[GRASS-SVN] r34637 - grass/branches/develbranch_6/vector/v.extract
svn_grass at osgeo.org
Sun Nov 30 14:29:16 EST 2008
Author: martinl
Date: 2008-11-30 14:29:16 -0500 (Sun, 30 Nov 2008)
New Revision: 34637
grass/branches/develbranch_6/vector/v.extract/main.c
v.extract: cosmetics (more guisection, order options based on
guisections)
Modified: grass/branches/develbranch_6/vector/v.extract/main.c
--- grass/branches/develbranch_6/vector/v.extract/main.c 2008-11-30 19:13:34 UTC (rev 34636)
+++ grass/branches/develbranch_6/vector/v.extract/main.c 2008-11-30 19:29:16 UTC (rev 34637)
@@ -88,7 +88,7 @@
/* set up the options and flags for the command line parser */
module = G_define_module();
- module->keywords = _("vector");
+ module->keywords = _("vector, extract");
module->description =
_("Selects vector objects from an existing vector map and "
"creates a new map containing only the selected objects.");
@@ -104,6 +104,7 @@
r_flag = G_define_flag();
r_flag->key = 'r';
r_flag->description = _("Reverse selection");
+ r_flag->guisection = _("Query");
inopt = G_define_standard_option(G_OPT_V_INPUT);
@@ -112,30 +113,28 @@
typopt = G_define_standard_option(G_OPT_V_TYPE);
typopt->answer = "point,line,boundary,centroid,area,face";
typopt->options = "point,line,boundary,centroid,area,face";
- typopt->description = _("Types to be extracted ");
+ typopt->label = _("Types to be extracted");
+ typopt->guisection = _("Query");
fieldopt = G_define_standard_option(G_OPT_V_FIELD);
- fieldopt->description =
- _("If -1, all features in all layers of given type " "are extracted");
- newopt = G_define_option();
- newopt->key = "new";
- newopt->type = TYPE_INTEGER;
- newopt->required = NO;
- newopt->answer = "-1";
- newopt->label =
- _("Enter -1 to keep original categories or the desired NEW category value");
- newopt->description = _("If new >= 0, table is not copied");
+ fieldopt->label =
+ _("Layer number (if -1, all features in all layers of given type " "are extracted)");
+ fieldopt->guisection = _("Query");
listopt = G_define_standard_option(G_OPT_V_CATS);
listopt->key = "list";
+ listopt->guisection = _("Query");
+ whereopt = G_define_standard_option(G_OPT_WHERE);
+ whereopt->guisection = _("Query");
fileopt = G_define_standard_option(G_OPT_F_INPUT);
fileopt->key = "file";
fileopt->required = NO;
fileopt->label =
_("Input text file with category numbers/number ranges to be extracted");
fileopt->description = _("If '-' given reads from standard input");
+ fileopt->guisection = _("Query");
nrandopt = G_define_option();
nrandopt->key = "random";
@@ -144,9 +143,17 @@
nrandopt->label =
_("Number of random categories matching vector objects to extract");
nrandopt->description =
- _("Number must be smaller than unique Cat count in layer");
+ _("Number must be smaller than unique cat count in layer");
+ nrandopt->guisection = _("Query");
- whereopt = G_define_standard_option(G_OPT_WHERE);
+ newopt = G_define_option();
+ newopt->key = "new";
+ newopt->type = TYPE_INTEGER;
+ newopt->required = NO;
+ newopt->answer = "-1";
+ newopt->label =
+ _("Enter -1 to keep original categories or the desired NEW category value");
+ newopt->description = _("If new >= 0, table is not copied");
/* heeeerrrrrre's the PARSER */
if (G_parser(argc, argv))
