[GRASS-SVN] r34620 - grass/branches/develbranch_6/imagery/i.fft
svn_grass at osgeo.org
Sat Nov 29 08:35:16 EST 2008
Author: martinl
Date: 2008-11-29 08:35:16 -0500 (Sat, 29 Nov 2008)
New Revision: 34620
grass/branches/develbranch_6/imagery/i.fft/fftmain.c
grass/branches/develbranch_6/imagery/i.fft/save_fft.c
i.fft: cosmetics (use standardized parameters, message standardization)
Modified: grass/branches/develbranch_6/imagery/i.fft/fftmain.c
--- grass/branches/develbranch_6/imagery/i.fft/fftmain.c 2008-11-29 04:45:32 UTC (rev 34619)
+++ grass/branches/develbranch_6/imagery/i.fft/fftmain.c 2008-11-29 13:35:16 UTC (rev 34620)
@@ -10,7 +10,7 @@
* PURPOSE: processes a single input raster map layer
* and constructs the real and imaginary Fourier
* components in frequency space
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -71,34 +71,21 @@
me = G_program_name();
module = G_define_module();
- module->keywords = _("imagery");
+ module->keywords = _("imagery, FFT");
module->description =
_("Fast Fourier Transform (FFT) for image processing.");
/* define options */
- op1 = G_define_option();
+ op1 = G_define_standard_option(G_OPT_R_INPUT);
op1->key = "input_image";
- op1->type = TYPE_STRING;
- op1->required = YES;
- op1->multiple = NO;
- op1->gisprompt = "old,cell,raster";
- op1->description = _("Input raster map being fft");
- op2 = G_define_option();
+ op2 = G_define_standard_option(G_OPT_R_OUTPUT);
op2->key = "real_image";
- op2->type = TYPE_STRING;
- op2->required = YES;
- op2->multiple = NO;
- op2->gisprompt = "new,cell,raster";
- op2->description = _("Output real part arrays stored as raster map");
+ op2->description = _("Name for output real part arrays stored as raster map");
- op3 = G_define_option();
+ op3 = G_define_standard_option(G_OPT_R_OUTPUT);
op3->key = "imaginary_image";
- op3->type = TYPE_STRING;
- op3->required = YES;
- op3->multiple = NO;
- op3->gisprompt = "new,cell,raster";
- op3->description = _("Output imaginary part arrays stored as raster map");
+ op3->description = _("Name for output imaginary part arrays stored as raster map");
op4 = G_define_option();
op4->key = "range";
@@ -131,15 +118,15 @@
/* check command line args for validity */
if (G_legal_filename(Cellmap_real) < 0)
- G_fatal_error(_("Illegal file name for real part: %s"), Cellmap_real);
+ G_fatal_error(_("<%s> is an illegal file name"), Cellmap_real);
if (G_legal_filename(Cellmap_imag) < 0)
- G_fatal_error(_("Illegal file name for imaginary part: %s"),
Cellmap_imag);
sscanf(op4->answer, "%d", &Range);
if (Range <= 0)
- G_fatal_error(_("Range less than or equal to zero not allowed."));
+ G_fatal_error(_("Range less than or equal to zero not allowed"));
G_get_set_window(&window); /* get the current window for later */
put_orig_window(&window);
@@ -161,7 +148,7 @@
data[1] = (double *)G_malloc((rows * cols) * sizeof(double));
/* Initialize real & complex components to zero */
- G_message(_("Initializing data...\n"));
+ G_debug(1, "Initializing data...");
register double *dptr1, *dptr0;
@@ -176,13 +163,17 @@
cell_row = G_allocate_cell_buf();
/* Read in cell map values */
- G_message(_("Reading the raster map..."));
+ G_message(_("Reading the raster map <%s>..."),
+ Cellmap_orig);
for (i = 0; i < or; i++) {
if (G_get_map_row(inputfd, cell_row, i) < 0)
G_fatal_error(_("Error while reading input raster map."));
for (j = 0; j < oc; j++)
*(data[0] + (i * cols) + j) = (double)cell_row[j];
+ G_percent(i+1, or, 2);
/* close input cell map and release the row buffer */
G_close_cell(inputfd);
G_free(cell_row);
@@ -190,8 +181,7 @@
/* perform FFT */
G_message(_("Starting FFT..."));
fft(-1, data, totsize, cols, rows);
- G_message(_("FFT completed..."));
/* set up a window for the transform cell map */
window.rows = rows;
window.cols = cols;
@@ -232,13 +222,13 @@
- G_message(_("Writing transformed data to file..."));
+ G_message(_("Writing transformed data..."));
/* write out the double arrays to cell_misc/file/FFTREAL and FFTIMAG */
max = 0.0;
min = 0.0;
save_fft(totsize, data, &max, &min);
- G_message(_("Writing viewable versions of transformed data to files..."));
+ G_message(_("Writing viewable versions of transformed data..."));
/* Write out result to a new cell map */
for (i=0; i<rows; i++) {
@@ -265,6 +255,8 @@
G_put_raster_row(realfd, cell_row, CELL_TYPE);
G_put_raster_row(imagfd, cell_row2, CELL_TYPE);
+ G_percent(i+1, rows, 2);
G_close_cell(realfd);
@@ -279,7 +271,7 @@
for (i = 0; i < 2; i++)
G_free(data[i]);
- G_done_msg(_("Transform successful."));
+ G_done_msg(_(" "));
exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/imagery/i.fft/save_fft.c
--- grass/branches/develbranch_6/imagery/i.fft/save_fft.c 2008-11-29 04:45:32 UTC (rev 34619)
+++ grass/branches/develbranch_6/imagery/i.fft/save_fft.c 2008-11-29 13:35:16 UTC (rev 34620)
@@ -14,12 +14,12 @@
min = *minimum;
if ((fp = G_fopen_new_misc("cell_misc", "fftreal", Cellmap_real)) == NULL)
- G_fatal_error(_("Unable to open file in the cell_misc directory."));
+ G_fatal_error(_("Unable to open file in the 'cell_misc' directory"));
fwrite((char *)data[0], sizeof(double), (size_t) total, fp);
fclose(fp);
if ((fp = G_fopen_new_misc("cell_misc", "fftimag", Cellmap_imag)) == NULL)
fwrite((char *)data[1], sizeof(double), (size_t) total, fp);
fclose(fp);
