[GRASS-SVN] r34644 -
grass/branches/develbranch_6/scripts/v.db.reconnect.all
svn_grass at osgeo.org
Sun Nov 30 19:52:51 EST 2008
Author: hamish
Date: 2008-11-30 19:52:51 -0500 (Sun, 30 Nov 2008)
New Revision: 34644
grass/branches/develbranch_6/scripts/v.db.reconnect.all/description.html
Clarify syntax of old_database= option (merge from trunk r34639; #385)
Modified: grass/branches/develbranch_6/scripts/v.db.reconnect.all/description.html
--- grass/branches/develbranch_6/scripts/v.db.reconnect.all/description.html 2008-11-30 22:28:57 UTC (rev 34643)
+++ grass/branches/develbranch_6/scripts/v.db.reconnect.all/description.html 2008-12-01 00:52:51 UTC (rev 34644)
@@ -4,6 +4,14 @@
all vectors in the current mapset from old_database to database. If a link
does not match the old_database it is left untouched.
+<H2>NOTES</H2>
+The value of the <em>old_database</em> option needs to be the exact
+string which appears as the fourth field printed by
+<code>'v.db.connect -g'</code>, i.e. with substituted variables.
<H2>AUTHOR</H2>
Radim Blazek
