[GRASS-SVN] r34604 - grass/branches/develbranch_6/vector/v.delaunay2
Fri Nov 28 17:23:12 EST 2008
Author: martinl
Date: 2008-11-28 17:23:12 -0500 (Fri, 28 Nov 2008)
New Revision: 34604
   grass/branches/develbranch_6/vector/v.delaunay2/geometry.c
   grass/branches/develbranch_6/vector/v.delaunay2/in_out.c
   grass/branches/develbranch_6/vector/v.delaunay2/main.c
   grass/branches/develbranch_6/vector/v.delaunay2/memory.c
r34603 reverted
Modified: grass/branches/develbranch_6/vector/v.delaunay2/geometry.c
--- grass/branches/develbranch_6/vector/v.delaunay2/geometry.c	2008-11-28 22:17:43 UTC (rev 34603)
+++ grass/branches/develbranch_6/vector/v.delaunay2/geometry.c	2008-11-28 22:23:12 UTC (rev 34604)
@@ -21,13 +21,9 @@
     unsigned int n;
     unsigned int split;
     struct edge *l_ccw_l, *r_cw_l, *l_ccw_r, *r_cw_r, *l_tangent;
     struct edge *a, *b, *c;
     double c_p;
     n = r - l + 1;
@@ -102,9 +98,7 @@
 				   struct vertex **org_r_lower)
     struct edge *l, *r;
     struct vertex *o_l, *o_r, *d_l, *d_r;
     boolean ready;
     l = r_cw_l;
@@ -145,11 +139,8 @@
 		  struct edge **l_tangent)
     struct edge *base, *l_cand, *r_cand;
     struct vertex *org_base, *dest_base;
     long double u_l_c_o_b, v_l_c_o_b, u_l_c_d_b, v_l_c_d_b;
     long double u_r_c_o_b, v_r_c_o_b, u_r_c_d_b, v_r_c_d_b;
     /* cross product */
@@ -157,15 +148,10 @@
     /* dot product */
     long double d_p_l_cand, d_p_r_cand;
     boolean above_l_cand, above_r_cand, above_next, above_prev;
     struct vertex *dest_l_cand, *dest_r_cand;
     long double cot_l_cand, cot_r_cand;
     struct edge *l_lower, *r_lower;
     struct vertex *org_r_lower, *org_l_lower;
     /* Create first cross edge by joining lower common tangent */
@@ -210,11 +196,8 @@
 	   in_circle test gets invalid. */
 	if (above_l_cand) {
 	    double u_n_o_b, v_n_o_b, u_n_d_b, v_n_d_b;
 	    double c_p_next, d_p_next, cot_next;
 	    struct edge *next;
 	    struct vertex *dest_next;
 	    d_p_l_cand =
@@ -250,11 +233,8 @@
 	if (above_r_cand) {
 	    double u_p_o_b, v_p_o_b, u_p_d_b, v_p_d_b;
 	    double c_p_prev, d_p_prev, cot_prev;
 	    struct edge *prev;
 	    struct vertex *dest_prev;
 	    d_p_r_cand =
Modified: grass/branches/develbranch_6/vector/v.delaunay2/in_out.c
--- grass/branches/develbranch_6/vector/v.delaunay2/in_out.c	2008-11-28 22:17:43 UTC (rev 34603)
+++ grass/branches/develbranch_6/vector/v.delaunay2/in_out.c	2008-11-28 22:23:12 UTC (rev 34604)
@@ -14,13 +14,10 @@
 		  int Type, struct Map_info map_out)
     struct edge *e_start, *e;
     struct vertex *u, *v;
     unsigned int i;
     static struct line_pnts *Points = NULL;
     static struct line_cats *Cats = NULL;
     if (!Points) {
@@ -65,15 +62,11 @@
 		      int mode3d, int Type, struct Map_info map_out)
     struct edge *e_start, *e, *next;
     struct vertex *u, *v, *w;
     unsigned int i;
     struct vertex *temp;
     struct line_pnts *Points = Vect_new_line_struct();
     struct line_cats *Cats = Vect_new_cats_struct();
     double x1, y1, z1, x2, y2, z2, x3, y3, z3;
@@ -147,13 +140,9 @@
 void remove_duplicates(struct vertex *list[], unsigned int *size)
     int n = *size - 1;
     int left = 0;
     int right = 1;
     int shift = 0;
     int empty = 0;
     if (n > 0)
@@ -175,7 +164,6 @@
 	       BOUND_BOX Box)
     int nlines, line, allocated, nsites;
     struct line_pnts *Points;
Modified: grass/branches/develbranch_6/vector/v.delaunay2/main.c
--- grass/branches/develbranch_6/vector/v.delaunay2/main.c	2008-11-28 22:17:43 UTC (rev 34603)
+++ grass/branches/develbranch_6/vector/v.delaunay2/main.c	2008-11-28 22:23:12 UTC (rev 34604)
@@ -1,4 +1,3 @@
  * MODULE:       v.delaunay
@@ -35,39 +34,26 @@
     /* GRASS related variables */
     char *mapset;
     struct Map_info map_in, map_out;
     struct Cell_head Window;
     BOUND_BOX Box;
     struct GModule *module;
     struct Flag *reg_flag, *line_flag;
     struct Option *in_opt, *out_opt;
     struct line_cats *Cats;
     int nareas, area;
     int Type;
     int complete_map;
     int mode3d;
     unsigned int i;
     unsigned int n;
     struct edge *l_cw, *r_ccw;
     struct vertex **sites_sorted;
     /* GRASS related manipulations */
@@ -158,7 +144,6 @@
 	/*  Assign centroid to each area */
 	for (area = 1; area <= nareas; area++) {
 	    double x, y, z, angle, slope;
 	    int ret;
 	    G_percent(area, nareas, 2);
Modified: grass/branches/develbranch_6/vector/v.delaunay2/memory.c
--- grass/branches/develbranch_6/vector/v.delaunay2/memory.c	2008-11-28 22:17:43 UTC (rev 34603)
+++ grass/branches/develbranch_6/vector/v.delaunay2/memory.c	2008-11-28 22:23:12 UTC (rev 34604)
@@ -5,9 +5,7 @@
 #include "data_types.h"
 struct vertex *sites;
 static struct edge *edges;
 static struct edge **free_list_e;
 static unsigned int n_free_e;
@@ -15,7 +13,6 @@
 void alloc_memory(unsigned int n)
     struct edge *e;
     int i;
     /* Sites storage. */
@@ -55,7 +52,6 @@
 void alloc_edges(unsigned int n)
     struct edge *e;
     int i;
     /* Edges. Euler's formula - at most 3n edges on a set of n sites */
