[GRASS-SVN] r33754 - grass/trunk/lib/init
Wed Oct 8 04:33:06 EDT 2008
Author: neteler
Date: 2008-10-08 04:33:06 -0400 (Wed, 08 Oct 2008)
New Revision: 33754
   grass/trunk/lib/init/variables.html
explained new GIS_ERROR_LOG variable (not sure about GISBASE/GIS_ERROR_LOG)
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2008-10-08 08:22:22 UTC (rev 33753)
+++ grass/trunk/lib/init/variables.html	2008-10-08 08:33:06 UTC (rev 33754)
@@ -121,7 +121,14 @@
   <dt>GRASS_BATCH_JOB</dt>
   <dd>defines the name (path) of a shell script to be processed as batch job.</dd>
+  <dt>GRASS_ERROR_LOG</dt>
+  <dd>If set, $GIS_ERROR_LOG should be the absolute path to the log file (a
+   relative path will be interpreted relative to the process' cwd, not
+   the cwd at the point the user set the variable). If not set,
+   $HOME/GIS_ERROR_LOG is used instead. The file will only be used if
+   it already exists.</dd>
   <dt>GRASS_ERROR_MAIL</dt>
   <dd>set to any value to send user mail on an error or warning that
     happens while stderr is being redirected.</dd>
@@ -529,7 +536,8 @@
   <dt>$HOME/GIS_ERROR_LOG</dt>
   <dd>if this file exists then all GRASS error and warning messages are
     logged here. Applies to current user. To generate the file, use:
-    <tt>touch $HOME/GIS_ERROR_LOG</tt></dd>
+    <tt>touch $HOME/GIS_ERROR_LOG</tt><br>
+   See also GIS_ERROR_LOG variable.</dd>
   <dt>$GISBASE/GIS_ERROR_LOG</dt>
