[GRASS-SVN] r34625 - grass/trunk/imagery/i.ifft
svn_grass at osgeo.org
Sat Nov 29 12:42:59 EST 2008
Author: martinl
Date: 2008-11-29 12:42:59 -0500 (Sat, 29 Nov 2008)
New Revision: 34625
grass/trunk/imagery/i.ifft/main.c
i.ifft: use standardized options
message standardization
Modified: grass/trunk/imagery/i.ifft/main.c
--- grass/trunk/imagery/i.ifft/main.c 2008-11-29 17:31:02 UTC (rev 34624)
+++ grass/trunk/imagery/i.ifft/main.c 2008-11-29 17:42:59 UTC (rev 34625)
@@ -1,3 +1,21 @@
+ * MODULE: i.ifft
+ * AUTHOR(S): David B. Satnik and Ali R. Vali (original contributors),
+ * Markus Neteler <neteler itc.it>
+ * Bernhard Reiter <bernhard intevation.de>,
+ * Brad Douglas <rez touchofmadness.com>,
+ * Glynn Clements <glynn gclements.plus.com>
+ * PURPOSE: processes the real and imaginary Fourier
+ * components in frequency space and constract raster map
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
Central Washington University GIS Laboratory
Programmer: David B. Satnik
@@ -55,35 +73,23 @@
/* Set description */
module = G_define_module();
- module->keywords = _("imagery");
+ module->keywords = _("imagery, FFT");
module->description =
_("Inverse Fast Fourier Transform (IFFT) for image processing.");
/* define options */
- opt.real = G_define_option();
+ opt.real = G_define_standard_option(G_OPT_R_INPUT);
opt.real->key = "real_image";
- opt.real->type = TYPE_STRING;
- opt.real->required = YES;
- opt.real->multiple = NO;
- opt.real->gisprompt = "old,cell,raster";
- opt.real->description = _("Input raster map (image fft, real part)");
+ opt.real->description = _("Name of input raster map (image fft, real part)");
- opt.imag = G_define_option();
+ opt.imag = G_define_standard_option(G_OPT_R_INPUT);
opt.imag->key = "imaginary_image";
- opt.imag->type = TYPE_STRING;
- opt.imag->required = YES;
- opt.imag->multiple = NO;
- opt.imag->gisprompt = "old,cell,raster";
- opt.imag->description = _("Input raster map (image fft, imaginary part");
+ opt.imag->description = _("Name of input raster map (image fft, imaginary part");
- opt.orig = G_define_option();
+ opt.orig = G_define_standard_option(G_OPT_R_OUTPUT);
opt.orig->key = "output_image";
- opt.orig->type = TYPE_STRING;
- opt.orig->required = YES;
- opt.orig->multiple = NO;
- opt.orig->gisprompt = "new,cell,raster";
- opt.orig->description = _("Output inverse raster map after IFFT");
+ opt.orig->description = _("Name for output raster map");
/*call parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -95,11 +101,13 @@
/* open input raster map */
realfd = G_open_cell_old(Cellmap_real, "");
if (realfd < 0)
- G_fatal_error(_("Unable to open real input map <%s>"), Cellmap_real);
+ G_fatal_error(_("Unable to open raster map <%s>"),
+ Cellmap_real);
imagfd = G_open_cell_old(Cellmap_imag, "");
- if (imagfd < 0)
- G_fatal_error(_("Unable to open imaginary input map <%s>"), Cellmap_imag);
+ if (imagfd < 0)
+ Cellmap_imag);
/* get and compare the original window data */
G_get_cellhd(Cellmap_real, "", &realhead);
@@ -113,7 +121,7 @@
realhead.west != imaghead.west ||
realhead.ew_res != imaghead.ew_res ||
realhead.ns_res != imaghead.ns_res)
- G_fatal_error(_("The real and imaginary original windows did not match."));
+ G_fatal_error(_("The real and imaginary original windows did not match"));
G_set_window(&realhead); /* set the window to the whole cell map */
@@ -135,16 +143,19 @@
#define C(i, j) ((i) * cols + (j))
/* Read in cell map values */
- G_message(_("Reading the raster maps..."));
+ G_message(_("Reading raster maps..."));
for (i = 0; i < rows; i++) {
if (G_get_d_raster_row(realfd, cell_real, i) < 0)
- G_fatal_error(_("Error while reading real input raster map."));
+ G_fatal_error(_("Unable to read raster map <%s> row %d"),
+ Cellmap_real, i);
if (G_get_d_raster_row(imagfd, cell_imag, i) < 0)
- G_fatal_error(_("Error while reading imaginary input raster map."));
+ Cellmap_imag, i);
for (j = 0; j < cols; j++) {
data[C(i, j)][0] = cell_real[j];
data[C(i, j)][1] = cell_imag[j];
+ G_percent(i+1, rows, 2);
/* close input cell maps */
@@ -152,7 +163,7 @@
G_close_cell(imagfd);
- G_message(_("Masking the raster maps..."));
+ G_message(_("Masking raster maps..."));
maskfd = G_maskfd();
if (maskfd >= 0) {
maskbuf = G_allocate_cell_buf();
@@ -165,6 +176,7 @@
data[C(i, j)][1] = 0.0;
G_close_cell(maskfd);
@@ -185,7 +197,7 @@
} while (0)
/* rotate the data array for standard display */
- G_message(_("Rotating data arrays..."));
+ G_message(_("Rotating data..."));
for (j = 0; j < cols / 2; j++)
SWAP2(C(i, j), C(i, j + cols / 2));
@@ -196,18 +208,22 @@
/* perform inverse FFT */
G_message(_("Starting Inverse FFT..."));
fft2(1, data, totsize, cols, rows);
- G_message(_("Inverse FFT completed..."));
/* open the output cell map */
if ((outputfd = G_open_fp_cell_new(Cellmap_orig)) < 0)
- G_fatal_error(_("Unable to open output map <%s>"), Cellmap_orig);
+ G_fatal_error(_("Unable to create raster map <%s>"),
+ Cellmap_orig);
/* Write out result to a new cell map */
- G_message(_("Writing output map..."));
+ G_message(_("Writing raster map <%s>..."),
+ Cellmap_orig);
cell_real[j] = data[C(i, j)][0];
G_put_d_raster_row(outputfd, cell_real);
G_close_cell(outputfd);
@@ -220,7 +236,7 @@
/* Release memory resources */
G_free(data);
- G_done_msg(_("Transform successful."));
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
