[GRASS-SVN] r33890 - grass-addons/gipe/i.evapo.time_integration
svn_grass at osgeo.org
Wed Oct 15 20:43:20 EDT 2008
Author: ychemin
Date: 2008-10-15 20:43:20 -0400 (Wed, 15 Oct 2008)
New Revision: 33890
grass-addons/gipe/i.evapo.time_integration/main.c
NULL value bug fixing from Ines
Modified: grass-addons/gipe/i.evapo.time_integration/main.c
--- grass-addons/gipe/i.evapo.time_integration/main.c 2008-10-15 17:26:18 UTC (rev 33889)
+++ grass-addons/gipe/i.evapo.time_integration/main.c 2008-10-16 00:43:20 UTC (rev 33890)
@@ -14,7 +14,6 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -30,12 +29,11 @@
int nrows, ncols;
int row, col;
struct GModule *module;
- struct Option *input, *input1, *input2, *input3, *output;
+ struct Option *input, *input1, *input2, *input3, *input4, *input5, *output;
struct History history; /*metadata */
struct Colors colors; /*Color rules */
- /* FMEO Declarations**************** */
char *name, *name1, *name2; /*input raster name */
char *result; /*output raster name */
@@ -44,7 +42,7 @@
int infd[MAXFILES], infd1[MAXFILES], infd2[MAXFILES];
int outfd;
/* Pointers for file names */
char **names;
char **ptr;
@@ -53,14 +51,15 @@
char **names2;
char **ptr2;
int DOYbeforeETa[MAXFILES], DOYafterETa[MAXFILES];
int bfr, aft;
int ok;
int i = 0, j = 0;
double etodoy; /*minimum ETo DOY */
+ double startperiod, endperiod; /*first and last days (DOYs) of the period studied */
void *inrast[MAXFILES], *inrast1[MAXFILES], *inrast2[MAXFILES];
DCELL *outrast;
int data_format; /* 0=double 1=float 2=32bit signed int 5=8bit unsigned int (ie text) */
@@ -69,13 +68,15 @@
RASTER_MAP_TYPE in_data_type1[MAXFILES]; /* DOY of ETa */
RASTER_MAP_TYPE in_data_type2[MAXFILES]; /* ETo */
RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
G_gisinit(argv[0]);
module = G_define_module();
module->keywords = _("evapotranspiration,temporal,integration");
- module->description =
- _("Temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)\n");
+ module->description =_("Temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)\n");
/* Define the different options */
@@ -98,12 +99,24 @@
input3->type = TYPE_DOUBLE;
input3->required = YES;
input3->description = _("Value of DOY for ETo first day");
+ input4 = G_define_option();
+ input4->key = _("start_period");
+ input4->type = TYPE_DOUBLE;
+ input4->required = YES;
+ input4->description = _("Value of DOY for the first day of the period studied ");
+ input5 = G_define_option();
+ input5->key = _("end_period");
+ input5->type = TYPE_DOUBLE;
+ input5->required = YES;
+ input5->description = _("Value of DOY for the last day of the period studied ");
output = G_define_standard_option(G_OPT_R_OUTPUT);
output->description =
_("Name of the output temporally integrated ETa layer");
- /* FMEO init nfiles */
+ /* init nfiles */
nfiles = 1;
nfiles1 = 1;
nfiles2 = 1;
@@ -121,9 +134,22 @@
names2 = input2->answers;
ptr2 = input2->answers;
etodoy = atof(input3->answer);
+ startperiod = atof(input4->answer);
+ endperiod = atof(input5->answer);
result = output->answer;
+ if (endperiod<startperiod) {
+ G_fatal_error(_("The DOY for end_period can not be smaller than start_period"));
+ ok = 0;
+ if (etodoy>startperiod) {
+ G_fatal_error(_("The DOY for start_period can not be smaller than eto_doy_min"));
+ ok = 0;
if (G_legal_filename(result) < 0) {
G_fatal_error(_("[%s] is an illegal name"), result);
@@ -142,9 +168,8 @@
G_fatal_error(_("cell file [%s] not found"), name);
ok = 0;
- if (!ok) {
+ if (!ok)
continue;
infd[nfiles] = G_open_cell_old(name, mapset);
if (infd[nfiles] < 0) {
ok = 0;
@@ -152,20 +177,17 @@
/* Allocate input buffer */
in_data_type[nfiles] = G_raster_map_type(name, mapset);
- if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0) {
+ if ((infd[nfiles] = G_open_cell_old(name, mapset)) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), name);
- if ((G_get_cellhd(name, mapset, &cellhd)) < 0) {
+ if ((G_get_cellhd(name, mapset, &cellhd)) < 0)
G_fatal_error(_("Cannot read file header of [%s]"), name);
inrast[nfiles] = G_allocate_raster_buf(in_data_type[nfiles]);
nfiles++;
nfiles--;
- if (nfiles <= 1) {
+ if (nfiles <= 1)
G_fatal_error(_("The min specified input map is two"));
ok = 1;
for (; *ptr1 != NULL; ptr1++) {
@@ -179,9 +201,8 @@
G_fatal_error(_("cell file [%s] not found"), name1);
ok = 0;
- if (!ok) {
+ if (!ok)
continue;
infd1[nfiles1] = G_open_cell_old(name1, mapset);
if (infd1[nfiles1] < 0) {
ok = 0;
@@ -189,22 +210,21 @@
in_data_type1[nfiles1] = G_raster_map_type(name1, mapset);
- if ((infd1[nfiles1] = G_open_cell_old(name1, mapset)) < 0) {
+ if ((infd1[nfiles1] = G_open_cell_old(name1, mapset)) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), name1);
- if ((G_get_cellhd(name1, mapset, &cellhd)) < 0) {
+ if ((G_get_cellhd(name1, mapset, &cellhd)) < 0)
G_fatal_error(_("Cannot read file header of [%s]"), name1);
inrast1[nfiles1] = G_allocate_raster_buf(in_data_type1[nfiles1]);
nfiles1++;
nfiles1--;
- if (nfiles1 <= 1) {
+ if (nfiles1 <= 1)
- if (nfiles != nfiles1) G_fatal_error(_("ETa and ETa_DOY file numbers are not equal!"));
+ if (nfiles != nfiles1)
+ G_fatal_error(_("ETa and ETa_DOY file numbers are not equal!"));
@@ -220,9 +240,8 @@
G_fatal_error(_("cell file [%s] not found"), name2);
ok = 0;
- if (!ok) {
+ if (!ok)
continue;
infd2[nfiles2] = G_open_cell_old(name2, mapset);
if (infd2[nfiles2] < 0) {
ok = 0;
@@ -240,21 +259,20 @@
nfiles2++;
nfiles2--;
- if (nfiles2 <= 1) {
+ if (nfiles2 <= 1)
/* Allocate output buffer, use input map data_type */
nrows = G_window_rows();
ncols = G_window_cols();
outrast = G_allocate_raster_buf(out_data_type);
/* Create New raster files */
- if ((outfd = G_open_raster_new(result, 1)) < 0) {
+ if ((outfd = G_open_raster_new(result, 1)) < 0)
G_fatal_error(_("Could not open <%s>"), result);
/* Process pixels */
double doy[MAXFILES];
double sum[MAXFILES];
@@ -266,13 +284,14 @@
DCELL d1[MAXFILES];
DCELL d2[MAXFILES];
G_percent(row, nrows, 2);
/* read input map */
for (i = 1; i <= nfiles; i++) {
if ((G_get_raster_row(infd[i], inrast[i], row, in_data_type[i])) < 0) {
G_fatal_error(_("Could not read from <%s>"), name);
for (i = 1; i <= nfiles1; i++) {
if ((G_get_raster_row(infd1[i], inrast1[i], row, in_data_type1[i])) < 0) {
G_fatal_error(_("Could not read from <%s>"), name1);
@@ -285,8 +304,12 @@
/*process the data */
for (col = 0; col < ncols; col++) {
+ int d1_null=0;
+ int d_null=0;
switch (in_data_type[i]) {
case CELL_TYPE:
@@ -296,15 +319,27 @@
d[i] = (double)((FCELL *) inrast[i])[col];
break;
case DCELL_TYPE:
- d[i] = (double)((DCELL *) inrast[i])[col];
- break;
+ if (G_is_d_null_value(&((DCELL *) inrast[i])[col])){
+ d_null=1;
+ break;
+ else{
+ d[i] = (double)((DCELL *) inrast[i])[col];
+ break;
switch (in_data_type1[i]) {
case CELL_TYPE:
- d1[i] = (double)((CELL *) inrast1[i])[col];
- break;
+ if (G_is_c_null_value(&((CELL *) inrast1[i])[col])){
+ d1_null=1;
+ break;
+ else{
+ d1[i] = (double)((CELL *) inrast1[i])[col];
+ break;
case FCELL_TYPE:
d1[i] = (double)((FCELL *) inrast1[i])[col];
break;
@@ -312,7 +347,9 @@
d1[i] = (double)((DCELL *) inrast1[i])[col];
break;
for (i = 1; i <= nfiles2; i++) {
switch (in_data_type2[i]) {
case CELL_TYPE:
@@ -327,49 +364,102 @@
/* Find out the DOY of the eto image */
- /* DOY_eto_index = ModisDOY - etodoymin */
- doy[i] = d1[i] - etodoy+1;
- d_ETrF[i] = d[i] / d2[(int)doy[i]];
+ if ( d_null==1 || d1_null==1 )
+ G_set_d_null_value(&outrast[col],1);
+ else
+ doy[i] = d1[i] - etodoy+1;
+ if (G_is_d_null_value(&d2[(int)doy[i]]) || d2[(int)doy[i]]==0 )
+ else
+ d_ETrF[i] = d[i] / d2[(int)doy[i]];
- if (i == 1)
- DOYbeforeETa[i] = etodoy;
+ /* do nothing */
+ if ( d_null==1 || d1_null==1)
+ //G_message(" null value ");
else
- DOYbeforeETa[i] = 1+ (d1[i] + d1[i - 1]) / 2.0;
- if (i == nfiles1)
- DOYafterETa[i] = etodoy + nfiles2-1;
- else
- DOYafterETa[i] = (d1[i + 1] + d1[i]) / 2.0;
+ DOYbeforeETa[i]=0; DOYafterETa[i]=0;
+ if (i == 1)
+ DOYbeforeETa[i] = startperiod;
+ else
+ int k=i-1;
+ while (d1[k]>=startperiod )
+ if (d1[k]<0) // case were d1[k] is null
+ k=k-1;
+ else
+ DOYbeforeETa[i] = 1+((d1[i] + d1[k])/2.0);
+ break;
-/* //Sum over 8-day periods, if no missing periods
- DOYbeforeETa[i] = etodoy+8*(i-1);
- if (i == nfiles1)
- else
- DOYafterETa[i] = etodoy+8*i-1;
+ if (i == nfiles1)
+ DOYafterETa[i] = endperiod;
+ else
+ int k=i+1;
+ while (d1[k]<=endperiod)
+ k=k+1;
+ else
+ DOYafterETa[i] = (d1[i] + d1[k]) / 2.0;
+ break;
sum[MAXFILES] = 0.0;
- bfr = (int)DOYbeforeETa[i];
- aft = (int)DOYafterETa[i];
- sum[i]=0.0;
- for (j = bfr; j < aft; j++) {
- sum[i] += d2[(int)(j-etodoy+1)];
+ if(d_null==1 || d1_null==1){
+ /* do nothing */
+ else{
+ if (DOYbeforeETa[i]==0 || DOYbeforeETa[i]==0 ) G_set_d_null_value(&outrast[col],1);
+ else {
+ bfr = (int)DOYbeforeETa[i];
+ aft = (int)DOYafterETa[i];
+ //G_message("bfr=%i aft=%i", bfr, aft);
+ sum[i]=0.0;
+ for (j = bfr; j < aft; j++)
+ sum[i] += d2[(int)(j-etodoy+1)];
d_out = 0.0;
- d_out += d_ETrF[i] * sum[i];
+ if(d_null==1 || d_null==1){
+ else{
+ d_out += d_ETrF[i] * sum[i];
+ outrast[col] = d_out;
- outrast[col] = d_out;
if (G_put_raster_row(outfd, outrast, out_data_type) < 0)
