[GRASS-SVN] r33671 - grass/branches/develbranch_6/lib/init
svn_grass at osgeo.org
Sat Oct 4 12:23:02 EDT 2008
Author: pkelly
Date: 2008-10-04 12:23:02 -0400 (Sat, 04 Oct 2008)
New Revision: 33671
grass/branches/develbranch_6/lib/init/gis_set.tcl
Don't crash when there are no accessible mapsets
Modified: grass/branches/develbranch_6/lib/init/gis_set.tcl
--- grass/branches/develbranch_6/lib/init/gis_set.tcl 2008-10-04 10:15:58 UTC (rev 33670)
+++ grass/branches/develbranch_6/lib/init/gis_set.tcl 2008-10-04 16:23:02 UTC (rev 33671)
@@ -573,10 +573,9 @@
if { [CheckLocation] } {
# setting list of mapsets
refresh_ms
- selFromList .frame0.frameMS.listbox $mapset
- if { [.frame0.frameMS.listbox get [.frame0.frameMS.listbox curselection]] == $mapset } {
- .frame0.frameBUTTONS.ok configure -state normal
+ if { [selFromList .frame0.frameMS.listbox $mapset] } {
+ .frame0.frameBUTTONS.ok configure -state normal
bind .frame0.frameDB.mid.entry <Return> {
@@ -756,16 +755,21 @@
proc selFromList { lis str } {
# Selects list entry, if there is match
set siz [$lis size]
- set curSelected 0
+ set curSelected ""
for { set x 0 } { $x < $siz } { incr x } {
if { $str == [$lis get $x] } {
set curSelected $x
break
- $lis yview $curSelected
- $lis selection clear 0 end
- $lis select set $curSelected
+ if { $curSelected != "" } {
+ $lis yview $curSelected
+ $lis selection clear 0 end
+ $lis select set $curSelected
+ return 1
+ } else {
+ return 0
