[GRASS-SVN] r33851 - grass/trunk/scripts/i.oif
svn_grass at osgeo.org
Sun Oct 12 21:02:24 EDT 2008
Author: hamish
Date: 2008-10-12 21:02:23 -0400 (Sun, 12 Oct 2008)
New Revision: 33851
grass/trunk/scripts/i.oif/i.oif.html
fix typo (patch from Nikos; trac bug #329); whitespace
Modified: grass/trunk/scripts/i.oif/i.oif.html
--- grass/trunk/scripts/i.oif/i.oif.html 2008-10-13 00:56:48 UTC (rev 33850)
+++ grass/trunk/scripts/i.oif/i.oif.html 2008-10-13 01:02:23 UTC (rev 33851)
@@ -10,22 +10,30 @@
<P>
The analysis is saved to a file in the current directory called "i.oif.result".
<H2>NOTES</H2>
-Colour Composits in BGR order: important band combinations (example:
+Colour Composites in BGR order: important band combinations (example:
234 in BGR order means: B=2, G=3, R=4):
<ul>
-<li> 123: near natural ("true") colour; however, because of correlation of the 3 bands in visible
- spectrum, this combination contains not much more info than is contained in single band.
-<li> 234: sensitive to green vegetation (portrayed as red), coniferous as distinctly darker
- red than deciduous forests. Roads and water bodies are clear.
-<li> 243: green vegetation is green but coniferous forests aren't as clear as in the 234 combination
-<li> 247: one of the best for info pertaining to forestry. Good for operation scale mapping of
- recent harvest areas and road construction.
-<li> 345: contains one band from each of the main reflective units (vis, nir, shortwave infra).
- Green vegetation is green and the shortwave band shows vegetational stress and mortality.
- Roads are less evident as band 3 is blue.
+<li> 123: near natural ("true") colour; however, because of correlation of
+the 3 bands in visible spectrum, this combination contains not much more
+info than is contained in single band.
+<li> 234: sensitive to green vegetation (portrayed as red), coniferous as
+distinctly darker red than deciduous forests. Roads and water bodies are clear.
+<li> 243: green vegetation is green but coniferous forests aren't as clear as
+the 234 combination.
+<li> 247: one of the best for info pertaining to forestry. Good for operation
+scale mapping of recent harvest areas and road construction.
+<li> 345: contains one band from each of the main reflective units (vis, nir,
+shortwave infra). Green vegetation is green and the shortwave band shows
+vegetational stress and mortality. Roads are less evident as band 3 is blue.
<li> 347: similar to 345 but depicts burned areas better.
<li> 354: appears more like a colour infrared photo.
<li> 374: similar to 354.
@@ -37,14 +45,19 @@
Jensen, 1996. Introductory digital image processing, p.98. ISBN 0-13-205840-5
<H2>SEE ALSO</H2>
<EM><A HREF="d.rgb.html">d.rgb</A></EM><BR>
<EM><A HREF="r.composite.html">r.composite</A></EM><BR>
<EM><A HREF="r.covar.html">r.covar</A></EM><BR>
<EM><A HREF="r.univar.html">r.univar</A></EM><BR>
<BR>
<H2>AUTHOR</H2>
Markus Neteler, ITC-Irst, Trento, Italy<br>
Updated to GRASS 5.7 by Michael Barton, Arizona State University
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
