more = 8;
-    double px, py;
-    arrPoints = NULL;
-    if (auto_side)
-	side =
-		     sPoints);
-		    G_fatal_error("Vect_get_point_in_poly() failed.");
-				      more);
-	if (auto_side)
-	    side =
-			 tol, sPoints);
-    return;
-    int res, winding;
-    int more = 8;
-    isles = NULL;
-			  more);
-    return;
-    int i, isle;
-    int more = 8;
-	   continue;
-			  tPoints->z[0]);
-			  more);
-    return;
-    double tx, ty;
-    int j, nsegments;
-	phi1 = 0;
-			       &ty);
-    else {
-    return;
-   \param distance
-    G_debug(2,
-	    "Vect_line_parallel(): npoints = %d, da = %f, db = %f, "
-	    "dalpha = %f, side = %d, round_corners = %d, tol = %f",
-		  tol, OutPoints);
-    /*    if (!loops)
-    return;
