[GRASS-SVN] r33644 - grass/trunk/vector/v.extract
svn_grass at osgeo.org
Wed Oct 1 15:26:14 EDT 2008
Author: martinl
Date: 2008-10-01 15:26:14 -0400 (Wed, 01 Oct 2008)
New Revision: 33644
grass/trunk/vector/v.extract/Makefile
grass/trunk/vector/v.extract/main.c
grass/trunk/vector/v.extract/v.extract.html
marisn: Random feature extraction support for v.extract
(merge from devbr6, r33639)
Modified: grass/trunk/vector/v.extract/Makefile
--- grass/trunk/vector/v.extract/Makefile 2008-10-01 19:17:45 UTC (rev 33643)
+++ grass/trunk/vector/v.extract/Makefile 2008-10-01 19:26:14 UTC (rev 33644)
@@ -3,8 +3,8 @@
PGM=v.extract
-LIBES = $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(GMATHLIB) $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(GMATHDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2008-10-01 19:17:45 UTC (rev 33643)
+++ grass/trunk/vector/v.extract/main.c 2008-10-01 19:26:14 UTC (rev 33644)
@@ -25,9 +25,13 @@
#include <string.h>
#include <ctype.h>
#include <math.h>
+#include <search.h>
+#include <sys/types.h>
+#include <unistd.h>
#include <grass/gis.h>
#include <grass/Vect.h>
#include <grass/dbmi.h>
+#include <grass/gmath.h>
#include <grass/glocale.h>
static int *cat_array, cat_count, cat_size;
@@ -47,26 +51,38 @@
cat_array[cat_count++] = x;
+/* Comparison function for *search */
+static int cmp(const void *pa, const void *pb)
+ int *p1 = (int *)pa;
+ int *p2 = (int *)pb;
+ if (*p1 < *p2)
+ return -1;
+ if (*p1 > *p2)
+ return 1;
+ return 0;
int main(int argc, char **argv)
- int i, new_cat, type, ncats, *cats, field;
+ int i, new_cat, type, ncats, *cats, field, c;
int **ocats, *nocats, nfields, *fields;
int dissolve = 0, x, y, type_only;
char buffr[1024], text[80];
char *input, *output;
struct GModule *module;
struct Option *inopt, *outopt, *fileopt, *newopt, *typopt, *listopt,
- *fieldopt;
- struct Option *whereopt;
- struct Flag *t_flag;
- struct Flag *d_flag, *r_flag;
- struct Map_info In;
- struct Map_info Out;
+ *fieldopt, *whereopt, *nrandopt;
+ struct Flag *t_flag, *d_flag, *r_flag;
+ struct Map_info In, Out;
struct field_info *Fi;
FILE *in;
dbDriver *driver;
dbHandle handle;
struct line_cats *Cats;
+ struct Cat_index *ci;
+ int ucat_count, *ucat_array = NULL, prnd, seed, nrandom, nfeatures;
G_gisinit(argv[0]);
@@ -121,16 +137,40 @@
_("Input text file with category numbers/number ranges to be extracted");
fileopt->description = _("If '-' given reads from standard input");
+ nrandopt = G_define_option();
+ nrandopt->key = "random";
+ nrandopt->type = TYPE_INTEGER;
+ nrandopt->required = NO;
+ nrandopt->label =
+ _("Number of random categories matching vector objects to extract");
+ nrandopt->description =
+ _("Number must be smaller than unique Cat count in layer");
whereopt = G_define_standard_option(G_OPT_DB_WHERE);
/* heeeerrrrrre's the PARSER */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* start checking options and flags */
+ c = 0;
+ if (fileopt->answer != NULL)
+ c++;
+ if (listopt->answers != NULL)
+ c++;
+ if (whereopt->answer != NULL)
+ c++;
+ if (nrandopt->answer != NULL)
+ c++;
+ if (c > 1)
+ G_fatal_error(_("List, file, where and random options are exclusive. "
+ "Please specify only one of them"));
+ c = 0;
type_only = 0;
- if (!listopt->answers && !fileopt->answer && !whereopt->answer) {
+ if (!listopt->answers && !fileopt->answer && !whereopt->answer &&
+ !nrandopt->answer) {
type_only = 1;
@@ -159,14 +199,11 @@
Vect_set_open_level(2);
Vect_open_old(&In, input, "");
- /* Open output file */
- Vect_open_new(&Out, output, Vect_is_3d(&In));
- Vect_hist_copy(&In, &Out);
- Vect_hist_command(&Out);
+ type = Vect_option_to_types(typopt);
+ if (type & GV_AREA) {
+ type |= GV_CENTROID;
- /* Read and write header info */
- Vect_copy_head_data(&In, &Out);
/* Read categoy list */
cat_count = 0;
if (listopt->answer != NULL) {
@@ -255,12 +292,80 @@
if (ncats >= 0)
G_free(cats);
+ else if (nrandopt->answer != NULL) { /* Generate random category list */
- type = Vect_option_to_types(typopt);
- if (type & GV_AREA) {
- type |= GV_CENTROID;
+ /* We operate on layer's CAT's and thus valid layer is required */
+ if (Vect_cidx_get_field_index(&In, field) < 0)
+ G_fatal_error(_("This map has no categories attached. "
+ "Use v.category to attach categories to this vector map."));
+ /* Don't do any processing, if user input is wrong */
+ nrandom = atoi(nrandopt->answer);
+ if (nrandom < 1)
+ G_fatal_error(_("Please specify random number larger than 0"));
+ nfeatures = Vect_cidx_get_type_count(&In, field, type);
+ if (nrandom >= nfeatures)
+ G_fatal_error(_("Random category count must be smaller than feature count. "
+ "There are only %d features of type(s): %s"),
+ nfeatures, typopt->answer);
+ /* Let's create an array of uniq CAT values
+ According to Vlib/build.c, cidx should be allready sorted by dig_cidx_sort() */
+ ci = &(In.plus.cidx[Vect_cidx_get_field_index(&In, field)]);
+ ucat_count = 0;
+ for (c = 0; c < ci->n_cats; c++) {
+ /* Bitwise AND compares ci feature type with user's requested types */
+ if (ci->cat[c][1] & type) {
+ /* Don't do anything if such value allready exists */
+ if (ucat_count > 0 &&
+ ucat_array[ucat_count - 1] == ci->cat[c][0])
+ continue;
+ ucat_array =
+ G_realloc(ucat_array, (ucat_count + 1) * sizeof(int));
+ ucat_array[ucat_count] = ci->cat[c][0];
+ ucat_count++;
+ if (nrandom >= ucat_count)
+ G_fatal_error(_("Random category count is larger or equal to uniq \"%s\" feature category count %d"),
+ typopt->answer, ucat_count);
+ if (ucat_count >= RAND_MAX)
+ G_fatal_error
+ ("There are more categories than random number generator can reach. "
+ "Report this as a GRASS bug.");
+ seed = getpid();
+ /* Initialise random number generator */
+ G_math_rand(-1 * seed);
+ /* Fill cat_array with list of valid random numbers */
+ while (cat_count < nrandom) {
+ /* Random number in range from 0 to largest CAT value */
+ prnd =
+ (int)floor(G_math_rand(seed) *
+ (ucat_array[ucat_count - 1] + 1));
+ qsort(cat_array, cat_count, sizeof(int), cmp);
+ /* Check if generated number isn't already in final list and is in list of existing CATs */
+ if (bsearch(&prnd, cat_array, cat_count, sizeof(int), cmp) == NULL
+ && bsearch(&prnd, ucat_array, ucat_count, sizeof(int),
+ cmp) != NULL)
+ add_cat(prnd);
+ G_free(ucat_array);
+ /* Open output file only when it's required */
+ Vect_open_new(&Out, output, Vect_is_3d(&In));
+ Vect_hist_copy(&In, &Out);
+ Vect_hist_command(&Out);
+ /* Read and write header info */
+ Vect_copy_head_data(&In, &Out);
xtract_line(cat_count, cat_array, &In, &Out, new_cat, type, dissolve,
field, type_only, r_flag->answer ? 1 : 0);
Modified: grass/trunk/vector/v.extract/v.extract.html
--- grass/trunk/vector/v.extract/v.extract.html 2008-10-01 19:17:45 UTC (rev 33643)
+++ grass/trunk/vector/v.extract/v.extract.html 2008-10-01 19:26:14 UTC (rev 33644)
@@ -8,7 +8,7 @@
areas have the same output category, the boundary is removed.
<p>
-If <b>list</b>, <b>file</b> and <b>where</b> options are not
+If <b>list</b>, <b>file</b>, <b>random</b> or <b>where</b> options are not
specified, all features of given type and layer are
extracted. Categories are not changed in that case.
@@ -111,6 +111,15 @@
v.extract -d in=map_with_islands out=maps_without_islands
</pre></div>
+<h3>Extract 3 random areas from geology map</h3>
+<p>
+<div class="code"><pre>
+v.extract input=geology at PERMANENT output=random_geology type=area random=3
+</pre></div>
+will create new map with three random categories matching areas. Notice, that
+there may be more tan one feature with same category.
+</p>
<h2>SEE ALSO</h2>
<em>
