[GRASS-SVN] r33669 - grass/branches/develbranch_6/general/g.mremove
Sat Oct 4 06:13:51 EDT 2008
Author: hamish
Date: 2008-10-04 06:13:51 -0400 (Sat, 04 Oct 2008)
New Revision: 33669
   grass/branches/develbranch_6/general/g.mremove/main.c
explain what needs to happen
Modified: grass/branches/develbranch_6/general/g.mremove/main.c
--- grass/branches/develbranch_6/general/g.mremove/main.c	2008-10-04 10:03:09 UTC (rev 33668)
+++ grass/branches/develbranch_6/general/g.mremove/main.c	2008-10-04 10:13:51 UTC (rev 33669)
@@ -103,6 +103,9 @@
     if (flag.regex->answer && flag.extended->answer)
 	G_fatal_error(_("-r and -e are mutually exclusive"));
+    if (!flag.force->answer)
+	G_message(_("The following files would be deleted:"));
     for (n = 0; n < nlist; n++) {
 	o = opt[n];
 	G_free((char *)o->gisprompt);
@@ -123,8 +126,8 @@
 		    name = wc2regex(name);
 		if (regcomp(&regex, name,
 			    (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
-		    G_fatal_error(_
-				  ("Unable to compile regular expression %s"),
+		    G_fatal_error(
+				  _("Unable to compile regular expression %s"),
 				  name);
 		if (!flag.regex->answer && !flag.extended->answer)
 		    G_free(name);
@@ -150,6 +153,11 @@
+    if (!flag.force->answer) {
+	G_message(" ");
+	G_message(_("You must use the force flag to actually remove them. Exiting."));
     exit(result);
