[GRASS-SVN] r33897 - in grass/trunk: gui/wxpython/gui_modules
lib/gis
svn_grass at osgeo.org
Thu Oct 16 05:20:20 EDT 2008
Author: martinl
Date: 2008-10-16 05:20:20 -0400 (Thu, 16 Oct 2008)
New Revision: 33897
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/lib/gis/parser.c
wxGUI: dbdriver/dbname widgets implemented
(merge from devbr6, r33895)
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-10-16 09:19:01 UTC (rev 33896)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2008-10-16 09:20:20 UTC (rev 33897)
@@ -8,6 +8,8 @@
- TreeCrtlComboPopup
- VectorDBInfo
- LayerSelect
+ - DriverSelect
+ - DatabaseSelect
- ColumnSelect
(C) 2007-2008 by the GRASS Development Team This program is free
@@ -455,6 +457,33 @@
self.SetItems(['1'])
self.SetStringSelection('1')
+class DriverSelect(wx.ComboBox):
+ Creates combo box for selecting database driver.
+ def __init__(self, parent, choices, value,
+ id=wx.ID_ANY, pos=wx.DefaultPosition,
+ size=globalvar.DIALOG_LAYER_SIZE, **kargs):
+ super(DriverSelect, self).__init__(parent, id, value, pos, size,
+ choices, style=wx.CB_READONLY)
+ self.SetName("DriverSelect")
+ self.SetStringSelection(value)
+class DatabaseSelect(wx.TextCtrl):
+ def __init__(self, parent, value='',
+ size=globalvar.DIALOG_TEXTCTRL_SIZE, **kargs):
+ super(DatabaseSelect, self).__init__(parent, id, value, pos, size)
+ self.SetName("DatabaseSelect")
class TableSelect(wx.ComboBox):
Creates combo box for selecting attribute tables from the database
@@ -472,12 +501,26 @@
if not choices:
self.InsertTables()
- def InsertTables(self):
+ def InsertTables(self, driver=None, database=None):
"""Insert attribute tables into combobox"""
items = []
- for table in gcmd.Command(['db.tables',
- '-p']).ReadStdOutput():
- items.append(table)
+ cmd = ['db.tables',
+ '-p']
+ if driver:
+ cmd.append('driver=%s' % driver)
+ if database:
+ cmd.append('database=%s' % database)
+ try:
+ tableCmd = gcmd.Command(cmd)
+ except gcmd.CmdError:
+ tableCmd = None
+ if tableCmd and \
+ tableCmd.returncode == 0:
+ for table in tableCmd.ReadStdOutput():
+ items.append(table)
self.SetItems(items)
self.SetValue('')
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-10-16 09:19:01 UTC (rev 33896)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-10-16 09:20:20 UTC (rev 33897)
@@ -1009,6 +1009,7 @@
valuelist=map( str, p.get('values',[]) )
if p.get('multiple', 'no') == 'yes' and \
+ p.get('gisprompt',False) == False and \
p.get('type', '') == 'string':
txt = wx.StaticBox (parent=which_panel, id=0, label=" " + title + ": ")
self.label_id.append(txt.GetId())
@@ -1036,7 +1037,7 @@
chkbox.Bind(wx.EVT_CHECKBOX, self.OnCheckBoxMulti)
which_sizer.Add( item=hSizer, proportion=0,
flag=wx.EXPAND | wx.TOP | wx.RIGHT | wx.LEFT, border=5 )
- else:
+ elif p.get('gisprompt',False) == False:
if len(valuelist) == 1: # -> textctrl
txt = wx.StaticText(parent=which_panel,
label = "%s. %s %s" % (title, _('Valid range'),
@@ -1133,8 +1134,10 @@
# GIS element entry
if p.get('prompt','') not in ('color',
'color_none',
+ 'dbdriver',
+ 'dbname',
+ 'dbtable',
'dbcolumn',
- 'dbtable',
'layer',
'layer_all') and \
p.get('element', '') != 'file':
@@ -1156,7 +1159,7 @@
which_sizer.Add(item=selection, proportion=0,
flag=wx.ADJUST_MINSIZE| wx.BOTTOM | wx.LEFT | wx.RIGHT, border=5)
# A select.Select is a combobox with two children: a textctl and a popupwindow;
# we target the textctl here
p['wxId'] = selection.GetChildren()[0].GetId()
@@ -1164,9 +1167,11 @@
if p.get('prompt', '') == 'vector':
selection.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
- # layer, dbcolumn, dbtable entry
- elif p.get('prompt', '') in ('dbcolumn',
+ # layer, dbdriver, dbname, dbcolumn, dbtable entry
+ elif p.get('prompt', '') in ('dbdriver',
+ 'dbname',
'dbtable',
+ 'dbcolumn',
'layer',
'layer_all'):
if p.get('prompt', '') in ('layer',
@@ -1180,11 +1185,23 @@
p['wxGetValue'] = win.GetStringSelection
win.Bind(wx.EVT_CHOICE, self.OnUpdateSelection)
win.Bind(wx.EVT_CHOICE, self.OnSetValue)
+ elif p.get('prompt', '') == 'dbdriver':
+ win = gselect.DriverSelect(parent=which_panel,
+ choices=p['values'],
+ value=p['default'])
+ p['wxGetValue'] = win.GetStringSelection
+ win.Bind(wx.EVT_COMBOBOX, self.OnUpdateSelection)
+ win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+ elif p.get('prompt', '') == 'dbname':
+ win = gselect.DatabaseSelect(parent=which_panel,
+ win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ win.Bind(wx.EVT_TEXT, self.OnSetValue)
elif p.get('prompt', '') == 'dbtable':
win = gselect.TableSelect(parent=which_panel)
- else:
+ elif p.get('prompt', '') == 'dbcolumn':
win = gselect.ColumnSelect(parent=which_panel)
@@ -1271,6 +1288,9 @@
pMap = None
pLayer = None
+ pDriver = None
+ pDatabase = None
+ pTable = None
pColumn = []
for p in self.task.params:
if p.get('gisprompt', False) == False:
@@ -1286,6 +1306,12 @@
pLayer = p
elif prompt == 'dbcolumn':
pColumn.append(p['wxId'])
+ elif prompt == 'dbdriver':
+ pDriver = p
+ elif prompt == 'dbname':
+ pDatabase = p
+ elif prompt == 'dbtable':
+ pTable = p
if pMap:
pMap['wxId-bind'] = pColumn
@@ -1294,6 +1320,15 @@
if pLayer:
pLayer['wxId-bind'] = pColumn
+ if pDriver and pTable:
+ pDriver['wxId-bind'] = [pTable['wxId'], ]
+ if pDatabase and pTable:
+ pDatabase['wxId-bind'] = [pTable['wxId'], ]
+ if pTable and pColumn:
+ pTable['wxId-bind'] = pColumn
# determine panel size
@@ -1442,34 +1477,43 @@
"""Update list of available layers, tables, columns for
vector map layer"""
id = event.GetId()
p = self.task.get_param(id, element='wxId', raiseError=False)
if not p or \
not p.has_key('wxId-bind'):
return
+ pType = p.get('prompt', '')
+ if not pType:
+ return
pMap = self.task.get_param('map', raiseError=False)
if not pMap:
pMap = self.task.get_param('input', raiseError=False)
- if not pMap or \
- pMap.get('prompt', '') != 'vector':
- return
if p == pMap:
map = event.GetString()
- else:
+ elif pMap:
map = pMap.get('value', '')
- if not map:
- return
for uid in p['wxId-bind']:
win = self.FindWindowById(uid)
name = win.GetName()
if name == 'LayerSelect':
win.InsertLayers(map)
+ elif name == 'TableSelect':
+ pDriver = self.task.get_param('dbdriver', element='prompt', raiseError=False)
+ driver = db = None
+ if pDriver:
+ driver = pDriver['value']
+ pDb = self.task.get_param('dbname', element='prompt', raiseError=False)
+ if pDb:
+ db = pDb['value']
+ win.InsertTables(driver, db)
elif name == 'ColumnSelect':
- pLayer = self.task.get_param('layer', element='name', raiseError=False)
+ pLayer = self.task.get_param('layer', element='prompt', raiseError=False)
if pLayer and \
pLayer.get('prompt', '') == 'layer':
if pLayer.get('value', '') != '':
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2008-10-16 09:19:01 UTC (rev 33896)
+++ grass/trunk/lib/gis/parser.c 2008-10-16 09:20:20 UTC (rev 33897)
@@ -373,6 +373,7 @@
Opt->required = NO;
Opt->multiple = NO;
Opt->description = _("Driver name");
+ Opt->gisprompt = "old_dbdriver,dbdriver,dbdriver";
break;
case G_OPT_DB_DATABASE:
Opt->key = "database";
@@ -381,6 +382,7 @@
Opt->required = NO;
Opt->multiple = NO;
Opt->description = _("Database name");
+ Opt->gisprompt = "old_dbname,dbname,dbname";
break;
case G_OPT_DB_COLUMN:
Opt->key = "column";
