[GRASS-SVN] r33717 - grass/trunk/lib/gis
svn_grass at osgeo.org
Tue Oct 7 06:02:00 EDT 2008
Author: glynn
Date: 2008-10-07 06:01:59 -0400 (Tue, 07 Oct 2008)
New Revision: 33717
grass/trunk/lib/gis/null_val.c
Make G_is_[fd]_null_value() check for any NaN, not just all-ones
Modified: grass/trunk/lib/gis/null_val.c
--- grass/trunk/lib/gis/null_val.c 2008-10-07 09:07:12 UTC (rev 33716)
+++ grass/trunk/lib/gis/null_val.c 2008-10-07 10:01:59 UTC (rev 33717)
@@ -427,22 +427,7 @@
int G_is_f_null_value(const FCELL * fcellVal)
- int i; /* counter */
- /* Check if the null patterns have been initialized */
- if (!initialized) {
- InitError();
- /* Check if the FCELL value matches the null pattern */
- for (i = 0; i < sizeof(FCELL); i++) {
- if (((unsigned char *)fcellVal)[i] !=
- ((unsigned char *)&fcellNullPattern)[i]) {
- return FALSE;
- return TRUE;
+ return *fcellVal != *fcellVal;
@@ -467,22 +452,7 @@
int G_is_d_null_value(const DCELL * dcellVal)
- InitError();
- /* Check if the DCELL value matches the null pattern */
- for (i = 0; i < sizeof(DCELL); i++) {
- if (((unsigned char *)dcellVal)[i] !=
- ((unsigned char *)&dcellNullPattern)[i]) {
- return FALSE;
- return TRUE;
+ return *dcellVal != *dcellVal;
