[GRASS-SVN] r33741 - grass/trunk/scripts/i.spectral
svn_grass at osgeo.org
Tue Oct 7 20:02:06 EDT 2008
Author: glynn
Date: 2008-10-07 20:02:05 -0400 (Tue, 07 Oct 2008)
New Revision: 33741
grass/trunk/scripts/i.spectral/i.spectral.py
Allow use of d.linegraph instead of gnuplot
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py 2008-10-07 22:48:46 UTC (rev 33740)
+++ grass/trunk/scripts/i.spectral/i.spectral.py 2008-10-08 00:02:05 UTC (rev 33741)
@@ -60,6 +60,10 @@
#%key: c
#%description: label with coordinates instead of numbering
#%end
+#%flag
+#%key: g
+#%description: use gnuplot for display
+#%end
import sys
import os
@@ -73,12 +77,101 @@
if name[5:].isdigit():
grass.try_remove(name)
+ grass.try_remove('data_x')
+ for name in glob.glob('data_y_[0-9]*'):
+ if name[7:].isdigit():
+ grass.try_remove(name)
+def draw_gnuplot(what, xlabels, output, label):
+ xrange = 0
+ for i, row in enumerate(what):
+ outfile = 'data_%d' % i
+ outf = file(outfile, 'w')
+ xrange = max(xrange, len(row) - 2)
+ for j, val in enumerate(row[3:]):
+ outf.write("%d %s\n" % (j + 1, val))
+ outf.close()
+ # build gnuplot script
+ lines = []
+ if output:
+ lines += [
+ "set term png large",
+ "set output '%s'" % output
+ lines += [
+ "set xtics (%s)" % xlabels,
+ "set grid",
+ "set title 'Spectral signatures'",
+ "set xrange [0:%d]" % xrange,
+ "set noclabel",
+ "set xlabel 'Bands'",
+ "set ylabel 'DN Value'",
+ "set data style lines"
+ cmd = []
+ if not label:
+ title = str(i + 1)
+ else:
+ title = str(tuple(row[0:2]))
+ cmd.append("'data_%d' title '%s'" % (i, title))
+ cmd = ','.join(cmd)
+ cmd = ' '.join(['plot', cmd, "with linespoints pt 779"])
+ lines.append(cmd)
+ plotfile = 'spectrum.gnuplot'
+ plotf = file(plotfile, 'w')
+ for line in lines:
+ plotf.write(line + '\n')
+ plotf.close()
+ if output:
+ grass.call(['gnuplot', plotfile])
+ else:
+ grass.call(['gnuplot', '-persist', plotfile])
+def draw_linegraph(what):
+ yfiles = []
+ xfile = 'data_x'
+ xf = file(xfile, 'w')
+ for j, val in enumerate(what[0][3:]):
+ xf.write("%d\n" % (j + 1))
+ xf.close()
+ yfile = 'data_y_%d' % i
+ yf = file(yfile, 'w')
+ yf.write("%s\n" % val)
+ yf.close()
+ yfiles.append(yfile)
+ sienna = '#%02x%02x%02x' % (160, 82, 45)
+ coral = '#%02x%02x%02x' % (255, 127, 80)
+ gp_colors = ['red', 'green', 'blue', 'magenta', 'cyan', sienna, 'orange', coral]
+ colors = gp_colors
+ while len(what) > len(colors):
+ colors += gp_colors
+ colors = colors[0:len(what)]
+ grass.run_command('d.linegraph', x_file = xfile, y_file = yfiles,
+ y_color = colors, title = 'Spectral signatures',
+ x_title = 'Bands', y_title = 'DN Value')
def main():
group = options['group']
raster = options['raster']
output = options['output']
coords = options['coords']
label = flags['c']
+ gnuplot = flags['g']
if not group and not raster:
grass.fatal("Either group= or raster= is required")
@@ -87,7 +180,7 @@
grass.fatal("group= and raster= are mutually exclusive")
#check if present
- if not grass.find_program('gnuplot', ['-V']):
+ if gnuplot and not grass.find_program('gnuplot', ['-V']):
grass.fatal("gnuplot required, please install first")
tmp1 = grass.tempfile()
@@ -114,7 +207,7 @@
# ## get data from list of files and set the x-axis labels
rastermaps = raster.split(',')
- xlabels = ["'%s' %d" % (n, i) for i, n in enumerate(rastermaps)]
+ xlabels = ["'%s' %d" % (n, i + 1) for i, n in enumerate(rastermaps)]
xlabels = ','.join(xlabels)
numbands = len(rastermaps)
@@ -129,61 +222,11 @@
f[i] = float(v)
what.append(f)
- numclicks = len(what)
- start = 0
- num = numbands
# build data files
- for i, row in enumerate(what):
- outfile = 'data_%d' % i
- outf = file(outfile, 'w')
- for j, val in enumerate(row[3:]):
- outf.write("%s %s\n" % (j, val))
- outf.close()
- xrange = numbands + 1
- # build gnuplot script
- lines = []
- if output:
- lines += [
- "set term png large",
- "set output '%s'" % output
- lines += [
- "set xtics (%s)" % xlabels,
- "set grid",
- "set title 'Spectral signatures'",
- "set xrange [0:%s]" % xrange,
- "set noclabel",
- "set xlabel 'Bands'",
- "set ylabel 'DN Value'",
- "set data style lines"
- cmd = []
- if not label:
- title = str(i)
- else:
- title = str(tuple(row[0:2]))
- cmd.append("'data_%d' title '%s'" % (i, title))
- cmd = ','.join(cmd)
- cmd = ' '.join(['plot', cmd, "with linespoints pt 779"])
- lines.append(cmd)
- plotfile = 'spectrum.gnuplot'
- plotf = file(plotfile, 'w')
- for line in lines:
- plotf.write(line + '\n')
- plotf.close()
- if output:
- grass.call(['gnuplot', plotfile])
+ if gnuplot:
+ draw_gnuplot(what, xlabels, output, label)
else:
- grass.call(['gnuplot', '-persist', plotfile])
+ draw_linegraph(what)
if __name__ == "__main__":
options, flags = grass.parser()
