[GRASS-SVN] r33776 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Thu Oct 9 02:16:55 EDT 2008
Author: martinl
Date: 2008-10-09 02:16:55 -0400 (Thu, 09 Oct 2008)
New Revision: 33776
grass/branches/develbranch_6/lib/python/grass.py
glynn: Add documentation strings
(merge from trunk, r33770)
Modified: grass/branches/develbranch_6/lib/python/grass.py
--- grass/branches/develbranch_6/lib/python/grass.py 2008-10-09 04:41:25 UTC (rev 33775)
+++ grass/branches/develbranch_6/lib/python/grass.py 2008-10-09 06:16:55 UTC (rev 33776)
@@ -45,6 +45,12 @@
return str(val)
def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
+ """Return a list of strings suitable for use as the args parameter to
+ Popen() or call(). Example:
+ >>> grass.make_command("g.message", flags = 'w', message = 'this is a warning')
+ ['g.message', '-w', 'message=this is a warning']
args = [prog]
if overwrite:
args.append("--o")
@@ -62,6 +68,10 @@
return args
def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
+ """Returns a Popen object with the command created by make_command.
+ Accepts any of the arguments which Popen() accepts apart from "args"
+ and "shell".
options = {}
popts = {}
for opt, val in kwargs.iteritems():
@@ -73,30 +83,46 @@
return Popen(args, **popts)
def run_command(*args, **kwargs):
+ """Passes all arguments to start_command, then waits for the process to
+ complete, returning its exit code. Similar to subprocess.call(), but
+ with the make_command() interface.
ps = start_command(*args, **kwargs)
return ps.wait()
def pipe_command(*args, **kwargs):
+ """Passes all arguments to start_command, but also adds
+ "stdout = PIPE". Returns the Popen object.
kwargs['stdout'] = PIPE
return start_command(*args, **kwargs)
def feed_command(*args, **kwargs):
+ "stdin = PIPE". Returns the Popen object.
kwargs['stdin'] = PIPE
def read_command(*args, **kwargs):
+ """Passes all arguments to pipe_command, then waits for the process to
+ complete, returning its stdout (i.e. similar to shell `backticks`).
ps = pipe_command(*args, **kwargs)
return ps.communicate()[0]
def write_command(*args, **kwargs):
+ """Passes all arguments to feed_command, with the string specified
+ by the 'stdin' argument fed to the process' stdin.
stdin = kwargs['stdin']
- kwargs['stdin'] = PIPE
- p = start_command(*args, **kwargs)
+ p = feed_command(*args, **kwargs)
p.stdin.write(stdin)
p.stdin.close()
return p.wait()
def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
+ """Interface to os.execvpe(), but with the make_command() interface."""
args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
if env == None:
env = os.environ
@@ -105,24 +131,31 @@
# interface to g.message
def message(msg, flag = None):
+ """Display a message using g.message"""
run_command("g.message", flags = flag, message = msg)
def debug(msg):
+ """Display a debugging message using g.message -d"""
message(msg, flag = 'd')
def verbose(msg):
+ """Display a verbose message using g.message -v"""
message(msg, flag = 'v')
def info(msg):
+ """Display an informational message using g.message -i"""
message(msg, flag = 'i')
def warning(msg):
+ """Display a warning message using g.message -w"""
message(msg, flag = 'w')
def error(msg):
+ """Display an error message using g.message -e"""
message(msg, flag = 'e')
def fatal(msg):
+ """Display an error message using g.message -e, then abort"""
error(msg)
sys.exit(1)
@@ -141,6 +174,17 @@
return (options, flags)
def parser():
+ """Interface to g.parser, intended to be run from the top-level, e.g.:
+ if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
+ Thereafter, the global variables "options" and "flags" will be
+ dictionaries containing option/flag values, keyed by lower-case
+ option/flag names. The values in "options" are strings, those in
+ "flags" are Python booleans.
if not os.getenv("GISBASE"):
print >> sys.stderr, "You must be in GRASS GIS to run this program."
sys.exit(1)
@@ -166,11 +210,15 @@
# interface to g.tempfile
def tempfile():
+ """Returns the name of a temporary file, created with g.tempfile."""
return read_command("g.tempfile", pid = os.getpid()).strip()
# key-value parsers
def parse_key_val(s, sep = '=', dflt = None):
+ """Parse a string into a dictionary, where entries are separated
+ by newlines and the key and value are separated by `sep' (default: `=')
result = {}
for line in s.splitlines():
kv = line.split(sep, 1)
@@ -185,6 +233,11 @@
_kv_regex = None
def parse_key_val2(s):
+ by newlines and the key and value are separated by `=', and the
+ value is enclosed in single quotes.
+ Suitable for parsing the output from g.findfile and g.gisenv.
global _kv_regex
if _kv_regex == None:
_kv_regex = re.compile("([^=]+)='(.*)';?")
@@ -200,21 +253,30 @@
# interface to g.gisenv
def gisenv():
+ """Returns the output from running g.gisenv (with no arguments), as a
+ dictionary.
return parse_key_val2(read_command("g.gisenv"))
# interface to g.region
def region():
+ """Returns the output from running "g.region -g", as a dictionary."""
s = read_command("g.region", flags='g')
return parse_key_val(s)
def use_temp_region():
+ """Copies the current region to a temporary region with "g.region save=",
+ then sets WIND_OVERRIDE to refer to that region. Installs an atexit
+ handler to delete the temporary region upon termination.
name = "tmp.%s.%d" % (os.path.basename(sys.argv[0]), os.getpid())
run_command("g.region", save = name)
os.environ['WIND_OVERRIDE'] = name
atexit.register(del_temp_region)
def del_temp_region():
+ """Unsets WIND_OVERRIDE and removes any region named by it."""
try:
name = os.environ.pop('WIND_OVERRIDE')
run_command("g.remove", quiet = True, region = name)
@@ -224,12 +286,16 @@
# interface to g.findfile
def find_file(name, element = 'cell', mapset = None):
+ """Returns the output from running g.findfile as a dictionary."""
s = read_command("g.findfile", element = element, file = name, mapset = mapset)
return parse_key_val2(s)
# interface to g.list
def list_grouped(type):
+ """Returns the output from running g.list, as a dictionary where the keys
+ are mapset names and the values are lists of maps in that mapset.
dashes_re = re.compile("^----+$")
mapset_re = re.compile("<(.*)>:$")
result = {}
@@ -255,10 +321,14 @@
return result
def list_pairs(type):
+ """Returns the output from running g.list, as a list of (map, mapset)
+ pairs.
return _concat([[(map, mapset) for map in maps]
for mapset, maps in list_grouped(type).iteritems()])
def list_strings(type):
+ """Returns the output from running g.list, as a list of qualified names."""
return ["%s@%s" % pair for pair in list_pairs(type)]
# color parsing
@@ -282,6 +352,11 @@
"indigo": (0.00, 0.50, 1.00)}
def parse_color(val, dflt = None):
+ """Parses the string "val" as a GRASS colour, which can be either one of
+ the named colours or an R:G:B tuple e.g. 255:255:255. Returns an
+ (r,g,b) triple whose components are floating point values between 0
+ and 1.
if val in named_colors:
return named_colors[val]
@@ -294,12 +369,14 @@
# check GRASS_OVERWRITE
def overwrite():
+ """Return True if existing files may be overwritten"""
owstr = 'GRASS_OVERWRITE'
return owstr in os.environ and os.environ[owstr] != '0'
# check GRASS_VERBOSE
def verbosity():
+ """Return the verbosity level selected by GRASS_VERBOSE"""
vbstr = 'GRASS_VERBOSE'
if vbstr:
return int(vbstr)
@@ -311,6 +388,9 @@
# basename inc. extension stripping
def basename(path, ext = None):
+ """Remove leading directory components and an optional extension
+ from the specified path
name = os.path.basename(path)
if not ext:
return name
@@ -322,6 +402,9 @@
# find a program (replacement for "which")
def find_program(pgm, args = []):
+ """Attempt to run a program, with optional arguments. Return False
+ if the attempt failed due to a missing executable, True otherwise
nuldev = file(os.devnull, 'w+')
try:
call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
@@ -334,6 +417,9 @@
# try to remove a file, without complaints
def try_remove(path):
+ """Attempt to remove a file; no exception is generated if the
+ attempt fails.
try:
os.remove(path)
except:
@@ -342,6 +428,9 @@
# try to remove a directory, without complaints
def try_rmdir(path):
+ """Attempt to remove a directory; no exception is generated if the
+ attempt fails.
try:
os.rmdir(path)
except:
@@ -350,6 +439,9 @@
# run "v.db.connect -g ..." and parse output
def vector_db(map, layer = None, **args):
+ """Return the database connection details for a vector map
+ (interface to `v.db.connect -g').
s = read_command('v.db.connect', flags = 'g', map = map, layer = layer, **args)
result = []
for l in s.splitlines():
@@ -365,6 +457,9 @@
# run "db.describe -c ..." and parse output
def db_describe(table, **args):
+ """Return the list of columns for a database table
+ (interface to `db.describe -c').
s = read_command('db.describe', flags = 'c', table = table, **args)
if not s:
return None
@@ -387,12 +482,18 @@
# run "db.connect -p" and parse output
def db_connection():
+ """Return the current database connection parameters
+ (interface to `db.connect -p').
s = read_command('db.connect', flags = 'p')
return parse_key_val(s, sep = ':')
# run "v.info -c ..." and parse output
def vector_columns(map, layer = None, **args):
+ """Return the list of columns for the database table connected to
+ a vector map (interface to `v.info -c').
s = read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True, **args)
result = []
@@ -404,10 +505,16 @@
# add vector history
def vector_history(map):
+ """Set the command history for a vector map to the command used to
+ invoke the script (interface to `v.support').
run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
# add raster history
def raster_history(map):
+ """Set the command history for a raster map to the command used to
+ invoke the script (interface to `r.support').
run_command('r.support', map = map, history = os.environ['CMDLINE'])
