[GRASS-SVN] r33782 - in grass/branches/develbranch_6/display:
d.rast d.vect
svn_grass at osgeo.org
Thu Oct 9 04:41:41 EDT 2008
Author: martinl
Date: 2008-10-09 04:41:41 -0400 (Thu, 09 Oct 2008)
New Revision: 33782
grass/branches/develbranch_6/display/d.rast/main.c
grass/branches/develbranch_6/display/d.vect/plot1.c
d.rast: more guisections ('Query')
Modified: grass/branches/develbranch_6/display/d.rast/main.c
--- grass/branches/develbranch_6/display/d.rast/main.c 2008-10-09 08:35:21 UTC (rev 33781)
+++ grass/branches/develbranch_6/display/d.rast/main.c 2008-10-09 08:41:41 UTC (rev 33782)
@@ -64,6 +64,7 @@
catlist->required = NO;
catlist->multiple = YES;
catlist->description = _("List of categories to be displayed (INT maps)");
+ catlist->guisection = _("Query");
vallist = G_define_option();
vallist->key = "vallist";
@@ -72,6 +73,7 @@
vallist->required = NO;
vallist->multiple = YES;
vallist->description = _("List of values to be displayed (FP maps)");
+ vallist->guisection = _("Query");
bg = G_define_option();
bg->key = "bg";
@@ -87,6 +89,7 @@
flag_i = G_define_flag();
flag_i->key = 'i';
flag_i->description = _("Invert catlist");
+ flag_i->guisection = _("Query");
flag_x = G_define_flag();
flag_x->key = 'x';
Modified: grass/branches/develbranch_6/display/d.vect/plot1.c
--- grass/branches/develbranch_6/display/d.vect/plot1.c 2008-10-09 08:35:21 UTC (rev 33781)
+++ grass/branches/develbranch_6/display/d.vect/plot1.c 2008-10-09 08:41:41 UTC (rev 33782)
@@ -145,7 +145,8 @@
dbCatValArray cvarr_rgb, cvarr_width;
dbCatVal *cv_rgb = NULL, *cv_width = NULL;
int nrec_rgb = 0, nrec_width = 0;
+ int nerror_rgb;
int open_db;
int custom_rgb = FALSE;
char colorstring[12]; /* RRR:GGG:BBB */
@@ -154,6 +155,8 @@
unsigned char which;
int width;
+ nerror_rgb = 0;
line_color = G_malloc(sizeof(RGBA_Color));
fill_color = G_malloc(sizeof(RGBA_Color));
primary_color = G_malloc(sizeof(RGBA_Color));
@@ -204,7 +207,7 @@
/* for reading RRR:GGG:BBB color strings from table */
if (rgb_column == NULL || *rgb_column == '\0')
- G_fatal_error(_("Color definition column not specified."));
+ G_fatal_error(_("Color definition column not specified"));
db_CatValArray_init(&cvarr_rgb);
@@ -279,7 +282,7 @@
if (Vect_level(Map) >= 2) {
line++;
if (line > nlines)
- return 0;
+ break;
if (!Vect_line_alive(Map, line))
continue;
ltype = Vect_read_line(Map, Points, Cats, line);
@@ -291,7 +294,7 @@
G_warning(_("Unable to read vector map"));
return -1;
case -2: /* EOF */
- return 0;
+ break;
@@ -381,15 +384,18 @@
else {
custom_rgb = FALSE;
- G_warning(_("Error in color definition column (%s), element %d "
- "with cat %d: colorstring [%s]"),
- rgb_column, line, cat, colorstring);
+ G_important_message(_("Error in color definition column '%s', feature id %d "
+ "with cat %d: colorstring '%s'"),
+ rgb_column, line, cat, colorstring);
+ nerror_rgb++;
else {
custom_rgb = FALSE;
- G_warning(_("Error in color definition column (%s), element %d with cat %d"),
- rgb_column, line, cat);
+ "with cat %d"),
+ rgb_column, line, cat);
+ nerror_rgb++;
} /* end if cat */
@@ -520,6 +526,11 @@
+ if (nerror_rgb > 0) {
+ G_warning(_("Error in color definition column '%s': %d features affected"),
+ rgb_column, nerror_rgb);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
