[GRASS-SVN] r33667 - grass/trunk/raster/r.series
svn_grass at osgeo.org
Sat Oct 4 04:28:33 EDT 2008
Author: glynn
Date: 2008-10-04 04:28:33 -0400 (Sat, 04 Oct 2008)
New Revision: 33667
grass/trunk/raster/r.series/main.c
Allow multiple aggregates to be computed in one run
Modified: grass/trunk/raster/r.series/main.c
--- grass/trunk/raster/r.series/main.c 2008-10-04 08:27:30 UTC (rev 33666)
+++ grass/trunk/raster/r.series/main.c 2008-10-04 08:28:33 UTC (rev 33667)
@@ -54,11 +54,19 @@
struct input
- char *name;
+ const char *name;
int fd;
DCELL *buf;
+struct output
+ const char *name;
+ int fd;
+ DCELL *buf;
+ stat_func *method_fn;
static char *build_method_list(void)
char *buf = G_malloc(1024);
@@ -78,6 +86,19 @@
return buf;
+static int find_method(const char *method_name)
+ int i;
+ for (i = 0; menu[i].name; i++)
+ if (strcmp(menu[i].name, method_name) == 0)
+ return i;
+ G_fatal_error(_("Unknown method <%s>"), method_name);
+ return -1;
int main(int argc, char *argv[])
struct GModule *module;
@@ -89,16 +110,13 @@
struct Flag *nulls;
} flag;
- int method;
- stat_func *method_fn;
int i;
int num_inputs;
struct input *inputs;
- char *out_name;
- int out_fd;
+ int num_outputs;
+ struct output *outputs;
struct History history;
- DCELL *out_buf;
- DCELL *values;
+ DCELL *values, *values_tmp;
int nrows, ncols;
int row, col;
@@ -114,6 +132,7 @@
parm.input = G_define_standard_option(G_OPT_R_INPUTS);
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.output->multiple = YES;
parm.method = G_define_option();
parm.method->key = "method";
@@ -121,6 +140,7 @@
parm.method->required = YES;
parm.method->options = build_method_list();
parm.method->description = _("Aggregate operation");
+ parm.method->multiple = YES;
flag.nulls = G_define_flag();
flag.nulls->key = 'n';
@@ -129,20 +149,9 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- /* get the method */
- method = -1;
- for (i = 0; menu[i].name; i++)
- if (strcmp(menu[i].name, parm.method->answer) == 0) {
- method = i;
- break;
- if (method < 0)
- G_fatal_error(_("Unknown method <%s>"), parm.method->answer);
- method_fn = menu[method].method;
/* process the input maps */
- for (i = 0; parm.input->answers[i]; i++) ;
+ for (i = 0; parm.input->answers[i]; i++)
num_inputs = i;
if (num_inputs < 1)
@@ -162,19 +171,36 @@
p->buf = G_allocate_d_raster_buf();
- /* process the output map */
- out_name = parm.output->answer;
+ /* process the output maps */
+ for (i = 0; parm.output->answers[i]; i++)
+ num_outputs = i;
- out_fd =
- G_open_raster_new(out_name,
- menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
- if (out_fd < 0)
- G_fatal_error(_("Unable to create raster map <%s>"), out_name);
+ for (i = 0; parm.method->answers[i]; i++)
+ if (num_outputs != i)
+ G_fatal_error(_("output= and method= must have the same number of values"));
- out_buf = G_allocate_d_raster_buf();
+ outputs = G_calloc(num_outputs, sizeof(struct output));
+ for (i = 0; i < num_outputs; i++) {
+ struct output *out = &outputs[i];
+ const char *output_name = parm.output->answers[i];
+ const char *method_name = parm.method->answers[i];
+ int method = find_method(method_name);
+ out->name = output_name;
+ out->method_fn = menu[method].method;
+ out->buf = G_allocate_d_raster_buf();
+ out->fd = G_open_raster_new(
+ output_name, menu[method].is_int ? CELL_TYPE : DCELL_TYPE);
+ if (out->fd < 0)
+ G_fatal_error(_("Unable to create raster map <%s>"), out->name);
/* initialise variables */
values = G_malloc(num_inputs * sizeof(DCELL));
+ values_tmp = G_malloc(num_inputs * sizeof(DCELL));
nrows = G_window_rows();
ncols = G_window_cols();
@@ -200,24 +226,35 @@
values[i] = v;
- if (null && flag.nulls->answer)
- G_set_d_null_value(&out_buf[col], 1);
- else
- (*method_fn) (&out_buf[col], values, num_inputs);
+ if (null && flag.nulls->answer)
+ G_set_d_null_value(&out->buf[col], 1);
+ else {
+ memcpy(values_tmp, values, num_inputs * sizeof(DCELL));
+ (*out->method_fn)(&out->buf[col], values_tmp, num_inputs);
- G_put_d_raster_row(out_fd, out_buf);
+ G_put_d_raster_row(outputs[i].fd, outputs[i].buf);
G_percent(row, nrows, 2);
/* close maps */
- G_close_cell(out_fd);
- G_short_history(out_name, "raster", &history);
- G_command_history(&history);
- G_write_history(out_name, &history);
+ G_close_cell(out->fd);
+ G_short_history(out->name, "raster", &history);
+ G_command_history(&history);
+ G_write_history(out->name, &history);
for (i = 0; i < num_inputs; i++)
G_close_cell(inputs[i].fd);
