[GRASS-SVN] r33767 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Wed Oct 8 21:02:58 EDT 2008
Author: hamish
Date: 2008-10-08 21:02:58 -0400 (Wed, 08 Oct 2008)
New Revision: 33767
grass/branches/develbranch_6/lib/python/README.txt
make it easier to read
Modified: grass/branches/develbranch_6/lib/python/README.txt
--- grass/branches/develbranch_6/lib/python/README.txt 2008-10-09 00:18:41 UTC (rev 33766)
+++ grass/branches/develbranch_6/lib/python/README.txt 2008-10-09 01:02:58 UTC (rev 33767)
@@ -1,3 +1,10 @@
+GRASS scripting tasks for Python provided by "grass.py".
+Usage: "import grass"
def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
Return a list of strings suitable for use as the args parameter to
@@ -6,6 +13,9 @@
>>> grass.make_command("g.message", flags = 'w', message = 'this is a warning')
['g.message', '-w', 'message=this is a warning']
def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
Returns a Popen object with the command created by make_command.
@@ -23,6 +33,9 @@
GRASS_GUI='text';
MONITOR='x0';
def pipe_command(*args, **kwargs):
Passes all arguments to start_command, but also adds
@@ -39,17 +52,26 @@
GRASS_GUI='text';
MONITOR='x0';
def run_command(*args, **kwargs):
Passes all arguments to start_command, then waits for the process to
complete, returning its exit code. Similar to subprocess.call(), but
with the make_command() interface.
def read_command(*args, **kwargs):
complete, returning its stdout (i.e. similar to shell "backticks").
def message(msg, flag = None):
def debug(msg):
def verbose(msg):
@@ -59,10 +81,16 @@
These all run g.message, differing only in which flag (if any) is used.
def fatal(msg):
Like error(), but also calls sys.exit(1).
def parser():
Interface to g.parser, intended to be run from the top-level, e.g.:
@@ -76,10 +104,16 @@
option/flag names. The values in "options" are strings, those in
"flags" are Python booleans.
def tempfile():
Returns the name of a temporary file, created with g.tempfile.
def gisenv():
Returns the output from running g.gisenv (with no arguments), as a
@@ -89,6 +123,9 @@
>>> print env['GISDBASE']
/opt/grass-data
def region():
Returns the output from running "g.region -g", as a dictionary.
@@ -100,16 +137,25 @@
>>> (region['nsres'], region['ewres'])
('30', '30')
def use_temp_region():
Copies the current region to a temporary region with "g.region save=",
then sets WIND_OVERRIDE to refer to that region. Installs an atexit
handler to delete the temporary region upon termination.
def del_temp_region():
Unsets WIND_OVERRIDE and removes any region named by it.
def find_file(name, element = 'cell'):
Returns the output from running g.findfile as a dictionary. Example:
@@ -120,6 +166,9 @@
>>> print result['file']
/opt/grass-data/spearfish57/PERMANENT/vector/fields
def list_grouped(type):
Returns the output from running g.list, as a dictionary where the keys
@@ -129,6 +178,9 @@
>>> grass.list_grouped('rast')['PERMANENT']
['aspect', 'erosion1', 'quads', 'soils', 'strm.dist', ...
def list_pairs(type):
Returns the output from running g.list, as a list of (map, mapset)
@@ -137,6 +189,9 @@
>>> grass.list_pairs('rast')
[('aspect', 'PERMANENT'), ('erosion1', 'PERMANENT'), ('quads', 'PERMANENT'), ...
def list_strings(type):
Returns the output from running g.list, as a list of qualified names.
@@ -145,6 +200,9 @@
>>> grass.list_strings('rast')
['aspect at PERMANENT', 'erosion1 at PERMANENT', 'quads at PERMANENT', 'soils at PERMANENT', ...
def parse_color(val, dflt = None):
Parses the string "val" as a GRASS colour, which can be either one of
