[GRASS-SVN] r33833 - grass/trunk/general/manage/cmd
svn_grass at osgeo.org
Sun Oct 12 02:54:35 EDT 2008
Author: neteler
Date: 2008-10-12 02:54:34 -0400 (Sun, 12 Oct 2008)
New Revision: 33833
grass/trunk/general/manage/cmd/g.rename.html
mention case trick; more reasonable example
Modified: grass/trunk/general/manage/cmd/g.rename.html
--- grass/trunk/general/manage/cmd/g.rename.html 2008-10-12 05:42:28 UTC (rev 33832)
+++ grass/trunk/general/manage/cmd/g.rename.html 2008-10-12 06:54:34 UTC (rev 33833)
@@ -52,11 +52,23 @@
will allow the user to overwrite other existing files in
the current mapset by making the <em>new</em> file name
that of an already existing file.
+<p>
+For portability reasons, <em>g.rename</em> is ignoring case of
+names. To change the case of a map name, first rename the map
+to a name which differs by more than case, then rename it to
+the intended name.
<h2>EXAMPLE</h2>
<div class="code"><pre>
-g.rename rast=oldrast,newrast vect=oldvect51,newvect51 oldvect=oldvect50,newvect50
+# rename raster map
+g.rename rast=oldrast,newrast
+# rename vector map
+g.rename vect=oldvect,newvect
+# combined renaming
+g.rename rast=oldrast,newrast vect=oldvect,newvect
</pre></div>
<h2>SEE ALSO</h2>
