[GRASS-SVN] r33728 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Tue Oct 7 09:38:51 EDT 2008
Author: martinl
Date: 2008-10-07 09:38:51 -0400 (Tue, 07 Oct 2008)
New Revision: 33728
grass/trunk/gui/wxpython/gui_modules/colorrules.py
grass/trunk/gui/wxpython/gui_modules/globalvar.py
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/workspace.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: colorrules module cleaned
map scale mode fixed
workspace updated for constrain comp resolution
various minor fixes
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -1,147 +1,166 @@
-MODULE: colorrules.py
+ at package colorrules.py
-CLASSES:
- * ColorTable
- * BuferedWindow
+ at brief Dialog for interactive management of raster color tables and vector
+rgb_column
-PURPOSE: Dialog for interactive management of raster color tables and vector
- rgb_column
+Classes:
+ - ColorTable
+ - BuferedWindow
-AUTHORS: The GRASS Development Team
- Michael Barton (Arizona State University)
+(C) 2008 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
-COPYRIGHT: (C) 2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ at author Michael Barton (Arizona State University)
+ at author Martin Landa <landa.martin gmail.com> (various updates)
import os
import sys
import shutil
-from debug import Debug as Debug
import wx
-import wx.lib.colourselect as csel
+import wx.lib.colourselect as csel
import wx.lib.scrolledpanel as scrolled
+import grass
import dbm
import gcmd
import globalvar
import gselect
import render
import utils
+from debug import Debug as Debug
+from preferences import globalSettings as UserSettings
class ColorTable(wx.Frame):
def __init__(self, parent, id=wx.ID_ANY, title='',
pos=wx.DefaultPosition, size=(-1, -1),
- style=wx.DEFAULT_FRAME_STYLE|wx.RESIZE_BORDER,
+ style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
**kwargs):
wx.Frame.__init__(self, parent, id, title, pos, size, style)
- Dialog for interactively entering rules
- for map management commands
+ Dialog for interactively entering rules for map management
+ commands
@param cmd command (given as list)
+ self.parent = parent # GMFrame
- self.CentreOnParent()
- self.parent = parent
- self.cmd = kwargs['cmd'] # grass command
- self.inmap = '' # input map to change
- self.rastmin = '' # min cat in raster map
- self.rastmax = '' # max cat in raster map
- self.layerchoices = ['1'] # list of database layers for vector (minimum of 1)
- self.columnchoices = [] # list of database columns for vector
- self.vlayer = 1 # vector layer for attribute table to use for setting color
- self.vtable = '' # vector attribute table used for setting color
- self.vcolumn = '' # vector attribute column for assigning colors
- self.vrgb = '' # vector attribute column to use for storing colors
- self.old_colrtable = '' # existing color table of raster map
- self.vals = '' # raster category or vector attribute values for assigning colors
- self.rgb_string = '' # r:g:b color string for assigning colors to cats
- self.ruleslines = {} # rules for creating colortable
- self.overwrite = True
- self.Map = render.Map() # instance of render.Map to be associated with display
- self.layer = None # reference to layer with preview
- self.mapname = ''
+ # grass command
+ self.cmd = kwargs['cmd']
+ # input map to change
+ self.inmap = ''
+ # raster properties
+ self.rast = {
+ # min cat in raster map
+ 'min' : None,
+ # max cat in raster map
+ 'max' : None,
+ # vector properties
+ self.vect = {
+ # list of database layers for vector (minimum of 1)
+ 'layers' : ['1'],
+ # list of database columns for vector
+ 'columns' : [],
+ # vector layer for attribute table to use for setting color
+ 'layer' : 1,
+ # vector attribute table used for setting color
+ 'table' : '',
+ # vector attribute column for assigning colors
+ 'column' : '',
+ # vector attribute column to use for storing colors
+ 'rgb' : '',
+ # rules for creating colortable
+ self.ruleslines = {}
+ # instance of render.Map to be associated with display
+ self.Map = render.Map()
+ # reference to layer with preview
+ self.layer = None
if self.cmd == 'r.colors':
- title = 'Create new color table for raster map'
- maplabel = 'Select raster map:'
- elem = 'cell'
- crlabel = 'Enter raster cat values or percents'
+ self.SetTitle(_('Create new color table for raster map'))
+ self.elem = 'cell'
+ crlabel = _('Enter raster cat values or percents')
elif self.cmd == 'vcolors':
- title = 'Create new color table for vector map'
- maplabel = 'Select vector map:'
- elem = 'vector'
- crlabel = 'Enter vector attribute values or ranges (n or n1 to n2)'
+ self.SetTitle(_('Create new color table for vector map'))
+ self.elem = 'vector'
+ crlabel = _('Enter vector attribute values or ranges (n or n1 to n2)')
# Set the size & cursor
self.SetClientSize(size)
- # set window frame title
- self.SetTitle(title)
+ ### self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
# top controls
- self.map_label = wx.StaticText(parent=self, id=wx.ID_ANY, label=maplabel)
self.selectionInput = gselect.Select(parent=self, id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE,
- type=elem)
+ type=self.elem)
self.ovrwrtcheck = wx.CheckBox(parent=self, id=wx.ID_ANY,
- label=_('replace existing color table'))
- self.ovrwrtcheck.SetValue(self.overwrite)
+ label=_('replace existing color table'))
+ self.ovrwrtcheck.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
self.helpbtn = wx.Button(parent=self, id=wx.ID_HELP)
- if self.cmd == 'vcolors':
+ if self.elem == 'vector':
self.cb_vl_label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label='Layer:')
+ label=_('Layer:'))
self.cb_vc_label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label='Attribute column:')
+ label=_('Attribute column:'))
self.cb_vrgb_label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label='RGB color column:')
+ label=_('RGB color column:'))
self.cb_vlayer = gselect.LayerSelect(self)
- self.cb_vcol = gselect.ColumnSelect(self, vector='', layer='')
- self.cb_vrgb = gselect.ColumnSelect(self, vector='', layer='')
+ self.cb_vcol = gselect.ColumnSelect(self)
+ self.cb_vrgb = gselect.ColumnSelect(self)
# color table and preview window
self.cr_label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=crlabel)
+ label=crlabel)
self.cr_panel = self.__colorrulesPanel()
- self.InitDisplay() # initialize preview display
- self.preview = BufferedWindow(self, id = wx.ID_ANY, size=(400,300), Map=self.Map)
+ # add two rules as default
+ self.AddRules(2)
- # bottom controls
- self.line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(-1,-1),
- style=wx.LI_HORIZONTAL)
- cancel_btn = wx.Button(self, wx.ID_CANCEL)
- apply_btn = wx.Button(self, wx.ID_APPLY)
- ok_btn = wx.Button(self, wx.ID_OK)
- ok_btn.SetDefault()
+ self.numRules = wx.SpinCtrl(parent=self, id=wx.ID_ANY,
+ min=1, max=1e6)
- self.btnsizer = wx.StdDialogButtonSizer()
- self.btnsizer.Add(cancel_btn, flag=wx.ALL, border=5)
- self.btnsizer.Add(apply_btn, flag=wx.ALL, border=5)
- self.btnsizer.Add(ok_btn, flag=wx.ALL, border=5)
- self.btnsizer.Realize()
+ # initialize preview display
+ self.InitDisplay()
+ self.preview = BufferedWindow(self, id=wx.ID_ANY, size=(400, 300),
+ Map=self.Map)
+ self.preview.EraseMap()
- self.preview_btn = wx.Button(self, wx.ID_ANY, _("Preview"))
+ self.btnCancel = wx.Button(parent=self, id=wx.ID_CANCEL)
+ self.btnApply = wx.Button(parent=self, id=wx.ID_APPLY)
+ self.btnOK = wx.Button(parent=self, id=wx.ID_OK)
+ self.btnOK.SetDefault()
+ self.btnOK.Enable(False)
+ self.btnApply.Enable(False)
+ self.btnPreview = wx.Button(parent=self, id=wx.ID_ANY,
+ label=_("Preview"))
+ self.btnPreview.Enable(False)
+ self.btnAdd = wx.Button(parent=self, id=wx.ID_ADD)
# bindings
self.Bind(wx.EVT_BUTTON, self.OnHelp, self.helpbtn)
- self.Bind(wx.EVT_CHECKBOX, self.OnOverwrite, self.ovrwrtcheck)
self.selectionInput.Bind(wx.EVT_TEXT, self.OnSelectionInput)
- self.Bind(wx.EVT_BUTTON, self.OnCancel, cancel_btn)
- self.Bind(wx.EVT_BUTTON, self.OnApply, apply_btn)
- self.Bind(wx.EVT_BUTTON, self.OnOK, ok_btn)
- self.Bind(wx.EVT_BUTTON, self.OnPreview, self.preview_btn)
+ self.Bind(wx.EVT_BUTTON, self.OnCancel, self.btnCancel)
+ self.Bind(wx.EVT_BUTTON, self.OnApply, self.btnApply)
+ self.Bind(wx.EVT_BUTTON, self.OnOK, self.btnOK)
+ self.Bind(wx.EVT_BUTTON, self.OnPreview, self.btnPreview)
+ self.Bind(wx.EVT_BUTTON, self.OnAddRules, self.btnAdd)
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
# additional bindings for vector color management
@@ -150,88 +169,165 @@
self.Bind(wx.EVT_COMBOBOX, self.OnColumnSelection, self.cb_vcol)
self.Bind(wx.EVT_COMBOBOX, self.OnRGBColSelection, self.cb_vrgb)
+ # set map layer from layer tree
+ try:
+ layer = self.parent.curr_page.maptree.layer_selected
+ except:
+ layer = None
+ if layer:
+ mapLayer = self.parent.curr_page.maptree.GetPyData(layer)[0]['maplayer']
+ name = mapLayer.GetName()
+ type = mapLayer.GetType()
+ if (type == 'raster' and self.elem == 'cell') or \
+ (type == 'vector' and self.elem == 'vector'):
+ self.selectionInput.SetValue(name)
+ self.inmap = name
+ self.OnSelectionInput(None)
# layout
self.__doLayout()
+ self.CentreOnScreen()
self.Show()
def __doLayout(self):
- sizer = wx.GridBagSizer(hgap=5, vgap=5)
- sizer.AddGrowableCol(2)
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # input
+ if self.cmd == 'r.colors':
+ maplabel = _('Select raster map:')
+ elif self.cmd == 'vcolors':
+ maplabel = _('Select vector map:')
+ inputBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
+ label=" %s " % maplabel)
+ inputSizer = wx.StaticBoxSizer(inputBox, wx.VERTICAL)
+ inputSizer.Add(item=self.selectionInput,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border=5)
+ replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
+ replaceSizer.Add(item=self.ovrwrtcheck, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=1)
+ replaceSizer.Add(item=self.helpbtn, proportion=0,
+ flag=wx.ALIGN_RIGHT | wx.ALL, border=1)
+ inputSizer.Add(item=replaceSizer, proportion=1,
+ # body & preview
+ bodySizer = wx.GridBagSizer(hgap=5, vgap=5)
row = 0
- sizer.Add(self.map_label, pos=(row,0),
- flag=wx.ALIGN_CENTER_VERTICAL|wx.EXPAND|wx.ALL, border=5)
- row += 1 # row 1
- sizer.Add(item=self.selectionInput, pos=(row,0), span=(1,3),
- flag=wx.ALIGN_CENTER_VERTICAL|wx.EXPAND | wx.ALL, border=5)
- row += 1 # row 2
- sizer.Add(item=self.ovrwrtcheck, pos=(row, 0), span=(1,2),
- flag=wx.ALL, border=5)
- sizer.Add(item=self.helpbtn, pos=(row,2), flag=wx.ALIGN_RIGHT|wx.ALL, border=5)
+ bodySizer.Add(item=self.cr_label, pos=(row, 0), span=(1, 3),
+ flag=wx.ALL, border=5)
+ vSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ vSizer.Add(self.cb_vl_label, pos=(0, 0),
+ flag=wx.ALIGN_CENTER_VERTICAL)
+ vSizer.Add(self.cb_vlayer, pos=(0, 1),
+ vSizer.Add(self.cb_vc_label, pos=(0, 2),
+ vSizer.Add(self.cb_vcol, pos=(0, 3),
+ vSizer.Add(self.cb_vrgb_label, pos=(1, 2),
+ vSizer.Add(self.cb_vrgb, pos=(1, 3),
row += 1
- sizer.Add(self.cb_vl_label, pos=(row,0),
- flag=wx.ALIGN_CENTER_VERTICAL|wx.LEFT, border=10)
- sizer.Add(self.cb_vc_label, pos=(row,1),
- sizer.Add(self.cb_vrgb_label, pos=(row,2),
- row += 1
- sizer.Add(self.cb_vlayer, pos=(row,0),
- flag=wx.ALIGN_CENTER_VERTICAL|wx.LEFT, border=5)
- sizer.Add(self.cb_vcol, pos=(row,1),
- sizer.Add(self.cb_vrgb, pos=(row,2),
+ bodySizer.Add(item=vSizer, pos=(row, 0), span=(1, 3))
+ row += 1
+ bodySizer.Add(item=self.cr_panel, pos=(row, 0), span=(1, 2))
+ bodySizer.Add(item=self.preview, pos=(row, 2),
+ flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=10)
+ bodySizer.AddGrowableCol(2)
+ row += 1
+ bodySizer.Add(item=self.numRules, pos=(row, 0),
+ bodySizer.Add(item=self.btnAdd, pos=(row, 1))
+ bodySizer.Add(item=self.btnPreview, pos=(row, 2),
+ flag=wx.ALIGN_RIGHT)
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(self.btnCancel,
+ flag=wx.LEFT | wx.RIGHT, border=5)
+ btnSizer.Add(self.btnApply,
+ btnSizer.Add(self.btnOK,
+ sizer.Add(item=inputSizer, proportion=0,
+ flag=wx.ALL | wx.EXPAND, border=5)
+ sizer.Add(item=bodySizer, proportion=1,
- row += 1 # row 3
- sizer.Add(item=self.cr_label, pos=(row,0), span=(1,2), flag=wx.ALL, border=5)
- row += 1 # row 4
- sizer.AddGrowableRow(row)
- sizer.Add(item=self.cr_panel, pos=(row,0),
- flag=wx.EXPAND|wx.LEFT|wx.RIGHT, border=10)
- sizer.Add(item=self.preview, pos=(row,1), span=(1,2),
- flag=wx.ALIGN_LEFT|wx.EXPAND|wx.LEFT|wx.RIGHT, border=10)
- row += 1 # row 5
- sizer.Add(item=self.line, pos=(row,0), span=(1,3),
- flag=wx.GROW|wx.EXPAND|wx.ALIGN_CENTER_VERTICAL|
- wx.TOP|wx.BOTTOM, border=5)
- row += 1 # row 6
- sizer.Add(self.btnsizer, pos=(row,0), span=(1,2),
- flag=wx.ALIGN_CENTER|wx.FIXED_MINSIZE)
- sizer.Add(self.preview_btn, pos=(row,2),
- flag=wx.ALIGN_BOTTOM|wx.ALIGN_CENTER|wx.FIXED_MINSIZE|wx.ALL, border=5)
+ sizer.Add(item=wx.StaticLine(parent=self, id=wx.ID_ANY,
+ style=wx.LI_HORIZONTAL),
+ proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=5)
+ sizer.Add(item=btnSizer, proportion=0,
+ flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
self.SetSizer(sizer)
sizer.Fit(self)
+ self.Layout()
def __colorrulesPanel(self):
- cr_panel = scrolled.ScrolledPanel(self, -1, size=(180,300),
- style=wx.TAB_TRAVERSAL|wx.SUNKEN_BORDER,
- name="cr_panel" )
- cr_sizer = wx.GridBagSizer(vgap=2, hgap=4)
+ cr_panel = scrolled.ScrolledPanel(parent=self, id=wx.ID_ANY,
+ size=(180, 300),
+ style=wx.TAB_TRAVERSAL | wx.SUNKEN_BORDER)
+ self.cr_sizer = wx.GridBagSizer(vgap=2, hgap=4)
+ cr_panel.SetSizer(self.cr_sizer)
+ cr_panel.SetAutoLayout(True)
+ return cr_panel
- for num in range(100):
- txt_ctrl = wx.TextCtrl(parent=cr_panel, id=num, value='',
- pos=wx.DefaultPosition, size=(100,-1),
+ def OnAddRules(self, event):
+ """Add rules button pressed"""
+ nrules = self.numRules.GetValue()
+ self.AddRules(nrules)
+ def AddRules(self, nrules):
+ """Add rules"""
+ snum = len(self.ruleslines.keys())
+ for num in range(snum, snum+nrules):
+ # enable
+ enable = wx.CheckBox(parent=self.cr_panel, id=num)
+ enable.SetValue(True)
+ self.Bind(wx.EVT_CHECKBOX, self.OnRuleEnable, enable)
+ # value
+ txt_ctrl = wx.TextCtrl(parent=self.cr_panel, id=1000+num, value='',
+ size=(100,-1),
style=wx.TE_NOHIDESEL)
- self.Bind(wx.EVT_TEXT, self.OnVals, txt_ctrl)
- color_ctrl = csel.ColourSelect(cr_panel, id=num)
- self.Bind(csel.EVT_COLOURSELECT, self.OnSelectColor, color_ctrl)
- self.ruleslines[num] = ["","0:0:0"]
- cr_sizer.Add(item=txt_ctrl, pos=(num,0),
- flag=wx.ALIGN_CENTER|wx.LEFT, border=10)
- cr_sizer.Add(item=color_ctrl, pos=(num,1),
- flag=wx.ALIGN_CENTER|wx.RIGHT, border=10)
- cr_panel.SetSizer(cr_sizer)
- cr_panel.SetAutoLayout(1)
- cr_panel.SetupScrolling()
+ self.Bind(wx.EVT_TEXT, self.OnRuleValue, txt_ctrl)
+ # color
+ color_ctrl = csel.ColourSelect(self.cr_panel, id=2000+num)
+ self.Bind(csel.EVT_COLOURSELECT, self.OnRuleColor, color_ctrl)
+ self.ruleslines[enable.GetId()] = { 'value' : '',
+ 'color': "0:0:0" }
+ self.cr_sizer.Add(item=enable, pos=(num, 0),
+ self.cr_sizer.Add(item=txt_ctrl, pos=(num, 1),
+ flag=wx.ALIGN_CENTER | wx.RIGHT, border=5)
+ self.cr_sizer.Add(item=color_ctrl, pos=(num, 2),
- return cr_panel
+ self.cr_panel.Layout()
+ self.cr_panel.SetupScrolling()
def InitDisplay(self):
Initialize preview display, set dimensions and region
@@ -260,36 +356,55 @@
self.Destroy()
def OnSelectionInput(self, event):
- self.inmap = event.GetString()
- if self.inmap == '': return
+ if event:
+ self.inmap = event.GetString()
- if self.cmd == 'r.colors':
+ if self.inmap == '':
+ return
+ if self.elem == 'cell':
+ cmdlist = ['r.info',
+ '-r',
+ 'map=%s' % self.inmap]
try:
- cmdlist = ['r.info', 'map=%s' % self.inmap, '-r']
p = gcmd.Command(cmdlist)
- output = p.ReadStdOutput()
- for line in output:
- line = line.strip('\n ')
+ for line in p.ReadStdOutput():
if 'min' in line:
- self.rastmin = line.split('=')[1].strip('\n ')
- if 'max' in line:
- self.rastmax = line.split('=')[1].strip('\n ')
- self.cr_label.SetLabel('Enter raster cat values or percents (range = %s-%s)' %
- (self.rastmin,self.rastmax))
- except:
- pass
- elif self.cmd == 'vcolors':
+ self.rast['min'] = float(line.split('=')[1])
+ elif 'max' in line:
+ self.rast['max'] = float(line.split('=')[1])
+ except gcmd.CmdError:
+ self.inmap = ''
+ self.rast['min'] = self.rast['max'] = None
+ self.cr_label.SetLabel(_('Enter raster cat values or percents'))
+ return
+ self.cr_label.SetLabel(_('Enter raster cat values or percents (range = %d-%d)' %
+ (self.rast['min'], self.rast['max'])))
+ elif self.elem == 'vector':
# initialize layer selection combobox
self.cb_vlayer.InsertLayers(self.inmap)
# initialize attribute table for layer=1
- self.vtable = gselect.VectorDBInfo(self.inmap).layers[int(self.vlayer)]['table']
+ layer = int(self.vect['layer'])
+ self.vect['table'] = gselect.VectorDBInfo(self.inmap).layers[layer]['table']
# initialize column selection comboboxes
- self.cb_vcol.InsertColumns(vector=self.inmap, layer=self.vlayer)
- self.cb_vrgb.InsertColumns(vector=self.inmap, layer=self.vlayer)
+ self.cb_vcol.InsertColumns(vector=self.inmap, layer=layer)
+ self.cb_vrgb.InsertColumns(vector=self.inmap, layer=layer)
self.Update()
+ self.btnPreview.Enable(True)
+ self.btnOK.Enable(True)
+ self.btnApply.Enable(True)
def OnLayerSelection(self, event):
# reset choices in column selection comboboxes if layer changes
self.vlayer = int(event.GetString())
@@ -299,44 +414,85 @@
self.Update()
def OnColumnSelection(self, event):
- self.vcolumn = event.GetString()
+ self.vect['column'] = event.GetString()
def OnRGBColSelection(self, event):
- self.vrgb = event.GetString()
- def OnVals(self, event):
+ self.vect['rgb'] = event.GetString()
+ def OnRuleEnable(self, event):
+ """Rule enabled/disabled"""
+ id = event.GetId()
+ if event.IsChecked():
+ value = self.FindWindowById(id+1000).GetValue()
+ color = self.FindWindowById(id+2000).GetValue()
+ color_str = str(color[0]) + ':' \
+ + str(color[1]) + ':' + \
+ str(color[2])
+ self.ruleslines[id] = {
+ 'value' : value,
+ 'color' : color_str }
+ else:
+ del self.ruleslines[id]
+ def OnRuleValue(self, event):
+ """Rule value changed"""
num = event.GetId()
+ vals = event.GetString().strip()
+ if vals == '':
+ return
tc = self.FindWindowById(num)
- vals = event.GetString().strip()
- if vals == '': return
- self.ruleslines[num][0] = vals
- if self.vcolumn == '' or self.vrgb == '':
+ try:
+ float(vals)
+ except ValueError:
tc.SetValue('')
- wx.MessageBox("Please select attribute column and RGB color column first")
+ self.ruleslines[num-1000]['value'] = ''
+ return
+ self.ruleslines[num-1000]['value'] = vals
+ if self.vect['column'] == '' or self.vect['rgb'] == '':
+ tc.SetValue('')
+ wx.MessageBox(parent=self,
+ message=_("Please select attribute column "
+ "and RGB color column first"),
+ style=wx.CENTRE)
else:
- self.ruleslines[num][0] = self.SQLConvert(vals)
- def OnSelectColor(self, event):
+ try:
+ self.ruleslines[num-1000]['value'] = self.SQLConvert(vals)
+ tc.SetValue('')
+ return
+ def OnRuleColor(self, event):
+ """Rule color changed"""
num = event.GetId()
rgba_color = event.GetValue()
- rgb_string = str(rgba_color[0]) + ':' + str(rgba_color[1]) + ':' + str(rgba_color[2])
- self.ruleslines[num][1] = rgb_string
+ rgb_string = str(rgba_color[0]) + ':' \
+ + str(rgba_color[1]) + ':' + \
+ self.ruleslines[num-2000]['color'] = rgb_string
def SQLConvert(self, vals):
valslist = []
valslist = vals.split('to')
- try:
- if len(valslist) == 1:
- sqlrule = '%s=%s' % (self.vcolumn, float(valslist[0]))
- elif len(valslist) > 1:
- sqlrule = '%s>=%s AND %s<=%s' % (self.vcolumn, float(valslist[0]),
- self.vcolumn, float(valslist[1]))
- else:
- return ""
- except:
- return ""
+ if len(valslist) == 1:
+ sqlrule = '%s=%s' % (self.vect['column'], valslist[0])
+ elif len(valslist) > 1:
+ sqlrule = '%s>=%s AND %s<=%s' % (self.vect['column'], valslist[0],
+ self.vect['column'], valslist[1])
+ else:
+ return None
return sqlrule
@@ -344,70 +500,84 @@
self.CreateColorTable()
def OnOK(self, event):
- self.CreateColorTable()
+ self.OnApply(event)
self.Destroy()
def OnCancel(self, event):
self.Destroy()
def OnPreview(self, event):
- # Add layer to the map for preview
- cmdlist = ['d.rast', 'map=%s' % self.inmap]
- # Find existing color table and copy to temp file
- p = gcmd.Command(['g.findfile', 'element=colr', 'file=%s' % self.inmap])
- if 'file=' in line:
- old_colrtable = line.split('=')[1].strip("'")
+ """Update preview"""
+ # raster
+ cmdlist = ['d.rast',
+ # find existing color table and copy to temp file
try:
+ old_colrtable = grass.find_file(name=self.inmap, element='colr2')['file']
+ except TypeError:
+ old_colrtable = None
+ if old_colrtable:
colrtemp = utils.GetTempfile()
- shutil.copyfile(old_colrtable,colrtemp)
- except:
- return
- cmdlist = ['d.vect', '-a', 'map=%s' % self.inmap, 'rgb_column=%s' % self.vrgb,
+ shutil.copyfile(old_colrtable, colrtemp)
+ # vector
+ cmdlist = ['d.vect',
+ '-a',
+ '--q',
+ 'map=%s' % self.inmap,
+ 'rgb_column=%s' % self.vect['rgb'],
'type=point,line,boundary,area,face']
else:
return
- self.layer = self.Map.AddLayer(type="command", name='raster', command=[cmdlist],
- l_active=True, l_hidden=False, l_opacity=1, l_render=False)
+ if not self.layer:
+ self.layer = self.Map.AddLayer(type="command", name='preview', command=[cmdlist],
+ l_active=True, l_hidden=False, l_opacity=1.0,
+ l_render=False)
+ else:
+ self.layer.SetCmd([cmdlist])
# apply new color table and display preview
+ self.CreateColorTable(force=True)
self.preview.UpdatePreview()
- shutil.copyfile(colrtemp, old_colrtable)
- try:
+ # restore previous color table
+ if old_colrtable:
+ shutil.copyfile(colrtemp, old_colrtable)
os.remove(colrtemp)
- except:
- pass
+ else:
+ gcmd.Command(['r.colors',
+ '-r',
+ 'map=%s' % self.inmap])
def OnHelp(self, event):
+ """Show GRASS manual page"""
gcmd.Command(['g.manual',
'--quiet',
- '%s' % self.cmd[0]])
- def OnOverwrite(self, event):
- self.overwrite = event.IsChecked()
- def CreateColorTable(self):
+ '%s' % self.cmd])
+ def CreateColorTable(self, force=False):
+ """Creates color table"""
rulestxt = ''
- for num in range(len(self.ruleslines)):
- if self.ruleslines[num][0] != "":
- rulestxt += self.ruleslines[num][0] + ' ' + self.ruleslines[num][1] + '\n'
- rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.vtable,
- self.vrgb, self.ruleslines[num][1], self.ruleslines[num][0])
- if rulestxt == '': return
+ for rule in self.ruleslines.itervalues():
+ if not rule['value']: # skip empty rules
+ continue
+ rulestxt += rule['value'] + ' ' + rule['color'] + '\n'
+ rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.vect['table'],
+ self.vect['rgb'],
+ rule['color'],
+ rule['value'])
+ if rulestxt == '':
+ return
gtemp = utils.GetTempfile()
output = open(gtemp, "w")
try:
@@ -415,31 +585,23 @@
finally:
output.close()
- cmdlist = ['r.colors', 'map=%s' % self.inmap, 'rules=%s' % gtemp]
+ cmdlist = ['r.colors',
+ 'rules=%s' % gtemp]
- if self.overwrite == False:
+ if not force and \
+ not self.ovrwrtcheck.IsChecked():
cmdlist.append('-w')
- cmdlist = ['db.execute', 'input=%s' % gtemp]
- try:
- p = gcmd.Command(cmdlist)
- error = p.ReadErrOutput()
- except:
- pass
+ cmdlist = ['db.execute',
+ 'input=%s' % gtemp]
+ p = gcmd.Command(cmdlist)
class BufferedWindow(wx.Window):
- A Buffered window class.
- When the drawing needs to change, you app needs to call the
- UpdateHist() method. Since the drawing is stored in a bitmap, you
- can also save the drawing to file by calling the
- SaveToFile(self,file_name,file_type) method.
+ """A Buffered window class"""
def __init__(self, parent, id,
pos = wx.DefaultPosition,
size = wx.DefaultSize,
@@ -450,58 +612,40 @@
self.Map = Map
- self.mapname = self.parent.mapname
+ # re-render the map from GRASS or just redraw image
+ self.render = True
+ # indicates whether or not a resize event has taken place
+ self.resize = False
- # Flags
+ # event bindings
- self.render = True # re-render the map from GRASS or just redraw image
- self.resize = False # indicates whether or not a resize event has taken place
- self.dragimg = None # initialize variable for map panning
- self.pen = None # pen for drawing zoom boxes, etc.
- # Event bindings
self.Bind(wx.EVT_PAINT, self.OnPaint)
- #self.Bind(wx.EVT_SIZE, self.OnSize)
self.Bind(wx.EVT_IDLE, self.OnIdle)
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x: None)
- # Render output objects
+ # render output objects
- self.mapfile = None # image file to be rendered
- self.img = "" # wx.Image object (self.mapfile)
+ # image file to be rendered
+ self.mapfile = None
+ # wx.Image object (self.mapfile)
+ self.img = None
- self.imagedict = {} # images and their PseudoDC ID's for painting and dragging
self.pdc = wx.PseudoDC()
- self._Buffer = '' # will store an off screen empty bitmap for saving to file
+ # will store an off screen empty bitmap for saving to file
+ self._Buffer = None
# make sure that extents are updated at init
self.Map.region = self.Map.GetRegion()
- self.Map.SetRegion()
+ self.Map.SetRegion()
- self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
- def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0,0,0,0]):
- Draws histogram or clears window
- if drawid == None:
- if pdctype == 'image' :
- drawid = imagedict[img]
- elif pdctype == 'clear':
- drawid == None
- else:
- drawid = wx.NewId()
- else:
- pdc.SetId(drawid)
+ def Draw(self, pdc, img=None, pdctype='image'):
+ """Draws preview or clears window"""
pdc.BeginDrawing()
- Debug.msg (3, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % (drawid, pdctype, coords))
+ Debug.msg (3, "BufferedWindow.Draw(): pdctype=%s" % (pdctype))
if pdctype == 'clear': # erase the display
bg = wx.WHITE_BRUSH
@@ -511,46 +655,40 @@
pdc.EndDrawing()
return
- if pdctype == 'image':
+ if pdctype == 'image' and img:
bg = wx.TRANSPARENT_BRUSH
pdc.SetBackground(bg)
bitmap = wx.BitmapFromImage(img)
- w,h = bitmap.GetSize()
- pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
- pdc.SetIdBounds(drawid, (coords[0],coords[1],w,h))
+ w, h = bitmap.GetSize()
+ pdc.DrawBitmap(bitmap, 0, 0, True) # draw the composite map
pdc.EndDrawing()
self.Refresh()
def OnPaint(self, event):
- Draw psuedo DC to buffer
+ """Draw pseudo DC to buffer"""
self._Buffer = wx.EmptyBitmap(self.Map.width, self.Map.height)
dc = wx.BufferedPaintDC(self, self._Buffer)
# use PrepareDC to set position correctly
self.PrepareDC(dc)
# we need to clear the dc BEFORE calling PrepareDC
bg = wx.Brush(self.GetBackgroundColour())
dc.Clear()
# create a clipping rect from our position and size
# and the Update Region
rgn = self.GetUpdateRegion()
r = rgn.GetBox()
# draw to the dc using the calculated clipping rect
- self.pdc.DrawToDCClipped(dc,r)
- #self.pdc.DrawToDC(dc)
+ self.pdc.DrawToDCClipped(dc, r)
def OnSize(self, event):
- Init image size to match window size
- # set size of the input image
+ """Init image size to match window size"""
+ # set size of the input image
self.Map.width, self.Map.height = self.GetClientSize()
# Make new off screen bitmap: this bitmap will always have the
@@ -571,65 +709,52 @@
self.resize = True
def OnIdle(self, event):
+ """Only re-render a preview image from GRASS during
+ idle time instead of multiple times during resizing.
- Only re-render a histogram image from GRASS during
- idle time instead of multiple times during resizing.
if self.resize:
self.render = True
self.UpdatePreview()
event.Skip()
def GetImage(self):
- Converts files to wx.Image
+ """Converts files to wx.Image"""
if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
os.path.getsize(self.Map.mapfile):
img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
else:
img = None
- self.imagedict[img] = 99 # set image PeudoDC ID
return img
def UpdatePreview(self, img=None):
- Update canvas if window changes geometry
+ """Update canvas if window changes geometry"""
Debug.msg (2, "BufferedWindow.UpdatePreview(%s): render=%s" % (img, self.render))
oldfont = ""
oldencoding = ""
if self.render:
+ # make sure that extents are updated
+ self.Map.region = self.Map.GetRegion()
# render new map images
self.mapfile = self.Map.Render(force=self.render)
self.img = self.GetImage()
self.resize = False
- if not self.img: return
- try:
- id = self.imagedict[self.img]
- except:
+ if not self.img:
return
# paint images to PseudoDC
self.pdc.Clear()
self.pdc.RemoveAll()
- self.Draw(self.pdc, self.img, drawid=id) # draw map image background
+ # draw map image background
+ self.Draw(self.pdc, self.img, pdctype='image')
self.resize = False
- # update statusbar
- # Debug.msg (3, "BufferedWindow.UpdateHist(%s): region=%s" % self.Map.region)
def EraseMap(self):
- Erase the map display
+ """Erase preview"""
self.Draw(self.pdc, pdctype='clear')
Modified: grass/trunk/gui/wxpython/gui_modules/globalvar.py
--- grass/trunk/gui/wxpython/gui_modules/globalvar.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/gui_modules/globalvar.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -86,6 +86,7 @@
DIALOG_COMBOBOX_SIZE = (300, -1)
DIALOG_GSELECT_SIZE = (400, -1)
DIALOG_TEXTCTRL_SIZE = (400, -1)
+DIALOG_LAYER_SIZE = (100, -1)
MAP_WINDOW_SIZE = (680, 520)
HIST_WINDOW_SIZE = (500, 350)
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -405,14 +405,15 @@
self.tables[table][name]['values'] = []
self.tables[table][name]['ids'] = []
-class LayerSelect(wx.ComboBox):
+class LayerSelect(wx.Choice):
Creates combo box for selecting data layers defined for vector.
The 'layer' terminology is likely to change for GRASS 7
id=wx.ID_ANY, pos=wx.DefaultPosition,
- size=wx.DefaultSize, vector=None, choices=[]):
+ size=globalvar.DIALOG_LAYER_SIZE,
+ vector=None, choices=[]):
super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
choices=choices)
@@ -438,7 +439,8 @@
id=wx.ID_ANY, value='', pos=wx.DefaultPosition,
size=wx.DefaultSize, vector=None, layer=1, choices=[]):
- super(ColumnSelect, self).__init__(parent, id, value, pos, size, choices)
+ super(ColumnSelect, self).__init__(parent, id, value, pos, size, choices,
+ style=wx.CB_READONLY)
if not vector:
return
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -3060,23 +3060,24 @@
raise ValueError
value = int(scale[2:])
except ValueError:
- self.mapScale.SetValue('1:' + str(int(self.mapScaleValue)))
+ self.mapScale.SetValue('1:%ld' % int(self.mapScaleValue))
return
dEW = value * (self.Map.region['cols'] / self.ppm[0])
dNS = value * (self.Map.region['rows'] / self.ppm[1])
- self.Map.region['n'] = self.Map.region['center_northing'] + dNS / 2
- self.Map.region['s'] = self.Map.region['center_northing'] - dNS / 2
- self.Map.region['w'] = self.Map.region['center_easting'] - dEW / 2
- self.Map.region['e'] = self.Map.region['center_easting'] + dEW / 2
+ self.Map.region['n'] = self.Map.region['center_northing'] + dNS / 2.
+ self.Map.region['s'] = self.Map.region['center_northing'] - dNS / 2.
+ self.Map.region['w'] = self.Map.region['center_easting'] - dEW / 2.
+ self.Map.region['e'] = self.Map.region['center_easting'] + dEW / 2.
# add to zoom history
self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
self.Map.region['e'], self.Map.region['w'])
# redraw a map
self.MapWindow.UpdateMap()
+ self.mapScale.SetFocus()
def StatusbarUpdate(self):
"""Update statusbar content"""
@@ -3158,12 +3159,16 @@
xscale = (region['e'] - region['w']) / (region['cols'] / self.ppm[0])
yscale = (region['n'] - region['s']) / (region['rows'] / self.ppm[1])
- scale = (xscale + yscale) / 2
+ scale = (xscale + yscale) / 2.
Debug.msg(3, "MapFrame.StatusbarUpdate(mapscale): xscale=%f, yscale=%f -> scale=%f" % \
(xscale, yscale, scale))
self.statusbar.SetStatusText("")
- self.mapScale.SetValue("1:%ld" % scale)
+ try:
+ self.mapScale.SetValue("1:%ld" % (scale + 0.5))
+ except TypeError:
+ pass
self.mapScaleValue = scale
self.mapScale.Show()
@@ -3915,12 +3920,14 @@
self.PopupMenu(zoommenu)
zoommenu.Destroy()
- def SetProperties(self, render=False, mode=0, showCompExtent=False):
+ def SetProperties(self, render=False, mode=0, showCompExtent=False,
+ constrainRes=False):
"""Set properies of map display window"""
self.autoRender.SetValue(render)
self.toggleStatus.SetSelection(mode)
self.StatusbarUpdate()
self.showRegion.SetValue(showCompExtent)
+ self.compResolution.SetValue(constrainRes)
if showCompExtent:
self.MapWindow.regionCoords = []
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -244,7 +244,7 @@
"""Set layer type"""
if type not in ('raster', '3d-raster', 'vector',
'overlay', 'command',
- 'shaded', 'rgb', 'his', 'rastarrow',
+ 'shaded', 'rgb', 'his', 'rastarrow', 'rastnum',
'thememap', 'themechart', 'grid', 'labels',
'geodesic','rhumb'):
raise gcmd.GStdError(_("Unsupported map layer type '%s'") % str(type))
Modified: grass/trunk/gui/wxpython/gui_modules/workspace.py
--- grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/gui_modules/workspace.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -101,7 +101,8 @@
"showCompExtent" : bool(int(attrs.get('showCompExtent', "0"))),
"pos" : pos,
"size" : size,
- "extent" : extent})
+ "extent" : extent,
+ "constrainRes" : bool(int(attrs.get('constrainRes', "0")))})
elif name == 'group':
self.groupName = attrs.get('name', None)
@@ -370,11 +371,13 @@
file.write('%s<display render="%d" '
'mode="%d" showCompExtent="%d" '
+ 'constrainRes="%d" '
'dim="%d,%d,%d,%d" '
'extent="%f,%f,%f,%f">\n' % (' ' * self.indent,
int(mapTree.mapdisplay.autoRender.IsChecked()),
mapTree.mapdisplay.toggleStatus.GetSelection(),
int(mapTree.mapdisplay.showRegion.IsChecked()),
+ int(mapTree.mapdisplay.compResolution.IsChecked()),
displayPos[0],
displayPos[1],
displaySize[0],
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-10-07 13:31:26 UTC (rev 33727)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-10-07 13:38:51 UTC (rev 33728)
@@ -669,8 +669,9 @@
# set windows properties
mapdisplay[-1].SetProperties(render=display['render'],
- mode=display['mode'],
- showCompExtent=display['showCompExtent'])
+ mode=display['mode'],
+ showCompExtent=display['showCompExtent'],
+ constrainRes=display['constrainRes'])
# set position and size of map display
if UserSettings.Get(group='workspace', key='posDisplay', subkey='enabled') is False:
@@ -1240,10 +1241,10 @@
rastmenu.AppendItem(addrastarrow)
self.Bind(wx.EVT_MENU, self.AddRastarrow, addrastarrow)
- # addrastnums = wx.MenuItem(rastmenu, -1, Icons ["addrnum"].GetLabel())
- # addrastnums.SetBitmap(Icons["addrnum"].GetBitmap (self.iconsize))
- # rastmenu.AppendItem(addrastnums)
- # self.Bind(wx.EVT_MENU, self.AddRastnum, addrastnums)
+ addrastnums = wx.MenuItem(rastmenu, -1, Icons ["addrnum"].GetLabel())
+ addrastnums.SetBitmap(Icons["addrnum"].GetBitmap (self.iconsize))
+ rastmenu.AppendItem(addrastnums)
+ self.Bind(wx.EVT_MENU, self.AddRastnum, addrastnums)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
