[GRASS-SVN] r33707 - grass/trunk/scripts/i.spectral
svn_grass at osgeo.org
Tue Oct 7 01:20:15 EDT 2008
Author: glynn
Date: 2008-10-07 01:20:15 -0400 (Tue, 07 Oct 2008)
New Revision: 33707
Added:
grass/trunk/scripts/i.spectral/i.spectral.py
Convert i.spectral to Python
Added: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py (rev 0)
+++ grass/trunk/scripts/i.spectral/i.spectral.py 2008-10-07 05:20:15 UTC (rev 33707)
@@ -0,0 +1,192 @@
+#!/usr/bin/env python
+# MODULE: i.spectral
+# AUTHOR(S): Markus Neteler, 18. August 1998
+# Converted to Python by Glynn Clements
+# PURPOSE: displays spectral response at user specified locations in group or images
+# COPYRIGHT: (C) 1999 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# written by Markus Neteler 18. August 1998
+# neteler geog.uni-hannover.de
+# bugfix: 25. Nov.98/20. Jan. 1999
+# 3 March 2006: Added multiple images and group support by Francesco Pirotti - CIRGEO
+# this script needs gnuplot
+#%Module
+#% description: displays spectral response at user specified locations in group or images
+#% keywords: imagery, raster, multispectral
+#%End
+#%option
+#% key: group
+#% type: string
+#% gisprompt: old,group
+#% description: group input
+#% required : no
+#%end
+#%option
+#% key: raster
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: raster input maps
+#% multiple : yes
+#% required : no
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,PNG
+#% description: write output to PNG image
+#% multiple : no
+#% required : no
+#%end
+#%option
+#% key: coords
+#% type: double
+#% key_desc: east,north
+#% description: coordinates
+#% multiple : yes
+#% required : yes
+#%end
+#%flag
+#%key: c
+#%description: label with coordinates instead of numbering
+#%end
+import sys
+import os
+import subprocess
+import atexit
+import glob
+import grass
+def cleanup():
+ grass.try_remove('spectrum.gnuplot')
+ for name in glob.glob('data_[0-9]*'):
+ if name[5:].isdigit():
+ grass.try_remove(name)
+def main():
+ group = options['group']
+ raster = options['raster']
+ output = options['output']
+ coords = options['coords']
+ label = flags['c']
+ if not group and not raster:
+ grass.fatal("Either group= or raster= is required")
+ if group and raster:
+ grass.fatal("group= and raster= are mutually exclusive")
+ #check if present
+ if not grass.find_program('gnuplot', ['-V']):
+ grass.fatal("gnuplot required, please install first")
+ tmp1 = grass.tempfile()
+ tmp2 = grass.tempfile()
+ # get y-data for gnuplot-data file
+ # get data from group files and set the x-axis labels
+ if group:
+ # ## PARSES THE GROUP FILES - gets rid of ugly header info from group list output
+ maps = []
+ s = grass.read_command('i.group', flags='l', group = group, quiet = True)
+ active = False
+ for l in s.splitlines():
+ if l == '-------------':
+ active = not active
+ continue
+ if not active:
+ continue
+ f = l.replace(' in ','@').split()
+ maps += f
+ rastermaps = maps
+ else:
+ # ## get data from list of files and set the x-axis labels
+ rastermaps = raster.split(',')
+ xlabels = ["'%s' %d" % (n, i) for i, n in enumerate(rastermaps)]
+ xlabels = ','.join(xlabels)
+ numbands = len(rastermaps)
+ what = []
+ s = grass.read_command('r.what', input = rastermaps, east_north = coords, quiet = True)
+ f = l.split('|')
+ for i, v in enumerate(f):
+ if v in ['', '*']:
+ f[i] = 0
+ else:
+ f[i] = float(v)
+ what.append(f)
+ numclicks = len(what)
+ start = 0
+ num = numbands
+ # build data files
+ for i, row in enumerate(what):
+ outfile = 'data_%d' % i
+ outf = file(outfile, 'w')
+ for j, val in enumerate(row[3:]):
+ outf.write("%s %s\n" % (j, val))
+ outf.close()
+ xrange = numbands + 1
+ # build gnuplot script
+ lines = []
+ if output:
+ lines += [
+ "set term png large",
+ "set output '%s'" % output
+ lines += [
+ "set xtics (%s)" % xlabels,
+ "set grid",
+ "set title 'Spectral signatures'",
+ "set xrange [0:%s]" % xrange,
+ "set noclabel",
+ "set xlabel 'Bands'",
+ "set ylabel 'DN Value'",
+ "set data style lines"
+ cmd = []
+ if not label:
+ title = str(i)
+ else:
+ title = str(tuple(row[0:2]))
+ cmd.append("'data_%d' title '%s'" % (i, title))
+ cmd = ','.join(cmd)
+ cmd = ' '.join(['plot', cmd, "with linespoints pt 779"])
+ lines.append(cmd)
+ plotfile = 'spectrum.gnuplot'
+ plotf = file(plotfile, 'w')
+ for line in lines:
+ plotf.write(line + '\n')
+ plotf.close()
+ if output:
+ subprocess.call(['gnuplot', plotfile])
+ else:
+ subprocess.call(['gnuplot', '-persist', plotfile])
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass/trunk/scripts/i.spectral/i.spectral.py
___________________________________________________________________
