[GRASS-SVN] r33752 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Wed Oct 8 04:18:44 EDT 2008
Author: neteler
Date: 2008-10-08 04:18:44 -0400 (Wed, 08 Oct 2008)
New Revision: 33752
grass/branches/develbranch_6/lib/gis/null_val.c
glynn: Make G_is_[fd]_null_value() check for any NaN, not just all-ones (merge from trunk, r33717)
Modified: grass/branches/develbranch_6/lib/gis/null_val.c
--- grass/branches/develbranch_6/lib/gis/null_val.c 2008-10-08 08:18:33 UTC (rev 33751)
+++ grass/branches/develbranch_6/lib/gis/null_val.c 2008-10-08 08:18:44 UTC (rev 33752)
@@ -427,22 +427,7 @@
int G_is_f_null_value(const FCELL * fcellVal)
- int i; /* counter */
- /* Check if the null patterns have been initialized */
- if (!initialized) {
- InitError();
- /* Check if the FCELL value matches the null pattern */
- for (i = 0; i < sizeof(FCELL); i++) {
- if (((unsigned char *)fcellVal)[i] !=
- ((unsigned char *)&fcellNullPattern)[i]) {
- return FALSE;
- return TRUE;
+ return *fcellVal != *fcellVal;
@@ -467,22 +452,7 @@
int G_is_d_null_value(const DCELL * dcellVal)
- InitError();
- /* Check if the DCELL value matches the null pattern */
- for (i = 0; i < sizeof(DCELL); i++) {
- if (((unsigned char *)dcellVal)[i] !=
- ((unsigned char *)&dcellNullPattern)[i]) {
- return FALSE;
- return TRUE;
+ return *dcellVal != *dcellVal;
