[GRASS-SVN] r33883 - in grass/trunk: gui/wxpython/gui_modules
scripts/v.dissolve
svn_grass at osgeo.org
Wed Oct 15 01:51:22 EDT 2008
Author: martinl
Date: 2008-10-15 01:51:22 -0400 (Wed, 15 Oct 2008)
New Revision: 33883
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/scripts/v.dissolve/v.dissolve
grass/trunk/scripts/v.dissolve/v.dissolve.py
wxGUI: support for layer_all ('-1' for all layers)
(merge from devbr6, r33881)
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-10-15 05:48:52 UTC (rev 33882)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-10-15 05:51:22 UTC (rev 33883)
@@ -421,10 +421,13 @@
def __init__(self, parent,
id=wx.ID_ANY, pos=wx.DefaultPosition,
size=globalvar.DIALOG_LAYER_SIZE,
- vector=None, choices=[]):
+ vector=None, choices=[], all=False):
super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
choices=choices)
+ self.all = all
self.SetName("LayerSelect")
if len(choices) > 1:
@@ -433,19 +436,24 @@
if vector:
self.InsertLayers(vector)
else:
- self.SetItems(['1'])
- self.SetSelection(0)
+ if all:
+ self.SetItems(['-1', '1'])
+ else:
+ self.SetItems(['1'])
+ self.SetStringSelection('1')
def InsertLayers(self, vector):
"""Insert layers for a vector into the layer combobox"""
layerchoices = VectorDBInfo(vector).layers.keys()
+ if self.all:
+ layerchoices.insert(0, '-1')
if len(layerchoices) > 1:
self.SetItems(map(str, layerchoices))
else:
class TableSelect(wx.ComboBox):
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-10-15 05:48:52 UTC (rev 33882)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-10-15 05:51:22 UTC (rev 33883)
@@ -1135,7 +1135,8 @@
'color_none',
'dbcolumn',
'dbtable',
- 'layer') and \
+ 'layer',
+ 'layer_all') and \
p.get('element', '') != 'file':
if p.get('multiple', 'no') == 'yes':
multiple = True
@@ -1166,9 +1167,16 @@
# layer, dbcolumn, dbtable entry
elif p.get('prompt', '') in ('dbcolumn',
'dbtable',
- 'layer'):
- if p.get('prompt', '') == 'layer':
- win = gselect.LayerSelect(parent=which_panel)
+ 'layer',
+ 'layer_all'):
+ if p.get('prompt', '') in ('layer',
+ 'layer_all'):
+ if p.get('prompt', '') == 'layer_all':
+ all = True
+ else:
+ all = False
+ win = gselect.LayerSelect(parent=which_panel,
+ all=all)
p['wxGetValue'] = win.GetStringSelection
win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
win.Bind(wx.EVT_CHOICE, self.OnSetValue)
Modified: grass/trunk/scripts/v.dissolve/v.dissolve
--- grass/trunk/scripts/v.dissolve/v.dissolve 2008-10-15 05:48:52 UTC (rev 33882)
+++ grass/trunk/scripts/v.dissolve/v.dissolve 2008-10-15 05:51:22 UTC (rev 33883)
@@ -37,8 +37,10 @@
#%option
#% key: layer
#% type: integer
-#% description: Layer number. If -1, all layers are extracted
+#% label: Layer number. If -1, all layers are extracted.
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
#% answer: 1
+#% gisprompt: old_layer,layer,layer_all
#% required : no
#%end
#%option
@@ -46,6 +48,7 @@
#% type: string
#% description: Name of column used to dissolve common boundaries
#% required : no
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
#%end
if [ -z "$GISBASE" ] ; then
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-10-15 05:48:52 UTC (rev 33882)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-10-15 05:51:22 UTC (rev 33883)
@@ -38,14 +38,17 @@
#%option
#% key: layer
#% type: integer
#% answer: 1
#% required : no
#%end
#%option
#% key: column
#% type: string
#% required : no
#%end
