[GRASS-SVN] r33844 - in grass/branches/develbranch_6: include
lib/gis
svn_grass at osgeo.org
Sun Oct 12 06:46:47 EDT 2008
Author: martinl
Date: 2008-10-12 06:46:47 -0400 (Sun, 12 Oct 2008)
New Revision: 33844
grass/branches/develbranch_6/include/gis.h
grass/branches/develbranch_6/lib/gis/parser.c
new gisprompts - dbcolumn, dbtable, layer
Modified: grass/branches/develbranch_6/include/gis.h
--- grass/branches/develbranch_6/include/gis.h 2008-10-12 09:04:01 UTC (rev 33843)
+++ grass/branches/develbranch_6/include/gis.h 2008-10-12 10:46:47 UTC (rev 33844)
@@ -103,9 +103,7 @@
#define TYPE_STRING 3
#define YES 1
#define NO 0
-#define GISPROMPT_COLOR "old,color,color"
-#define GISPROMPT_DBCOLUMN "old,dbcolumn,dbcolumn"
-#define GISPROMPT_DBTABLE "old,dbtable,dbtable"
+#define GISPROMPT_COLOR "old_color,color,color"
/* File/directory name lengths */
#define GNAME_MAX 256
Modified: grass/branches/develbranch_6/lib/gis/parser.c
--- grass/branches/develbranch_6/lib/gis/parser.c 2008-10-12 09:04:01 UTC (rev 33843)
+++ grass/branches/develbranch_6/lib/gis/parser.c 2008-10-12 10:46:47 UTC (rev 33844)
@@ -335,7 +335,7 @@
Opt->required = NO;
Opt->multiple = NO;
Opt->description = _("Table name");
- Opt->gisprompt = GISPROMPT_DBTABLE;
+ Opt->gisprompt = "old_dbtable,dbtable,dbtable";
break;
case G_OPT_DRIVER:
Opt->key = "driver";
@@ -360,7 +360,7 @@
Opt->required = NO;
Opt->multiple = NO;
Opt->description = _("Name of attribute column");
- Opt->gisprompt = GISPROMPT_DBCOLUMN;
+ Opt->gisprompt = "old_dbcolumn,dbcolumn,dbcolumn";
break;
case G_OPT_COLUMNS:
Opt->key = "columns";
@@ -369,7 +369,7 @@
Opt->required = NO;
Opt->multiple = YES;
Opt->description = _("Name of attribute column(s)");
break;
/* imagery group */
@@ -573,6 +573,8 @@
Opt->description =
_("A single vector map can be connected to multiple database "
"tables. This number determines which table to use.");
+ Opt->gisprompt = "old_layer,layer,layer";
break;
case G_OPT_V_CAT:
Opt->key = "cat";
@@ -2751,17 +2753,10 @@
ptr1 = G_ask_old_file("", buff, element, desc);
else if (!strcmp("new_file", age)) /* file shouldn't exist unless overwrite is enabled */
ptr1 = G_ask_new_file("", buff, element, desc);
- else if (!strcmp("color", age))
- /* These prompts are only implemented in the gui */
- /* The data can still be entered in the console */
- return -1;
else {
- fprintf(stderr,
- "\nPROGRAMMER ERROR: first item in gisprompt is <%s>\n", age);
- fprintf(stderr,
- " Must be either new, old, mapset, any, old_file, new_file, or color\n");
return -1;
if (ptr1 == '\0')
*buff = '\0';
