[GRASS-SVN] r33655 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Oct 2 11:37:39 EDT 2008
Author: martinl
Date: 2008-10-02 11:37:38 -0400 (Thu, 02 Oct 2008)
New Revision: 33655
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
wxGUI: database encoding support implemented
(merge from devbr6, r33654)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-10-02 15:34:45 UTC (rev 33654)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-10-02 15:37:38 UTC (rev 33655)
@@ -58,6 +58,21 @@
from debug import Debug as Debug
from preferences import globalSettings as UserSettings
+def unicodeValue(value):
+ """Encode value"""
+ enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
+ if enc:
+ value = unicode(value, enc)
+ elif os.environ.has_key('GRASS_DB_ENCODING'):
+ value = unicode(value, os.environ['GRASS_DB_ENCODING'])
+ else:
+ try:
+ value = unicode(value, 'ascii')
+ except UnicodeDecodeError:
+ value = _("Unable to decode value. Set encoding in GUI preferences ('Attributes').")
+ return value
class Log:
The log output is redirected to the status bar of the containing frame.
@@ -234,11 +249,14 @@
for value in record.split('|'):
# casting ...
- try:
- self.itemDataMap[i].append(self.columns[columns[j]]['ctype'] (value))
- except:
- self.itemDataMap[i].append('')
+ if self.columns[columns[j]]['ctype'] != type(''):
+ try:
+ self.itemDataMap[i].append(self.columns[columns[j]]['ctype'] (value))
+ except ValueError:
+ self.itemDataMap[i].append('')
+ else:
+ self.itemDataMap[i].append(unicodeValue(value))
if keyId > -1 and keyId == j:
try:
cat = self.columns[columns[j]]['ctype'] (value)
@@ -330,7 +348,7 @@
def OnGetItemText(self, item, col):
"""Get item text"""
index = self.itemIndexMap[item]
- s = str(self.itemDataMap[index][col])
+ s = self.itemDataMap[index][col]
return s
def OnGetItemAttr(self, item):
@@ -1273,16 +1291,18 @@
for i in range(len(values)):
if i == keyId: # skip key column
continue
- if str(list.GetItem(item, i).GetText()) != str(values[i]):
+ if list.GetItem(item, i).GetText() != values[i]:
if len(values[i]) > 0:
try:
if missingKey is True:
idx = i - 1
else:
idx = i
- list.itemDataMap[item][idx] = \
- list.columns[columnName[i]]['ctype'] (values[i])
+ if list.columns[columnName[i]]['ctype'] != type(''):
+ list.itemDataMap[item][idx] = \
+ list.columns[columnName[i]]['ctype'] (values[i])
+ else:
+ list.itemDataMap[item][idx] = values[i]
except:
raise ValueError(_("Casting value '%(value)s' to %(type)s failed.") % \
{'value' : str(values[i]),
@@ -1294,14 +1314,13 @@
updateString += "%s=%s," % (columnName[i], values[i])
else: # NULL
updateString += "%s=NULL," % (columnName[i])
except ValueError, err:
wx.MessageBox(parent=self,
message="%s%s%s" % (_("Unable to update existing record."),
os.linesep, err),
caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
return
if len(updateString) > 0:
self.listOfSQLStatements.append('UPDATE %s SET %s WHERE %s=%d' % \
(table, updateString.strip(','),
@@ -1620,9 +1639,17 @@
# perform SQL non-select statements (e.g. 'delete from table where cat=1')
if len(self.listOfSQLStatements) > 0:
- sqlFile = tempfile.NamedTemporaryFile(mode="w")
+ sqlFile = tempfile.NamedTemporaryFile(mode="wt")
for sql in self.listOfSQLStatements:
- sqlFile.file.write(sql + ";\n")
+ if not enc and \
+ os.environ.has_key('GRASS_DB_ENCODING'):
+ enc = os.environ['GRASS_DB_ENCODING']
+ if enc:
+ sqlFile.file.write(sql.encode(enc))
+ else:
+ sqlFile.file.write(sql)
+ sqlFile.file.write(os.linesep)
sqlFile.file.flush()
driver = self.mapDBInfo.layers[self.layer]["driver"]
@@ -2878,7 +2905,7 @@
if newvalue == '':
newvalue = None
if newvalue != value:
updatedColumns.append(name)
if newvalue is None:
@@ -2956,13 +2983,21 @@
"""Submit records"""
sqlCommands = self.GetSQLString(updateValues=True)
if len(sqlCommands) > 0:
- sqlfile = tempfile.NamedTemporaryFile(mode="w")
+ sqlFile = tempfile.NamedTemporaryFile(mode="w")
for sql in sqlCommands:
- sqlfile.file.write(sql + ";\n")
- sqlfile.file.flush()
+ if not enc and \
+ if enc:
+ else:
+ sqlFile.file.flush()
gcmd.Command(cmd=["db.execute",
"--q",
- "input=%s" % sqlfile.name])
+ "input=%s" % sqlFile.name])
if self.closeDialog.IsChecked():
self.OnCancel(event)
@@ -3113,8 +3148,12 @@
continue
vtype = columns[name]['type']
if columns[name]['values'][idx] is not None:
- value = str(columns[name]['values'][idx])
+ if columns[name]['ctype'] != type(''):
+ value = str(columns[name]['values'][idx])
+ else:
+ value = columns[name]['values'][idx]
else:
value = ''
@@ -3124,7 +3163,8 @@
label="[" + vtype.lower() + "]")
delimiter = wx.StaticText(parent=panel, id=wx.ID_ANY, label=":")
- colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value) # TODO: validator
+ colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value)
colValue.SetName(name)
self.Bind(wx.EVT_TEXT, self.OnSQLStatement, colValue)
@@ -3199,7 +3239,10 @@
if len(value) < 1:
value = None
else:
- value = self.tables[table][name]['ctype'] (value.strip())
+ if self.tables[table][name]['ctype'] != type(''):
+ value = self.tables[table][name]['ctype'] (value.strip())
+ else:
+ value = unicodeValue(value.strip())
self.tables[table][name]['values'].append(value)
else:
if not data.has_key(key):
@@ -3211,7 +3254,7 @@
if key == 'Key column': # skip attributes
readAttrb = True
return data
def SelectFromTable(self, layer, cols='*', where=None):
@@ -3242,7 +3285,10 @@
name, value = line.split('|')
# casting ...
if value:
- value = self.tables[table][name]['ctype'] (value)
+ value = self.tables[table][name]['ctype'] (value)
+ else:
+ value = unicodeValue(value)
else:
value = None
@@ -3391,7 +3437,7 @@
for labelId, valueId in self.widgets:
column = self.FindWindowById(labelId).GetLabel().replace(':', '')
if columns is None or column in columns:
- value = str(self.FindWindowById(valueId).GetValue()) # -> string
+ value = self.FindWindowById(valueId).GetValue()
valueList.append(value)
# add key value
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-10-02 15:34:45 UTC (rev 33654)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2008-10-02 15:37:38 UTC (rev 33655)
@@ -33,6 +33,7 @@
import gcmd
import utils
+from preferences import globalSettings as UserSettings
wxCmdOutput, EVT_CMD_OUTPUT = NewEvent()
wxCmdProgress, EVT_CMD_PROGRESS = NewEvent()
@@ -198,7 +199,7 @@
if Debug.get_level() == 0:
# don't redirect when debugging is enabled
- # sys.stdout = self.cmd_stdout
+ sys.stdout = self.cmd_stdout
sys.stderr = self.cmd_stderr
return True
@@ -735,4 +736,16 @@
self.AddText(seg)
else:
self.parent.linePos = self.GetCurrentPos()
- self.AddText(txt)
+ try:
+ self.AddText(txt)
+ if enc:
+ txt = unicode(txt, enc)
+ txt = unicode(txt, os.environ['GRASS_DB_ENCODING'])
+ else:
+ txt = _('Unable to encode text. Please set encoding in GUI preferences.') + os.linesep
+ self.AddText(txt)
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-10-02 15:34:45 UTC (rev 33654)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-10-02 15:37:38 UTC (rev 33655)
@@ -129,7 +129,10 @@
'keycolumn' : {
'value' : 'cat'
+ 'encoding' : {
+ 'value' : '',
# Command
@@ -1227,6 +1230,16 @@
flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(leftDbClick, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ # encoding
+ label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Encoding"))
+ encoding = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
+ value=self.settings.Get(group='atm', key='encoding', subkey='value'),
+ name="GetValue", size=(200, -1))
+ self.winId['atm:encoding:value'] = encoding.GetId()
+ flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(encoding, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
# ask on delete record
askOnDeleteRec = wx.CheckBox(parent=panel, id=wx.ID_ANY,
label=_("Ask when deleting data record(s) from table"),
