[GRASS-SVN] r33784 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Thu Oct 9 04:58:48 EDT 2008
Author: martinl
Date: 2008-10-09 04:58:48 -0400 (Thu, 09 Oct 2008)
New Revision: 33784
grass/trunk/display/d.vect/plot1.c
d.vect: print only one warning for invalid rgb (print message for every affected feature)
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c 2008-10-09 08:55:59 UTC (rev 33783)
+++ grass/trunk/display/d.vect/plot1.c 2008-10-09 08:58:48 UTC (rev 33784)
@@ -56,7 +56,8 @@
dbCatValArray cvarr_rgb, cvarr_width;
dbCatVal *cv_rgb = NULL, *cv_width = NULL;
int nrec_rgb = 0, nrec_width = 0;
+ int nerror_rgb;
int open_db;
int custom_rgb = FALSE;
char colorstring[12]; /* RRR:GGG:BBB */
@@ -65,6 +66,8 @@
unsigned char which;
int width;
+ nerror_rgb = 0;
line_color = G_malloc(sizeof(RGBA_Color));
fill_color = G_malloc(sizeof(RGBA_Color));
primary_color = G_malloc(sizeof(RGBA_Color));
@@ -113,7 +116,7 @@
/* for reading RRR:GGG:BBB color strings from table */
if (rgb_column == NULL || *rgb_column == '\0')
- G_fatal_error(_("Color definition column not specified."));
+ G_fatal_error(_("Color definition column not specified"));
db_CatValArray_init(&cvarr_rgb);
@@ -188,7 +191,7 @@
if (Vect_level(Map) >= 2) {
line++;
if (line > nlines)
- return 0;
+ break;
if (!Vect_line_alive(Map, line))
continue;
ltype = Vect_read_line(Map, Points, Cats, line);
@@ -200,7 +203,7 @@
G_warning(_("Unable to read vector map"));
return -1;
case -2: /* EOF */
- return 0;
+ break;
@@ -290,15 +293,18 @@
else {
custom_rgb = FALSE;
- G_warning(_("Error in color definition column (%s), element %d "
- "with cat %d: colorstring [%s]"),
- rgb_column, line, cat, colorstring);
+ G_important_message(_("Error in color definition column '%s', feature id %d "
+ "with cat %d: colorstring '%s'"),
+ rgb_column, line, cat, colorstring);
+ nerror_rgb++;
else {
custom_rgb = FALSE;
- G_warning(_("Error in color definition column (%s), element %d with cat %d"),
- rgb_column, line, cat);
+ "with cat %d"),
+ rgb_column, line, cat);
+ nerror_rgb++;
} /* end if cat */
@@ -429,6 +435,11 @@
+ if (nerror_rgb > 0) {
+ G_warning(_("Error in color definition column '%s': %d features affected"),
+ rgb_column, nerror_rgb);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
