[GRASS-SVN] r33835 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Sun Oct 12 03:12:31 EDT 2008
Author: neteler
Date: 2008-10-12 03:12:30 -0400 (Sun, 12 Oct 2008)
New Revision: 33835
Added:
grass/branches/develbranch_6/locale/po/grasswxpy_el.po
grass/branches/develbranch_6/locale/po/grasslibs_el.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grasstcl_el.po
updated
Modified: grass/branches/develbranch_6/locale/po/grasslibs_el.po
--- grass/branches/develbranch_6/locale/po/grasslibs_el.po 2008-10-12 06:55:55 UTC (rev 33834)
+++ grass/branches/develbranch_6/locale/po/grasslibs_el.po 2008-10-12 07:12:30 UTC (rev 33835)
@@ -1,5 +1,4 @@
-# translation of grasslibs_el.po to Báóßëåéïò Áíôùíßïõ
-# Greek translation of grasslibs.pot
+# translation of grasslibs_el.po to Greek - Báóßëåéïò Áíôùíßïõ
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2007 GRASS Development Team
@@ -9,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_el\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-09-29 17:23+0200\n"
+"POT-Creation-Date: 2008-10-11 14:54+0200\n"
"PO-Revision-Date: 2008-10-01 14:42+0300\n"
"Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
"Language-Team: Báóßëåéïò Áíôùíßïõ <grass-translations at lists.osgeo.org>\n"
@@ -18,38 +17,6 @@
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
-#: ../lib/gpde/test/test_arrays.c:48
-msgid ""
-"\n"
-"++ Running array unit tests ++"
-msgstr ""
-"\n"
-"++ ÅêôÝëåóç ôåóô ìïíÜäáò ðßíáêá++"
-#: ../lib/gpde/test/test_arrays.c:50
-msgid "\t 1. testing 2d arrays"
-msgstr "\t 1. äïêßìç ðßíáêá 2 äéáóôÜóåùí"
-#: ../lib/gpde/test/test_arrays.c:53
-msgid "\t 2. testing 3d arrays"
-msgstr "\t 1. äïêßìç ðßíáêá 3 äéáóôÜóåùí"
-#: ../lib/gpde/test/test_arrays.c:57
-msgid ""
-"\n"
-"-- Array unit tests failure --"
-msgstr ""
-"\n"
-"-- Áðïôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
-#: ../lib/gpde/test/test_arrays.c:59
-msgid ""
-"\n"
-"-- Array unit tests finished successfully --"
-msgstr ""
-"\n"
-"-- Åðéôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
#: ../lib/gpde/test/test_tools.c:34
msgid ""
"\n"
@@ -74,37 +41,37 @@
"\n"
"++ Åðéôõ÷Þò åêôÝëåóç ôåóô ìáèçìáôéêÞò ìïíÜäáò ++"
-#: ../lib/gpde/test/test_gwflow.c:43
+#: ../lib/gpde/test/test_arrays.c:48
msgid ""
"\n"
-"++ Running gwflow integration tests ++"
+"++ Running array unit tests ++"
msgstr ""
"\n"
-"++ Åêôåëïýíôáé äïêéìÝò åíóùìÜôùóçò gwflow ++"
+"++ ÅêôÝëåóç ôåóô ìïíÜäáò ðßíáêá++"
-#: ../lib/gpde/test/test_gwflow.c:45
-msgid "\t 1. testing 2d gwflow"
-msgstr "\t 1. äïêéìÞ 2 äéáóôÜóåùí gwflow"
+#: ../lib/gpde/test/test_arrays.c:50
+msgid "\t 1. testing 2d arrays"
+msgstr "\t 1. äïêßìç ðßíáêá 2 äéáóôÜóåùí"
-#: ../lib/gpde/test/test_gwflow.c:48
-msgid "\t 2. testing 3d gwflow"
-msgstr "\t 1. äïêéìÞ 3 äéáóôÜóåùí gwflow"
+#: ../lib/gpde/test/test_arrays.c:53
+msgid "\t 2. testing 3d arrays"
+msgstr "\t 1. äïêßìç ðßíáêá 3 äéáóôÜóåùí"
-#: ../lib/gpde/test/test_gwflow.c:52
+#: ../lib/gpde/test/test_arrays.c:57
msgid ""
"\n"
-"-- gwflow integration tests failure --"
+"-- Array unit tests failure --"
msgstr ""
"\n"
-"-- áðïôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
+"-- Áðïôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
-#: ../lib/gpde/test/test_gwflow.c:54
+#: ../lib/gpde/test/test_arrays.c:59
msgid ""
"\n"
-"-- gwflow integration tests finished successfully --"
+"-- Array unit tests finished successfully --"
msgstr ""
"\n"
-"-- Åðéôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
+"-- Åðéôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
#: ../lib/gpde/test/test_heat.c:33
msgid ""
@@ -198,6 +165,38 @@
msgid "Performs unit and integration tests for gpde library"
msgstr "Åêôåëåß äïêéìÝò ìïíÜäáò êáé åíóùìÜôùóçò ãéá ôçí âéâëéïèÞêç gpde"
+#: ../lib/gpde/test/test_gwflow.c:43
+msgid ""
+"\n"
+"++ Running gwflow integration tests ++"
+msgstr ""
+"\n"
+"++ Åêôåëïýíôáé äïêéìÝò åíóùìÜôùóçò gwflow ++"
+#: ../lib/gpde/test/test_gwflow.c:45
+msgid "\t 1. testing 2d gwflow"
+msgstr "\t 1. äïêéìÞ 2 äéáóôÜóåùí gwflow"
+#: ../lib/gpde/test/test_gwflow.c:48
+msgid "\t 2. testing 3d gwflow"
+msgstr "\t 1. äïêéìÞ 3 äéáóôÜóåùí gwflow"
+#: ../lib/gpde/test/test_gwflow.c:52
+msgid ""
+"\n"
+"-- gwflow integration tests failure --"
+msgstr ""
+"\n"
+"-- áðïôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
+#: ../lib/gpde/test/test_gwflow.c:54
+msgid ""
+"\n"
+"-- gwflow integration tests finished successfully --"
+msgstr ""
+"\n"
+"-- Åðéôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
#: ../lib/gpde/test/test_geom.c:36
msgid ""
"\n"
@@ -401,7 +400,7 @@
msgstr "Ï ÷ñüíïò õðïëïãßæåôáé óå äåõôåñüëåðôá"
#: ../lib/gpde/N_arrays_io.c:55 ../lib/gis/legal_name.c:94
-#: ../lib/gis/legal_name.c:97 ../lib/gis/opencell.c:1010
+#: ../lib/gis/legal_name.c:97 ../lib/gis/opencell.c:1011
#: ../lib/ogsf/gsd_legend.c:238 ../lib/ogsf/Gs3.c:126 ../lib/ogsf/Gs3.c:200
#: ../lib/ogsf/Gs3.c:284 ../lib/ogsf/Gs3.c:357 ../lib/ogsf/Gs3.c:472
#: ../lib/ogsf/Gs3.c:568 ../lib/ogsf/Gs3.c:635 ../lib/ogsf/Gs3.c:692
@@ -445,8 +444,8 @@
#: ../lib/gpde/N_arrays_io.c:227 ../lib/gpde/N_arrays_io.c:232
#: ../lib/gpde/N_arrays_io.c:237
-#, c-format
-msgid "Unable to write rast row %i"
+#, fuzzy, c-format
+msgid "Unable to write raster row %i"
msgstr "Áäõíáìßá åããñáöÞò ãñáììÞ raster %i"
#: ../lib/gpde/N_arrays_io.c:295
@@ -577,9 +576,9 @@
msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
-msgid "Table <%s> already existsin database <%s>"
-msgstr ""
+#, fuzzy, c-format
+msgid "Table <%s> already exists in database <%s>"
+msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
#: ../lib/db/dbmi_client/table.c:110
@@ -912,19 +911,6 @@
msgid "Unable to delete layer/category %d/%d line %d"
msgstr "Áäõíáìßá äéáãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s>"
-#: ../lib/vector/Vlib/intersect.c:127
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
-"Ç 3äéÜóôáôç áðåéêüíéóç äåí õðïóôçñßæåôáé áðü ôï Vect_segment_intersection()"
-#: ../lib/vector/Vlib/intersect.c:322
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:448
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
#: ../lib/vector/Vlib/build.c:31 ../lib/vector/Vlib/open.c:40
#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:30
#: ../lib/vector/Vlib/rewind.c:35 ../lib/vector/Vlib/write.c:53
@@ -932,117 +918,124 @@
msgid "Requested format is not compiled in this version"
msgstr "Ôï óõãêåêñéìÝíï format äåí ãßíåé compiled ãéá ôçí Ýêäïóç áõôÞ"
-#: ../lib/vector/Vlib/build.c:144
+#: ../lib/vector/Vlib/build.c:147
#, c-format
msgid "Building topology for vector map <%s>...\n"
msgstr "Äçìéïõñãßá ôïðïëïãßáò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>...\n"
-#: ../lib/vector/Vlib/build.c:160
+#: ../lib/vector/Vlib/build.c:163
msgid "Topology was built\n"
msgstr "Ç ôïðïëïãßá äçìéïõñãÞèçêå\n"
-#: ../lib/vector/Vlib/build.c:172
+#: ../lib/vector/Vlib/build.c:175
#, c-format
msgid "Number of nodes : %d\n"
msgstr "Áñéèìüò êüìâùí : %d\n"
-#: ../lib/vector/Vlib/build.c:173
+#: ../lib/vector/Vlib/build.c:176
#, c-format
msgid "Number of primitives: %d\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:174
+#: ../lib/vector/Vlib/build.c:177
#, c-format
msgid "Number of points : %d\n"
msgstr "Áñéèìüò óçìåßùí : %d\n"
-#: ../lib/vector/Vlib/build.c:175
+#: ../lib/vector/Vlib/build.c:178
#, c-format
msgid "Number of lines : %d\n"
msgstr "Áñéèìüò ãñáììþí : %d\n"
-#: ../lib/vector/Vlib/build.c:176
+#: ../lib/vector/Vlib/build.c:179
#, c-format
msgid "Number of boundaries: %d\n"
msgstr "Áñéèìüò óõíïñéáêþí ãñáììþí: %d\n"
-#: ../lib/vector/Vlib/build.c:177
+#: ../lib/vector/Vlib/build.c:180
#, c-format
msgid "Number of centroids : %d\n"
msgstr "Áñéèìüò êÝíôñùí ðïëõãþíïõ : %d\n"
-#: ../lib/vector/Vlib/build.c:180
+#: ../lib/vector/Vlib/build.c:183
#, c-format
msgid "Number of faces : %d\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:183
+#: ../lib/vector/Vlib/build.c:186
#, c-format
msgid "Number of kernels : %d\n"
msgstr "Áñéèìüò ðõñÞíùí : %d\n"
-#: ../lib/vector/Vlib/build.c:223
+#: ../lib/vector/Vlib/build.c:226
#, c-format
msgid "Number of areas : %d\n"
msgstr "Áñéèìüò ðåñéï÷þí : %d\n"
-#: ../lib/vector/Vlib/build.c:224
+#: ../lib/vector/Vlib/build.c:227
#, c-format
msgid "Number of isles : %d\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:227
+#: ../lib/vector/Vlib/build.c:230
#, c-format
msgid "Number of incorrect boundaries : %d\n"
msgstr "Áñéèìüò ëáíèáóìÝíùí óõíïñéáêþí ãñáììþí (boundaries) : %d\n"
-#: ../lib/vector/Vlib/build.c:231
+#: ../lib/vector/Vlib/build.c:234
#, c-format
msgid "Number of centroids outside area : %d\n"
msgstr "Áñéèìüò êÝíôñùí ðïëõãþíùí Ýîù áðü ôçí ðåñéï÷Þ : %d\n"
-#: ../lib/vector/Vlib/build.c:235
+#: ../lib/vector/Vlib/build.c:238
#, c-format
msgid "Number of duplicate centroids : %d\n"
msgstr "Áñéèìüò äéðëþí êÝíôñùí ðïëõãþíùí : %d\n"
-#: ../lib/vector/Vlib/build.c:239
+#: ../lib/vector/Vlib/build.c:242
#, c-format
msgid "Number of areas without centroid : %d\n"
msgstr "Áñéèìüò ðåñéï÷þí ÷ùñßò êÝíôñá : %d\n"
-#: ../lib/vector/Vlib/build.c:244
+#: ../lib/vector/Vlib/build.c:247
msgid "Number of areas : -\n"
msgstr "Áñéèìüò ðåñéï÷þí : -\n"
-#: ../lib/vector/Vlib/build.c:245
+#: ../lib/vector/Vlib/build.c:248
msgid "Number of isles : -\n"
msgstr ""
-#: ../lib/vector/Vlib/build.c:274
+#: ../lib/vector/Vlib/build.c:277
#, c-format
msgid "Unable to open topo file for write <%s>"
msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ ãéá åããñáöÞ <%s>"
-#: ../lib/vector/Vlib/build.c:282
+#: ../lib/vector/Vlib/build.c:285
msgid "Error writing out topo file"
msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ ÷Üñôç"
-#: ../lib/vector/Vlib/build.c:425
+#: ../lib/vector/Vlib/build.c:428
#, c-format
msgid "Unable open spatial index file for write <%s>"
msgstr "Áäõíáìßá áíïßãìáôïò ðßíáêá ÷ùñéêþí äåäïìÝíùí ãéá åããñáöÞ <%s>"
-#: ../lib/vector/Vlib/build.c:433
+#: ../lib/vector/Vlib/build.c:436
msgid "Error writing out spatial index file"
msgstr "ÓöÜëìá åããñáöÞò ÷ùñéêþí äåäïìÝíùí óôï áñ÷åßï"
-#: ../lib/vector/Vlib/dangles.c:173 ../lib/vector/Vlib/dangles.c:272
-#: ../lib/vector/Vlib/dangles.c:284
-#, fuzzy
-msgid "Removed dangles:"
-msgstr "Ðåñéï÷Ýò ðïõ áöáéñÝèçêáí"
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
+msgstr ""
+"Ç 3äéÜóôáôç áðåéêüíéóç äåí õðïóôçñßæåôáé áðü ôï Vect_segment_intersection()"
+#: ../lib/vector/Vlib/intersect.c:322
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:448
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+msgstr ""
#: ../lib/vector/Vlib/open.c:100
#, c-format
msgid "Programmer requested unknown open level %d"
@@ -1176,42 +1169,6 @@
msgid "Unable to close vector <%s>"
msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ äéáíýóìáôïò <%s>"
-#: ../lib/vector/Vlib/cindex.c:31
-msgid "Category index is not up to date"
-msgstr "Ï êáôÜëïãïò ôùí êáôçãïñéþí äåí åßíáé åíçìåñùìÝíïò"
-#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:125
-#: ../lib/vector/Vlib/cindex.c:143 ../lib/vector/Vlib/cindex.c:166
-msgid "Invalid layer index (index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:107
-msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:232
-msgid "Layer or category index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:283
-msgid "Layer index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:460
-#, c-format
-msgid "Unable to open cidx file <%s> for write"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:468
-#, c-format
-msgid "Error writing out category index file <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:511
-#, c-format
-msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr ""
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
@@ -1252,6 +1209,46 @@
"Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
"äåäïìÝíùí."
+#: ../lib/vector/Vlib/cindex.c:31
+msgid "Category index is not up to date"
+msgstr "Ï êáôÜëïãïò ôùí êáôçãïñéþí äåí åßíáé åíçìåñùìÝíïò"
+#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:125
+#: ../lib/vector/Vlib/cindex.c:143 ../lib/vector/Vlib/cindex.c:166
+msgid "Invalid layer index (index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:107
+msgid "Invalid layer index (index < 0 or index >= number of layers)"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:232
+msgid "Layer or category index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:283
+msgid "Layer index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:460
+#, c-format
+msgid "Unable to open cidx file <%s> for write"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:468
+#, c-format
+msgid "Error writing out category index file <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:511
+#, c-format
+msgid "Unable to open category index file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/vector/Vlib/clean_nodes.c:54 ../lib/vector/Vlib/clean_nodes.c:250
+msgid "Modifications"
+msgstr "ÌåôáôñïðÝò"
#: ../lib/vector/Vlib/read.c:99
#, fuzzy
msgid "vector map is not opened"
@@ -1266,15 +1263,12 @@
"Vect_read_line():ãñáììÞ %d äåí Ý÷åé ëïãéêÞ (max ãñáììÞ óôïí äéáíõóìáôéêü "
"÷Üñôç: %d)"
-#: ../lib/vector/Vlib/clean_nodes.c:54 ../lib/vector/Vlib/clean_nodes.c:250
-msgid "Modifications"
-msgstr "ÌåôáôñïðÝò"
+#: ../lib/vector/Vlib/dangles.c:173 ../lib/vector/Vlib/dangles.c:272
+#: ../lib/vector/Vlib/dangles.c:284
+#, fuzzy
+msgid "Removed dangles:"
+msgstr "Ðåñéï÷Ýò ðïõ áöáéñÝèçêáí"
-#: ../lib/vector/Vlib/bridges.c:121 ../lib/vector/Vlib/bridges.c:202
-#: ../lib/vector/Vlib/bridges.c:209
-msgid "Removed bridges"
-msgstr ""
#: ../lib/vector/Vlib/array.c:98
#, c-format
msgid "%d errors in category string."
@@ -1303,11 +1297,6 @@
msgid "Unable to select record from table <%s> (key %s, where %s)"
msgstr "Áäõíáìßá åðéëïãÞò ôçò åããñáöÞò <%s> (êëåéäß %s, üðïõ %s)"
-#: ../lib/vector/Vlib/remove_duplicates.c:69
-#: ../lib/vector/Vlib/remove_duplicates.c:117
-msgid "Duplicates"
-msgstr "ÄéðëÝò åããñáöÝò"
#: ../lib/vector/Vlib/break_lines.c:122
#, c-format
msgid "%s %5d"
@@ -1336,6 +1325,11 @@
msgid "Breaks"
msgstr "\"Óðáóßìáôá\" (breaks)"
+#: ../lib/vector/Vlib/bridges.c:121 ../lib/vector/Vlib/bridges.c:202
+#: ../lib/vector/Vlib/bridges.c:209
+msgid "Removed bridges"
+msgstr ""
#: ../lib/vector/Vlib/poly.c:235
msgid "Unable to find point in polygon"
msgstr "Áäõíáìßá åýñåóçò óçìåßïõ óôï ðïëýãùíï"
@@ -1441,7 +1435,7 @@
msgstr "ÅðéöÜíåéá ìåãÝèïõò = 0.0 áãíïåßôáé"
#: ../lib/vector/Vlib/build_nat.c:151
-msgid "Request to find area outside nonexisting isle"
+msgid "Request to find area outside nonexistent isle"
msgstr ""
#: ../lib/vector/Vlib/build_nat.c:510
@@ -1543,7 +1537,8 @@
msgstr "Ç äïìÞ ôïõ ÷Üñôç Ý÷åé êëåßóåé"
#: ../lib/vector/Vlib/area.c:53
-msgid "Attempt to read points of nonexisting area"
+#, fuzzy
+msgid "Attempt to read points of nonexistent area"
msgstr "ÐñïóðÜèåéá ðñïóðåëáóçò óçìåßùí óå åðéöÜíåéá ðïõ äåí õðÜñ÷åé"
#: ../lib/vector/Vlib/area.c:125
@@ -1603,9 +1598,10 @@
msgid "Area is composed of dead boundary"
msgstr ""
-#: ../lib/vector/Vlib/read_nat.c:136
-msgid "Attempt to read dead line"
-msgstr ""
+#: ../lib/vector/Vlib/remove_duplicates.c:69
+#: ../lib/vector/Vlib/remove_duplicates.c:117
+msgid "Duplicates"
+msgstr "ÄéðëÝò åããñáöÝò"
#: ../lib/vector/Vlib/map.c:55
#, fuzzy
@@ -1695,6 +1691,10 @@
msgstr ""
"Áäõíáìßá ðñïóèÞêçò óýíäåóçò ìå âÜóç äåäïìÝíùí ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+#: ../lib/vector/Vlib/read_nat.c:136
+msgid "Attempt to read dead line"
+msgstr ""
#: ../lib/vector/Vlib/overlay.c:74
#, fuzzy
msgid "unknown operator"
@@ -2061,7 +2061,7 @@
#: ../lib/proj/convert.c:440
#, c-format
msgid ""
-"Invalid tranformation number %d; valid range is 1 to %d. Leaving datum "
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
"transform parameters unspecified."
msgstr ""
@@ -2331,111 +2331,111 @@
msgid "Other Projection"
msgstr ""
-#: ../lib/gis/opencell.c:103
+#: ../lib/gis/opencell.c:105
#, fuzzy, c-format
msgid "Unable to open raster map <%s@%s>"
msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
-#: ../lib/gis/opencell.c:169
+#: ../lib/gis/opencell.c:171
#, fuzzy, c-format
msgid "Unable to find <%s@%s>"
msgstr "Áäõíáìßá áíïßãìáôïò åðéðÝäïõ <%s>"
-#: ../lib/gis/opencell.c:186
+#: ../lib/gis/opencell.c:188
#, c-format
msgid ""
"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%"
"s> which does not exist"
msgstr ""
-#: ../lib/gis/opencell.c:210
+#: ../lib/gis/opencell.c:212
#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
msgstr ""
-#: ../lib/gis/opencell.c:217
+#: ../lib/gis/opencell.c:219
#, c-format
msgid ""
"Raster map <%s@%s> is in different projection than current region. Found "
"raster map <%s@%s>, should be <%s>."
msgstr ""
-#: ../lib/gis/opencell.c:224
+#: ../lib/gis/opencell.c:226
#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
msgstr ""
-#: ../lib/gis/opencell.c:231
+#: ../lib/gis/opencell.c:233
#, c-format
msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
msgstr ""
-#: ../lib/gis/opencell.c:260
+#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
-#: ../lib/gis/opencell.c:641
+#: ../lib/gis/opencell.c:642
#, fuzzy, c-format
msgid "Raster map <%s> is not in the current mapset (%s)"
msgstr ""
"Ï äéáíõóìáôéêüò ÷Üñôçò ðïõ äåí áíÞêåé óôï ôñÝ÷ïí mapset äåí ìðïñåß íá "
"áíïßîåé ãéá åíçìÝñùóç"
-#: ../lib/gis/opencell.c:648
+#: ../lib/gis/opencell.c:649
#, c-format
msgid "<%s> is an illegal file name"
msgstr ""
-#: ../lib/gis/opencell.c:654
+#: ../lib/gis/opencell.c:655
#, c-format
msgid "<%s>: bad mapset"
msgstr ""
-#: ../lib/gis/opencell.c:665 ../lib/gis/opencell.c:766
+#: ../lib/gis/opencell.c:666 ../lib/gis/opencell.c:767
msgid "G__open_raster_new(): no temp files available"
msgstr ""
-#: ../lib/gis/opencell.c:735
+#: ../lib/gis/opencell.c:736
msgid ""
"Unable to write embedded null values for raster map open for random access"
msgstr ""
-#: ../lib/gis/opencell.c:940
+#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
msgstr ""
-#: ../lib/gis/opencell.c:975 ../lib/gis/opencell.c:1063
+#: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
#, fuzzy, c-format
msgid "Unable to find '%s' in '%s'"
msgstr "Áäõíáìßá ìåôïíïìáóßáò êáôáëüãïõ óõóôÞìáôïò '%s' óå '%s'"
-#: ../lib/gis/opencell.c:1008
+#: ../lib/gis/opencell.c:1009
#, fuzzy, c-format
msgid "Raster map <%s> not found in mapset <%s>"
msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
-#: ../lib/gis/opencell.c:1069
+#: ../lib/gis/opencell.c:1070
#, fuzzy, c-format
msgid "Unable to find '%s'"
msgstr "Áäõíáìßá äéáãñáöÞò áñ÷åßïõ '%s'"
-#: ../lib/gis/opencell.c:1074
+#: ../lib/gis/opencell.c:1075
#, fuzzy, c-format
msgid "Unable to open '%s'"
msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
-#: ../lib/gis/opencell.c:1084
+#: ../lib/gis/opencell.c:1085
#, c-format
msgid "Invalid type: field '%s' in file '%s'"
msgstr ""
-#: ../lib/gis/opencell.c:1098
+#: ../lib/gis/opencell.c:1099
#, fuzzy, c-format
msgid "Raster map <%s> is not xdr: byte_order: %s"
-#: ../lib/gis/opencell.c:1178
+#: ../lib/gis/opencell.c:1179
msgid ""
"G_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
@@ -2465,6 +2465,16 @@
msgid "can't write category information for [%s] in [%s]"
msgstr ""
+#: ../lib/gis/find_file.c:74
+#, c-format
+msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr ""
+#: ../lib/gis/find_file.c:82
+#, fuzzy, c-format
+msgid "Using <%s@%s>"
+msgstr "Áäõíáìßá áíïßãìáôïò åðéðÝäïõ <%s>"
#: ../lib/gis/quant_io.c:89
#, c-format
msgid "The floating data range for %s@%s is empty"
@@ -2488,6 +2498,35 @@
msgid "Unknown Location"
msgstr ""
+#: ../lib/gis/color_rules.c:110
+msgid "syntax error"
+msgstr ""
+#: ../lib/gis/color_rules.c:112
+msgid "R/G/B not in range 0-255"
+msgstr ""
+#: ../lib/gis/color_rules.c:114
+msgid "invalid color name"
+msgstr ""
+#: ../lib/gis/color_rules.c:116
+msgid "percentage not in range 0-100"
+msgstr ""
+#: ../lib/gis/color_rules.c:118
+msgid "invalid value"
+msgstr ""
+#: ../lib/gis/color_rules.c:120
+msgid "unknown error"
+msgstr ""
+#: ../lib/gis/color_rules.c:151
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
#: ../lib/gis/spawn.c:80 ../lib/gis/spawn.c:112
msgid "Too many arguments"
msgstr ""
@@ -2540,35 +2579,6 @@
msgid "Unable to change directory to %s"
msgstr ""
-#: ../lib/gis/color_rules.c:110
-msgid "syntax error"
-msgstr ""
-#: ../lib/gis/color_rules.c:112
-msgid "R/G/B not in range 0-255"
-msgstr ""
-#: ../lib/gis/color_rules.c:114
-msgid "invalid color name"
-msgstr ""
-#: ../lib/gis/color_rules.c:116
-msgid "percentage not in range 0-100"
-msgstr ""
-#: ../lib/gis/color_rules.c:118
-msgid "invalid value"
-msgstr ""
-#: ../lib/gis/color_rules.c:120
-msgid "unknown error"
-msgstr ""
-#: ../lib/gis/color_rules.c:151
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
#: ../lib/gis/mapset.c:39
msgid "MAPSET is not set"
msgstr ""
@@ -2867,6 +2877,18 @@
msgid "unable to write f_format file for CELL maps"
msgstr ""
+#: ../lib/gis/home.c:39
+msgid "unable to determine user's home directory"
+msgstr ""
+#: ../lib/gis/error.c:257
+msgid "WARNING: "
+msgstr ""
+#: ../lib/gis/error.c:258
+msgid "ERROR: "
+msgstr ""
#: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
#, c-format
msgid "Unable to read header file for raster map <%s@%s>."
@@ -2902,18 +2924,6 @@
msgid " Invalid format."
msgstr ""
-#: ../lib/gis/home.c:39
-msgid "unable to determine user's home directory"
-msgstr ""
-#: ../lib/gis/error.c:257
-msgid "WARNING: "
-msgstr ""
-#: ../lib/gis/error.c:258
-msgid "ERROR: "
-msgstr ""
#: ../lib/gis/cats.c:381
#, c-format
msgid "category support for [%s] in mapset [%s] %s"
@@ -2959,16 +2969,6 @@
msgid "No ellipsoid info given in file %s in <%s>"
msgstr ""
-#: ../lib/gis/raster_metadata.c:111
-#, c-format
-msgid "Can't read %s for [%s in %s]"
-msgstr ""
-#: ../lib/gis/raster_metadata.c:144
-#, c-format
-msgid "Can't create %s metadata file for [%s in %s]"
-msgstr ""
#: ../lib/gis/location.c:44
#, c-format
msgid "LOCATION << %s >> not available"
@@ -3352,70 +3352,70 @@
msgid " You provided %d items:\n"
msgstr ""
-#: ../lib/gis/parser.c:2542
+#: ../lib/gis/parser.c:2544
#, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
msgstr ""
-#: ../lib/gis/parser.c:2596
+#: ../lib/gis/parser.c:2599
#, c-format
msgid ""
"\n"
"FLAG: Set the following flag?\n"
msgstr ""
-#: ../lib/gis/parser.c:2610
+#: ../lib/gis/parser.c:2613
#, c-format
msgid ""
"\n"
"OPTION: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2611
+#: ../lib/gis/parser.c:2614
#, c-format
msgid " key: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2613
+#: ../lib/gis/parser.c:2616
#, c-format
msgid " format: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2615
+#: ../lib/gis/parser.c:2618
#, c-format
msgid " default: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2616
+#: ../lib/gis/parser.c:2619
#, c-format
msgid "required: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2618
+#: ../lib/gis/parser.c:2621
#, c-format
msgid "multiple: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2620
+#: ../lib/gis/parser.c:2623
#, c-format
msgid " options: %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2633
+#: ../lib/gis/parser.c:2636
#, c-format
msgid "enter option > "
msgstr ""
-#: ../lib/gis/parser.c:2650 ../lib/gis/parser.c:2660
+#: ../lib/gis/parser.c:2653 ../lib/gis/parser.c:2663
msgid " Try again? "
msgstr ""
-#: ../lib/gis/parser.c:2658
+#: ../lib/gis/parser.c:2661
#, c-format
msgid "Sorry, %s is not accepted.\n"
msgstr ""
-#: ../lib/gis/parser.c:2668
+#: ../lib/gis/parser.c:2671
#, c-format
msgid ""
"\n"
@@ -3423,11 +3423,11 @@
" %s\n"
msgstr ""
-#: ../lib/gis/parser.c:2669
+#: ../lib/gis/parser.c:2672
msgid "Is this correct? "
msgstr ""
-#: ../lib/gis/parser.c:2734
+#: ../lib/gis/parser.c:2737
msgid "to accept the default"
msgstr ""
@@ -3469,6 +3469,26 @@
msgid "Cannot write quant rules for map %s"
msgstr ""
+#: ../lib/gis/raster_metadata.c:111
+#, c-format
+msgid "Can't read %s for [%s in %s]"
+msgstr ""
+#: ../lib/gis/raster_metadata.c:144
+#, c-format
+msgid "Can't create %s metadata file for [%s in %s]"
+msgstr ""
+#: ../lib/gis/open.c:62
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:84
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
#: ../lib/gis/timestamp.c:282
#, c-format
msgid "Can't create timestamp file for %s map %s in mapset %s"
@@ -3489,16 +3509,6 @@
msgid "Invalid timestamp file for %s map %s in mapset %s"
msgstr ""
-#: ../lib/gis/open.c:62
-#, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open.c:84
-#, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:199
msgid "Illegal n-s resolution value"
msgstr ""
@@ -3903,6 +3913,18 @@
msgid "ask: can't happen"
msgstr ""
+#: ../lib/gis/alloc.c:45
+msgid "G_malloc: out of memory"
+msgstr ""
+#: ../lib/gis/alloc.c:79
+msgid "G_calloc: out of memory"
+msgstr ""
+#: ../lib/gis/alloc.c:117
+msgid "G_realloc: out of memory"
+msgstr ""
#: ../lib/gis/histogram.c:57
#, c-format
msgid "Histogram for [%s in %s] missing (run r.support)"
@@ -3923,18 +3945,16 @@
msgid "can't create histogram for [%s in %s]"
msgstr ""
-#: ../lib/gis/alloc.c:45
-msgid "G_malloc: out of memory"
-msgstr ""
+#: ../lib/gis/gdal.c:54
+#, fuzzy, c-format
+msgid "Unable to locate symbol <%s>"
-#: ../lib/gis/alloc.c:79
-msgid "G_calloc: out of memory"
-msgstr ""
+#: ../lib/gis/gdal.c:94
+#, fuzzy
+msgid "Unable to load GDAL library"
+msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
-#: ../lib/gis/alloc.c:117
-msgid "G_realloc: out of memory"
-msgstr ""
#: ../lib/nviz/change_view.c:108
#, c-format
msgid "Invalid view position coordinates, using %f,%f"
@@ -4052,20 +4072,11 @@
msgid "Loading 3d raster map <%s>..."
msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s> óôç ìíÞìç"
-#: ../lib/ogsf/gsdrape.c:207
-#, fuzzy
-msgid "Unable to process vector map - out of memory"
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
#: ../lib/ogsf/Gvl3.c:39 ../lib/ogsf/gvl_file.c:428
#, fuzzy, c-format
msgid "3D raster map <%s> not found"
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr ""
#: ../lib/ogsf/gsd_img_mpeg.c:63
#, fuzzy
msgid "Unable to allocate stream"
@@ -4132,6 +4143,11 @@
msgid "Unable to open file <%s> for writing"
+#: ../lib/ogsf/gsdrape.c:207
+#, fuzzy
+msgid "Unable to process vector map - out of memory"
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
#: ../lib/ogsf/gsd_legend.c:245
#, fuzzy, c-format
msgid "Unable to read color file of raster map <%s>"
@@ -4223,6 +4239,10 @@
msgid "Check no. of frames requested and keyframes marked"
msgstr ""
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr ""
#: ../lib/ogsf/gvl_file.c:104
msgid "Maximum number of datafiles exceeded"
msgstr ""
@@ -4441,23 +4461,19 @@
msgid " taking FFT of image..."
msgstr ""
-#: ../lib/gmath/del2g.c:57
-msgid "Insufficent memory for allocation of gaussian"
+#: ../lib/gmath/del2g.c:56
+msgid " computing del**2 g..."
msgstr ""
#: ../lib/gmath/del2g.c:59
-msgid " computing del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:62
msgid " taking FFT of del**2 g..."
msgstr ""
-#: ../lib/gmath/del2g.c:66
+#: ../lib/gmath/del2g.c:63
msgid " multiplying transforms..."
msgstr ""
-#: ../lib/gmath/del2g.c:69
+#: ../lib/gmath/del2g.c:66
msgid " taking inverse FFT..."
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2008-10-12 06:55:55 UTC (rev 33834)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2008-10-12 07:12:30 UTC (rev 33835)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grassmods_el\n"
-"POT-Creation-Date: 2008-08-19 23:37+0200\n"
"PO-Revision-Date: 2007-03-23 16:35+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -19,18 +19,19 @@
#: ../db/base/execute.c:60 ../db/base/createdb.c:43 ../db/base/dropdb.c:43
#: ../db/base/tables.c:46 ../db/base/droptable.c:44 ../db/base/select.c:62
#: ../db/base/columns.c:45 ../db/base/describe.c:52 ../db/base/databases.c:52
-#: ../vector/v.db.connect/main.c:182 ../vector/v.db.connect/main.c:248
+#: ../vector/v.db.connect/main.c:188 ../vector/v.db.connect/main.c:254
#: ../vector/v.edit/select.c:513 ../vector/v.in.sites/main.c:158
-#: ../vector/v.out.svg/main.c:142 ../vector/v.out.ogr/main.c:322
-#: ../vector/v.extract/main.c:241 ../doc/vector/v.example/main.c:123
-#: ../display/d.vect/main.c:499 ../display/d.thematic.area/main.c:231
+#: ../vector/v.out.svg/main.c:141 ../vector/v.out.vtk/writeVTK.c:634
+#: ../vector/v.out.ogr/main.c:322 ../vector/v.extract/main.c:278
+#: ../doc/vector/v.example/main.c:123 ../display/d.vect/main.c:499
+#: ../display/d.thematic.area/main.c:230
#, c-format
msgid "Unable to start driver <%s>"
msgstr ""
#: ../db/base/execute.c:66 ../db/base/tables.c:51 ../db/base/select.c:68
#: ../db/base/describe.c:57 ../display/d.vect/main.c:504
-#: ../display/d.thematic.area/main.c:236
+#: ../display/d.thematic.area/main.c:235
#, c-format
msgid "Unable to open database <%s>"
msgstr ""
@@ -75,8 +76,8 @@
#: ../db/base/copy.c:37
msgid ""
-"Either 'from_table' (optionaly with 'where') can be used or 'select' option, "
-"but not 'from_table' and 'select' at the same time."
+"Either 'from_table' (optionally with 'where') can be used or 'select' "
+"option, but not 'from_table' and 'select' at the same time."
msgstr ""
#: ../db/base/copy.c:43
@@ -141,11 +142,6 @@
#: ../db/base/tables.c:95 ../db/base/drivers.c:74 ../db/base/columns.c:92
#: ../db/base/describe.c:125 ../db/base/connect.c:45
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.test_to_translate.c:2
msgid "database, attribute table"
msgstr ""
@@ -183,15 +179,15 @@
#: ../db/base/select.c:195 ../raster/r.distance/parse.c:50
#: ../raster/r.stats/main.c:108 ../raster/r.cats/main.c:72
-#: ../vector/v.db.select/main.c:59
+#: ../vector/v.db.select/main.c:63
msgid "Output field separator"
msgstr ""
-#: ../db/base/select.c:199 ../vector/v.db.select/main.c:63
+#: ../db/base/select.c:199 ../vector/v.db.select/main.c:68
msgid "Output vertical record separator"
msgstr ""
-#: ../db/base/select.c:206 ../vector/v.db.select/main.c:70
+#: ../db/base/select.c:206 ../vector/v.db.select/main.c:76
msgid "Null value indicator"
msgstr ""
@@ -199,7 +195,7 @@
msgid "Name of file with sql statement"
msgstr ""
-#: ../db/base/select.c:214 ../vector/v.db.select/main.c:74
+#: ../db/base/select.c:214 ../vector/v.db.select/main.c:86
msgid "Do not include column names in output"
msgstr ""
@@ -207,7 +203,7 @@
msgid "Describe query only (don't run it)"
msgstr ""
-#: ../db/base/select.c:222 ../vector/v.db.select/main.c:78
+#: ../db/base/select.c:222 ../vector/v.db.select/main.c:91
msgid "Vertical output (instead of horizontal)"
msgstr ""
@@ -223,11 +219,11 @@
msgid "List all columns for a given table."
msgstr ""
-#: ../db/base/describe.c:63 ../vector/v.db.connect/main.c:193
-#: ../vector/v.in.ascii/in.c:399 ../vector/v.patch/main.c:139
+#: ../db/base/describe.c:63 ../vector/v.db.connect/main.c:199
+#: ../vector/v.in.ascii/in.c:402 ../vector/v.patch/main.c:139
#: ../vector/v.patch/main.c:177 ../vector/v.random/main.c:199
-#: ../vector/v.out.svg/main.c:155 ../vector/v.out.ogr/main.c:332
-#: ../doc/vector/v.example/main.c:134
+#: ../vector/v.out.svg/main.c:154 ../vector/v.out.vtk/writeVTK.c:643
+#: ../vector/v.out.ogr/main.c:332 ../doc/vector/v.example/main.c:134
#, c-format
msgid "Unable to describe table <%s>"
msgstr ""
@@ -351,18 +347,6 @@
msgid "Cannot get list of tables:\n"
msgstr ""
-#: ../db/drivers/mysql/describe.c:120
-#, c-format
-msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr ""
-#: ../db/drivers/mysql/describe.c:126
-#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
#: ../db/drivers/mysql/parse.c:60
msgid "Wrong port number in MySQL database definition: "
msgstr ""
@@ -391,6 +375,34 @@
msgid "Cannot select data: \n"
msgstr ""
+#: ../db/drivers/mysql/describe.c:120
+#, c-format
+msgid "MySQL driver: column '%s', type %d is not supported"
+msgstr ""
+#: ../db/drivers/mysql/describe.c:126
+#, c-format
+msgid ""
+"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
+"damaged"
+msgstr ""
+#: ../db/drivers/mysql/db.c:67
+msgid "Cannot connect to MySQL: "
+msgstr ""
+#: ../db/drivers/mysql/db.c:83
+msgid "Cannot parse MySQL embedded database name"
+msgstr ""
+#: ../db/drivers/mysql/db.c:99
+msgid "Cannot initialize MySQL embedded server"
+msgstr ""
+#: ../db/drivers/mysql/db.c:118
+msgid "Cannot connect to MySQL embedded server: "
+msgstr ""
#: ../db/drivers/mysql/fetch.c:34
msgid "Cursor not found"
msgstr ""
@@ -419,26 +431,14 @@
msgid "Cannot scan datetime: "
msgstr ""
-#: ../db/drivers/mysql/db.c:67
-msgid "Cannot connect to MySQL: "
-msgstr ""
-#: ../db/drivers/mysql/db.c:83
-msgid "Cannot parse MySQL embedded database name"
-msgstr ""
-#: ../db/drivers/mysql/db.c:99
-msgid "Cannot initialize MySQL embedded server"
-msgstr ""
-#: ../db/drivers/mysql/db.c:118
-msgid "Cannot connect to MySQL embedded server: "
-msgstr ""
#: ../db/drivers/mysql/error.c:29
msgid "DBMI-MySQL driver error:\n"
msgstr ""
+#: ../db/drivers/postgres/parse.c:63
+msgid "Unknown option in database definition for PostgreSQL: "
+msgstr ""
#: ../db/drivers/postgres/describe.c:103
#, c-format
msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
@@ -470,10 +470,6 @@
"(true)"
msgstr ""
-#: ../db/drivers/postgres/parse.c:63
-msgid "Unknown option in database definition for PostgreSQL: "
-msgstr ""
#: ../db/drivers/postgres/fetch.c:172
msgid "Cannot recognize boolean value"
msgstr ""
@@ -1040,19 +1036,19 @@
#: ../raster/r.to.rast3elev/main.c:114 ../raster/r.to.rast3elev/main.c:129
#: ../raster/r.statistics/main.c:79 ../raster/r.statistics/main.c:85
#: ../raster/r.info/main.c:118 ../raster/r.patch/main.c:114
-#: ../raster/r.grow2/main.c:186 ../raster/r.surf.idw/main.c:109
+#: ../raster/r.grow2/main.c:187 ../raster/r.surf.idw/main.c:109
#: ../raster/r.thin/io.c:96 ../raster/r.flow/io.c:63
#: ../raster/r.topidx/check_ready.c:11 ../raster/r.out.pov/main.c:174
#: ../raster/r.covar/main.c:95 ../raster/r.out.arc/main.c:114
-#: ../raster/r.report/parse.c:241 ../raster/r.random/main.c:113
+#: ../raster/r.report/parse.c:243 ../raster/r.random/main.c:113
#: ../raster/r.random/main.c:118 ../raster/r.his/main.c:127
#: ../raster/r.his/main.c:164 ../raster/r.his/main.c:189
#: ../raster/r.bilinear/main.c:81 ../raster/r.kappa/stats.c:30
#: ../raster/r.kappa/stats.c:35 ../raster/r.kappa/main.c:146
#: ../raster/r.median/main.c:75 ../raster/r.resamp.rst/main.c:400
#: ../raster/r.resamp.rst/main.c:426 ../raster/r.stats/main.c:259
-#: ../raster/r.slope.aspect/main.c:384 ../raster/r.colors/main.c:267
-#: ../raster/r.colors/main.c:346 ../raster/r.out.ppm/main.c:116
+#: ../raster/r.slope.aspect/main.c:384 ../raster/r.colors/main.c:283
+#: ../raster/r.colors/main.c:362 ../raster/r.out.ppm/main.c:116
#: ../raster/r.fill.dir/main.c:172 ../raster/r.mfilter.fp/main.c:126
#: ../raster/r.cost/main.c:322 ../raster/r.out.vtk/main.c:47
#: ../raster/r.out.vtk/main.c:60 ../raster/r.support/modcolr/modcolr.c:45
@@ -1064,7 +1060,7 @@
#: ../raster/r.watershed/ram/init_vars.c:398
#: ../raster/r.watershed/seg/init_vars.c:427 ../raster/r.contour/main.c:158
#: ../raster/r.cross/main.c:114 ../raster/r.cats/main.c:125
-#: ../raster/r.cats/main.c:146 ../raster/r.series/main.c:173
+#: ../raster/r.cats/main.c:146 ../raster/r.series/main.c:181
#: ../raster/r.water.outlet/legal.c:23 ../raster/r.out.tiff/r.out.tiff.c:166
#: ../raster/r.out.mpeg/main.c:217 ../raster/r.walk/main.c:523
#: ../raster/r.walk/main.c:526 ../raster/r.mapcalc/map.c:377
@@ -1074,12 +1070,13 @@
#: ../raster/wildfire/r.ros/main.c:345 ../raster/wildfire/r.ros/main.c:350
#: ../raster/wildfire/r.ros/main.c:368 ../raster/wildfire/r.ros/main.c:372
#: ../raster/wildfire/r.ros/main.c:391 ../raster/wildfire/r.ros/main.c:395
-#: ../raster/wildfire/r.ros/main.c:408 ../raster/wildfire/r.spread/main.c:368
-#: ../raster/wildfire/r.spread/main.c:374
-#: ../raster/wildfire/r.spread/main.c:380
-#: ../raster/wildfire/r.spread/main.c:387
-#: ../raster/wildfire/r.spread/main.c:392
-#: ../raster/wildfire/r.spread/main.c:397 ../raster/r.resample/main.c:97
+#: ../raster/wildfire/r.ros/main.c:408 ../raster/wildfire/r.spread/main.c:356
+#: ../raster/wildfire/r.spread/main.c:359
+#: ../raster/wildfire/r.spread/main.c:362
+#: ../raster/wildfire/r.spread/main.c:365
+#: ../raster/wildfire/r.spread/main.c:369
+#: ../raster/wildfire/r.spread/main.c:372
+#: ../raster/wildfire/r.spread/main.c:375 ../raster/r.resample/main.c:97
#: ../raster/r.buffer/main.c:117 ../raster/r.support.stats/main.c:48
#: ../raster/r.bitpattern/main.c:101 ../vector/v.what.rast/main.c:138
#: ../vector/v.extrude/main.c:178 ../vector/v.sample/main.c:158
@@ -1094,20 +1091,20 @@
#: ../imagery/i.fft/fftmain.c:121
#: ../imagery/i.ortho.photo/photo.2target/main.c:203
#: ../imagery/i.ortho.photo/photo.2target/main.c:233
-#: ../visualization/xganim/main.c:366 ../visualization/nviz2/cmd/surface.c:54
-#: ../visualization/nviz2/cmd/surface.c:97 ../display/d.histogram/main.c:162
+#: ../visualization/xganim/main.c:366 ../visualization/nviz2/cmd/surface.c:56
+#: ../visualization/nviz2/cmd/surface.c:106 ../display/d.histogram/main.c:162
#: ../display/d.profile/main.c:94 ../display/d.rast.num/number.c:149
#: ../display/d.what.rast/opencell.c:13 ../display/d.what.rast/main.c:148
#: ../display/d.title/main.c:105 ../display/d.legend/main.c:256
#: ../display/d.rast.arrow/arrow.c:195 ../display/d.rast.arrow/arrow.c:237
-#: ../display/d.rast.arrow/arrow.c:372 ../display/d.rast/main.c:111
+#: ../display/d.rast.arrow/arrow.c:372 ../display/d.rast/main.c:110
#: ../display/d.rgb/main.c:101 ../display/d.his/main.c:137
#: ../display/d.his/main.c:174 ../display/d.his/main.c:199
#: ../display/d.zoom/main.c:208 ../display/d.nviz/main.c:184
#: ../display/d.colortable/main.c:104 ../display/d.extend/main.c:60
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:392
-#: ../general/g.region/main.c:451 ../general/g.region/main.c:794
-#: ../general/g.region/main.c:802
+#: ../general/g.region/main.c:450 ../general/g.region/main.c:793
+#: ../general/g.region/main.c:801 ../general/g.mremove/do_remove.c:50
#, c-format
msgid "Raster map <%s> not found"
msgstr ""
@@ -1260,13 +1257,13 @@
msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:99 ../raster/r.out.vtk/parameters.c:93
-#: ../vector/v.out.vtk/main.c:74
+#: ../vector/v.out.vtk/main.c:75
msgid "Scale factor for elevation"
msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:112 ../raster/r.out.ascii/main.c:85
#: ../raster/r.out.vtk/parameters.c:105 ../vector/v.out.ascii/out.c:81
-#: ../vector/v.out.vtk/main.c:68 ../display/d.rast.num/number.c:117
+#: ../vector/v.out.vtk/main.c:69 ../display/d.rast.num/number.c:117
msgid "Number of significant digits (floating point only)"
msgstr ""
@@ -1279,7 +1276,7 @@
msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:128
-#: ../raster/r.out.vtk/parameters.c:135 ../vector/v.out.vtk/main.c:87
+#: ../raster/r.out.vtk/parameters.c:135 ../vector/v.out.vtk/main.c:88
msgid "Correct the coordinates to fit the VTK-OpenGL precision"
msgstr ""
@@ -1449,27 +1446,27 @@
#: ../raster/r.in.ascii/main.c:206 ../raster/r.carve/main.c:189
#: ../raster/r.texture/main.c:306 ../raster/r.basins.fill/main.c:117
#: ../raster/r.null/null.c:303 ../raster/r.lake/main.c:229
-#: ../raster/r.lake/main.c:318 ../raster/r.surf.idw2/main.c:111
-#: ../raster/r.patch/main.c:145 ../raster/r.grow2/main.c:208
-#: ../raster/r.circle/dist.c:127 ../raster/r.surf.idw/main.c:148
-#: ../raster/r.thin/io.c:168 ../raster/r.li/r.li.daemon/daemon.c:117
-#: ../raster/r.flow/io.c:167 ../raster/r.flow/io.c:202
-#: ../raster/r.in.gdal/main.c:715 ../raster/r.in.gdal/main.c:720
-#: ../raster/r.in.gdal/main.c:734 ../raster/r.sunmask/main.c:457
-#: ../raster/r.bilinear/main.c:104 ../raster/r.surf.random/randsurf.c:28
-#: ../raster/r.surf.random/randsurf.c:32 ../raster/r.in.xyz/main.c:492
-#: ../raster/r.slope.aspect/opennew.c:19 ../raster/r.clump/main.c:99
-#: ../raster/r.in.mat/main.c:430 ../raster/r.cross/main.c:134
-#: ../raster/r.series/main.c:190 ../raster/r.mapcalc/map3.c:580
-#: ../raster/r.mapcalc/map.c:507 ../raster/r.composite/main.c:194
-#: ../raster/r.buffer/write_map.c:40 ../raster/r.in.arc/main.c:154
-#: ../raster/r.bitpattern/main.c:125 ../vector/lidar/v.surf.bspline/main.c:290
-#: ../vector/v.kernel/main.c:268 ../vector/v.surf.idw/main.c:249
-#: ../vector/v.neighbors/main.c:96 ../vector/v.to.rast/vect2rast.c:125
-#: ../vector/v.to.rast/vect2rast.c:129 ../doc/raster/r.example/main.c:141
-#: ../imagery/i.his.rgb/openfiles.c:15 ../imagery/i.his.rgb/openfiles.c:17
-#: ../imagery/i.his.rgb/openfiles.c:19 ../imagery/i.smap/shapiro/opencell.c:30
-#: ../imagery/i.pca/main.c:392
+#: ../raster/r.lake/main.c:318 ../raster/r.in.bin/main.c:497
+#: ../raster/r.surf.idw2/main.c:111 ../raster/r.patch/main.c:145
+#: ../raster/r.grow2/main.c:209 ../raster/r.circle/dist.c:127
+#: ../raster/r.surf.idw/main.c:148 ../raster/r.thin/io.c:168
+#: ../raster/r.li/r.li.daemon/daemon.c:117 ../raster/r.flow/io.c:167
+#: ../raster/r.flow/io.c:202 ../raster/r.in.gdal/main.c:715
+#: ../raster/r.in.gdal/main.c:720 ../raster/r.in.gdal/main.c:734
+#: ../raster/r.sunmask/main.c:457 ../raster/r.bilinear/main.c:104
+#: ../raster/r.surf.random/randsurf.c:28 ../raster/r.surf.random/randsurf.c:32
+#: ../raster/r.in.xyz/main.c:495 ../raster/r.slope.aspect/opennew.c:19
+#: ../raster/r.clump/main.c:99 ../raster/r.in.mat/main.c:430
+#: ../raster/r.cross/main.c:134 ../raster/r.series/main.c:213
+#: ../raster/r.mapcalc/map3.c:580 ../raster/r.mapcalc/map.c:507
+#: ../raster/r.composite/main.c:194 ../raster/r.buffer/write_map.c:40
+#: ../raster/r.in.arc/main.c:154 ../raster/r.bitpattern/main.c:125
+#: ../vector/lidar/v.surf.bspline/main.c:290 ../vector/v.kernel/main.c:268
+#: ../vector/v.surf.idw/main.c:258 ../vector/v.neighbors/main.c:96
+#: ../vector/v.to.rast/vect2rast.c:125 ../vector/v.to.rast/vect2rast.c:129
+#: ../doc/raster/r.example/main.c:141 ../imagery/i.his.rgb/openfiles.c:15
+#: ../imagery/i.his.rgb/openfiles.c:17 ../imagery/i.his.rgb/openfiles.c:19
+#: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:392
#, c-format
msgid "Unable to create raster map <%s>"
msgstr ""
@@ -1504,1037 +1501,6 @@
msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
msgstr ""
-#: ../locale/scriptstrings/d.m_to_translate.c:1
-msgid "Display manager for GRASS"
-msgstr ""
-#: ../locale/scriptstrings/d.m_to_translate.c:2
-msgid "Name of .dmrc settings file"
-msgstr ""
-#: ../locale/scriptstrings/gis.m_to_translate.c:1
-msgid "GIS manager for GRASS"
-msgstr ""
-#: ../locale/scriptstrings/gis.m_to_translate.c:2
-msgid "Name of GIS manager settings file (.grc)"
-msgstr ""
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:1
-msgid "Configuration editor for r.li.'index'"
-msgstr ""
-#: ../locale/scriptstrings/r.li.setup_to_translate.c:2
-msgid "raster, landscape structure analysis"
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between data layers (in pairs)."
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-msgid "display, diagram"
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-msgid "raster input map"
-msgstr ""
-#: ../locale/scriptstrings/d.monsize_to_translate.c:1
-msgid "Selects/starts specified monitor at specified size"
-msgstr ""
-#: ../locale/scriptstrings/d.monsize_to_translate.c:2
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:2
-#: ../locale/scriptstrings/d.resize_to_translate.c:2
-#: ../locale/scriptstrings/d.split_to_translate.c:2
-#: ../display/d.colortable/main.c:66 ../display/d.extend/main.c:31
-msgid "display, setup"
-msgstr ""
-#: ../locale/scriptstrings/d.monsize_to_translate.c:3
-msgid "Display monitor to start"
-msgstr ""
-#: ../locale/scriptstrings/d.monsize_to_translate.c:4
-msgid "Width in pixels of new display monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.monsize_to_translate.c:5
-msgid "Height in pixels of new display monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
-msgid "Moves displayed maps to another monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
-msgid "clear target monitor before moving"
-msgstr ""
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
-msgid "stay with source monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
-msgid "kill source monitor after moving"
-msgstr ""
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
-msgid "Target monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
-msgid "Source monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
-msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr ""
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
-msgid "display, export, GPS"
-msgstr ""
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
-msgid "name for new map image (lives in ~/.gpsdrive)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:4
-msgid "Make JPEG instead of PNG image"
-msgstr ""
-#: ../locale/scriptstrings/d.out.png_to_translate.c:1
-msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-#: ../locale/scriptstrings/d.out.png_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-msgid "display, export"
-msgstr ""
-#: ../locale/scriptstrings/d.out.png_to_translate.c:3
-msgid "Name of PNG file"
-msgstr ""
-#: ../locale/scriptstrings/d.out.png_to_translate.c:4
-msgid "Resolution of output file (single=1, double=2, quad=4)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-msgid "Name for output file (do NOT add extension)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-#: ../visualization/nviz2/cmd/args.c:83
-msgid "Graphics file format"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-msgid "Dimensions of output file versus current window size"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-msgid "(same=1, double size=2, quadruple size=4)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-#: ../locale/scriptstrings/d.out.file_to_translate.c:9
-#: ../locale/scriptstrings/d.out.file_to_translate.c:12
-#: ../locale/scriptstrings/d.out.file_to_translate.c:15
-#: ../locale/scriptstrings/d.out.file_to_translate.c:22
-#: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid "Images"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:8
-msgid "Width and height of output image (overrides resolution setting)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:10
-msgid "Compression for PNG files"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:11
-msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:13
-msgid "File size/quality for JPEG files"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:14
-msgid "(10=smallest/worst, 100=largest/best)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:16
-msgid "Paper size for PostScript output"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:17
-#: ../locale/scriptstrings/d.out.file_to_translate.c:19
-#: ../locale/scriptstrings/d.out.file_to_translate.c:26
-msgid "PostScript"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:18
-msgid "PostScript level (only limits functionality!)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:20
-msgid "Set background color to black (white default)"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:21
-msgid "Set transparent background"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:23
-msgid "Use the Cario driver to render images"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:25
-msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "Name of raster angle map"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Name of optional EPS output file"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-msgid "Plot using Xgraph"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#: ../display/d.rast.edit/main.c:61
-msgid "Interactively edit cell values in a raster map."
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../display/d.rast.edit/main.c:59
-msgid "display, raster"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../raster/r.random/main.c:57 ../raster/r.resamp.rst/main.c:167
-#: ../raster/r.out.bin/main.c:73 ../raster/r.water.outlet/main.c:54
-#: ../imagery/i.zc/main.c:69
-msgid "Name of input raster map"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:9
-#: ../raster/r.in.gridatb/main.c:53
-msgid "Name for output raster map"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-msgid "Name of aspect raster map"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-msgid "Maximum number of rows to load"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-msgid "Maximum number of columns to load"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../visualization/ximgview/main.c:270 ../display/d.histogram/main.c:71
-#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
-#: ../display/d.profile/main.c:61 ../display/d.measure/main.c:49
-#: ../display/d.colors/main.c:50 ../display/d.what.vect/main.c:54
-#: ../display/d.font/main.c:46 ../display/d.rast.num/number.c:84
-#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
-#: ../display/d.what.rast/main.c:45 ../display/d.title/main.c:45
-#: ../display/d.geodesic/main.c:46 ../display/d.text/main.c:66
-#: ../display/d.font.freetype/main.c:59 ../display/d.info/main.c:33
-#: ../display/d.save/main.c:79 ../display/d.rast.arrow/arrow.c:110
-#: ../display/d.menu/main.c:66 ../display/d.thematic.area/main.c:79
-#: ../display/d.text.freetype/main.c:138 ../display/d.rast/main.c:51
-#: ../display/d.extract/main.c:50 ../display/d.rgb/main.c:55
-#: ../display/d.where/main.c:42 ../display/d.paint.labels/main.c:46
-#: ../display/d.text.new/main.c:139 ../display/d.ask/main.c:36
-#: ../display/d.his/main.c:65 ../display/d.zoom/main.c:57
-#: ../display/d.rhumbline/main.c:45 ../display/d.nviz/main.c:68
-#: ../display/d.mon/cmd/main.c:48 ../display/d.frame/frame.c:60
-msgid "display"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-msgid "omit entries with missing label"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-msgid "Number of lines to appear in the legend"
-msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the current display frame in the GRASS monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-msgid "Redraw all frames"
-msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "Do not preserve individual regions when redrawing all frames"
-msgstr ""
-#: ../locale/scriptstrings/d.resize_to_translate.c:1
-msgid "Resizes active display monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.resize_to_translate.c:3
-msgid "New width for window"
-msgstr ""
-#: ../locale/scriptstrings/d.resize_to_translate.c:4
-msgid "New height for window"
-msgstr ""
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-msgid "Drapes a color raster over a shaded relief map using d.his"
-msgstr ""
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-msgid "Name of shaded relief or aspect map"
-msgstr ""
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-msgid "Name of raster to drape over relief map"
-msgstr ""
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-msgid "Percent to brighten"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:1
-msgid "Slide show of GRASS raster/vector maps."
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:2
-msgid "display, slideshow"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:3
-msgid "Show vector maps rather than raster maps"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:4
-msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:5
-msgid "Map number show across the monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:6
-msgid "Map number show down the monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:7
-msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr ""
-#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
-msgid "Number of seconds to pause between slides"
-msgstr ""
-#: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-#: ../locale/scriptstrings/d.split_to_translate.c:3
-msgid "Enter raster map to display in 1st frame"
-msgstr ""
-#: ../locale/scriptstrings/d.split_to_translate.c:4
-msgid "Enter command to execute in 1st frame"
-msgstr ""
-#: ../locale/scriptstrings/d.split_to_translate.c:5
-msgid "Enter raster map to display in 2nd frame"
-msgstr ""
-#: ../locale/scriptstrings/d.split_to_translate.c:6
-msgid "Enter command to execute in 2nd frame"
-msgstr ""
-#: ../locale/scriptstrings/d.split_to_translate.c:7
-msgid "How to split display"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
-msgid "Displays thematic vectormap"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-msgid "display, legend"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
-msgid "Files"
-msgstr ""
-msgid "Vector map to display thematically"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:5
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:9
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:11
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
-msgid "Theme_prefs"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
-msgid "Vector map type"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
-msgid "Attribute column to use for thematic display (must be numeric)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
-msgid "Type of thematic display"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
-msgid "Thematic divisions of data for display"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
-msgid ""
-"Break points for custom breaks option. Separate values by spaces. (0 10 20 "
-"30 ...)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
-msgid "Layer to use for thematic display"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
-msgid "Points"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
-msgid "Vector point icon for point data"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
-msgid ""
-"Icon size for point data (minimum icon size/line width for graduated points/"
-"lines)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
-msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
-msgid "Number of classes for interval theme (integer)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
-msgid "Color"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
-msgid ""
-"Color scheme for graduated color mapping (select 'single_color' for "
-"graduated point/line display)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-msgid ""
-"Color for graduated points map (grass named color or R:G:B triplet). Set "
-"color scheme to single color."
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
-msgid ""
-"Color for graduated lines or point/area outlines (grass named color or R:G:B "
-"triplet). Set color scheme to single color."
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
-msgid ""
-"Beginning color for custom color gradient. Must be expressed as R:G:B "
-"triplet."
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-msgid ""
-"Ending color for custom color gradient. Must be expressed as R:G:B triplet"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
-msgid "Misc"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
-msgid "Select x11 display monitor for legend"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
-msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
-msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
-msgid ""
-"Root for the name of psmap instruction files to be in current directory (if "
-"not set, no psmap instruction files will be created)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
-msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
-msgid "Create graphic legend in x11 display monitor"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
-msgid "Only draw fills (no outlines) for areas and points"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
-msgid "Update color values to GRASSRGB column in attribute table"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
-msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
-msgid "Use math notation brackets in legend"
-msgstr ""
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
-msgid "Drops a column from selected attribute table"
-msgstr ""
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/g.mremove_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
-msgstr ""
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
-msgid "Table from which to drop attribute column"
-msgstr ""
-#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
-msgid "Name of the column"
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-msgid "Drops an attribute table."
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-msgid "Table to drop"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-msgid "Imports attribute tables in various formats."
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-msgid "Table file to be imported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-msgid "Table name of SQL DB table"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Name for output table"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-msgid "Name for auto-generated unique key column"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-msgid "GRASS table name"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-msgid "Table file to be exported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-msgid "Table format"
-msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-msgid "Test name"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Display the HTML man pages of GRASS"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-msgid "general, manual, help"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "Display index"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "Display as MAN text page instead of HTML page in browser"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Manual entry to be displayed"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:1
-msgid "Apply regular expressions and wildcards to g.list"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:2
-#: ../locale/scriptstrings/g.mremove_to_translate.c:2
-#: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:39
-#: ../general/manage/cmd/list.c:41 ../general/manage/cmd/remove.c:99
-msgid "general, map management"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:3
-#: ../locale/scriptstrings/g.mremove_to_translate.c:3
-msgid "Use regular expression instead of wildcard"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:4
-msgid "Print mapset name"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:5
-msgid "Data type"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:6
-msgid "Mapset(s) to list (default: current mapset search path)"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:7
-msgid "Output separator (default: newline)"
-msgstr ""
-#: ../locale/scriptstrings/g.mlist_to_translate.c:8
-msgid "Map name search pattern (default: all)"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:1
-msgid "Apply regular expressions and wildcards to g.remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:5
-msgid "Raster to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:6
-msgid "3d raster to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:7
-msgid "Vector to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:8
-msgid "Region to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:9
-msgid "Icon to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:10
-msgid "Label to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:11
-msgid "3dview to remove"
-msgstr ""
-#: ../locale/scriptstrings/g.mremove_to_translate.c:12
-msgid "Group to remove"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
-msgid "raster, imagery, fusion"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
-msgid "sensor: LANDSAT"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:4
-msgid "sensor: QuickBird"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:5
-msgid "sensor: SPOT"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:6
-msgid "raster input map (green: tm2 | qbird_green | spot1)"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:7
-msgid "raster input map (NIR: tm4 | qbird_nir | spot2)"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:8
-msgid "raster input map (MIR; tm5 | qbird_red | spot3)"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
-msgid "raster input map (etmpan | qbird_pan | spotpan)"
-msgstr ""
-#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
-msgid "raster output map prefix (e.g. 'brov')"
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-msgid "raster, imagery, mosaicking"
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-msgid "1st map for mosaic (top of image stack)."
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "2nd map for mosaic."
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:5
-msgid "3rd map for mosaic."
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:6
-msgid "4th map for mosaic."
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-msgid "Import of SPOT VGT NDVI file into a raster map"
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-msgid "raster, imagery, import"
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-msgid "also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
-msgid "Auto-balancing of colors for LANDSAT images"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-msgid "raster, imagery, colors"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-msgid "LANDSAT red channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
-msgid "LANDSAT green channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
-msgid "LANDSAT blue channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
-msgid "Cropping intensity (upper brightness level)"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
-msgid "Extend colors to full range of data on each channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
-msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-msgid "Reset to standard color range"
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-msgid "raster, imagery, statistics"
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "LANDSAT TM band 1."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-msgid "LANDSAT TM band 2."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-msgid "LANDSAT TM band 3."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:6
-msgid "LANDSAT TM band 4."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "LANDSAT TM band 5."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:8
-msgid "LANDSAT TM band 7."
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:9
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:3
-#: ../general/g.region/main.c:130
-msgid "Print in shell script style"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"displays spectral response at user specified locations in group or images"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-msgid "imagery, raster, multispectral"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-msgid "group input"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-msgid "raster input maps"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-msgid "write output to PNG image"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-msgid "Use image list and not group"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-msgid "Select multiple points"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-msgid "label with coordinates instead of numbering"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-msgid "raster, imagery"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-msgid "use transformation rules for LANDSAT-4"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-msgid "use transformation rules for LANDSAT-5"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-msgid "use transformation rules for LANDSAT-7"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "raster input map (LANDSAT channel 1)"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid "raster input map (LANDSAT channel 2)"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-msgid "raster input map (LANDSAT channel 3)"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "raster input map (LANDSAT channel 4)"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid "raster input map (LANDSAT channel 5)"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-msgid "raster input map (LANDSAT channel 7)"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-msgid "raster output TC maps prefix"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous, projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:3
-msgid "Input coordinate file (omit to read from stdin)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-msgid "Field separator"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid ""
-"Output long/lat in decimal degrees or other projections with many decimal "
-"places"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
#: ../raster/r.describe/main.c:59 ../raster/r.rescale.eq/main.c:52
#: ../raster/r.surf.area/main.c:88 ../raster/r.coin/cmd_parms.c:42
#: ../raster/r.out.png/r.out.png.c:136 ../raster/r.distance/main.c:38
@@ -2551,7 +1517,7 @@
#: ../raster/r.patch/main.c:54 ../raster/r.le/r.le.setup/main.c:61
#: ../raster/r.le/r.le.pixel/main.c:45 ../raster/r.le/r.le.trace/main.c:57
#: ../raster/r.le/r.le.patch/main.c:47 ../raster/r.digit/main.c:45
-#: ../raster/r.grow2/main.c:127 ../raster/r.circle/dist.c:51
+#: ../raster/r.grow2/main.c:128 ../raster/r.circle/dist.c:51
#: ../raster/r.surf.idw/main.c:69 ../raster/r.thin/main.c:55
#: ../raster/r.surf.contour/main.c:50 ../raster/r.topidx/main.c:37
#: ../raster/r.out.pov/main.c:121 ../raster/r.covar/main.c:53
@@ -2575,1181 +1541,12 @@
#: ../raster/r.recode/main.c:42 ../raster/r.gwflow/main.c:223
#: ../raster/wildfire/r.ros/main.c:212
#: ../raster/wildfire/r.spreadpath/main.c:72
-#: ../raster/wildfire/r.spread/main.c:103 ../raster/r.resample/main.c:54
+#: ../raster/wildfire/r.spread/main.c:101 ../raster/r.resample/main.c:54
#: ../raster/r.in.arc/main.c:59 ../raster/r.bitpattern/main.c:62
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:153
msgid "raster"
msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-msgid "Name of first raster map for blending"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-msgid "Name of second raster map for blending"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-msgid "Base name for red, green and blue output maps containing the blend"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-msgid "Percentage weight of first map for color blending"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-msgid "raster, elevation, interpolation"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-msgid "Raster map in which to fill nulls"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-msgid ""
-"Output raster map with nulls filled by interpolation from surrounding values"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-msgid "Spline tension parameter"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline smoothing parameter"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-msgid "Input ASTER image to be georeferenced & rectified"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-msgid "Import SRTM HGT files into GRASS"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
-#: ../raster/r.in.poly/main.c:29
-msgid "raster, import"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-msgid "SRTM input tile (file without .hgt.zip extension)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-msgid "Output raster map (default: input tile)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr ""
-msgid "Downloads and imports data from WMS servers."
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-msgid "wms"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../vector/v.in.dxf/main.c:66
-msgid "List available layers and exit"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:49
-msgid "Request"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Skip to downloading (to resume downloads faster)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:42
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:44
-msgid "Download"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-msgid "Don't request transparent data"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-msgid "Clean existing data out of download directory"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../raster/r.in.gdal/main.c:140
-msgid "Keep band numbers instead of using band color names"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:46
-msgid "Import"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-msgid "Don't reproject the data, just patch it"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid "Use GET method instead of POST data method"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-msgid "This may be needed to connect to servers which lack POST capability"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-msgid "Mapserver to request data from"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-msgid "Layers to request from map server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-msgid "Styles to request from map server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-msgid "Source projection to request from server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-msgid "Image format requested from the server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid "Addition query options for server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-msgid "Maximum columns to request at a time"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-msgid "Maximum rows to request at a time"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "Additional options for r.tileset"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Folder to save downloaded data to"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:41
-msgid "Additional options for wget"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:43
-msgid "Additional options for curl"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:45
-msgid "Reprojection method to use"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:47
-msgid "Filename to save capabilities XML file to"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:48
-msgid "Requires list available layers flag"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:50
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Verbosity level"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
-msgid "Calculate new raster map from a r.mapcalc expression."
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:2
-msgid "A"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:3
-msgid "B"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:4
-msgid "C"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:5
-msgid "D"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:6
-msgid "E"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:7
-msgid "F"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:8
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:8
-msgid "Formula (e.g. A-B or A*C+B)"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
-msgid "Show help"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r.mapcalc expressions)"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:12
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:12
-msgid "Do not overwrite existing map"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Create a MASK for limiting raster operation"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-msgid "raster, mask"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-msgid "Raster map to use as MASK"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-msgid "Create inverse MASK from specified 'maskcats' list"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Overwrite existing MASK"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Remove existing MASK (overrides other options)"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
-msgid "Exports GRASS raster into GDAL supported formats."
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.gdal/main.c:394
-#: ../raster/r.out.mat/main.c:64 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.tiff/r.out.tiff.c:99
-msgid "raster, export"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:3
-#: ../raster/r.out.gdal/main.c:398
-msgid "List supported output formats"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:4
-msgid "Region sensitive output"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
-#: ../raster/r.out.gdal/main.c:410
-msgid "GIS format to write (case sensitive, see also -l flag)"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
-#: ../raster/r.out.gdal/main.c:431
-msgid "File type"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
-#: ../raster/r.out.mpeg/main.c:406
-msgid "Name for output file"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
-#: ../raster/r.out.gdal/main.c:453
-msgid "Metadata key passed on the output dataset if possible"
-msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#: ../raster/r.stats/main.c:103
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:2
-msgid "raster, elevation"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-msgid "Name of raster plane to be created"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane. Value must be between -90 and 90 degrees"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane. Value must be between 0 and 360 degrees"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:9
-msgid "Type of the raster map to be created"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-msgid "raster, statistics, aggregation"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-msgid "lesser val option that sets the <= area size limit [hectares]"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-msgid "greater val option that sets the >= area size limit [hectares]"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-msgid "reclass raster output map"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:1
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:2
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
-#: ../raster/r.statistics/main.c:42 ../raster/r.report/main.c:27
-#: ../raster/r.quantile/main.c:230 ../raster/r.stats/main.c:92
-#: ../raster/r.univar2/r.univar_main.c:75
-msgid "raster, statistics"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:4
-msgid "Slower but accurate (applies to FP maps only)"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:5
-msgid "Map for x coefficient"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:6
-msgid "Map for y coefficient"
-msgstr ""
-#: ../locale/scriptstrings/r.regression.line_to_translate.c:7
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
-#: ../raster/r.topidx/main.c:42
-msgid "Input elevation map"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
-msgid "Output shaded relief map name"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:6
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:7
-msgid "Factor for exaggerating relief"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
-msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-msgid "raster, tiling"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-msgid "Produces shell script output"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces web map server query string output"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Conversion factor from units to meters in source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-msgid "Destination projection, defaults to this location's projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Maximum number of columns for a tile in the source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-msgid "Maximum number of rows for a tile in the source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Number of cells tiles should overlap in each direction"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-msgid "Output field seperator"
-msgstr ""
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
-msgid "calculates univariate statistics from a GRASS raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
-msgid "extended statistics (quartiles and percentile)"
-msgstr ""
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:4
-#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
-msgid "Name of raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
-msgid "Percentile to calculate (requires -e flag)"
-msgstr ""
-msgid "Calculates new grid3D volume from r3.mapcalc expression."
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:2
-msgid "A (grid3D file)"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:3
-msgid "B (grid3D file)"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:4
-msgid "C (grid3D file)"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:5
-msgid "D (grid3D file)"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:6
-msgid "E (grid3D file)"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:7
-msgid "F (grid3D file)"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
-msgid "Name for output grid3D volume"
-msgstr ""
-#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:11
-msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
-#: ../vector/v.out.ascii/out.c:43 ../vector/v.sample/main.c:86
-#: ../vector/v.in.region/main.c:38 ../vector/v.info/main.c:64
-#: ../vector/v.info/main.c:248 ../vector/v.patch/main.c:68
-#: ../vector/v.vol.rst/main.c:202 ../vector/v.mkgrid/main.c:62
-#: ../vector/v.clean/test/topocheck.c:40 ../vector/v.voronoi/dt_main.c:46
-#: ../vector/v.voronoi/vo_main.c:119 ../vector/v.out.vtk/main.c:45
-#: ../vector/v.select/main.c:132 ../vector/v.surf.rst/main.c:160
-#: ../vector/v.buffer/main.c:254 ../vector/v.extract/main.c:75
-msgid "vector"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-msgid "Adds missing centroids to closed boundaries."
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-msgid "vector, centroid, area"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-msgid "Name of input vector map"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:6
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-msgid "Name for output vector map"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-msgid "Action to be taken"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-#: ../vector/v.out.vtk/main.c:82
-msgid "Layer number"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-msgid "Category number starting value"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:8
-#: ../vector/v.category/main.c:104
-msgid "Category increment"
-msgstr ""
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-"format"
-msgstr ""
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
-#: ../vector/v.in.ogr/main.c:102 ../vector/v.in.dwg/main.c:65
-#: ../vector/v.in.db/main.c:52
-msgid "vector, import"
-msgstr ""
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-msgid "run non-interactively"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:115
-#: ../vector/v.db.select/main.c:48 ../vector/v.to.db/main.c:32
-msgid "vector, database, attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
-msgid "Vector map for which to edit attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
-msgid "Layer where to add column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and adds a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-msgid "Vector map for which to add new attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-msgid "Layer where to add new attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-msgid "Allows to join a table to a vector map table."
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-msgid "Vector map to which to join other table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-msgid "Layer where to join"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-msgid "Join column in map table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "Other table name"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-msgid "Join column in other table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
-msgid "Vector map for which to drop attribute column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
-msgid "Layer where to drop column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-msgid "Removes existing attribute table of a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-msgid "Vector map from which to remove attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-msgid "Layer from which to drop linked attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
-msgid "Vector map for which to rename attribute column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
-msgid "Layer where to rename column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid "Reconnects vectors to a new database."
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-msgid ""
-"Name of old database. The database must be in form printed by v.db.connect -"
-"g, i.e. with substituted variables"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-msgid "Name of new database"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Old schema"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-msgid "New schema"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
-#: ../vector/lidar/v.outlier/main.c:66 ../vector/v.univar/main.c:64
-#: ../vector/v.class/main.c:45 ../vector/v.qcount/main.c:69
-#: ../vector/v.random/main.c:84 ../vector/v.kcv/main.c:76
-#: ../vector/v.normal/main.c:79
-msgid "vector, statistics"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:3
-msgid "Extended statistics (quartiles and 90th percentile)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
-msgid "Name of data table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
-msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
-msgid "Database/directory for table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
-msgid "Database driver"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-msgid "Vector map to edit the attribute table for"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid "Layer to which the table to be changed is connected"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-msgid "Column to update"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with (varchar values have to be in single quotes, "
-"e.g. 'grass')"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid "Column to query"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-msgid "vector, area, dissolve"
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-msgid "Layer number. If -1, all layers are extracted"
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid "Name of column used to dissolve common boundaries"
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-msgid "Import E00 file into a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:3
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:3
-#: ../raster/r.out.mat/main.c:81 ../raster/r.in.mat/main.c:115
-#: ../raster/r.out.tiff/r.out.tiff.c:136
-msgid "Verbose mode"
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00 file"
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-msgid "Input type point, line or area"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:1
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
-msgid "vector, import, GPS"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
-msgid "Download Waypoints from GPS"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:5
-msgid "Download Routes from GPS"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:6
-msgid "Download Track from GPS"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:7
-msgid "Force import of track or route data as points"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:8
-msgid "Use gardump instead of gpstrans as the download program"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:9
-msgid "Import track in 3D (gardump only)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:10
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:8
-msgid "Do not attempt projection transform from WGS84"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.garmin_to_translate.c:12
-msgid "Port Garmin receiver is connected to"
-msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-msgid "Imports geonames.org country files into a GRASS vector points map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-msgid "vector, import, gazetteer"
-msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-msgid "Uncompressed geonames file from (with .txt extension)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-msgid "Uncompressed GNS file from NGA (with .txt extension)"
-msgstr ""
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
-msgid "Import waypoints"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:5
-msgid "Import routes"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:6
-msgid "Import track"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:7
-msgid "Force vertices of track or route data as points"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:9
-msgid "Device or file used to import data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
-msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Import Mapgen or Matlab vector maps into GRASS."
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-msgid "Input map is in Matlab format"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Name of input file in Mapgen/Matlab format"
-msgstr ""
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-msgid "sites, vector, import"
-msgstr ""
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-msgid "Run non-interactively"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "import GetFeature from WFS"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-msgid "GetFeature URL starting with http"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-msgid "Vector output map"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a GRASS raster map based on vector "
-"polygons and uploads statistics to new attribute columns."
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-msgid "vector, raster, statistics"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-msgid "Continue if upload column(s) already exist"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../raster/r.univar2/r.univar_main.c:49
-#: ../raster/r.univar2/r3.univar_main.c:48 ../vector/v.univar/main.c:100
-msgid "Calculate extended statistics"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-msgid "Name of vector polygon map"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid "Name of raster map to calculate statistics from"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-msgid "Column prefix for new attribute columns"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-#: ../raster/r.univar2/r.univar_main.c:40
-#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:92
-msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vectors."
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-msgid "vector, report, statistics"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-msgid "Reverse sort the result"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-msgid "Sort the result"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Value to calculate"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),p(ercent)"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-msgid "Points vector map to modify"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-msgid "Layer in the vector to be modified"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-msgid "Column to be updated with the query result"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-msgid "Vector map to be queried"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-msgid "Layer of the query vector containg data"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-msgid "Column to be queried"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-msgid "Maximum query distance in map units"
-msgstr ""
#: ../raster/r.describe/main.c:61
msgid "Prints terse list of category values found in a raster map layer."
msgstr ""
@@ -3785,10 +1582,10 @@
#: ../raster/r.describe/main.c:107 ../raster/r.coin/cmd_parms.c:79
#: ../raster/r.distance/parse.c:64 ../raster/r.carve/main.c:116
#: ../raster/r.compress/main.c:82 ../raster/r.covar/main.c:67
-#: ../raster/r.colors/main.c:224 ../raster/r.out.ppm/main.c:69
+#: ../raster/r.colors/main.c:234 ../raster/r.out.ppm/main.c:69
#: ../raster/r.neighbors/main.c:161 ../raster/r.clump/main.c:69
#: ../raster/r.out.ppm3/main.c:90 ../raster/r.contour/main.c:135
-#: ../raster/r.cross/main.c:89 ../raster/r.series/main.c:130
+#: ../raster/r.cross/main.c:89 ../raster/r.series/main.c:150
#: ../raster/r.buffer/main.c:91 ../imagery/i.smap/shapiro/parse.c:42
#: ../imagery/i.maxlik/main.c:89
msgid "Run quietly"
@@ -3800,10 +1597,10 @@
#: ../raster/r.texture/main.c:218 ../raster/r.compress/main.c:90
#: ../raster/r.patch/main.c:88 ../raster/r.covar/main.c:75
#: ../raster/r.rescale/main.c:103 ../raster/r.slope.aspect/main.c:325
-#: ../raster/r.colors/main.c:233 ../raster/r.random.surface/init.c:109
+#: ../raster/r.colors/main.c:243 ../raster/r.random.surface/init.c:109
#: ../raster/r.neighbors/main.c:274 ../raster/r.clump/main.c:78
#: ../raster/r.to.vect/main.c:97 ../raster/r.out.ppm3/main.c:102
-#: ../raster/r.cross/main.c:96 ../raster/r.series/main.c:142
+#: ../raster/r.cross/main.c:96 ../raster/r.series/main.c:162
#: ../raster/r.resample/main.c:90 ../raster/r.buffer/main.c:100
#: ../vector/v.qcount/main.c:117 ../vector/v.mkgrid/main.c:125
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:328
@@ -3849,8 +1646,8 @@
msgstr ""
#: ../raster/r.rescale.eq/main.c:98 ../raster/r.texture/main.c:108
-#: ../raster/r.patch/main.c:73 ../raster/r.grow2/main.c:166
-#: ../raster/r.report/parse.c:93 ../raster/r.kappa/main.c:87
+#: ../raster/r.patch/main.c:73 ../raster/r.grow2/main.c:167
+#: ../raster/r.report/parse.c:95 ../raster/r.kappa/main.c:87
#: ../raster/r.slope.aspect/main.c:287 ../raster/r.mfilter.fp/main.c:91
#: ../raster/r.mfilter/main.c:84 ../raster/r.resample/main.c:79
#: ../raster/r.bitpattern/main.c:87 ../vector/v.perturb/main.c:117
@@ -3883,7 +1680,7 @@
msgid "Aggregation method"
msgstr ""
-#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:134
+#: ../raster/r.resamp.stats/main.c:277 ../raster/r.series/main.c:154
msgid "Propagate NULLs"
msgstr ""
@@ -3891,7 +1688,7 @@
msgid "Weight according to area (slower)"
msgstr ""
-#: ../raster/r.resamp.stats/main.c:290 ../raster/r.series/main.c:154
+#: ../raster/r.resamp.stats/main.c:290 ../raster/r.series/main.c:97
#, c-format
msgid "Unknown method <%s>"
msgstr ""
@@ -3904,7 +1701,7 @@
#: ../raster/r.null/null.c:298 ../raster/r.lake/main.c:258
#: ../raster/r.lake/main.c:269 ../raster/r.out.gdal/main.c:104
#: ../raster/r.surf.idw2/read_cell.c:34 ../raster/r.out.mat/main.c:108
-#: ../raster/r.to.rast3elev/main.c:160 ../raster/r.grow2/main.c:202
+#: ../raster/r.to.rast3elev/main.c:160 ../raster/r.grow2/main.c:203
#: ../raster/r.surf.idw/main.c:136 ../raster/r.thin/io.c:100
#: ../raster/r.out.pov/main.c:178 ../raster/r.covar/main.c:98
#: ../raster/r.out.arc/main.c:118 ../raster/r.random/count.c:24
@@ -3928,13 +1725,13 @@
#: ../raster/wildfire/r.ros/main.c:507 ../raster/wildfire/r.ros/main.c:515
#: ../raster/wildfire/r.ros/main.c:523 ../raster/wildfire/r.ros/main.c:532
#: ../raster/wildfire/r.ros/main.c:540 ../raster/wildfire/r.ros/main.c:549
-#: ../raster/wildfire/r.spread/main.c:453
-#: ../raster/wildfire/r.spread/main.c:460
-#: ../raster/wildfire/r.spread/main.c:467
-#: ../raster/wildfire/r.spread/main.c:476
-#: ../raster/wildfire/r.spread/main.c:483
-#: ../raster/wildfire/r.spread/main.c:489
-#: ../raster/wildfire/r.spread/main.c:561 ../raster/r.buffer/read_map.c:42
+#: ../raster/wildfire/r.spread/main.c:411
+#: ../raster/wildfire/r.spread/main.c:415
+#: ../raster/wildfire/r.spread/main.c:419
+#: ../raster/wildfire/r.spread/main.c:425
+#: ../raster/wildfire/r.spread/main.c:430
+#: ../raster/wildfire/r.spread/main.c:434
+#: ../raster/wildfire/r.spread/main.c:503 ../raster/r.buffer/read_map.c:42
#: ../raster/r.buffer/write_map.c:45 ../raster/r.bitpattern/main.c:108
#: ../raster/r.to.rast3/main.c:366 ../vector/v.what.rast/main.c:141
#: ../vector/v.extrude/main.c:182 ../vector/v.sample/main.c:161
@@ -3947,7 +1744,7 @@
#: ../display/d.rast.edit/cell.c:92 ../display/d.profile/ExtractProf.c:93
#: ../display/d.profile/What.c:23 ../display/d.rast.num/number.c:153
#: ../display/d.what.rast/opencell.c:24 ../display/d.rast.arrow/arrow.c:380
-#: ../display/d.rast/display.c:76 ../display/d.rgb/main.c:105
+#: ../display/d.rast/display.c:79 ../display/d.rgb/main.c:105
#: ../display/d.his/main.c:141 ../display/d.his/main.c:164
#: ../display/d.nviz/main.c:186
#, c-format
@@ -3955,7 +1752,7 @@
msgstr ""
#: ../raster/r.resamp.stats/main.c:374 ../raster/r.resamp.interp/main.c:320
-#: ../raster/r.colors/main.c:349
+#: ../raster/r.colors/main.c:365
#, c-format
msgid "Unable to read color table for %s"
msgstr ""
@@ -4299,11 +2096,6 @@
msgid "Invalid method: %s"
msgstr ""
-#: ../raster/r.coin/print_coin.c:44
-#, c-format
-msgid "Preparing report ..."
-msgstr ""
#: ../raster/r.coin/inter.c:35
msgid "GIS Coincidence Tabulation Facility\n"
msgstr ""
@@ -4395,6 +2187,11 @@
"Do you wish to run this report with a different unit of measure? (y/n) [y] "
msgstr ""
+#: ../raster/r.coin/print_coin.c:44
+#, c-format
+msgid "Preparing report ..."
+msgstr ""
#: ../raster/r.coin/cmd_parms.c:44
msgid ""
"Tabulates the mutual occurrence (coincidence) of categories for two raster "
@@ -4521,12 +2318,12 @@
#: ../raster/r.watershed/shed/com_line.c:263
#: ../raster/r.watershed/seg/init_vars.c:417
#: ../raster/r.water.outlet/legal.c:10 ../raster/r.walk/main.c:531
-#: ../raster/r.recode/main.c:85 ../raster/wildfire/r.spread/main.c:407
-#: ../raster/wildfire/r.spread/main.c:421
-#: ../raster/wildfire/r.spread/main.c:436 ../raster/r.buffer/main.c:120
+#: ../raster/r.recode/main.c:85 ../raster/wildfire/r.spread/main.c:380
+#: ../raster/wildfire/r.spread/main.c:389
+#: ../raster/wildfire/r.spread/main.c:399 ../raster/r.buffer/main.c:120
#: ../raster/r.bitpattern/main.c:104 ../vector/v.to.rast3/main.c:69
#: ../vector/v.edit/main.c:86 ../vector/v.kernel/main.c:263
-#: ../vector/v.in.ogr/main.c:330 ../vector/v.surf.idw/main.c:123
+#: ../vector/v.in.ogr/main.c:330 ../vector/v.surf.idw/main.c:131
#: ../doc/raster/r.example/main.c:114 ../imagery/i.ifft/ifftmain.c:110
#: ../imagery/i.zc/main.c:119
#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:11
@@ -4554,25 +2351,6 @@
msgid "Calculating surface %d (of %d)"
msgstr ""
-#: ../raster/r.reclass/reclass.c:49 ../raster/r.reclass/reclass.c:109
-msgid "Too many categories"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:214
-#, c-format
-msgid "Cannot read header file of <%s@%s>"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:229
-#, c-format
-msgid "Cannot create reclass file of <%s>"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:242
-#, c-format
-msgid "Cannot create category file of <%s>"
-msgstr ""
#: ../raster/r.reclass/main.c:51
msgid ""
"Creates a new map layer whose category values are based upon a "
@@ -4664,6 +2442,25 @@
msgid "%f rounded up to %d\n"
msgstr ""
+#: ../raster/r.reclass/reclass.c:49 ../raster/r.reclass/reclass.c:109
+msgid "Too many categories"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:214
+#, c-format
+msgid "Cannot read header file of <%s@%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:229
+#, c-format
+msgid "Cannot create reclass file of <%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:242
+#, c-format
+msgid "Cannot create category file of <%s>"
+msgstr ""
#: ../raster/r.los/main.c:83
msgid "Line-of-sight raster analysis program."
msgstr ""
@@ -4786,7 +2583,7 @@
#: ../raster/r.drain/main.c:215 ../raster/r.carve/main.c:172
#: ../raster/r.cost/main.c:301 ../raster/r.region/main.c:241
-#: ../vector/v.db.connect/main.c:119 ../vector/v.perturb/main.c:154
+#: ../vector/v.db.connect/main.c:122 ../vector/v.perturb/main.c:154
#: ../vector/v.edit/main.c:140
#: ../vector/lidar/v.lidar.edgedetection/main.c:170
#: ../vector/lidar/v.lidar.correction/main.c:147
@@ -4796,7 +2593,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:244
#: ../vector/v.net.salesman/main.c:171 ../vector/v.distance/main.c:298
#: ../vector/v.reclass/main.c:106 ../vector/v.to.points/main.c:244
-#: ../vector/v.segment/main.c:99 ../vector/v.db.select/main.c:93
+#: ../vector/v.segment/main.c:99 ../vector/v.db.select/main.c:119
#: ../vector/v.univar/main.c:115 ../vector/v.class/main.c:95
#: ../vector/v.what.rast/main.c:119 ../vector/v.build.polylines/main.c:139
#: ../vector/v.net.iso/main.c:187 ../vector/v.extrude/main.c:142
@@ -4811,7 +2608,7 @@
#: ../vector/v.out.dxf/main.c:69 ../vector/v.normal/main.c:128
#: ../vector/v.voronoi/dt_main.c:77 ../vector/v.voronoi/vo_main.c:157
#: ../vector/v.what/main.c:147 ../vector/v.hull/main.c:315
-#: ../vector/v.out.svg/main.c:128 ../vector/v.to.db/parse.c:120
+#: ../vector/v.out.svg/main.c:127 ../vector/v.to.db/parse.c:120
#: ../vector/v.select/main.c:188 ../vector/v.net.alloc/main.c:143
#: ../vector/v.label/main.c:270 ../vector/v.type/main.c:202
#: ../vector/v.surf.rst/main.c:517 ../vector/v.to.rast/vect2rast.c:37
@@ -4822,12 +2619,13 @@
#: ../vector/v.lrs/v.lrs.create/main.c:256
#: ../vector/v.lrs/v.lrs.where/main.c:127
#: ../vector/v.lrs/v.lrs.where/main.c:135 ../vector/v.buffer/main.c:365
-#: ../vector/v.extract/main.c:145 ../doc/vector/v.example/main.c:73
-#: ../visualization/nviz2/cmd/vector.c:78 ../display/d.what.vect/main.c:148
+#: ../vector/v.extract/main.c:185 ../doc/vector/v.example/main.c:73
+#: ../visualization/nviz2/cmd/vector.c:83 ../display/d.what.vect/main.c:148
#: ../display/d.vect/main.c:480 ../display/d.vect.chart/main.c:246
-#: ../display/d.thematic.area/main.c:212 ../display/d.extract/main.c:98
+#: ../display/d.thematic.area/main.c:211 ../display/d.extract/main.c:98
#: ../display/d.zoom/main.c:245 ../display/d.extend/main.c:97
-#: ../display/d.path/main.c:193 ../general/g.region/main.c:519
+#: ../display/d.path/main.c:193 ../general/g.region/main.c:518
+#: ../general/g.mremove/do_remove.c:34
#, c-format
msgid "Vector map <%s> not found"
msgstr ""
@@ -4923,7 +2721,7 @@
#: ../raster/r.in.ascii/main.c:85 ../raster/r.in.bin/main.c:166
#: ../raster/r.in.gdal/main.c:114 ../raster/r.in.poly/main.c:43
-#: ../raster/r.in.arc/main.c:87
+#: ../raster/r.in.arc/main.c:87 ../raster/r.external/main.c:536
msgid "Title for resultant raster map"
msgstr ""
@@ -4955,7 +2753,7 @@
#: ../raster/r.resamp.rst/main.c:619 ../raster/r.resamp.rst/main.c:631
#: ../raster/r.resamp.rst/main.c:644 ../raster/r.resamp.rst/main.c:658
#: ../raster/r.resamp.rst/main.c:671 ../raster/r.resamp.rst/main.c:684
-#: ../raster/r.in.arc/main.c:114 ../vector/v.in.ascii/in.c:239
+#: ../raster/r.in.arc/main.c:114 ../vector/v.in.ascii/in.c:242
#: ../vector/v.surf.rst/main.c:597 ../vector/v.surf.rst/main.c:606
#: ../vector/v.surf.rst/main.c:615 ../vector/v.surf.rst/main.c:625
#: ../vector/v.surf.rst/main.c:634 ../vector/v.surf.rst/main.c:643
@@ -5009,6 +2807,12 @@
msgid "Unable to write to file"
msgstr ""
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.gdal/main.c:394
+#: ../raster/r.out.mat/main.c:64 ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.tiff/r.out.tiff.c:99
+msgid "raster, export"
+msgstr ""
#: ../raster/r.out.ascii/main.c:61
msgid "Converts a raster map layer into an ASCII text file."
msgstr ""
@@ -5062,7 +2866,7 @@
#: ../raster/r.out.ascii/main.c:172 ../raster/r.profile/main.c:157
#: ../raster/r.out.arc/main.c:135 ../raster/r.out.ppm3/main.c:149
#: ../raster/r.cats/main.c:177 ../vector/v.out.ascii/out.c:143
-#: ../vector/v.out.vtk/main.c:164 ../display/d.nviz/main.c:203
+#: ../vector/v.out.vtk/main.c:176 ../display/d.nviz/main.c:203
#: ../general/g.pnmcomp/main.c:241 ../general/g.pnmcomp/main.c:258
#, c-format
msgid "Unable to open file <%s>"
@@ -5079,7 +2883,7 @@
msgstr ""
#: ../raster/r.carve/raster.c:12 ../raster/r.texture/main.c:258
-#: ../raster/r.out.tiff/r.out.tiff.c:283 ../imagery/i.zc/main.c:169
+#: ../raster/r.out.tiff/r.out.tiff.c:283 ../imagery/i.zc/main.c:167
msgid "Reading raster map..."
msgstr ""
@@ -5257,35 +3061,12 @@
msgid "Endpoint coordinates are outside of current region settings"
msgstr ""
-#: ../raster/r.texture/h_measure.c:84
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
-msgstr ""
-#: ../raster/r.texture/h_measure.c:88
-#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-#: ../raster/r.texture/h_measure.c:758 ../raster/r.cost/main.c:603
-#: ../imagery/i.smap/bouman/interp.c:69
-msgid "Unable to allocate memory"
-msgstr ""
-#: ../raster/r.texture/h_measure.c:927
-#, c-format
-msgid "Too many iterations to required to find %s - giving up"
-msgstr ""
#: ../raster/r.texture/main.c:73
msgid "Generate images with textural features from a raster map."
msgstr ""
#: ../raster/r.texture/main.c:84
-msgid "Prefix for ouput raster map(s)"
+msgid "Prefix for output raster map(s)"
msgstr ""
#: ../raster/r.texture/main.c:91
@@ -5378,6 +3159,29 @@
msgid "Calculated measure #%d (56 measures available)"
msgstr ""
+#: ../raster/r.texture/h_measure.c:84
+msgid ""
+"Negative or no data pixel found. This module is not yet able to process no "
+"data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:88
+#, c-format
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:758 ../raster/r.cost/main.c:603
+#: ../imagery/i.smap/bouman/interp.c:69
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:927
+#, c-format
+msgid "Too many iterations to required to find %s - giving up"
+msgstr ""
#: ../raster/r.basins.fill/main.c:55
msgid "Generates a raster map layer showing watershed subbasins."
msgstr ""
@@ -5426,7 +3230,7 @@
msgstr ""
#: ../raster/r.sum/main.c:74 ../raster/r.walk/main.c:682
-#: ../raster/r.walk/main.c:744 ../raster/wildfire/r.spread/main.c:574
+#: ../raster/r.walk/main.c:744 ../raster/wildfire/r.spread/main.c:514
#, c-format
msgid "Reading %s..."
msgstr ""
@@ -5455,27 +3259,27 @@
#: ../raster/r.sun/main.c:245 ../raster/r.sun/main.c:257
#: ../raster/r.sun/main.c:265 ../raster/r.sun/main.c:277
#: ../raster/r.sun/main.c:284 ../raster/r.sun/main.c:296
-#: ../raster/r.sun/main.c:305 ../raster/simwe/r.sim.sediment/main.c:168
-#: ../raster/simwe/r.sim.sediment/main.c:173
-#: ../raster/simwe/r.sim.sediment/main.c:178
-#: ../raster/simwe/r.sim.sediment/main.c:183
-#: ../raster/simwe/r.sim.sediment/main.c:189
-#: ../raster/simwe/r.sim.sediment/main.c:195
-#: ../raster/simwe/r.sim.sediment/main.c:201
-#: ../raster/simwe/r.sim.sediment/main.c:207
-#: ../raster/simwe/r.sim.sediment/main.c:215
-#: ../raster/simwe/r.sim.sediment/main.c:223
-#: ../raster/simwe/r.sim.water/main.c:170
-#: ../raster/simwe/r.sim.water/main.c:175
-#: ../raster/simwe/r.sim.water/main.c:180
-#: ../raster/simwe/r.sim.water/main.c:187
-#: ../raster/simwe/r.sim.water/main.c:196
-#: ../raster/simwe/r.sim.water/main.c:203
-#: ../raster/simwe/r.sim.water/main.c:212
-#: ../raster/simwe/r.sim.water/main.c:218
-#: ../raster/simwe/r.sim.water/main.c:226
-#: ../raster/simwe/r.sim.water/main.c:233
-#: ../raster/simwe/r.sim.water/main.c:241
+#: ../raster/r.sun/main.c:305 ../raster/simwe/r.sim.sediment/main.c:119
+#: ../raster/simwe/r.sim.sediment/main.c:124
+#: ../raster/simwe/r.sim.sediment/main.c:129
+#: ../raster/simwe/r.sim.sediment/main.c:134
+#: ../raster/simwe/r.sim.sediment/main.c:140
+#: ../raster/simwe/r.sim.sediment/main.c:146
+#: ../raster/simwe/r.sim.sediment/main.c:152
+#: ../raster/simwe/r.sim.sediment/main.c:158
+#: ../raster/simwe/r.sim.sediment/main.c:166
+#: ../raster/simwe/r.sim.sediment/main.c:174
+#: ../raster/simwe/r.sim.water/main.c:125
+#: ../raster/simwe/r.sim.water/main.c:130
+#: ../raster/simwe/r.sim.water/main.c:135
+#: ../raster/simwe/r.sim.water/main.c:142
+#: ../raster/simwe/r.sim.water/main.c:151
+#: ../raster/simwe/r.sim.water/main.c:158
+#: ../raster/simwe/r.sim.water/main.c:167
+#: ../raster/simwe/r.sim.water/main.c:173
+#: ../raster/simwe/r.sim.water/main.c:181
+#: ../raster/simwe/r.sim.water/main.c:188
+#: ../raster/simwe/r.sim.water/main.c:195
#: ../raster/r.watershed/front/main.c:56 ../raster/r.watershed/front/main.c:64
#: ../raster/r.watershed/front/main.c:72 ../raster/r.watershed/front/main.c:81
#: ../raster/r.watershed/front/main.c:90 ../raster/r.watershed/front/main.c:99
@@ -5534,15 +3338,15 @@
#: ../raster/r.sun/main.c:314 ../raster/r.sun/main.c:323
#: ../raster/r.sun/main.c:332 ../raster/r.sun/main.c:341
-#: ../raster/r.sun/main.c:350 ../raster/simwe/r.sim.sediment/main.c:229
-#: ../raster/simwe/r.sim.sediment/main.c:236
-#: ../raster/simwe/r.sim.sediment/main.c:243
-#: ../raster/simwe/r.sim.sediment/main.c:249
-#: ../raster/simwe/r.sim.sediment/main.c:256
-#: ../raster/simwe/r.sim.water/main.c:247
-#: ../raster/simwe/r.sim.water/main.c:253
-#: ../raster/simwe/r.sim.water/main.c:259
-#: ../raster/simwe/r.sim.water/main.c:266 ../raster/r.resamp.rst/main.c:194
+#: ../raster/r.sun/main.c:350 ../raster/simwe/r.sim.sediment/main.c:180
+#: ../raster/simwe/r.sim.sediment/main.c:187
+#: ../raster/simwe/r.sim.sediment/main.c:194
+#: ../raster/simwe/r.sim.sediment/main.c:200
+#: ../raster/simwe/r.sim.sediment/main.c:207
+#: ../raster/simwe/r.sim.water/main.c:201
+#: ../raster/simwe/r.sim.water/main.c:207
+#: ../raster/simwe/r.sim.water/main.c:213
+#: ../raster/simwe/r.sim.water/main.c:220 ../raster/r.resamp.rst/main.c:194
#: ../raster/r.resamp.rst/main.c:202 ../raster/r.resamp.rst/main.c:210
#: ../raster/r.resamp.rst/main.c:218 ../raster/r.resamp.rst/main.c:226
#: ../raster/r.resamp.rst/main.c:290 ../raster/r.watershed/front/main.c:117
@@ -5691,7 +3495,7 @@
#: ../raster/r.sun/main.c:736 ../raster/r.sun/main.c:743
#: ../raster/r.sun/main.c:750 ../raster/r.sun/main.c:757
-#: ../raster/r.sun/main.c:764 ../raster/r.in.bin/main.c:501
+#: ../raster/r.sun/main.c:764
#, c-format
msgid "Unable to create raster map %s"
msgstr ""
@@ -5805,7 +3609,7 @@
msgid "Cover values extracted from the category labels of the cover map"
msgstr ""
-#: ../raster/r.average/main.c:82 ../raster/r.grow2/main.c:211
+#: ../raster/r.average/main.c:82 ../raster/r.grow2/main.c:212
#, c-format
msgid "Error reading category file for <%s>"
msgstr ""
@@ -5859,7 +3663,7 @@
msgstr ""
#: ../raster/r.lake/main.c:206
-msgid "Both seed map and coordinates cannot be specifed"
+msgid "Both seed map and coordinates cannot be specified"
msgstr ""
#: ../raster/r.lake/main.c:209
@@ -5871,7 +3675,7 @@
msgstr ""
#: ../raster/r.lake/main.c:215
-msgid "Both lake and overwrite cannot be specifed"
+msgid "Both lake and overwrite cannot be specified"
msgstr ""
#: ../raster/r.lake/main.c:218
@@ -5937,7 +3741,7 @@
#: ../raster/r.out.gdal/main.c:339
#, c-format
msgid ""
-"Input raster map constains cells with NULL-value (no-data). The value %d was "
+"Input raster map contains cells with NULL-value (no-data). The value %d was "
"used to represent no-data values in the input map.You can specify nodata "
"value by %s parameter."
msgstr ""
@@ -5945,7 +3749,7 @@
#: ../raster/r.out.gdal/main.c:344
#, c-format
msgid ""
-"Input raster map constains cells with NULL-value (no-data). The value %g was "
+"Input raster map contains cells with NULL-value (no-data). The value %g was "
msgstr ""
@@ -5954,18 +3758,22 @@
msgid "Exports GRASS raster map into GDAL supported formats."
msgstr ""
+#: ../raster/r.out.gdal/main.c:398
+msgid "List supported output formats"
+msgstr ""
#: ../raster/r.out.gdal/main.c:399 ../raster/r.in.gdal/main.c:135
#: ../raster/r.stats/main.c:136 ../raster/r.stats/main.c:141
#: ../raster/r.stats/main.c:146 ../raster/r.stats/main.c:152
#: ../raster/r.stats/main.c:157 ../raster/r.stats/main.c:162
#: ../raster/r.stats/main.c:167 ../raster/r.stats/main.c:172
-#: ../vector/v.to.db/parse.c:96 ../vector/v.to.db/parse.c:101
-#: ../vector/v.to.db/parse.c:107 ../imagery/i.group/main.c:78
-#: ../imagery/i.group/main.c:84 ../general/g.region/main.c:92
-#: ../general/g.region/main.c:98 ../general/g.region/main.c:103
-#: ../general/g.region/main.c:109 ../general/g.region/main.c:115
-#: ../general/g.region/main.c:120 ../general/g.region/main.c:126
-#: ../general/g.region/main.c:131
+#: ../raster/r.external/main.c:555 ../vector/v.to.db/parse.c:96
+#: ../vector/v.to.db/parse.c:101 ../vector/v.to.db/parse.c:107
+#: ../imagery/i.group/main.c:78 ../imagery/i.group/main.c:84
+#: ../general/g.region/main.c:91 ../general/g.region/main.c:97
+#: ../general/g.region/main.c:102 ../general/g.region/main.c:108
+#: ../general/g.region/main.c:114 ../general/g.region/main.c:119
+#: ../general/g.region/main.c:125 ../general/g.region/main.c:130
msgid "Print"
msgstr ""
@@ -5975,11 +3783,20 @@
#: ../raster/r.out.gdal/main.c:404 ../raster/r.out.gdal/main.c:440
#: ../raster/r.in.gdal/main.c:90 ../raster/r.in.gdal/main.c:94
-#: ../raster/r.colors/main.c:132 ../vector/v.in.ascii/in.c:57
+#: ../raster/r.colors/main.c:171 ../raster/r.external/main.c:512
+#: ../raster/r.external/main.c:522 ../vector/v.in.ascii/in.c:57
#: ../vector/v.in.ogr/main.c:115 ../vector/v.in.ogr/main.c:119
msgid "Required"
msgstr ""
+#: ../raster/r.out.gdal/main.c:410
+msgid "GIS format to write (case sensitive, see also -l flag)"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:431
+msgid "File type"
+msgstr ""
#: ../raster/r.out.gdal/main.c:439
msgid "Name for output raster file"
msgstr ""
@@ -5989,6 +3806,10 @@
"Creation option to the output format driver. Multiple options may be listed."
msgstr ""
+#: ../raster/r.out.gdal/main.c:453
+msgid "Metadata key passed on the output dataset if possible"
+msgstr ""
#: ../raster/r.out.gdal/main.c:462
msgid "Assign a specified nodata value to output bands"
msgstr ""
@@ -6065,6 +3886,11 @@
msgid "Unable to create raster map <%s> using driver <%s>"
msgstr ""
+#: ../raster/r.in.bin/main.c:122 ../raster/r.in.gdal/main.c:79
+#: ../raster/r.in.poly/main.c:29 ../raster/r.external/main.c:505
+msgid "raster, import"
+msgstr ""
#: ../raster/r.in.bin/main.c:124
msgid "Import a binary raster file into a GRASS raster map layer."
msgstr ""
@@ -6128,11 +3954,11 @@
#: ../raster/r.in.bin/main.c:150 ../raster/r.in.bin/main.c:182
#: ../raster/r.in.bin/main.c:190 ../raster/r.in.bin/main.c:198
#: ../raster/r.in.bin/main.c:206 ../raster/r.in.bin/main.c:213
-#: ../raster/r.in.bin/main.c:220 ../general/g.region/main.c:138
-#: ../general/g.region/main.c:198 ../general/g.region/main.c:208
-#: ../general/g.region/main.c:218 ../general/g.region/main.c:228
-#: ../general/g.region/main.c:237 ../general/g.region/main.c:246
-#: ../general/g.region/main.c:324 ../general/g.region/main.c:335
+#: ../raster/r.in.bin/main.c:220 ../general/g.region/main.c:137
+#: ../general/g.region/main.c:197 ../general/g.region/main.c:207
+#: ../general/g.region/main.c:217 ../general/g.region/main.c:227
+#: ../general/g.region/main.c:236 ../general/g.region/main.c:245
+#: ../general/g.region/main.c:323 ../general/g.region/main.c:334
msgid "Bounds"
msgstr ""
@@ -6172,6 +3998,14 @@
msgid "Set Value to NULL"
msgstr ""
+#: ../raster/r.in.bin/main.c:242
+msgid "Parsing bytes per cell"
+msgstr ""
+#: ../raster/r.in.bin/main.c:244
+msgid "Bad number of bytes per cell"
+msgstr ""
#: ../raster/r.in.bin/main.c:250
msgid "Byte Swapping Turned On."
msgstr ""
@@ -6182,39 +4016,78 @@
"Must provide at least[north= south= east= west=] OR [r=\tc=]"
msgstr ""
-#: ../raster/r.in.bin/main.c:293
+#: ../raster/r.in.bin/main.c:293 ../raster/r.in.bin/main.c:333
msgid "You have to provide all limits of geographic region (n,s,e,w)"
msgstr ""
-#: ../raster/r.in.bin/main.c:323
+#: ../raster/r.in.bin/main.c:295 ../raster/r.in.bin/main.c:335
+#: ../display/d.grid/main.c:181
#, c-format
+msgid "Illegal north coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:297 ../raster/r.in.bin/main.c:337
+#, c-format
+msgid "Illegal south coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:299 ../raster/r.in.bin/main.c:339
+#: ../display/d.grid/main.c:175
+#, c-format
+msgid "Illegal east coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:301 ../raster/r.in.bin/main.c:341
+#, c-format
+msgid "Illegal west coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:303 ../raster/r.in.bin/main.c:313
+#, c-format
+msgid "Illegal number of rows <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:305 ../raster/r.in.bin/main.c:316
+#, c-format
+msgid "Illegal number of columns <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:321
+#, c-format
msgid "Using N=%f S=%f E=%f W=%f"
msgstr ""
-#: ../raster/r.in.bin/main.c:350
+#: ../raster/r.in.bin/main.c:346
#, c-format
msgid "Using rows=%d cols=%d\n"
msgstr ""
-#: ../raster/r.in.bin/main.c:455 ../raster/r.in.bin/main.c:465
-#: ../raster/r.in.bin/main.c:477
+#: ../raster/r.in.bin/main.c:451 ../raster/r.in.bin/main.c:461
+#: ../raster/r.in.bin/main.c:473
msgid "Bytes do not match File size"
msgstr ""
-#: ../raster/r.in.bin/main.c:456 ../raster/r.in.bin/main.c:466
-#: ../raster/r.in.bin/main.c:478
+#: ../raster/r.in.bin/main.c:452 ../raster/r.in.bin/main.c:462
+#: ../raster/r.in.bin/main.c:474
#, c-format
msgid "File Size %d ... Total Bytes %d"
msgstr ""
-#: ../raster/r.in.bin/main.c:458 ../raster/r.in.bin/main.c:468
-#: ../raster/r.in.bin/main.c:480
+#: ../raster/r.in.bin/main.c:454 ../raster/r.in.bin/main.c:464
+#: ../raster/r.in.bin/main.c:476
#, c-format
msgid "Try bytes=%d or adjusting input parameters"
msgstr ""
-#: ../raster/r.in.bin/main.c:520
+#: ../raster/r.in.bin/main.c:510
#, c-format
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign east= and west= correctly?"
+msgstr ""
+#: ../raster/r.in.bin/main.c:518
+#, c-format
msgid "Conversion failed at row %d"
msgstr ""
@@ -6251,7 +4124,7 @@
msgstr ""
#: ../raster/r.surf.idw2/main.c:72 ../raster/r.surf.idw/main.c:81
-#: ../vector/v.surf.idw/main.c:97
+#: ../vector/v.surf.idw/main.c:98
msgid "Number of interpolation points"
msgstr ""
@@ -6260,7 +4133,7 @@
"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
msgstr ""
-#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:127
+#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:135
#, c-format
msgid "%s=%s - illegal number of interpolation points"
msgstr ""
@@ -6279,7 +4152,7 @@
msgid "Cannot get row"
msgstr ""
-#: ../raster/r.surf.idw2/read_cell.c:38 ../raster/r.series/main.c:175
+#: ../raster/r.surf.idw2/read_cell.c:38 ../raster/r.series/main.c:183
#, c-format
msgid "Reading raster map <%s>..."
msgstr ""
@@ -6339,150 +4212,150 @@
msgid "reading r.stats output"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:112
+#: ../raster/simwe/r.sim.sediment/main.c:111
msgid "raster, sediment flow, erosion, deposition"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:114
+#: ../raster/simwe/r.sim.sediment/main.c:113
msgid ""
"Sediment transport and erosion/deposition simulation using path sampling "
"method (SIMWE)"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:167
-#: ../raster/simwe/r.sim.water/main.c:169
+#: ../raster/simwe/r.sim.sediment/main.c:118
+#: ../raster/simwe/r.sim.water/main.c:124
msgid "Name of the elevation raster map [m]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:172
+#: ../raster/simwe/r.sim.sediment/main.c:123
msgid "Name of the water depth raster map [m]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:177
-#: ../raster/simwe/r.sim.water/main.c:174
+#: ../raster/simwe/r.sim.sediment/main.c:128
+#: ../raster/simwe/r.sim.water/main.c:129
msgid "Name of the x-derivatives raster map [m/m]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:182
-#: ../raster/simwe/r.sim.water/main.c:179
+#: ../raster/simwe/r.sim.sediment/main.c:133
+#: ../raster/simwe/r.sim.water/main.c:134
msgid "Name of the y-derivatives raster map [m/m]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:188
+#: ../raster/simwe/r.sim.sediment/main.c:139
msgid "Name of the detachment capacity coefficient raster map [s/m]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:194
+#: ../raster/simwe/r.sim.sediment/main.c:145
msgid "Name of the transport capacity coefficient raster map [s]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:200
+#: ../raster/simwe/r.sim.sediment/main.c:151
msgid "Name of the critical shear stress raster map [Pa]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:206
-#: ../raster/simwe/r.sim.water/main.c:217
+#: ../raster/simwe/r.sim.sediment/main.c:157
+#: ../raster/simwe/r.sim.water/main.c:172
msgid "Name of the Mannings n raster map"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:214
+#: ../raster/simwe/r.sim.sediment/main.c:165
msgid "Name of the Mannings n value"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:222
-#: ../raster/simwe/r.sim.water/main.c:240
+#: ../raster/simwe/r.sim.sediment/main.c:173
+#: ../raster/simwe/r.sim.water/main.c:194
msgid "Name of the sampling locations vector points map"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:228
+#: ../raster/simwe/r.sim.sediment/main.c:179
msgid "Output transport capacity raster map [kg/ms]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:235
+#: ../raster/simwe/r.sim.sediment/main.c:186
msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:242
+#: ../raster/simwe/r.sim.sediment/main.c:193
msgid "Output sediment concentration raster map [particle/m3]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:248
+#: ../raster/simwe/r.sim.sediment/main.c:199
msgid "Output sediment flux raster map [kg/ms]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:255
+#: ../raster/simwe/r.sim.sediment/main.c:206
msgid "Output erosion-deposition raster map [kg/m2s]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:263
+#: ../raster/simwe/r.sim.sediment/main.c:213
msgid "Number of walkers"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:264
-#: ../raster/simwe/r.sim.sediment/main.c:272
-#: ../raster/simwe/r.sim.sediment/main.c:281
-#: ../raster/simwe/r.sim.sediment/main.c:289
-#: ../raster/simwe/r.sim.sediment/main.c:297
-#: ../raster/simwe/r.sim.water/main.c:275
-#: ../raster/simwe/r.sim.water/main.c:283
-#: ../raster/simwe/r.sim.water/main.c:292
-#: ../raster/simwe/r.sim.water/main.c:300
-#: ../raster/simwe/r.sim.water/main.c:308
-#: ../raster/simwe/r.sim.water/main.c:317
-#: ../raster/simwe/r.sim.water/main.c:325
-#: ../raster/simwe/r.sim.water/main.c:334
+#: ../raster/simwe/r.sim.sediment/main.c:214
+#: ../raster/simwe/r.sim.sediment/main.c:222
+#: ../raster/simwe/r.sim.sediment/main.c:231
+#: ../raster/simwe/r.sim.sediment/main.c:239
+#: ../raster/simwe/r.sim.sediment/main.c:247
+#: ../raster/simwe/r.sim.water/main.c:228
+#: ../raster/simwe/r.sim.water/main.c:236
+#: ../raster/simwe/r.sim.water/main.c:245
+#: ../raster/simwe/r.sim.water/main.c:253
+#: ../raster/simwe/r.sim.water/main.c:261
+#: ../raster/simwe/r.sim.water/main.c:270
+#: ../raster/simwe/r.sim.water/main.c:278
+#: ../raster/simwe/r.sim.water/main.c:287
msgid "Parameters"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:271
-#: ../raster/simwe/r.sim.water/main.c:282
+#: ../raster/simwe/r.sim.sediment/main.c:221
+#: ../raster/simwe/r.sim.water/main.c:235
msgid "Time used for iterations [minutes]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:280
-#: ../raster/simwe/r.sim.water/main.c:291
+#: ../raster/simwe/r.sim.sediment/main.c:230
+#: ../raster/simwe/r.sim.water/main.c:244
msgid "Time interval for creating output maps [minutes]"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:288
-#: ../raster/simwe/r.sim.water/main.c:299
+#: ../raster/simwe/r.sim.sediment/main.c:238
+#: ../raster/simwe/r.sim.water/main.c:252
msgid "Density of output walkers"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:296
-#: ../raster/simwe/r.sim.water/main.c:307
+#: ../raster/simwe/r.sim.sediment/main.c:246
+#: ../raster/simwe/r.sim.water/main.c:260
msgid "Water diffusion constant"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:342
-#: ../raster/simwe/r.sim.water/main.c:466
+#: ../raster/simwe/r.sim.sediment/main.c:328
+#: ../raster/simwe/r.sim.water/main.c:438
msgid "More than 100 files are going to be created !!!!!"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:348
-#: ../raster/simwe/r.sim.water/main.c:472
+#: ../raster/simwe/r.sim.sediment/main.c:334
+#: ../raster/simwe/r.sim.water/main.c:444
#, c-format
msgid "default nwalk=%d, rwalk=%f"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:357
-#: ../raster/simwe/r.sim.water/main.c:482
+#: ../raster/simwe/r.sim.sediment/main.c:343
+#: ../raster/simwe/r.sim.water/main.c:454
#, c-format
msgid "Using metric conversion factor %f, step=%f"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:366
-msgid "You are not outputing any raster or site files"
+#: ../raster/simwe/r.sim.sediment/main.c:352
+msgid "You are not outputting any raster or site files"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:369
-#: ../raster/simwe/r.sim.water/main.c:494 ../vector/v.surf.rst/main.c:668
+#: ../raster/simwe/r.sim.sediment/main.c:355
+#: ../raster/simwe/r.sim.water/main.c:466 ../vector/v.surf.rst/main.c:668
#: ../vector/v.surf.rst/main.c:720
msgid "Input failed"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:428
-#: ../raster/simwe/r.sim.water/main.c:538
+#: ../raster/simwe/r.sim.sediment/main.c:414
+#: ../raster/simwe/r.sim.water/main.c:510
msgid "Cannot write raster maps"
msgstr ""
@@ -6584,69 +4457,69 @@
msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:186
+#: ../raster/simwe/r.sim.water/main.c:141
msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:195
+#: ../raster/simwe/r.sim.water/main.c:150
msgid "Rainfall excess rate unique value [mm/hr]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:202
+#: ../raster/simwe/r.sim.water/main.c:157
msgid "Name of the runoff infiltration rate raster map [mm/hr]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:211
+#: ../raster/simwe/r.sim.water/main.c:166
msgid "Runoff infiltration rate unique value [mm/hr]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:225
+#: ../raster/simwe/r.sim.water/main.c:180
msgid "Mannings n unique value"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:232
+#: ../raster/simwe/r.sim.water/main.c:187
msgid "Name of the flow controls raster map (permeability ratio 0-1)"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:246
+#: ../raster/simwe/r.sim.water/main.c:200
msgid "Output water depth raster map [m]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:252
+#: ../raster/simwe/r.sim.water/main.c:206
msgid "Output water discharge raster map [m3/s]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:258
+#: ../raster/simwe/r.sim.water/main.c:212
msgid "Output simulation error raster map [m]"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:265
+#: ../raster/simwe/r.sim.water/main.c:219
msgid "Name of the output walkers vector points map"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:274
+#: ../raster/simwe/r.sim.water/main.c:227
msgid "Number of walkers, default is twice the no. of cells"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:316
+#: ../raster/simwe/r.sim.water/main.c:269
msgid ""
"Threshold water depth [m] (diffusion increases after this water depth is "
"reached)"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:324
+#: ../raster/simwe/r.sim.water/main.c:277
msgid "Diffusion increase constant"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:333
+#: ../raster/simwe/r.sim.water/main.c:286
msgid "Weighting factor for water flow velocity vector"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:342
+#: ../raster/simwe/r.sim.water/main.c:291
msgid "Time-series output"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:491
+#: ../raster/simwe/r.sim.water/main.c:463
msgid "You are not outputting any raster or vector points maps"
msgstr ""
@@ -6658,9 +4531,14 @@
msgid "Name for the output binary MAT-File"
msgstr ""
+#: ../raster/r.out.mat/main.c:81 ../raster/r.in.mat/main.c:115
+#: ../raster/r.out.tiff/r.out.tiff.c:136
+msgid "Verbose mode"
+msgstr ""
#: ../raster/r.out.mat/main.c:90 ../raster/r.cost/main.c:226
#: ../raster/r.in.mat/main.c:125 ../raster/r.out.tiff/r.out.tiff.c:144
-#: ../raster/wildfire/r.ros/main.c:314 ../raster/wildfire/r.spread/main.c:257
+#: ../raster/wildfire/r.ros/main.c:314 ../raster/wildfire/r.spread/main.c:255
#: ../vector/v.kernel/main.c:191 ../display/d.vect/main.c:391
#: ../display/d.mon/pgms/release.c:36
msgid ""
@@ -6821,6 +4699,12 @@
msgid "%s: running %s command"
msgstr ""
+#: ../raster/r.statistics/main.c:42 ../raster/r.report/main.c:27
+#: ../raster/r.quantile/main.c:230 ../raster/r.stats/main.c:92
+#: ../raster/r.univar2/r.univar_main.c:75
+msgid "raster, statistics"
+msgstr ""
#: ../raster/r.statistics/main.c:44
msgid "Calculates category or object oriented statistics."
msgstr ""
@@ -6837,7 +4721,7 @@
msgid "This module currently only works for integer (CELL) maps"
msgstr ""
-#: ../raster/r.statistics/main.c:91 ../raster/r.report/parse.c:262
+#: ../raster/r.statistics/main.c:91 ../raster/r.report/parse.c:264
#: ../raster/r.support/front/front.c:230 ../raster/r.cats/main.c:155
#: ../raster/r.cats/main.c:213 ../raster/r.mapcalc/map3.c:186
#: ../raster/r.mapcalc/map.c:92 ../display/d.title/main.c:112
@@ -7002,7 +4886,7 @@
msgstr ""
#: ../raster/r.patch/main.c:153 ../raster/r.slope.aspect/main.c:592
-#: ../raster/r.series/main.c:201
+#: ../raster/r.series/main.c:224
msgid "Percent complete..."
msgstr ""
@@ -7114,42 +4998,42 @@
msgid "No map created"
msgstr ""
-#: ../raster/r.grow2/main.c:129
+#: ../raster/r.grow2/main.c:130
msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
-#: ../raster/r.grow2/main.c:140
+#: ../raster/r.grow2/main.c:141
msgid "Radius of buffer in raster cells"
msgstr ""
-#: ../raster/r.grow2/main.c:147
+#: ../raster/r.grow2/main.c:148
msgid "Metric"
msgstr ""
-#: ../raster/r.grow2/main.c:156
+#: ../raster/r.grow2/main.c:157
msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
msgstr ""
-#: ../raster/r.grow2/main.c:162
+#: ../raster/r.grow2/main.c:163
msgid "Value to write for \"grown\" cells"
msgstr ""
-#: ../raster/r.grow2/main.c:198
+#: ../raster/r.grow2/main.c:199
#, c-format
msgid "Unknown metric: [%s]."
msgstr ""
-#: ../raster/r.grow2/main.c:216
+#: ../raster/r.grow2/main.c:217
#, c-format
msgid "Error in reading color file for <%s>"
msgstr ""
-#: ../raster/r.grow2/main.c:300
+#: ../raster/r.grow2/main.c:301
#, c-format
msgid "Error writing category file for <%s>"
msgstr ""
-#: ../raster/r.grow2/main.c:304
+#: ../raster/r.grow2/main.c:305
#, c-format
msgid "Error writing color file for <%s>"
msgstr ""
@@ -7207,6 +5091,14 @@
msgid "Cannot read row"
msgstr ""
+#: ../raster/r.thin/main.c:57
+msgid "Thins non-zero cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../raster/r.thin/main.c:69
+msgid "Maximal number of iterations"
+msgstr ""
#: ../raster/r.thin/io.c:105
#, c-format
msgid "File %s -- %d rows X %d columns"
@@ -7238,14 +5130,6 @@
msgid "Window %d rows X %d columns"
msgstr ""
-#: ../raster/r.thin/main.c:57
-msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr ""
-#: ../raster/r.thin/main.c:69
-msgid "Maximal number of iterations"
-msgstr ""
#: ../raster/r.thin/thin_lines.c:67
#, c-format
msgid "%s: Unable to find bounding box for lines"
@@ -7545,43 +5429,6 @@
msgid "Calculates Shannon's diversity index on a raster map"
msgstr ""
-#: ../raster/r.flow/precomp.c:47
-msgid "Precomputing: e/w distances"
-msgstr ""
-#: ../raster/r.flow/precomp.c:49
-msgid "Precomputing: quantization tolerances"
-msgstr ""
-#: ../raster/r.flow/precomp.c:52
-msgid "Precomputing: inverted elevations"
-msgstr ""
-#: ../raster/r.flow/precomp.c:56
-msgid "Precomputing: interpolated border elevations"
-msgstr ""
-#: ../raster/r.flow/precomp.c:62
-msgid "Precomputing: re-oriented aspects"
-msgstr ""
-#: ../raster/r.flow/precomp.c:66
-msgid "Precomputing: aspects"
-msgstr ""
-#: ../raster/r.flow/precomp.c:110
-#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
-msgstr ""
-#: ../raster/r.flow/precomp.c:115
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
#: ../raster/r.flow/mem.c:39
#, c-format
msgid "Unable to write segment file for %s"
@@ -7655,6 +5502,43 @@
"calculating flow accumulation."
msgstr ""
+#: ../raster/r.flow/precomp.c:47
+msgid "Precomputing: e/w distances"
+msgstr ""
+#: ../raster/r.flow/precomp.c:49
+msgid "Precomputing: quantization tolerances"
+msgstr ""
+#: ../raster/r.flow/precomp.c:52
+msgid "Precomputing: inverted elevations"
+msgstr ""
+#: ../raster/r.flow/precomp.c:56
+msgid "Precomputing: interpolated border elevations"
+msgstr ""
+#: ../raster/r.flow/precomp.c:62
+msgid "Precomputing: re-oriented aspects"
+msgstr ""
+#: ../raster/r.flow/precomp.c:66
+msgid "Precomputing: aspects"
+msgstr ""
+#: ../raster/r.flow/precomp.c:110
+#, c-format
+msgid ""
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
+msgstr ""
+#: ../raster/r.flow/precomp.c:115
+#, c-format
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
+msgstr ""
#: ../raster/r.flow/io.c:66
#, c-format
msgid "Unable to get header for %s"
@@ -7696,7 +5580,7 @@
msgstr ""
#: ../raster/r.flow/io.c:170 ../vector/v.net.visibility/main.c:87
-#: ../vector/v.edit/main.c:100 ../vector/v.in.dxf/main.c:164
+#: ../vector/v.edit/main.c:100 ../vector/v.in.dxf/main.c:168
#: ../vector/lidar/v.lidar.edgedetection/main.c:175
#: ../vector/lidar/v.lidar.correction/main.c:156
#: ../vector/lidar/v.lidar.correction/main.c:162
@@ -7749,11 +5633,15 @@
msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
msgstr ""
+#: ../raster/r.topidx/main.c:42
+msgid "Input elevation map"
+msgstr ""
#: ../raster/r.topidx/main.c:46
msgid "Output topographic index map"
msgstr ""
-#: ../raster/r.topidx/main.c:54
+#: ../raster/r.topidx/main.c:53
#, c-format
msgid "Lat/Long location is not supported by %s. Please reproject map first."
msgstr ""
@@ -7835,12 +5723,12 @@
msgid "List one entry per line instead of full row"
msgstr ""
-#: ../raster/r.report/stats.c:64
+#: ../raster/r.report/stats.c:65
#, c-format
msgid "Unable to open result file <%s>"
msgstr ""
-#: ../raster/r.report/stats.c:98 ../raster/r.kappa/stats.c:13
+#: ../raster/r.report/stats.c:99 ../raster/r.kappa/stats.c:13
msgid "Problem reading r.stats output"
msgstr ""
@@ -7852,86 +5740,90 @@
msgid "Raster map(s) to report on"
msgstr ""
-#: ../raster/r.report/parse.c:45
+#: ../raster/r.report/parse.c:44 ../vector/v.to.db/parse.c:82
+msgid "Units"
+msgstr ""
+#: ../raster/r.report/parse.c:46
msgid ""
-"mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p"
-"(ercent_cover)"
+"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
+"cover"
msgstr ""
-#: ../raster/r.report/parse.c:54
+#: ../raster/r.report/parse.c:56
msgid "Character representing no data cell value"
msgstr ""
-#: ../raster/r.report/parse.c:55 ../raster/r.report/parse.c:64
-#: ../raster/r.report/parse.c:73 ../raster/r.report/parse.c:98
-#: ../raster/r.report/parse.c:103 ../raster/r.report/parse.c:108
+#: ../raster/r.report/parse.c:57 ../raster/r.report/parse.c:66
+#: ../raster/r.report/parse.c:75 ../raster/r.report/parse.c:100
+#: ../raster/r.report/parse.c:105 ../raster/r.report/parse.c:110
msgid "Formatting"
msgstr ""
-#: ../raster/r.report/parse.c:61
+#: ../raster/r.report/parse.c:63
#, c-format
msgid "Page length (default: %d lines)"
msgstr ""
-#: ../raster/r.report/parse.c:70
+#: ../raster/r.report/parse.c:72
#, c-format
msgid "Page width (default: %d characters)"
msgstr ""
-#: ../raster/r.report/parse.c:80
+#: ../raster/r.report/parse.c:82
msgid "Name of an output file to hold the report"
msgstr ""
-#: ../raster/r.report/parse.c:89 ../raster/r.stats/main.c:125
+#: ../raster/r.report/parse.c:91 ../raster/r.stats/main.c:125
msgid "Number of fp subranges to collect stats from"
msgstr ""
-#: ../raster/r.report/parse.c:97
+#: ../raster/r.report/parse.c:99
msgid "Suppress page headers"
msgstr ""
-#: ../raster/r.report/parse.c:102
+#: ../raster/r.report/parse.c:104
msgid "Use formfeeds between pages"
msgstr ""
-#: ../raster/r.report/parse.c:107
+#: ../raster/r.report/parse.c:109
msgid "Scientific format"
msgstr ""
-#: ../raster/r.report/parse.c:112
+#: ../raster/r.report/parse.c:114
msgid "Filter out all no data cells"
msgstr ""
-#: ../raster/r.report/parse.c:116
+#: ../raster/r.report/parse.c:118
msgid "Filter out cells where all maps have no data"
msgstr ""
-#: ../raster/r.report/parse.c:120 ../raster/r.stats/main.c:185
+#: ../raster/r.report/parse.c:122 ../raster/r.stats/main.c:185
msgid "Report for cats fp ranges (fp maps only)"
msgstr ""
-#: ../raster/r.report/parse.c:125 ../raster/r.stats/main.c:189
+#: ../raster/r.report/parse.c:127 ../raster/r.stats/main.c:189
msgid "Read fp map as integer (use map's quant rules)"
msgstr ""
-#: ../raster/r.report/parse.c:168
+#: ../raster/r.report/parse.c:170
msgid "nsteps has to be > 0; using nsteps=255"
msgstr ""
-#: ../raster/r.report/parse.c:175
+#: ../raster/r.report/parse.c:177
msgid "Illegal page length"
msgstr ""
-#: ../raster/r.report/parse.c:182
+#: ../raster/r.report/parse.c:184
msgid "Illegal page width"
msgstr ""
-#: ../raster/r.report/parse.c:221
+#: ../raster/r.report/parse.c:223
#, c-format
msgid "Only %d unit%s allowed"
msgstr ""
-#: ../raster/r.report/parse.c:254
+#: ../raster/r.report/parse.c:256
#, c-format
msgid "Unable to read fp range for raster map <%s>"
msgstr ""
@@ -7952,7 +5844,7 @@
msgid "Name of location to read projection from for GCPs transformation"
msgstr ""
-#: ../raster/r.in.gdal/main.c:115
+#: ../raster/r.in.gdal/main.c:115 ../raster/r.external/main.c:537
msgid "Metadata"
msgstr ""
@@ -7960,28 +5852,34 @@
msgid "Name for new location to create"
msgstr ""
-#: ../raster/r.in.gdal/main.c:126
+#: ../raster/r.in.gdal/main.c:126 ../raster/r.external/main.c:542
msgid "Override projection (use location's projection)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:130 ../vector/v.in.ogr/main.c:230
+#: ../raster/r.in.gdal/main.c:130 ../raster/r.external/main.c:546
+#: ../vector/v.in.ogr/main.c:230
msgid "Extend location extents based on new dataset"
msgstr ""
-#: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:201
+#: ../raster/r.in.gdal/main.c:134 ../raster/r.external/main.c:554
+#: ../vector/v.in.ogr/main.c:201
msgid "List supported formats and exit"
msgstr ""
+#: ../raster/r.in.gdal/main.c:140
+msgid "Keep band numbers instead of using band color names"
+msgstr ""
#: ../raster/r.in.gdal/main.c:161
msgid "You have to specify a target location different from output location"
msgstr ""
-#: ../raster/r.in.gdal/main.c:179
+#: ../raster/r.in.gdal/main.c:179 ../raster/r.external/main.c:54
#, c-format
msgid "Supported Formats:\n"
msgstr ""
-#: ../raster/r.in.gdal/main.c:203
+#: ../raster/r.in.gdal/main.c:203 ../raster/r.external/main.c:590
msgid "Name for output raster map not specified"
msgstr ""
@@ -7997,7 +5895,7 @@
"(-tps)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:248
+#: ../raster/r.in.gdal/main.c:248 ../raster/r.external/main.c:202
msgid ""
"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
"transform the map to North-up."
@@ -8014,32 +5912,34 @@
msgid "Location <%s> created"
msgstr ""
-#: ../raster/r.in.gdal/main.c:306
+#: ../raster/r.in.gdal/main.c:306 ../raster/r.external/main.c:83
msgid ""
"Unable to convert input raster map projection information to GRASS format "
"for checking"
msgstr ""
-#: ../raster/r.in.gdal/main.c:322 ../vector/v.in.ogr/main.c:501
+#: ../raster/r.in.gdal/main.c:322 ../raster/r.external/main.c:99
+#: ../vector/v.in.ogr/main.c:501
msgid "Over-riding projection check"
msgstr ""
-#: ../raster/r.in.gdal/main.c:333 ../vector/v.in.ogr/main.c:510
+#: ../raster/r.in.gdal/main.c:333 ../raster/r.external/main.c:107
+#: ../vector/v.in.ogr/main.c:510
msgid ""
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-#: ../raster/r.in.gdal/main.c:338
+#: ../raster/r.in.gdal/main.c:338 ../raster/r.external/main.c:112
msgid "Location PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.in.gdal/main.c:349
+#: ../raster/r.in.gdal/main.c:349 ../raster/r.external/main.c:123
msgid "Dataset PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.in.gdal/main.c:376 ../vector/v.in.ogr/main.c:526
-#: ../vector/v.in.ogr/main.c:533
+#: ../raster/r.in.gdal/main.c:376 ../raster/r.external/main.c:150
+#: ../vector/v.in.ogr/main.c:526 ../vector/v.in.ogr/main.c:533
msgid "Import dataset PROJ_INFO is:\n"
msgstr ""
@@ -8050,21 +5950,22 @@
"location definition for the dataset.\n"
msgstr ""
-#: ../raster/r.in.gdal/main.c:401
+#: ../raster/r.in.gdal/main.c:401 ../raster/r.external/main.c:175
msgid ""
"Consider generating a new location from the input dataset using the "
"'location' parameter.\n"
msgstr ""
-#: ../raster/r.in.gdal/main.c:406 ../vector/v.in.ogr/main.c:584
+#: ../raster/r.in.gdal/main.c:406 ../raster/r.external/main.c:180
+#: ../vector/v.in.ogr/main.c:584
msgid "Projection of input dataset and current location appear to match"
msgstr ""
-#: ../raster/r.in.gdal/main.c:412
+#: ../raster/r.in.gdal/main.c:412 ../raster/r.external/main.c:611
msgid "Proceeding with import..."
msgstr ""
-#: ../raster/r.in.gdal/main.c:438
+#: ../raster/r.in.gdal/main.c:438 ../raster/r.external/main.c:615
#, c-format
msgid "Selected band (%d) does not exist"
msgstr ""
@@ -8128,7 +6029,7 @@
msgid "Setting grey color table for <%s> (16bit, image range)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:927
+#: ../raster/r.in.gdal/main.c:927 ../raster/r.external/main.c:480
#, c-format
msgid "<%s> created"
msgstr ""
@@ -8203,6 +6104,12 @@
"points."
msgstr ""
+#: ../raster/r.random/main.c:57 ../raster/r.resamp.rst/main.c:167
+#: ../raster/r.out.bin/main.c:73 ../raster/r.water.outlet/main.c:54
+#: ../imagery/i.zc/main.c:69
+msgid "Name of input raster map"
+msgstr ""
#: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
msgid "Name of cover raster map"
msgstr ""
@@ -9037,6 +6944,10 @@
msgid "Generates area statistics for raster map layers."
msgstr ""
+#: ../raster/r.stats/main.c:103
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr ""
#: ../raster/r.stats/main.c:131
msgid "One cell (range) per line"
msgstr ""
@@ -9087,7 +6998,7 @@
msgid "'%s' must be greater than zero; using %s=255"
msgstr ""
-#: ../raster/r.stats/main.c:250 ../raster/r.series/main.c:163
+#: ../raster/r.stats/main.c:250 ../raster/r.series/main.c:171
msgid "Raster map not found"
msgstr ""
@@ -9140,100 +7051,100 @@
msgid "Create an integer map"
msgstr ""
-#: ../raster/r.in.xyz/main.c:156
+#: ../raster/r.in.xyz/main.c:159
msgid "raster, import, LIDAR"
msgstr ""
-#: ../raster/r.in.xyz/main.c:158
+#: ../raster/r.in.xyz/main.c:161
msgid ""
"Create a raster map from an assemblage of many coordinates using univariate "
"statistics."
msgstr ""
-#: ../raster/r.in.xyz/main.c:162
+#: ../raster/r.in.xyz/main.c:165
msgid "ASCII file containing input data (or \"-\" to read from stdin)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:170
+#: ../raster/r.in.xyz/main.c:173
msgid "Statistic to use for raster values"
msgstr ""
-#: ../raster/r.in.xyz/main.c:174 ../raster/r.in.xyz/main.c:240
-#: ../raster/r.in.xyz/main.c:249
+#: ../raster/r.in.xyz/main.c:177 ../raster/r.in.xyz/main.c:243
+#: ../raster/r.in.xyz/main.c:252
msgid "Statistic"
msgstr ""
-#: ../raster/r.in.xyz/main.c:182 ../raster/r.in.arc/main.c:80
+#: ../raster/r.in.xyz/main.c:185 ../raster/r.in.arc/main.c:80
msgid "Storage type for resultant raster map"
msgstr ""
-#: ../raster/r.in.xyz/main.c:185 ../raster/r.in.xyz/main.c:194
-#: ../raster/r.in.xyz/main.c:202 ../raster/r.in.xyz/main.c:210
+#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.xyz/main.c:197
+#: ../raster/r.in.xyz/main.c:205 ../raster/r.in.xyz/main.c:213
#: ../vector/v.edit/args.c:102 ../vector/v.edit/args.c:220
#: ../vector/v.out.ogr/main.c:98 ../vector/v.out.ogr/main.c:118
msgid "Input"
msgstr ""
-#: ../raster/r.in.xyz/main.c:193
+#: ../raster/r.in.xyz/main.c:196
msgid "Column number of x coordinates in input file (first column is 1)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:201
+#: ../raster/r.in.xyz/main.c:204
msgid "Column number of y coordinates in input file"
msgstr ""
-#: ../raster/r.in.xyz/main.c:209
+#: ../raster/r.in.xyz/main.c:212
msgid "Column number of data values in input file"
msgstr ""
-#: ../raster/r.in.xyz/main.c:217
+#: ../raster/r.in.xyz/main.c:220
msgid "Filter range for z data (min,max)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:224
+#: ../raster/r.in.xyz/main.c:227
msgid "Scale to apply to z data"
msgstr ""
-#: ../raster/r.in.xyz/main.c:232 ../raster/r.cost/main.c:199
+#: ../raster/r.in.xyz/main.c:235 ../raster/r.cost/main.c:199
#: ../raster/r.walk/main.c:257
msgid "Percent of map to keep in memory"
msgstr ""
-#: ../raster/r.in.xyz/main.c:239
+#: ../raster/r.in.xyz/main.c:242
msgid "pth percentile of the values"
msgstr ""
-#: ../raster/r.in.xyz/main.c:248
+#: ../raster/r.in.xyz/main.c:251
msgid ""
"Discard <trim> percent of the smallest and <trim> percent of the largest "
"observations"
msgstr ""
-#: ../raster/r.in.xyz/main.c:253
+#: ../raster/r.in.xyz/main.c:256
msgid "Scan data file for extent then exit"
msgstr ""
-#: ../raster/r.in.xyz/main.c:258
+#: ../raster/r.in.xyz/main.c:261
msgid "In scan mode, print using shell script style"
msgstr ""
-#: ../raster/r.in.xyz/main.c:262
+#: ../raster/r.in.xyz/main.c:265
msgid "Ignore broken lines"
msgstr ""
-#: ../raster/r.in.xyz/main.c:288
+#: ../raster/r.in.xyz/main.c:291
msgid "Please specify a reasonable column number."
msgstr ""
-#: ../raster/r.in.xyz/main.c:383
+#: ../raster/r.in.xyz/main.c:386
msgid "Unable to calculate percentile without the pth option specified!"
msgstr ""
-#: ../raster/r.in.xyz/main.c:395
+#: ../raster/r.in.xyz/main.c:398
msgid "Unable to calculate trimmed mean without the trim option specified!"
msgstr ""
-#: ../raster/r.in.xyz/main.c:464 ../raster/r.in.mat/main.c:144
+#: ../raster/r.in.xyz/main.c:467 ../raster/r.in.mat/main.c:144
#: ../raster/r.in.arc/main.c:124 ../vector/v.segment/main.c:92
#: ../vector/v.net.path/path.c:49 ../vector/v.lrs/v.lrs.segment/main.c:131
#: ../display/d.linegraph/linegraph.c:193
@@ -9242,67 +7153,67 @@
msgid "Unable to open input file <%s>"
msgstr ""
-#: ../raster/r.in.xyz/main.c:471
+#: ../raster/r.in.xyz/main.c:474
msgid ""
"If input is not from a file it is only possible to perform a single pass."
msgstr ""
-#: ../raster/r.in.xyz/main.c:477
+#: ../raster/r.in.xyz/main.c:480
msgid "zrange will not be taken into account during scan"
msgstr ""
-#: ../raster/r.in.xyz/main.c:515 ../raster/r.in.xyz/main.c:1081
+#: ../raster/r.in.xyz/main.c:518 ../raster/r.in.xyz/main.c:1085
msgid "Scanning data ..."
msgstr ""
-#: ../raster/r.in.xyz/main.c:522 ../raster/r.in.poly/poly2rast.c:41
+#: ../raster/r.in.xyz/main.c:525 ../raster/r.in.poly/poly2rast.c:41
#, c-format
msgid "Pass #%d (of %d) ..."
msgstr ""
-#: ../raster/r.in.xyz/main.c:593 ../raster/r.in.xyz/main.c:601
-#: ../raster/r.in.xyz/main.c:1096 ../raster/r.in.xyz/main.c:1104
+#: ../raster/r.in.xyz/main.c:596 ../raster/r.in.xyz/main.c:604
+#: ../raster/r.in.xyz/main.c:1100 ../raster/r.in.xyz/main.c:1108
#, c-format
msgid ""
"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %d:\n"
+"following character(s) in row %lu:\n"
"[%s]"
msgstr ""
-#: ../raster/r.in.xyz/main.c:597 ../raster/r.in.xyz/main.c:1100
+#: ../raster/r.in.xyz/main.c:600 ../raster/r.in.xyz/main.c:1104
msgid "Line ignored as requested"
msgstr ""
-#: ../raster/r.in.xyz/main.c:616 ../raster/r.in.xyz/main.c:1134
+#: ../raster/r.in.xyz/main.c:619 ../raster/r.in.xyz/main.c:1138
#, c-format
-msgid "Bad y-coordinate line %d column %d. <%s>"
+msgid "Bad y-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.in.xyz/main.c:623 ../raster/r.in.xyz/main.c:1119
+#: ../raster/r.in.xyz/main.c:626 ../raster/r.in.xyz/main.c:1123
#, c-format
-msgid "Bad x-coordinate line %d column %d. <%s>"
+msgid "Bad x-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.in.xyz/main.c:630 ../raster/r.in.xyz/main.c:1149
+#: ../raster/r.in.xyz/main.c:633 ../raster/r.in.xyz/main.c:1153
#, c-format
-msgid "Bad z-coordinate line %d column %d. <%s>"
+msgid "Bad z-coordinate line %lu column %d. <%s>"
msgstr ""
-#: ../raster/r.in.xyz/main.c:712
+#: ../raster/r.in.xyz/main.c:715
msgid "Writing to map ..."
msgstr ""
-#: ../raster/r.in.xyz/main.c:1008
+#: ../raster/r.in.xyz/main.c:1011
#, c-format
msgid "Writing map, row %d"
msgstr ""
-#: ../raster/r.in.xyz/main.c:1055
+#: ../raster/r.in.xyz/main.c:1058
#, c-format
-msgid "%d points found in region."
+msgid "%lu points found in region."
msgstr ""
-#: ../raster/r.in.xyz/main.c:1169
+#: ../raster/r.in.xyz/main.c:1173
#, c-format
msgid "Range: min max\n"
msgstr ""
@@ -9511,47 +7422,24 @@
msgid "Standard deviation"
msgstr ""
-#: ../raster/r.colors/main.c:126
+#: ../raster/r.colors/main.c:165
msgid "raster, color table"
msgstr ""
-#: ../raster/r.colors/main.c:128
+#: ../raster/r.colors/main.c:167
msgid "Creates/modifies the color table associated with a raster map layer."
msgstr ""
-#: ../raster/r.colors/main.c:142
+#: ../raster/r.colors/main.c:181
msgid "Type of color table"
msgstr ""
-#: ../raster/r.colors/main.c:144
-msgid ""
-"aspect;aspect oriented grey colors;aspectcolr;aspect oriented rainbow colors;"
-"bcyr;blue through cyan through yellow to red;bgyr;blue through green through "
-"yellow to red;byg;blue through yellow to green colors;byr;blue through "
-"yellow to red colors;curvature;for terrain curvatures (from v.surf.rst and r."
-"slope.aspect curvature colors);differences;differences oriented colors;"
-"elevation;maps percentage ranges of raster values to elevation color ramp;"
-"etopo2;rainbow color ramp for the ETOPO2 2-minute Worldwide Bathymetry/"
-"Topography dataset;evi;enhanced vegetative index colors;grey;grey scale;"
-"grey1.0;grey scale for raster values between 0.0-1.0;grey255;grey scale for "
-"raster values bewtween 0-255;grey.eq;histogram-equalized grey scale;grey.log;"
-"histogram logarithmic transformed grey scale;gyr;green through yellow to red "
-"colors;ndvi;Normalized Difference Vegetation Index colors;population;color "
-"table covering human population classification breaks;rainbow;rainbow color "
-"table;ramp;color ramp;random;random color table;rules;create new color table "
-"based on user-specified rules;ryb;red through yellow to blue colors;ryg;red "
-"through yellow to green colors;slope;r.slope.aspect-type slope colors for "
-"raster values 0-90;srtm;color palette for Shuttle Radar Topography Mission "
-"elevation values;terrain;global elevation color table covering -11000 to "
-"+8850m;wave;color wave;"
-msgstr ""
-#: ../raster/r.colors/main.c:173 ../raster/r.colors/main.c:187
-#: ../raster/r.colors/main.c:205 ../raster/r.colors/main.c:210
-#: ../raster/r.colors/main.c:215 ../vector/v.label.sa/main.c:177
-#: ../vector/v.label.sa/main.c:187 ../vector/v.label.sa/main.c:194
-#: ../vector/v.label.sa/main.c:204 ../vector/v.label.sa/main.c:214
-#: ../vector/v.label.sa/main.c:224 ../vector/v.label.sa/main.c:231
+#: ../raster/r.colors/main.c:183 ../raster/r.colors/main.c:197
+#: ../raster/r.colors/main.c:215 ../raster/r.colors/main.c:220
+#: ../raster/r.colors/main.c:225 ../vector/v.label.sa/main.c:176
+#: ../vector/v.label.sa/main.c:186 ../vector/v.label.sa/main.c:193
+#: ../vector/v.label.sa/main.c:203 ../vector/v.label.sa/main.c:213
+#: ../vector/v.label.sa/main.c:223 ../vector/v.label.sa/main.c:230
#: ../vector/v.label/main.c:153 ../vector/v.label/main.c:177
#: ../vector/v.label/main.c:190 ../vector/v.label/main.c:196
#: ../vector/v.label/main.c:206 ../display/d.vect/main.c:163
@@ -9561,95 +7449,95 @@
msgid "Colors"
msgstr ""
-#: ../raster/r.colors/main.c:181
+#: ../raster/r.colors/main.c:191
msgid "Raster map name from which to copy color table"
msgstr ""
-#: ../raster/r.colors/main.c:186
-msgid "Path to rules file"
+#: ../raster/r.colors/main.c:196
+msgid "Path to rules file (\"-\" to read rules from stdin)"
msgstr ""
-#: ../raster/r.colors/main.c:191
+#: ../raster/r.colors/main.c:201
msgid "Remove existing color table"
msgstr ""
-#: ../raster/r.colors/main.c:196
+#: ../raster/r.colors/main.c:206
msgid "Only write new color table if one doesn't already exist"
msgstr ""
-#: ../raster/r.colors/main.c:200
+#: ../raster/r.colors/main.c:210
msgid "List available rules then exit"
msgstr ""
-#: ../raster/r.colors/main.c:204
+#: ../raster/r.colors/main.c:214
msgid "Invert colors"
msgstr ""
-#: ../raster/r.colors/main.c:209
+#: ../raster/r.colors/main.c:219
msgid "Logarithmic scaling"
msgstr ""
-#: ../raster/r.colors/main.c:214
+#: ../raster/r.colors/main.c:224
msgid "Histogram equalization"
msgstr ""
-#: ../raster/r.colors/main.c:219
+#: ../raster/r.colors/main.c:229
msgid "Enter rules interactively"
msgstr ""
-#: ../raster/r.colors/main.c:253
+#: ../raster/r.colors/main.c:263
msgid "No map specified"
msgstr ""
-#: ../raster/r.colors/main.c:256
+#: ../raster/r.colors/main.c:266
msgid ""
"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
"specified!"
msgstr ""
-#: ../raster/r.colors/main.c:259
+#: ../raster/r.colors/main.c:269
msgid ""
"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
"options"
msgstr ""
-#: ../raster/r.colors/main.c:262
+#: ../raster/r.colors/main.c:272
msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
msgstr ""
-#: ../raster/r.colors/main.c:273
+#: ../raster/r.colors/main.c:289
#, c-format
msgid "%s - unable to remove color table"
msgstr ""
-#: ../raster/r.colors/main.c:275
+#: ../raster/r.colors/main.c:291
#, c-format
msgid "%s - color table not found"
msgstr ""
-#: ../raster/r.colors/main.c:303
+#: ../raster/r.colors/main.c:319
msgid "Can't make random color table for floating point map"
msgstr ""
-#: ../raster/r.colors/main.c:308
+#: ../raster/r.colors/main.c:324
msgid "Can't make grey.eq color table for floating point map"
msgstr ""
-#: ../raster/r.colors/main.c:315
+#: ../raster/r.colors/main.c:331
msgid "Can't make logarithmic color table for floating point map"
msgstr ""
-#: ../raster/r.colors/main.c:328
+#: ../raster/r.colors/main.c:344
#, c-format
msgid "%s - unknown color request"
msgstr ""
-#: ../raster/r.colors/main.c:339
+#: ../raster/r.colors/main.c:355
#, c-format
msgid "Unable to load rules file %s"
msgstr ""
-#: ../raster/r.colors/main.c:374
+#: ../raster/r.colors/main.c:390
#, c-format
msgid "Color table for <%s> set to %s"
msgstr ""
@@ -10082,12 +7970,13 @@
msgstr ""
#: ../raster/r.cost/main.c:217 ../raster/wildfire/r.ros/main.c:301
-#: ../vector/v.kernel/main.c:176 ../display/d.vect/main.c:339
+#: ../raster/wildfire/r.spreadpath/main.c:110 ../vector/v.kernel/main.c:176
+#: ../display/d.vect/main.c:339
msgid "Run verbosely"
msgstr ""
#: ../raster/r.cost/main.c:238 ../raster/r.water.outlet/main.c:84
-#: ../raster/r.walk/main.c:322
+#: ../raster/r.walk/main.c:322 ../raster/wildfire/r.spread/main.c:338
msgid "Unable to read current window parameters"
msgstr ""
@@ -10895,7 +8784,7 @@
msgid "weight= and -c are mutually exclusive"
msgstr ""
-#: ../raster/r.neighbors/main.c:203 ../raster/r.series/main.c:178
+#: ../raster/r.neighbors/main.c:203 ../raster/r.series/main.c:186
#: ../ps/ps.map/outl_io.c:72
#, c-format
msgid "Unable to open raster map <%s> in mapset <%s>"
@@ -10972,7 +8861,11 @@
msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
msgstr ""
-#: ../raster/r.in.gridatb/main.c:68
+#: ../raster/r.in.gridatb/main.c:53
+msgid "Name for output raster map"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:67
#, c-format
msgid "File not found: %s"
msgstr ""
@@ -11050,13 +8943,13 @@
msgstr ""
#: ../raster/r.to.vect/main.c:156 ../raster/r.contour/main.c:184
-#: ../vector/v.db.connect/main.c:188 ../vector/v.db.connect/main.c:296
+#: ../vector/v.db.connect/main.c:194 ../vector/v.db.connect/main.c:302
#: ../vector/v.to.rast3/main.c:86 ../vector/v.edit/select.c:520
#: ../vector/v.in.dxf/write_vect.c:187
#: ../vector/lidar/v.surf.bspline/main.c:304 ../vector/v.distance/main.c:359
#: ../vector/v.distance/main.c:396 ../vector/v.reclass/main.c:124
-#: ../vector/v.in.ascii/in.c:308 ../vector/v.db.select/main.c:105
-#: ../vector/v.db.select/main.c:178 ../vector/v.what.rast/main.c:132
+#: ../vector/v.in.ascii/in.c:311 ../vector/v.db.select/main.c:142
+#: ../vector/v.db.select/main.c:273 ../vector/v.what.rast/main.c:132
#: ../vector/v.extrude/main.c:166 ../vector/v.sample/main.c:207
#: ../vector/v.in.sites/main.c:163 ../vector/v.patch/main.c:132
#: ../vector/v.patch/main.c:162 ../vector/v.patch/main.c:274
@@ -11066,13 +8959,14 @@
#: ../vector/v.random/main.c:160 ../vector/v.overlay/main.c:180
#: ../vector/v.overlay/main.c:281 ../vector/v.label.sa/labels.c:83
#: ../vector/v.kcv/main.c:173 ../vector/v.normal/main.c:141
-#: ../vector/v.out.svg/main.c:149 ../vector/v.to.db/update.c:32
-#: ../vector/v.to.db/query.c:88 ../vector/v.label/main.c:282
-#: ../vector/v.in.db/main.c:118 ../vector/v.to.rast/support.c:131
-#: ../vector/v.to.rast/support.c:283 ../vector/v.to.rast/vect2rast.c:56
-#: ../vector/v.out.ogr/main.c:327 ../vector/v.lrs/v.lrs.create/main.c:286
+#: ../vector/v.out.svg/main.c:148 ../vector/v.to.db/update.c:32
+#: ../vector/v.to.db/query.c:88 ../vector/v.out.vtk/writeVTK.c:639
+#: ../vector/v.label/main.c:282 ../vector/v.in.db/main.c:118
+#: ../vector/v.to.rast/support.c:131 ../vector/v.to.rast/support.c:283
+#: ../vector/v.to.rast/vect2rast.c:56 ../vector/v.out.ogr/main.c:327
+#: ../vector/v.lrs/v.lrs.create/main.c:286
#: ../vector/v.lrs/v.lrs.create/main.c:294 ../vector/v.buffer/main.c:387
-#: ../vector/v.extract/main.c:246 ../doc/vector/v.example/main.c:128
+#: ../vector/v.extract/main.c:283 ../doc/vector/v.example/main.c:128
#: ../ps/ps.map/catval.c:54 ../ps/ps.map/catval.c:116
#: ../ps/ps.map/catval.c:182
#, c-format
@@ -11084,7 +8978,7 @@
#: ../vector/lidar/lidarlib/raster.c:100 ../vector/lidar/lidarlib/raster.c:114
#: ../vector/lidar/lidarlib/raster.c:132 ../vector/lidar/lidarlib/raster.c:148
#: ../vector/lidar/lidarlib/raster.c:162 ../vector/lidar/lidarlib/raster.c:178
-#: ../vector/lidar/lidarlib/raster.c:191 ../vector/v.in.ascii/in.c:377
+#: ../vector/lidar/lidarlib/raster.c:191 ../vector/v.in.ascii/in.c:380
#: ../vector/v.in.sites/main.c:170 ../vector/v.mkgrid/main.c:235
#: ../vector/v.random/main.c:178 ../vector/v.lrs/v.lrs.create/main.c:325
#, c-format
@@ -11098,7 +8992,7 @@
#: ../raster/r.to.vect/main.c:201 ../raster/r.contour/main.c:203
#: ../vector/v.in.dxf/write_vect.c:212 ../vector/v.distance/main.c:822
-#: ../vector/v.in.ascii/in.c:386 ../vector/v.sample/main.c:223
+#: ../vector/v.in.ascii/in.c:389 ../vector/v.sample/main.c:223
#: ../vector/v.in.sites/main.c:179 ../vector/v.mkgrid/main.c:243
#: ../vector/v.random/main.c:189 ../vector/v.overlay/main.c:460
#, c-format
@@ -11156,7 +9050,7 @@
msgid "Set from current region"
msgstr ""
-#: ../raster/r.region/main.c:70 ../general/g.region/main.c:81
+#: ../raster/r.region/main.c:70 ../general/g.region/main.c:80
msgid "Set from default region"
msgstr ""
@@ -11168,31 +9062,31 @@
msgid "Set region from named region"
msgstr ""
-#: ../raster/r.region/main.c:97 ../general/g.region/main.c:161
+#: ../raster/r.region/main.c:97 ../general/g.region/main.c:160
msgid "Set region to match this raster map"
msgstr ""
-#: ../raster/r.region/main.c:105 ../general/g.region/main.c:177
+#: ../raster/r.region/main.c:105 ../general/g.region/main.c:176
msgid "Set region to match this vector map"
msgstr ""
-#: ../raster/r.region/main.c:113 ../general/g.region/main.c:186
+#: ../raster/r.region/main.c:113 ../general/g.region/main.c:185
msgid "Set region to match this 3dview file"
msgstr ""
-#: ../raster/r.region/main.c:122 ../general/g.region/main.c:196
+#: ../raster/r.region/main.c:122 ../general/g.region/main.c:195
msgid "Value for the northern edge"
msgstr ""
-#: ../raster/r.region/main.c:132 ../general/g.region/main.c:206
+#: ../raster/r.region/main.c:132 ../general/g.region/main.c:205
msgid "Value for the southern edge"
msgstr ""
-#: ../raster/r.region/main.c:142 ../general/g.region/main.c:216
+#: ../raster/r.region/main.c:142 ../general/g.region/main.c:215
msgid "Value for the eastern edge"
msgstr ""
-#: ../raster/r.region/main.c:152 ../general/g.region/main.c:226
+#: ../raster/r.region/main.c:152 ../general/g.region/main.c:225
msgid "Value for the western edge"
msgstr ""
@@ -11202,37 +9096,37 @@
#: ../raster/r.region/main.c:172 ../raster/r.region/main.c:231
#: ../raster/r.region/main.c:354 ../display/d.title/main.c:108
-#: ../general/g.region/main.c:453 ../general/g.region/main.c:804
+#: ../general/g.region/main.c:452 ../general/g.region/main.c:803
#, c-format
msgid "Unable to read header of raster map <%s@%s>"
msgstr ""
-#: ../raster/r.region/main.c:186 ../general/g.region/main.c:394
+#: ../raster/r.region/main.c:186 ../general/g.region/main.c:393
#, c-format
msgid "Region <%s> not found"
msgstr ""
-#: ../raster/r.region/main.c:188 ../general/g.region/main.c:396
+#: ../raster/r.region/main.c:188 ../general/g.region/main.c:395
#, c-format
msgid "Unable to read region <%s> in <%s>"
msgstr ""
-#: ../raster/r.region/main.c:199 ../general/g.region/main.c:408
+#: ../raster/r.region/main.c:199 ../general/g.region/main.c:407
#, c-format
msgid "3dview file <%s> not found"
msgstr ""
-#: ../raster/r.region/main.c:205 ../general/g.region/main.c:413
+#: ../raster/r.region/main.c:205 ../general/g.region/main.c:412
#, c-format
msgid "Unable to open 3dview file <%s> in <%s>"
msgstr ""
-#: ../raster/r.region/main.c:210 ../general/g.region/main.c:419
+#: ../raster/r.region/main.c:210 ../general/g.region/main.c:418
#, c-format
msgid "Unable to read 3dview file <%s> in <%s>"
msgstr ""
-#: ../raster/r.region/main.c:213 ../general/g.region/main.c:422
+#: ../raster/r.region/main.c:213 ../general/g.region/main.c:421
#, c-format
msgid "Old 3dview file. Region <%s> not found in <%s>"
msgstr ""
@@ -11274,14 +9168,6 @@
msgid "Converting ... "
msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:37
-msgid "Writing vertices..."
-msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:82
-msgid "Writing color file..."
-msgstr ""
#: ../raster/r.out.vrml/main.c:47
msgid "raster, export, VRML"
msgstr ""
@@ -11298,7 +9184,7 @@
msgid "Name of color file"
msgstr ""
-#: ../raster/r.out.vrml/main.c:70 ../visualization/nviz2/cmd/args.c:455
+#: ../raster/r.out.vrml/main.c:70 ../visualization/nviz2/cmd/args.c:488
msgid "Vertical exaggeration"
msgstr ""
@@ -11311,6 +9197,14 @@
msgid "Opening %s for writing... "
msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:37
+msgid "Writing vertices..."
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:82
+msgid "Writing color file..."
+msgstr ""
#: ../raster/r.in.mat/main.c:94
msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr ""
@@ -11426,11 +9320,21 @@
msgid "Writing raster map, row %d"
msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:40
+#: ../raster/r.univar2/r3.univar_main.c:39 ../vector/v.univar/main.c:92
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr ""
#: ../raster/r.univar2/r.univar_main.c:45
#: ../raster/r.univar2/r3.univar_main.c:44 ../vector/v.univar/main.c:96
msgid "Print the stats in shell script style"
msgstr ""
+#: ../raster/r.univar2/r.univar_main.c:49
+#: ../raster/r.univar2/r3.univar_main.c:48 ../vector/v.univar/main.c:100
+msgid "Calculate extended statistics"
+msgstr ""
#: ../raster/r.univar2/r.univar_main.c:77
msgid ""
"Calculates univariate statistics from the non-null cells of a raster map."
@@ -12177,24 +10081,6 @@
msgid "Minimum number of rows to hold in memory is 1"
msgstr ""
-#: ../raster/r.quant/read_rules.c:49
-msgid "Old data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:55
-#, c-format
-msgid "Old data range is %s to %s"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:58
-msgid "Old integer data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:60
-#, c-format
-msgid "Old integer data range is %d to %d"
-msgstr ""
#: ../raster/r.quant/main.c:43
msgid "Produces the quantization file for a floating-point map."
msgstr ""
@@ -12250,6 +10136,24 @@
msgid "New quant table created for %s"
msgstr ""
+#: ../raster/r.quant/read_rules.c:49
+msgid "Old data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:55
+#, c-format
+msgid "Old data range is %s to %s"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:58
+msgid "Old integer data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:60
+#, c-format
+msgid "Old integer data range is %d to %d"
+msgstr ""
#: ../raster/r.contour/cont.c:81
#, c-format
msgid "Total levels: %4d"
@@ -12311,14 +10215,14 @@
msgid "Could not read range file"
msgstr ""
-#: ../raster/r.contour/main.c:199 ../vector/v.db.connect/main.c:301
+#: ../raster/r.contour/main.c:199 ../vector/v.db.connect/main.c:307
#: ../vector/v.reclass/main.c:218 ../vector/v.to.points/main.c:298
#: ../vector/v.sample/main.c:219 ../vector/v.in.ogr/main.c:773
#: ../vector/v.net.path/path.c:113
msgid "Cannot create index"
msgstr ""
-#: ../raster/r.contour/main.c:221 ../vector/v.sample/main.c:286
+#: ../raster/r.contour/main.c:221 ../vector/v.sample/main.c:289
#: ../vector/v.kcv/main.c:248
#, c-format
msgid "Unable to insert row: %s"
@@ -12466,20 +10370,24 @@
msgid "Reading <%s> in <%s>"
msgstr ""
-#: ../raster/r.series/main.c:110
+#: ../raster/r.series/main.c:128
msgid "raster, series"
msgstr ""
-#: ../raster/r.series/main.c:112
+#: ../raster/r.series/main.c:130
msgid ""
"Makes each output cell value a function of the values assigned to the "
"corresponding cells in the input raster map layers."
msgstr ""
-#: ../raster/r.series/main.c:125
+#: ../raster/r.series/main.c:144
msgid "Aggregate operation"
msgstr ""
+#: ../raster/r.series/main.c:197
+msgid "output= and method= must have the same number of values"
+msgstr ""
#: ../raster/r.water.outlet/main.c:47
msgid "Watershed basin creation program."
msgstr ""
@@ -12611,6 +10519,10 @@
msgid "Raster file(s) for View%d"
msgstr ""
+#: ../raster/r.out.mpeg/main.c:406
+msgid "Name for output file"
+msgstr ""
#: ../raster/r.out.mpeg/main.c:416
msgid "Quality factor (1 = highest quality, lowest compression)"
msgstr ""
@@ -12948,6 +10860,31 @@
msgid "Overflow occured in the calculation"
msgstr ""
+#: ../raster/r.recode/main.c:43
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../raster/r.recode/main.c:46
+msgid "Raster map to be recoded"
+msgstr ""
+#: ../raster/r.recode/main.c:53
+msgid "File containing recode rules"
+msgstr ""
+#: ../raster/r.recode/main.c:65
+msgid "Align the current region to the input map"
+msgstr ""
+#: ../raster/r.recode/main.c:69
+msgid "Force output to double map type (DCELL)"
+msgstr ""
+#: ../raster/r.recode/main.c:100
+#, c-format
+msgid "No rules specified. Raster map <%s> not created."
+msgstr ""
#: ../raster/r.recode/read_rules.c:19
#, c-format
msgid "Unable to read f_range for map %s"
@@ -13001,31 +10938,6 @@
msgid "%s is not a valid rule"
msgstr ""
-#: ../raster/r.recode/main.c:43
-msgid "Recodes categorical raster maps."
-msgstr ""
-#: ../raster/r.recode/main.c:46
-msgid "Raster map to be recoded"
-msgstr ""
-#: ../raster/r.recode/main.c:53
-msgid "File containing recode rules"
-msgstr ""
-#: ../raster/r.recode/main.c:65
-msgid "Align the current region to the input map"
-msgstr ""
-#: ../raster/r.recode/main.c:69
-msgid "Force output to double map type (DCELL)"
-msgstr ""
-#: ../raster/r.recode/main.c:100
-#, c-format
-msgid "No rules specified. Raster map <%s> not created."
-msgstr ""
#: ../raster/r.mfilter/main.c:94
msgid "Apply filter only to zero data values"
msgstr ""
@@ -13127,7 +11039,7 @@
msgstr ""
#: ../raster/r.gwflow/main.c:150
-msgid "The hight of the river bed in [m]"
+msgid "The height of the river bed in [m]"
msgstr ""
#: ../raster/r.gwflow/main.c:158
@@ -13139,7 +11051,7 @@
msgstr ""
#: ../raster/r.gwflow/main.c:173
-msgid "The hight of the drainage bed in [m]"
+msgid "The height of the drainage bed in [m]"
msgstr ""
#: ../raster/r.gwflow/main.c:181
@@ -13232,9 +11144,9 @@
#: ../raster/wildfire/r.ros/main.c:424 ../raster/wildfire/r.ros/main.c:428
#: ../raster/wildfire/r.ros/main.c:432 ../raster/wildfire/r.ros/main.c:439
-#: ../raster/wildfire/r.spread/main.c:413
-#: ../raster/wildfire/r.spread/main.c:427
-#: ../raster/wildfire/r.spread/main.c:442
+#: ../raster/wildfire/r.spread/main.c:384
+#: ../raster/wildfire/r.spread/main.c:393
+#: ../raster/wildfire/r.spread/main.c:403
#, c-format
msgid "Raster map <%s> already exists in mapset <%s>, select another name"
msgstr ""
@@ -13254,7 +11166,7 @@
msgstr ""
#: ../raster/wildfire/r.spreadpath/main.c:91
-msgid "Name of raster map containing back-path norhting information"
+msgid "Name of raster map containing back-path northing information"
msgstr ""
#: ../raster/wildfire/r.spreadpath/main.c:99
@@ -13265,116 +11177,112 @@
msgid "Name of spread path raster map"
msgstr ""
-#: ../raster/wildfire/r.spreadpath/main.c:110
-msgid "Run verbosly"
-msgstr ""
-#: ../raster/wildfire/r.spread/main.c:105
+#: ../raster/wildfire/r.spread/main.c:103
msgid ""
"Simulates elliptically anisotropic spread on a graphics window and generates "
"a raster map of the cumulative time of spread, given raster maps containing "
"the rates of spread (ROS), the ROS directions and the spread origins."
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:110
+#: ../raster/wildfire/r.spread/main.c:108
msgid ""
"It optionally produces raster maps to contain backlink UTM coordinates for "
"tracing spread paths."
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:118
-#: ../raster/wildfire/r.spread/main.c:127
-#: ../raster/wildfire/r.spread/main.c:136
-#: ../raster/wildfire/r.spread/main.c:145
-#: ../raster/wildfire/r.spread/main.c:153
-#: ../raster/wildfire/r.spread/main.c:161
-#: ../raster/wildfire/r.spread/main.c:169
+#: ../raster/wildfire/r.spread/main.c:116
+#: ../raster/wildfire/r.spread/main.c:125
+#: ../raster/wildfire/r.spread/main.c:134
+#: ../raster/wildfire/r.spread/main.c:143
+#: ../raster/wildfire/r.spread/main.c:151
+#: ../raster/wildfire/r.spread/main.c:159
+#: ../raster/wildfire/r.spread/main.c:167
msgid "Input_maps"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:120
+#: ../raster/wildfire/r.spread/main.c:118
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:129
+#: ../raster/wildfire/r.spread/main.c:127
msgid "Name of raster map containing DIRections of max ROS (degree)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:138
+#: ../raster/wildfire/r.spread/main.c:136
msgid "Name of raster map containing BASE ROS (cm/min)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:147
+#: ../raster/wildfire/r.spread/main.c:145
msgid "Name of raster map containing STARTing sources"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:155
+#: ../raster/wildfire/r.spread/main.c:153
msgid ""
"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:163
+#: ../raster/wildfire/r.spread/main.c:161
msgid ""
"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:171
+#: ../raster/wildfire/r.spread/main.c:169
msgid ""
"Name of raster map containing fine Fuel MOISture of the cell receiving a "
"spotting firebrand (%) (required w/ -s)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:179
+#: ../raster/wildfire/r.spread/main.c:177
msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:186
+#: ../raster/wildfire/r.spread/main.c:184
msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:193
+#: ../raster/wildfire/r.spread/main.c:191
msgid "INITial TIME for current simulation (0) (min)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:200
+#: ../raster/wildfire/r.spread/main.c:198
msgid "Simulating time duration LAG (fill the region) (min)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:207
+#: ../raster/wildfire/r.spread/main.c:205
msgid "Name of raster map as a display backdrop"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:214
-#: ../raster/wildfire/r.spread/main.c:222
-#: ../raster/wildfire/r.spread/main.c:230
+#: ../raster/wildfire/r.spread/main.c:212
+#: ../raster/wildfire/r.spread/main.c:220
+#: ../raster/wildfire/r.spread/main.c:228
msgid "Output_maps"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:216
+#: ../raster/wildfire/r.spread/main.c:214
msgid "Name of raster map to contain OUTPUT spread time (min)"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:224
-msgid "Name of raster map to contain X_BACK coordiates"
+#: ../raster/wildfire/r.spread/main.c:222
+msgid "Name of raster map to contain X_BACK coordinates"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:232
-msgid "Name of raster map to contain Y_BACK coordiates"
+#: ../raster/wildfire/r.spread/main.c:230
+msgid "Name of raster map to contain Y_BACK coordinates"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:237
+#: ../raster/wildfire/r.spread/main.c:235
msgid "Run VERBOSELY"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:241
+#: ../raster/wildfire/r.spread/main.c:239
msgid "DISPLAY 'live' spread process on screen"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:245
+#: ../raster/wildfire/r.spread/main.c:243
msgid "For wildfires: consider SPOTTING effect"
msgstr ""
-#: ../raster/wildfire/r.spread/main.c:521
+#: ../raster/wildfire/r.spread/main.c:463
msgid "Reading inputs..."
msgstr ""
@@ -13548,6 +11456,103 @@
msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
msgstr ""
+#: ../raster/r.external/main.c:172
+msgid ""
+"\n"
+"You can use the -o flag to r.external to override this check and use the "
+"location definition for the dataset.\n"
+msgstr ""
+#: ../raster/r.external/main.c:300
+msgid "Complex types not supported"
+msgstr ""
+#: ../raster/r.external/main.c:315
+#, c-format
+msgid "Copying color table for %s"
+msgstr ""
+#: ../raster/r.external/main.c:333
+#, c-format
+msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr ""
+#: ../raster/r.external/main.c:339
+#, c-format
+msgid "Setting grey color table for <%s> (data range)"
+msgstr ""
+#: ../raster/r.external/main.c:353
+#, c-format
+msgid "Unable to create cell/%s file"
+msgstr ""
+#: ../raster/r.external/main.c:362
+#, c-format
+msgid "Unable to create fcell/%s file"
+msgstr ""
+#: ../raster/r.external/main.c:394
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/main.c:397
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/main.c:422
+#, c-format
+msgid "Unable to create cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/main.c:425
+#, c-format
+msgid "Error writing cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/main.c:438
+msgid "Unable to write quant file"
+msgstr ""
+#: ../raster/r.external/main.c:470
+#, c-format
+msgid "Creating support files for %s"
+msgstr ""
+#: ../raster/r.external/main.c:507
+msgid "Link GDAL supported raster file to a binary raster map layer."
+msgstr ""
+#: ../raster/r.external/main.c:510
+msgid "Raster file to be linked"
+msgstr ""
+#: ../raster/r.external/main.c:516
+msgid "Name of non-file GDAL data source"
+msgstr ""
+#: ../raster/r.external/main.c:528
+msgid "Band to select"
+msgstr ""
+#: ../raster/r.external/main.c:550
+msgid "Require exact range"
+msgstr ""
+#: ../raster/r.external/main.c:584
+msgid "Name for input source not specified"
+msgstr ""
+#: ../raster/r.external/main.c:587
+msgid "input= and source= are mutually exclusive"
+msgstr ""
+#: ../raster/r.external/main.c:618
+msgid "Unable to set window"
+msgstr ""
#: ../vector/v.net.visibility/main.c:46
msgid "vector, path, visibility"
msgstr ""
@@ -13587,6 +11592,11 @@
msgid "Lat-long projection"
msgstr ""
+#: ../vector/v.db.connect/main.c:50 ../vector/v.distance/main.c:115
+#: ../vector/v.db.select/main.c:52 ../vector/v.to.db/main.c:32
+msgid "vector, database, attribute table"
+msgstr ""
#: ../vector/v.db.connect/main.c:52
msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
@@ -13599,109 +11609,109 @@
msgid "Must refer to an integer column"
msgstr ""
-#: ../vector/v.db.connect/main.c:77
+#: ../vector/v.db.connect/main.c:80
msgid "Print all map connection parameters and exit"
msgstr ""
-#: ../vector/v.db.connect/main.c:81
+#: ../vector/v.db.connect/main.c:84
msgid "Print all map connection parameters and exit in shell script style"
msgstr ""
-#: ../vector/v.db.connect/main.c:84
+#: ../vector/v.db.connect/main.c:87
msgid "Format: layer[/layer name] table key database driver"
msgstr ""
-#: ../vector/v.db.connect/main.c:89
+#: ../vector/v.db.connect/main.c:92
msgid "Print types/names of table columns for specified layer and exit"
msgstr ""
-#: ../vector/v.db.connect/main.c:95
+#: ../vector/v.db.connect/main.c:98
msgid "Overwrite connection parameter for certain layer"
msgstr ""
-#: ../vector/v.db.connect/main.c:100
+#: ../vector/v.db.connect/main.c:103
msgid "Delete connection for certain layer (not the table)"
msgstr ""
-#: ../vector/v.db.connect/main.c:129
+#: ../vector/v.db.connect/main.c:132
msgid "Please choose only one print style"
msgstr ""
-#: ../vector/v.db.connect/main.c:135
+#: ../vector/v.db.connect/main.c:138
msgid "Unable to modify vector map stored in other mapset"
msgstr ""
-#: ../vector/v.db.connect/main.c:142 ../vector/v.info/main.c:186
+#: ../vector/v.db.connect/main.c:145 ../vector/v.info/main.c:186
#, c-format
msgid "Database connection for map <%s> is not defined in DB file"
msgstr ""
-#: ../vector/v.db.connect/main.c:148
+#: ../vector/v.db.connect/main.c:151
#, c-format
msgid "Vector map <%s> is connected by:"
msgstr ""
-#: ../vector/v.db.connect/main.c:153 ../display/d.what.vect/what.c:435
-#: ../display/d.vect/main.c:495 ../display/d.thematic.area/main.c:227
+#: ../vector/v.db.connect/main.c:156 ../display/d.what.vect/what.c:435
+#: ../display/d.vect/main.c:495 ../display/d.thematic.area/main.c:226
#, c-format
msgid "Database connection not defined"
msgstr ""
-#: ../vector/v.db.connect/main.c:169
+#: ../vector/v.db.connect/main.c:175
#, c-format
msgid ""
"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
-#: ../vector/v.db.connect/main.c:178 ../vector/v.edit/select.c:506
+#: ../vector/v.db.connect/main.c:184 ../vector/v.edit/select.c:506
#: ../vector/v.distance/main.c:354 ../vector/v.distance/main.c:390
-#: ../vector/v.db.select/main.c:99 ../vector/v.what.rast/main.c:126
+#: ../vector/v.db.select/main.c:136 ../vector/v.what.rast/main.c:126
#: ../vector/v.extrude/main.c:161 ../vector/v.sample/main.c:167
#: ../vector/v.generalize/misc.c:160 ../vector/v.surf.idw/read_sites.c:34
#: ../vector/v.overlay/main.c:273 ../vector/v.to.rast/support.c:126
#: ../vector/v.to.rast/support.c:277 ../vector/v.to.rast/vect2rast.c:51
-#: ../vector/v.extract/main.c:233 ../doc/vector/v.example/main.c:103
+#: ../vector/v.extract/main.c:270 ../doc/vector/v.example/main.c:103
#, c-format
msgid "Database connection not defined for layer %d"
msgstr ""
-#: ../vector/v.db.connect/main.c:231
+#: ../vector/v.db.connect/main.c:237
#, c-format
msgid "Use -o to overwrite existing link for layer <%d>"
msgstr ""
-#: ../vector/v.db.connect/main.c:239 ../vector/v.db.connect/main.c:279
+#: ../vector/v.db.connect/main.c:245 ../vector/v.db.connect/main.c:285
#, c-format
msgid "Table <%s> does not exist in database <%s>"
msgstr ""
-#: ../vector/v.db.connect/main.c:254 ../vector/v.transform/trans_digit.c:93
+#: ../vector/v.db.connect/main.c:260 ../vector/v.transform/trans_digit.c:93
#: ../vector/v.in.db/main.c:137
#, c-format
msgid "Missing column <%s> in table <%s>"
msgstr ""
-#: ../vector/v.db.connect/main.c:260 ../vector/v.in.db/main.c:140
+#: ../vector/v.db.connect/main.c:266 ../vector/v.in.db/main.c:140
msgid "Data type of key column must be integer"
msgstr ""
-#: ../vector/v.db.connect/main.c:267 ../vector/v.db.connect/main.c:285
+#: ../vector/v.db.connect/main.c:273 ../vector/v.db.connect/main.c:291
#, c-format
msgid ""
"The table <%s> is now part of vector map <%s> and may be deleted or "
"overwritten by GRASS modules"
msgstr ""
-#: ../vector/v.db.connect/main.c:306 ../vector/v.in.ogr/main.c:778
+#: ../vector/v.db.connect/main.c:312 ../vector/v.in.ogr/main.c:778
#, c-format
msgid "Cannot grant privileges on table %s"
msgstr ""
-#: ../vector/v.db.connect/main.c:309
+#: ../vector/v.db.connect/main.c:315
msgid "Select privileges were granted on the table"
msgstr ""
-#: ../vector/v.db.connect/main.c:316
+#: ../vector/v.db.connect/main.c:322
msgid ""
"For defining a new connection you have to specify these parameters: driver, "
"database, table [, key [, layer]]"
@@ -13760,6 +11770,18 @@
msgid "Unable to close new 3d raster map"
msgstr ""
+#: ../vector/v.external/main.c:58 ../vector/v.perturb/main.c:73
+#: ../vector/v.out.ascii/out.c:43 ../vector/v.sample/main.c:86
+#: ../vector/v.in.region/main.c:38 ../vector/v.info/main.c:64
+#: ../vector/v.info/main.c:248 ../vector/v.patch/main.c:68
+#: ../vector/v.vol.rst/main.c:202 ../vector/v.mkgrid/main.c:62
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.voronoi/dt_main.c:46
+#: ../vector/v.voronoi/vo_main.c:119 ../vector/v.out.vtk/main.c:46
+#: ../vector/v.select/main.c:132 ../vector/v.surf.rst/main.c:160
+#: ../vector/v.buffer/main.c:254 ../vector/v.extract/main.c:91
+msgid "vector"
+msgstr ""
#: ../vector/v.external/main.c:60
msgid "Creates a new vector as a read-only link to OGR layer."
msgstr ""
@@ -13907,7 +11929,7 @@
msgid "Unable to get category list <%s>"
msgstr ""
-#: ../vector/v.edit/main.c:77 ../vector/v.in.ascii/in.c:195
+#: ../vector/v.edit/main.c:77 ../vector/v.in.ascii/in.c:198
#, c-format
msgid "Unable to open ASCII file <%s>"
msgstr ""
@@ -13931,7 +11953,7 @@
#: ../vector/v.edit/main.c:148
#, c-format
msgid ""
-"Unable to open vector map <%s> as the backround map. It is given as vector "
+"Unable to open vector map <%s> as the background map. It is given as vector "
"map to be edited."
msgstr ""
@@ -14075,7 +12097,9 @@
#: ../vector/v.in.ogr/main.c:145 ../vector/v.in.ogr/main.c:167
#: ../display/d.vect/main.c:144 ../display/d.vect/main.c:149
#: ../display/d.vect/main.c:152 ../display/d.vect/main.c:155
-#: ../display/d.vect/main.c:358 ../display/d.thematic.area/main.c:134
+#: ../display/d.vect/main.c:358 ../display/d.thematic.area/main.c:133
+#: ../display/d.rast/main.c:67 ../display/d.rast/main.c:76
+#: ../display/d.rast/main.c:93
msgid "Query"
msgstr ""
@@ -14145,8 +12169,8 @@
#: ../vector/v.edit/args.c:173
msgid ""
-"length;Select only lines or boudaries shorter/longer than threshold distance;"
-"dangle;Select dangles shorter/longer than threshold distance"
+"length;Select only lines or boundaries shorter/longer than threshold "
+"distance;dangle;Select dangles shorter/longer than threshold distance"
msgstr ""
#: ../vector/v.edit/args.c:181
@@ -14173,7 +12197,7 @@
msgid "Pair: value,step (e.g. 1100,10)"
msgstr ""
-#: ../vector/v.edit/args.c:204 ../vector/v.extract/main.c:90
+#: ../vector/v.edit/args.c:204 ../vector/v.extract/main.c:106
msgid "Reverse selection"
msgstr ""
@@ -14185,7 +12209,7 @@
msgid "Do not expect header of input data"
msgstr ""
-#: ../vector/v.edit/args.c:224 ../vector/v.in.dxf/main.c:78
+#: ../vector/v.edit/args.c:224 ../vector/v.in.dxf/main.c:74
#: ../vector/v.random/main.c:130
msgid "Do not build topology"
msgstr ""
@@ -14215,6 +12239,15 @@
msgid "Tool %s requires option %s"
msgstr ""
+#: ../vector/v.in.dxf/add_line.c:28 ../vector/v.in.dxf/add_point.c:27
+#: ../vector/v.in.dxf/add_polyline.c:107
+#: ../vector/v.in.dxf/add_lwpolyline.c:33 ../vector/v.in.dxf/add_circle.c:32
+#: ../vector/v.in.dxf/add_arc.c:36 ../vector/v.in.dxf/add_text.c:35
+#: ../vector/v.in.dxf/add_3dface.c:29
+#, c-format
+msgid "Layer %d: %s\n"
+msgstr ""
#: ../vector/v.in.dxf/add_polyline.c:46
msgid "vertices following flag missing"
msgstr ""
@@ -14224,14 +12257,6 @@
msgid "3-d data in dxf file. Polyline_flag: %d"
msgstr ""
-#: ../vector/v.in.dxf/add_polyline.c:107 ../vector/v.in.dxf/add_line.c:28
-#: ../vector/v.in.dxf/add_point.c:27 ../vector/v.in.dxf/add_lwpolyline.c:33
-#: ../vector/v.in.dxf/add_circle.c:32 ../vector/v.in.dxf/add_arc.c:36
-#: ../vector/v.in.dxf/add_text.c:35 ../vector/v.in.dxf/add_3dface.c:29
-#, c-format
-msgid "Layer %d: %s\n"
-msgstr ""
#: ../vector/v.in.dxf/write_vect.c:58 ../vector/v.in.ascii/points.c:401
#: ../vector/v.in.sites/main.c:240 ../vector/v.mkgrid/main.c:285
#, c-format
@@ -14251,7 +12276,7 @@
msgid "Layer %d: %s"
msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:214 ../vector/v.in.ascii/in.c:496
+#: ../vector/v.in.dxf/write_vect.c:214 ../vector/v.in.ascii/in.c:499
#: ../vector/v.in.sites/main.c:174
#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
@@ -14266,58 +12291,73 @@
msgid "end of file while looking for HEADER"
msgstr ""
+#: ../vector/v.in.dxf/main.c:60 ../vector/v.in.ascii/in.c:48
+#: ../vector/v.in.ogr/main.c:102 ../vector/v.in.dwg/main.c:65
+#: ../vector/v.in.db/main.c:52
+msgid "vector, import"
+msgstr ""
#: ../vector/v.in.dxf/main.c:62
msgid "Converts files in DXF format to GRASS vector map format."
msgstr ""
-#: ../vector/v.in.dxf/main.c:70
+#: ../vector/v.in.dxf/main.c:66
msgid "Ignore the map extent of DXF file"
msgstr ""
-#: ../vector/v.in.dxf/main.c:74
+#: ../vector/v.in.dxf/main.c:70
msgid "Do not create attribute tables"
msgstr ""
-#: ../vector/v.in.dxf/main.c:83
-msgid "Invert selection by layers (don't import layers in list)"
+#: ../vector/v.in.dxf/main.c:78
+msgid "Import polyface meshes as 3D wire frame"
msgstr ""
-#: ../vector/v.in.dxf/main.c:87
-msgid "Import all objects into one layer"
+#: ../vector/v.in.dxf/main.c:82
+msgid "List available layers and exit"
msgstr ""
-#: ../vector/v.in.dxf/main.c:91
-msgid "Import polyface meshes as 3D wire frame"
+#: ../vector/v.in.dxf/main.c:83 ../vector/v.in.dxf/main.c:89
+#: ../vector/v.in.dxf/main.c:94 ../vector/v.in.dxf/main.c:108
+msgid "DXF layers"
msgstr ""
-#: ../vector/v.in.dxf/main.c:94
+#: ../vector/v.in.dxf/main.c:88
+msgid "Invert selection by layers (don't import layers in list)"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:93
+msgid "Import all objects into one layer"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:97
msgid "Name of input DXF file"
msgstr ""
-#: ../vector/v.in.dxf/main.c:104
+#: ../vector/v.in.dxf/main.c:107
msgid "List of layers to import"
msgstr ""
-#: ../vector/v.in.dxf/main.c:118
+#: ../vector/v.in.dxf/main.c:122
#, c-format
msgid "Unable to open DXF file <%s>"
msgstr ""
-#: ../vector/v.in.dxf/main.c:153
+#: ../vector/v.in.dxf/main.c:157
#, c-format
msgid "Option <%s>: <%s> exists."
msgstr ""
-#: ../vector/v.in.dxf/main.c:158
+#: ../vector/v.in.dxf/main.c:162
#, c-format
msgid "Use '%s' option to change vector map name"
msgstr ""
-#: ../vector/v.in.dxf/main.c:185
+#: ../vector/v.in.dxf/main.c:189
msgid "Building topology failed"
msgstr ""
-#: ../vector/v.in.dxf/main.c:191
+#: ../vector/v.in.dxf/main.c:195
msgid "Failed to import DXF file!"
msgstr ""
@@ -14473,7 +12513,7 @@
msgstr ""
#: ../vector/lidar/v.lidar.edgedetection/main.c:342
-msgid "Creating auxiliar table for archiving overlaping zones"
+msgid "Creating auxiliar table for archiving overlapping zones"
msgstr ""
#: ../vector/lidar/v.lidar.edgedetection/main.c:345
@@ -14563,6 +12603,13 @@
msgid "Correction and creation of terrain vector"
msgstr ""
+#: ../vector/lidar/v.outlier/main.c:66 ../vector/v.univar/main.c:64
+#: ../vector/v.class/main.c:45 ../vector/v.qcount/main.c:69
+#: ../vector/v.random/main.c:84 ../vector/v.kcv/main.c:76
+#: ../vector/v.normal/main.c:79
+msgid "vector, statistics"
+msgstr ""
#: ../vector/lidar/v.outlier/main.c:67
msgid "Removes outliers from vector point data."
msgstr ""
@@ -14752,7 +12799,7 @@
msgid "CrossCorrelation: No point lies into the current region"
msgstr ""
-#: ../vector/lidar/v.surf.bspline/main.c:77 ../vector/v.surf.idw/main.c:83
+#: ../vector/lidar/v.surf.bspline/main.c:77 ../vector/v.surf.idw/main.c:84
msgid "vector, interpolation"
msgstr ""
@@ -14813,7 +12860,7 @@
"a raster output or other driver."
msgstr ""
-#: ../vector/lidar/v.surf.bspline/main.c:298 ../display/d.vect/plot1.c:194
+#: ../vector/lidar/v.surf.bspline/main.c:298 ../display/d.vect/plot1.c:197
#: ../display/d.vect/area.c:54 ../display/d.thematic.area/plot1.c:193
msgid "Cannot read field info"
msgstr ""
@@ -15031,7 +13078,7 @@
msgstr ""
#: ../vector/v.distance/main.c:438
-msgid "Incomatible column types"
+msgid "Incompatible column types"
msgstr ""
#: ../vector/v.distance/main.c:511
@@ -15278,185 +13325,185 @@
msgid "Number of header lines to skip at top of input file (points mode)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:85 ../vector/v.in.ascii/in.c:97
-#: ../vector/v.in.ascii/in.c:107 ../vector/v.in.ascii/in.c:117
-#: ../vector/v.in.ascii/in.c:129 ../vector/v.in.ascii/in.c:152
+#: ../vector/v.in.ascii/in.c:88 ../vector/v.in.ascii/in.c:100
+#: ../vector/v.in.ascii/in.c:110 ../vector/v.in.ascii/in.c:120
+#: ../vector/v.in.ascii/in.c:132 ../vector/v.in.ascii/in.c:155
msgid "Columns"
msgstr ""
-#: ../vector/v.in.ascii/in.c:86
+#: ../vector/v.in.ascii/in.c:89
msgid "Column definition in SQL style (points mode)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:87
+#: ../vector/v.in.ascii/in.c:90
msgid ""
"For example: 'x double precision, y double precision, cat int, name varchar"
"(10)'"
msgstr ""
-#: ../vector/v.in.ascii/in.c:99
+#: ../vector/v.in.ascii/in.c:102
msgid ""
"Number of column used as x coordinate (first column is 1) for points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:109
+#: ../vector/v.in.ascii/in.c:112
msgid ""
"Number of column used as y coordinate (first column is 1) for points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:119
+#: ../vector/v.in.ascii/in.c:122
msgid ""
"Number of column used as z coordinate (first column is 1) for points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:121
+#: ../vector/v.in.ascii/in.c:124
msgid "If 0, z coordinate is not used"
msgstr ""
-#: ../vector/v.in.ascii/in.c:131
+#: ../vector/v.in.ascii/in.c:134
msgid "Number of column used as category (first column is 1) for points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:133
+#: ../vector/v.in.ascii/in.c:136
msgid ""
"If 0, unique category is assigned to each row and written to new column 'cat'"
msgstr ""
-#: ../vector/v.in.ascii/in.c:137
+#: ../vector/v.in.ascii/in.c:140
msgid "Create 3D vector map"
msgstr ""
-#: ../vector/v.in.ascii/in.c:142
+#: ../vector/v.in.ascii/in.c:145
msgid "Create a new empty vector map and exit. Nothing is read from input"
msgstr ""
-#: ../vector/v.in.ascii/in.c:147
+#: ../vector/v.in.ascii/in.c:150
msgid "Don't expect a header when reading in standard format"
msgstr ""
-#: ../vector/v.in.ascii/in.c:151
+#: ../vector/v.in.ascii/in.c:154
msgid "Do not create table in points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:156
+#: ../vector/v.in.ascii/in.c:159
msgid "Do not build topology in points mode"
msgstr ""
-#: ../vector/v.in.ascii/in.c:161
+#: ../vector/v.in.ascii/in.c:164
msgid "Only import points falling within current region (points mode)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:175
+#: ../vector/v.in.ascii/in.c:178
msgid "Please specify reasonable number of lines to skip"
msgstr ""
-#: ../vector/v.in.ascii/in.c:178
+#: ../vector/v.in.ascii/in.c:181
msgid "Please specify z column"
msgstr ""
-#: ../vector/v.in.ascii/in.c:189
+#: ../vector/v.in.ascii/in.c:192
msgid "Please specify reasonable z column"
msgstr ""
-#: ../vector/v.in.ascii/in.c:247
+#: ../vector/v.in.ascii/in.c:250
#, c-format
msgid "Maximum input row length: %d"
msgstr ""
-#: ../vector/v.in.ascii/in.c:248
+#: ../vector/v.in.ascii/in.c:251
#, c-format
msgid "Maximum number of columns: %d"
msgstr ""
-#: ../vector/v.in.ascii/in.c:249
+#: ../vector/v.in.ascii/in.c:252
#, c-format
msgid "Minimum number of columns: %d"
msgstr ""
-#: ../vector/v.in.ascii/in.c:254
+#: ../vector/v.in.ascii/in.c:257
msgid ""
"x column number > minimum last column number\n"
"(incorrect field separator?)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:258
+#: ../vector/v.in.ascii/in.c:261
msgid ""
"y column number > minimum last column number\n"
msgstr ""
-#: ../vector/v.in.ascii/in.c:262
+#: ../vector/v.in.ascii/in.c:265
msgid ""
"z column number > minimum last column number (incorrect field separator?)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:267
+#: ../vector/v.in.ascii/in.c:270
msgid ""
"cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:273
+#: ../vector/v.in.ascii/in.c:276
msgid "x column is not of number type"
msgstr ""
-#: ../vector/v.in.ascii/in.c:277
+#: ../vector/v.in.ascii/in.c:280
msgid "y column is not of number type"
msgstr ""
-#: ../vector/v.in.ascii/in.c:281
+#: ../vector/v.in.ascii/in.c:284
msgid "z column is not of number type"
msgstr ""
-#: ../vector/v.in.ascii/in.c:285
+#: ../vector/v.in.ascii/in.c:288
msgid "cat column is not of number type"
msgstr ""
-#: ../vector/v.in.ascii/in.c:327
+#: ../vector/v.in.ascii/in.c:330
msgid "Category column is not of integer type"
msgstr ""
-#: ../vector/v.in.ascii/in.c:408
+#: ../vector/v.in.ascii/in.c:411
#, c-format
msgid ""
"Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr ""
-#: ../vector/v.in.ascii/in.c:436
+#: ../vector/v.in.ascii/in.c:439
#, c-format
msgid "Column number %d <%s> defined as double has only integer values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:441
+#: ../vector/v.in.ascii/in.c:444
#, c-format
msgid "Column number %d <%s> defined as string has only integer values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:449
+#: ../vector/v.in.ascii/in.c:452
#, c-format
msgid "Column number %d <%s> defined as integer has double values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:454
+#: ../vector/v.in.ascii/in.c:457
#, c-format
msgid "Column number %d <%s> defined as string has double values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:462
+#: ../vector/v.in.ascii/in.c:465
#, c-format
msgid "Column number %d <%s> defined as integer has string values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:468
+#: ../vector/v.in.ascii/in.c:471
#, c-format
msgid "Column number %d <%s> defined as double has string values"
msgstr ""
-#: ../vector/v.in.ascii/in.c:474
+#: ../vector/v.in.ascii/in.c:477
#, c-format
msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
msgstr ""
-#: ../vector/v.in.ascii/in.c:514
+#: ../vector/v.in.ascii/in.c:517
msgid "Populating table..."
msgstr ""
@@ -15585,8 +13632,8 @@
msgid "'output' must be given for old version"
msgstr ""
-#: ../vector/v.out.ascii/out.c:123 ../vector/v.out.vtk/main.c:174
-msgid "Failed to interprete 'dp' parameter as an integer"
+#: ../vector/v.out.ascii/out.c:123 ../vector/v.out.vtk/main.c:186
+msgid "Failed to interpret 'dp' parameter as an integer"
msgstr ""
#: ../vector/v.out.ascii/out.c:159
@@ -15696,19 +13743,47 @@
msgid "%d lines written to output map (%d lost)"
msgstr ""
-#: ../vector/v.db.select/main.c:49
+#: ../vector/v.db.select/main.c:53
msgid "Prints vector map attributes."
msgstr ""
-#: ../vector/v.db.select/main.c:126
+#: ../vector/v.db.select/main.c:64 ../vector/v.db.select/main.c:70
+#: ../vector/v.db.select/main.c:77 ../vector/v.db.select/main.c:87
+#: ../vector/v.db.select/main.c:92
+msgid "Format"
+msgstr ""
+#: ../vector/v.db.select/main.c:82
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
+msgstr ""
+#: ../vector/v.db.select/main.c:128
+#, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
+msgstr ""
+#: ../vector/v.db.select/main.c:163
msgid "Unable to open select cursor"
msgstr ""
-#: ../vector/v.db.select/main.c:145
+#: ../vector/v.db.select/main.c:184
#, c-format
msgid "Unable to fetch data from table <%s>"
msgstr ""
+#: ../vector/v.db.select/main.c:230
+#, c-format
+msgid "Unable to get bounding box of area %d"
+msgstr ""
+#: ../vector/v.db.select/main.c:235
+#, c-format
+msgid "Unable to get bounding box of line %d"
+msgstr ""
#: ../vector/v.univar/main.c:66
msgid ""
"Calculates univariate statistics for attribute. Variance and standard "
@@ -15741,17 +13816,17 @@
msgid "Column name or expression"
msgstr ""
-#: ../vector/v.class/main.c:68 ../display/d.thematic.area/main.c:106
+#: ../vector/v.class/main.c:68 ../display/d.thematic.area/main.c:105
msgid "Algorithm to use for classification"
msgstr ""
-#: ../vector/v.class/main.c:69 ../display/d.thematic.area/main.c:107
+#: ../vector/v.class/main.c:69 ../display/d.thematic.area/main.c:106
msgid ""
"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
"(normal distribution);"
msgstr ""
-#: ../vector/v.class/main.c:80 ../display/d.thematic.area/main.c:118
+#: ../vector/v.class/main.c:80 ../display/d.thematic.area/main.c:117
msgid "Number of classes to define"
msgstr ""
@@ -15773,12 +13848,12 @@
"Classification of %s into %i classes\n"
msgstr ""
-#: ../vector/v.class/main.c:195 ../display/d.thematic.area/main.c:471
+#: ../vector/v.class/main.c:195 ../display/d.thematic.area/main.c:461
#, c-format
msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../vector/v.class/main.c:196 ../display/d.thematic.area/main.c:473
+#: ../vector/v.class/main.c:196 ../display/d.thematic.area/main.c:463
#, c-format
msgid "Mean: %f\tStandard deviation = %f\n"
msgstr ""
@@ -15788,7 +13863,7 @@
msgid "Lowest chi2 = %f\n"
msgstr ""
-#: ../vector/v.class/main.c:203 ../display/d.thematic.area/main.c:480
+#: ../vector/v.class/main.c:203 ../display/d.thematic.area/main.c:470
#, c-format
msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
@@ -15900,17 +13975,17 @@
msgstr ""
#: ../vector/v.build.polylines/main.c:128
-msgid "Do not print polyline info"
+msgid "Unused"
msgstr ""
-#: ../vector/v.build.polylines/main.c:209
+#: ../vector/v.build.polylines/main.c:206
#, c-format
msgid "%d lines or boundaries found in vector map <%s@%s>"
msgstr ""
-#: ../vector/v.build.polylines/main.c:211
+#: ../vector/v.build.polylines/main.c:208
#, c-format
-msgid "%d polylines stored to vector map <%s%s>"
+msgid "%d polylines stored in vector map <%s@%s>"
msgstr ""
#: ../vector/v.net.iso/main.c:72
@@ -16037,7 +14112,7 @@
msgid "Extruding areas..."
msgstr ""
-#: ../vector/v.extrude/main.c:202 ../vector/v.out.svg/main.c:216
+#: ../vector/v.extrude/main.c:202 ../vector/v.out.svg/main.c:215
#, c-format
msgid "Skipping area %d without centroid"
msgstr ""
@@ -16048,7 +14123,7 @@
msgstr ""
#: ../vector/v.extrude/main.c:256
-msgid "Extruding basic vector objects..."
+msgid "Extruding vector primitives..."
msgstr ""
#: ../vector/v.extrude/main.c:289
@@ -16264,6 +14339,22 @@
msgid "Unable to calculate the output vectors"
msgstr ""
+#: ../vector/v.generalize/displacement.c:78
+msgid "Reading data..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:196
+msgid "Inverting matrix..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:198
+msgid "Unable to calculate the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:201
+msgid "Resolving conflicts..."
+msgstr ""
#: ../vector/v.generalize/main.c:79
msgid ""
"vector, generalization, simplification, smoothing, displacement, network "
@@ -16380,32 +14471,16 @@
msgid "Number of vertices was reduced from %d to %d [%d%%]"
msgstr ""
-#: ../vector/v.generalize/displacement.c:78
-msgid "Reading data..."
-msgstr ""
-#: ../vector/v.generalize/displacement.c:196
-msgid "Inverting matrix..."
-msgstr ""
-#: ../vector/v.generalize/displacement.c:198
-msgid "Unable to calculate the inverse matrix"
-msgstr ""
-#: ../vector/v.generalize/displacement.c:201
-msgid "Resolving conflicts..."
-msgstr ""
#: ../vector/v.generalize/network.c:163
msgid "Calculating centrality measures..."
msgstr ""
-#: ../vector/v.generalize/misc.c:124 ../vector/v.extract/main.c:317
+#: ../vector/v.generalize/misc.c:124 ../vector/v.extract/main.c:422
msgid "Writing attributes..."
msgstr ""
#: ../vector/v.generalize/misc.c:156 ../vector/v.voronoi/vo_main.c:323
-#: ../vector/v.select/main.c:482 ../vector/v.extract/main.c:350
+#: ../vector/v.select/main.c:482 ../vector/v.extract/main.c:455
#, c-format
msgid "Layer %d"
msgstr ""
@@ -16521,7 +14596,7 @@
#: ../vector/v.info/main.c:275
#, c-format
-msgid " Map is 3D: %d"
+msgid " Map is 3D: %s"
msgstr ""
#: ../vector/v.info/main.c:278
@@ -16747,7 +14822,7 @@
msgstr ""
#: ../vector/v.in.ogr/main.c:761 ../vector/v.surf.rst/main.c:559
-#: ../display/d.vect/plot1.c:199 ../display/d.vect/area.c:59
+#: ../display/d.vect/plot1.c:202 ../display/d.vect/area.c:59
#: ../display/d.vect/attr.c:45 ../display/d.thematic.area/plot1.c:198
#, c-format
msgid "Cannot open database %s by driver %s"
@@ -16920,7 +14995,7 @@
msgstr ""
#: ../vector/v.in.sites/main.c:183
-msgid "Transfering sites to vector point map..."
+msgid "Transferring sites to vector point map..."
msgstr ""
#: ../vector/v.in.sites/main.c:255
@@ -17069,43 +15144,48 @@
msgid "%d points loaded"
msgstr ""
-#: ../vector/v.surf.idw/main.c:85
+#: ../vector/v.surf.idw/main.c:86
msgid ""
"Surface interpolation from vector point data by Inverse Distance Squared "
"Weighting."
msgstr ""
-#: ../vector/v.surf.idw/main.c:102
+#: ../vector/v.surf.idw/main.c:106
+msgid ""
+"Power parameter; greater values assign greater influence to closer points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:110
msgid "If set to 0, z coordinates are used (3D vector only)"
msgstr ""
-#: ../vector/v.surf.idw/main.c:109
+#: ../vector/v.surf.idw/main.c:117
msgid "Attribute table column with values to interpolate"
msgstr ""
-#: ../vector/v.surf.idw/main.c:110
+#: ../vector/v.surf.idw/main.c:118
msgid "Required if layer > 0"
msgstr ""
-#: ../vector/v.surf.idw/main.c:114
+#: ../vector/v.surf.idw/main.c:122
msgid "Don't index points by raster cell"
msgstr ""
-#: ../vector/v.surf.idw/main.c:115
+#: ../vector/v.surf.idw/main.c:123
msgid ""
"Slower but uses less memory and includes points from outside region in the "
"interpolation"
msgstr ""
-#: ../vector/v.surf.idw/main.c:133
+#: ../vector/v.surf.idw/main.c:141
msgid "No attribute column specified"
msgstr ""
-#: ../vector/v.surf.idw/main.c:167
+#: ../vector/v.surf.idw/main.c:176
msgid "No data points found"
msgstr ""
-#: ../vector/v.surf.idw/main.c:252
+#: ../vector/v.surf.idw/main.c:261
#, c-format
msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
msgstr ""
@@ -17443,11 +15523,19 @@
msgid "Please answer yes or no"
msgstr ""
+#: ../vector/v.transform/creat_trans.c:118
+msgid "Error reading coordinates file"
+msgstr ""
#: ../vector/v.transform/creat_trans.c:123
#, c-format
msgid "Number of points that have been entered [%d]"
msgstr ""
+#: ../vector/v.transform/creat_trans.c:126
+msgid "Error creating transformation"
+msgstr ""
#: ../vector/v.transform/setup_trans.c:83
msgid "The points weren't spread out enough."
msgstr ""
@@ -17558,6 +15646,10 @@
"in the same layer are separated by '/'"
msgstr ""
+#: ../vector/v.category/main.c:104
+msgid "Category increment"
+msgstr ""
#: ../vector/v.category/main.c:108
msgid "Feature id(s)"
msgstr ""
@@ -17664,46 +15756,6 @@
msgid "Generating points..."
msgstr ""
-#: ../vector/v.convert/old2new.c:31
-msgid "Failed opening input dig file."
-msgstr ""
-#: ../vector/v.convert/old2new.c:46
-msgid "dig_att file doesn't exist."
-msgstr ""
-#: ../vector/v.convert/old2new.c:50
-msgid "Failed opening input dig_att file."
-msgstr ""
-#: ../vector/v.convert/old2new.c:72
-msgid "Attaching categories..."
-msgstr ""
-#: ../vector/v.convert/old2new.c:89
-#, c-format
-msgid "Failed to attach an attribute (category %d) to a line."
-msgstr ""
-#: ../vector/v.convert/old2new.c:94
-#, c-format
-msgid "Line %d label: %d matched another label: %d."
-msgstr ""
-#: ../vector/v.convert/old2new.c:103
-msgid "Writing new file..."
-msgstr ""
-#: ../vector/v.convert/old2new.c:125
-#, c-format
-msgid "[%d] points and lines written to output file."
-msgstr ""
-#: ../vector/v.convert/old2new.c:139
-#, c-format
-msgid "[%d] centroids written to output file."
-msgstr ""
#: ../vector/v.convert/type.c:29
#, c-format
msgid "OLD_T_NEW Got a bad type code [%x]"
@@ -17748,6 +15800,46 @@
msgid "Cannot insert into table: %s"
msgstr ""
+#: ../vector/v.convert/old2new.c:31
+msgid "Failed opening input dig file."
+msgstr ""
+#: ../vector/v.convert/old2new.c:46
+msgid "dig_att file doesn't exist."
+msgstr ""
+#: ../vector/v.convert/old2new.c:50
+msgid "Failed opening input dig_att file."
+msgstr ""
+#: ../vector/v.convert/old2new.c:72
+msgid "Attaching categories..."
+msgstr ""
+#: ../vector/v.convert/old2new.c:89
+#, c-format
+msgid "Failed to attach an attribute (category %d) to a line."
+msgstr ""
+#: ../vector/v.convert/old2new.c:94
+#, c-format
+msgid "Line %d label: %d matched another label: %d."
+msgstr ""
+#: ../vector/v.convert/old2new.c:103
+msgid "Writing new file..."
+msgstr ""
+#: ../vector/v.convert/old2new.c:125
+#, c-format
+msgid "[%d] points and lines written to output file."
+msgstr ""
+#: ../vector/v.convert/old2new.c:139
+#, c-format
+msgid "[%d] centroids written to output file."
+msgstr ""
#: ../vector/v.convert/read.c:41
msgid "Reading dig file..."
msgstr ""
@@ -17969,8 +16061,9 @@
msgid "Unknown column type '%s'"
msgstr ""
-#: ../vector/v.overlay/main.c:351 ../vector/v.out.svg/main.c:371
-#: ../vector/v.out.ogr/main.c:699 ../vector/v.lrs/v.lrs.label/main.c:347
+#: ../vector/v.overlay/main.c:351 ../vector/v.out.svg/main.c:370
+#: ../vector/v.out.vtk/writeVTK.c:579 ../vector/v.out.ogr/main.c:701
+#: ../vector/v.lrs/v.lrs.label/main.c:347
msgid "Unable to fetch data from table"
msgstr ""
@@ -18103,7 +16196,7 @@
msgstr ""
#: ../vector/v.label.sa/labels.c:145 ../vector/v.label/main.c:297
-#: ../display/d.vect/plot1.c:291
+#: ../display/d.vect/plot1.c:294
msgid "Unable to read vector map"
msgstr ""
@@ -18120,63 +16213,65 @@
msgid "Create optimally placed labels for vector map(s)"
msgstr ""
-#: ../vector/v.label.sa/main.c:131 ../vector/v.label/main.c:79
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label/main.c:79
msgid "Name of attribute column to be used for labels"
msgstr ""
-#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:68
+#: ../vector/v.label.sa/main.c:134 ../vector/v.label/main.c:68
msgid "Name for new paint-label file"
msgstr ""
-#: ../vector/v.label.sa/main.c:145
+#: ../vector/v.label.sa/main.c:144
msgid "Name of TrueType font (as listed in the fontcap)"
msgstr ""
-#: ../vector/v.label.sa/main.c:146 ../vector/v.label.sa/main.c:154
+#: ../vector/v.label.sa/main.c:145 ../vector/v.label.sa/main.c:153
#: ../vector/v.label/main.c:126 ../vector/v.label/main.c:133
#: ../vector/v.label/main.c:141 ../vector/v.label/main.c:149
#: ../vector/v.lrs/v.lrs.label/main.c:180
msgid "Font"
msgstr ""
-#: ../vector/v.label.sa/main.c:151 ../vector/v.label/main.c:130
+#: ../vector/v.label.sa/main.c:150 ../vector/v.label/main.c:130
#: ../vector/v.lrs/v.lrs.label/main.c:186
msgid "Label size (in map-units)"
msgstr ""
-#: ../vector/v.label.sa/main.c:158
+#: ../vector/v.label.sa/main.c:157
msgid "Icon size of point features (in map-units)"
msgstr ""
-#: ../vector/v.label.sa/main.c:172 ../vector/v.label/main.c:152
-#: ../vector/v.lrs/v.lrs.label/main.c:193 ../display/d.grid/main.c:85
+#: ../vector/v.label.sa/main.c:171 ../vector/v.label/main.c:152
+#: ../vector/v.lrs/v.lrs.label/main.c:193 ../display/d.grid/main.c:86
+#: ../display/d.rhumbline/main.c:70
msgid "Text color"
msgstr ""
-#: ../vector/v.label.sa/main.c:181
-msgid "Hilight color for text"
+#: ../vector/v.label.sa/main.c:180 ../vector/v.label/main.c:175
+#: ../vector/v.lrs/v.lrs.label/main.c:210
+msgid "Highlight color for text"
msgstr ""
-#: ../vector/v.label.sa/main.c:191 ../vector/v.label/main.c:181
+#: ../vector/v.label.sa/main.c:190 ../vector/v.label/main.c:181
msgid "Width of highlight coloring"
msgstr ""
-#: ../vector/v.label.sa/main.c:198 ../vector/v.label/main.c:188
+#: ../vector/v.label.sa/main.c:197 ../vector/v.label/main.c:188
#: ../vector/v.lrs/v.lrs.label/main.c:228 ../display/d.path/main.c:116
#: ../general/g.pnmcomp/main.c:334
msgid "Background color"
msgstr ""
-#: ../vector/v.label.sa/main.c:209 ../vector/v.label/main.c:201
+#: ../vector/v.label.sa/main.c:208 ../vector/v.label/main.c:201
msgid "Opaque to vector (only relevant if background color is selected)"
msgstr ""
-#: ../vector/v.label.sa/main.c:218 ../vector/v.label/main.c:194
+#: ../vector/v.label.sa/main.c:217 ../vector/v.label/main.c:194
#: ../vector/v.lrs/v.lrs.label/main.c:237 ../display/d.grid/main.c:80
msgid "Border color"
msgstr ""
-#: ../vector/v.label.sa/main.c:228
+#: ../vector/v.label.sa/main.c:227
msgid "Border width (only for ps.map output)"
msgstr ""
@@ -18485,7 +16580,7 @@
msgstr ""
#: ../vector/v.net/main.c:118
-msgid "Unknow operation"
+msgid "Unknown operation"
msgstr ""
#: ../vector/v.net/main.c:122
@@ -18534,6 +16629,19 @@
msgid "%d points found: %.3lf %.3lf %.3lf line category: %d"
msgstr ""
+#: ../vector/v.out.dxf/main.c:50
+msgid "Exports GRASS vector map layers to DXF file format."
+msgstr ""
+#: ../vector/v.out.dxf/main.c:60
+msgid "DXF output file"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:97
+#, c-format
+msgid "%d features written to '%s'."
+msgstr ""
#: ../vector/v.out.dxf/write_dxf.c:21
#, c-format
msgid "The file '%s' already exists."
@@ -18549,19 +16657,6 @@
msgid "%s: Cannot write dxf file."
msgstr ""
-#: ../vector/v.out.dxf/main.c:50
-msgid "Exports GRASS vector map layers to DXF file format."
-msgstr ""
-#: ../vector/v.out.dxf/main.c:60
-msgid "DXF output file"
-msgstr ""
-#: ../vector/v.out.dxf/main.c:97
-#, c-format
-msgid "%d features written to '%s'."
-msgstr ""
#: ../vector/v.normal/main.c:80
msgid "Tests for normality for points."
msgstr ""
@@ -18598,7 +16693,7 @@
msgid "Output tessellation as a graph (lines), not areas"
msgstr ""
-#: ../vector/v.voronoi/vo_main.c:328 ../vector/v.extract/main.c:355
+#: ../vector/v.voronoi/vo_main.c:328 ../vector/v.extract/main.c:460
msgid "No table"
msgstr ""
@@ -18616,114 +16711,114 @@
msgid "Nothing Found.\n"
msgstr ""
-#: ../vector/v.what/what.c:136
+#: ../vector/v.what/what.c:135
#, c-format
msgid ""
-"Line: %d \n"
-"Type: %s \n"
-"Left: %d \n"
-"Right: %d \n"
+"Id: %d\n"
+"Type: %s\n"
+"Left: %d\n"
+"Right: %d\n"
msgstr ""
-#: ../vector/v.what/what.c:140 ../vector/v.what/what.c:174
+#: ../vector/v.what/what.c:139 ../vector/v.what/what.c:173
#: ../display/d.what.vect/what.c:235
#, c-format
msgid "Length: %f\n"
msgstr ""
-#: ../vector/v.what/what.c:156
+#: ../vector/v.what/what.c:155
#, c-format
msgid ""
-"Node[%d]: %d \n"
-"Number of lines: %d \n"
+"Node[%d]: %d\n"
+"Number of lines: %d\n"
"Coordinates: %.6f, %.6f, %.6f\n"
msgstr ""
-#: ../vector/v.what/what.c:164
+#: ../vector/v.what/what.c:163
#, c-format
msgid ""
-"Line: %5d \n"
+"Id: %5d\n"
"Angle: %.8f\n"
msgstr ""
-#: ../vector/v.what/what.c:171
+#: ../vector/v.what/what.c:170
#, c-format
msgid "Type: %s"
msgstr ""
-#: ../vector/v.what/what.c:172
+#: ../vector/v.what/what.c:171
#, c-format
-msgid "Line: %d\n"
+msgid "Id: %d\n"
msgstr ""
-#: ../vector/v.what/what.c:183 ../display/d.what.vect/what.c:289
+#: ../vector/v.what/what.c:182 ../display/d.what.vect/what.c:289
#, c-format
msgid "Point height: %f\n"
msgstr ""
-#: ../vector/v.what/what.c:194 ../display/d.what.vect/what.c:307
+#: ../vector/v.what/what.c:193 ../display/d.what.vect/what.c:307
#, c-format
msgid "Line height: %f\n"
msgstr ""
-#: ../vector/v.what/what.c:198
+#: ../vector/v.what/what.c:197
#, c-format
msgid ""
-"Line height min: %f \n"
+"Line height min: %f\n"
"Line height max: %f\n"
msgstr ""
-#: ../vector/v.what/what.c:207
+#: ../vector/v.what/what.c:206
#, c-format
msgid ""
-"Object type: Area \n"
+"Type: Area\n"
"Area height: %f\n"
msgstr ""
-#: ../vector/v.what/what.c:211
+#: ../vector/v.what/what.c:210
#, c-format
-msgid "Object type: Area\n"
+msgid "Type: Area\n"
msgstr ""
-#: ../vector/v.what/what.c:218
+#: ../vector/v.what/what.c:217
#, c-format
msgid ""
-"Area: %d \n"
+"Area: %d\n"
"Number of isles: %d\n"
msgstr ""
-#: ../vector/v.what/what.c:223
+#: ../vector/v.what/what.c:222
#, c-format
msgid "Isle[%d]: %d\n"
msgstr ""
-#: ../vector/v.what/what.c:230
+#: ../vector/v.what/what.c:229
#, c-format
msgid "Island: %d In area: %d\n"
msgstr ""
-#: ../vector/v.what/what.c:235 ../vector/v.what/what.c:242
+#: ../vector/v.what/what.c:234 ../vector/v.what/what.c:241
#, c-format
msgid ""
-"Sq Meters: %.3f \n"
+"Sq Meters: %.3f\n"
"Hectares: %.3f\n"
msgstr ""
-#: ../vector/v.what/what.c:237 ../vector/v.what/what.c:245
+#: ../vector/v.what/what.c:236 ../vector/v.what/what.c:244
#, c-format
msgid ""
-"Acres: %.3f \n"
+"Acres: %.3f\n"
"Sq Miles: %.4f\n"
msgstr ""
-#: ../vector/v.what/what.c:263
+#: ../vector/v.what/what.c:262
#, c-format
msgid ""
"Layer: %d\n"
-"Category: %d \n"
+"Category: %d\n"
msgstr ""
-#: ../vector/v.what/what.c:270
+#: ../vector/v.what/what.c:269
#, c-format
msgid ""
"\n"
@@ -18830,47 +16925,47 @@
msgid "Attribute(s) to include in output SVG"
msgstr ""
-#: ../vector/v.out.svg/main.c:117
+#: ../vector/v.out.svg/main.c:116
msgid "Precision must not be negative"
msgstr ""
-#: ../vector/v.out.svg/main.c:120
+#: ../vector/v.out.svg/main.c:119
msgid "Precision must not be higher than 15"
msgstr ""
-#: ../vector/v.out.svg/main.c:191
+#: ../vector/v.out.svg/main.c:190
#, c-format
msgid "Unable to open SVG file <%s>"
msgstr ""
-#: ../vector/v.out.svg/main.c:206
+#: ../vector/v.out.svg/main.c:205
msgid "No areas found, skipping type=poly"
msgstr ""
-#: ../vector/v.out.svg/main.c:243
+#: ../vector/v.out.svg/main.c:242
#, c-format
msgid "Extracted %d areas"
msgstr ""
-#: ../vector/v.out.svg/main.c:249
+#: ../vector/v.out.svg/main.c:248
msgid "No points found, skipping type=point"
msgstr ""
-#: ../vector/v.out.svg/main.c:272
+#: ../vector/v.out.svg/main.c:271
#, c-format
msgid "Extracted %d points"
msgstr ""
-#: ../vector/v.out.svg/main.c:278
+#: ../vector/v.out.svg/main.c:277
msgid "No lines found, skipping type=line"
msgstr ""
-#: ../vector/v.out.svg/main.c:299
+#: ../vector/v.out.svg/main.c:298
#, c-format
msgid "Extracted %d lines"
msgstr ""
-#: ../vector/v.out.svg/main.c:367
+#: ../vector/v.out.svg/main.c:366
#, c-format
msgid "Cannot select attributes for cat=%d"
msgstr ""
@@ -18946,10 +17041,6 @@
msgid "Value to upload"
msgstr ""
-#: ../vector/v.to.db/parse.c:82
-msgid "Units"
-msgstr ""
#: ../vector/v.to.db/parse.c:84
msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)"
msgstr ""
@@ -19033,24 +17124,55 @@
"No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:696
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:622
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:630
+msgid "No attribute table found"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:662
+msgid "No numerical attributes found. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:716 ../vector/v.out.vtk/writeVTK.c:743
+#: ../vector/v.out.vtk/writeVTK.c:770 ../vector/v.out.vtk/writeVTK.c:796
+#, c-format
+msgid "Error reading value of attribute '%s'"
+msgstr ""
#: ../vector/v.out.vtk/head.c:27
msgid "writeVTKHeader: Writing VTK-Header"
msgstr ""
-#: ../vector/v.out.vtk/main.c:47
+#: ../vector/v.out.vtk/main.c:48
msgid "Converts a GRASS binary vector map to VTK ASCII output."
msgstr ""
-#: ../vector/v.out.vtk/main.c:57
+#: ../vector/v.out.vtk/main.c:58
msgid "Path to resulting VTK file"
msgstr ""
-#: ../vector/v.out.vtk/main.c:176
+#: ../vector/v.out.vtk/main.c:83
+msgid "Layer number"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:93
+msgid "Export numeric attribute table fields as VTK scalar variables"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:188
msgid "dp has to be from 0 to 8"
msgstr ""
-#: ../vector/v.out.vtk/main.c:185
-msgid "Failed to interprete 'layer' parameter as an integer"
+#: ../vector/v.out.vtk/main.c:197
+msgid "Failed to interpret 'layer' parameter as an integer"
msgstr ""
#: ../vector/v.support/main.c:40
@@ -19169,7 +17291,7 @@
#: ../vector/v.label/main.c:91 ../vector/v.label/main.c:96
#: ../vector/v.label/main.c:171 ../vector/v.label/main.c:184
-#: ../general/g.region/main.c:143 ../general/g.region/main.c:346
+#: ../general/g.region/main.c:142 ../general/g.region/main.c:345
msgid "Effects"
msgstr ""
@@ -19215,10 +17337,6 @@
msgid "Border width"
msgstr ""
-#: ../vector/v.label/main.c:175 ../vector/v.lrs/v.lrs.label/main.c:210
-msgid "Highlight color for text"
-msgstr ""
#: ../vector/v.label/main.c:234 ../imagery/i.class/main.c:90
#: ../imagery/i.points/main.c:80
#: ../imagery/i.ortho.photo/photo.2target/main.c:90
@@ -19226,18 +17344,19 @@
#: ../display/d.profile/main.c:134 ../display/d.measure/main.c:87
#: ../display/d.what.vect/main.c:160 ../display/d.font/main.c:86
#: ../display/d.rast.num/number.c:128 ../display/d.linegraph/linegraph.c:251
-#: ../display/d.what.rast/main.c:109 ../display/d.text/main.c:132
-#: ../display/d.font.freetype/main.c:103 ../display/d.info/main.c:73
-#: ../display/d.legend/main.c:274 ../display/d.graph/main.c:96
-#: ../display/d.vect/main.c:401 ../display/d.vect.chart/main.c:257
-#: ../display/d.rast.arrow/arrow.c:245 ../display/d.menu/main.c:108
-#: ../display/d.thematic.area/main.c:406 ../display/d.text.freetype/main.c:310
-#: ../display/d.rast/main.c:114 ../display/d.extract/main.c:79
-#: ../display/d.rgb/main.c:89 ../display/d.where/main.c:144
-#: ../display/d.paint.labels/main.c:90 ../display/d.barscale/main.c:137
-#: ../display/d.text.new/main.c:284 ../display/d.his/main.c:117
-#: ../display/d.zoom/main.c:158 ../display/d.zoom/main.c:293
-#: ../display/d.zoom/redraw.c:39 ../display/d.grid/main.c:182
+#: ../display/d.what.rast/main.c:109 ../display/d.geodesic/main.c:105
+#: ../display/d.text/main.c:132 ../display/d.font.freetype/main.c:103
+#: ../display/d.info/main.c:73 ../display/d.legend/main.c:274
+#: ../display/d.graph/main.c:96 ../display/d.vect/main.c:401
+#: ../display/d.vect.chart/main.c:257 ../display/d.rast.arrow/arrow.c:245
+#: ../display/d.menu/main.c:108 ../display/d.thematic.area/main.c:396
+#: ../display/d.text.freetype/main.c:310 ../display/d.rast/main.c:113
+#: ../display/d.extract/main.c:79 ../display/d.rgb/main.c:89
+#: ../display/d.where/main.c:144 ../display/d.paint.labels/main.c:90
+#: ../display/d.barscale/main.c:137 ../display/d.text.new/main.c:284
+#: ../display/d.his/main.c:117 ../display/d.zoom/main.c:158
+#: ../display/d.zoom/main.c:293 ../display/d.zoom/redraw.c:39
+#: ../display/d.grid/main.c:186 ../display/d.rhumbline/main.c:108
#: ../display/d.nviz/main.c:249 ../display/d.extend/main.c:41
#: ../display/d.frame/select.c:36 ../display/d.frame/frame.c:129
#: ../display/d.frame/frame.c:183 ../display/d.frame/frame.c:223
@@ -19387,10 +17506,10 @@
msgstr ""
#: ../vector/v.surf.rst/main.c:402
-msgid "You are not outputing any raster or vector maps"
+msgid "You are not outputting any raster or vector maps"
msgstr ""
-#: ../vector/v.surf.rst/main.c:406 ../vector/v.extract/main.c:229
+#: ../vector/v.surf.rst/main.c:406 ../vector/v.extract/main.c:266
#: ../display/d.vect/main.c:492
msgid "'layer' must be > 0 for 'where'."
msgstr ""
@@ -19499,19 +17618,10 @@
msgid "%d points written to vector map"
msgstr ""
-#: ../vector/v.in.db/main.c:219 ../vector/v.extract/main.c:370
+#: ../vector/v.in.db/main.c:219 ../vector/v.extract/main.c:475
msgid "Unable to copy table"
msgstr ""
-#: ../vector/v.to.rast/do_lines.c:63 ../vector/v.to.rast/do_areas.c:61
-msgid "Unable to use column specified"
-msgstr ""
-#: ../vector/v.to.rast/do_lines.c:122
-#, c-format
-msgid "%d lines with varying height were not written to raster"
-msgstr ""
#: ../vector/v.to.rast/main.c:38
msgid "vector, raster, conversion"
msgstr ""
@@ -19568,6 +17678,15 @@
msgid "Unknown option '%s'"
msgstr ""
+#: ../vector/v.to.rast/do_lines.c:63 ../vector/v.to.rast/do_areas.c:61
+msgid "Unable to use column specified"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:122
+#, c-format
+msgid "%d lines with varying height were not written to raster"
+msgstr ""
#: ../vector/v.to.rast/support.c:138 ../vector/v.to.rast/support.c:290
#, c-format
msgid "Unknown column <%s> in table <%s>"
@@ -19869,24 +17988,19 @@
#: ../vector/v.out.ogr/main.c:643
#, c-format
-msgid "%d features without category written"
+msgid "%d features without category were written"
msgstr ""
#: ../vector/v.out.ogr/main.c:645
#, c-format
-msgid "%d features without attributes written"
+msgid "%d features without attributes were written"
msgstr ""
#: ../vector/v.out.ogr/main.c:647
#, c-format
-msgid "%d features found without category skip"
+msgid "%d features found without category were skipped"
msgstr ""
-#: ../vector/v.out.ogr/main.c:694
-#, c-format
-msgid "Cannot select attributes for cat = %d"
-msgstr ""
#: ../vector/v.net.steiner/main.c:58
#, c-format
msgid "Init costs from node %d"
@@ -19911,7 +18025,7 @@
msgstr ""
#: ../vector/v.net.steiner/main.c:389
-msgid "Number of steiner poins (-1 for all possible)"
+msgid "Number of steiner points (-1 for all possible)"
msgstr ""
#: ../vector/v.net.steiner/main.c:453
@@ -20571,74 +18685,112 @@
msgid "Error in pj_do_transform"
msgstr ""
-#: ../vector/v.extract/main.c:77
+#: ../vector/v.extract/main.c:93
msgid ""
"Selects vector objects from an existing vector map and creates a new map "
"containing only the selected objects."
msgstr ""
-#: ../vector/v.extract/main.c:82
+#: ../vector/v.extract/main.c:98
msgid "Dissolve common boundaries (default is no)"
msgstr ""
-#: ../vector/v.extract/main.c:86
+#: ../vector/v.extract/main.c:102
msgid "Do not copy table (see also 'new' parameter)"
msgstr ""
-#: ../vector/v.extract/main.c:99
+#: ../vector/v.extract/main.c:115
msgid "Types to be extracted "
msgstr ""
-#: ../vector/v.extract/main.c:103
+#: ../vector/v.extract/main.c:119
msgid "If -1, all features in all layers of given type are extracted"
msgstr ""
-#: ../vector/v.extract/main.c:111
+#: ../vector/v.extract/main.c:127
msgid "Enter -1 to keep original categories or the desired NEW category value"
msgstr ""
-#: ../vector/v.extract/main.c:112
+#: ../vector/v.extract/main.c:128
msgid "If new >= 0, table is not copied"
msgstr ""
-#: ../vector/v.extract/main.c:121
+#: ../vector/v.extract/main.c:137
msgid "Input text file with category numbers/number ranges to be extracted"
msgstr ""
-#: ../vector/v.extract/main.c:122
+#: ../vector/v.extract/main.c:138
msgid "If '-' given reads from standard input"
msgstr ""
-#: ../vector/v.extract/main.c:156
+#: ../vector/v.extract/main.c:145
+msgid "Number of random categories matching vector objects to extract"
+msgstr ""
+#: ../vector/v.extract/main.c:147
+msgid "Number must be smaller than unique Cat count in layer"
+msgstr ""
+#: ../vector/v.extract/main.c:167
+msgid ""
+"List, file, where and random options are exclusive. Please specify only one "
+"of them"
+msgstr ""
+#: ../vector/v.extract/main.c:196
msgid "Layer 0 not supported"
msgstr ""
-#: ../vector/v.extract/main.c:183
+#: ../vector/v.extract/main.c:220
#, c-format
msgid "Category value in '%s' not valid"
msgstr ""
-#: ../vector/v.extract/main.c:199
+#: ../vector/v.extract/main.c:236
#, c-format
msgid "Process file <%s> for category numbers"
msgstr ""
-#: ../vector/v.extract/main.c:204
+#: ../vector/v.extract/main.c:241
#, c-format
msgid "Unable to open specified file <%s>"
msgstr ""
-#: ../vector/v.extract/main.c:214
+#: ../vector/v.extract/main.c:251
#, c-format
msgid "Ignored text entry: %s"
msgstr ""
-#: ../vector/v.extract/main.c:252
+#: ../vector/v.extract/main.c:289
#, c-format
msgid "%d categories loaded from table <%s>"
msgstr ""
-#: ../vector/v.extract/main.c:387
+#: ../vector/v.extract/main.c:304
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
+msgstr ""
+#: ../vector/v.extract/main.c:310
+msgid "Please specify random number larger than 0"
+msgstr ""
+#: ../vector/v.extract/main.c:314
+#, c-format
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
+msgstr ""
+#: ../vector/v.extract/main.c:337
+#, c-format
+msgid ""
+"Random category count is larger or equal to uniq \"%s\" feature category "
+"count %d"
+msgstr ""
+#: ../vector/v.extract/main.c:492
msgid "Removing duplicate centroids..."
msgstr ""
@@ -20669,17 +18821,17 @@
#: ../doc/vector/v.example/main.c:167
#, c-format
-msgid "Unabale to get attribute data for cat %d"
+msgid "Unable to get attribute data for cat %d"
msgstr ""
#: ../doc/vector/v.example/main.c:176
#, c-format
-msgid "Error while retreiving database record for cat %d"
+msgid "Error while retrieving database record for cat %d"
msgstr ""
#: ../doc/vector/v.example/main.c:209
#, c-format
-msgid "Unable to copy atribute table to vector map <%s>"
+msgid "Unable to copy attribute table to vector map <%s>"
msgstr ""
#: ../ps/ps.map/ps_vlines.c:55 ../ps/ps.map/ps_vareas.c:163
@@ -20727,7 +18879,7 @@
msgid "Outlining areas in raster map <%s in %s> ..."
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:30 ../ps/ps.map/ps_fclrtbl.c:40
+#: ../ps/ps.map/ps_clrtbl.c:30 ../ps/ps.map/ps_fclrtbl.c:46
#, c-format
msgid "Creating color table for <%s in %s>..."
msgstr ""
@@ -20738,7 +18890,7 @@
msgid "Category file for <%s> not available"
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:39 ../ps/ps.map/ps_fclrtbl.c:63
+#: ../ps/ps.map/ps_clrtbl.c:39 ../ps/ps.map/ps_fclrtbl.c:69
msgid "Unable to read colors for colorbar"
msgstr ""
@@ -20749,13 +18901,13 @@
"assigned to this output postscript file."
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:62 ../ps/ps.map/ps_fclrtbl.c:86
-#: ../ps/ps.map/ps_fclrtbl.c:91
+#: ../ps/ps.map/ps_clrtbl.c:62 ../ps/ps.map/ps_fclrtbl.c:92
+#: ../ps/ps.map/ps_fclrtbl.c:97
msgid "Colorbar y location beyond page margins. Adjusting."
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:68 ../ps/ps.map/ps_fclrtbl.c:97
-#: ../ps/ps.map/ps_fclrtbl.c:102
+#: ../ps/ps.map/ps_clrtbl.c:68 ../ps/ps.map/ps_fclrtbl.c:103
+#: ../ps/ps.map/ps_fclrtbl.c:108
msgid "Colorbar x location beyond page margins. Adjusting."
msgstr ""
@@ -20789,15 +18941,15 @@
"GRASS. Please use <%s> instead."
msgstr ""
-#: ../ps/ps.map/scale.c:138
+#: ../ps/ps.map/scale.c:137
msgid "PSmap: do_scale(): shouldn't happen"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:45
+#: ../ps/ps.map/ps_fclrtbl.c:51
msgid "Range information not available (run r.support)"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:58
+#: ../ps/ps.map/ps_fclrtbl.c:64
msgid "A floating point colortable must contain a range of values"
msgstr ""
@@ -20820,7 +18972,7 @@
msgid "Reading vector map <%s in %s> ..."
msgstr ""
-#: ../ps/ps.map/do_vectors.c:133
+#: ../ps/ps.map/do_vectors.c:139
#, c-format
msgid "Reading vector points file <%s in %s> ..."
msgstr ""
@@ -21053,40 +19205,35 @@
msgid "Power 2 values : [%d] rows [%d] columns."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:136 ../imagery/i.zc/main.c:156
-#: ../imagery/i.fft/fftmain.c:163
-msgid "Insufficent memory for allocation of data structure"
-msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:139
+#: ../imagery/i.ifft/ifftmain.c:137
msgid "Reading the raster maps..."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:146
+#: ../imagery/i.ifft/ifftmain.c:144
msgid "Masking the raster maps..."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:167
+#: ../imagery/i.ifft/ifftmain.c:165
msgid "Rotating data arrays..."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:206
+#: ../imagery/i.ifft/ifftmain.c:204
msgid "Starting Inverse FFT..."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:208
+#: ../imagery/i.ifft/ifftmain.c:206
msgid "Inverse FFT completed..."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:215
+#: ../imagery/i.ifft/ifftmain.c:213
msgid "Unable to open output file."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:220
+#: ../imagery/i.ifft/ifftmain.c:218
msgid "Writing data to file..."
msgstr ""
-#: ../imagery/i.ifft/ifftmain.c:246 ../imagery/i.fft/fftmain.c:284
+#: ../imagery/i.ifft/ifftmain.c:244 ../imagery/i.fft/fftmain.c:282
msgid "Transform successful."
msgstr ""
@@ -21265,15 +19412,6 @@
msgid "Output saturation raster map"
msgstr ""
-#: ../imagery/i.smap/bouman/segment.c:69
-msgid "Number of classes must be < 256!"
-msgstr ""
-#: ../imagery/i.smap/bouman/segment.c:93
-#, c-format
-msgid "Processing rows %d-%d (of %d), cols=%d-%d (of %d)"
-msgstr ""
#: ../imagery/i.smap/bouman/model.c:38
#, c-format
msgid ""
@@ -21310,10 +19448,25 @@
msgid "interp: invalid parameter values."
msgstr ""
+#: ../imagery/i.smap/bouman/segment.c:69
+msgid "Number of classes must be < 256!"
+msgstr ""
+#: ../imagery/i.smap/bouman/segment.c:93
+#, c-format
+msgid "Processing rows %d-%d (of %d), cols=%d-%d (of %d)"
+msgstr ""
#: ../imagery/i.smap/bouman/multialloc.c:115
msgid "get_img: out of memory."
msgstr ""
+#: ../imagery/i.smap/shapiro/main.c:40
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
#: ../imagery/i.smap/shapiro/openfiles.c:15
#: ../imagery/i.smap/shapiro/read_sig.c:13 ../imagery/i.gensig/openfiles.c:16
#, c-format
@@ -21326,12 +19479,6 @@
msgid "Subgroup [%s] in group [%s] contains no files."
msgstr ""
-#: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
#: ../imagery/i.smap/shapiro/write_img.c:13
#, c-format
msgid "Writing [%s] ..."
@@ -21465,14 +19612,6 @@
msgid "Eigen values:"
msgstr ""
-#: ../imagery/i.class/complete_reg.c:12
-msgid "Too few points for region. Must have at least 3 points."
-msgstr ""
-#: ../imagery/i.class/complete_reg.c:14
-msgid "Area already completed."
-msgstr ""
#: ../imagery/i.class/add_point.c:22
#, c-format
msgid "Can't mark another point. Only %d points allowed. Sorry."
@@ -21515,6 +19654,14 @@
msgid "Did not find input cell map MASK."
msgstr ""
+#: ../imagery/i.class/complete_reg.c:12
+msgid "Too few points for region. Must have at least 3 points."
+msgstr ""
+#: ../imagery/i.class/complete_reg.c:14
+msgid "Area already completed."
+msgstr ""
#: ../imagery/i.class/remove_mask.c:15
msgid "Error while removing the old MASK cell map."
msgstr ""
@@ -21845,19 +19992,19 @@
msgid "Power 2 values : %d rows %d columns"
msgstr ""
-#: ../imagery/i.zc/main.c:159
+#: ../imagery/i.zc/main.c:157
msgid "Initializing data..."
msgstr ""
-#: ../imagery/i.zc/main.c:172 ../imagery/i.fft/fftmain.c:184
+#: ../imagery/i.zc/main.c:170 ../imagery/i.fft/fftmain.c:182
msgid "Error while reading input raster map."
msgstr ""
-#: ../imagery/i.zc/main.c:190 ../imagery/i.fft/fftmain.c:237
+#: ../imagery/i.zc/main.c:188 ../imagery/i.fft/fftmain.c:235
msgid "Writing transformed data to file..."
msgstr ""
-#: ../imagery/i.zc/main.c:211
+#: ../imagery/i.zc/main.c:209
msgid "Transform successful"
msgstr ""
@@ -21919,27 +20066,27 @@
msgid "Range less than or equal to zero not allowed."
msgstr ""
-#: ../imagery/i.fft/fftmain.c:166
+#: ../imagery/i.fft/fftmain.c:164
msgid "Initializing data...\n"
msgstr ""
-#: ../imagery/i.fft/fftmain.c:181
+#: ../imagery/i.fft/fftmain.c:179
msgid "Reading the raster map..."
msgstr ""
-#: ../imagery/i.fft/fftmain.c:193
+#: ../imagery/i.fft/fftmain.c:191
msgid "Starting FFT..."
msgstr ""
-#: ../imagery/i.fft/fftmain.c:195
+#: ../imagery/i.fft/fftmain.c:193
msgid "FFT completed..."
msgstr ""
-#: ../imagery/i.fft/fftmain.c:213
+#: ../imagery/i.fft/fftmain.c:211
msgid "Rotating data..."
msgstr ""
-#: ../imagery/i.fft/fftmain.c:243
+#: ../imagery/i.fft/fftmain.c:241
msgid "Writing viewable versions of transformed data to files..."
msgstr ""
@@ -21956,28 +20103,6 @@
msgid "Unable to open temp file."
msgstr ""
-#: ../imagery/i.cluster/checkpt.c:16
-#, c-format
-msgid "using seed means (%d files)\n"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:28
-#, c-format
-msgid ""
-"\n"
-"######## iteration %d ###########\n"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:30
-#, c-format
-msgid "%d classes, %.2f%% points stable\n"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:40
-#, c-format
-msgid "Iteration %d: %% Convergence: %.2f (%s elapsed, %s left)"
-msgstr ""
#: ../imagery/i.cluster/print1.c:12
#, c-format
msgid ""
@@ -22049,6 +20174,33 @@
"\n"
msgstr ""
+#: ../imagery/i.cluster/checkpt.c:16
+#, c-format
+msgid "using seed means (%d files)\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:28
+#, c-format
+msgid ""
+"\n"
+"######## iteration %d ###########\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:30
+#, c-format
+msgid "%d classes, %.2f%% points stable\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:40
+#, c-format
+msgid "Iteration %d: %% Convergence: %.2f (%s elapsed, %s left)"
+msgstr ""
+#: ../imagery/i.cluster/print6.c:11
+#, c-format
+msgid "class distribution"
+msgstr ""
#: ../imagery/i.cluster/open_files.c:17
#, c-format
msgid ""
@@ -22082,24 +20234,19 @@
#: ../imagery/i.cluster/open_files.c:61
#, c-format
-msgid "** Can't open seed singature file <%s> **"
+msgid "Can't open seed signature file <%s>"
msgstr ""
#: ../imagery/i.cluster/open_files.c:67
#, c-format
-msgid "** Can't read signature file <%s> **"
+msgid "Can't read signature file <%s>"
msgstr ""
#: ../imagery/i.cluster/open_files.c:71
#, c-format
-msgid "** <%s> has too many signatures (limit is 255)"
+msgid "<%s> has too many signatures (limit is 255)"
msgstr ""
-#: ../imagery/i.cluster/print6.c:11
-#, c-format
-msgid "class distribution"
-msgstr ""
#: ../imagery/i.cluster/main.c:82
msgid ""
"Generates spectral signatures for land cover types in an image using a "
@@ -22377,12 +20524,12 @@
msgstr ""
#: ../imagery/i.ortho.photo/photo.2target/main.c:59
-msgid "Name of image to be rectified which will be initialy drawn on screen."
+msgid "Name of image to be rectified which will be initially drawn on screen."
msgstr ""
#: ../imagery/i.ortho.photo/photo.2target/main.c:65
msgid ""
-"Name of a map from target mapset which will be initialy drawn on screen."
+"Name of a map from target mapset which will be initially drawn on screen."
msgstr ""
#: ../imagery/i.ortho.photo/photo.2target/main.c:208
@@ -22499,22 +20646,6 @@
msgid "signature %d is not valid (singular) - ignored."
msgstr ""
-#: ../imagery/i.cca/transform.c:18
-msgid "Unable to allocate cell buffers."
-msgstr ""
-#: ../imagery/i.cca/transform.c:24
-msgid "Error reading cell map during transform."
-msgstr ""
-#: ../imagery/i.cca/transform.c:46
-msgid "Error writing cell map during transform."
-msgstr ""
-#: ../imagery/i.cca/transform.c:51
-msgid "Transform completed.\n"
-msgstr ""
#: ../imagery/i.cca/main.c:86
msgid "Canonical components analysis (cca) program for image processing."
msgstr ""
@@ -22574,6 +20705,22 @@
msgid "The output cell map <%s.%d> has values outside the 0-255 range."
msgstr ""
+#: ../imagery/i.cca/transform.c:18
+msgid "Unable to allocate cell buffers."
+msgstr ""
+#: ../imagery/i.cca/transform.c:24
+msgid "Error reading cell map during transform."
+msgstr ""
+#: ../imagery/i.cca/transform.c:46
+msgid "Error writing cell map during transform."
+msgstr ""
+#: ../imagery/i.cca/transform.c:51
+msgid "Transform completed.\n"
+msgstr ""
#: ../imagery/i.target/main.c:47
msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
@@ -22655,6 +20802,27 @@
msgid "Unable to map image file"
msgstr ""
+#: ../visualization/ximgview/main.c:270 ../display/d.histogram/main.c:71
+#: ../display/d.mapgraph/main.c:48 ../display/d.erase/main.c:32
+#: ../display/d.profile/main.c:61 ../display/d.measure/main.c:49
+#: ../display/d.colors/main.c:50 ../display/d.what.vect/main.c:54
+#: ../display/d.font/main.c:46 ../display/d.rast.num/number.c:84
+#: ../display/d.linegraph/linegraph.c:113 ../display/d.colorlist/main.c:35
+#: ../display/d.what.rast/main.c:45 ../display/d.title/main.c:45
+#: ../display/d.geodesic/main.c:45 ../display/d.text/main.c:66
+#: ../display/d.font.freetype/main.c:59 ../display/d.info/main.c:33
+#: ../display/d.save/main.c:79 ../display/d.rast.arrow/arrow.c:110
+#: ../display/d.menu/main.c:66 ../display/d.thematic.area/main.c:78
+#: ../display/d.text.freetype/main.c:138 ../display/d.extract/main.c:50
+#: ../display/d.rgb/main.c:55 ../display/d.where/main.c:42
+#: ../display/d.paint.labels/main.c:46 ../display/d.text.new/main.c:139
+#: ../display/d.ask/main.c:36 ../display/d.his/main.c:65
+#: ../display/d.zoom/main.c:57 ../display/d.rhumbline/main.c:45
+#: ../display/d.nviz/main.c:68 ../display/d.mon/cmd/main.c:48
+#: ../display/d.frame/frame.c:60
+msgid "display"
+msgstr ""
#: ../visualization/ximgview/main.c:271
msgid "View BMP images from the PNG driver."
msgstr ""
@@ -22748,7 +20916,7 @@
msgstr ""
#: ../visualization/nviz/src/nviz_init.c:130
-msgid "Load previosly saved state file"
+msgid "Load previously saved state file"
msgstr ""
#: ../visualization/nviz/src/nviz_init.c:279
@@ -22759,8 +20927,8 @@
msgid "Loading data failed"
msgstr ""
-#: ../visualization/nviz2/cmd/vector.c:166
-msgid "Unknow icon marker"
+#: ../visualization/nviz2/cmd/vector.c:181
+msgid "Unknown icon marker"
msgstr ""
#: ../visualization/nviz2/cmd/main.c:46
@@ -22811,23 +20979,23 @@
msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
msgstr ""
-#: ../visualization/nviz2/cmd/surface.c:71
+#: ../visualization/nviz2/cmd/surface.c:73
#, c-format
msgid "Missing topography attribute for surface %d"
msgstr ""
-#: ../visualization/nviz2/cmd/surface.c:117
+#: ../visualization/nviz2/cmd/surface.c:126
#, c-format
msgid "Color attribute not defined, using default <%s>"
msgstr ""
-#: ../visualization/nviz2/cmd/surface.c:194
+#: ../visualization/nviz2/cmd/surface.c:203
#, c-format
msgid "Surface id %d doesn't exist"
msgstr ""
-#: ../visualization/nviz2/cmd/surface.c:241
-#: ../visualization/nviz2/cmd/surface.c:248
+#: ../visualization/nviz2/cmd/surface.c:250
+#: ../visualization/nviz2/cmd/surface.c:257
#, c-format
msgid "Unable to set draw mode for surface id %d"
msgstr ""
@@ -22845,6 +21013,10 @@
msgid "Image"
msgstr ""
+#: ../visualization/nviz2/cmd/args.c:83
+msgid "Graphics file format"
+msgstr ""
#: ../visualization/nviz2/cmd/args.c:93
msgid "Width and height of output image"
msgstr ""
@@ -22909,8 +21081,8 @@
#: ../visualization/nviz2/cmd/args.c:213 ../visualization/nviz2/cmd/args.c:224
#: ../visualization/nviz2/cmd/args.c:235 ../visualization/nviz2/cmd/args.c:247
#: ../visualization/nviz2/cmd/args.c:259 ../visualization/nviz2/cmd/args.c:268
-#: ../visualization/nviz2/cmd/args.c:280 ../visualization/nviz2/cmd/args.c:477
-#: ../visualization/nviz2/cmd/args.c:489
+#: ../visualization/nviz2/cmd/args.c:280 ../visualization/nviz2/cmd/args.c:290
+#: ../visualization/nviz2/cmd/args.c:510 ../visualization/nviz2/cmd/args.c:522
msgid "Draw"
msgstr ""
@@ -22934,133 +21106,138 @@
msgid "Wire color"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:290
+#: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
+#: ../visualization/nviz2/cmd/args.c:426
+msgid "Position"
+msgstr ""
+#: ../visualization/nviz2/cmd/args.c:301
msgid "Name of line vector overlay map(s)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:291 ../visualization/nviz2/cmd/args.c:302
-#: ../visualization/nviz2/cmd/args.c:313 ../visualization/nviz2/cmd/args.c:325
-#: ../visualization/nviz2/cmd/args.c:335
+#: ../visualization/nviz2/cmd/args.c:302 ../visualization/nviz2/cmd/args.c:313
+#: ../visualization/nviz2/cmd/args.c:324 ../visualization/nviz2/cmd/args.c:336
+#: ../visualization/nviz2/cmd/args.c:346 ../visualization/nviz2/cmd/args.c:358
msgid "Vector lines"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:301
+#: ../visualization/nviz2/cmd/args.c:312
msgid "Vector line width"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:310
+#: ../visualization/nviz2/cmd/args.c:321
msgid "Vector line color"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:322
+#: ../visualization/nviz2/cmd/args.c:333
msgid "Vector line display mode"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:334
+#: ../visualization/nviz2/cmd/args.c:345
msgid "Vector line height"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:347
+#: ../visualization/nviz2/cmd/args.c:369
msgid "Name of point vector overlay map(s)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:348 ../visualization/nviz2/cmd/args.c:359
-#: ../visualization/nviz2/cmd/args.c:371 ../visualization/nviz2/cmd/args.c:382
-#: ../visualization/nviz2/cmd/args.c:395
+#: ../visualization/nviz2/cmd/args.c:370 ../visualization/nviz2/cmd/args.c:381
+#: ../visualization/nviz2/cmd/args.c:393 ../visualization/nviz2/cmd/args.c:404
+#: ../visualization/nviz2/cmd/args.c:417 ../visualization/nviz2/cmd/args.c:427
msgid "Vector points"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:358
+#: ../visualization/nviz2/cmd/args.c:380
msgid "Icon size"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:370
+#: ../visualization/nviz2/cmd/args.c:392
msgid "Icon width"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:379
+#: ../visualization/nviz2/cmd/args.c:401
msgid "Icon color"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:391
+#: ../visualization/nviz2/cmd/args.c:413
msgid "Icon marker"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:410
+#: ../visualization/nviz2/cmd/args.c:443
msgid "Viewpoint position (x,y model coordinates)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:411 ../visualization/nviz2/cmd/args.c:422
-#: ../visualization/nviz2/cmd/args.c:432 ../visualization/nviz2/cmd/args.c:444
+#: ../visualization/nviz2/cmd/args.c:444 ../visualization/nviz2/cmd/args.c:455
+#: ../visualization/nviz2/cmd/args.c:465 ../visualization/nviz2/cmd/args.c:477
msgid "Viewpoint"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:421
+#: ../visualization/nviz2/cmd/args.c:454
msgid "Viewpoint height (in map units)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:431
+#: ../visualization/nviz2/cmd/args.c:464
msgid "Viewpoint field of view (in degrees)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:443
+#: ../visualization/nviz2/cmd/args.c:476
msgid "Viewpoint twist angle (in degrees)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:464 ../visualization/nviz2/cmd/args.c:499
-#: ../visualization/nviz2/cmd/args.c:511 ../visualization/nviz2/cmd/args.c:521
+#: ../visualization/nviz2/cmd/args.c:497 ../visualization/nviz2/cmd/args.c:532
+#: ../visualization/nviz2/cmd/args.c:544 ../visualization/nviz2/cmd/args.c:554
msgid "Volume"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:474
+#: ../visualization/nviz2/cmd/args.c:507
msgid "Volume draw mode"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:486
+#: ../visualization/nviz2/cmd/args.c:519
msgid "Volume shading"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:498
+#: ../visualization/nviz2/cmd/args.c:531
msgid "Volume position"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:509
+#: ../visualization/nviz2/cmd/args.c:542
msgid "Volume resolution"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:520
+#: ../visualization/nviz2/cmd/args.c:553
msgid "Isosurface level"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:566
+#: ../visualization/nviz2/cmd/args.c:599
#, c-format
msgid "At least one <%s> or <%s> required"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:580 ../visualization/nviz2/cmd/args.c:610
-#: ../visualization/nviz2/cmd/args.c:622 ../visualization/nviz2/cmd/args.c:628
-#: ../visualization/nviz2/cmd/args.c:634 ../visualization/nviz2/cmd/args.c:640
+#: ../visualization/nviz2/cmd/args.c:613 ../visualization/nviz2/cmd/args.c:643
+#: ../visualization/nviz2/cmd/args.c:655 ../visualization/nviz2/cmd/args.c:661
+#: ../visualization/nviz2/cmd/args.c:667 ../visualization/nviz2/cmd/args.c:673
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:616
+#: ../visualization/nviz2/cmd/args.c:649
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:653 ../visualization/nviz2/cmd/args.c:667
-#: ../visualization/nviz2/cmd/args.c:674
+#: ../visualization/nviz2/cmd/args.c:686 ../visualization/nviz2/cmd/args.c:700
+#: ../visualization/nviz2/cmd/args.c:707
#, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:660
+#: ../visualization/nviz2/cmd/args.c:693
#, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d"
msgstr ""
-#: ../visualization/nviz2/cmd/args.c:686
+#: ../visualization/nviz2/cmd/args.c:719
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d"
msgstr ""
@@ -23081,10 +21258,18 @@
msgid "Can't clear current graphics window"
msgstr ""
-#: ../display/d.rast.edit/cell.c:86 ../display/d.rast/display.c:72
+#: ../display/d.rast.edit/cell.c:86 ../display/d.rast/display.c:75
msgid "Cannot use current window"
msgstr ""
+#: ../display/d.rast.edit/main.c:59 ../display/d.rast/main.c:51
+msgid "display, raster"
+msgstr ""
+#: ../display/d.rast.edit/main.c:61
+msgid "Interactively edit cell values in a raster map."
+msgstr ""
#: ../display/d.histogram/main.c:73
msgid ""
"Displays a histogram in the form of a pie or bar chart for a user-specified "
@@ -23132,7 +21317,7 @@
msgid "When -C flag is set, the nsteps argument is ignored"
msgstr ""
-#: ../display/d.histogram/main.c:171 ../display/d.legend/main.c:515
+#: ../display/d.histogram/main.c:171 ../display/d.legend/main.c:517
#, c-format
msgid "Range information for <%s> not available"
msgstr ""
@@ -23682,6 +21867,44 @@
msgid "No map name given"
msgstr ""
+#: ../display/d.geodesic/main.c:47
+msgid ""
+"Displays a geodesic line, tracing the shortest distance between two "
+"geographic points along a great circle, in a longitude/latitude data set."
+msgstr ""
+#: ../display/d.geodesic/main.c:56 ../display/d.rhumbline/main.c:55
+#: ../display/d.path/main.c:66
+msgid "Starting and ending coordinates"
+msgstr ""
+#: ../display/d.geodesic/main.c:62 ../display/d.vect/main.c:162
+#: ../display/d.rhumbline/main.c:61
+msgid "Line color"
+msgstr ""
+#: ../display/d.geodesic/main.c:70
+msgid "Text color or \"none\""
+msgstr ""
+#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:79
+#, c-format
+msgid "Location is not %s"
+msgstr ""
+#: ../display/d.geodesic/main.c:83 ../display/d.rhumbline/main.c:85
+#: ../display/d.path/main.c:143
+msgid "No coordinates given"
+msgstr ""
+#: ../display/d.geodesic/main.c:87 ../display/d.geodesic/main.c:91
+#: ../display/d.geodesic/main.c:95 ../display/d.geodesic/main.c:99
+#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:93
+#: ../display/d.rhumbline/main.c:98 ../display/d.rhumbline/main.c:102
+#, c-format
+msgid "%s - illegal longitude"
+msgstr ""
#: ../display/d.text/main.c:68 ../display/d.text.new/main.c:141
msgid ""
"Draws text in the active display frame on the graphics monitor using the "
@@ -23724,7 +21947,7 @@
#: ../display/d.text/main.c:147 ../display/d.graph/do_graph.c:112
#: ../display/d.graph/do_graph.c:393 ../display/d.graph/do_graph.c:408
#: ../display/d.graph/main.c:103 ../display/d.text.freetype/main.c:842
-#: ../display/d.paint.labels/color.c:66
+#: ../display/d.rast/display.c:32 ../display/d.paint.labels/color.c:66
#, c-format
msgid "[%s]: No such color"
msgstr ""
@@ -23774,7 +21997,7 @@
#: ../display/d.legend/main.c:86 ../display/d.graph/main.c:54
#: ../display/d.vect.chart/main.c:63 ../display/d.barscale/main.c:56
-#: ../display/d.grid/main.c:52
+#: ../display/d.grid/main.c:51
msgid "display, cartography"
msgstr ""
@@ -23784,6 +22007,10 @@
"monitor."
msgstr ""
+#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
+msgid "Name of raster map"
+msgstr ""
#: ../display/d.legend/main.c:99
msgid "Sets the legend's text color"
msgstr ""
@@ -23855,33 +22082,37 @@
msgid "Range information for <%s> not available (run r.support)"
msgstr ""
-#: ../display/d.legend/main.c:371 ../display/d.legend/main.c:529
+#: ../display/d.legend/main.c:360
+msgid "Input map contains no data"
+msgstr ""
+#: ../display/d.legend/main.c:373 ../display/d.legend/main.c:531
msgid "Color range exceeds lower limit of actual data"
msgstr ""
-#: ../display/d.legend/main.c:377 ../display/d.legend/main.c:533
+#: ../display/d.legend/main.c:379 ../display/d.legend/main.c:535
msgid "Color range exceeds upper limit of actual data"
msgstr ""
-#: ../display/d.legend/main.c:434
+#: ../display/d.legend/main.c:436
#, c-format
msgid "use=%s out of range [%d,%d] (extend with range= ?)"
msgstr ""
-#: ../display/d.legend/main.c:475
+#: ../display/d.legend/main.c:477
msgid "Nothing to draw! (no categories with labels? out of range?)"
msgstr ""
-#: ../display/d.legend/main.c:485
+#: ../display/d.legend/main.c:487
msgid "Forcing a smooth legend: too many categories for current window height"
msgstr ""
-#: ../display/d.legend/main.c:540
+#: ../display/d.legend/main.c:542
#, c-format
msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
msgstr ""
-#: ../display/d.legend/main.c:888
+#: ../display/d.legend/main.c:890
msgid "Nothing to draw! (no categories with labels?)"
msgstr ""
@@ -23971,12 +22202,11 @@
msgid "Can't read vector map"
msgstr ""
-#: ../display/d.vect/plot1.c:207 ../display/d.vect/area.c:68
-#: ../display/d.thematic.area/plot1.c:206
-msgid "Color definition column not specified."
+#: ../display/d.vect/plot1.c:210
+msgid "Color definition column not specified"
msgstr ""
-#: ../display/d.vect/plot1.c:217 ../display/d.vect/area.c:78
+#: ../display/d.vect/plot1.c:220 ../display/d.vect/area.c:78
#: ../display/d.thematic.area/plot1.c:216
#, c-format
msgid ""
@@ -23984,45 +22214,50 @@
"BBB where RGB values range 0-255."
msgstr ""
-#: ../display/d.vect/plot1.c:222 ../display/d.vect/plot1.c:250
+#: ../display/d.vect/plot1.c:225 ../display/d.vect/plot1.c:253
#: ../display/d.vect/area.c:84 ../display/d.vect/area.c:112
#: ../display/d.thematic.area/plot1.c:221
#: ../display/d.thematic.area/plot1.c:249
-#: ../display/d.thematic.area/main.c:255
+#: ../display/d.thematic.area/main.c:254
#, c-format
msgid "Cannot select data (%s) from table"
msgstr ""
-#: ../display/d.vect/plot1.c:235 ../display/d.vect/area.c:97
+#: ../display/d.vect/plot1.c:238 ../display/d.vect/area.c:97
#: ../display/d.thematic.area/plot1.c:234
msgid "Line width column not specified."
msgstr ""
-#: ../display/d.vect/plot1.c:246 ../display/d.vect/area.c:108
+#: ../display/d.vect/plot1.c:249 ../display/d.vect/area.c:108
#: ../display/d.thematic.area/plot1.c:245
#, c-format
msgid "Line width column (%s) not a number."
msgstr ""
-#: ../display/d.vect/plot1.c:384 ../display/d.thematic.area/plot1.c:365
+#: ../display/d.vect/plot1.c:387
#, c-format
msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring [%"
-"s]"
+"Error in color definition column '%s', feature id %d with cat %d: "
+"colorstring '%s'"
msgstr ""
-#: ../display/d.vect/plot1.c:391 ../display/d.thematic.area/plot1.c:372
+#: ../display/d.vect/plot1.c:395
#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
+msgid "Error in color definition column '%s', feature id %d with cat %d"
msgstr ""
-#: ../display/d.vect/plot1.c:459 ../display/d.vect/area.c:344
+#: ../display/d.vect/plot1.c:465 ../display/d.vect/area.c:344
#: ../display/d.thematic.area/plot1.c:440
#, c-format
msgid ""
"Error in line width column (%s), element %d with cat %d: line width [%d]"
msgstr ""
+#: ../display/d.vect/plot1.c:530
+#, c-format
+msgid "Error in color definition column '%s': %d features affected"
+msgstr ""
#: ../display/d.vect/topo.c:39 ../display/d.thematic.area/plot1.c:290
#, c-format
msgid ""
@@ -24042,14 +22277,10 @@
msgid "Display"
msgstr ""
-#: ../display/d.vect/main.c:148 ../display/d.thematic.area/main.c:131
+#: ../display/d.vect/main.c:148 ../display/d.thematic.area/main.c:130
msgid "Layer number. If -1, all layers are displayed."
msgstr ""
-#: ../display/d.vect/main.c:162
-msgid "Line color"
-msgstr ""
#: ../display/d.vect/main.c:166 ../display/d.vect/main.c:176
#: ../display/d.vect/main.c:264 ../display/d.vect/main.c:274
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
@@ -24150,7 +22381,7 @@
"Maximum region size (average from height and width) when map is displayed"
msgstr ""
-#: ../display/d.vect/main.c:328 ../display/d.thematic.area/main.c:158
+#: ../display/d.vect/main.c:328 ../display/d.thematic.area/main.c:157
msgid "Rendering method for filled polygons"
msgstr ""
@@ -24184,7 +22415,7 @@
msgstr ""
#: ../display/d.vect/main.c:369
-msgid "Colorize polygons according to z height)"
+msgid "Colorize polygons according to z height"
msgstr ""
#: ../display/d.vect/main.c:411 ../display/d.paint.labels/main.c:102
@@ -24202,7 +22433,7 @@
msgstr ""
#: ../display/d.vect/main.c:451 ../display/d.vect/main.c:466
-#: ../display/d.thematic.area/main.c:296
+#: ../display/d.thematic.area/main.c:317
#, c-format
msgid "Unknown color: [%s]"
msgstr ""
@@ -24216,11 +22447,11 @@
msgid "%d errors in cat option"
msgstr ""
-#: ../display/d.vect/main.c:637 ../display/d.thematic.area/main.c:411
+#: ../display/d.vect/main.c:637 ../display/d.thematic.area/main.c:401
msgid "Plotting ..."
msgstr ""
-#: ../display/d.vect/main.c:645 ../display/d.thematic.area/main.c:418
+#: ../display/d.vect/main.c:645 ../display/d.thematic.area/main.c:408
msgid ""
"The bounding box of the map is outside the current region, nothing drawn."
msgstr ""
@@ -24237,6 +22468,10 @@
msgid "Cannot display topology, not available"
msgstr ""
+#: ../display/d.vect/area.c:68 ../display/d.thematic.area/plot1.c:206
+msgid "Color definition column not specified."
+msgstr ""
#: ../display/d.vect/area.c:277
#, c-format
msgid ""
@@ -24310,7 +22545,7 @@
msgid "Maximum value used for bar plot reference"
msgstr ""
-#: ../display/d.vect.chart/main.c:148 ../display/d.thematic.area/main.c:174
+#: ../display/d.vect.chart/main.c:148 ../display/d.thematic.area/main.c:173
msgid "Create legend information and send to stdout"
msgstr ""
@@ -24405,111 +22640,123 @@
msgid "Menu must contain a title and at least one option"
msgstr ""
-#: ../display/d.thematic.area/main.c:81
+#: ../display/d.thematic.area/plot1.c:365
+#, c-format
msgid ""
-"Displays a thematic vector area map in the activeframe on the graphics "
+"Error in color definition column (%s), element %d with cat %d: colorstring [%"
+"s]"
+msgstr ""
+#: ../display/d.thematic.area/plot1.c:372
+#, c-format
+msgid "Error in color definition column (%s), element %d with cat %d"
+msgstr ""
+#: ../display/d.thematic.area/main.c:80
+msgid ""
+"Displays a thematic vector area map in the active frame on the graphics "
"monitor."
msgstr ""
-#: ../display/d.thematic.area/main.c:91
+#: ../display/d.thematic.area/main.c:90
msgid "Data to be classified: column name or expression"
msgstr ""
-#: ../display/d.thematic.area/main.c:98
+#: ../display/d.thematic.area/main.c:97
msgid "Class breaks, without minimum and maximum"
msgstr ""
-#: ../display/d.thematic.area/main.c:125
+#: ../display/d.thematic.area/main.c:124
msgid "Colors (one per class)."
msgstr ""
-#: ../display/d.thematic.area/main.c:140 ../display/d.thematic.area/main.c:148
+#: ../display/d.thematic.area/main.c:139 ../display/d.thematic.area/main.c:147
msgid "Boundaries"
msgstr ""
-#: ../display/d.thematic.area/main.c:141
+#: ../display/d.thematic.area/main.c:140
msgid "Boundary width"
msgstr ""
-#: ../display/d.thematic.area/main.c:147
+#: ../display/d.thematic.area/main.c:146
msgid "Boundary color"
msgstr ""
-#: ../display/d.thematic.area/main.c:160
+#: ../display/d.thematic.area/main.c:159
msgid ""
"d;use the display library basic functions (features: polylines);c;use the "
"display library clipping functions (features: clipping);l;use the display "
"library culling functions (features: culling, polylines)"
msgstr ""
-#: ../display/d.thematic.area/main.c:168
+#: ../display/d.thematic.area/main.c:167
msgid "File in which to save d.graph instructions for legend display"
msgstr ""
-#: ../display/d.thematic.area/main.c:179
+#: ../display/d.thematic.area/main.c:178
msgid ""
"When printing legend info , include extended statistical info from "
"classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:183
+#: ../display/d.thematic.area/main.c:182
msgid "Do not draw map, only output the legend"
msgstr ""
-#: ../display/d.thematic.area/main.c:196
+#: ../display/d.thematic.area/main.c:195
#, c-format
msgid "Invalid rendering method <%s>"
msgstr ""
-#: ../display/d.thematic.area/main.c:218
+#: ../display/d.thematic.area/main.c:217
#, c-format
msgid "%s: You must build topology on vector map. Run v.build."
msgstr ""
-#: ../display/d.thematic.area/main.c:225
+#: ../display/d.thematic.area/main.c:224
msgid "'layer' must be > 0"
msgstr ""
-#: ../display/d.thematic.area/main.c:251
+#: ../display/d.thematic.area/main.c:250
#, c-format
msgid "Data (%s) not numeric. Column must be numeric."
msgstr ""
-#: ../display/d.thematic.area/main.c:307
+#: ../display/d.thematic.area/main.c:328
msgid ""
"You gave both manual breaks and a classification algorithm or a number of "
"classes. The manual breaks have precedence and will thus be used."
msgstr ""
-#: ../display/d.thematic.area/main.c:375
+#: ../display/d.thematic.area/main.c:365
msgid "You must either give classbreaks or a classification algorithm"
msgstr ""
-#: ../display/d.thematic.area/main.c:388
+#: ../display/d.thematic.area/main.c:378
#, c-format
msgid ""
"Not enough colors or error in color specifications.\n"
"Need %i colors."
msgstr ""
-#: ../display/d.thematic.area/main.c:393
+#: ../display/d.thematic.area/main.c:383
#, c-format
msgid "Error interpreting color %s"
msgstr ""
-#: ../display/d.thematic.area/main.c:467
+#: ../display/d.thematic.area/main.c:457
#, c-format
msgid ""
"\n"
"Total number of records: %.0f\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:469
+#: ../display/d.thematic.area/main.c:459
#, c-format
msgid "Classification of %s into %i classes\n"
msgstr ""
-#: ../display/d.thematic.area/main.c:477
+#: ../display/d.thematic.area/main.c:467
#, c-format
msgid "Last chi2 = %f\n"
msgstr ""
@@ -24633,62 +22880,42 @@
"graphics monitor."
msgstr ""
-#: ../display/d.rast/main.c:62
+#: ../display/d.rast/main.c:58
msgid "Raster map to be displayed"
msgstr ""
-#: ../display/d.rast/main.c:70
+#: ../display/d.rast/main.c:66
msgid "List of categories to be displayed (INT maps)"
msgstr ""
-#: ../display/d.rast/main.c:78
+#: ../display/d.rast/main.c:75
msgid "List of values to be displayed (FP maps)"
msgstr ""
-#: ../display/d.rast/main.c:86
+#: ../display/d.rast/main.c:84
msgid "Background color (for null)"
msgstr ""
-#: ../display/d.rast/main.c:90 ../display/d.rgb/main.c:62
+#: ../display/d.rast/main.c:88 ../display/d.rgb/main.c:62
msgid "Overlay (non-null values only)"
msgstr ""
-#: ../display/d.rast/main.c:94
+#: ../display/d.rast/main.c:92
msgid "Invert catlist"
msgstr ""
-#: ../display/d.rast/main.c:99
+#: ../display/d.rast/main.c:98
msgid "Don't add to list of rasters and commands in monitor"
msgstr ""
-#: ../display/d.rast/main.c:119
+#: ../display/d.rast/main.c:118
msgid "Ignoring catlist: map is floating point (please use 'val=')"
msgstr ""
-#: ../display/d.rast/main.c:125
+#: ../display/d.rast/main.c:124
msgid "Ignoring vallist: map is integer (please use 'cat=')"
msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid "Select vector(s) with mouse"
-msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - L: draw box with left mouse button to select"
-msgstr ""
-#: ../display/d.extract/extract.c:46
-msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-#: ../display/d.extract/extract.c:47
-msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-#: ../display/d.extract/extract.c:49
-msgid "L: add M: remove R: quit and save\n"
-msgstr ""
#: ../display/d.extract/main.c:52
msgid "Selects and extracts vectors with mouse into new vector map."
msgstr ""
@@ -24709,6 +22936,26 @@
msgid "Cannot get db link info -> cannot copy table."
msgstr ""
+#: ../display/d.extract/extract.c:44
+msgid "Select vector(s) with mouse"
+msgstr ""
+#: ../display/d.extract/extract.c:45
+msgid " - L: draw box with left mouse button to select"
+msgstr ""
+#: ../display/d.extract/extract.c:46
+msgid " - M: draw box with middle mouse button to remove from display"
+msgstr ""
+#: ../display/d.extract/extract.c:47
+msgid " - R: quit and save selected vectors to new map\n"
+msgstr ""
+#: ../display/d.extract/extract.c:49
+msgid "L: add M: remove R: quit and save\n"
+msgstr ""
#: ../display/d.rgb/main.c:57
msgid ""
"Displays three user-specified raster map layers as red, green, and blue "
@@ -24989,7 +23236,7 @@
msgstr ""
#: ../display/d.zoom/main.c:307
-msgid "No previous zoom availible"
+msgid "No previous zoom available"
msgstr ""
#: ../display/d.zoom/main.c:311
@@ -25027,10 +23274,6 @@
msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
msgstr ""
-#: ../display/d.grid/fiducial.c:52
-msgid "Reading symbol"
-msgstr ""
#: ../display/d.grid/plot.c:315
msgid ""
"WGS84 grid output not possible as this location does not contain\n"
@@ -25057,96 +23300,106 @@
msgid "Error in pj_do_proj6"
msgstr ""
-#: ../display/d.grid/main.c:54
+#: ../display/d.grid/fiducial.c:52
+msgid "Reading symbol"
+msgstr ""
+#: ../display/d.grid/main.c:53
msgid ""
"Overlays a user-specified grid in the active display frame on the graphics "
"monitor."
msgstr ""
-#: ../display/d.grid/main.c:62
+#: ../display/d.grid/main.c:61
msgid "Size of grid to be drawn"
msgstr ""
-#: ../display/d.grid/main.c:63
+#: ../display/d.grid/main.c:62
msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
msgstr ""
-#: ../display/d.grid/main.c:72
+#: ../display/d.grid/main.c:71
msgid "Lines of the grid pass through this coordinate"
msgstr ""
-#: ../display/d.grid/main.c:76
+#: ../display/d.grid/main.c:75
msgid "Grid color"
msgstr ""
-#: ../display/d.grid/main.c:93
+#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
+#: ../display/d.grid/main.c:87
+msgid "Color"
+msgstr ""
+#: ../display/d.grid/main.c:95
msgid "Font size for gridline coordinate labels"
msgstr ""
-#: ../display/d.grid/main.c:98
+#: ../display/d.grid/main.c:100
msgid "Draw geographic grid (referenced to current ellipsoid)"
msgstr ""
-#: ../display/d.grid/main.c:103
+#: ../display/d.grid/main.c:105
msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
msgstr ""
-#: ../display/d.grid/main.c:107
+#: ../display/d.grid/main.c:109
msgid "Draw '+' marks instead of grid lines"
msgstr ""
-#: ../display/d.grid/main.c:111
+#: ../display/d.grid/main.c:113
msgid "Draw fiducial marks instead of grid lines"
msgstr ""
-#: ../display/d.grid/main.c:115
+#: ../display/d.grid/main.c:117
msgid "Disable grid drawing"
msgstr ""
-#: ../display/d.grid/main.c:119
+#: ../display/d.grid/main.c:118 ../display/d.grid/main.c:123
+#: ../display/d.grid/main.c:128
+msgid "Disable"
+msgstr ""
+#: ../display/d.grid/main.c:122
msgid "Disable border drawing"
msgstr ""
-#: ../display/d.grid/main.c:123
+#: ../display/d.grid/main.c:127
msgid "Disable text drawing"
msgstr ""
-#: ../display/d.grid/main.c:133
+#: ../display/d.grid/main.c:137
msgid "Both grid and border drawing are disabled"
msgstr ""
-#: ../display/d.grid/main.c:137
+#: ../display/d.grid/main.c:141
msgid "Geo-Grid option is not available for LL projection"
msgstr ""
-#: ../display/d.grid/main.c:139
+#: ../display/d.grid/main.c:143
msgid "Geo-Grid option is not available for XY projection"
msgstr ""
-#: ../display/d.grid/main.c:150
-msgid "Chose a single mark style"
+#: ../display/d.grid/main.c:154
+msgid "Choose a single mark style"
msgstr ""
-#: ../display/d.grid/main.c:160
+#: ../display/d.grid/main.c:164
#, c-format
msgid "Invalid geo-grid size <%s>"
msgstr ""
-#: ../display/d.grid/main.c:165
+#: ../display/d.grid/main.c:169
#, c-format
msgid "Invalid grid size <%s>"
msgstr ""
-#: ../display/d.grid/main.c:171
-#, c-format
-msgid "Illegal east coordinate <%s>"
+#: ../display/d.rhumbline/main.c:47
+msgid ""
+"Displays the rhumbline joining two user-specified points, in the active "
+"frame on the user's graphics monitor."
msgstr ""
-#: ../display/d.grid/main.c:177
-#, c-format
-msgid "Illegal north coordinate <%s>"
-msgstr ""
#: ../display/d.nviz/main.c:69
msgid "Creates fly-through script to run in NVIZ."
msgstr ""
@@ -25235,6 +23488,10 @@
"setback distance puts it beyond the edge?"
msgstr ""
+#: ../display/d.colortable/main.c:66 ../display/d.extend/main.c:31
+msgid "display, setup"
+msgstr ""
#: ../display/d.colortable/main.c:68
msgid "Displays the color table associated with a raster map layer."
msgstr ""
@@ -25288,6 +23545,17 @@
msgid "Problem selecting %s. Will try once more"
msgstr ""
+#: ../display/d.mon/pgms/select.c:18 ../display/d.mon/pgms/start.c:68
+#, c-format
+msgid "Usage: %s monitor_name"
+msgstr ""
+#: ../display/d.mon/pgms/select.c:27 ../display/d.mon/pgms/release.c:74
+#: ../display/d.mon/pgms/stop.c:76
+#, c-format
+msgid "No such monitor as <%s>"
+msgstr ""
#: ../display/d.mon/pgms/release.c:41 ../display/d.mon/pgms/stop.c:33
#, c-format
msgid "%s: -%c unrecognized option"
@@ -25303,12 +23571,6 @@
msgid "Monitor <%s> in use by another user"
msgstr ""
-#: ../display/d.mon/pgms/release.c:74 ../display/d.mon/pgms/select.c:27
-#: ../display/d.mon/pgms/stop.c:76
-#, c-format
-msgid "No such monitor as <%s>"
-msgstr ""
#: ../display/d.mon/pgms/release.c:77
msgid "Failed testing lock mechanism"
msgstr ""
@@ -25318,11 +23580,6 @@
msgid "Usage: %s [-fv] [name]"
msgstr ""
-#: ../display/d.mon/pgms/select.c:18 ../display/d.mon/pgms/start.c:68
-#, c-format
-msgid "Usage: %s monitor_name"
-msgstr ""
#: ../display/d.mon/pgms/stop.c:49
#, c-format
msgid "Usage: %s [-f] monitor_name"
@@ -25472,10 +23729,6 @@
msgid "Finds shortest path for selected starting and ending node."
msgstr ""
-#: ../display/d.path/main.c:66
-msgid "Starting and ending coordinates"
-msgstr ""
#: ../display/d.path/main.c:102 ../display/d.path/main.c:110
#: ../display/d.path/main.c:118 ../display/d.path/main.c:128
msgid "Rendering"
@@ -25485,10 +23738,6 @@
msgid "Render bold lines"
msgstr ""
-#: ../display/d.path/main.c:143
-msgid "No coordinates given"
-msgstr ""
#: ../display/d.path/main.c:146 ../display/d.path/main.c:150
#, c-format
msgid "%s - illegal x value"
@@ -25641,7 +23890,7 @@
#: ../general/g.tempfile/main.c:36 ../general/g.pnmcomp/main.c:281
#: ../general/g.proj/main.c:54 ../general/g.findetc/main.c:28
#: ../general/g.ask/main.c:40 ../general/g.findfile/main.c:34
-#: ../general/g.filename/main.c:39 ../general/g.region/main.c:73
+#: ../general/g.filename/main.c:39 ../general/g.region/main.c:72
#: ../general/g.message/main.c:32 ../general/g.version/main.c:34
msgid "general"
msgstr ""
@@ -25679,9 +23928,15 @@
msgstr ""
#: ../general/g.access/main.c:67
-msgid "Unable to determine mapset permssions"
+msgid "Unable to determine mapset permissions"
msgstr ""
+#: ../general/manage/cmd/rename.c:40 ../general/manage/cmd/copy.c:39
+#: ../general/manage/cmd/list.c:41 ../general/manage/cmd/remove.c:99
+#: ../general/g.mlist/main.c:64 ../general/g.mremove/main.c:58
+msgid "general, map management"
+msgstr ""
#: ../general/manage/cmd/rename.c:42
msgid "Renames data base element files in the user's current mapset."
msgstr ""
@@ -25737,36 +23992,38 @@
msgid "<%s> already exists"
msgstr ""
-#: ../general/manage/cmd/list.c:43
+#: ../general/manage/cmd/list.c:43 ../general/g.mlist/main.c:66
msgid ""
"Lists available GRASS data base files of the user-specified data type to "
"standard output."
msgstr ""
-#: ../general/manage/cmd/list.c:72
+#: ../general/manage/cmd/list.c:72 ../general/g.mlist/main.c:114
msgid "Mapset to list (default: current search path)"
msgstr ""
-#: ../general/manage/cmd/list.c:77
+#: ../general/manage/cmd/list.c:76 ../general/g.mlist/main.c:140
msgid "Verbose listing (also list map titles)"
msgstr ""
-#: ../general/manage/cmd/remove.c:38
+#: ../general/manage/cmd/remove.c:38 ../general/g.mremove/check_reclass.c:14
#, c-format
msgid "[%s@%s] is a base map for [%s]. Remove forced."
msgstr ""
-#: ../general/manage/cmd/remove.c:41
+#: ../general/manage/cmd/remove.c:41 ../general/g.mremove/check_reclass.c:18
#, c-format
msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
msgstr ""
#: ../general/manage/cmd/remove.c:63 ../general/manage/cmd/remove.c:76
+#: ../general/g.mremove/check_reclass.c:41
+#: ../general/g.mremove/check_reclass.c:55
#, c-format
msgid "Removing information about reclassed map from [%s@%s] failed"
msgstr ""
-#: ../general/manage/cmd/remove.c:101
+#: ../general/manage/cmd/remove.c:101 ../general/g.mremove/main.c:60
msgid "Removes data base element files from the user's current mapset."
msgstr ""
@@ -25774,7 +24031,7 @@
msgid "Force remove"
msgstr ""
-#: ../general/manage/cmd/remove.c:120
+#: ../general/manage/cmd/remove.c:120 ../general/g.mremove/main.c:96
#, c-format
msgid "%s file(s) to be removed"
msgstr ""
@@ -26144,6 +24401,22 @@
msgid "Cannot open SEARCH_PATH for write"
msgstr ""
+#: ../general/g.findfile/main.c:36
+msgid "Searches for GRASS data base files and sets variables for the shell."
+msgstr ""
+#: ../general/g.findfile/main.c:47 ../general/g.filename/main.c:48
+msgid "Name of an element"
+msgstr ""
+#: ../general/g.findfile/main.c:53
+msgid "Name of a mapset"
+msgstr ""
+#: ../general/g.findfile/main.c:60
+msgid "Name of an existing map"
+msgstr ""
#: ../general/g.findfile/main.c:74
#, c-format
msgid ""
@@ -26155,10 +24428,6 @@
msgid "Prints GRASS data base file names."
msgstr ""
-#: ../general/g.filename/main.c:48
-msgid "Name of an element"
-msgstr ""
#: ../general/g.filename/main.c:54
msgid "Name of a database file"
msgstr ""
@@ -26167,166 +24436,170 @@
msgid "Name of a mapset (default: current)"
msgstr ""
-#: ../general/g.region/main.c:75
+#: ../general/g.region/main.c:74
msgid "Manages the boundary definitions for the geographic region."
msgstr ""
-#: ../general/g.region/main.c:82 ../general/g.region/main.c:87
-#: ../general/g.region/main.c:155 ../general/g.region/main.c:162
-#: ../general/g.region/main.c:171 ../general/g.region/main.c:178
-#: ../general/g.region/main.c:188
+#: ../general/g.region/main.c:81 ../general/g.region/main.c:86
+#: ../general/g.region/main.c:154 ../general/g.region/main.c:161
+#: ../general/g.region/main.c:170 ../general/g.region/main.c:177
+#: ../general/g.region/main.c:187
msgid "Existing"
msgstr ""
-#: ../general/g.region/main.c:86
+#: ../general/g.region/main.c:85
msgid "Save as default region"
msgstr ""
-#: ../general/g.region/main.c:91
+#: ../general/g.region/main.c:90
msgid "Print the current region"
msgstr ""
-#: ../general/g.region/main.c:96
+#: ../general/g.region/main.c:95
msgid "Print the current region in lat/long using the current ellipsoid/datum"
msgstr ""
-#: ../general/g.region/main.c:102
+#: ../general/g.region/main.c:101
msgid "Print the current region extent"
msgstr ""
-#: ../general/g.region/main.c:108
+#: ../general/g.region/main.c:107
msgid "Print the current region map center coordinates"
msgstr ""
-#: ../general/g.region/main.c:114
+#: ../general/g.region/main.c:113
msgid "Print region resolution in meters (geodesic)"
msgstr ""
-#: ../general/g.region/main.c:119
+#: ../general/g.region/main.c:118
msgid "Print also 3D settings"
msgstr ""
-#: ../general/g.region/main.c:125
+#: ../general/g.region/main.c:124
msgid "Print the maximum bounding box in lat/long on WGS84"
msgstr ""
-#: ../general/g.region/main.c:136
+#: ../general/g.region/main.c:129
+msgid "Print in shell script style"
+msgstr ""
+#: ../general/g.region/main.c:135
msgid ""
"Align region to resolution (default = align to bounds, works only for 2D "
"resolution)"
msgstr ""
-#: ../general/g.region/main.c:142
+#: ../general/g.region/main.c:141
msgid "Do not update the current region"
msgstr ""
-#: ../general/g.region/main.c:153
+#: ../general/g.region/main.c:152
msgid "Set current region from named region"
msgstr ""
-#: ../general/g.region/main.c:169
+#: ../general/g.region/main.c:168
msgid "Set region to match this 3D raster map (both 2D and 3D values)"
msgstr ""
-#: ../general/g.region/main.c:236
+#: ../general/g.region/main.c:235
msgid "Value for the top edge"
msgstr ""
-#: ../general/g.region/main.c:245
+#: ../general/g.region/main.c:244
msgid "Value for the bottom edge"
msgstr ""
-#: ../general/g.region/main.c:254
+#: ../general/g.region/main.c:253
msgid "Number of rows in the new region"
msgstr ""
-#: ../general/g.region/main.c:255 ../general/g.region/main.c:264
-#: ../general/g.region/main.c:274 ../general/g.region/main.c:284
-#: ../general/g.region/main.c:294 ../general/g.region/main.c:304
-#: ../general/g.region/main.c:313
+#: ../general/g.region/main.c:254 ../general/g.region/main.c:263
+#: ../general/g.region/main.c:273 ../general/g.region/main.c:283
+#: ../general/g.region/main.c:293 ../general/g.region/main.c:303
+#: ../general/g.region/main.c:312
msgid "Resolution"
msgstr ""
-#: ../general/g.region/main.c:263
+#: ../general/g.region/main.c:262
msgid "Number of columns in the new region"
msgstr ""
-#: ../general/g.region/main.c:273
+#: ../general/g.region/main.c:272
msgid "Grid resolution 2D (both north-south and east-west)"
msgstr ""
-#: ../general/g.region/main.c:283
+#: ../general/g.region/main.c:282
msgid "3D grid resolution (north-south, east-west and top-bottom)"
msgstr ""
-#: ../general/g.region/main.c:292
+#: ../general/g.region/main.c:291
msgid "North-south grid resolution 2D"
msgstr ""
-#: ../general/g.region/main.c:302
+#: ../general/g.region/main.c:301
msgid "East-west grid resolution 2D"
msgstr ""
-#: ../general/g.region/main.c:312
+#: ../general/g.region/main.c:311
msgid "Top-bottom grid resolution 3D"
msgstr ""
-#: ../general/g.region/main.c:322
+#: ../general/g.region/main.c:321
msgid "Shrink region until it meets non-NULL data from this raster map"
msgstr ""
-#: ../general/g.region/main.c:333
+#: ../general/g.region/main.c:332
msgid "Adjust region cells to cleanly align with this raster map"
msgstr ""
-#: ../general/g.region/main.c:344
+#: ../general/g.region/main.c:343
msgid "Save current region settings in named region file"
msgstr ""
-#: ../general/g.region/main.c:479
+#: ../general/g.region/main.c:478 ../general/g.mremove/do_remove.c:55
#, c-format
msgid "3D raster map <%s> not found"
msgstr ""
-#: ../general/g.region/main.c:482
+#: ../general/g.region/main.c:481
#, c-format
msgid "Unable to read header of 3D raster map <%s@%s>"
msgstr ""
-#: ../general/g.region/main.c:525
+#: ../general/g.region/main.c:524
#, c-format
msgid "Unable to open vector map <%s@%s>"
msgstr ""
-#: ../general/g.region/main.c:807
+#: ../general/g.region/main.c:806
#, c-format
msgid "Raster map <%s@%s>: %s"
msgstr ""
-#: ../general/g.region/main.c:813
+#: ../general/g.region/main.c:812
#, c-format
msgid "<%s> is an illegal region name"
msgstr ""
-#: ../general/g.region/main.c:817
+#: ../general/g.region/main.c:816
#, c-format
msgid "Unable to set region <%s>"
msgstr ""
-#: ../general/g.region/main.c:823
+#: ../general/g.region/main.c:822
msgid "Unable to update current region"
msgstr ""
-#: ../general/g.region/main.c:831
+#: ../general/g.region/main.c:830
msgid "Unable to change default region. The current mapset is not <PERMANENT>."
msgstr ""
-#: ../general/g.region/main.c:848
+#: ../general/g.region/main.c:847
#, c-format
msgid "Invalid input <%s=%s>"
msgstr ""
-#: ../general/g.region/main.c:869
+#: ../general/g.region/main.c:868
msgid "format"
msgstr ""
@@ -26703,7 +24976,7 @@
msgstr ""
#: ../general/g.mapset/main.c:158
-msgid "Unable to read GIS_LOCK enviroment variable"
+msgid "Unable to read GIS_LOCK environment variable"
msgstr ""
#: ../general/g.mapset/main.c:172
@@ -26738,3 +25011,93 @@
"You can switch the history by commands:\n"
"history -S; history -L %s/.history; setenv histfile=%s/.history"
msgstr ""
+#: ../general/g.mlist/main.c:97
+msgid "Map name search pattern (default: all)"
+msgstr ""
+#: ../general/g.mlist/main.c:106
+msgid "One-character output separator, newline, comma, space, or tab"
+msgstr ""
+#: ../general/g.mlist/main.c:119 ../general/g.mremove/main.c:66
+msgid "Use basic regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.mlist/main.c:124 ../general/g.mremove/main.c:71
+msgid "Use extended regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.mlist/main.c:128
+msgid "Print data types"
+msgstr ""
+#: ../general/g.mlist/main.c:132
+msgid "Print mapset names"
+msgstr ""
+#: ../general/g.mlist/main.c:136
+msgid "Pretty printing in human readable format"
+msgstr ""
+#: ../general/g.mlist/main.c:148 ../general/g.mremove/main.c:104
+msgid "-r and -e are mutually exclusive"
+msgstr ""
+#: ../general/g.mlist/main.c:156 ../general/g.mremove/main.c:130
+#, c-format
+msgid "Unable to compile regular expression %s"
+msgstr ""
+#: ../general/g.mlist/read_list.c:144 ../general/g.mremove/read_list.c:144
+#, c-format
+msgid ""
+"Format error: <%s>\n"
+"Line: %d\n"
+"%s"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:21
+#, c-format
+msgid "Removing %s <%s>"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:42 ../general/g.mremove/do_remove.c:84
+msgid "couldn't be removed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:62
+#, c-format
+msgid "%s: couldn't be removed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:67 ../general/g.mremove/do_remove.c:89
+#, c-format
+msgid "%s: missing"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:71 ../general/g.mremove/do_remove.c:93
+#, c-format
+msgid "%s: removed"
+msgstr ""
+#: ../general/g.mremove/do_remove.c:100
+#, c-format
+msgid "<%s> nothing removed"
+msgstr ""
+#: ../general/g.mremove/main.c:76
+msgid "Force removal (required for actual deletion of files)"
+msgstr ""
+#: ../general/g.mremove/main.c:80
+msgid "Remove base maps"
+msgstr ""
+#: ../general/g.mremove/main.c:107
+msgid "The following files would be deleted:"
+msgstr ""
+#: ../general/g.mremove/main.c:158
+msgid "You must use the force flag to actually remove them. Exiting."
+msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasstcl_el.po
--- grass/branches/develbranch_6/locale/po/grasstcl_el.po 2008-10-12 06:55:55 UTC (rev 33834)
+++ grass/branches/develbranch_6/locale/po/grasstcl_el.po 2008-10-12 07:12:30 UTC (rev 33835)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasstcl_el\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2008-08-19 23:37+0200\n"
+"POT-Creation-Date: 2008-10-11 14:54+0200\n"
"PO-Revision-Date: 2007-03-23 16:35+0100\n"
"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -16,231 +16,231 @@
"Content-Type: text/plain; charset=ISO-8859-7\n"
"Content-Transfer-Encoding: 8bit\n"
-#: ../vector/v.digit/settings.tcl:63
+#: ../vector/v.digit/settings.tcl:75
msgid "Add new column"
msgstr ""
-#: ../vector/v.digit/settings.tcl:66
+#: ../vector/v.digit/settings.tcl:78
msgid "Create table"
msgstr ""
-#: ../vector/v.digit/settings.tcl:99
+#: ../vector/v.digit/settings.tcl:111
msgid "Add command"
msgstr ""
-#: ../vector/v.digit/settings.tcl:135
+#: ../vector/v.digit/settings.tcl:149
msgid "Table successfully created"
msgstr ""
-#: ../vector/v.digit/settings.tcl:151
+#: ../vector/v.digit/settings.tcl:165
msgid "Settings already opened"
msgstr ""
-#: ../vector/v.digit/settings.tcl:160 ../lib/init/epsg_option.tcl:311
-#: ../lib/init/file_option.tcl:263 ../gui/tcltk/gis.m/gm.tcl:446
+#: ../vector/v.digit/settings.tcl:174 ../lib/init/epsg_option.tcl:311
+#: ../lib/init/file_option.tcl:263 ../gui/tcltk/gis.m/gm.tcl:455
#: ../gui/tcltk/gis.m/animate.tcl:536 ../gui/tcltk/gis.m/dnviz.tcl:228
#: ../gui/tcltk/gis.m/rules.tcl:170
msgid "OK"
msgstr ""
-#: ../vector/v.digit/settings.tcl:169
+#: ../vector/v.digit/settings.tcl:183
msgid "Symbology"
msgstr ""
-#: ../vector/v.digit/settings.tcl:173 ../vector/v.digit/settings.tcl:326
+#: ../vector/v.digit/settings.tcl:187 ../vector/v.digit/settings.tcl:340
msgid "Background"
msgstr ""
-#: ../vector/v.digit/settings.tcl:180
+#: ../vector/v.digit/settings.tcl:194
msgid "Highlight"
msgstr ""
-#: ../vector/v.digit/settings.tcl:187
+#: ../vector/v.digit/settings.tcl:201
msgid "Point"
msgstr ""
-#: ../vector/v.digit/settings.tcl:196
+#: ../vector/v.digit/settings.tcl:210
msgid "Line"
msgstr ""
-#: ../vector/v.digit/settings.tcl:205
+#: ../vector/v.digit/settings.tcl:219
msgid "Boundary (no area)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:213
+#: ../vector/v.digit/settings.tcl:227
msgid "Boundary (1 area)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:221
+#: ../vector/v.digit/settings.tcl:235
msgid "Boundary (2 areas)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:230
+#: ../vector/v.digit/settings.tcl:244
msgid "Centroid (in area)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:238
+#: ../vector/v.digit/settings.tcl:252
msgid "Centroid (outside area)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:246
+#: ../vector/v.digit/settings.tcl:260
msgid "Centroid (duplicate in area)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:255
+#: ../vector/v.digit/settings.tcl:269
msgid "Node (1 line)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:263
+#: ../vector/v.digit/settings.tcl:277
msgid "Node (2 lines)"
msgstr ""
-#: ../vector/v.digit/settings.tcl:273
+#: ../vector/v.digit/settings.tcl:287
msgid "Settings"
msgstr ""
-#: ../vector/v.digit/settings.tcl:278
+#: ../vector/v.digit/settings.tcl:292
msgid "Snapping threshold in screen pixels"
msgstr ""
-#: ../vector/v.digit/settings.tcl:288
+#: ../vector/v.digit/settings.tcl:302
msgid "Snapping threshold in map units"
msgstr ""
-#: ../vector/v.digit/settings.tcl:305
+#: ../vector/v.digit/settings.tcl:319
msgid "Line width in screen pixels"
msgstr ""
-#: ../vector/v.digit/settings.tcl:307
+#: ../vector/v.digit/settings.tcl:321
msgid "Set line width in pixels"
msgstr ""
-#: ../vector/v.digit/settings.tcl:315
+#: ../vector/v.digit/settings.tcl:329
msgid "Table"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:19
+#: ../vector/v.digit/toolbox.tcl:20
msgid "Welcome to v.digit"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:20
+#: ../vector/v.digit/toolbox.tcl:21
msgid "Left button"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:21
+#: ../vector/v.digit/toolbox.tcl:22
msgid "Middle button"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:22
+#: ../vector/v.digit/toolbox.tcl:23
msgid "Right button"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:75
+#: ../vector/v.digit/toolbox.tcl:76
msgid " Layer"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:79
+#: ../vector/v.digit/toolbox.tcl:80
msgid " Category"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:83
+#: ../vector/v.digit/toolbox.tcl:84
msgid " Mode "
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:95
+#: ../vector/v.digit/toolbox.tcl:96
msgid "Insert new record into table"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:112
+#: ../vector/v.digit/toolbox.tcl:113
msgid "Digitize new point"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:117
+#: ../vector/v.digit/toolbox.tcl:118
msgid "Digitize new line"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:122
+#: ../vector/v.digit/toolbox.tcl:123
msgid "Digitize new boundary"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:127
+#: ../vector/v.digit/toolbox.tcl:128
msgid "Digitize new centroid"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:133
+#: ../vector/v.digit/toolbox.tcl:134
msgid "Move vertex"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:138
+#: ../vector/v.digit/toolbox.tcl:139
msgid "Add vertex"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:143
+#: ../vector/v.digit/toolbox.tcl:144
msgid "Remove vertex"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:148
+#: ../vector/v.digit/toolbox.tcl:149
msgid "Split line"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:153
+#: ../vector/v.digit/toolbox.tcl:154
msgid "Edit line/boundary"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:158
+#: ../vector/v.digit/toolbox.tcl:159
msgid "Move point, line, boundary, or centroid"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:163
+#: ../vector/v.digit/toolbox.tcl:164
msgid "Delete point, line, boundary, or centroid"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:174
+#: ../vector/v.digit/toolbox.tcl:175
msgid "Redraw"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:179
+#: ../vector/v.digit/toolbox.tcl:180
msgid "Zoom in by window"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:184
+#: ../vector/v.digit/toolbox.tcl:185
msgid "Zoom out"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:189 ../gui/tcltk/gis.m/maptool.tcl:151
+#: ../vector/v.digit/toolbox.tcl:190 ../gui/tcltk/gis.m/maptool.tcl:151
#: ../gui/tcltk/gis.m/georecttool.tcl:130
msgid "Pan"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:194
+#: ../vector/v.digit/toolbox.tcl:195
msgid "Zoom to default region"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:207
+#: ../vector/v.digit/toolbox.tcl:208
msgid "Zoom to saved region"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:213
+#: ../vector/v.digit/toolbox.tcl:214
msgid "Display categories"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:218
+#: ../vector/v.digit/toolbox.tcl:219
msgid "Copy categories"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:223
+#: ../vector/v.digit/toolbox.tcl:224
msgid "Display attributes"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:235
+#: ../vector/v.digit/toolbox.tcl:236
msgid "Open settings"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:241
+#: ../vector/v.digit/toolbox.tcl:242
msgid "Save and exit"
msgstr ""
-#: ../vector/v.digit/toolbox.tcl:252
+#: ../vector/v.digit/toolbox.tcl:253
msgid "mouse button actions (left, middle, right)"
msgstr ""
@@ -282,16 +282,16 @@
#: ../lib/gtcltk/select.tcl:209 ../lib/init/epsg_option.tcl:167
#: ../lib/init/epsg_option.tcl:314 ../lib/init/file_option.tcl:114
-#: ../lib/init/file_option.tcl:266 ../gui/tcltk/gis.m/gm.tcl:449
+#: ../lib/init/file_option.tcl:266 ../gui/tcltk/gis.m/gm.tcl:458
#: ../gui/tcltk/gis.m/animate.tcl:538 ../gui/tcltk/gis.m/dnviz.tcl:230
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:855 ../gui/tcltk/gis.m/georect.tcl:703
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:859 ../gui/tcltk/gis.m/georect.tcl:703
#: ../gui/tcltk/gis.m/rules.tcl:172
msgid "Cancel"
msgstr ""
#: ../lib/gis/gui.tcl:11 ../lib/gis/gui.tcl:15 ../lib/gis/gui.tcl:19
-#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:266
-#: ../gui/tcltk/gis.m/runandoutput.tcl:272
+#: ../lib/gis/gui.tcl:310 ../gui/tcltk/gis.m/runandoutput.tcl:270
+#: ../gui/tcltk/gis.m/runandoutput.tcl:276
#: ../gui/tcltk/gis.m/grassabout.tcl:94 ../gui/tcltk/gis.m/gmlib.tcl:141
msgid "Error"
msgstr ""
@@ -323,10 +323,10 @@
msgstr ""
#: ../lib/gis/gui.tcl:513 ../lib/init/gis_set.tcl:507
-#: ../gui/tcltk/gis.m/rastarrows.tcl:164 ../gui/tcltk/gis.m/rastarrows.tcl:167
#: ../gui/tcltk/gis.m/thematic.tcl:241 ../gui/tcltk/gis.m/thematic.tcl:245
#: ../gui/tcltk/gis.m/profile.tcl:131 ../gui/tcltk/gis.m/profile.tcl:135
#: ../gui/tcltk/gis.m/labels.tcl:136 ../gui/tcltk/gis.m/labels.tcl:140
+#: ../gui/tcltk/gis.m/rastarrows.tcl:164 ../gui/tcltk/gis.m/rastarrows.tcl:167
#: ../gui/tcltk/gis.m/runandoutput.tcl:47 ../gui/tcltk/gis.m/rastnums.tcl:163
#: ../gui/tcltk/gis.m/rastnums.tcl:166 ../gui/tcltk/gis.m/frames.tcl:118
#: ../gui/tcltk/gis.m/frames.tcl:122 ../gui/tcltk/gis.m/animate.tcl:408
@@ -361,7 +361,7 @@
msgid "Help"
msgstr ""
-#: ../lib/gis/gui.tcl:514 ../gui/tcltk/gis.m/runandoutput.tcl:127
+#: ../lib/gis/gui.tcl:514 ../gui/tcltk/gis.m/runandoutput.tcl:131
msgid "Clear"
msgstr ""
@@ -545,9 +545,9 @@
msgstr ""
#: ../lib/init/gis_set.tcl:128 ../lib/init/gis_set.tcl:379
-#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:609
-#: ../lib/init/gis_set.tcl:630 ../lib/init/gis_set.tcl:648
-#: ../lib/init/gis_set.tcl:676
+#: ../lib/init/gis_set.tcl:485 ../lib/init/gis_set.tcl:608
+#: ../lib/init/gis_set.tcl:629 ../lib/init/gis_set.tcl:647
+#: ../lib/init/gis_set.tcl:675
msgid "WARNING: invalid location"
msgstr ""
@@ -662,7 +662,7 @@
" Select valid location and try again."
msgstr ""
-#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:654
+#: ../lib/init/gis_set.tcl:491 ../lib/init/gis_set.tcl:653
msgid "WARNING: invalid mapset"
msgstr ""
@@ -687,24 +687,24 @@
msgid "WARNING: Invalid database. Finding first valid directory in parent tree"
msgstr ""
-#: ../lib/init/gis_set.tcl:610 ../lib/init/gis_set.tcl:631
-#: ../lib/init/gis_set.tcl:649 ../lib/init/gis_set.tcl:677
+#: ../lib/init/gis_set.tcl:609 ../lib/init/gis_set.tcl:630
+#: ../lib/init/gis_set.tcl:648 ../lib/init/gis_set.tcl:676
#, tcl-format
msgid ""
"Warning: selected location <%%s> is not valid. \n"
msgstr ""
-#: ../lib/init/gis_set.tcl:655
+#: ../lib/init/gis_set.tcl:654
#, tcl-format
msgid "Warning: <%%s> is not a valid mapset"
msgstr ""
-#: ../lib/init/gis_set.tcl:747
+#: ../lib/init/gis_set.tcl:746
msgid "WARNING: change directory failed"
msgstr ""
-#: ../lib/init/gis_set.tcl:748
+#: ../lib/init/gis_set.tcl:747
#, tcl-format
msgid ""
"Warning: could not change directory to <%s>.\n"
@@ -741,10 +741,10 @@
"valid georeferenced file"
msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:83 ../gui/tcltk/gis.m/rastarrows.tcl:357
#: ../gui/tcltk/gis.m/thematic.tcl:107 ../gui/tcltk/gis.m/thematic.tcl:607
#: ../gui/tcltk/gis.m/thematic.tcl:680 ../gui/tcltk/gis.m/labels.tcl:78
-#: ../gui/tcltk/gis.m/labels.tcl:279 ../gui/tcltk/gis.m/rastnums.tcl:79
+#: ../gui/tcltk/gis.m/labels.tcl:279 ../gui/tcltk/gis.m/rastarrows.tcl:83
+#: ../gui/tcltk/gis.m/rastarrows.tcl:357 ../gui/tcltk/gis.m/rastnums.tcl:79
#: ../gui/tcltk/gis.m/rastnums.tcl:360 ../gui/tcltk/gis.m/frames.tcl:78
#: ../gui/tcltk/gis.m/frames.tcl:275 ../gui/tcltk/gis.m/animate.tcl:91
#: ../gui/tcltk/gis.m/mapprint.tcl:194 ../gui/tcltk/gis.m/mapprint.tcl:201
@@ -754,7 +754,7 @@
#: ../gui/tcltk/gis.m/chart.tcl:89 ../gui/tcltk/gis.m/chart.tcl:441
#: ../gui/tcltk/gis.m/vector.tcl:194 ../gui/tcltk/gis.m/vector.tcl:819
#: ../gui/tcltk/gis.m/cmd.tcl:75 ../gui/tcltk/gis.m/cmd.tcl:206
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:212 ../gui/tcltk/gis.m/mapcanvas.tcl:221
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:212 ../gui/tcltk/gis.m/mapcanvas.tcl:222
#: ../gui/tcltk/gis.m/barscale.tcl:91 ../gui/tcltk/gis.m/barscale.tcl:401
#: ../gui/tcltk/gis.m/rgbhis.tcl:83 ../gui/tcltk/gis.m/rgbhis.tcl:362
#: ../gui/tcltk/gis.m/dtext.tcl:92 ../gui/tcltk/gis.m/dtext.tcl:401
@@ -763,79 +763,6 @@
msgid "Error creating tempfile"
msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:106
-msgid "Aspect map"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:109 ../gui/tcltk/gis.m/rastarrows.tcl:121
-#, tcl-format
-msgid "arrows for %s"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:118
-msgid "Slope/intensity map"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:134
-msgid "Display arrows whose orientations are based on raster aspect map"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:140
-msgid " (optionally, arrow lengths are based on slope or intensity map)"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:147 ../gui/tcltk/gis.m/thematic.tcl:223
-#: ../gui/tcltk/gis.m/labels.tcl:118 ../gui/tcltk/gis.m/rastnums.tcl:146
-#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:200
-#: ../gui/tcltk/gis.m/raster.tcl:168 ../gui/tcltk/gis.m/chart.tcl:166
-#: ../gui/tcltk/gis.m/vector.tcl:306 ../gui/tcltk/gis.m/cmd.tcl:105
-#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/rgbhis.tcl:143
-#: ../gui/tcltk/gis.m/dtext.tcl:166 ../gui/tcltk/gis.m/histogram.tcl:145
-msgid "Opaque "
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:151 ../gui/tcltk/gis.m/thematic.tcl:227
-#: ../gui/tcltk/gis.m/labels.tcl:122 ../gui/tcltk/gis.m/rastnums.tcl:150
-#: ../gui/tcltk/gis.m/gridline.tcl:151 ../gui/tcltk/gis.m/legend.tcl:204
-#: ../gui/tcltk/gis.m/raster.tcl:172 ../gui/tcltk/gis.m/chart.tcl:170
-#: ../gui/tcltk/gis.m/cmd.tcl:109 ../gui/tcltk/gis.m/barscale.tcl:164
-#: ../gui/tcltk/gis.m/rgbhis.tcl:147 ../gui/tcltk/gis.m/dtext.tcl:170
-#: ../gui/tcltk/gis.m/histogram.tcl:149
-msgid " Transparent"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:157
-msgid "Aspect map: "
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:173
-msgid " aspect value type"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:181
-msgid " draw arrows every Nth grid cell"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:189
-msgid " arrow color "
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:194
-msgid " cell grid color"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:204
-msgid " null value color"
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:219
-msgid "Slope/intensity map: "
-msgstr ""
-#: ../gui/tcltk/gis.m/rastarrows.tcl:230
-msgid " scale factor for computing arrow length"
-msgstr ""
#: ../gui/tcltk/gis.m/thematic.tcl:129 ../gui/tcltk/gis.m/vector.tcl:220
#: ../gui/tcltk/d.m/menu.tcl:94 ../gui/tcltk/d.m/menu.tcl:134
msgid "Vector map"
@@ -869,6 +796,26 @@
msgid " or by graduated sizes (points and lines)"
msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:223 ../gui/tcltk/gis.m/labels.tcl:118
+#: ../gui/tcltk/gis.m/rastarrows.tcl:147 ../gui/tcltk/gis.m/rastnums.tcl:146
+#: ../gui/tcltk/gis.m/gridline.tcl:147 ../gui/tcltk/gis.m/legend.tcl:200
+#: ../gui/tcltk/gis.m/raster.tcl:168 ../gui/tcltk/gis.m/chart.tcl:166
+#: ../gui/tcltk/gis.m/vector.tcl:306 ../gui/tcltk/gis.m/cmd.tcl:105
+#: ../gui/tcltk/gis.m/barscale.tcl:160 ../gui/tcltk/gis.m/rgbhis.tcl:143
+#: ../gui/tcltk/gis.m/dtext.tcl:166 ../gui/tcltk/gis.m/histogram.tcl:145
+msgid "Opaque "
+msgstr ""
+#: ../gui/tcltk/gis.m/thematic.tcl:227 ../gui/tcltk/gis.m/labels.tcl:122
+#: ../gui/tcltk/gis.m/rastarrows.tcl:151 ../gui/tcltk/gis.m/rastnums.tcl:150
+#: ../gui/tcltk/gis.m/gridline.tcl:151 ../gui/tcltk/gis.m/legend.tcl:204
+#: ../gui/tcltk/gis.m/raster.tcl:172 ../gui/tcltk/gis.m/chart.tcl:170
+#: ../gui/tcltk/gis.m/cmd.tcl:109 ../gui/tcltk/gis.m/barscale.tcl:164
+#: ../gui/tcltk/gis.m/rgbhis.tcl:147 ../gui/tcltk/gis.m/dtext.tcl:170
+#: ../gui/tcltk/gis.m/histogram.tcl:149
+msgid " Transparent"
+msgstr ""
#: ../gui/tcltk/gis.m/thematic.tcl:233 ../gui/tcltk/gis.m/vector.tcl:316
#: ../gui/tcltk/d.m/thematic.tcl:116
msgid "Vector map:"
@@ -1053,6 +1000,14 @@
msgid "Save legend to EPS file"
msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:54
+msgid "Raster map for profile"
+msgstr ""
+#: ../gui/tcltk/gis.m/profile.tcl:77
+msgid "Profile Window"
+msgstr ""
#: ../gui/tcltk/gis.m/profile.tcl:110
msgid ""
"Select raster map to profile.\n"
@@ -1079,7 +1034,7 @@
msgid "r.univar error"
msgstr ""
-#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:433
+#: ../gui/tcltk/gis.m/profile.tcl:415 ../gui/tcltk/gis.m/mapcanvas.tcl:435
msgid "g.proj or projection error"
msgstr ""
@@ -1187,53 +1142,106 @@
msgid "GRASS%s GIS Manager - %s"
msgstr ""
-#: ../gui/tcltk/gis.m/gm.tcl:394
+#: ../gui/tcltk/gis.m/gm.tcl:395
msgid "Select GRASS display font"
msgstr ""
-#: ../gui/tcltk/gis.m/gm.tcl:404
+#: ../gui/tcltk/gis.m/gm.tcl:409
msgid "Font: "
msgstr ""
-#: ../gui/tcltk/gis.m/gm.tcl:439
+#: ../gui/tcltk/gis.m/gm.tcl:448
msgid "Character encoding: "
msgstr ""
-#: ../gui/tcltk/gis.m/gm.tcl:520
+#: ../gui/tcltk/gis.m/gm.tcl:529
#, tcl-format
msgid "GRASS%s GIS Manager - %s %s"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:118
+#: ../gui/tcltk/gis.m/rastarrows.tcl:106
+msgid "Aspect map"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:109 ../gui/tcltk/gis.m/rastarrows.tcl:121
+#, tcl-format
+msgid "arrows for %s"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:118
+msgid "Slope/intensity map"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:134
+msgid "Display arrows whose orientations are based on raster aspect map"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:140
+msgid " (optionally, arrow lengths are based on slope or intensity map)"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:157
+msgid "Aspect map: "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:173
+msgid " aspect value type"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:181
+msgid " draw arrows every Nth grid cell"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:189
+msgid " arrow color "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:194
+msgid " cell grid color"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:204
+msgid " null value color"
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:219
+msgid "Slope/intensity map: "
+msgstr ""
+#: ../gui/tcltk/gis.m/rastarrows.tcl:230
+msgid " scale factor for computing arrow length"
+msgstr ""
+#: ../gui/tcltk/gis.m/runandoutput.tcl:119
msgid "Run (background)"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:120
+#: ../gui/tcltk/gis.m/runandoutput.tcl:122
msgid "Run (GUI)"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:122
+#: ../gui/tcltk/gis.m/runandoutput.tcl:125
msgid "Run (in Xterm)"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:125 ../gui/tcltk/gis.m/gmmenu.tcl:88
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:859 ../gui/tcltk/d.m/menu.tcl:172
+#: ../gui/tcltk/gis.m/runandoutput.tcl:129 ../gui/tcltk/gis.m/gmmenu.tcl:88
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:863 ../gui/tcltk/d.m/menu.tcl:172
msgid "Save"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:148
+#: ../gui/tcltk/gis.m/runandoutput.tcl:152
msgid "Output - GIS.m"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:250
+#: ../gui/tcltk/gis.m/runandoutput.tcl:254
msgid "X Windows not available"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:251
+#: ../gui/tcltk/gis.m/runandoutput.tcl:255
msgid "Functions that require X Windows are not available in Windows"
msgstr ""
-#: ../gui/tcltk/gis.m/runandoutput.tcl:273
+#: ../gui/tcltk/gis.m/runandoutput.tcl:277
msgid "This module requires X11 support, but no xmons were found"
msgstr ""
@@ -1304,7 +1312,7 @@
msgstr ""
#: ../gui/tcltk/gis.m/maptool.tcl:228 ../gui/tcltk/gis.m/gmmenu.tcl:615
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1860 ../gui/tcltk/d.m/menu.tcl:554
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1865 ../gui/tcltk/d.m/menu.tcl:554
msgid "Query"
msgstr ""
@@ -4002,92 +4010,92 @@
msgid "Command:"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:523
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:526
msgid "Maximum zoom-in reached"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:593 ../gui/tcltk/gis.m/mapcanvas.tcl:1220
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:596 ../gui/tcltk/gis.m/mapcanvas.tcl:1225
#: ../gui/tcltk/gis.m/georect.tcl:1587
msgid "Error setting region"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:601
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:605
msgid "please wait..."
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:760 ../gui/tcltk/gis.m/mapcanvas.tcl:1814
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:764 ../gui/tcltk/gis.m/mapcanvas.tcl:1819
msgid "You have to select map layer first"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:761 ../gui/tcltk/gis.m/mapcanvas.tcl:1815
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:765 ../gui/tcltk/gis.m/mapcanvas.tcl:1820
msgid "No map layer selected"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:833
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:837
msgid "Save Region"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:836
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:840
msgid "Save current display geometry to named region"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:842
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:846
msgid "Enter region name"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:877
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:881
#, tcl-format
msgid ""
"Region file %s already exists. \n"
"Do you want to overwrite it?"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1064
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1068
#, tcl-format
msgid "Display: rows=%d cols=%d N-S res=%g E-W res=%g"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1136
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1140
msgid "Error setting region (Problem with g.region?)"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1183 ../gui/tcltk/gis.m/mapcanvas.tcl:1188
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1188 ../gui/tcltk/gis.m/mapcanvas.tcl:1193
msgid "Error reading current resolution with g.region"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1245 ../gui/tcltk/gis.m/georect.tcl:2029
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1250 ../gui/tcltk/gis.m/georect.tcl:2029
msgid "Drag or click mouse to zoom"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1247 ../gui/tcltk/gis.m/georect.tcl:2031
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1252 ../gui/tcltk/gis.m/georect.tcl:2031
msgid "Drag or click mouse to unzoom"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1482 ../gui/tcltk/gis.m/georect.tcl:2229
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1487 ../gui/tcltk/gis.m/georect.tcl:2229
msgid "Drag with mouse to pan"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1609
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1614
msgid "Measurement"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1628
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1633
msgid "Draw measure line with mouse"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1785
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1790
msgid "Click to query feature"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1853
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1858
msgid "This layer type does not support queries"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1854
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1859
msgid "Query not supported"
msgstr ""
-#: ../gui/tcltk/gis.m/mapcanvas.tcl:1861
+#: ../gui/tcltk/gis.m/mapcanvas.tcl:1866
msgid "You must select a map to query\n"
msgstr ""
@@ -4555,6 +4563,30 @@
msgid "r.info error"
msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:156 ../gui/tcltk/d.m/vector.tcl:354
+msgid " show data"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:230
+msgid "Graduate colors: preset color schemes"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:258
+msgid "create graphic legend"
+msgstr ""
+#: ../gui/tcltk/d.m/thematic.tcl:267
+msgid " select monitor for legend"
+msgstr ""
+#: ../gui/tcltk/d.m/labels.tcl:65
+msgid "Labels name:"
+msgstr ""
+#: ../gui/tcltk/d.m/frames.tcl:64
+msgid "remove all frames"
+msgstr ""
#: ../gui/tcltk/d.m/monitorsel.tcl:33
msgid "x0"
msgstr ""
@@ -4611,30 +4643,6 @@
msgid "Start/select display monitor x6"
msgstr ""
-#: ../gui/tcltk/d.m/thematic.tcl:156 ../gui/tcltk/d.m/vector.tcl:354
-msgid " show data"
-msgstr ""
-#: ../gui/tcltk/d.m/thematic.tcl:230
-msgid "Graduate colors: preset color schemes"
-msgstr ""
-#: ../gui/tcltk/d.m/thematic.tcl:258
-msgid "create graphic legend"
-msgstr ""
-#: ../gui/tcltk/d.m/thematic.tcl:267
-msgid " select monitor for legend"
-msgstr ""
-#: ../gui/tcltk/d.m/labels.tcl:65
-msgid "Labels name:"
-msgstr ""
-#: ../gui/tcltk/d.m/frames.tcl:64
-msgid "remove all frames"
-msgstr ""
#: ../gui/tcltk/d.m/gridline.tcl:78
msgid "geodetic grid"
msgstr ""
Added: grass/branches/develbranch_6/locale/po/grasswxpy_el.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_el.po (rev 0)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_el.po 2008-10-12 07:12:30 UTC (rev 33835)
@@ -0,0 +1,7116 @@
+# translation of grasswxpy_el.po to Greek - BáóÃëåéïò ÃÃôùÃÃïõ
+# This file is distributed under the same license as the GRASS package.
+# Copyright (C) 2008 GRASS Development Team
+msgid ""
+msgstr ""
+"Project-Id-Version: grasswxpy_el\n"
+"Report-Msgid-Bugs-To: \n"
+"PO-Revision-Date: 2008-10-01 14:42+0300\n"
+"Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
+"Language-Team: BáóÃëåéïò ÃÃôùÃÃïõ <grass-translations at lists.osgeo."
+"org>\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=ISO-8859-7\n"
+"Content-Transfer-Encoding: 8bit\n"
+"X-Generator: KBabel 1.11.4\n"
+#: ../gui/wxpython/icons/icon.py:162
+msgid "Unable to load icon theme, using default icon theme..."
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:228
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:230
+msgid "Re-render map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:231
+msgid "Force re-rendering of all layers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:233
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:235
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:237
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:238
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:240
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:241
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:243
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:244
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:246
+msgid "Query raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:247
+msgid "Query selected raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:249
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:251
+msgid "Zoom options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:252
+msgid "Display zoom management"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:254
+msgid "Add overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:255
+msgid "Add graphic overlays to map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:257
+msgid "Add scalebar and north arrow"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:259
+msgid "Add legend"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:261
+msgid "Save display to PNG file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:263
+#: ../gui/wxpython/gui_modules/mapdisp.py:3273
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:266
+msgid "Start new display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:268
+msgid "Create new workspace file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:270
+msgid "Load map layers into workspace"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/gui_modules/menudata.py:35
+msgid "Open existing workspace file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/gui_modules/menudata.py:50
+msgid "Save current workspace to file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:277
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:279
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:281
+msgid "Add command layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:283
+msgid "Add layer group"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:285
+msgid "Add grid or vector labels overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:287 ../gui/wxpython/gui_modules/dbm.py:2281
+msgid "Delete selected layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:289
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:291
+msgid "Show attribute table"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:293
+msgid "Add RGB layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:295
+msgid "Add HIS layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:297
+msgid "Add shaded relief map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:299
+msgid "Add raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:301
+msgid "Add raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:303
+msgid "Add thematic layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:305
+msgid "Add thematic chart layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:307
+msgid "Add grid layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:309
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:311
+msgid "Add rhumbline layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:313
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/gui_modules/mapdisp.py:3851
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:317
+msgid "Add 3D raster map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:320
+msgid "Digitize new point"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:321 ../gui/wxpython/icons/icon.py:330
+msgid "Left: new point"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:323
+msgid "Digitize new line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:324 ../gui/wxpython/icons/icon.py:327
+#: ../gui/wxpython/icons/icon.py:348
+msgid "Left: new point; Middle: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:326
+msgid "Digitize new boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:329
+msgid "Digitize new centroid"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:332
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:333 ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/icons/icon.py:339 ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:354 ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:363 ../gui/wxpython/icons/icon.py:369
+msgid "Left: Select; Middle: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/gui_modules/toolbars.py:689
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:338
+msgid "Delete feature(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:341
+msgid "Display/update attributes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:342 ../gui/wxpython/icons/icon.py:345
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:344
+msgid "Display/update categories"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:347
+msgid "Edit line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:350
+msgid "Move feature(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:353
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:356
+msgid "Remove vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:359 ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/gui_modules/nviz_tools.py:945
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:360
+msgid "Settings dialog for digitization tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:362
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:365
+msgid "Quit digitizing tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:367
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:371
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:372
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:375
+msgid "Analyze map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:377
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:379
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:381
+msgid "Profile surface map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:383
+msgid "Draw/re-draw profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:385
+msgid "Profile options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:387
+msgid "Create histogram of image or raster file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:389
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:391
+msgid "Select color"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:393
+#: ../gui/wxpython/gui_modules/gdialogs.py:297
+msgid "Set options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:395
+msgid "Analyze"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:398
+msgid "Set GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:399
+msgid "Define GCP (Ground Control Points)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/gui_modules/menudata.py:433
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:403
+msgid "Recalculate RMS error"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:405
+msgid "Redraw GCP markers in map displays"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:407
+msgid "Save GCPs to POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:409
+msgid "Add new GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:411
+msgid "Delete selected GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:413
+msgid "Clear selected GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:415
+msgid "Reload GCPs from selected POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:417
+msgid "Quit georectification module"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:420
+msgid "Settings dialog for georectification tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:424
+msgid "Show Nviz settings dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:131
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:137
+#: ../gui/wxpython/gui_modules/location_wizard.py:1076
+#: ../gui/wxpython/gui_modules/location_wizard.py:1154
+#: ../gui/wxpython/gui_modules/location_wizard.py:1246
+#: ../gui/wxpython/gui_modules/menuform.py:1217
+#: ../gui/wxpython/gui_modules/gdialogs.py:801
+#: ../gui/wxpython/gui_modules/gdialogs.py:811 ../gui/wxpython/gis_set.py:123
+msgid "Browse"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:145
+#: ../gui/wxpython/gis_set.py:99
+msgid "GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:161
+msgid "Project Location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:199
+msgid "Choose GRASS data directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:210
+#: ../gui/wxpython/gui_modules/location_wizard.py:1839
+msgid "Location already exists in GRASS Database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:213
+msgid "Unable to create location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:217
+#: ../gui/wxpython/gui_modules/location_wizard.py:540
+#: ../gui/wxpython/gui_modules/location_wizard.py:1420
+#: ../gui/wxpython/gui_modules/location_wizard.py:1840
+#: ../gui/wxpython/gui_modules/location_wizard.py:1916
+#: ../gui/wxpython/gui_modules/location_wizard.py:2021
+#: ../gui/wxpython/gui_modules/location_wizard.py:2055
+#: ../gui/wxpython/gui_modules/location_wizard.py:2230
+#: ../gui/wxpython/gui_modules/location_wizard.py:2249
+#: ../gui/wxpython/gui_modules/location_wizard.py:2556
+#: ../gui/wxpython/gui_modules/georect.py:885
+#: ../gui/wxpython/gui_modules/georect.py:922
+#: ../gui/wxpython/gui_modules/gdialogs.py:144
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/mapdisp.py:1138
+#: ../gui/wxpython/gui_modules/mapdisp.py:1769
+#: ../gui/wxpython/gui_modules/mapdisp.py:2723
+#: ../gui/wxpython/gui_modules/workspace.py:617
+#: ../gui/wxpython/gui_modules/preferences.py:1508
+#: ../gui/wxpython/gui_modules/dbm.py:188
+#: ../gui/wxpython/gui_modules/dbm.py:272
+#: ../gui/wxpython/gui_modules/dbm.py:1217
+#: ../gui/wxpython/gui_modules/dbm.py:1321
+#: ../gui/wxpython/gui_modules/dbm.py:1405
+#: ../gui/wxpython/gui_modules/dbm.py:1417
+#: ../gui/wxpython/gui_modules/dbm.py:1431
+#: ../gui/wxpython/gui_modules/dbm.py:1524
+#: ../gui/wxpython/gui_modules/dbm.py:1546
+#: ../gui/wxpython/gui_modules/dbm.py:1686
+#: ../gui/wxpython/gui_modules/dbm.py:1697
+#: ../gui/wxpython/gui_modules/dbm.py:1709
+#: ../gui/wxpython/gui_modules/dbm.py:2554
+#: ../gui/wxpython/gui_modules/dbm.py:2561
+#: ../gui/wxpython/gui_modules/dbm.py:2599
+#: ../gui/wxpython/gui_modules/gcmd.py:59
+#: ../gui/wxpython/gui_modules/gcmd.py:82
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:406
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:431
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1224
+#: ../gui/wxpython/gui_modules/vdigit.py:1895
+#: ../gui/wxpython/gui_modules/vdigit.py:2073
+#: ../gui/wxpython/gui_modules/vdigit.py:2097 ../gui/wxpython/gis_set.py:672
+#: ../gui/wxpython/wxgui.py:731 ../gui/wxpython/wxgui.py:863
+#: ../gui/wxpython/wxgui.py:872
+msgid "Error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:239
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:246
+msgid "Select coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:249
+msgid "Select EPSG code of coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:251
+msgid "Use coordinate system of selected georeferenced file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:254
+msgid "Use coordinate system of selected WKT or PRJ file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:257
+msgid "Create custom PROJ.4 parameters string for coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:260
+msgid "Use arbitrary non-earth coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:332
+msgid "Choose projection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:347
+#: ../gui/wxpython/gui_modules/location_wizard.py:771
+#: ../gui/wxpython/gui_modules/location_wizard.py:779
+#: ../gui/wxpython/gui_modules/location_wizard.py:964
+#: ../gui/wxpython/gui_modules/location_wizard.py:1254
+msgid "Code"
+msgstr ""
+msgid "Description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:350
+msgid "Projection code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:358
+#: ../gui/wxpython/gui_modules/location_wizard.py:793
+#: ../gui/wxpython/gui_modules/location_wizard.py:976
+#: ../gui/wxpython/gui_modules/location_wizard.py:1237
+msgid "Search in description:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:539
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:639
+#: ../gui/wxpython/gui_modules/location_wizard.py:1431
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:647
+msgid "Select datum with associated ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:650
+msgid "Select ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:651
+msgid "Set zone for UTM projection:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:653
+msgid "Zone:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:656
+msgid "Hemisphere for zone:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:744
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr ""
+msgid "Datum"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:784
+msgid "Datum code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:808
+msgid "Transformation parameters:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:941
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:968
+msgid "Ellipsoid code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1069
+#: ../gui/wxpython/gui_modules/location_wizard.py:1128
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1074
+msgid "Georeferenced file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1147
+#: ../gui/wxpython/gui_modules/location_wizard.py:1206
+msgid "Select WKT file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1152
+msgid "WKT file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1225
+msgid "Choose EPSG Code"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1233
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1235
+msgid "EPSG code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1247
+msgid "Browse EPSG Codes"
+msgstr ""
+msgid "Parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1368
+msgid "Choose EPSG codes file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1419
+#, python-format
+msgid "Unable to read EPGS codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1439
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1490
+msgid "Summary"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1512
+msgid "GRASS Database:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1518
+msgid "Location Name:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1524
+msgid "Projection:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1563
+msgid "PROJ.4 definition:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1608
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1609
+msgid "Create new location?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1645
+msgid "Define new GRASS Location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1723
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1725
+#, python-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1739
+#, python-format
+msgid "Unable to create new location. Location <%s> not created."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1741
+#: ../gui/wxpython/gui_modules/location_wizard.py:1749
+#: ../gui/wxpython/gis_set.py:127
+msgid "Location wizard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1747
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1837
+#: ../gui/wxpython/gui_modules/location_wizard.py:1915
+#: ../gui/wxpython/gui_modules/location_wizard.py:2020
+#: ../gui/wxpython/gui_modules/location_wizard.py:2094
+#: ../gui/wxpython/gui_modules/location_wizard.py:2125
+msgid "Unable to create new location"
+msgstr ""
+msgid "EPSG code missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2054
+msgid "Datum transform is required."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2095
+#: ../gui/wxpython/gui_modules/location_wizard.py:2126
+msgid "file not found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2149
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2193
+msgid "&Set region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2229
+msgid "Invalid location selected."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2248
+msgid "Invalid region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2278
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2279
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2302
+#: ../gui/wxpython/gui_modules/location_wizard.py:2583
+#, python-format
+msgid "Rows: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2303
+#: ../gui/wxpython/gui_modules/location_wizard.py:2584
+#, python-format
+msgid "Cols: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2304
+#: ../gui/wxpython/gui_modules/location_wizard.py:2585
+#, python-format
+msgid "Cells: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2345
+#: ../gui/wxpython/gui_modules/location_wizard.py:2587
+#, python-format
+msgid "Depth: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2346
+#: ../gui/wxpython/gui_modules/location_wizard.py:2588
+#, python-format
+msgid "3D Cells: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2349
+msgid "Top"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2357
+msgid "Bottom"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2365
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2428
+msgid "North"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2436
+msgid "West"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2456
+msgid "East"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2465
+msgid "South"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2469
+msgid "N-S resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2477
+msgid "E-W resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2555
+#, python-format
+msgid "Invalid value: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2612
+msgid "Select datum transformation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2626
+msgid "List of datum transformations"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2630
+msgid "Datums:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:107
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:137
+#: ../gui/wxpython/gui_modules/georect.py:140
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:175
+msgid "Set ground control points (GCPs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:274
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:301
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:302
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:640
+msgid "raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:661
+msgid "vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:308
+msgid "Select source location:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:319
+msgid "Select source mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:373
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:384
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:401
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:420
+msgid "Select group:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:431
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:434
+msgid "Create/edit group..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:440
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:491
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:496
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:541
+msgid "Select image/map to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:549
+msgid "Select display image/map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:581
+msgid "You must select a valid image/map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:605
+msgid "Create & manage ground control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:699
+msgid "Select rectification method for rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:700
+msgid "1st order"
+msgstr ""
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:706
+msgid "clip to computational region in target location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:711
+msgid "Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:777
+#, python-format
+msgid "At least %d GCPs required. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:778
+msgid "Delete GCP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:879
+#, python-format
+msgid "POINTS file <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:880
+msgid "POINTS file saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:883
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:920
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:965
+msgid "RMS Error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:966
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"7+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1037
+msgid "Georectifier settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1127
+#, python-format
+msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1160
+msgid "use| X coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1161
+msgid "Y coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1162
+msgid "E coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1163
+msgid "N coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1164
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1165
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1265
+#: ../gui/wxpython/gui_modules/georect.py:1373
+msgid "Edit GCP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1266
+msgid "Invalid coordinate value. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1384
+msgid "Ground Control Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1398
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1399
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1400
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1401
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1487
+msgid "Symbol settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:554
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1243
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:538
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1214
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1541
+#: ../gui/wxpython/gui_modules/profile.py:990
+#: ../gui/wxpython/gui_modules/profile.py:1335
+#: ../gui/wxpython/gui_modules/preferences.py:825
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1269
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1543
+#: ../gui/wxpython/gui_modules/profile.py:992
+#: ../gui/wxpython/gui_modules/profile.py:1337
+#: ../gui/wxpython/gui_modules/preferences.py:827
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1271
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1546
+#: ../gui/wxpython/gui_modules/profile.py:995
+#: ../gui/wxpython/gui_modules/profile.py:1340
+#: ../gui/wxpython/gui_modules/preferences.py:830
+#: ../gui/wxpython/gui_modules/vdigit.py:1075
+msgid "Close dialog and ignore changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1573
+#, python-format
+msgid "Georectifier settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:138
+#: ../gui/wxpython/gui_modules/menuform.py:1179
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:186
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:203
+#, python-format
+msgid "Parameter not found: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:221
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:255
+#: ../gui/wxpython/gui_modules/menuform.py:1408
+msgid "<required>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:256
+#, python-format
+msgid "Parameter %(name)s (%(desc)s) is missing.\n"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:627
+msgid "Enter parameters for "
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:631
+msgid " (those in bold typeface are required)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:642
+msgid "Close this window without executing the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:647
+msgid "Show manual page of the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:665
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:666
+msgid "Run the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:670
+msgid "Abort the running command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:674
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:706
+#: ../gui/wxpython/gui_modules/gdialogs.py:68
+#: ../gui/wxpython/gui_modules/preferences.py:1096
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:715
+#: ../gui/wxpython/gui_modules/preferences.py:1086
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:827
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:895
+#: ../gui/wxpython/gui_modules/menuform.py:1275
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:885
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:923 ../gui/wxpython/wxgui.py:310
+#: ../gui/wxpython/wxgui.py:400
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:930
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1005
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1043
+msgid "Valid range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1198
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1215
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1216
+#: ../gui/wxpython/gui_modules/menudata.py:26
+msgid "File"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1477
+#, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1511
+#, python-format
+msgid "Unable to fetch interface description for command '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1595
+#, python-format
+msgid "Unable to parse command %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1683
+#, python-format
+msgid "usage: %s <grass command>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:58
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:64
+msgid "Create attribute table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:127
+#: ../gui/wxpython/gui_modules/menudata.py:1201
+msgid "Create new vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:143
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:160
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:163
+msgid "Overwrite?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:203
+#, python-format
+msgid "New vector map <%s> created"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:225
+msgid "Load region:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:233
+msgid "Save region:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:304
+#, python-format
+msgid ""
+"Drag %s with mouse in pointer mode to position.\n"
+"Double-click to change options."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:307
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:358
+#, python-format
+msgid "Legend of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:473
+msgid "Enter text:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:486
+msgid "Rotation:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:499
+#: ../gui/wxpython/gui_modules/preferences.py:960
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:510
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:601
+msgid "Load"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:636
+msgid "Map layer type:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:647
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:660
+msgid "Filter:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:672
+msgid "List of maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:728
+#: ../gui/wxpython/gui_modules/gdialogs.py:1081
+#: ../gui/wxpython/gui_modules/dbm.py:959
+msgid "Select all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:729
+#: ../gui/wxpython/gui_modules/gdialogs.py:1082
+#: ../gui/wxpython/gui_modules/dbm.py:960
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:782
+msgid "Multiple import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:796
+msgid "Input DXF file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:797
+msgid "Choose DXF file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:800
+msgid "Choose DXF file to import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:806
+msgid "Input directory"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:807
+msgid "Choose directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:814
+msgid "Select file extension:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:831
+msgid "Add imported layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:839
+msgid "Close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:842
+msgid "&Import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:843
+msgid "Import selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:883
+#, python-format
+msgid " List of %s layers "
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:998
+#, python-format
+msgid ""
+"File <%(file)s>: Unable to get list of DXF layers.\n"
+"\n"
+"%(details)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1044
+#: ../gui/wxpython/gui_modules/dbm.py:2019
+#: ../gui/wxpython/gui_modules/dbm.py:2120
+#: ../gui/wxpython/gui_modules/dbm.py:2356
+#: ../gui/wxpython/gui_modules/dbm.py:3133
+#: ../gui/wxpython/gui_modules/vdigit.py:1382
+#: ../gui/wxpython/gui_modules/vdigit.py:1384
+#: ../gui/wxpython/gui_modules/vdigit.py:1765
+#: ../gui/wxpython/gui_modules/vdigit.py:2196
+msgid "Layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1045
+msgid "Layer name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1046
+msgid "Output vector map name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1128
+msgid "Set Map Layer Opacity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
+msgid "transparent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1155
+msgid "opaque"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:30
+msgid "Enter rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:50
+msgid "Create new color table using color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:51
+msgid "Raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:53
+msgid "Enter color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:56
+msgid "Reclassify raster map using rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:57
+msgid "Raster map to reclassify:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:58
+msgid "Reclassified raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:59
+#: ../gui/wxpython/gui_modules/rules.py:71
+msgid "Enter reclassification rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:62
+msgid "Recode raster map using rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:63
+msgid "Raster map to recode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:64
+msgid "Recoded raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:65
+msgid "Enter recoding rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:68
+msgid "Reclassify vector map using SQL rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:69
+msgid "Vector map to reclassify:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:70
+msgid "Reclassified vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:103
+msgid "overwrite existing file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1137
+#: ../gui/wxpython/gui_modules/mapdisp.py:1768
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1285
+#: ../gui/wxpython/gui_modules/mapdisp.py:1292
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2353
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2404
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2406
+#: ../gui/wxpython/gui_modules/workspace.py:633
+msgid "Warning"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2467
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2541
+msgid "Render"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2544
+msgid "Enable/disable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2547
+msgid "Show computational extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2552
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2560
+#: ../gui/wxpython/gui_modules/preferences.py:1027
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2564
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2663
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2677
+msgid "Vector digitizer toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2694
+msgid "Georectification toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2706
+#, python-format
+msgid ""
+"Unable to start Nviz. The GLCanvas class has not been included with this "
+"build of wxPython! Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2711
+#, python-format
+msgid ""
+"Unable to start Nviz. The OpenGL package was not found. You can get it at "
+"http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2716
+#, python-format
+msgid ""
+"Unable to start Nviz. Python extension for Nviz was not found or loaded "
+"properly. Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2747
+msgid "Please wait, loading data..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2777
+msgid "Nviz toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3265
+msgid "Page setup"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3269
+msgid "Print preview"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3363
+msgid "No map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3364
+#: ../gui/wxpython/gui_modules/mapdisp.py:3448
+#: ../gui/wxpython/gui_modules/dbm.py:2784 ../gui/wxpython/wxgui.py:1102
+#: ../gui/wxpython/wxgui.py:1470
+msgid "Message"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3447
+msgid "No vector map selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3509
+msgid "Query raster/vector map(s) (display mode)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3517
+msgid "Query vector map (edit mode)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3631
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3638
+msgid "Measuring distance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3642
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3800
+msgid "Scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3806
+msgid "Show/hide scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3807
+msgid "scale object"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3833
+msgid "Show/hide legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3834
+msgid "legend object"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3899
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:266
+msgid "Zoom to selected map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3903
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3907
+msgid "Zoom to default region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3911
+msgid "Zoom to saved region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3915
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3919
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:27
+#: ../gui/wxpython/gui_modules/preferences.py:1306
+msgid "Workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:29
+msgid "New workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:30
+msgid "Create new workspace file (erase current workspace settings first)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:34
+msgid "Open existing workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:39
+msgid "Load map layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:741
+msgid "Load map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:44
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:45
+msgid "Load map layers from GRC file to layer tree (not fully implemented)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:49 ../gui/wxpython/wxgui.py:825
+#: ../gui/wxpython/wxgui.py:843
+msgid "Save workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:54
+msgid "Save workspace as"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:55
+msgid "Save current workspace as file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:59
+msgid "Close current workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:60
+msgid "Close current workspace file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:66
+msgid "Import raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:68
+msgid "Import raster data using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:69
+msgid "Import GDAL supported raster file into a binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:72
+msgid "Multiple raster data import using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:73
+msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:79
+msgid "Aggregate ASCII xyz import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:80
+msgid ""
+"Create a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:84
+msgid "ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:85
+msgid "Converts ASCII raster file to binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:89
+msgid "ASCII polygons and lines import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:90
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:95
+msgid "Binary file import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:96
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:100
+msgid "ESRI ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:101
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+"map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:105
+msgid "GRIDATB.FOR import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:106
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:110
+msgid "MAT-File (v.4) import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:111
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:115
+msgid "SPOT NDVI import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:116
+msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr ""
+msgid "SRTM HGT import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:121
+msgid "Import SRTM HGT files into GRASS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:125
+msgid "Terra ASTER HDF import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:126
+msgid ""
+"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:131
+msgid "WMS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:132
+msgid "Downloads and imports data from WMS servers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:137
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:139
+msgid "Import vector data using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:140
+msgid "Convert OGR vector layers to GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:144
+msgid "Multiple vector data import using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:145
+msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:150
+msgid "ASCII points/GRASS ASCII vector import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:151
+msgid "Creates a vector map from ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:155
+msgid "Old GRASS vector import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:156
+msgid "Imports older versions of GRASS vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:161
+msgid "DXF import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:162
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:166
+msgid "Multiple DXF layers import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:167
+msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:172
+msgid "ESRI e00 import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:173
+msgid "Import E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:177
+msgid "Garmin GPS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:178
+msgid ""
+"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:182
+msgid "GPSBabel GPS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:183
+msgid ""
+"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+"file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:187
+msgid "GEOnet import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:188
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:192
+msgid "Matlab and MapGen import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:193
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:198
+msgid "Import grid 3D volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:200
+msgid "ASCII 3D import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:201
+msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:205
+msgid "Vis5D import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:206
+msgid ""
+"import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 "
+"time step)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:211
+msgid "Import database table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:213
+msgid "Multiple import formats using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:214
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:220
+msgid "Export raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:222
+msgid "Multiple export formats using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:223
+msgid "Exports GRASS raster map into GDAL supported formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:228
+msgid "ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:229
+msgid "Converts a raster map layer into an ASCII text file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:233
+msgid "ASCII x,y,z export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:234
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:239
+msgid "ESRI ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:240
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:244
+msgid "GRIDATB.FOR export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:245
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:249
+msgid "MAT-File (v.4) export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:250
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:255
+msgid "Binary export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:256
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:261
+msgid "MPEG-1 export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:262
+msgid "Raster File Series to MPEG Conversion Program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:266
+msgid "PNG export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:267
+msgid "Export GRASS raster as non-georeferenced PNG image format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:271
+msgid "PPM export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:272
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the currently defined region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:276
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:277
+msgid ""
+"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+"resolution of the CURRENTLY DEFINED REGION."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:281
+#: ../gui/wxpython/gui_modules/menudata.py:320
+msgid "POV-Ray export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:282
+msgid "Converts a raster map layer into a height-field file for POVRAY."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:286
+msgid "TIFF export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:287
+msgid ""
+"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+"resolution of the currently defined region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:291
+msgid "VRML export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:292
+msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:296
+#: ../gui/wxpython/gui_modules/menudata.py:330
+#: ../gui/wxpython/gui_modules/menudata.py:348
+msgid "VTK export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:297
+msgid "Converts raster maps into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:302
+msgid "Export vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:304
+msgid "Multiple export formats using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:305
+msgid "Converts to one of the supported OGR vector formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:310
+msgid "ASCII points/GRASS ASCII vector export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:311
+msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:315
+msgid "DXF export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:316
+msgid "Exports GRASS vector map layers to DXF file format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:321
+msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:325
+msgid "SVG export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:326
+msgid "Exports a GRASS vector map to SVG."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:331
+msgid "Converts a GRASS binary vector map to VTK ASCII output."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:336
+msgid "Export grid 3D volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:338
+msgid "ASCII 3D export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:339
+msgid "Converts a 3D raster map layer into an ASCII text file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:343
+msgid "Vis5D export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:344
+msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:349
+msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:355
+msgid "Manage maps and volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:357
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:358
+msgid ""
+"Copies available data files in the user's current mapset search path and "
+"location to the appropriate element directories under the user's current "
+"mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:363
+msgid "List"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:364
+msgid ""
+"Lists available GRASS data base files of the user-specified data type to "
+"standard output."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:368
+msgid "List filtered"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:369
+msgid "Apply regular expressions and wildcards to g.list"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:374
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
+msgid "Rename"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:375
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:380
+msgid "Delete"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:381
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:385
+msgid "Delete filtered"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:386
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:391
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:393
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:394
+msgid "Converts a raster map into a vector map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:398
+msgid "Raster series to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:399
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:403
+msgid "Raster 2.5D to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:404
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:409
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:410
+msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:414
+msgid "Vector to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:415
+msgid ""
+"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+"raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:419
+msgid "Sites to vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:420
+msgid "Converts a GRASS site_lists file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:425
+msgid "Volume to raster series"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:426
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:434
+msgid "Georectify raster and vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:439
+msgid "NVIZ (requires Tcl/Tk)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:440
+msgid "nviz - Visualization and animation tool for GRASS data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:445
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:446
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:451
+msgid "Postscript plot"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:452
+msgid "Hardcopy PostScript map output utility."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:457
+msgid "E&xit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:458
+msgid "Exit GUI"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:463
+msgid "Config"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:464
+msgid "Region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:466
+msgid "Display region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:467
+#: ../gui/wxpython/gui_modules/menudata.py:472
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:471
+msgid "Set region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:477
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:479
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:480
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:484
+msgid "Change working environment"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:485
+msgid "Change current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:489
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:490
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:494
+msgid "Show settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:495
+#: ../gui/wxpython/gui_modules/menudata.py:500
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:499
+msgid "Change settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:504
+msgid "Version"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:505
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:510
+#: ../gui/wxpython/gui_modules/menudata.py:512
+msgid "Manage projections"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:513
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format). Can also be used to create "
+"GRASS locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:517
+msgid "Projection for current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:518
+msgid "Create/edit projection information for current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:523
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:524
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:530
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:531
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:536
+msgid "Raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:537
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:539
+msgid "Digitize raster (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:540
+msgid "Digitize raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:545
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:546
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:551
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:552
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:556
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:557
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:561
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:562
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:566
+msgid "Timestamp"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:567
+msgid "Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:572
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:573
+msgid "Resamples raster map layers using aggregation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:577
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:578
+msgid "Resamples raster map layers using interpolation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:582
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:583
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:587
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:588
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:593
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:594
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:598
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:599
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:604
+msgid "Reproject raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:605
+msgid "Re-projects a raster map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:609
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:610
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:615
+#: ../gui/wxpython/gui_modules/menudata.py:1293
+msgid "Manage colors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:617
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:618
+msgid "Creates/modifies the color table associated with a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:622
+msgid "Color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:623
+#: ../gui/wxpython/gui_modules/menudata.py:1294
+msgid "Set colors interactively by entering color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:628
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:629
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:633
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:634
+msgid ""
+"Combines red, green and blue map layers into a single composite map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:638
+#: ../gui/wxpython/gui_modules/menudata.py:1598
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:639
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:645
+msgid "Query by coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:646
+msgid "Queries raster map layers on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:651
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:652
+msgid ""
+"Creates a raster map layer showing buffer zones surrounding cells that "
+"contain non-NULL category values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:656
+msgid "Closest points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:657
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:661
+#: ../gui/wxpython/gui_modules/nviz_tools.py:251
+#: ../gui/wxpython/gui_modules/nviz_tools.py:432
+#: ../gui/wxpython/gui_modules/nviz_tools.py:850
+msgid "Mask"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:662
+msgid "Create a MASK for limiting raster operation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:666
+msgid "Map calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:667
+msgid "Map calculator for raster map algebra"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:670
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:672
+msgid "Moving window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:673
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:677
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:678
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:683
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:685
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:686
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:690
+msgid "Raster series"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:691
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:695
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:696
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:701
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:702
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:707
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:709
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:710
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:714
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:715
+msgid ""
+"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
+"position is specified, or B: date/time to calculate the sun position by r."
+"sunmask itself."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:720
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:722
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:723
+msgid ""
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:727
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:728
+msgid ""
+"Outputs a raster map layer showing the cumulative cost of moving between "
+"different geographic locations on an input raster map layer whose cell "
+"category values represent cost."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:732
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:733
+msgid "Traces a flow through an elevation model on a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:738
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:652
+msgid "Shaded relief"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:739
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:744
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:745
+msgid ""
+"Generates raster map layers of slope, aspect, curvatures and partial "
+"derivatives from a raster map layer of true elevation values. Aspect is "
+"calculated counterclockwise from east."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:749
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:750
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:754
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:755
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:760
+msgid "Visibility"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:761
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:766
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:768
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:769
+msgid ""
+"Recategorizes data in a raster map layer by grouping cells that form "
+"physically discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:773
+msgid "Grow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:774
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:778
+msgid "Thin"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:779
+msgid "Thins non-zero cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:785
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:787
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:788
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:792
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:793
+msgid "Fills lake from seed at given level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:798
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:799
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:803
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:804
+msgid "Flow computation for massive grids (Float version)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:808
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:809
+msgid ""
+"Construction of slope curves (flowlines), flowpath lengths, and flowline "
+"densities (upslope areas) from a raster digital elevation model (DEM)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:814
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:815
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:819
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:820
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:825
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:826
+msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:830
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:831
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:836
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:837
+msgid "Generates a raster map layer showing watershed subbasins."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:841
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:842
+msgid "Watershed basin analysis program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:846
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:847
+msgid "Watershed basin creation program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:852
+msgid "Landscape structure modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:854
+msgid "Set up (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:855
+#: ../gui/wxpython/gui_modules/menudata.py:878
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:860
+msgid "Analyze landscape"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:861
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:865
+msgid "Analyze patches"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:866
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:870
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:871
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:876
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:879
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:884
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:885
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:889
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:890
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:895
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:896
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:900
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:901
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:905
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:906
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:910
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:911
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:915
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:916
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:920
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:921
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:926
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:927
+#: ../gui/wxpython/gui_modules/menudata.py:943
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:931
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:932
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:936
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:937
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:942
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:947
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:948
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:953
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:955
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:956
+msgid ""
+"Generates three, or four raster map layers showing 1) the base "
+"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
+"direction of the maximum ROS, and optionally 4) the maximum potential "
+"spotting distance."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:960
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:961
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:965
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:966
+msgid ""
+"It optionally produces raster maps to contain backlink UTM coordinates for "
+"tracing spread paths."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:972
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:974
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:975
+msgid "Interactively edit cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:980
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:981
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:985
+msgid "Reclassify interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:986
+msgid "Reclassify raster categories interactively by entering reclass rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:990
+msgid "Reclassify using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:991
+msgid ""
+"Creates a new map layer whose category values are based upon a "
+"reclassification of the categories in an existing raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:996
+msgid "Recode interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:997
+msgid ""
+"Recode raster categories interactively by entering recode rules (create new "
+"raster map)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1001
+msgid "Recode using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1002
+msgid ""
+"r.recode.rules - Use ascii rules file to recode categories in raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1007
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1008
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1012
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1013
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1020
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1021
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1024
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1026
+msgid "Random cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1027
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1031
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1032
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"sites."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1037
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1039
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1040
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1045
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1046
+msgid ""
+"Generates a raster density map from vector points data using a moving 2D "
+"isotropic Gaussian kernel or optionally generates a vector density map on "
+"vector network with a 1D kernel."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1050
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1051
+msgid ""
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1056
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1057
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1062
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1063
+msgid ""
+"Produces a raster map layer of uniform random deviates whose range can be "
+"expressed by the user."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1067
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1068
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1074
+msgid "Generate contour lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1075
+msgid ""
+"Produces a vector map layer of specified contours from a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1078
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1080
+msgid "Bilinear from raster points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1081
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1085
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1086
+msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1091
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1092
+msgid "Surface interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1096
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1097
+msgid ""
+"Surface interpolation from vector point data by Inverse Distance Squared "
+"Weighting."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1102
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1103
+msgid "Surface generation program from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1107
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1108
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1113
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1114
+msgid ""
+"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1120
+#: ../gui/wxpython/gui_modules/menudata.py:1711
+msgid "Report and statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1122
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1123
+msgid "Output basic information about a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1127
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1128
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1133
+msgid "General statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1134
+msgid "Generates area statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1138
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1139
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1143
+msgid "Sum category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1144
+msgid "Sums up the raster cell values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1148
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1149
+msgid "Reports statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1153
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1154
+msgid ""
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1158
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1159
+msgid "Surface area estimation for rasters."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1163
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1164
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1169
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1170
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1174
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1175
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1180
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1181
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1185
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1186
+msgid "Calculates linear regression from two raster maps: y = a + b*x"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1190
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1191
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1198
+msgid "Vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1199
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1202
+msgid "Create new empty vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1207
+msgid "Create/rebuild topology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1208
+msgid "Creates topology for GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1212
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1213
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1217
+msgid "Generalization"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1218
+msgid "Vector based generalization."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1223
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1224
+msgid "Change the type of geometry elements."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1229
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1230
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1235
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1236
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1240
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1241
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1245
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1246
+msgid "Create parallel line to input lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1251
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1252
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1257
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1258
+msgid "Converts vector map to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1262
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1263
+msgid "Extrudes flat vector object to 3D with defined height."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1268
+msgid "Link to OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1269
+msgid ""
+"Available drivers: ESRI Shapefile,MapInfo File,UK .NTF,SDTS,TIGER,S57,DGN,"
+"VRT,REC,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,GMT,SQLite,ODBC,PGeo,PostgreSQL,"
+"AVCBin"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1274
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1275
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1280
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1281
+msgid ""
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1285
+msgid "Reproject vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1286
+msgid "Allows projection conversion of vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1299
+msgid "Query with attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1300
+msgid ""
+"Selects vector objects from an existing vector map and creates a new map "
+"containing only the selected objects."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1304
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1305
+msgid "Queries a vector map layer at given locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1309
+msgid "Query with another vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1310
+msgid "Select features from ainput by features from binput"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1315
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1316
+msgid ""
+"Creates a buffer around features of given type (areas must contain centroid)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1319
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1321
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1322
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1326
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1327
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1331
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1332
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1337
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1339
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1340
+msgid "Create Linear Reference System"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1344
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1345
+msgid "Create stationing from input lines, and linear reference system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1349
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1350
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1354
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1355
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1361
+msgid "Nearest features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1362
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1365
+msgid "Network analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1367
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1368
+msgid ""
+"Centre node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1372
+msgid "Network maintenance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1373
+msgid "Network maintenance."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1377
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1378
+msgid "Visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1382
+msgid "Shortest path"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1383
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1387
+msgid "Display shortest route (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1388
+msgid ""
+"Display shortest route along network between 2 nodes (visualization only, "
+"requires XTerm))"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1392
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1393
+msgid ""
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1397
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1398
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1402
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1403
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1408
+#: ../gui/wxpython/gui_modules/menudata.py:1410
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1411
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1415
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1416
+msgid "Create a new vector map layer by combining other vector map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1422
+msgid "Change attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1424
+msgid "Manage or report categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1425
+msgid "Attach, delete or report vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1429
+msgid "Reclassify objects interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1430
+msgid "Reclassify vector objects interactively by entering SQL rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1434
+msgid "Reclassify objects using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1435
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1442
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1443
+msgid "Create a new vector from the current region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1446
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1448
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1449
+msgid "Uses a GRASS vector points map to produce a convex hull vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1453
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1454
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1458
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1459
+msgid ""
+"Creates a Voronoi diagram from an input vector map containing points or "
+"centroids."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1465
+msgid "Generate grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1466
+msgid "Creates a GRASS vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1469
+msgid "Generate points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1471
+msgid "Generate from database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1472
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1476
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1477
+msgid "Create points along input lines in new vector with 2 layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1481
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1482
+msgid "Randomly generate a 2D/3D vector points map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1486
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1487
+msgid "Random location perturbations of GRASS vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1494
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1495
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1499
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1500
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1505
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1506
+msgid ""
+"Calculates univariate statistics from a GRASS raster map based on vector "
+"polygons and uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1510
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1511
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1514
+msgid "Update point attributes from raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1516
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1517
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1521
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1522
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1528
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1530
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1531
+msgid "Outputs basic information about a user-specified vector map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1536
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1537
+msgid "Reports geometry statistics for vectors."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1541
+msgid "Upload or report topology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1542
+msgid "Populate database values from vector features."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1547
+msgid "Univariate attribute statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1548
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1553
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1554
+msgid "Indices for quadrat counts of sites lists."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1558
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1559
+msgid "Tests for normality for points."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1566
+msgid "Imagery"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1567
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1569
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1570
+msgid "Creates, edits, and lists groups and subgroups of imagery files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1574
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1575
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1580
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1581
+msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1586
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1588
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1589
+msgid "Auto-balancing of colors for LANDSAT images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1593
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1594
+msgid ""
+"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
+"transformation function."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1599
+msgid ""
+"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
+"transformation function"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1605
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1606
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1610
+msgid "Ortho photo rectification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1611
+msgid "Ortho Photo rectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1616
+msgid "Brovey sharpening"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1617
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1620
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1622
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1623
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1628
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1629
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1633
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1634
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1639
+msgid "Interactive input for supervised classification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1640
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1644
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1645
+msgid "Generates statistics for i.maxlik from raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1649
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1650
+msgid "Generate statistics for i.smap from raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1655
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1657
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1658
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1662
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1663
+msgid "Raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1669
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:338
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1670
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1674
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1675
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1679
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1680
+msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1683
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1685
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1686
+msgid "Canonical components analysis (cca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1690
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1691
+msgid "Principal components analysis (pca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1695
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1696
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1700
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1701
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1706
+msgid "Atmospheric correction"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1707
+msgid "Performs atmospheric correction using the 6S algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1713
+msgid "Bit pattern comparison "
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1714
+msgid "Compares bit patterns with a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1718
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1719
+msgid ""
+"Calculate error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1723
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1724
+msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1731
+msgid "Volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1732
+msgid "Develop volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1734
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1735
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1739
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1740
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1747
+msgid "3D Mask"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1748
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1752
+msgid "3D raster map calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1753
+msgid "Map calculator for volumetric map algebra"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1757
+msgid "Cross section"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1758
+msgid ""
+"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
+"map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1762
+msgid "Interpolate volume from points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1763
+msgid ""
+"Interpolates point data to a G3D grid volume using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1767
+msgid "Report and Statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1769
+msgid "Basic volume metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1770
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1777
+#: ../gui/wxpython/gui_modules/dbm.py:2019
+#: ../gui/wxpython/gui_modules/dbm.py:2131
+#: ../gui/wxpython/gui_modules/dbm.py:2370
+msgid "Database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1778
+msgid "Database information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1780
+msgid "Describe table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1781
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1785
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1786
+msgid "List all columns for a given table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1790
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1791
+msgid "List all database drivers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1795
+msgid "List tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1796
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1802
+msgid "Manage databases"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1804
+msgid "Connect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1805
+msgid "Prints/sets general DB connection for current mapset and exits."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1809
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1810
+msgid "Sets user/password for driver/database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1815
+msgid "Copy table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1816
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1820
+msgid "New table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1821
+msgid ""
+"Creates and adds a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1825
+msgid "Remove table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1826
+msgid "Drops an attribute table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1831
+msgid "Add columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1832
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1836
+msgid "Change values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1837
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1841
+#: ../gui/wxpython/gui_modules/dbm.py:765
+msgid "Rename column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1842
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1847
+msgid "Test"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1848
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1853
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1855
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1856
+msgid "Selects data from table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1860
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1861
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1865
+msgid "SQL statement"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1866
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1872
+msgid "Vector database connections"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1874
+msgid "Reconnect vector to database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1875
+msgid "Reconnects vectors to a new database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1879
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1880
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1887
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1889
+msgid "GRASS GIS help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1890
+#: ../gui/wxpython/gui_modules/menudata.py:1895
+msgid "Display the HTML man pages of GRASS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1894
+msgid "GRASS GIS GUI help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1899
+#: ../gui/wxpython/gui_modules/menudata.py:1900
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:616
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:629
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:787
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:64
+msgid "Profile Analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:152
+#: ../gui/wxpython/gui_modules/profile.py:270
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:156
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:158
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:159
+msgid "Cell values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:279
+#, python-format
+msgid "Profile of %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:305
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:430
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:431
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:641
+msgid "Profile text settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:668
+msgid "Profile settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:731
+msgid "Select raster map to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:766
+msgid "Select raster map 1 (required):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:767
+msgid "Select raster map 2 (optional):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:768
+msgid "Select raster map 3 (optional):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:862
+msgid "Text settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:869
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:879
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:900
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:910
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:925
+#: ../gui/wxpython/gui_modules/preferences.py:944
+#: ../gui/wxpython/gui_modules/preferences.py:1567
+msgid "Font settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:933
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:947
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:961
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1043
+#: ../gui/wxpython/gui_modules/profile.py:1388
+#, python-format
+msgid "Profile settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1099
+msgid "Profile line settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1109
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:340
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1114
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1121
+#: ../gui/wxpython/gui_modules/vdigit.py:1148
+msgid "Line width"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1131
+msgid "Line style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1140
+#: ../gui/wxpython/gui_modules/profile.py:1192
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1164
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1169
+#: ../gui/wxpython/gui_modules/nviz_tools.py:250
+#: ../gui/wxpython/gui_modules/nviz_tools.py:849
+msgid "Color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1175
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1184
+#: ../gui/wxpython/gui_modules/profile.py:1230
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1199
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1214
+msgid "Axis settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1220
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1221
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1239
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1247
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1255
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1279
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1284
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1291
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1297
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1307
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:359
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:491
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:492
+msgid "Collapse all except PERMANENT"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:493
+msgid "Collapse all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:494
+msgid "Expand all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:495
+#: ../gui/wxpython/gui_modules/dbm.py:951
+msgid "Edit selected record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:496
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:521
+msgid "box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:522
+msgid "sphere"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:523
+msgid "cube"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:524
+msgid "diamond"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:525
+msgid "dtree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:526
+msgid "ctree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:527
+msgid "aster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:528
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:529
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:596
+#, python-format
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+" Details: %(detail)s\n"
+" Line: '%(line)s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:626
+msgid "Uknown settings file location."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:657
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:756
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:791
+msgid "User GUI settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:815
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:823
+msgid "Revert settings to default and apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:858
+#: ../gui/wxpython/gui_modules/vdigit.py:1136
+#: ../gui/wxpython/gui_modules/nviz_tools.py:956
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:861
+msgid "General settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:872
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:894
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:897
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:910
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:922
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:940
+#: ../gui/wxpython/gui_modules/vdigit.py:1143
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:955
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:969
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:980
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1007
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1040
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1061
+msgid "Command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1064
+msgid "Command dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1106
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1125
+msgid "Raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1136
+msgid "Overlay raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1150
+msgid "Vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+#: ../gui/wxpython/gui_modules/nviz_tools.py:569
+msgid "Display:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1178
+#: ../gui/wxpython/gui_modules/vdigit.py:1364
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1186
+msgid "Highlighting"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1202
+msgid "Line width (in pixels)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1225
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1230
+msgid "Left mouse double click"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1241
+msgid "Encoding"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1252
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1273
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/dbm.py:2142
+#: ../gui/wxpython/gui_modules/dbm.py:2166
+#: ../gui/wxpython/gui_modules/dbm.py:2382
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1309
+msgid "Loading workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1321
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1332
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1350
+#: ../gui/wxpython/gui_modules/dbm.py:589
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1353
+msgid "Advanced settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1365
+msgid "Place where to store settings:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1386
+msgid "Icon theme:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1403
+msgid "Note: Requires GUI restart."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1423
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1447
+#, python-format
+msgid "Settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1507
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1574
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1673
+msgid "Set/unset access to mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1687
+#, python-format
+msgid ""
+"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
+"and current mapset are always accessible."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1754
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1755
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1756
+msgid "Group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:72
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:166
+msgid "Loading data..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:185
+#, python-format
+msgid "Column <%(column)s> not found in in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:236
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:266
+#, python-format
+msgid ""
+"Error loading attribute data. Record number: %(rec)d. Unable to cast value '%"
+"(val)s' in key column (%(key)s) to integer.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:289
+msgid "Limit 100000 records."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:306
+#: ../gui/wxpython/gui_modules/dbm.py:657
+#: ../gui/wxpython/gui_modules/dbm.py:978
+#: ../gui/wxpython/gui_modules/dbm.py:1578
+#: ../gui/wxpython/gui_modules/dbm.py:1594
+#: ../gui/wxpython/gui_modules/dbm.py:1719
+#, python-format
+msgid "Number of loaded records: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:460
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:464
+msgid "Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:495
+msgid "Browse data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:501
+msgid "Manage tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:507
+msgid "Manage layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:510
+msgid "Click here to show database connection information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:511
+msgid "Click here to hide database connection information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:547
+#: ../gui/wxpython/gui_modules/dbm.py:670
+#: ../gui/wxpython/gui_modules/dbm.py:2137
+#: ../gui/wxpython/gui_modules/dbm.py:2376
+msgid "Table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:553
+msgid "Attribute data - right-click to edit/manage records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:557
+msgid "SQL Query"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:580
+msgid "Apply SELECT statement and reload data records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:582
+#: ../gui/wxpython/gui_modules/dbm.py:1826
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:586
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:690
+#, python-format
+msgid "Table <%s> - right-click to delete column(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:703
+msgid "Manage columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:710
+#: ../gui/wxpython/gui_modules/dbm.py:1966
+msgid "Column name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:721
+msgid "Data type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:738
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:755
+msgid "Add"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:775
+msgid "To"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:785
+msgid "&Rename"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:844
+msgid "Layers of vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:853
+msgid "List of layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:955
+#: ../gui/wxpython/gui_modules/dbm.py:1175
+msgid "Insert new record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:956
+msgid "Delete selected record(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:957
+msgid "Delete all records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:962
+msgid "Highlight selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:963
+msgid "Highlight selected and zoom"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:967
+#: ../gui/wxpython/gui_modules/dbm.py:1852
+#: ../gui/wxpython/gui_modules/dbm.py:1856
+msgid "Extract selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:972
+#: ../gui/wxpython/gui_modules/dbm.py:1461
+#: ../gui/wxpython/gui_modules/vdigit.py:1930
+msgid "Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1004
+#, python-format
+msgid ""
+"Selected data records (%d) will permanently deleted from table. Do you want "
+"to delete them?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1007
+#: ../gui/wxpython/gui_modules/dbm.py:1053
+msgid "Delete records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1050
+#, python-format
+msgid ""
+"All data records (%d) will permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1186
+#, python-format
+msgid "Record with category number %d already exists in the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1196
+#, python-format
+msgid "Category number (column %s) is missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1204
+#: ../gui/wxpython/gui_modules/dbm.py:1307
+#, python-format
+msgid "Casting value '%(value)s' to %(type)s failed."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1215
+msgid "Unable to insert new record."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1284
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1319
+msgid "Unable to update existing record."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1403
+msgid "Unable to rename column. No column name defined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1412
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1428
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
+"(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1456
+msgid "Drop selected column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1459
+msgid "Drop all columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1522
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1544
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1685
+#: ../gui/wxpython/gui_modules/dbm.py:1708
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1695
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1780
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1851
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1929
+#: ../gui/wxpython/gui_modules/dbm.py:2298
+#: ../gui/wxpython/gui_modules/dbm.py:2687
+#, python-format
+msgid "Drop also linked attribute table (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2126
+#: ../gui/wxpython/gui_modules/dbm.py:2364
+msgid "Driver"
+msgstr ""
+msgid "Key"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2090
+msgid ""
+"Unable to determine default DB connection settings. Please define DB "
+"connection using db.connect module."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2109
+msgid "Add layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2161
+msgid "Table name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2174
+msgid "&Create table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2178
+msgid "&Add layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2182
+msgid "&Set default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2195
+msgid "Layer description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2242
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2284
+msgid "Layer to detele"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2305
+msgid "&Delete layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2349
+msgid "Modify selected layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2421
+msgid "&Modify layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2552
+msgid "Unable to create new table. Table name or key column name is missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2559
+#, python-format
+msgid "Unable to create new table. Table <%s> already exists in the database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2596
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2774
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2778
+#, python-format
+msgid ""
+"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+"You can disable this message from digitization settings. Or you can create "
+"and link attribute table to the vector map using Attribute Table Manager."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2797
+msgid "Close dialog on submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2807
+msgid "No attributes found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2813
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2815
+msgid "Add attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2817
+msgid "Display attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2821
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2822
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2838
+#: ../gui/wxpython/gui_modules/vdigit.py:1820
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3076
+msgid "Unknown"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3134
+#: ../gui/wxpython/gui_modules/dbm.py:3370
+#: ../gui/wxpython/gui_modules/vdigit.py:1382
+#: ../gui/wxpython/gui_modules/vdigit.py:1772
+#: ../gui/wxpython/gui_modules/vdigit.py:2197
+msgid "Category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3323
+msgid "Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3467 ../gui/wxpython/wxgui.py:1128
+msgid "GRASS GIS Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:43
+#, python-format
+msgid "GRASS SQL Builder: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:303
+#, python-format
+msgid "Command '%s' not yet implemented."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:375
+msgid "Save file as..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:477
+msgid ""
+"Please note that the data are left in incosistent stage and can be corrupted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:480
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:486
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:754
+msgid "Unable to encode text. Please set encoding in GUI preferences."
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:94
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:95
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:96
+msgid "Comp. region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:97
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:98
+msgid "Display mode"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:99
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:100
+msgid "Map scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:93
+#, python-format
+msgid "Error in command execution %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:101
+msgid "Preferences error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:108
+msgid "Vector digitizer error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:115
+msgid "Attribute table manager error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:122
+msgid "Nviz error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:353
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:356
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:358
+#: ../gui/wxpython/gui_modules/gcmd.py:362
+msgid "Error: "
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:447
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:126
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:260
+#, python-format
+msgid "Unsupported map layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:427
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:458
+msgid "Unable to open file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:625
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:628
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:972
+#: ../gui/wxpython/gui_modules/render.py:1059
+#, python-format
+msgid "Unable to render map layer <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1175
+#, python-format
+msgid "Unable render overlay <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1209
+#, python-format
+msgid "Unable render overlay <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:108
+msgid "GRASS GIS Map Display: "
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:118
+msgid "Map Layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:251
+msgid "Remove"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:262
+msgid "Change opacity level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:264
+msgid "Properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
+msgid "Set computational region from selected map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:281
+msgid "Show attribute data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:284
+msgid "Start editing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
+msgid "Stop editing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:300
+msgid "Use as background vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:326
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:342
+msgid "Metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:333
+msgid "Zoom to selected map (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:335
+msgid "Set computational region from selected map (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
+msgid "Nviz properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:404
+msgid "Unable to create profile of raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:429
+msgid "Unable to display histogram of raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:514
+#, python-format
+msgid "Set opacity <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:588
+msgid "Layer group:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:593
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1144
+msgid "Click to edit layer settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:640
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:643
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:646
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:649
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:652
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:655
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:658
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:661
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:664
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:667
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:670
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:673
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:676
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:679
+msgid "(double click to set properties)"
+msgstr ""
+msgid "3d raster"
+msgstr ""
+msgid "RGB"
+msgstr ""
+msgid "HIS"
+msgstr ""
+msgid "raster cell numbers"
+msgstr ""
+msgid "raster flow arrows"
+msgstr ""
+msgid "thematic map"
+msgstr ""
+msgid "thematic charts"
+msgstr ""
+msgid "grid"
+msgstr ""
+msgid "geodesic line"
+msgstr ""
+msgid "rhumbline"
+msgstr ""
+msgid "vector labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:953
+msgid "Please wait, updating data..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1223
+#, python-format
+msgid "Map <%s> not found."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:52
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:54
+#, python-format
+msgid "GRASS %s Map Calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:697
+msgid "Duplicate attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:764
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:774
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:782
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:790
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:798
+msgid "Break selected lines/boundaries at intersection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:806
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:814
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:822
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:830
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:838
+msgid "Feature type conversion"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1007
+#: ../gui/wxpython/gui_modules/toolbars.py:1099
+#: ../gui/wxpython/gui_modules/toolbars.py:1172
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1045
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1067
+msgid "Digitize"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1105
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1107
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1114
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1178
+#: ../gui/wxpython/gui_modules/toolbars.py:1183
+msgid "New vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:121
+msgid ""
+"Unable to initialize display driver, see README file for more information.\n"
+"\n"
+"Details:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:127
+#: ../gui/wxpython/gui_modules/vdigit.py:134
+#, python-format
+msgid ""
+"Unable to open vector map <%s> for editing.\n"
+"\n"
+"Data are probably corrupted, try to run v.build to rebuild the topology "
+"(Vector->Develop vector map->Create/rebuild topology)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:646
+msgid "Undo failed, data corrupted."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1070
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1073
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1098
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1166
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1172
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1188
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1193
+#: ../gui/wxpython/gui_modules/vdigit.py:1521
+#: ../gui/wxpython/gui_modules/vdigit.py:1534
+#: ../gui/wxpython/gui_modules/vdigit.py:1538
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1206
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1223
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1236
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1238
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1241
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1253
+msgid "Digitize line features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1256
+msgid "Break lines at intersection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1266
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1269
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1282
+msgid "Query tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1289
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1294
+msgid "Select by box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1303
+msgid "length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1308
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1310
+#: ../gui/wxpython/gui_modules/vdigit.py:1333
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1326
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1331
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1371
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1376
+msgid "Add new record into table"
+msgstr ""
+msgid "Mode"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1411
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1399
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1409
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1424
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1429
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1453
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1454
+msgid "Highlight (duplicates)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1455
+msgid "Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1456
+msgid "Line"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1457
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1458
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1459
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1460
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1461
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1462
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1463
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1464
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1465
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1466
+msgid "Area (closed boundary + centroid)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1467
+msgid "Direction"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1514
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1516
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1569
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1728
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1759
+msgid "Add new category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1796
+msgid "Apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1798
+msgid "Ignore changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1800
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1890
+#: ../gui/wxpython/gui_modules/vdigit.py:2092
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater then zero."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1924
+msgid "Delete selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1928
+msgid "Delete all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2072
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2234
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2237
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2244
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2253
+msgid "Step"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2286
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2379
+msgid "Feature id"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2380
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:92
+msgid "Create new color table for raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:94
+#: ../gui/wxpython/gui_modules/colorrules.py:388
+msgid "Enter raster cat values or percents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:96
+msgid "Create new color table for vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:98
+msgid "Enter vector attribute values or ranges (n or n1 to n2)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:113
+msgid "replace existing color table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:119
+msgid "Layer:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:121
+msgid "Attribute column:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:123
+msgid "RGB color column:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:152
+msgid "Preview"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:200
+msgid "Select raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:202
+msgid "Select vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:391
+#, python-format
+msgid "Enter raster cat values or percents (range = %d-%d)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:463
+msgid "Please select attribute column and RGB color column first"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:479
+msgid "Loading raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:483
+msgid "Loading 3d raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:489
+msgid "failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:491
+#, python-format
+msgid "Unsupported layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:545
+msgid "Unable to unload raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:546
+msgid "Raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:550
+msgid "Unable to unload 3d raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:551
+msgid "3d raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:558
+msgid "unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:609
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:660
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:663
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1185
+#, python-format
+msgid "Vector point layer not found (id=%d)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1187
+#, python-format
+msgid "Unable to set data layer properties (id=%d)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1191
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:40
+msgid "Nviz tools"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:109
+#: ../gui/wxpython/gui_modules/nviz_tools.py:984
+msgid "View"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:118
+msgid "W"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:120
+msgid "N"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:127
+msgid "S"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:129
+msgid "E"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:138
+#: ../gui/wxpython/gui_modules/nviz_tools.py:994
+msgid "Perspective:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:149
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:163
+msgid "Height:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:170
+msgid "Z-exag:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:184
+msgid "Look at:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:188
+msgid "top"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:189
+msgid "north"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:190
+msgid "south"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:191
+msgid "east"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:192
+msgid "west"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:193
+msgid "north-west"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+msgid "north-east"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:195
+msgid "south-east"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:196
+msgid "south-west"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:203
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:204
+msgid "Reset to default view"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:242
+msgid "Surface attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:249
+msgid "Topography"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:252
+#: ../gui/wxpython/gui_modules/nviz_tools.py:851
+msgid "Transparency"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:253
+#: ../gui/wxpython/gui_modules/nviz_tools.py:852
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:254
+#: ../gui/wxpython/gui_modules/nviz_tools.py:853
+msgid "Emission"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:260
+#: ../gui/wxpython/gui_modules/nviz_tools.py:861
+msgid "map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_tools.py:866
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:871
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:738
+msgid "Draw"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:334
+#: ../gui/wxpython/gui_modules/nviz_tools.py:745
+msgid "Mode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:337
+msgid "coarse"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:338
+msgid "fine"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:339
+msgid "both"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
+msgid "Resolution:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:353
+msgid "coarse:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:365
+msgid "fine:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:380
+msgid "Coarse style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:383
+msgid "wire"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:384
+msgid "surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:393
+#: ../gui/wxpython/gui_modules/nviz_tools.py:759
+msgid "Shading:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:396
+#: ../gui/wxpython/gui_modules/nviz_tools.py:574
+#: ../gui/wxpython/gui_modules/nviz_tools.py:762
+msgid "flat"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:397
+#: ../gui/wxpython/gui_modules/nviz_tools.py:763
+msgid "gouraud"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:406
+msgid "Wire color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:421
+msgid "All"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:422
+msgid "Use for all loaded surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:437
+msgid "Mask zeros:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:441
+msgid "by elevation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:446
+msgid "by color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:461
+msgid "Position"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:524
+msgid "Show vector lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+msgid "Vector lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:573
+msgid "on surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:583
+#: ../gui/wxpython/gui_modules/nviz_tools.py:688
+msgid "Height above surface:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+msgid "Show vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:626
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
+msgid "Vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:632
+msgid "Icon size:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:648
+msgid "width:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:664
+msgid "symbol:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:677
+msgid "color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:748
+msgid "isosurfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:749
+msgid "slides"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:794
+msgid "List of isosurfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:842
+msgid "Isosurface attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:848
+msgid "Topography level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:962
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:997
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1076
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1106
+msgid "(value)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1009
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1057
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1088
+msgid "(step)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1024
+msgid "Position:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+msgid "(x)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1054
+msgid "Height"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1073
+msgid "Twist"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
+msgid "Z-exag"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1118
+msgid "(step):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1140
+msgid "Surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1164
+msgid "Show lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
+msgid "Show points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1198
+msgid "Size:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1229
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1262
+msgid "Default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1267
+msgid "Restore default settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1507
+#, python-format
+msgid "Nviz settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2122
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2124
+msgid "Level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2296
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2314
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2332
+msgid "Layer properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2440
+#, python-format
+msgid "Vector map <%s> is 3D"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2443
+#, python-format
+msgid "Vector map <%s> is 2D"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2445
+#, python-format
+msgid "%(primitives)d primitives (%(points)d points)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:84
+msgid "Choose project location and mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:87
+msgid "Manage"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:89
+#, python-format
+msgid ""
+"Welcome to GRASS GIS %s\n"
+"The world's leading open source GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:95
+msgid ""
+"Select an existing project location and mapset\n"
+"or define a new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:101
+msgid ""
+"Project location\n"
+"(projection/coordinate system)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:104
+msgid ""
+"Accessible mapsets\n"
+"(directories of GIS files)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:107
+msgid ""
+"Create new mapset\n"
+"in selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:110
+msgid "Define new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:113
+msgid ""
+"Rename/delete selected\n"
+"mapset or location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:118
+msgid "Start GRASS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:125
+msgid "Create mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:129
+msgid "Rename mapset"
+msgstr ""
+msgid "Rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:130
+msgid "Delete mapset"
+msgstr ""
+msgid "Delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:173
+msgid "Welcome to GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:181
+msgid "Enter GRASS session"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:206
+#, python-format
+msgid "ERROR: Location <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:218
+#, python-format
+msgid "ERROR: Mapset <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:426 ../gui/wxpython/gis_set.py:450
+#, python-format
+msgid ""
+"Current name: %s\n"
+"Enter new name:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:427
+msgid "Rename selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:438
+msgid "Unable to rename mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:451
+msgid "Rename selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:464
+msgid "Unable to rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:476
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%"
+"(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:481
+msgid "Delete selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:490
+msgid "Unable to delete mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:501
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:505
+msgid "Delete selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:516
+msgid "Unable to delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:642
+msgid "Choose GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:657
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:658
+msgid "Create new mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:671
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:702
+msgid "GRASS Quickstart"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:100
+msgid "GRASS GIS Layer Manager (Experimental Prototype)"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:306
+msgid "Map layers for each display"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:431
+msgid "Type GRASS command and run by pressing ENTER"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:552
+msgid ""
+"Workspace is not empty. Do you want to store current settings to workspace "
+"file?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:555
+msgid "Save current settings?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:570
+msgid "Choose workspace file"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:634 ../gui/wxpython/wxgui.py:639
+#, python-format
+msgid ""
+"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
+"document."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:644 ../gui/wxpython/wxgui.py:749
+#: ../gui/wxpython/wxgui.py:785
+msgid "Please wait, loading workspace..."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:729
+msgid "Unable to read workspace file"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:769
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:808
+msgid "Choose file to save current workspace"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:823 ../gui/wxpython/wxgui.py:840
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:862
+#, python-format
+msgid "Unable to open workspace file <%s> for writing."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:871
+#, python-format
+msgid "Writing current settings to workspace file failed (%s)."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1063
+msgid "Import DXF layers"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1069
+msgid "Import GDAL layers"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1075
+msgid "Import OGR layers"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1100
+msgid "Attribute management is available only for vector maps."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1123
+msgid "Please wait, loading attribute data..."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1436
+#, python-format
+msgid "Do you want to remove map layer %s from layer tree?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1439
+msgid "Do you want to remove selected map layer from layer tree?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1443
+msgid "Remove map layer"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1469
+msgid "No map layer selected. Operation cancelled."
+msgstr ""
