[GRASS-SVN] r33647 - grass/trunk/scripts/r.in.srtm
svn_grass at osgeo.org
Wed Oct 1 17:56:18 EDT 2008
Author: glynn
Date: 2008-10-01 17:56:17 -0400 (Wed, 01 Oct 2008)
New Revision: 33647
Added:
grass/trunk/scripts/r.in.srtm/r.in.srtm.py
Convert r.in.srtm to Python
Added: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py (rev 0)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2008-10-01 21:56:17 UTC (rev 33647)
@@ -0,0 +1,251 @@
+#!/usr/bin/env python
+#import of SRTM hgt files into GRASS
+# written by Markus Neteler 11/2003 neteler AT itc it
+# COPYRIGHT: (C) 2004, 2006 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# Dec 2004: merged with srtm_generate_hdr.sh (M. Neteler)
+# corrections and refinement (W. Kyngesburye)
+# Aug 2004: modified to accept files from other directories
+# (by H. Bowman)
+# June 2005: added flag to read in US 1-arcsec tiles (H. Bowman)
+# April 2006: links updated from ftp://e0dps01u.ecs.nasa.gov/srtm/
+# to current links below
+# October 2008: Converted to Python by Glynn Clements
+#Derived from:
+# ftp://e0srp01u.ecs.nasa.gov/srtm/version1/Documentation/Notes_for_ARCInfo_users.txt
+# (note: document was updated silently end of 2003)
+# ftp://e0srp01u.ecs.nasa.gov/srtm/version1/Documentation/SRTM_Topo.txt
+# "3.0 Data Formats
+# To be more exact, these coordinates refer to the geometric center of
+# the lower left pixel, which in the case of SRTM-1 data will be about
+# 30 meters in extent."
+#- SRTM 90 Tiles are 1 degree by 1 degree
+#- SRTM filename coordinates are said to be the *center* of the LL pixel.
+# N51E10 -> lower left cell center
+#- BIL uses *center* of the UL (!) pixel:
+# http://downloads.esri.com/support/whitepapers/other_/eximgav.pdf
+#- GDAL uses *corners* of pixels for its coordinates.
+# NOTE: Even, if small difference: SRTM is referenced to EGM96, not WGS84 ellps
+# http://earth-info.nga.mil/GandG/wgs84/gravitymod/egm96/intpt.html
+#%Module
+#% description: Import SRTM HGT files into GRASS
+#% keywords: raster, import
+#%End
+#%option
+#% key: input
+#% gisprompt: old_file,file,input
+#% type: string
+#% description: SRTM input tile (file without .hgt.zip extension)
+#% required : yes
+#%end
+#%option
+#% key: output
+#% gisprompt: new,cell,raster
+#% type: string
+#% description: Output raster map (default: input tile)
+#% required : no
+#%end
+#%flag
+#% key: 1
+#% description: Input is a 1-arcsec tile (default: 3-arcsec)
+#%end
+tmpl1sec = """BYTEORDER M
+LAYOUT BIL
+NROWS 3601
+NCOLS 3601
+NBANDS 1
+NBITS 16
+BANDROWBYTES 7202
+TOTALROWBYTES 7202
+BANDGAPBYTES 0
+PIXELTYPE SIGNEDINT
+NODATA -32768
+ULXMAP %s
+ULYMAP %s
+XDIM 0.000277777777777778
+YDIM 0.000277777777777778
+tmpl3sec = """BYTEORDER M
+LAYOUT BIL
+NROWS 1201
+NCOLS 1201
+NBANDS 1
+NBITS 16
+BANDROWBYTES 2402
+TOTALROWBYTES 2402
+BANDGAPBYTES 0
+NODATA -32768
+ULXMAP %s
+ULYMAP %s
+XDIM 0.000833333333333
+YDIM 0.000833333333333
+proj = ''.join([
+ 'GEOGCS[',
+ '"wgs84",',
+ 'DATUM["WGS_1984",SPHEROID["wgs84",6378137,298.257223563],TOWGS84[0.000000,0.000000,0.000000]],',
+ 'PRIMEM["Greenwich",0],',
+ 'UNIT["degree",0.0174532925199433]',
+import sys
+import os
+import subprocess
+import shutil
+import atexit
+import grass
+def cleanup():
+ if not in_temp:
+ return
+ for ext in ['.bil', '.hdr', '.prj', '.hgt.zip']:
+ grass.try_remove(tile + ext)
+ os.chdir('..')
+ grass.try_rmdir(tmpdir)
+def main():
+ global tile, tmpdir, in_temp
+ in_temp = False
+ input = options['input']
+ output = options['output']
+ one = flags['1']
+ #are we in LatLong location?
+ s = grass.read_command("g.proj", flags='j')
+ kv = grass.parse_key_val(s)
+ if kv['+proj'] != 'longlat':
+ grass.fatal("This module only operates in LatLong locations")
+ # use these from now on:
+ infile = input
+ while infile[-4:].lower() in ['.hgt', '.zip']:
+ infile = infile[:-4]
+ (fdir, tile) = os.path.split(infile)
+ if not output:
+ tileout = tile
+ else:
+ tileout = output
+ zipfile = infile + ".hgt.zip"
+ hgtfile = infile + ".hgt"
+ if os.path.isfile(zipfile):
+ #### check if we have unzip
+ if not grass.find_program('unzip'):
+ grass.fatal('The "unzip" program is required, please install it first')
+ # really a ZIP file?
+ # make it quiet in a safe way (just in case -qq isn't portable)
+ tenv = os.environ.copy()
+ tenv['UNZIP'] = '-qq'
+ if subprocess.call(['unzip', '-t', zipfile], env = tenv) != 0:
+ grass.fatal("'%s' does not appear to be a valid zip file." % zipfile)
+ is_zip = True
+ elif os.path.isfile(hgtfile):
+ # try and see if it's already unzipped
+ is_zip = False
+ else:
+ grass.fatal("File '%s' or '%s' not found" % (zipfile, hgtfile))
+ #make a temporary directory
+ tmpdir = grass.tempfile()
+ grass.try_remove(tmpdir)
+ os.mkdir(tmpdir)
+ if is_zip:
+ shutil.copyfile(zipfile, os.path.join(tmpdir, zipfile))
+ else:
+ shutil.copyfile(hgtfile, os.path.join(tmpdir, hgtfile))
+ #change to temporary directory
+ os.chdir(tmpdir)
+ in_temp = True
+ zipfile = tile + ".hgt.zip"
+ hgtfile = tile + ".hgt"
+ bilfile = tile + ".bil"
+ if is_zip:
+ #unzip & rename data file:
+ grass.message("Extracting '%s'..." % infile)
+ if subprocess.call(['unzip', zipfile], env = tenv) != 0:
+ grass.fatal("Unable to unzip file.")
+ grass.message("Converting input file to BIL...")
+ os.rename(hgtfile, bilfile)
+ north = tile[0]
+ ll_latitude = int(tile[1:3])
+ east = tile[3]
+ ll_longitude = int(tile[4:7])
+ # are we on the southern hemisphere? If yes, make LATITUDE negative.
+ if north == "S":
+ ll_latitude *= -1
+ # are we west of Greenwich? If yes, make LONGITUDE negative.
+ if east == "W":
+ ll_longitude *= -1
+ # Calculate Upper Left from Lower Left
+ ulxmap = "%.1f" % ll_longitude
+ # SRTM90 tile size is 1 deg:
+ ulymap = "%.1f" % (ll_latitude + 1)
+ if not one:
+ tmpl = tmpl3sec
+ else:
+ grass.message("Attempting to import 1-arcsec data.")
+ tmpl = tmpl1sec
+ header = tmpl % (ulxmap, ulymap)
+ hdrfile = tile + '.hdr'
+ outf = file(hdrfile, 'w')
+ outf.write(header)
+ outf.close()
+ #create prj file: To be precise, we would need EGS96! But who really cares...
+ prjfile = tile + '.prj'
+ outf = file(prjfile, 'w')
+ outf.write(proj)
+ outf.close()
+ if grass.run_command('r.in.gdal', input = bilfile, out = tileout) != 0:
+ grass.fatal("Unable to import data")
+ # nice color table
+ grass.run_command('r.colors', map = tileout, color = 'srtm')
+ # write cmd history:
+ grass.raster_history(tileout)
+ grass.message("Done: generated map " + tileout)
+ grass.message("(Note: Holes in the data can be closed with 'r.fillnulls' using splines)")
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
___________________________________________________________________
