[GRASS-SVN] r33789 - in grass/branches/develbranch_6: lib/python
vector/v.db.connect
svn_grass at osgeo.org
Thu Oct 9 07:56:47 EDT 2008
Author: neteler
Date: 2008-10-09 07:56:47 -0400 (Thu, 09 Oct 2008)
New Revision: 33789
grass/branches/develbranch_6/lib/python/grass.py
grass/branches/develbranch_6/vector/v.db.connect/main.c
Add fs= option to v.db.connect (for use by -g);
Change vector_db to use fs=| (to allow for spaces in pathnames) (merge from trunk, r33787)
Modified: grass/branches/develbranch_6/lib/python/grass.py
--- grass/branches/develbranch_6/lib/python/grass.py 2008-10-09 11:23:35 UTC (rev 33788)
+++ grass/branches/develbranch_6/lib/python/grass.py 2008-10-09 11:56:47 UTC (rev 33789)
@@ -442,10 +442,10 @@
"""Return the database connection details for a vector map
(interface to `v.db.connect -g').
- s = read_command('v.db.connect', flags = 'g', map = map, layer = layer, **args)
+ s = read_command('v.db.connect', flags = 'g', map = map, layer = layer, fs = '|', **args)
result = []
for l in s.splitlines():
- f = l.split(' ')
+ f = l.split('|')
if len(f) != 5:
continue
if layer and int(layer) == int(f[0]):
Modified: grass/branches/develbranch_6/vector/v.db.connect/main.c
--- grass/branches/develbranch_6/vector/v.db.connect/main.c 2008-10-09 11:23:35 UTC (rev 33788)
+++ grass/branches/develbranch_6/vector/v.db.connect/main.c 2008-10-09 11:56:47 UTC (rev 33789)
@@ -33,7 +33,7 @@
char *input, *mapset;
struct GModule *module;
struct Option *inopt, *dbdriver, *dbdatabase, *dbtable, *field_opt,
- *dbkey;
+ *dbkey, *sep_opt;
struct Flag *overwrite, *print, *columns, *delete, *shell_print;
dbDriver *driver;
dbString table_name;
@@ -72,6 +72,9 @@
field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ sep_opt = G_define_standard_option(G_OPT_F_SEP);
+ sep_opt->answer = " ";
print = G_define_flag();
print->key = 'p';
print->description = _("Print all map connection parameters and exit");
@@ -153,15 +156,18 @@
G_fatal_error(_("Database connection not defined"));
if (shell_print->answer) {
+ const char *sep = sep_opt->answer;
if (fi->name) {
- fprintf(stdout, "%d/%s %s %s %s %s\n", fi->number,
- fi->name, fi->table, fi->key,
- fi->database, fi->driver);
+ fprintf(stdout, "%d/%s%s%s%s%s%s%s%s%s\n",
+ fi->number, fi->name, sep,
+ fi->table, sep, fi->key, sep,
+ fi->database, sep, fi->driver);
else {
- fprintf(stdout, "%d %s %s %s %s\n", fi->number,
- fi->table, fi->key, fi->database,
- fi->driver);
+ fprintf(stdout, "%d%s%s%s%s%s%s%s%s\n",
+ fi->number, sep,
else {
