[GRASS-SVN] r33846 - in grass/branches/develbranch_6:
display/d.vect gui/wxpython/gui_modules lib/gis
svn_grass at osgeo.org
Sun Oct 12 07:10:30 EDT 2008
Author: martinl
Date: 2008-10-12 07:10:29 -0400 (Sun, 12 Oct 2008)
New Revision: 33846
grass/branches/develbranch_6/display/d.vect/main.c
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/lib/gis/parser.c
gisprompt: handle color transparency
Modified: grass/branches/develbranch_6/display/d.vect/main.c
--- grass/branches/develbranch_6/display/d.vect/main.c 2008-10-12 10:48:12 UTC (rev 33845)
+++ grass/branches/develbranch_6/display/d.vect/main.c 2008-10-12 11:10:29 UTC (rev 33846)
@@ -161,7 +161,7 @@
color_opt->answer = DEFAULT_FG_COLOR;
color_opt->label = _("Line color");
color_opt->guisection = _("Colors");
- color_opt->gisprompt = GISPROMPT_COLOR;
+ color_opt->gisprompt = "old_color,color,color_none";
color_opt->description =
_("Either a standard GRASS color, R:G:B triplet, or \"none\"");
@@ -171,7 +171,7 @@
fcolor_opt->answer = "200:200:200";
fcolor_opt->label = _("Area fill color");
fcolor_opt->guisection = _("Colors");
- fcolor_opt->gisprompt = GISPROMPT_COLOR;
+ fcolor_opt->gisprompt = "old_color,color,color_none";
fcolor_opt->description =
@@ -250,7 +250,7 @@
lcolor_opt->answer = "red";
lcolor_opt->label = _("Label color");
lcolor_opt->guisection = _("Labels");
- lcolor_opt->gisprompt = GISPROMPT_COLOR;
+ lcolor_opt->gisprompt = "old_color,color,color";
lcolor_opt->description = _("Either a standard color name or R:G:B triplet");
bgcolor_opt = G_define_option();
@@ -259,7 +259,7 @@
bgcolor_opt->answer = "none";
bgcolor_opt->guisection = _("Labels");
bgcolor_opt->label = _("Label background color");
- bgcolor_opt->gisprompt = GISPROMPT_COLOR;
+ bgcolor_opt->gisprompt = "old_color,color,color_none";
bgcolor_opt->description =
@@ -269,7 +269,7 @@
bcolor_opt->answer = "none";
bcolor_opt->guisection = _("Labels");
bcolor_opt->label = _("Label border color");
- bcolor_opt->gisprompt = GISPROMPT_COLOR;
+ bcolor_opt->gisprompt = "old_color,color,color_none";
bcolor_opt->description =
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-10-12 10:48:12 UTC (rev 33845)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-10-12 11:10:29 UTC (rev 33846)
@@ -1132,6 +1132,7 @@
flag=wx.ADJUST_MINSIZE | wx.RIGHT | wx.LEFT | wx.TOP, border=5)
# GIS element entry
if p.get('prompt','') not in ('color',
+ 'color_none',
'dbcolumn',
'dbtable',
'layer') and \
@@ -1180,16 +1181,15 @@
which_sizer.Add(item=win, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
# color entry
- elif p.get('prompt', '') == 'color':
- # Heuristic way of finding whether transparent is allowed
- handle_transparency = 'none' in p.get('description', '')
+ elif p.get('prompt', '') in ('color',
+ 'color_none'):
default_color = (200,200,200)
label_color = _("Select Color")
if p.get('default','') != '':
default_color, label_color = color_resolve( p['default'] )
if p.get('value','') != '': # parameter previously set
default_color, label_color = color_resolve( p['value'] )
- if handle_transparency:
+ if p.get('prompt', '') == 'color_none':
this_sizer = wx.BoxSizer(orient=wx.HORIZONTAL )
else:
this_sizer = which_sizer
@@ -1202,7 +1202,7 @@
# the selector proper and either a "transparent" button or None
p['wxId'] = [btn_colour.GetId(),]
btn_colour.Bind(csel.EVT_COLOURSELECT, self.OnColorChange )
none_check = wx.CheckBox(which_panel, wx.ID_ANY, _("Transparent") )
if p.get('value','') != '' and p.get('value',[''])[0] == "none":
none_check.SetValue(True)
Modified: grass/branches/develbranch_6/lib/gis/parser.c
--- grass/branches/develbranch_6/lib/gis/parser.c 2008-10-12 10:48:12 UTC (rev 33845)
+++ grass/branches/develbranch_6/lib/gis/parser.c 2008-10-12 11:10:29 UTC (rev 33846)
@@ -624,7 +624,7 @@
Opt->key_desc = "name";
Opt->required = NO;
Opt->answer = DEFAULT_FG_COLOR;
- Opt->gisprompt = GISPROMPT_COLOR;
+ Opt->gisprompt = "old_color,color,color";
Opt->label = _("Color");
Opt->description = _("Either a standard color name or R:G:B triplet");
break;
@@ -634,7 +634,7 @@
Opt->required = NO;
Opt->answer = DEFAULT_BG_COLOR;
+ Opt->gisprompt = "old_color,color,color_none";
Opt->label = _("Background color");
Opt->description =
