[GRASS-SVN] r33660 - grass/branches/develbranch_6/vector/v.digit
Fri Oct 3 04:33:12 EDT 2008
Author: marisn
Date: 2008-10-03 04:33:12 -0400 (Fri, 03 Oct 2008)
New Revision: 33660
   grass/branches/develbranch_6/vector/v.digit/settings.tcl
   grass/branches/develbranch_6/vector/v.digit/toolbox.tcl
Add undo to add new column command in v.digit
Modified: grass/branches/develbranch_6/vector/v.digit/settings.tcl
--- grass/branches/develbranch_6/vector/v.digit/settings.tcl	2008-10-03 08:29:43 UTC (rev 33659)
+++ grass/branches/develbranch_6/vector/v.digit/settings.tcl	2008-10-03 08:33:12 UTC (rev 33660)
@@ -33,7 +33,7 @@
 proc add_tab_col { name type width namedit typedit widthedit } {
-    global tabrow columns table_frame
+    global tabrow columns table_frame iconpath
     set row [ frame $table_frame.row$tabrow ]
     set columns(frm,$tabrow) $row
@@ -41,6 +41,7 @@
     set columns(name,$tabrow) $name
     set columns(type,$tabrow) $type
     set columns(width,$tabrow) $width
+    set columns(rem,$tabrow) 0
     Entry $row.a -width 20 -textvariable columns(name,$tabrow) -bg white
     if { $namedit == 0 } { $row.a configure -state disabled }
@@ -50,14 +51,25 @@
     if { $typedit == 0 } { $row.b configure -state disabled }
     Entry $row.c -width 10 -textvariable columns(width,$tabrow) -bg white
     if { $widthedit == 0 } { $row.c configure -state disabled }
-    set_col_type $tabrow
-    pack $row.a $row.b $row.c -side left;
+    set_col_type $tabrow
+    Button $row.d -image [image create photo -file "$iconpath/remove.gif"]  \
+    	-borderwidth 1\
+    	-command "rem_tab_col $row $tabrow"
+    if { $typedit == 0 } { $row.d configure -state disabled }
+    pack $row.a $row.b $row.c $row.d -side left;
     pack $row -side top -fill x -expand no -anchor n
     incr tabrow
+proc rem_tab_col { row num } {
+	global columns
+	set columns(rem,$num) 1
+	destroy $row
 proc table_buttons { } {
     global table_page
     set addcol [Button $table_page.addcol -text [G_msg "Add new column"]  \
@@ -115,12 +127,14 @@
     global tabrow columns create_table_err create_table_msg
     set coldef ""
-    for {set i 1} {$i < $tabrow} {incr i} {
-        if { $i > 1 } { append coldef ", " }
-        append coldef "$columns(name,$i) $columns(type,$i) "
-        if { $columns(type,$i) == "varchar" } {
-            append coldef "( $columns(width,$i) )"
+    for {set i 1} {$i < $tabrow} {incr i} {
+    	if { $columns(rem,$i) == 0 } {
+        	if { $i > 1 } { append coldef ", " }
+        	append coldef "$columns(name,$i) $columns(type,$i) "
+        	if { $columns(type,$i) == "varchar" } {
+            		append coldef "( $columns(width,$i) )"
     puts $coldef
@@ -130,9 +144,9 @@
     c_create_table $field $field_name $columns(name,1) $coldef
     if { $create_table_err == 1 } {
-        MessageDlg .msg -type ok -message $create_table_msg
+        MessageDlg .msg -icon error -parent .settings -type ok -message $create_table_msg
     } else {
-        MessageDlg .msg -type ok -message [G_msg "Table successfully created"]
+        MessageDlg .msg -icon info -parent .settings -type ok -message [G_msg "Table successfully created"]
         clear_table
         c_table_definition
Modified: grass/branches/develbranch_6/vector/v.digit/toolbox.tcl
--- grass/branches/develbranch_6/vector/v.digit/toolbox.tcl	2008-10-03 08:29:43 UTC (rev 33659)
+++ grass/branches/develbranch_6/vector/v.digit/toolbox.tcl	2008-10-03 08:33:12 UTC (rev 33660)
@@ -23,7 +23,7 @@
 set prompt_right [G_msg "Right button"]
 set coor ""
-wm title . "v.digit - $map_name@$map_mapset"
+wm title . "v.digit toolbox - $map_name@$map_mapset"
 proc get_update_line {ox oy x y} {
     .screen.canvas delete active
